Maximum bed size
Discussion in 'General Talk' started by markus506, Jan 9, 2023.
  1. markus506
    markus506 New
    Hi there,
    I am planning on using the CNC electronics bundle to make a custom 2D gantry to move a camera around. The gantry is approximately 13 ft x 13 ft. Is there any limitation in the controller/included software that would limit the bed size?
    Thanks!
    Only mechanical :)
    Things like How to calculate V-Slot® deflection, belt vibration and stretch, that sort of things are what you got to look out for
  3. David the swarfer
    I remember a discussion on length limits for GRBL but google is failing to find it, was probably part of a text based discussion group that has disappeared..
    There IS an axis length limit, dependent on the steps/mm and the size of the internal step counters.
    GRBL has to translate any movement command from inches/mm to 'steps to do'.
    My belt driven machine is set at 40 steps/mm and is 750mm on the Y axis.
    So end to end, from 0 to 750mm it would take 30000 steps, a number easily stored in a 2 byte signed integer and even easier in a 4 byte integer.
    A slightly longer axis of 820mm would exceed a 2 byte integer, which is why GRBL uses 4 byte integers.
    To exceed the 4byte int would take an axis of over 53million mm. So not a practical limit, really. (-:
    We can run into problems with very high resolution. If we use a low pitch leadscrew, say 2mm, and very high microstepping, say 256, and a reduction gearbox of say 40:1
    we end up with 5120 steps/mm which gives us a length of ~419meters.
    This might be exceeded on a rotary axis doing long continuous rotations when pretending to be a lathe.
    So, not generally a practical limit but it does exist (-:
  4. markus506
    markus506 New
    Thank you all for the information!
