LEAD 1010 having troubles with Hello World test
Discussion in 'CAM' started by davabran, Feb 13, 2019.
  1. davabran
    davabran New
    Hello,
    I have the LEAD 1010 freshly assembled and am pretty excited to get things working. I having trouble getting the Hello World example working with my machine. The problem is I set my bit to work 0,0,0 on my board and i run the Hello World example the Z axis goes in the Z+ direction till it hits the limit switch stopping the run. My motors are connected correctly as the X+ moves right, Y+ moves away, and Z+ moves up away from the board. In the openbuilds code generator I set to the LEAD 1010 machine with a 3.175mm diam. bit. My Openbuilds Control machine driver is set to LEAD 1010. I'm probably overlooking a something simple, but this gcode stuff is new to me. I don't understand the G54 line or G90 line in the code. Linked below is a video of the problem I'm having, I'll also list my gcode. Any advice is appreciated.
    My spoil board is 3/4" mdf and my test piece is 3/4" mdf. I know this is a taller setup but it was cheap scraps I found. I know i'm losing some Z height, but I thought I should still have enough room for this operation. In the beginning of the gcode has "G0 Z7" so 7mm in the Z+ direction, but at the start it seems to go a lot more then that and hits my limit switch stopping the run.
    G-Code
    Code:
    ; GCODE Generated by cam.openbuilds.com on 2019-02-13
    G21 ; mm-mode
    G54; Work Coordinates
    G21; mm-mode
    G90; Absolute Positioning
    M3 S1000; Spindle On
    ; Operation 0: CNC: Vector (path inside)
    ; Tool Diameter: 3.175
    G0 Z7
    G0 F1000 X88.5473 Y104.7872
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X91.1946 Y104.5565 Z-1.0000 S1000
    G1 F1000 X92.4876 Y104.6196 Z-1.0000 S1000
    G1 F1000 X93.6603 Y104.8078 Z-1.0000 S1000
    G1 F1000 X94.6847 Y105.1103 Z-1.0000 S1000
    G1 F1000 X95.5774 Y105.5221 Z-1.0000 S1000
    G1 F1000 X96.3625 Y106.0355 Z-1.0000 S1000
    G1 F1000 X97.0450 Y106.6382 Z-1.0000 S1000
    G1 F1000 X97.6286 Y107.3319 Z-1.0000 S1000
    G1 F1000 X98.1173 Y108.1217 Z-1.0000 S1000
    G1 F1000 X98.5080 Y109.0306 Z-1.0000 S1000
    G1 F1000 X98.7974 Y110.0972 Z-1.0000 S1000
    G1 F1000 X98.9785 Y111.3378 Z-1.0000 S1000
    G1 F1000 X99.0396 Y112.7253 Z-1.0000 S1000
    G1 F1000 X98.8992 Y114.6215 Z-1.0000 S1000
    G1 F1000 X98.5002 Y116.2066 Z-1.0000 S1000
    G1 F1000 X97.8621 Y117.5245 Z-1.0000 S1000
    G1 F1000 X96.9863 Y118.6172 Z-1.0000 S1000
    G1 F1000 X95.8787 Y119.4868 Z-1.0000 S1000
    G1 F1000 X94.5263 Y120.1232 Z-1.0000 S1000
    G1 F1000 X92.8846 Y120.5224 Z-1.0000 S1000
    G1 F1000 X90.9378 Y120.6611 Z-1.0000 S1000
    G1 F1000 X89.0430 Y120.5206 Z-1.0000 S1000
    G1 F1000 X87.4374 Y120.1167 Z-1.0000 S1000
    G1 F1000 X86.0963 Y119.4692 Z-1.0000 S1000
    G1 F1000 X84.9788 Y118.5787 Z-1.0000 S1000
    G1 F1000 X84.0887 Y117.4603 Z-1.0000 S1000
    G1 F1000 X83.4411 Y116.1154 Z-1.0000 S1000
    G1 F1000 X83.0365 Y114.5006 Z-1.0000 S1000
    G1 F1000 X82.8949 Y112.5786 Z-1.0000 S1000
    G1 F1000 X82.9654 Y111.2032 Z-1.0000 S1000
    G1 F1000 X83.1733 Y109.9695 Z-1.0000 S1000
    G1 F1000 X83.5076 Y108.8931 Z-1.0000 S1000
    G1 F1000 X83.9664 Y107.9497 Z-1.0000 S1000
    G1 F1000 X84.5302 Y107.1222 Z-1.0000 S1000
    G1 F1000 X85.1644 Y106.4244 Z-1.0000 S1000
    G1 F1000 X85.8638 Y105.8550 Z-1.0000 S1000
    G1 F1000 X86.6404 Y105.4011 Z-1.0000 S1000
    G1 F1000 X87.5350 Y105.0440 Z-1.0000 S1000
    G1 F1000 X88.5473 Y104.7872 Z-1.0000 S1000
    G0 Z7
    G0 X66.2383 Y120.3472
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X66.2383 Y104.8711 Z-1.0000 S1000
    G1 F1000 X77.8213 Y104.8711 Z-1.0000 S1000
    G1 F1000 X77.8213 Y106.2889 Z-1.0000 S1000
    G1 F1000 X70.4140 Y106.2889 Z-1.0000 S1000
    G1 F1000 X70.3014 Y106.2929 Z-1.0000 S1000
    G1 F1000 X70.1894 Y106.3049 Z-1.0000 S1000
    G1 F1000 X70.0784 Y106.3248 Z-1.0000 S1000
    G1 F1000 X69.9692 Y106.3525 Z-1.0000 S1000
    G1 F1000 X69.8623 Y106.3879 Z-1.0000 S1000
    G1 F1000 X69.7581 Y106.4308 Z-1.0000 S1000
    G1 F1000 X69.6572 Y106.4809 Z-1.0000 S1000
    G1 F1000 X69.5601 Y106.5381 Z-1.0000 S1000
    G1 F1000 X69.4673 Y106.6021 Z-1.0000 S1000
    G1 F1000 X69.3793 Y106.6724 Z-1.0000 S1000
    G1 F1000 X69.2965 Y106.7488 Z-1.0000 S1000
    G1 F1000 X69.2193 Y106.8310 Z-1.0000 S1000
    G1 F1000 X69.1482 Y106.9183 Z-1.0000 S1000
    G1 F1000 X69.0834 Y107.0105 Z-1.0000 S1000
    G1 F1000 X69.0254 Y107.1071 Z-1.0000 S1000
    G1 F1000 X68.9743 Y107.2075 Z-1.0000 S1000
    G1 F1000 X68.9305 Y107.3113 Z-1.0000 S1000
    G1 F1000 X68.8941 Y107.4180 Z-1.0000 S1000
    G1 F1000 X68.8654 Y107.5270 Z-1.0000 S1000
    G1 F1000 X68.8446 Y107.6377 Z-1.0000 S1000
    G1 F1000 X68.8316 Y107.7496 Z-1.0000 S1000
    G1 F1000 X68.8265 Y107.8764 Z-1.0000 S1000
    G1 F1000 X68.8265 Y120.3472 Z-1.0000 S1000
    G1 F1000 X66.2383 Y120.3472 Z-1.0000 S1000
    G0 Z7
    G0 X48.8595 Y120.3472
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X48.8595 Y104.8711 Z-1.0000 S1000
    G1 F1000 X60.4425 Y104.8711 Z-1.0000 S1000
    G1 F1000 X60.4425 Y106.2889 Z-1.0000 S1000
    G1 F1000 X53.0352 Y106.2889 Z-1.0000 S1000
    G1 F1000 X52.9226 Y106.2929 Z-1.0000 S1000
    G1 F1000 X52.8106 Y106.3049 Z-1.0000 S1000
    G1 F1000 X52.6996 Y106.3248 Z-1.0000 S1000
    G1 F1000 X52.5904 Y106.3525 Z-1.0000 S1000
    G1 F1000 X52.4835 Y106.3879 Z-1.0000 S1000
    G1 F1000 X52.3793 Y106.4308 Z-1.0000 S1000
    G1 F1000 X52.2784 Y106.4809 Z-1.0000 S1000
    G1 F1000 X52.1813 Y106.5381 Z-1.0000 S1000
    G1 F1000 X52.0885 Y106.6021 Z-1.0000 S1000
    G1 F1000 X52.0005 Y106.6724 Z-1.0000 S1000
    G1 F1000 X51.9177 Y106.7488 Z-1.0000 S1000
    G1 F1000 X51.8405 Y106.8310 Z-1.0000 S1000
    G1 F1000 X51.7694 Y106.9183 Z-1.0000 S1000
    G1 F1000 X51.7046 Y107.0105 Z-1.0000 S1000
    G1 F1000 X51.6466 Y107.1071 Z-1.0000 S1000
    G1 F1000 X51.5955 Y107.2075 Z-1.0000 S1000
    G1 F1000 X51.5517 Y107.3113 Z-1.0000 S1000
    G1 F1000 X51.5153 Y107.4180 Z-1.0000 S1000
    G1 F1000 X51.4866 Y107.5270 Z-1.0000 S1000
    G1 F1000 X51.4658 Y107.6377 Z-1.0000 S1000
    G1 F1000 X51.4528 Y107.7496 Z-1.0000 S1000
    G1 F1000 X51.4477 Y107.8764 Z-1.0000 S1000
    G1 F1000 X51.4477 Y120.3472 Z-1.0000 S1000
    G1 F1000 X48.8595 Y120.3472 Z-1.0000 S1000
    G0 Z7
    G0 X30.0303 Y120.3472
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X30.0303 Y104.8711 Z-1.0000 S1000
    G1 F1000 X42.5802 Y104.8711 Z-1.0000 S1000
    G1 F1000 X42.5802 Y105.9200 Z-1.0000 S1000
    G1 F1000 X34.2188 Y105.9200 Z-1.0000 S1000
    G1 F1000 X34.1062 Y105.9240 Z-1.0000 S1000
    G1 F1000 X33.9942 Y105.9360 Z-1.0000 S1000
    G1 F1000 X33.8832 Y105.9559 Z-1.0000 S1000
    G1 F1000 X33.7740 Y105.9836 Z-1.0000 S1000
    G1 F1000 X33.6671 Y106.0190 Z-1.0000 S1000
    G1 F1000 X33.5629 Y106.0619 Z-1.0000 S1000
    G1 F1000 X33.4620 Y106.1120 Z-1.0000 S1000
    G1 F1000 X33.3649 Y106.1692 Z-1.0000 S1000
    G1 F1000 X33.2721 Y106.2332 Z-1.0000 S1000
    G1 F1000 X33.1841 Y106.3035 Z-1.0000 S1000
    G1 F1000 X33.1013 Y106.3799 Z-1.0000 S1000
    G1 F1000 X33.0241 Y106.4621 Z-1.0000 S1000
    G1 F1000 X32.9530 Y106.5494 Z-1.0000 S1000
    G1 F1000 X32.8882 Y106.6416 Z-1.0000 S1000
    G1 F1000 X32.8302 Y106.7382 Z-1.0000 S1000
    G1 F1000 X32.7791 Y106.8386 Z-1.0000 S1000
