limit switches can't be inverted
Discussion in 'OpenBuilds Forum Help' started by heldenfrosch, Apr 16, 2023.
  1. heldenfrosch
    Hi!
    I use NPN NO proximity switches with my new Blackbox. I flashed new firmware.
    They are wired correctly, the LEDs work.
    ? shows Pn: PXYZ when limit pins are not inverted. After inverting it shows PYZ. Homing then works for X, but of course not for Y and Z.
    Any ideas why X obviously can be inverted but Y and Z not?
    Thanks in advance
    Matthias
    in CONTROL use the troubleshooting page to check that the switches correctly trigger AND trigger the correct axis.
    ignore my probe input, the external optocoupler inverts it and that is not currently connected.
  3. heldenfrosch
    Hi!
    Thanks for the quick reply. I did this already, the right axis get triggered when tested manually before inverting. By default all switches are triggered.
    When I change $5 from 0 to 1:
    Y and Z can still be untriggered manually.
    X32: $5=0 or $5=7 if you want it to act on all.
    Its a bitmask. X=1, y=2, z=4. XYZ =1+2+4=7
  5. heldenfrosch
    Hey Peter!
    I didn't know that. Great, that did the job!
    The next problem is, that the laser won't fire on full power. M3S100 leads to ca. 350mV PWM. Here are my settings. Any idea?
    Thanks in advance!
    Matthias
    $0=8.0
    $1=25
    $2=1
    $3=0
    $4=0
    $5=7
    $6=0
    $7=0
    $8=0
    $10=509
    $11=0.010
    $12=0.002
    $13=0
    $14=0
    $15=0
    $16=0
    $17=0
    $18=0
    $19=0
    $20=0
    $21=1
    $22=1
    $23=3
    $24=50.0
    $25=500.0
    $26=250
    $27=10.000
    $28=0.100
    $29=0.0
    $30=1000.000
    $31=0.000
    $32=1
    $33=5000.0
    $34=0.0
    $35=0.0
    $36=100.0
    $37=0
    $39=1
    $40=0
    $43=1
    $44=4
    $45=3
    $46=0
    $62=0
    $63=3
    $64=0
    $65=0
    $70=7
    $73=1
    $74=
    $75=
    $100=320.000
    $101=160.000
    $102=320.000
    $110=500.000
    $111=500.000
    $112=500.000
    $120=10.000
    $121=10.000
    $122=10.000
    $130=200.000
    $131=200.000
    $132=200.000
    $300=Grbl
    $302=192.168.5.1
    $303=192.168.5.1
    $304=255.255.255.0
    $305=23
    $306=80
    $307=81
    $341=0
    $342=30.0
    $343=25.0
    $344=200.0
    $345=100.0
    $370=0
    $384=0
    S100= 100/1000 = 10% of 3.3v = 330mv so spot on yes
    You want S1000
    Use the provided Tool On menu in CONTROL it does that kind of math for you, and you can learn from the commands it sends :)
  7. heldenfrosch
    Hi! Thanks! This test with the tool button showed that I can get the 100% or 3.3V.
    The problem is, that no matter what job I start the laser won't go above 20% or so. GCode says M4
    S1000F24000
    I spent so much time trying everything I could without any change.
    Thanks for your help!
    That is correct (if $30 is still set to 1000, just make sure it did not change)
    M4 is Dynamic Power - so have read through Grbl v1.1 Laser Mode
    If your acceleration is set too low it won't ramp up to full power sometimes
    Post a full Grbl Settings backup for review
  9. heldenfrosch
    Hey Peter!
    Great! The acceleration was the problem. Now everything works fine!
    Thank you so much! It's been a struggle for several months with 2 broken XPros.
    Cheers!
    Matthias
    Sorry to hear that - did you find root cause?
    Just raising potential issue - if it was something like using a 3rd party PSU (not ours) and not replacing it, or a short in the wiring never found - we don't want you having any more struggle later on with a broken BlackBox :)
  11. heldenfrosch
    Hi!
    I added a diode laser to my diy mill (CS MIO). Therefore I made an entirely separate controller-setup.
    The first XPro broke due to a shortage, maybe caused by wrong wiring of proximity switches. The reason for several trials was, that Spark Concepts didn't say anywhere and not in support communication that PNP won't work. Openbuilds is very clear in this.
    The second one had obviously a hardware failure. First everything worked well. Now it permanently sends PWM of 1.3V, even when nothing is plugged in. No chance to fix this, also not with resistor. Wiring the laser via relay was suggested by Spark Concepts, but this left the laser still firing permanently on high power.
    I like the Blackbox.
    Can I use the door port also like an end stop/emergency button?
    Cheers and thanks again!
    Matthias
  12. Peter Van Der Walt
    If that damage was caused by the Laser module itself, BB could be at risk too.
    It's not advisable...
    Creates a possibly false sense of safety!
    We don't recommend a software based Emergency stop / button connected to a controller thats dependent on controller/firmware/computer etc.
    The software has an Abort (click button or ESC key on keyboard) for less-real emergencies, but a proper E-Stop should ALWAYS cut ALL power to the machine.
    We recommend Wall Socket > https://www.rockler.com/safety-power-tool-switch > Power Strip> Everything else (Machine, Spindle, Dust extractor etc). In a real emergency you want to cut power to EVERYTHING at once. What if the dust extractor caught fire. Or the PSU is on fire. Or someone's hand is stuck under the router. That's why we advise against a software/controller based solution. When life, limb or property is at risk, cutting power is the safer option
  13. heldenfrosch
    Hi!
    How can we know if this was caused by the laser module?
    You aee right, I will install a switch that powers of the main wire...
    Matthias
  14. Peter Van Der Walt
    Best I can offer there is "go with your gut"
    If you are not 100% sure it could have been a mistake, a loose wire straggler outside a terminal, or some other explainable short/fault/accident - one would always wonder what really happened.
    Is the module from a reputable source (JTech or Optlaser). If not, do you, ultimately, trust them.
    Best case, it can damage a single output pin - with some effort you can remap pins in firmware (swop enable and PWM for example). But depending on what it did it may fry more
