Looking for plate with Extra Z for workbee
Discussion in 'CNC Mills/Routers' started by laurent Besseas, Jun 12, 2020.
  1. laurent Besseas
    Hello, openbuild shop didn't sale plate for extra Z dimension.
    I look at [spam link removed] without success. Any idea from where I can get them as I need to get 155mm clearence on Z.
    #1 laurent Besseas, Jun 12, 2020
  2. Alex Chambers
  3. laurent Besseas
    Thanks, in this case Lead CNC is probably a better choice right away.
  4. Alex Chambers
    Probably so - I had assumed from your original message that you were wanting to modify a workbee you already had. If it's a completely new machine you are looking for then the Lead 1010 with the high Z mod would seem to meet your needs.
  5. laurent Besseas
    I need to invest into one CNC but it need to be shorter XY for higher Z or wider XY for smaller Z, we can't get the best of both on stock!
    As the LEAD uses NO custom plates at all, its all off-the-shelf parts from openbuildspartstore.com you can modify it to your hearts desire. Watch the build video, explore the sketchup model, and you'll see what you want to swop
    So no need for taller "Z plates" - on the LEAD the sides are just off the shelf pieces of V-Slot (you can order in 250,500, etc lengths, or order long and cut yourself any length you need)
    #6 Peter Van Der Walt, Jun 12, 2020
    laurent Besseas likes this.
  7. aluminumwelder
    where can I find the workbee lead screw plates? I want to modify them from stock. I searched the openbuilds Grab Cad, the PDF's and Sketchup and only sketchup has the work bee Y axis plates, but they are for the belt verison, not the lead screw. thanks.
  8. Giarc
