LEAD 1010 with CNC4Newbie 7" Slider
Discussion in 'CNC Mills/Routers' started by FredTheNuke, Apr 21, 2019.
  1. FredTheNuke
    Hi all. I am working on installing this head on my LEAD 1010. Below are a few pics of what I came up with based on hole alignment and available hardware. Obviously this isn't the intended installation of this head. I gain no height and using the motor to lift itself is counter intuitive. Anyone have a video or pictures of this head installed? Beauty of this hobby is we can modify stuff to work if need be!!!
  2. sharmstr
  3. FredTheNuke
    Hmmm. now to figure out how he managed to align the second universal plate holes with the back of the slider...... I must have missed something. also wondering how he got them so tight onto the x gantry universal plate.
  4. sharmstr
    I believe he told them what plate he is using when he ordered it. He mentions that in those threads.
  5. FredTheNuke
    ****!!!! Sharmstr you are the MAN! I feel quite humbled that I missed the hole alignment - you can even pass a tool thru the back gantry plate to avoid using a standard hex key.... I owe you one! Now to solve the router mount issue. Then wire this machine. I can't power it up as my Blackbox won't arrive until later next week.
  6. sharmstr
    Awesome!
    (I'm a woman but I understand your sentiment).
  7. FredTheNuke
    Even better! Glad we have all folks represented in this community! Thanks again.
  8. FredTheNuke
    Problem is solved. You have to remove the front plate off of the linear guides, etc. And carefully reassemble and align. There are countersunk holes on the back that line up with the Openbuilds mount. Hopefully this helps the next person that does this upgrade!
  9. sharmstr
    Appreciate the follow up and pics. Makes it easier for me to answer a question i know nothing about. Lol
