mach 3 usb w onboard drivers
Discussion in 'CNC Mills/Routers' started by David Casto, Oct 25, 2019.
  1. David Casto
  2. jeffmorris
    jeffmorris Journeyman
    Don't buy it.
  3. phil from seattle
    phil from seattle Journeyman
    Agreed. Don't. To amplify, it will require a mach 3 license and a PC with a parallel port. An Arduino and a shield will be much cheaper and do fine.
  4. David Casto
    this is the actual one I bought
    I posted the wrong one first and didnt know how to change it. sorry for the confusion
    I am currently using an Eleksmaker Eleksmana ver 5.2 and it does great job nut i need to be able to push more power to my stepper motors and sadly I already purchased thie above controller. I will try to use it but worst case I learned a somewhat cheap lesson. but also this board has now parallel or com ports only the usb port. I like using estlecam can you give me the name of a controller card that can push 3.5 amps to my stepper motors.
  5. Alex Chambers
    Blackbox from Openbuilds BlackBox Motion Control System.
    There are others, but I am biased :D:D:D:ROFL:
    And software to control it is available from Openbuilds for free.
    #5 Alex Chambers, Oct 26, 2019
  6. Giarc
    If you use Estlcam and like it, you can buy an Arduino board and DQ542ma drivers. I use this combination with Estlcam. But, if I were doing it now, I would use the Blackbox because it would be easier with the required amperage for my needs
    Alex Chambers likes this.
    Estlcam can be flashed to the BlackBox too, its still an Arduino Uno with stock Grbl pinout at heart