    G1 F1000 X32.7353 Y106.9424 Z-1.0000 S1000
    G1 F1000 X32.6989 Y107.0491 Z-1.0000 S1000
    G1 F1000 X32.6702 Y107.1581 Z-1.0000 S1000
    G1 F1000 X32.6494 Y107.2688 Z-1.0000 S1000
    G1 F1000 X32.6364 Y107.3807 Z-1.0000 S1000
    G1 F1000 X32.6313 Y107.5075 Z-1.0000 S1000
    G1 F1000 X32.6313 Y111.1843 Z-1.0000 S1000
    G1 F1000 X32.6353 Y111.2969 Z-1.0000 S1000
    G1 F1000 X32.6473 Y111.4089 Z-1.0000 S1000
    G1 F1000 X32.6672 Y111.5199 Z-1.0000 S1000
    G1 F1000 X32.6949 Y111.6291 Z-1.0000 S1000
    G1 F1000 X32.7303 Y111.7360 Z-1.0000 S1000
    G1 F1000 X32.7732 Y111.8402 Z-1.0000 S1000
    G1 F1000 X32.8233 Y111.9411 Z-1.0000 S1000
    G1 F1000 X32.8805 Y112.0382 Z-1.0000 S1000
    G1 F1000 X32.9445 Y112.1310 Z-1.0000 S1000
    G1 F1000 X33.0148 Y112.2190 Z-1.0000 S1000
    G1 F1000 X33.0912 Y112.3018 Z-1.0000 S1000
    G1 F1000 X33.1734 Y112.3790 Z-1.0000 S1000
    G1 F1000 X33.2607 Y112.4501 Z-1.0000 S1000
    G1 F1000 X33.3529 Y112.5149 Z-1.0000 S1000
    G1 F1000 X33.4495 Y112.5729 Z-1.0000 S1000
    G1 F1000 X33.5499 Y112.6240 Z-1.0000 S1000
    G1 F1000 X33.6537 Y112.6678 Z-1.0000 S1000
    G1 F1000 X33.7604 Y112.7042 Z-1.0000 S1000
    G1 F1000 X33.8694 Y112.7329 Z-1.0000 S1000
    G1 F1000 X33.9801 Y112.7537 Z-1.0000 S1000
    G1 F1000 X34.0920 Y112.7667 Z-1.0000 S1000
    G1 F1000 X34.2188 Y112.7718 Z-1.0000 S1000
    G1 F1000 X41.6006 Y112.7718 Z-1.0000 S1000
    G1 F1000 X41.6006 Y113.4008 Z-1.0000 S1000
    G1 F1000 X34.2188 Y113.4008 Z-1.0000 S1000
    G1 F1000 X34.1062 Y113.4048 Z-1.0000 S1000
    G1 F1000 X33.9942 Y113.4168 Z-1.0000 S1000
    G1 F1000 X33.8832 Y113.4367 Z-1.0000 S1000
    G1 F1000 X33.7740 Y113.4644 Z-1.0000 S1000
    G1 F1000 X33.6671 Y113.4998 Z-1.0000 S1000
    G1 F1000 X33.5629 Y113.5427 Z-1.0000 S1000
    G1 F1000 X33.4620 Y113.5928 Z-1.0000 S1000
    G1 F1000 X33.3649 Y113.6500 Z-1.0000 S1000
    G1 F1000 X33.2721 Y113.7140 Z-1.0000 S1000
    G1 F1000 X33.1841 Y113.7843 Z-1.0000 S1000
    G1 F1000 X33.1013 Y113.8607 Z-1.0000 S1000
    G1 F1000 X33.0241 Y113.9429 Z-1.0000 S1000
    G1 F1000 X32.9530 Y114.0302 Z-1.0000 S1000
    G1 F1000 X32.8882 Y114.1224 Z-1.0000 S1000
    G1 F1000 X32.8302 Y114.2190 Z-1.0000 S1000
    G1 F1000 X32.7791 Y114.3194 Z-1.0000 S1000
    G1 F1000 X32.7353 Y114.4232 Z-1.0000 S1000
    G1 F1000 X32.6989 Y114.5299 Z-1.0000 S1000
    G1 F1000 X32.6702 Y114.6389 Z-1.0000 S1000
    G1 F1000 X32.6494 Y114.7496 Z-1.0000 S1000
    G1 F1000 X32.6364 Y114.8615 Z-1.0000 S1000
    G1 F1000 X32.6313 Y114.9883 Z-1.0000 S1000
    G1 F1000 X32.6313 Y117.9526 Z-1.0000 S1000
    G1 F1000 X32.6353 Y118.0652 Z-1.0000 S1000
    G1 F1000 X32.6473 Y118.1772 Z-1.0000 S1000
    G1 F1000 X32.6672 Y118.2882 Z-1.0000 S1000
    G1 F1000 X32.6949 Y118.3974 Z-1.0000 S1000
    G1 F1000 X32.7303 Y118.5043 Z-1.0000 S1000
    G1 F1000 X32.7732 Y118.6085 Z-1.0000 S1000
    G1 F1000 X32.8233 Y118.7094 Z-1.0000 S1000
    G1 F1000 X32.8805 Y118.8065 Z-1.0000 S1000
    G1 F1000 X32.9445 Y118.8993 Z-1.0000 S1000
    G1 F1000 X33.0148 Y118.9873 Z-1.0000 S1000
    G1 F1000 X33.0912 Y119.0701 Z-1.0000 S1000
    G1 F1000 X33.1734 Y119.1473 Z-1.0000 S1000
    G1 F1000 X33.2607 Y119.2184 Z-1.0000 S1000
    G1 F1000 X33.3529 Y119.2832 Z-1.0000 S1000
    G1 F1000 X33.4495 Y119.3412 Z-1.0000 S1000
    G1 F1000 X33.5499 Y119.3923 Z-1.0000 S1000
    G1 F1000 X33.6537 Y119.4361 Z-1.0000 S1000
    G1 F1000 X33.7604 Y119.4725 Z-1.0000 S1000
    G1 F1000 X33.8694 Y119.5012 Z-1.0000 S1000
    G1 F1000 X33.9801 Y119.5220 Z-1.0000 S1000
    G1 F1000 X34.0920 Y119.5350 Z-1.0000 S1000
    G1 F1000 X34.2188 Y119.5401 Z-1.0000 S1000
    G1 F1000 X42.3003 Y119.5401 Z-1.0000 S1000
    G1 F1000 X42.3003 Y120.3472 Z-1.0000 S1000
    G1 F1000 X30.0303 Y120.3472 Z-1.0000 S1000
    G0 Z7
    G0 X23.0386 Y104.8711
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X23.0386 Y120.3472 Z-1.0000 S1000
    G1 F1000 X20.4249 Y120.3472 Z-1.0000 S1000
    G1 F1000 X20.4249 Y115.4081 Z-1.0000 S1000
    G1 F1000 X20.4209 Y115.2955 Z-1.0000 S1000
    G1 F1000 X20.4089 Y115.1835 Z-1.0000 S1000
    G1 F1000 X20.3890 Y115.0725 Z-1.0000 S1000
    G1 F1000 X20.3613 Y114.9633 Z-1.0000 S1000
    G1 F1000 X20.3259 Y114.8564 Z-1.0000 S1000
    G1 F1000 X20.2830 Y114.7522 Z-1.0000 S1000
    G1 F1000 X20.2329 Y114.6513 Z-1.0000 S1000
    G1 F1000 X20.1757 Y114.5542 Z-1.0000 S1000
    G1 F1000 X20.1117 Y114.4614 Z-1.0000 S1000
    G1 F1000 X20.0414 Y114.3734 Z-1.0000 S1000
    G1 F1000 X19.9650 Y114.2906 Z-1.0000 S1000
    G1 F1000 X19.8828 Y114.2134 Z-1.0000 S1000
    G1 F1000 X19.7955 Y114.1423 Z-1.0000 S1000
    G1 F1000 X19.7033 Y114.0775 Z-1.0000 S1000
    G1 F1000 X19.6067 Y114.0195 Z-1.0000 S1000
    G1 F1000 X19.5063 Y113.9684 Z-1.0000 S1000
    G1 F1000 X19.4025 Y113.9246 Z-1.0000 S1000
    G1 F1000 X19.2958 Y113.8882 Z-1.0000 S1000
    G1 F1000 X19.1868 Y113.8595 Z-1.0000 S1000
    G1 F1000 X19.0761 Y113.8387 Z-1.0000 S1000
    G1 F1000 X18.9642 Y113.8257 Z-1.0000 S1000
    G1 F1000 X18.8374 Y113.8206 Z-1.0000 S1000
    G1 F1000 X12.5398 Y113.8206 Z-1.0000 S1000
    G1 F1000 X12.4272 Y113.8246 Z-1.0000 S1000
    G1 F1000 X12.3152 Y113.8366 Z-1.0000 S1000
    G1 F1000 X12.2042 Y113.8565 Z-1.0000 S1000
    G1 F1000 X12.0950 Y113.8842 Z-1.0000 S1000
    G1 F1000 X11.9881 Y113.9196 Z-1.0000 S1000
    G1 F1000 X11.8839 Y113.9625 Z-1.0000 S1000
    G1 F1000 X11.7830 Y114.0126 Z-1.0000 S1000
    G1 F1000 X11.6859 Y114.0698 Z-1.0000 S1000
    G1 F1000 X11.5931 Y114.1338 Z-1.0000 S1000
    G1 F1000 X11.5051 Y114.2041 Z-1.0000 S1000
    G1 F1000 X11.4223 Y114.2805 Z-1.0000 S1000
    G1 F1000 X11.3451 Y114.3627 Z-1.0000 S1000
    G1 F1000 X11.2740 Y114.4500 Z-1.0000 S1000
    G1 F1000 X11.2092 Y114.5422 Z-1.0000 S1000
    G1 F1000 X11.1512 Y114.6388 Z-1.0000 S1000
    G1 F1000 X11.1001 Y114.7392 Z-1.0000 S1000
    G1 F1000 X11.0563 Y114.8430 Z-1.0000 S1000
    G1 F1000 X11.0199 Y114.9497 Z-1.0000 S1000
    G1 F1000 X10.9912 Y115.0587 Z-1.0000 S1000
    G1 F1000 X10.9704 Y115.1694 Z-1.0000 S1000
    G1 F1000 X10.9574 Y115.2813 Z-1.0000 S1000
    G1 F1000 X10.9523 Y115.4081 Z-1.0000 S1000
    G1 F1000 X10.9523 Y120.3472 Z-1.0000 S1000
    G1 F1000 X8.3641 Y120.3472 Z-1.0000 S1000
    G1 F1000 X8.3641 Y104.8711 Z-1.0000 S1000
    G1 F1000 X10.9523 Y104.8711 Z-1.0000 S1000
    G1 F1000 X10.9523 Y110.8280 Z-1.0000 S1000
    G1 F1000 X10.9563 Y110.9406 Z-1.0000 S1000
    G1 F1000 X10.9683 Y111.0526 Z-1.0000 S1000
    G1 F1000 X10.9882 Y111.1636 Z-1.0000 S1000
    G1 F1000 X11.0159 Y111.2728 Z-1.0000 S1000
    G1 F1000 X11.0513 Y111.3797 Z-1.0000 S1000
    G1 F1000 X11.0942 Y111.4839 Z-1.0000 S1000
    G1 F1000 X11.1443 Y111.5848 Z-1.0000 S1000
    G1 F1000 X11.2015 Y111.6819 Z-1.0000 S1000
    G1 F1000 X11.2655 Y111.7747 Z-1.0000 S1000
    G1 F1000 X11.3358 Y111.8627 Z-1.0000 S1000
    G1 F1000 X11.4122 Y111.9455 Z-1.0000 S1000
    G1 F1000 X11.4944 Y112.0227 Z-1.0000 S1000
    G1 F1000 X11.5817 Y112.0938 Z-1.0000 S1000
    G1 F1000 X11.6739 Y112.1586 Z-1.0000 S1000
    G1 F1000 X11.7705 Y112.2166 Z-1.0000 S1000
    G1 F1000 X11.8709 Y112.2677 Z-1.0000 S1000
    G1 F1000 X11.9747 Y112.3115 Z-1.0000 S1000
    G1 F1000 X12.0814 Y112.3479 Z-1.0000 S1000
    G1 F1000 X12.1904 Y112.3766 Z-1.0000 S1000
    G1 F1000 X12.3011 Y112.3974 Z-1.0000 S1000
    G1 F1000 X12.4130 Y112.4104 Z-1.0000 S1000
