Lead 1010 Max speed for cutting foam board
Discussion in 'CNC Mills/Routers' started by BillyTheClown, Jun 5, 2024.
  1. BillyTheClown
    Just upgraded to Lead 1010 with high-z, expect to do my first cut tonight or maybe tomorrow night...
    On my old (slow) CNC I use cheap Home Depot pink foam insulation board for test cuts.
    I set the system MAX Feed/Plunge speeds in my Aspire tool path for the test cuts, and usually just do the finish pass skipping the roughing pass.
    What is the max feed speed for the lead 1010? Plunge speed?
    Looking at the doc but unable to find the values.
    Thanks..... Billy
    Click Grbl Settings tab: see $110-112 Grbl v1.1 Configuration
  3. BillyTheClown
    Peter, Thank you...
    Need to start reading Grbl settings..... Still a lot to learn..
