Mach 3 on Blackbox 1510
Discussion in 'Control Software' started by Axlhoss, Jul 30, 2020.
  1. Axlhoss
    Axlhoss New
    Tryin to run Mach 3 on my 1510 with blackbox.
    Any pointers on setup would be much appreciated.
  2. Giarc
    Mach 3 does not work with the Blackbox. Blackbox uses the free Opensource GRBL software.
    Rick 2.0 likes this.
  3. Axlhoss
    Axlhoss New
    Is there any other driver software besides the Openbuilds driver that can stop and start/restart files mid cut?
    Thanks,
  4. Axlhoss
    Axlhoss New
  5. Giarc
    Estlcam is what I use and it works great. Estlcam: 2D / 3D CAM und CNC Steuerung... It has tool change functions and lots of probing functions. I start and stop files in mid cut all the time. I do all of my drilling first while the workpiece is clamped down. Then, I stop the file and jog the spindle and gantry away from the work piece and screw it down using the newly drilled holes. As soon as it is fastened down, I resume the job.
    Axlhoss likes this.
  6. Giarc
    Estlcam works with the Blackbox. Just set it up as an Arduino using grbl 1.1.
    Axlhoss, JustinTime and Rick 2.0 like this.