    G1 F1000 X12.5398 Y112.4155 Z-1.0000 S1000
    G1 F1000 X18.8374 Y112.4155 Z-1.0000 S1000
    G1 F1000 X18.9500 Y112.4115 Z-1.0000 S1000
    G1 F1000 X19.0620 Y112.3995 Z-1.0000 S1000
    G1 F1000 X19.1730 Y112.3796 Z-1.0000 S1000
    G1 F1000 X19.2822 Y112.3519 Z-1.0000 S1000
    G1 F1000 X19.3891 Y112.3165 Z-1.0000 S1000
    G1 F1000 X19.4933 Y112.2736 Z-1.0000 S1000
    G1 F1000 X19.5942 Y112.2235 Z-1.0000 S1000
    G1 F1000 X19.6913 Y112.1663 Z-1.0000 S1000
    G1 F1000 X19.7841 Y112.1023 Z-1.0000 S1000
    G1 F1000 X19.8721 Y112.0320 Z-1.0000 S1000
    G1 F1000 X19.9549 Y111.9556 Z-1.0000 S1000
    G1 F1000 X20.0321 Y111.8734 Z-1.0000 S1000
    G1 F1000 X20.1032 Y111.7861 Z-1.0000 S1000
    G1 F1000 X20.1680 Y111.6939 Z-1.0000 S1000
    G1 F1000 X20.2260 Y111.5973 Z-1.0000 S1000
    G1 F1000 X20.2771 Y111.4969 Z-1.0000 S1000
    G1 F1000 X20.3209 Y111.3931 Z-1.0000 S1000
    G1 F1000 X20.3573 Y111.2864 Z-1.0000 S1000
    G1 F1000 X20.3860 Y111.1774 Z-1.0000 S1000
    G1 F1000 X20.4068 Y111.0667 Z-1.0000 S1000
    G1 F1000 X20.4198 Y110.9548 Z-1.0000 S1000
    G1 F1000 X20.4249 Y110.8280 Z-1.0000 S1000
    G1 F1000 X20.4249 Y104.8711 Z-1.0000 S1000
    G1 F1000 X23.0386 Y104.8711 Z-1.0000 S1000
    G0 Z7
    G0 X96.4525 Y112.7557
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X96.3889 Y111.3109 Z-1.0000 S1000
    G1 F1000 X96.3799 Y111.1986 Z-1.0000 S1000
    G1 F1000 X96.3708 Y111.1322 Z-1.0000 S1000
    G1 F1000 X96.1799 Y109.9275 Z-1.0000 S1000
    G1 F1000 X96.1584 Y109.8169 Z-1.0000 S1000
    G1 F1000 X96.1197 Y109.6789 Z-1.0000 S1000
    G1 F1000 X95.8017 Y108.7144 Z-1.0000 S1000
    G1 F1000 X95.7626 Y108.6087 Z-1.0000 S1000
    G1 F1000 X95.7162 Y108.5061 Z-1.0000 S1000
    G1 F1000 X95.6464 Y108.3802 Z-1.0000 S1000
    G1 F1000 X95.2011 Y107.6558 Z-1.0000 S1000
    G1 F1000 X95.1387 Y107.5619 Z-1.0000 S1000
    G1 F1000 X95.0699 Y107.4727 Z-1.0000 S1000
    G1 F1000 X94.9948 Y107.3887 Z-1.0000 S1000
    G1 F1000 X94.9372 Y107.3315 Z-1.0000 S1000
    G1 F1000 X94.3758 Y106.8027 Z-1.0000 S1000
    G1 F1000 X94.2911 Y106.7284 Z-1.0000 S1000
    G1 F1000 X94.2013 Y106.6603 Z-1.0000 S1000
    G1 F1000 X94.0702 Y106.5773 Z-1.0000 S1000
    G1 F1000 X93.4039 Y106.1996 Z-1.0000 S1000
    G1 F1000 X93.3039 Y106.1475 Z-1.0000 S1000
    G1 F1000 X93.2006 Y106.1027 Z-1.0000 S1000
    G1 F1000 X93.0685 Y106.0575 Z-1.0000 S1000
    G1 F1000 X92.2972 Y105.8309 Z-1.0000 S1000
    G1 F1000 X92.1880 Y105.8030 Z-1.0000 S1000
    G1 F1000 X92.0771 Y105.7829 Z-1.0000 S1000
    G1 F1000 X91.9860 Y105.7724 Z-1.0000 S1000
    G1 F1000 X91.1097 Y105.6969 Z-1.0000 S1000
    G1 F1000 X90.9971 Y105.6912 Z-1.0000 S1000
    G1 F1000 X90.8310 Y105.6974 Z-1.0000 S1000
    G1 F1000 X89.9751 Y105.7745 Z-1.0000 S1000
    G1 F1000 X89.8633 Y105.7886 Z-1.0000 S1000
    G1 F1000 X89.7528 Y105.8106 Z-1.0000 S1000
    G1 F1000 X89.6559 Y105.8367 Z-1.0000 S1000
    G1 F1000 X88.8945 Y106.0681 Z-1.0000 S1000
    G1 F1000 X88.7879 Y106.1047 Z-1.0000 S1000
    G1 F1000 X88.6842 Y106.1487 Z-1.0000 S1000
    G1 F1000 X88.5611 Y106.2129 Z-1.0000 S1000
    G1 F1000 X87.8944 Y106.5986 Z-1.0000 S1000
    G1 F1000 X87.7990 Y106.6584 Z-1.0000 S1000
    G1 F1000 X87.7080 Y106.7249 Z-1.0000 S1000
    G1 F1000 X87.5998 Y106.8181 Z-1.0000 S1000
    G1 F1000 X87.0277 Y107.3580 Z-1.0000 S1000
    G1 F1000 X86.9486 Y107.4382 Z-1.0000 S1000
    G1 F1000 X86.8753 Y107.5238 Z-1.0000 S1000
    G1 F1000 X86.7808 Y107.6559 Z-1.0000 S1000
    G1 F1000 X86.3216 Y108.3723 Z-1.0000 S1000
    G1 F1000 X86.2642 Y108.4693 Z-1.0000 S1000
    G1 F1000 X86.2138 Y108.5701 Z-1.0000 S1000
    G1 F1000 X86.1637 Y108.6934 Z-1.0000 S1000
    G1 F1000 X85.8357 Y109.6086 Z-1.0000 S1000
    G1 F1000 X85.8015 Y109.7160 Z-1.0000 S1000
    G1 F1000 X85.7668 Y109.8680 Z-1.0000 S1000
    G1 F1000 X85.5700 Y110.9820 Z-1.0000 S1000
    G1 F1000 X85.5544 Y111.0936 Z-1.0000 S1000
    G1 F1000 X85.5478 Y111.1790 Z-1.0000 S1000
    G1 F1000 X85.4822 Y112.4918 Z-1.0000 S1000
    G1 F1000 X85.4822 Y112.6500 Z-1.0000 S1000
    G1 F1000 X85.5482 Y113.9739 Z-1.0000 S1000
    G1 F1000 X85.5578 Y114.0862 Z-1.0000 S1000
    G1 F1000 X85.5703 Y114.1706 Z-1.0000 S1000
    G1 F1000 X85.7682 Y115.2926 Z-1.0000 S1000
    G1 F1000 X85.7917 Y115.4028 Z-1.0000 S1000
    G1 F1000 X85.8373 Y115.5529 Z-1.0000 S1000
    G1 F1000 X86.1673 Y116.4729 Z-1.0000 S1000
    G1 F1000 X86.2091 Y116.5775 Z-1.0000 S1000
    G1 F1000 X86.2582 Y116.6790 Z-1.0000 S1000
    G1 F1000 X86.3266 Y116.7959 Z-1.0000 S1000
    G1 F1000 X86.7886 Y117.5139 Z-1.0000 S1000
    G1 F1000 X86.8529 Y117.6064 Z-1.0000 S1000
    G1 F1000 X86.9236 Y117.6942 Z-1.0000 S1000
    G1 F1000 X87.0328 Y117.8083 Z-1.0000 S1000
    G1 F1000 X87.6037 Y118.3482 Z-1.0000 S1000
    G1 F1000 X87.6883 Y118.4227 Z-1.0000 S1000
    G1 F1000 X87.7779 Y118.4910 Z-1.0000 S1000
    G1 F1000 X87.8906 Y118.5637 Z-1.0000 S1000
    G1 F1000 X88.5474 Y118.9494 Z-1.0000 S1000
    G1 F1000 X88.6465 Y119.0030 Z-1.0000 S1000
    G1 F1000 X88.7492 Y119.0494 Z-1.0000 S1000
    G1 F1000 X88.8793 Y119.0962 Z-1.0000 S1000
    G1 F1000 X89.6220 Y119.3275 Z-1.0000 S1000
    G1 F1000 X89.7307 Y119.3572 Z-1.0000 S1000
    G1 F1000 X89.8412 Y119.3790 Z-1.0000 S1000
    G1 F1000 X89.9467 Y119.3925 Z-1.0000 S1000
    G1 F1000 X90.7752 Y119.4697 Z-1.0000 S1000
    G1 F1000 X90.8877 Y119.4761 Z-1.0000 S1000
    G1 F1000 X91.0004 Y119.4746 Z-1.0000 S1000
    G1 F1000 X91.0619 Y119.4704 Z-1.0000 S1000
    G1 F1000 X91.9243 Y119.3944 Z-1.0000 S1000
    G1 F1000 X92.0361 Y119.3805 Z-1.0000 S1000
    G1 F1000 X92.1466 Y119.3587 Z-1.0000 S1000
    G1 F1000 X92.2365 Y119.3349 Z-1.0000 S1000
    G1 F1000 X93.0042 Y119.1071 Z-1.0000 S1000
    G1 F1000 X93.1110 Y119.0712 Z-1.0000 S1000
    G1 F1000 X93.2150 Y119.0279 Z-1.0000 S1000
    G1 F1000 X93.3326 Y118.9679 Z-1.0000 S1000
    G1 F1000 X94.0057 Y118.5882 Z-1.0000 S1000
    G1 F1000 X94.1018 Y118.5294 Z-1.0000 S1000
    G1 F1000 X94.1935 Y118.4639 Z-1.0000 S1000
    G1 F1000 X94.2997 Y118.3745 Z-1.0000 S1000
    G1 F1000 X94.8782 Y117.8430 Z-1.0000 S1000
    G1 F1000 X94.9585 Y117.7639 Z-1.0000 S1000
    G1 F1000 X95.0329 Y117.6793 Z-1.0000 S1000
    G1 F1000 X95.1246 Y117.5553 Z-1.0000 S1000
    G1 F1000 X95.5893 Y116.8591 Z-1.0000 S1000
    G1 F1000 X95.6485 Y116.7633 Z-1.0000 S1000
    G1 F1000 X95.7007 Y116.6634 Z-1.0000 S1000
    G1 F1000 X95.7528 Y116.5419 Z-1.0000 S1000
    G1 F1000 X96.0848 Y115.6685 Z-1.0000 S1000
    G1 F1000 X96.1211 Y115.5618 Z-1.0000 S1000
    G1 F1000 X96.1606 Y115.4001 Z-1.0000 S1000
    G1 F1000 X96.3598 Y114.3493 Z-1.0000 S1000
    G1 F1000 X96.3769 Y114.2379 Z-1.0000 S1000
    G1 F1000 X96.3853 Y114.1393 Z-1.0000 S1000
    G1 F1000 X96.4517 Y112.9112 Z-1.0000 S1000
    G1 F1000 X96.4525 Y112.7557 Z-1.0000 S1000
    G0 Z7
    G0 X88.5473 Y104.7872
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X91.1946 Y104.5565 Z-2.0000 S1000
    G1 F1000 X92.4876 Y104.6196 Z-2.0000 S1000
    G1 F1000 X93.6603 Y104.8078 Z-2.0000 S1000
    G1 F1000 X94.6847 Y105.1103 Z-2.0000 S1000
    G1 F1000 X95.5774 Y105.5221 Z-2.0000 S1000
    G1 F1000 X96.3625 Y106.0355 Z-2.0000 S1000
    G1 F1000 X97.0450 Y106.6382 Z-2.0000 S1000
    G1 F1000 X97.6286 Y107.3319 Z-2.0000 S1000
    G1 F1000 X98.1173 Y108.1217 Z-2.0000 S1000
    G1 F1000 X98.5080 Y109.0306 Z-2.0000 S1000
    G1 F1000 X98.7974 Y110.0972 Z-2.0000 S1000
