MKS DLC32 do not home Z axis
Discussion in 'Controller Boards' started by Örjan, Apr 9, 2024.
Thread Status:
Not open for further replies.
  1. Örjan
    Örjan New
    I have built a small CNC and use MKS DLC32 to control it. I have adjusted all configurations so that X, Y, and Z move in the correct direction (0,0,0 in the upper right corner and -220,-285,-120 in the lower left). When I run the Home All command, only X and Y move, not Z. Can anyone see what I have done wrong?
    $0=10 ; Step pulse time, microseconds
    $1=25 ; Step idle delay, milliseconds
    $2=0 ; Step pulse invert, mask
    $3=0 ; Step direction invert, mask
    $4=0 ; Invert step enable pin, boolean
    $5=1 ; Invert limit pins, boolean/mask
    $6=1 ; Invert probe pin, boolean
    $46=10.000 ; Homing cycle 3
    $10=1 ; Status report options, mask
    $11=0.010 ; Junction deviation, millimeters
    $12=0.002 ; Arc tolerance, millimeters
    $13=0 ; Report in inches, boolean
    $20=1 ; Soft limits enable, boolean
    $21=1 ; Hard limits enable, boolean
    $22=1 ; Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
    $23=0 ; Homing direction invert, mask
    $24=300.000 ; Homing locate feed rate, mm/min
    $25=1000.000 ; Homing search seek rate, mm/min
    $26=250.000 ; Homing switch debounce delay, milliseconds
    $27=1.000 ; Homing switch pull-off distance, millimeters
    $28=1920.000 ; G73 retract distance, in mm
    $30=10000.000 ; Maximum spindle speed, RPM
    $31=0.000 ; Minimum spindle speed, RPM
    $32=0 ; Laser-mode enable, boolean
    $38=0 ; Spindle encoder pulses per revolution
    $40=1 ; Apply soft limits for jog commands, boolean
    $100=800.000 ; X-axis steps per millimeter
    $101=800.000 ; Y-axis steps per millimeter
    $102=800.000 ; Z-axis steps per millimeter
    $103=100.000 ; A-axis steps per degree
    $104=100.000 ; unknown
    $105=100.000 ; unknown
    $110=2500.000 ; X-axis maximum rate, mm/min
    $111=2500.000 ; Y-axis maximum rate, mm/min
    $112=2500.000 ; Z-axis maximum rate, mm/min
    $113=1000.000 ; A-axis maximum rate, deg/min
    $114=1000.000 ; unknown
    $115=1000.000 ; unknown
    $120=150.000 ; X-axis acceleration, mm/sec^2
    $121=150.000 ; Y-axis acceleration, mm/sec^2
    $123=200.000 ; A-axis acceleration, deg/sec^2
    $124=200.000 ; unknown
    $125=200.000 ; unknown
    $130=218.000 ; X-axis maximum travel, millimeters
    $131=285.000 ; Y-axis maximum travel, millimeters
    $132=120.000 ; Z-axis maximum travel, millimeters
    $133=300.000 ; A-axis maximum travel, degrees
    $134=300.000 ; unknown
    $135=300.000 ; unknown
    Flashed 2-axes firmware before?
    Wiring issue (test switches on troubleshooting tab)
  3. Örjan
    Örjan New
    Hmm, axes moves when jogging. The switches are ok (when testing them at the troubleshooting tab)
    still, did you?
    (only affects homing Frequently Asked Questions )
  5. Örjan
    Örjan New
    Thanks! I found it. In the G-code promt, first send: $Homing/Cycle0=Z
    and then $Homing/Cycle1=XY
    Everyting works fine!
    Case closed
    so not grbl then. Important to mention
Thread Status:
