Motor wiring / shaking in one place (solved)
Discussion in 'Controller Boards' started by KEITHABEAR, Jan 18, 2020.
  1. KEITHABEAR
    The openbuild control did a auto update and now my Z axes is jerking up and down . I tried to invert in the settings but nothing worked.
    I also had to reset the X&Y axes
    Very very unlikely to be update related. :)
    Jerky movement is almost always wiring: if only 3 of the 4 stepper motor wires are making good contact it shakes like that. Recheck your wiring, its been a while, some terminal maybe rattled loose, pulled out, or broke off (sometimes inside from continuous bending)
  3. KEITHABEAR
    That was it :), we had checked the wiring just not good enough.
