Bang my head on this one for days, Finally add a laser to the setup, (pwm>spindle) It works, but the M5 doesn't want to do his job Mach4 keep hanging on the M5 (after a stop & run it does work...till the next M command) this works: laser goes on & stop's after 5s S500 M3 G4 P5000 M5 But when there is code in between = no go Same goes on with the S command (only works once) I can run a normal fusion 360 contour, everything goes well till the M5. i guess this problem is there from the beginning , i turn on the spindle manuaal. Grts, Mach4_mill_6 axis (also tested some laser programs where u can set the m3 once, but then the S command stop the gcode)
Finally after update all the programs (pokey/a new mach4) it's working. works now on M3 and M4 stop M5 gcode runs the full code now. Tried quick the ob software, but was shooting dots instead of a nice line yeah!