    G1 F1000 X98.9785 Y111.3378 Z-2.0000 S1000
    G1 F1000 X99.0396 Y112.7253 Z-2.0000 S1000
    G1 F1000 X98.8992 Y114.6215 Z-2.0000 S1000
    G1 F1000 X98.5002 Y116.2066 Z-2.0000 S1000
    G1 F1000 X97.8621 Y117.5245 Z-2.0000 S1000
    G1 F1000 X96.9863 Y118.6172 Z-2.0000 S1000
    G1 F1000 X95.8787 Y119.4868 Z-2.0000 S1000
    G1 F1000 X94.5263 Y120.1232 Z-2.0000 S1000
    G1 F1000 X92.8846 Y120.5224 Z-2.0000 S1000
    G1 F1000 X90.9378 Y120.6611 Z-2.0000 S1000
    G1 F1000 X89.0430 Y120.5206 Z-2.0000 S1000
    G1 F1000 X87.4374 Y120.1167 Z-2.0000 S1000
    G1 F1000 X86.0963 Y119.4692 Z-2.0000 S1000
    G1 F1000 X84.9788 Y118.5787 Z-2.0000 S1000
    G1 F1000 X84.0887 Y117.4603 Z-2.0000 S1000
    G1 F1000 X83.4411 Y116.1154 Z-2.0000 S1000
    G1 F1000 X83.0365 Y114.5006 Z-2.0000 S1000
    G1 F1000 X82.8949 Y112.5786 Z-2.0000 S1000
    G1 F1000 X82.9654 Y111.2032 Z-2.0000 S1000
    G1 F1000 X83.1733 Y109.9695 Z-2.0000 S1000
    G1 F1000 X83.5076 Y108.8931 Z-2.0000 S1000
    G1 F1000 X83.9664 Y107.9497 Z-2.0000 S1000
    G1 F1000 X84.5302 Y107.1222 Z-2.0000 S1000
    G1 F1000 X85.1644 Y106.4244 Z-2.0000 S1000
    G1 F1000 X85.8638 Y105.8550 Z-2.0000 S1000
    G1 F1000 X86.6404 Y105.4011 Z-2.0000 S1000
    G1 F1000 X87.5350 Y105.0440 Z-2.0000 S1000
    G1 F1000 X88.5473 Y104.7872 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X66.2383 Y104.8711 Z-2.0000 S1000
    G1 F1000 X77.8213 Y104.8711 Z-2.0000 S1000
    G1 F1000 X77.8213 Y106.2889 Z-2.0000 S1000
    G1 F1000 X70.4140 Y106.2889 Z-2.0000 S1000
    G1 F1000 X70.3014 Y106.2929 Z-2.0000 S1000
    G1 F1000 X70.1894 Y106.3049 Z-2.0000 S1000
    G1 F1000 X70.0784 Y106.3248 Z-2.0000 S1000
    G1 F1000 X69.9692 Y106.3525 Z-2.0000 S1000
    G1 F1000 X69.8623 Y106.3879 Z-2.0000 S1000
    G1 F1000 X69.7581 Y106.4308 Z-2.0000 S1000
    G1 F1000 X69.6572 Y106.4809 Z-2.0000 S1000
    G1 F1000 X69.5601 Y106.5381 Z-2.0000 S1000
    G1 F1000 X69.4673 Y106.6021 Z-2.0000 S1000
    G1 F1000 X69.3793 Y106.6724 Z-2.0000 S1000
    G1 F1000 X69.2965 Y106.7488 Z-2.0000 S1000
    G1 F1000 X69.2193 Y106.8310 Z-2.0000 S1000
    G1 F1000 X69.1482 Y106.9183 Z-2.0000 S1000
    G1 F1000 X69.0834 Y107.0105 Z-2.0000 S1000
    G1 F1000 X69.0254 Y107.1071 Z-2.0000 S1000
    G1 F1000 X68.9743 Y107.2075 Z-2.0000 S1000
    G1 F1000 X68.9305 Y107.3113 Z-2.0000 S1000
    G1 F1000 X68.8941 Y107.4180 Z-2.0000 S1000
    G1 F1000 X68.8654 Y107.5270 Z-2.0000 S1000
    G1 F1000 X68.8446 Y107.6377 Z-2.0000 S1000
    G1 F1000 X68.8316 Y107.7496 Z-2.0000 S1000
    G1 F1000 X68.8265 Y107.8764 Z-2.0000 S1000
    G1 F1000 X68.8265 Y120.3472 Z-2.0000 S1000
    G1 F1000 X66.2383 Y120.3472 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X48.8595 Y104.8711 Z-2.0000 S1000
    G1 F1000 X60.4425 Y104.8711 Z-2.0000 S1000
    G1 F1000 X60.4425 Y106.2889 Z-2.0000 S1000
    G1 F1000 X53.0352 Y106.2889 Z-2.0000 S1000
    G1 F1000 X52.9226 Y106.2929 Z-2.0000 S1000
    G1 F1000 X52.8106 Y106.3049 Z-2.0000 S1000
    G1 F1000 X52.6996 Y106.3248 Z-2.0000 S1000
    G1 F1000 X52.5904 Y106.3525 Z-2.0000 S1000
    G1 F1000 X52.4835 Y106.3879 Z-2.0000 S1000
    G1 F1000 X52.3793 Y106.4308 Z-2.0000 S1000
    G1 F1000 X52.2784 Y106.4809 Z-2.0000 S1000
    G1 F1000 X52.1813 Y106.5381 Z-2.0000 S1000
    G1 F1000 X52.0885 Y106.6021 Z-2.0000 S1000
    G1 F1000 X52.0005 Y106.6724 Z-2.0000 S1000
    G1 F1000 X51.9177 Y106.7488 Z-2.0000 S1000
    G1 F1000 X51.8405 Y106.8310 Z-2.0000 S1000
    G1 F1000 X51.7694 Y106.9183 Z-2.0000 S1000
    G1 F1000 X51.7046 Y107.0105 Z-2.0000 S1000
    G1 F1000 X51.6466 Y107.1071 Z-2.0000 S1000
    G1 F1000 X51.5955 Y107.2075 Z-2.0000 S1000
    G1 F1000 X51.5517 Y107.3113 Z-2.0000 S1000
    G1 F1000 X51.5153 Y107.4180 Z-2.0000 S1000
    G1 F1000 X51.4866 Y107.5270 Z-2.0000 S1000
    G1 F1000 X51.4658 Y107.6377 Z-2.0000 S1000
    G1 F1000 X51.4528 Y107.7496 Z-2.0000 S1000
    G1 F1000 X51.4477 Y107.8764 Z-2.0000 S1000
    G1 F1000 X51.4477 Y120.3472 Z-2.0000 S1000
    G1 F1000 X48.8595 Y120.3472 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X30.0303 Y104.8711 Z-2.0000 S1000
    G1 F1000 X42.5802 Y104.8711 Z-2.0000 S1000
    G1 F1000 X42.5802 Y105.9200 Z-2.0000 S1000
    G1 F1000 X34.2188 Y105.9200 Z-2.0000 S1000
    G1 F1000 X34.1062 Y105.9240 Z-2.0000 S1000
    G1 F1000 X33.9942 Y105.9360 Z-2.0000 S1000
    G1 F1000 X33.8832 Y105.9559 Z-2.0000 S1000
    G1 F1000 X33.7740 Y105.9836 Z-2.0000 S1000
    G1 F1000 X33.6671 Y106.0190 Z-2.0000 S1000
    G1 F1000 X33.5629 Y106.0619 Z-2.0000 S1000
    G1 F1000 X33.4620 Y106.1120 Z-2.0000 S1000
    G1 F1000 X33.3649 Y106.1692 Z-2.0000 S1000
    G1 F1000 X33.2721 Y106.2332 Z-2.0000 S1000
    G1 F1000 X33.1841 Y106.3035 Z-2.0000 S1000
    G1 F1000 X33.1013 Y106.3799 Z-2.0000 S1000
    G1 F1000 X33.0241 Y106.4621 Z-2.0000 S1000
    G1 F1000 X32.9530 Y106.5494 Z-2.0000 S1000
    G1 F1000 X32.8882 Y106.6416 Z-2.0000 S1000
    G1 F1000 X32.8302 Y106.7382 Z-2.0000 S1000
    G1 F1000 X32.7791 Y106.8386 Z-2.0000 S1000
    G1 F1000 X32.7353 Y106.9424 Z-2.0000 S1000
    G1 F1000 X32.6989 Y107.0491 Z-2.0000 S1000
    G1 F1000 X32.6702 Y107.1581 Z-2.0000 S1000
    G1 F1000 X32.6494 Y107.2688 Z-2.0000 S1000
    G1 F1000 X32.6364 Y107.3807 Z-2.0000 S1000
    G1 F1000 X32.6313 Y107.5075 Z-2.0000 S1000
    G1 F1000 X32.6313 Y111.1843 Z-2.0000 S1000
    G1 F1000 X32.6353 Y111.2969 Z-2.0000 S1000
    G1 F1000 X32.6473 Y111.4089 Z-2.0000 S1000
    G1 F1000 X32.6672 Y111.5199 Z-2.0000 S1000
    G1 F1000 X32.6949 Y111.6291 Z-2.0000 S1000
    G1 F1000 X32.7303 Y111.7360 Z-2.0000 S1000
    G1 F1000 X32.7732 Y111.8402 Z-2.0000 S1000
    G1 F1000 X32.8233 Y111.9411 Z-2.0000 S1000
    G1 F1000 X32.8805 Y112.0382 Z-2.0000 S1000
    G1 F1000 X32.9445 Y112.1310 Z-2.0000 S1000
    G1 F1000 X33.0148 Y112.2190 Z-2.0000 S1000
    G1 F1000 X33.0912 Y112.3018 Z-2.0000 S1000
    G1 F1000 X33.1734 Y112.3790 Z-2.0000 S1000
    G1 F1000 X33.2607 Y112.4501 Z-2.0000 S1000
    G1 F1000 X33.3529 Y112.5149 Z-2.0000 S1000
    G1 F1000 X33.4495 Y112.5729 Z-2.0000 S1000
    G1 F1000 X33.5499 Y112.6240 Z-2.0000 S1000
    G1 F1000 X33.6537 Y112.6678 Z-2.0000 S1000
    G1 F1000 X33.7604 Y112.7042 Z-2.0000 S1000
    G1 F1000 X33.8694 Y112.7329 Z-2.0000 S1000
    G1 F1000 X33.9801 Y112.7537 Z-2.0000 S1000
    G1 F1000 X34.0920 Y112.7667 Z-2.0000 S1000
    G1 F1000 X34.2188 Y112.7718 Z-2.0000 S1000
    G1 F1000 X41.6006 Y112.7718 Z-2.0000 S1000
    G1 F1000 X41.6006 Y113.4008 Z-2.0000 S1000
    G1 F1000 X34.2188 Y113.4008 Z-2.0000 S1000
    G1 F1000 X34.1062 Y113.4048 Z-2.0000 S1000
    G1 F1000 X33.9942 Y113.4168 Z-2.0000 S1000
    G1 F1000 X33.8832 Y113.4367 Z-2.0000 S1000
    G1 F1000 X33.7740 Y113.4644 Z-2.0000 S1000
    G1 F1000 X33.6671 Y113.4998 Z-2.0000 S1000
    G1 F1000 X33.5629 Y113.5427 Z-2.0000 S1000
    G1 F1000 X33.4620 Y113.5928 Z-2.0000 S1000
    G1 F1000 X33.3649 Y113.6500 Z-2.0000 S1000
    G1 F1000 X33.2721 Y113.7140 Z-2.0000 S1000
    G1 F1000 X33.1841 Y113.7843 Z-2.0000 S1000
    G1 F1000 X33.1013 Y113.8607 Z-2.0000 S1000
    G1 F1000 X33.0241 Y113.9429 Z-2.0000 S1000
    G1 F1000 X32.9530 Y114.0302 Z-2.0000 S1000
    G1 F1000 X32.8882 Y114.1224 Z-2.0000 S1000
    G1 F1000 X32.8302 Y114.2190 Z-2.0000 S1000
    G1 F1000 X32.7791 Y114.3194 Z-2.0000 S1000
    G1 F1000 X32.7353 Y114.4232 Z-2.0000 S1000
    G1 F1000 X32.6989 Y114.5299 Z-2.0000 S1000
    G1 F1000 X32.6702 Y114.6389 Z-2.0000 S1000
