mks dlc v2.0 i want more velocity
Discussion in 'Controller Boards' started by jbanti, Sep 14, 2019.
  1. jbanti
    jbanti New
    Hello,
    i'm jaume i'm new iin this forum.
    Recenlty i purchased a acro laser system 1000*1000 with a nema 17 1,68A77oz steppers motors and a control board mks dlc v2.0.
    I tested it with a lightburn software. The problem is i cannot work fast than 500mm/min
    in the settings i put 5000 (for example) but i have no results.
    my question is the limit of velocity is for my controlboard? (its a system based in arduino uno)
    do you know a more powerful controlboards?
    thanks
    Try a OpenBuilds BlackBox 4X Documentation - way better stepper drivers so you will have enough speed, still based on Uno/grbl so nothing hard to learn, lots of info. Best of both
  3. jbanti
    jbanti New
    Thanks, i have found the grbl codes specifically $110, $111, $112, $32 and $120, $121, $122 and now it works fast and fine
