Limit Switches not working
Discussion in 'General Electronics' started by Keith Robinson, Dec 15, 2019.
  1. Keith Robinson
    Whenever I hit Home and the Z limit closes, the sequence shuts down. I have to disconnect, physically move the z axis off the limit and reconnect. If I move the X to the limit, it shuts my PC off, assuming it is overloading the USB connection due to a short. I have the ground to the common and the red to the NO pin. On the blackbox, I have them in the ground and power pins for each axis. The blackbox is not seeing the limits. I dont know where I am screwing it up. Please help.
  2. Gary Caruso
    Hi Keith, make sure you are wired signal to ground, not ground to 5v.
    Gary
    GND and SIG please!
    V+ (Power) is for ACTIVE endstops that need power! Like Xtension limits, or Inductive Sensors. Always follow docs.openbuilds.com/blackbox for any wiring!
  4. Ron Smith
    Ron Smith New
    Did you get your problem fixed?
    Did you double check your wiring against docs.openbuilds.com?
