Lead 1515 problems
Discussion in 'CNC Mills/Routers' started by dr_chops, Dec 13, 2022.
  1. dr_chops
    dr_chops New
    Hi can can anyone help me out my machine seems to be all over the place. Can anyone shed any light as to what’s going on? Sometimes it runs alright then the y axis wants to go in different directions
    cheers
    Lucas
  3. dr_chops
    dr_chops New
    but why all of suden tho?
    Do the checks first to confirm it is the case, but if it is - couple possible reasons:
    - a terminal left slightly loose and wire pulled out recently
    - terminated with insulation pinched into terminal along with the wire causing bad contact
    - terminal loose enough to cause a bad connection, but not pulled out yet
    - cable management issue causing some tight radius bends, or stretch/strain/pinch point issues causing damage to the extension cables itself
    - etc
    The symptoms are consistent with what you'd see if only 3 of the 4 wires are making solid contact throughout
  5. David the swarfer
    because the machine moves and vibrates and copper work hardens and cracks when bent repeatedly.
    that is why we use cable chains and cable chain rated cables inside them (preferably) and we make sure that no moving wire makes a sharp angle, smooth easy curves is what we want, with no stress points..