    G1 F1000 X32.6494 Y114.7496 Z-2.0000 S1000
    G1 F1000 X32.6364 Y114.8615 Z-2.0000 S1000
    G1 F1000 X32.6313 Y114.9883 Z-2.0000 S1000
    G1 F1000 X32.6313 Y117.9526 Z-2.0000 S1000
    G1 F1000 X32.6353 Y118.0652 Z-2.0000 S1000
    G1 F1000 X32.6473 Y118.1772 Z-2.0000 S1000
    G1 F1000 X32.6672 Y118.2882 Z-2.0000 S1000
    G1 F1000 X32.6949 Y118.3974 Z-2.0000 S1000
    G1 F1000 X32.7303 Y118.5043 Z-2.0000 S1000
    G1 F1000 X32.7732 Y118.6085 Z-2.0000 S1000
    G1 F1000 X32.8233 Y118.7094 Z-2.0000 S1000
    G1 F1000 X32.8805 Y118.8065 Z-2.0000 S1000
    G1 F1000 X32.9445 Y118.8993 Z-2.0000 S1000
    G1 F1000 X33.0148 Y118.9873 Z-2.0000 S1000
    G1 F1000 X33.0912 Y119.0701 Z-2.0000 S1000
    G1 F1000 X33.1734 Y119.1473 Z-2.0000 S1000
    G1 F1000 X33.2607 Y119.2184 Z-2.0000 S1000
    G1 F1000 X33.3529 Y119.2832 Z-2.0000 S1000
    G1 F1000 X33.4495 Y119.3412 Z-2.0000 S1000
    G1 F1000 X33.5499 Y119.3923 Z-2.0000 S1000
    G1 F1000 X33.6537 Y119.4361 Z-2.0000 S1000
    G1 F1000 X33.7604 Y119.4725 Z-2.0000 S1000
    G1 F1000 X33.8694 Y119.5012 Z-2.0000 S1000
    G1 F1000 X33.9801 Y119.5220 Z-2.0000 S1000
    G1 F1000 X34.0920 Y119.5350 Z-2.0000 S1000
    G1 F1000 X34.2188 Y119.5401 Z-2.0000 S1000
    G1 F1000 X42.3003 Y119.5401 Z-2.0000 S1000
    G1 F1000 X42.3003 Y120.3472 Z-2.0000 S1000
    G1 F1000 X30.0303 Y120.3472 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X23.0386 Y120.3472 Z-2.0000 S1000
    G1 F1000 X20.4249 Y120.3472 Z-2.0000 S1000
    G1 F1000 X20.4249 Y115.4081 Z-2.0000 S1000
    G1 F1000 X20.4209 Y115.2955 Z-2.0000 S1000
    G1 F1000 X20.4089 Y115.1835 Z-2.0000 S1000
    G1 F1000 X20.3890 Y115.0725 Z-2.0000 S1000
    G1 F1000 X20.3613 Y114.9633 Z-2.0000 S1000
    G1 F1000 X20.3259 Y114.8564 Z-2.0000 S1000
    G1 F1000 X20.2830 Y114.7522 Z-2.0000 S1000
    G1 F1000 X20.2329 Y114.6513 Z-2.0000 S1000
    G1 F1000 X20.1757 Y114.5542 Z-2.0000 S1000
    G1 F1000 X20.1117 Y114.4614 Z-2.0000 S1000
    G1 F1000 X20.0414 Y114.3734 Z-2.0000 S1000
    G1 F1000 X19.9650 Y114.2906 Z-2.0000 S1000
    G1 F1000 X19.8828 Y114.2134 Z-2.0000 S1000
    G1 F1000 X19.7955 Y114.1423 Z-2.0000 S1000
    G1 F1000 X19.7033 Y114.0775 Z-2.0000 S1000
    G1 F1000 X19.6067 Y114.0195 Z-2.0000 S1000
    G1 F1000 X19.5063 Y113.9684 Z-2.0000 S1000
    G1 F1000 X19.4025 Y113.9246 Z-2.0000 S1000
    G1 F1000 X19.2958 Y113.8882 Z-2.0000 S1000
    G1 F1000 X19.1868 Y113.8595 Z-2.0000 S1000
    G1 F1000 X19.0761 Y113.8387 Z-2.0000 S1000
    G1 F1000 X18.9642 Y113.8257 Z-2.0000 S1000
    G1 F1000 X18.8374 Y113.8206 Z-2.0000 S1000
    G1 F1000 X12.5398 Y113.8206 Z-2.0000 S1000
    G1 F1000 X12.4272 Y113.8246 Z-2.0000 S1000
    G1 F1000 X12.3152 Y113.8366 Z-2.0000 S1000
    G1 F1000 X12.2042 Y113.8565 Z-2.0000 S1000
    G1 F1000 X12.0950 Y113.8842 Z-2.0000 S1000
    G1 F1000 X11.9881 Y113.9196 Z-2.0000 S1000
    G1 F1000 X11.8839 Y113.9625 Z-2.0000 S1000
    G1 F1000 X11.7830 Y114.0126 Z-2.0000 S1000
    G1 F1000 X11.6859 Y114.0698 Z-2.0000 S1000
    G1 F1000 X11.5931 Y114.1338 Z-2.0000 S1000
    G1 F1000 X11.5051 Y114.2041 Z-2.0000 S1000
    G1 F1000 X11.4223 Y114.2805 Z-2.0000 S1000
    G1 F1000 X11.3451 Y114.3627 Z-2.0000 S1000
    G1 F1000 X11.2740 Y114.4500 Z-2.0000 S1000
    G1 F1000 X11.2092 Y114.5422 Z-2.0000 S1000
    G1 F1000 X11.1512 Y114.6388 Z-2.0000 S1000
    G1 F1000 X11.1001 Y114.7392 Z-2.0000 S1000
    G1 F1000 X11.0563 Y114.8430 Z-2.0000 S1000
    G1 F1000 X11.0199 Y114.9497 Z-2.0000 S1000
    G1 F1000 X10.9912 Y115.0587 Z-2.0000 S1000
    G1 F1000 X10.9704 Y115.1694 Z-2.0000 S1000
    G1 F1000 X10.9574 Y115.2813 Z-2.0000 S1000
    G1 F1000 X10.9523 Y115.4081 Z-2.0000 S1000
    G1 F1000 X10.9523 Y120.3472 Z-2.0000 S1000
    G1 F1000 X8.3641 Y120.3472 Z-2.0000 S1000
    G1 F1000 X8.3641 Y104.8711 Z-2.0000 S1000
    G1 F1000 X10.9523 Y104.8711 Z-2.0000 S1000
    G1 F1000 X10.9523 Y110.8280 Z-2.0000 S1000
    G1 F1000 X10.9563 Y110.9406 Z-2.0000 S1000
    G1 F1000 X10.9683 Y111.0526 Z-2.0000 S1000
    G1 F1000 X10.9882 Y111.1636 Z-2.0000 S1000
    G1 F1000 X11.0159 Y111.2728 Z-2.0000 S1000
    G1 F1000 X11.0513 Y111.3797 Z-2.0000 S1000
    G1 F1000 X11.0942 Y111.4839 Z-2.0000 S1000
    G1 F1000 X11.1443 Y111.5848 Z-2.0000 S1000
    G1 F1000 X11.2015 Y111.6819 Z-2.0000 S1000
    G1 F1000 X11.2655 Y111.7747 Z-2.0000 S1000
    G1 F1000 X11.3358 Y111.8627 Z-2.0000 S1000
    G1 F1000 X11.4122 Y111.9455 Z-2.0000 S1000
    G1 F1000 X11.4944 Y112.0227 Z-2.0000 S1000
    G1 F1000 X11.5817 Y112.0938 Z-2.0000 S1000
    G1 F1000 X11.6739 Y112.1586 Z-2.0000 S1000
    G1 F1000 X11.7705 Y112.2166 Z-2.0000 S1000
    G1 F1000 X11.8709 Y112.2677 Z-2.0000 S1000
    G1 F1000 X11.9747 Y112.3115 Z-2.0000 S1000
    G1 F1000 X12.0814 Y112.3479 Z-2.0000 S1000
    G1 F1000 X12.1904 Y112.3766 Z-2.0000 S1000
    G1 F1000 X12.3011 Y112.3974 Z-2.0000 S1000
    G1 F1000 X12.4130 Y112.4104 Z-2.0000 S1000
    G1 F1000 X12.5398 Y112.4155 Z-2.0000 S1000
    G1 F1000 X18.8374 Y112.4155 Z-2.0000 S1000
    G1 F1000 X18.9500 Y112.4115 Z-2.0000 S1000
    G1 F1000 X19.0620 Y112.3995 Z-2.0000 S1000
    G1 F1000 X19.1730 Y112.3796 Z-2.0000 S1000
    G1 F1000 X19.2822 Y112.3519 Z-2.0000 S1000
    G1 F1000 X19.3891 Y112.3165 Z-2.0000 S1000
    G1 F1000 X19.4933 Y112.2736 Z-2.0000 S1000
    G1 F1000 X19.5942 Y112.2235 Z-2.0000 S1000
    G1 F1000 X19.6913 Y112.1663 Z-2.0000 S1000
    G1 F1000 X19.7841 Y112.1023 Z-2.0000 S1000
    G1 F1000 X19.8721 Y112.0320 Z-2.0000 S1000
    G1 F1000 X19.9549 Y111.9556 Z-2.0000 S1000
    G1 F1000 X20.0321 Y111.8734 Z-2.0000 S1000
    G1 F1000 X20.1032 Y111.7861 Z-2.0000 S1000
    G1 F1000 X20.1680 Y111.6939 Z-2.0000 S1000
    G1 F1000 X20.2260 Y111.5973 Z-2.0000 S1000
    G1 F1000 X20.2771 Y111.4969 Z-2.0000 S1000
    G1 F1000 X20.3209 Y111.3931 Z-2.0000 S1000
    G1 F1000 X20.3573 Y111.2864 Z-2.0000 S1000
    G1 F1000 X20.3860 Y111.1774 Z-2.0000 S1000
    G1 F1000 X20.4068 Y111.0667 Z-2.0000 S1000
    G1 F1000 X20.4198 Y110.9548 Z-2.0000 S1000
    G1 F1000 X20.4249 Y110.8280 Z-2.0000 S1000
    G1 F1000 X20.4249 Y104.8711 Z-2.0000 S1000
    G1 F1000 X23.0386 Y104.8711 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X96.3889 Y111.3109 Z-2.0000 S1000
    G1 F1000 X96.3799 Y111.1986 Z-2.0000 S1000
    G1 F1000 X96.3708 Y111.1322 Z-2.0000 S1000
    G1 F1000 X96.1799 Y109.9275 Z-2.0000 S1000
    G1 F1000 X96.1584 Y109.8169 Z-2.0000 S1000
    G1 F1000 X96.1197 Y109.6789 Z-2.0000 S1000
    G1 F1000 X95.8017 Y108.7144 Z-2.0000 S1000
    G1 F1000 X95.7626 Y108.6087 Z-2.0000 S1000
    G1 F1000 X95.7162 Y108.5061 Z-2.0000 S1000
    G1 F1000 X95.6464 Y108.3802 Z-2.0000 S1000
    G1 F1000 X95.2011 Y107.6558 Z-2.0000 S1000
    G1 F1000 X95.1387 Y107.5619 Z-2.0000 S1000
    G1 F1000 X95.0699 Y107.4727 Z-2.0000 S1000
    G1 F1000 X94.9948 Y107.3887 Z-2.0000 S1000
    G1 F1000 X94.9372 Y107.3315 Z-2.0000 S1000
    G1 F1000 X94.3758 Y106.8027 Z-2.0000 S1000
    G1 F1000 X94.2911 Y106.7284 Z-2.0000 S1000
    G1 F1000 X94.2013 Y106.6603 Z-2.0000 S1000
    G1 F1000 X94.0702 Y106.5773 Z-2.0000 S1000
    G1 F1000 X93.4039 Y106.1996 Z-2.0000 S1000
    G1 F1000 X93.3039 Y106.1475 Z-2.0000 S1000
    G1 F1000 X93.2006 Y106.1027 Z-2.0000 S1000
    G1 F1000 X93.0685 Y106.0575 Z-2.0000 S1000
    G1 F1000 X92.2972 Y105.8309 Z-2.0000 S1000
    G1 F1000 X92.1880 Y105.8030 Z-2.0000 S1000
    G1 F1000 X92.0771 Y105.7829 Z-2.0000 S1000
