Load and load bearing.
Discussion in 'General Talk' started by DarkAlchemist, Sep 18, 2015.
  1. Joe Santarsiero
    Joe Santarsiero OB addict
    If you want to check for critical failure you have to select this in the study advisor (see pic.8).
  2. DarkAlchemist
    DarkAlchemist Well-Known
    Right, I know, but my point was 100 pounds on that beam should bend it much farther down than 1/10 of 1mm. I am not believing SW's numbers though it is probably something we aren't doing right. If I had 3 beams here I would find something one hundred pounds and tie a string in the middle of the beam (with both ends fixed to the other beams) and I bet a dollar to a doughnut that beam deflects way more .1mm and my jaw would drop if it didn't. :)
