Locktite for Fasteners into T-Nuts?
Discussion in 'General Talk' started by Matt_Batt, Oct 4, 2019.
  1. Matt_Batt
    Matt_Batt New
    Hi, apologies if this is a dumb question...
    So for many of the threaded connections in the OpenBuilds system the screw is going into a nyloc nut - therefore vibration induced loosening shouldn't be an issue.
    BUT - what about when we're joining parts by screwing M5's into T-nuts of various types, and the sub-assembly which is being connected is subject to vibration? (ie it's getting moved around a lot) In this case is it a good idea to use locktite or similar on the fasteners that are being screwed into the T-nuts?
    Just to be clear - I don't mean to keep the T-nuts in place where they are in the rail (use spring loaded T-nuts for that of course!), but rather to keep the M5 screw from coming loose out of the T-nut.
    Thanks for your advice!
  2. Alex Chambers
    Hi @Matt_Batt, loctite if you think that the part might be subject to a lot of vibration - but don't use the permanent variety!
    Also, a general point on nylocs - especially the small sizes - don't grip after a few dismantlings/re-assembly.
    Matt_Batt and sharmstr like this.
  3. Matt_Batt
    Matt_Batt New
    Thanks very much for your advice, Alex.
    Cheers!
