Limit switches false alarm
Discussion in 'General Electronics' started by Tajudeen, Oct 21, 2019.
  1. Tajudeen
    Tajudeen New
    I updated open builds control software 3 days ago (don't know if this is mere coincidence/I am currently thinking of going back to previous working update) and subsequently started getting limit switches false alarm as seen in the attached image. Please help resolve. I have applied several solution like that on git hub and many others except changing all my cables to shielded type.
    Note that I am running blackbox on a 1515 cnc router. Thank you
    Staff Member Moderator Project Maker Builder Resident Builder
    EMI on limit switches can be hard, see the Grbl Wiki for some more wiring schemes: gnea/grbl
    Or take the easy way out and use our Xtension Limits with onboard filtering, troubleshooting LED and easy to mount package: Xtension Limit Switch Kit
    Mark Carew, Alex Chambers and MaryD like this.
  3. phil from seattle
    phil from seattle Journeyman
    Best to use shielded wiring.
    If you are going to use those Open Builds limit switches, you will still want shielded wiring - noise can be introduced on the wires. Honestly, I don't think filtering at the switches is that effective as the wires between the switch and controller act like antennas.
    Unless its near an HF start plasma or VFD inverter, you shouldnt need shielded wiring. BlackBox also has filtering onboard too
  5. Tajudeen
    Tajudeen New
    Thank you for the info
  6. Tajudeen
    Tajudeen New
    Thank you for your help. I have resolved using the settings link