    G1 F1000 X91.9860 Y105.7724 Z-2.0000 S1000
    G1 F1000 X91.1097 Y105.6969 Z-2.0000 S1000
    G1 F1000 X90.9971 Y105.6912 Z-2.0000 S1000
    G1 F1000 X90.8310 Y105.6974 Z-2.0000 S1000
    G1 F1000 X89.9751 Y105.7745 Z-2.0000 S1000
    G1 F1000 X89.8633 Y105.7886 Z-2.0000 S1000
    G1 F1000 X89.7528 Y105.8106 Z-2.0000 S1000
    G1 F1000 X89.6559 Y105.8367 Z-2.0000 S1000
    G1 F1000 X88.8945 Y106.0681 Z-2.0000 S1000
    G1 F1000 X88.7879 Y106.1047 Z-2.0000 S1000
    G1 F1000 X88.6842 Y106.1487 Z-2.0000 S1000
    G1 F1000 X88.5611 Y106.2129 Z-2.0000 S1000
    G1 F1000 X87.8944 Y106.5986 Z-2.0000 S1000
    G1 F1000 X87.7990 Y106.6584 Z-2.0000 S1000
    G1 F1000 X87.7080 Y106.7249 Z-2.0000 S1000
    G1 F1000 X87.5998 Y106.8181 Z-2.0000 S1000
    G1 F1000 X87.0277 Y107.3580 Z-2.0000 S1000
    G1 F1000 X86.9486 Y107.4382 Z-2.0000 S1000
    G1 F1000 X86.8753 Y107.5238 Z-2.0000 S1000
    G1 F1000 X86.7808 Y107.6559 Z-2.0000 S1000
    G1 F1000 X86.3216 Y108.3723 Z-2.0000 S1000
    G1 F1000 X86.2642 Y108.4693 Z-2.0000 S1000
    G1 F1000 X86.2138 Y108.5701 Z-2.0000 S1000
    G1 F1000 X86.1637 Y108.6934 Z-2.0000 S1000
    G1 F1000 X85.8357 Y109.6086 Z-2.0000 S1000
    G1 F1000 X85.8015 Y109.7160 Z-2.0000 S1000
    G1 F1000 X85.7668 Y109.8680 Z-2.0000 S1000
    G1 F1000 X85.5700 Y110.9820 Z-2.0000 S1000
    G1 F1000 X85.5544 Y111.0936 Z-2.0000 S1000
    G1 F1000 X85.5478 Y111.1790 Z-2.0000 S1000
    G1 F1000 X85.4822 Y112.4918 Z-2.0000 S1000
    G1 F1000 X85.4822 Y112.6500 Z-2.0000 S1000
    G1 F1000 X85.5482 Y113.9739 Z-2.0000 S1000
    G1 F1000 X85.5578 Y114.0862 Z-2.0000 S1000
    G1 F1000 X85.5703 Y114.1706 Z-2.0000 S1000
    G1 F1000 X85.7682 Y115.2926 Z-2.0000 S1000
    G1 F1000 X85.7917 Y115.4028 Z-2.0000 S1000
    G1 F1000 X85.8373 Y115.5529 Z-2.0000 S1000
    G1 F1000 X86.1673 Y116.4729 Z-2.0000 S1000
    G1 F1000 X86.2091 Y116.5775 Z-2.0000 S1000
    G1 F1000 X86.2582 Y116.6790 Z-2.0000 S1000
    G1 F1000 X86.3266 Y116.7959 Z-2.0000 S1000
    G1 F1000 X86.7886 Y117.5139 Z-2.0000 S1000
    G1 F1000 X86.8529 Y117.6064 Z-2.0000 S1000
    G1 F1000 X86.9236 Y117.6942 Z-2.0000 S1000
    G1 F1000 X87.0328 Y117.8083 Z-2.0000 S1000
    G1 F1000 X87.6037 Y118.3482 Z-2.0000 S1000
    G1 F1000 X87.6883 Y118.4227 Z-2.0000 S1000
    G1 F1000 X87.7779 Y118.4910 Z-2.0000 S1000
    G1 F1000 X87.8906 Y118.5637 Z-2.0000 S1000
    G1 F1000 X88.5474 Y118.9494 Z-2.0000 S1000
    G1 F1000 X88.6465 Y119.0030 Z-2.0000 S1000
    G1 F1000 X88.7492 Y119.0494 Z-2.0000 S1000
    G1 F1000 X88.8793 Y119.0962 Z-2.0000 S1000
    G1 F1000 X89.6220 Y119.3275 Z-2.0000 S1000
    G1 F1000 X89.7307 Y119.3572 Z-2.0000 S1000
    G1 F1000 X89.8412 Y119.3790 Z-2.0000 S1000
    G1 F1000 X89.9467 Y119.3925 Z-2.0000 S1000
    G1 F1000 X90.7752 Y119.4697 Z-2.0000 S1000
    G1 F1000 X90.8877 Y119.4761 Z-2.0000 S1000
    G1 F1000 X91.0004 Y119.4746 Z-2.0000 S1000
    G1 F1000 X91.0619 Y119.4704 Z-2.0000 S1000
    G1 F1000 X91.9243 Y119.3944 Z-2.0000 S1000
    G1 F1000 X92.0361 Y119.3805 Z-2.0000 S1000
    G1 F1000 X92.1466 Y119.3587 Z-2.0000 S1000
    G1 F1000 X92.2365 Y119.3349 Z-2.0000 S1000
    G1 F1000 X93.0042 Y119.1071 Z-2.0000 S1000
    G1 F1000 X93.1110 Y119.0712 Z-2.0000 S1000
    G1 F1000 X93.2150 Y119.0279 Z-2.0000 S1000
    G1 F1000 X93.3326 Y118.9679 Z-2.0000 S1000
    G1 F1000 X94.0057 Y118.5882 Z-2.0000 S1000
    G1 F1000 X94.1018 Y118.5294 Z-2.0000 S1000
    G1 F1000 X94.1935 Y118.4639 Z-2.0000 S1000
    G1 F1000 X94.2997 Y118.3745 Z-2.0000 S1000
    G1 F1000 X94.8782 Y117.8430 Z-2.0000 S1000
    G1 F1000 X94.9585 Y117.7639 Z-2.0000 S1000
    G1 F1000 X95.0329 Y117.6793 Z-2.0000 S1000
    G1 F1000 X95.1246 Y117.5553 Z-2.0000 S1000
    G1 F1000 X95.5893 Y116.8591 Z-2.0000 S1000
    G1 F1000 X95.6485 Y116.7633 Z-2.0000 S1000
    G1 F1000 X95.7007 Y116.6634 Z-2.0000 S1000
    G1 F1000 X95.7528 Y116.5419 Z-2.0000 S1000
    G1 F1000 X96.0848 Y115.6685 Z-2.0000 S1000
    G1 F1000 X96.1211 Y115.5618 Z-2.0000 S1000
    G1 F1000 X96.1606 Y115.4001 Z-2.0000 S1000
    G1 F1000 X96.3598 Y114.3493 Z-2.0000 S1000
    G1 F1000 X96.3769 Y114.2379 Z-2.0000 S1000
    G1 F1000 X96.3853 Y114.1393 Z-2.0000 S1000
    G1 F1000 X96.4517 Y112.9112 Z-2.0000 S1000
    G1 F1000 X96.4525 Y112.7557 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X91.1946 Y104.5565 Z-3.0000 S1000
    G1 F1000 X92.4876 Y104.6196 Z-3.0000 S1000
    G1 F1000 X93.6603 Y104.8078 Z-3.0000 S1000
    G1 F1000 X94.6847 Y105.1103 Z-3.0000 S1000
    G1 F1000 X95.5774 Y105.5221 Z-3.0000 S1000
    G1 F1000 X96.3625 Y106.0355 Z-3.0000 S1000
    G1 F1000 X97.0450 Y106.6382 Z-3.0000 S1000
    G1 F1000 X97.6286 Y107.3319 Z-3.0000 S1000
    G1 F1000 X98.1173 Y108.1217 Z-3.0000 S1000
    G1 F1000 X98.5080 Y109.0306 Z-3.0000 S1000
    G1 F1000 X98.7974 Y110.0972 Z-3.0000 S1000
    G1 F1000 X98.9785 Y111.3378 Z-3.0000 S1000
    G1 F1000 X99.0396 Y112.7253 Z-3.0000 S1000
    G1 F1000 X98.8992 Y114.6215 Z-3.0000 S1000
    G1 F1000 X98.5002 Y116.2066 Z-3.0000 S1000
    G1 F1000 X97.8621 Y117.5245 Z-3.0000 S1000
    G1 F1000 X96.9863 Y118.6172 Z-3.0000 S1000
    G1 F1000 X95.8787 Y119.4868 Z-3.0000 S1000
    G1 F1000 X94.5263 Y120.1232 Z-3.0000 S1000
    G1 F1000 X92.8846 Y120.5224 Z-3.0000 S1000
    G1 F1000 X90.9378 Y120.6611 Z-3.0000 S1000
    G1 F1000 X89.0430 Y120.5206 Z-3.0000 S1000
    G1 F1000 X87.4374 Y120.1167 Z-3.0000 S1000
    G1 F1000 X86.0963 Y119.4692 Z-3.0000 S1000
    G1 F1000 X84.9788 Y118.5787 Z-3.0000 S1000
    G1 F1000 X84.0887 Y117.4603 Z-3.0000 S1000
    G1 F1000 X83.4411 Y116.1154 Z-3.0000 S1000
    G1 F1000 X83.0365 Y114.5006 Z-3.0000 S1000
    G1 F1000 X82.8949 Y112.5786 Z-3.0000 S1000
    G1 F1000 X82.9654 Y111.2032 Z-3.0000 S1000
    G1 F1000 X83.1733 Y109.9695 Z-3.0000 S1000
    G1 F1000 X83.5076 Y108.8931 Z-3.0000 S1000
    G1 F1000 X83.9664 Y107.9497 Z-3.0000 S1000
    G1 F1000 X84.5302 Y107.1222 Z-3.0000 S1000
    G1 F1000 X85.1644 Y106.4244 Z-3.0000 S1000
    G1 F1000 X85.8638 Y105.8550 Z-3.0000 S1000
    G1 F1000 X86.6404 Y105.4011 Z-3.0000 S1000
    G1 F1000 X87.5350 Y105.0440 Z-3.0000 S1000
    G1 F1000 X88.5473 Y104.7872 Z-3.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X66.2383 Y104.8711 Z-3.0000 S1000
    G1 F1000 X77.8213 Y104.8711 Z-3.0000 S1000
    G1 F1000 X77.8213 Y106.2889 Z-3.0000 S1000
    G1 F1000 X70.4140 Y106.2889 Z-3.0000 S1000
    G1 F1000 X70.3014 Y106.2929 Z-3.0000 S1000
    G1 F1000 X70.1894 Y106.3049 Z-3.0000 S1000
    G1 F1000 X70.0784 Y106.3248 Z-3.0000 S1000
    G1 F1000 X69.9692 Y106.3525 Z-3.0000 S1000
    G1 F1000 X69.8623 Y106.3879 Z-3.0000 S1000
    G1 F1000 X69.7581 Y106.4308 Z-3.0000 S1000
    G1 F1000 X69.6572 Y106.4809 Z-3.0000 S1000
    G1 F1000 X69.5601 Y106.5381 Z-3.0000 S1000
    G1 F1000 X69.4673 Y106.6021 Z-3.0000 S1000
    G1 F1000 X69.3793 Y106.6724 Z-3.0000 S1000
    G1 F1000 X69.2965 Y106.7488 Z-3.0000 S1000
    G1 F1000 X69.2193 Y106.8310 Z-3.0000 S1000
    G1 F1000 X69.1482 Y106.9183 Z-3.0000 S1000
    G1 F1000 X69.0834 Y107.0105 Z-3.0000 S1000
    G1 F1000 X69.0254 Y107.1071 Z-3.0000 S1000
    G1 F1000 X68.9743 Y107.2075 Z-3.0000 S1000
    G1 F1000 X68.9305 Y107.3113 Z-3.0000 S1000
    G1 F1000 X68.8941 Y107.4180 Z-3.0000 S1000
    G1 F1000 X68.8654 Y107.5270 Z-3.0000 S1000
    G1 F1000 X68.8446 Y107.6377 Z-3.0000 S1000
    G1 F1000 X68.8316 Y107.7496 Z-3.0000 S1000
    G1 F1000 X68.8265 Y107.8764 Z-3.0000 S1000
