limit switches
Discussion in 'CNC Mills/Routers' started by ZINN, Jul 4, 2019.
  1. ZINN
    ZINN Well-Known
    Is it possible to install all 6 limit switch positions on an openbuilds 1010 with black box controller which onl has 3 locations for limit switches?
  2. sharmstr
    sharmstr Master
  3. ZINN
    ZINN Well-Known
    How do the connections on limit switches labeled C NO NC match up with the 3 pin connectors on the Black Box (GR L D)?
  4. sharmstr
    sharmstr Master
  5. ZINN
    ZINN Well-Known
    I am trying to add 3 additional 2 wire limit switches that I have to the 3 wire connections that are hooked to the Black Box. So can I hook the C to the GND and the NO to the SIG for a normally open setting? Is the 3 wire connection configuration at the Black Box a normally open configuration for the new GND - V+ - SIG limit switches ?
  6. sharmstr
    sharmstr Master
    Ignore the V+ pin. The link I sent you says "TIP: To use Normally-Open switch wiring, ensure that $5=1 in your Grbl settings". In other words, the BB will work with either NO or NC wiring. You just need to make sure you set $5 in grbl correctly.
  7. ZINN
    ZINN Well-Known
    Thanks, I will try this.
