Motor Coupling Question
Discussion in 'CNC Mills/Routers' started by Project Hopeless, Aug 28, 2019.
  1. Project Hopeless
    My ball screw kit came with 6.5x10mm motor coupling and I need 8x10mm. So I could drill out the ones I have. But I question how good these are to begin with.
    They are an aluminum alloy slit type with small 2.5mm screws to apply the clamping force. Wouldn't a slit type with set screws be better than the clamping type, less likely to slip?
    My steppers have a notch in the shaft for a set screw but the ball screws do not. If so do I grind a small notch in the ball screw shaft?
  2. Gary Caruso
    Yes grind a small flat for the setscrew,
    I would just buy the right size, If you have a metal lathe you can drill them out well enough but any other way will be disappointing, they are cheap on ebay any size you need.
    Use loctite.
    Gary
  3. kam
    kam New
  4. kam
    kam New
    On the ball screw, slide the coupling on the shaft. Use a transfer punch through the set screw hole and punch the shaft . Then take the coupling off and drill a dimple for the set screw to fit in .this is just another way instead of grinding the ball screw shaft.
  5. jeffmorris
    jeffmorris Journeyman
    I think that punching the shaft may bend the shaft.
  6. Gary Caruso
    don't punch it with your fists ;)
  7. Project Hopeless
    Loctite on just the screw correct?
  8. Gary Caruso
    You can put it on the coupler to rod interface as well.. just be careful if using red it will be difficult to get back apart if you need to.. :)
