Lead 1515 4th Axis
Discussion in 'CNC Lathes' started by Maximilian Zödl, Aug 22, 2024.
  1. Maximilian Zödl
    Hey,
    I converted my Lead 1515 cnc to a lathe!
    Now i have a few questions:
    1. I use VCarve to create the G Code, what postprocessor can i use? I tried Wrap Y2A but Openbuilds Control doesnt recognise it.
    2. For now i just use normal GCode which works for now, except i have issued with holes , they get ellipitical, does anyone know why?
    That you in advance,
    Max
    You may need to customize a post, I don't know of a Vectric post that supports A yet (wrapping was more for X/Y wrapping) - but might be better to ask Vectric Support they might have a grblHAL compatible post for you: Contact us〡Vectric
    We have a post for Fusion GitHub - OpenBuilds/OpenBuilds-Fusion360-Postprocessor: Post Processor for Fusion 360 for use with OpenBuilds Machines running Grbl 1.1 only at this time (proper 4th axis, not wrapping)
    The viewer doesn't preview 4 axes code, but should still run if its compatible with the firmware 3D Viewer - Updates needed (Drill cycles, Rotary, etc) · Issue #278 · OpenBuilds/OpenBuilds-CONTROL
  3. Maximilian Zödl
    thank you, the software works fine now!
    but i do still have the problem with the oval shaped holes, and i think it may be caused by backlash in my stepper motor. are there any chances to reduce these (increasing current?) or is it maybe a software problem?
  4. David the swarfer
    backlash is always mechanical, something loose somewhere.
    a regular oval hole is more lilkely calibration, X or Y is travelling further/less than Y or X.
    but a hole with kinks in it is backlash, caused by the motor turning but not moving that axis after a direction reversal.
