M5 Low Profile Screw Counterbore bit?
Discussion in 'Other Builds' started by Greg Shapps, Oct 25, 2021.
Tags:
  1. Greg Shapps
    I am struggling with finding the proper Counterbore Bit for use with the M5 Low Profile screws. I would like to use my drill press to sink the Low Profile screw heads in an aluminum plate I am using just like the holes on the C-Beam Motor Mount Plate. Does anyone have a link for the correct size bit to do the counterboring?
    Should be a 10mm diameter, but check the screw heads with a caliper if in doubt