    G1 F1000 X68.8265 Y120.3472 Z-3.0000 S1000
    G1 F1000 X66.2383 Y120.3472 Z-3.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X48.8595 Y104.8711 Z-3.0000 S1000
    G1 F1000 X60.4425 Y104.8711 Z-3.0000 S1000
    G1 F1000 X60.4425 Y106.2889 Z-3.0000 S1000
    G1 F1000 X53.0352 Y106.2889 Z-3.0000 S1000
    G1 F1000 X52.9226 Y106.2929 Z-3.0000 S1000
    G1 F1000 X52.8106 Y106.3049 Z-3.0000 S1000
    G1 F1000 X52.6996 Y106.3248 Z-3.0000 S1000
    G1 F1000 X52.5904 Y106.3525 Z-3.0000 S1000
    G1 F1000 X52.4835 Y106.3879 Z-3.0000 S1000
    G1 F1000 X52.3793 Y106.4308 Z-3.0000 S1000
    G1 F1000 X52.2784 Y106.4809 Z-3.0000 S1000
    G1 F1000 X52.1813 Y106.5381 Z-3.0000 S1000
    G1 F1000 X52.0885 Y106.6021 Z-3.0000 S1000
    G1 F1000 X52.0005 Y106.6724 Z-3.0000 S1000
    G1 F1000 X51.9177 Y106.7488 Z-3.0000 S1000
    G1 F1000 X51.8405 Y106.8310 Z-3.0000 S1000
    G1 F1000 X51.7694 Y106.9183 Z-3.0000 S1000
    G1 F1000 X51.7046 Y107.0105 Z-3.0000 S1000
    G1 F1000 X51.6466 Y107.1071 Z-3.0000 S1000
    G1 F1000 X51.5955 Y107.2075 Z-3.0000 S1000
    G1 F1000 X51.5517 Y107.3113 Z-3.0000 S1000
    G1 F1000 X51.5153 Y107.4180 Z-3.0000 S1000
    G1 F1000 X51.4866 Y107.5270 Z-3.0000 S1000
    G1 F1000 X51.4658 Y107.6377 Z-3.0000 S1000
    G1 F1000 X51.4528 Y107.7496 Z-3.0000 S1000
    G1 F1000 X51.4477 Y107.8764 Z-3.0000 S1000
    G1 F1000 X51.4477 Y120.3472 Z-3.0000 S1000
    G1 F1000 X48.8595 Y120.3472 Z-3.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X30.0303 Y104.8711 Z-3.0000 S1000
    G1 F1000 X42.5802 Y104.8711 Z-3.0000 S1000
    G1 F1000 X42.5802 Y105.9200 Z-3.0000 S1000
    G1 F1000 X34.2188 Y105.9200 Z-3.0000 S1000
    G1 F1000 X34.1062 Y105.9240 Z-3.0000 S1000
    G1 F1000 X33.9942 Y105.9360 Z-3.0000 S1000
    G1 F1000 X33.8832 Y105.9559 Z-3.0000 S1000
    G1 F1000 X33.7740 Y105.9836 Z-3.0000 S1000
    G1 F1000 X33.6671 Y106.0190 Z-3.0000 S1000
    G1 F1000 X33.5629 Y106.0619 Z-3.0000 S1000
    G1 F1000 X33.4620 Y106.1120 Z-3.0000 S1000
    G1 F1000 X33.3649 Y106.1692 Z-3.0000 S1000
    G1 F1000 X33.2721 Y106.2332 Z-3.0000 S1000
    G1 F1000 X33.1841 Y106.3035 Z-3.0000 S1000
    G1 F1000 X33.1013 Y106.3799 Z-3.0000 S1000
    G1 F1000 X33.0241 Y106.4621 Z-3.0000 S1000
    G1 F1000 X32.9530 Y106.5494 Z-3.0000 S1000
    G1 F1000 X32.8882 Y106.6416 Z-3.0000 S1000
    G1 F1000 X32.8302 Y106.7382 Z-3.0000 S1000
    G1 F1000 X32.7791 Y106.8386 Z-3.0000 S1000
    G1 F1000 X32.7353 Y106.9424 Z-3.0000 S1000
    G1 F1000 X32.6989 Y107.0491 Z-3.0000 S1000
    G1 F1000 X32.6702 Y107.1581 Z-3.0000 S1000
    G1 F1000 X32.6494 Y107.2688 Z-3.0000 S1000
    G1 F1000 X32.6364 Y107.3807 Z-3.0000 S1000
    G1 F1000 X32.6313 Y107.5075 Z-3.0000 S1000
    G1 F1000 X32.6313 Y111.1843 Z-3.0000 S1000
    G1 F1000 X32.6353 Y111.2969 Z-3.0000 S1000
    G1 F1000 X32.6473 Y111.4089 Z-3.0000 S1000
    G1 F1000 X32.6672 Y111.5199 Z-3.0000 S1000
    G1 F1000 X32.6949 Y111.6291 Z-3.0000 S1000
    G1 F1000 X32.7303 Y111.7360 Z-3.0000 S1000
    G1 F1000 X32.7732 Y111.8402 Z-3.0000 S1000
    G1 F1000 X32.8233 Y111.9411 Z-3.0000 S1000
    G1 F1000 X32.8805 Y112.0382 Z-3.0000 S1000
    G1 F1000 X32.9445 Y112.1310 Z-3.0000 S1000
    G1 F1000 X33.0148 Y112.2190 Z-3.0000 S1000
    G1 F1000 X33.0912 Y112.3018 Z-3.0000 S1000
    G1 F1000 X33.1734 Y112.3790 Z-3.0000 S1000
    G1 F1000 X33.2607 Y112.4501 Z-3.0000 S1000
    G1 F1000 X33.3529 Y112.5149 Z-3.0000 S1000
    G1 F1000 X33.4495 Y112.5729 Z-3.0000 S1000
    G1 F1000 X33.5499 Y112.6240 Z-3.0000 S1000
    G1 F1000 X33.6537 Y112.6678 Z-3.0000 S1000
    G1 F1000 X33.7604 Y112.7042 Z-3.0000 S1000
    G1 F1000 X33.8694 Y112.7329 Z-3.0000 S1000
    G1 F1000 X33.9801 Y112.7537 Z-3.0000 S1000
    G1 F1000 X34.0920 Y112.7667 Z-3.0000 S1000
    G1 F1000 X34.2188 Y112.7718 Z-3.0000 S1000
    G1 F1000 X41.6006 Y112.7718 Z-3.0000 S1000
    G1 F1000 X41.6006 Y113.4008 Z-3.0000 S1000
    G1 F1000 X34.2188 Y113.4008 Z-3.0000 S1000
    G1 F1000 X34.1062 Y113.4048 Z-3.0000 S1000
    G1 F1000 X33.9942 Y113.4168 Z-3.0000 S1000
    G1 F1000 X33.8832 Y113.4367 Z-3.0000 S1000
    G1 F1000 X33.7740 Y113.4644 Z-3.0000 S1000
    G1 F1000 X33.6671 Y113.4998 Z-3.0000 S1000
    G1 F1000 X33.5629 Y113.5427 Z-3.0000 S1000
    G1 F1000 X33.4620 Y113.5928 Z-3.0000 S1000
    G1 F1000 X33.3649 Y113.6500 Z-3.0000 S1000
    G1 F1000 X33.2721 Y113.7140 Z-3.0000 S1000
    G1 F1000 X33.1841 Y113.7843 Z-3.0000 S1000
    G1 F1000 X33.1013 Y113.8607 Z-3.0000 S1000
    G1 F1000 X33.0241 Y113.9429 Z-3.0000 S1000
    G1 F1000 X32.9530 Y114.0302 Z-3.0000 S1000
    G1 F1000 X32.8882 Y114.1224 Z-3.0000 S1000
    G1 F1000 X32.8302 Y114.2190 Z-3.0000 S1000
    G1 F1000 X32.7791 Y114.3194 Z-3.0000 S1000
    G1 F1000 X32.7353 Y114.4232 Z-3.0000 S1000
    G1 F1000 X32.6989 Y114.5299 Z-3.0000 S1000
    G1 F1000 X32.6702 Y114.6389 Z-3.0000 S1000
    G1 F1000 X32.6494 Y114.7496 Z-3.0000 S1000
    G1 F1000 X32.6364 Y114.8615 Z-3.0000 S1000
    G1 F1000 X32.6313 Y114.9883 Z-3.0000 S1000
    G1 F1000 X32.6313 Y117.9526 Z-3.0000 S1000
    G1 F1000 X32.6353 Y118.0652 Z-3.0000 S1000
    G1 F1000 X32.6473 Y118.1772 Z-3.0000 S1000
    G1 F1000 X32.6672 Y118.2882 Z-3.0000 S1000
    G1 F1000 X32.6949 Y118.3974 Z-3.0000 S1000
    G1 F1000 X32.7303 Y118.5043 Z-3.0000 S1000
    G1 F1000 X32.7732 Y118.6085 Z-3.0000 S1000
    G1 F1000 X32.8233 Y118.7094 Z-3.0000 S1000
    G1 F1000 X32.8805 Y118.8065 Z-3.0000 S1000
    G1 F1000 X32.9445 Y118.8993 Z-3.0000 S1000
    G1 F1000 X33.0148 Y118.9873 Z-3.0000 S1000
    G1 F1000 X33.0912 Y119.0701 Z-3.0000 S1000
    G1 F1000 X33.1734 Y119.1473 Z-3.0000 S1000
    G1 F1000 X33.2607 Y119.2184 Z-3.0000 S1000
    G1 F1000 X33.3529 Y119.2832 Z-3.0000 S1000
    G1 F1000 X33.4495 Y119.3412 Z-3.0000 S1000
    G1 F1000 X33.5499 Y119.3923 Z-3.0000 S1000
    G1 F1000 X33.6537 Y119.4361 Z-3.0000 S1000
    G1 F1000 X33.7604 Y119.4725 Z-3.0000 S1000
    G1 F1000 X33.8694 Y119.5012 Z-3.0000 S1000
    G1 F1000 X33.9801 Y119.5220 Z-3.0000 S1000
    G1 F1000 X34.0920 Y119.5350 Z-3.0000 S1000
    G1 F1000 X34.2188 Y119.5401 Z-3.0000 S1000
    G1 F1000 X42.3003 Y119.5401 Z-3.0000 S1000
    G1 F1000 X42.3003 Y120.3472 Z-3.0000 S1000
    G1 F1000 X30.0303 Y120.3472 Z-3.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X23.0386 Y120.3472 Z-3.0000 S1000
    G1 F1000 X20.4249 Y120.3472 Z-3.0000 S1000
    G1 F1000 X20.4249 Y115.4081 Z-3.0000 S1000
    G1 F1000 X20.4209 Y115.2955 Z-3.0000 S1000
    G1 F1000 X20.4089 Y115.1835 Z-3.0000 S1000
    G1 F1000 X20.3890 Y115.0725 Z-3.0000 S1000
    G1 F1000 X20.3613 Y114.9633 Z-3.0000 S1000
    G1 F1000 X20.3259 Y114.8564 Z-3.0000 S1000
    G1 F1000 X20.2830 Y114.7522 Z-3.0000 S1000
    G1 F1000 X20.2329 Y114.6513 Z-3.0000 S1000
    G1 F1000 X20.1757 Y114.5542 Z-3.0000 S1000
    G1 F1000 X20.1117 Y114.4614 Z-3.0000 S1000
    G1 F1000 X20.0414 Y114.3734 Z-3.0000 S1000
    G1 F1000 X19.9650 Y114.2906 Z-3.0000 S1000
    G1 F1000 X19.8828 Y114.2134 Z-3.0000 S1000
    G1 F1000 X19.7955 Y114.1423 Z-3.0000 S1000
    G1 F1000 X19.7033 Y114.0775 Z-3.0000 S1000
    G1 F1000 X19.6067 Y114.0195 Z-3.0000 S1000
    G1 F1000 X19.5063 Y113.9684 Z-3.0000 S1000
    G1 F1000 X19.4025 Y113.9246 Z-3.0000 S1000
    G1 F1000 X19.2958 Y113.8882 Z-3.0000 S1000
    G1 F1000 X19.1868 Y113.8595 Z-3.0000 S1000
    G1 F1000 X19.0761 Y113.8387 Z-3.0000 S1000
    G1 F1000 X18.9642 Y113.8257 Z-3.0000 S1000
