Limit switch documentation fault?
Discussion in 'Control Software' started by KasperV79, Jan 8, 2020.
  1. KasperV79
    KasperV79 New
    Hi guys.
    Im wondering if did writing error in the documentation.
    OpenBuilds BlackBox 4X Documentation
    "TIP: To use Normally-Open switch wiring, ensure that $5=1 in your Grbl settings"
    This seems quite wrong. Im using NC homing switched and they work correctly when $5=1, also the graphic in troubleshooting where limitswitch states can be seen are correct when $5=1 on NC switches.
    so I guess there's typo?
    Giarc likes this.
    Good catch! Will update it to be $5=0 :) Thank you!
    KasperV79 likes this.
