More then 1 pointer
Discussion in 'Laser Cutters' started by Sander Pals, Nov 18, 2022.
  1. Sander Pals
    I have more then one pointers on my 3D view in openbuild controller… I reseted every setting, but it didn’t work. I even deleted openbuild and reinstalled it.
    When I start a new job, the program crashes. It gives different Alarm numbers every time I try. I use an Arduino Uno.
    Could someone help me?
    Sounds like EMI - make sure your Arduino is properly wired, shielded and all inputs filtered. Otherwise, consider a BlackBox
    Pressing Ctrl+F5 to refresh the UI should also work - the odd ones result from loss of comms caused by the EMI above
  3. Sander Pals
    Thank you for your reply Peter!
    I did everything to prevent electronical noise and EMI (see picture). I can move each axis on its own, but when I start a job (whitout plasma cutter turned on) it crashes. I did one job before this problem, but after this it didnt work anymore. Never changed the wirering.
    I consider buying a blackbox.
    Do you have any sugestions?
  4. Sander Pals
    *Job before the problem, it was with torch turned on.
    Proper CNC suitable Inverter, or repurposed hand-cutting HF start Plasma?
    Get a CUT50L
  6. Sander Pals
    But why do I need those if the cutter worked before?
    When I start a job without the torch turned on, it crashes. So the plasma cutter isn't the problem right?
    I am using a CUT50C.
    Could be EMI from motors, other devices - is the Arduino even genuine (or $2 ebay special?)
  8. Sander Pals
    Yes it is. I get your point, but moving the z-axis individually, it works.
    So is this stil EMI from the motors?
  9. Peter Van Der Walt
