min spec pc to run cnc
Discussion in 'General Electronics' started by arp, Apr 26, 2021.
  1. arp
    arp New
    hi im spending my cash on the cnc im not putting my good pc in the shed with the cnc
    so ill have to buy a second had pc laptop to run it
    what specs do you recommend min spec to run
  3. arp
    arp New
    Regardless, thats a good set of specs which covers the needs of Grbl hosts with 3D viewers etc as well. Its pretty sane.
    And trust me (; nothing worse than having to walk back inside for a quick reCAM while you sit by the machine... You'll run a copy of your CAM on there sooner or later
    If you really just want to run the machine, get an Interface:
  5. arp
    arp New
    i saw a youtube video with a guy plugging and unplugging the interface to get his usb working
    and i do have a rep of having bad luck in fact id go as far to say if i did not have bad luck i would not have any luck at all
    and the comments below the video are suspect
    and its going to be 250GBP time i import and pay tax
    First batch issues, long since resolved. Factory just fitted incorrect USB ports. All the bad ones was replaced. Read the replies in those comments threads - they do mention the swop outs and great customer service too
