Looking for assistance with Vcarve pro and IOT relay
Discussion in 'CAM' started by Darkfader, Oct 20, 2022.
  1. Darkfader
    Darkfader New
    I have read the post processor editing doc, but I am unsure of myself and don't want to mess anything up. If someone could explain this to me like I am a complete idiot, I would greatly appreciate it. I've never edited G-code before and this is intimidating.
    I'm using an OpenBuilds Lead 1515, BlackBox, and Touch Interface. I just purchased an IOT relay outlet and want to use it to power on the Dewalt 611 router when I run the job, and then power off when the job is complete.
    My workflow is generally, do my design work and generate toolpaths in VCarve Pro, then save to a thumb drive and run jobs directly from the Touch Interface so that my computer is not in the workshop at all.
    When I went into the Post Processor Management section in Vectric, I see this:
    begin HEADER
    "T1"
    "G17"
    "G21"
    "G90"
    "G0[ZH]"
    "G0[XH][YH]"
    + Command output after the header to switch spindle on
    begin SPINDLE_ON
    "M3 [ S ]"
    "G4 P1.8"
    + Commands output for rapid moves
    **I added spaces between the brackets and the S after M3 above because it was causing a strikethrough to the rest of the post. I don't know why that was happening.
    Then at the bottom is this:
    + Commands output at the end of the file
    begin FOOTER
    "M5"
    "G0[ZH]"
    "G0[XH][YH]"
    "M2"
    I've read that I need "M3S1000" in the header. Do I remove the brackets or do they stay? "M5" is already in the footer, so is that all I need? It's also stated that a copy needs to be made and I saw others state that the file needs to be saved as a text file versus a pp file and I am just lost as to how to set this up. Basically no clue what I'm doing here and the more I read the worse it gets.
    I've also read it's not good to run the shop vac and the router off the same IOT. If this is accurate, do I run signal wires from the same connections on the black box to two separate IOT's?
    I'd greatly appreciate any help.
    #1 Darkfader, Oct 20, 2022
  2. sharmstr
    You dont need to edit the post processor. Just make the blackbox to IOT connection per the directions. docs:blackbox:connect-dewalt-iotrelay [OpenBuilds Documentation]
    Plug your router and the vac into the normally off outlets. Make sure your router and vac power switches are turned on. I've run a dewalt and a vac off a 15amp circuit but felt better when it was on a 20amp circuit.
    vcarve will always put an M3 (on) and a M5 (off) command in your gcode files. In fact, you can see them in the post processor info you posted :)
    Giarc likes this.
  3. Darkfader
    Darkfader New
    Awesome. Thank you kindly.
