Motor Issues
Discussion in 'General Talk' started by Bryan Neiswanger, Dec 23, 2018.
  1. Bryan Neiswanger
    Finally got everything put together and all is good with X and Z but my Y and A seem to have issues going the same direction. I have checked and rechecked all my wires and all connections are correct but still can't get them to both got the same direction and they seem very noisy compared to X and Z. Any help would be greatly appreciated.
    Thanks,
    Bryan
  2. bubba
    bubba New
    The Y motors can't both go in the same direction. One has to, for lack of better term, go forward and the other motor has to go backwards. This should be as simple as wiring one of the motors 'backwards' to the other motor. If you are using connectors then rotate one of the connectors 180 degrees and plug back in.
  3. GrayUK
    Whilst bubba is right, remember that only applies to machines with belts. :rolleyes:
    Screw machine both go in the same direction. :D
  4. bubba
    bubba New
    You are absolutely right. I made an assumption about how the machine is configured. I should of asked more questions.
    GrayUK likes this.
  5. GrayUK
    I've been there as well. :banghead: That's why I noticed. :D:thumbsup:
  6. Bryan Neiswanger
    Sorry for the confusion I should have stated the machine which is a Sphinx 1050. Still haven't found anything that would cause this and it is intermittent. I disconnected the motor couplings and ran the Y axis and sometimes they would both turn right and other times they would turn opposite.
  7. Awestruck
    Awestruck New
    Are you using the XPRO controller? I'm not familiar with it, but I'm wondering if there is a setting in the config on your controller.
  8. Bryan Neiswanger
    Finally found the culprit last night. It ended up being a loose wire on the motor I was having trouble with. I had checked them by tugging on them all together so the bad wire didn't move but when I checked individually I was able to locate the bad one.
    Giarc, Peter Van Der Walt and GrayUK like this.
