LED spindle ring with Xpro v4
Discussion in 'General Electronics' started by Apeli, Dec 7, 2019.
  1. Apeli
    Apeli New
    Is there a way to wire the OB Led spindle ring (Spindle / Router LED Light Ring) directly from a xPro v4 controller? Ideally in a way that you could turn it on/off via gcode.
    The ring is 24v and there is a +12-24 V output + ground marked on the xpro spec, but nothing happens when I use that. I power the xpro with an ATX computer power source.
  2. sharmstr
    I'm pretty sure that 12-24 output will match the supply voltage. So, 12v in means 12v out.
    Apeli likes this.
    ATX = 12v
    The ring needs 24v