    G1 F1000 X18.8374 Y113.8206 Z-3.0000 S1000
    G1 F1000 X12.5398 Y113.8206 Z-3.0000 S1000
    G1 F1000 X12.4272 Y113.8246 Z-3.0000 S1000
    G1 F1000 X12.3152 Y113.8366 Z-3.0000 S1000
    G1 F1000 X12.2042 Y113.8565 Z-3.0000 S1000
    G1 F1000 X12.0950 Y113.8842 Z-3.0000 S1000
    G1 F1000 X11.9881 Y113.9196 Z-3.0000 S1000
    G1 F1000 X11.8839 Y113.9625 Z-3.0000 S1000
    G1 F1000 X11.7830 Y114.0126 Z-3.0000 S1000
    G1 F1000 X11.6859 Y114.0698 Z-3.0000 S1000
    G1 F1000 X11.5931 Y114.1338 Z-3.0000 S1000
    G1 F1000 X11.5051 Y114.2041 Z-3.0000 S1000
    G1 F1000 X11.4223 Y114.2805 Z-3.0000 S1000
    G1 F1000 X11.3451 Y114.3627 Z-3.0000 S1000
    G1 F1000 X11.2740 Y114.4500 Z-3.0000 S1000
    G1 F1000 X11.2092 Y114.5422 Z-3.0000 S1000
    G1 F1000 X11.1512 Y114.6388 Z-3.0000 S1000
    G1 F1000 X11.1001 Y114.7392 Z-3.0000 S1000
    G1 F1000 X11.0563 Y114.8430 Z-3.0000 S1000
    G1 F1000 X11.0199 Y114.9497 Z-3.0000 S1000
    G1 F1000 X10.9912 Y115.0587 Z-3.0000 S1000
    G1 F1000 X10.9704 Y115.1694 Z-3.0000 S1000
    G1 F1000 X10.9574 Y115.2813 Z-3.0000 S1000
    G1 F1000 X10.9523 Y115.4081 Z-3.0000 S1000
    G1 F1000 X10.9523 Y120.3472 Z-3.0000 S1000
    G1 F1000 X8.3641 Y120.3472 Z-3.0000 S1000
    G1 F1000 X8.3641 Y104.8711 Z-3.0000 S1000
    G1 F1000 X10.9523 Y104.8711 Z-3.0000 S1000
    G1 F1000 X10.9523 Y110.8280 Z-3.0000 S1000
    G1 F1000 X10.9563 Y110.9406 Z-3.0000 S1000
    G1 F1000 X10.9683 Y111.0526 Z-3.0000 S1000
    G1 F1000 X10.9882 Y111.1636 Z-3.0000 S1000
    G1 F1000 X11.0159 Y111.2728 Z-3.0000 S1000
    G1 F1000 X11.0513 Y111.3797 Z-3.0000 S1000
    G1 F1000 X11.0942 Y111.4839 Z-3.0000 S1000
    G1 F1000 X11.1443 Y111.5848 Z-3.0000 S1000
    G1 F1000 X11.2015 Y111.6819 Z-3.0000 S1000
    G1 F1000 X11.2655 Y111.7747 Z-3.0000 S1000
    G1 F1000 X11.3358 Y111.8627 Z-3.0000 S1000
    G1 F1000 X11.4122 Y111.9455 Z-3.0000 S1000
    G1 F1000 X11.4944 Y112.0227 Z-3.0000 S1000
    G1 F1000 X11.5817 Y112.0938 Z-3.0000 S1000
    G1 F1000 X11.6739 Y112.1586 Z-3.0000 S1000
    G1 F1000 X11.7705 Y112.2166 Z-3.0000 S1000
    G1 F1000 X11.8709 Y112.2677 Z-3.0000 S1000
    G1 F1000 X11.9747 Y112.3115 Z-3.0000 S1000
    G1 F1000 X12.0814 Y112.3479 Z-3.0000 S1000
    G1 F1000 X12.1904 Y112.3766 Z-3.0000 S1000
    G1 F1000 X12.3011 Y112.3974 Z-3.0000 S1000
    G1 F1000 X12.4130 Y112.4104 Z-3.0000 S1000
    G1 F1000 X12.5398 Y112.4155 Z-3.0000 S1000
    G1 F1000 X18.8374 Y112.4155 Z-3.0000 S1000
    G1 F1000 X18.9500 Y112.4115 Z-3.0000 S1000
    G1 F1000 X19.0620 Y112.3995 Z-3.0000 S1000
    G1 F1000 X19.1730 Y112.3796 Z-3.0000 S1000
    G1 F1000 X19.2822 Y112.3519 Z-3.0000 S1000
    G1 F1000 X19.3891 Y112.3165 Z-3.0000 S1000
    G1 F1000 X19.4933 Y112.2736 Z-3.0000 S1000
    G1 F1000 X19.5942 Y112.2235 Z-3.0000 S1000
    G1 F1000 X19.6913 Y112.1663 Z-3.0000 S1000
    G1 F1000 X19.7841 Y112.1023 Z-3.0000 S1000
    G1 F1000 X19.8721 Y112.0320 Z-3.0000 S1000
    G1 F1000 X19.9549 Y111.9556 Z-3.0000 S1000
    G1 F1000 X20.0321 Y111.8734 Z-3.0000 S1000
    G1 F1000 X20.1032 Y111.7861 Z-3.0000 S1000
    G1 F1000 X20.1680 Y111.6939 Z-3.0000 S1000
    G1 F1000 X20.2260 Y111.5973 Z-3.0000 S1000
    G1 F1000 X20.2771 Y111.4969 Z-3.0000 S1000
    G1 F1000 X20.3209 Y111.3931 Z-3.0000 S1000
    G1 F1000 X20.3573 Y111.2864 Z-3.0000 S1000
    G1 F1000 X20.3860 Y111.1774 Z-3.0000 S1000
    G1 F1000 X20.4068 Y111.0667 Z-3.0000 S1000
    G1 F1000 X20.4198 Y110.9548 Z-3.0000 S1000
    G1 F1000 X20.4249 Y110.8280 Z-3.0000 S1000
    G1 F1000 X20.4249 Y104.8711 Z-3.0000 S1000
    G1 F1000 X23.0386 Y104.8711 Z-3.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X96.3889 Y111.3109 Z-3.0000 S1000
    G1 F1000 X96.3799 Y111.1986 Z-3.0000 S1000
    G1 F1000 X96.3708 Y111.1322 Z-3.0000 S1000
    G1 F1000 X96.1799 Y109.9275 Z-3.0000 S1000
    G1 F1000 X96.1584 Y109.8169 Z-3.0000 S1000
    G1 F1000 X96.1197 Y109.6789 Z-3.0000 S1000
    G1 F1000 X95.8017 Y108.7144 Z-3.0000 S1000
    G1 F1000 X95.7626 Y108.6087 Z-3.0000 S1000
    G1 F1000 X95.7162 Y108.5061 Z-3.0000 S1000
    G1 F1000 X95.6464 Y108.3802 Z-3.0000 S1000
    G1 F1000 X95.2011 Y107.6558 Z-3.0000 S1000
    G1 F1000 X95.1387 Y107.5619 Z-3.0000 S1000
    G1 F1000 X95.0699 Y107.4727 Z-3.0000 S1000
    G1 F1000 X94.9948 Y107.3887 Z-3.0000 S1000
    G1 F1000 X94.9372 Y107.3315 Z-3.0000 S1000
    G1 F1000 X94.3758 Y106.8027 Z-3.0000 S1000
    G1 F1000 X94.2911 Y106.7284 Z-3.0000 S1000
    G1 F1000 X94.2013 Y106.6603 Z-3.0000 S1000
    G1 F1000 X94.0702 Y106.5773 Z-3.0000 S1000
    G1 F1000 X93.4039 Y106.1996 Z-3.0000 S1000
    G1 F1000 X93.3039 Y106.1475 Z-3.0000 S1000
    G1 F1000 X93.2006 Y106.1027 Z-3.0000 S1000
    G1 F1000 X93.0685 Y106.0575 Z-3.0000 S1000
    G1 F1000 X92.2972 Y105.8309 Z-3.0000 S1000
    G1 F1000 X92.1880 Y105.8030 Z-3.0000 S1000
    G1 F1000 X92.0771 Y105.7829 Z-3.0000 S1000
    G1 F1000 X91.9860 Y105.7724 Z-3.0000 S1000
    G1 F1000 X91.1097 Y105.6969 Z-3.0000 S1000
    G1 F1000 X90.9971 Y105.6912 Z-3.0000 S1000
    G1 F1000 X90.8310 Y105.6974 Z-3.0000 S1000
    G1 F1000 X89.9751 Y105.7745 Z-3.0000 S1000
    G1 F1000 X89.8633 Y105.7886 Z-3.0000 S1000
    G1 F1000 X89.7528 Y105.8106 Z-3.0000 S1000
    G1 F1000 X89.6559 Y105.8367 Z-3.0000 S1000
    G1 F1000 X88.8945 Y106.0681 Z-3.0000 S1000
    G1 F1000 X88.7879 Y106.1047 Z-3.0000 S1000
    G1 F1000 X88.6842 Y106.1487 Z-3.0000 S1000
    G1 F1000 X88.5611 Y106.2129 Z-3.0000 S1000
    G1 F1000 X87.8944 Y106.5986 Z-3.0000 S1000
    G1 F1000 X87.7990 Y106.6584 Z-3.0000 S1000
    G1 F1000 X87.7080 Y106.7249 Z-3.0000 S1000
    G1 F1000 X87.5998 Y106.8181 Z-3.0000 S1000
    G1 F1000 X87.0277 Y107.3580 Z-3.0000 S1000
    G1 F1000 X86.9486 Y107.4382 Z-3.0000 S1000
    G1 F1000 X86.8753 Y107.5238 Z-3.0000 S1000
    G1 F1000 X86.7808 Y107.6559 Z-3.0000 S1000
    G1 F1000 X86.3216 Y108.3723 Z-3.0000 S1000
    G1 F1000 X86.2642 Y108.4693 Z-3.0000 S1000
    G1 F1000 X86.2138 Y108.5701 Z-3.0000 S1000
    G1 F1000 X86.1637 Y108.6934 Z-3.0000 S1000
    G1 F1000 X85.8357 Y109.6086 Z-3.0000 S1000
    G1 F1000 X85.8015 Y109.7160 Z-3.0000 S1000
    G1 F1000 X85.7668 Y109.8680 Z-3.0000 S1000
    G1 F1000 X85.5700 Y110.9820 Z-3.0000 S1000
    G1 F1000 X85.5544 Y111.0936 Z-3.0000 S1000
    G1 F1000 X85.5478 Y111.1790 Z-3.0000 S1000
    G1 F1000 X85.4822 Y112.4918 Z-3.0000 S1000
    G1 F1000 X85.4822 Y112.6500 Z-3.0000 S1000
    G1 F1000 X85.5482 Y113.9739 Z-3.0000 S1000
    G1 F1000 X85.5578 Y114.0862 Z-3.0000 S1000
    G1 F1000 X85.5703 Y114.1706 Z-3.0000 S1000
    G1 F1000 X85.7682 Y115.2926 Z-3.0000 S1000
    G1 F1000 X85.7917 Y115.4028 Z-3.0000 S1000
    G1 F1000 X85.8373 Y115.5529 Z-3.0000 S1000
    G1 F1000 X86.1673 Y116.4729 Z-3.0000 S1000
    G1 F1000 X86.2091 Y116.5775 Z-3.0000 S1000
    G1 F1000 X86.2582 Y116.6790 Z-3.0000 S1000
    G1 F1000 X86.3266 Y116.7959 Z-3.0000 S1000
    G1 F1000 X86.7886 Y117.5139 Z-3.0000 S1000
    G1 F1000 X86.8529 Y117.6064 Z-3.0000 S1000
    G1 F1000 X86.9236 Y117.6942 Z-3.0000 S1000
    G1 F1000 X87.0328 Y117.8083 Z-3.0000 S1000
    G1 F1000 X87.6037 Y118.3482 Z-3.0000 S1000
    G1 F1000 X87.6883 Y118.4227 Z-3.0000 S1000
    G1 F1000 X87.7779 Y118.4910 Z-3.0000 S1000
    G1 F1000 X87.8906 Y118.5637 Z-3.0000 S1000
    G1 F1000 X88.5474 Y118.9494 Z-3.0000 S1000
    G1 F1000 X88.6465 Y119.0030 Z-3.0000 S1000
    G1 F1000 X88.7492 Y119.0494 Z-3.0000 S1000
    G1 F1000 X88.8793 Y119.0962 Z-3.0000 S1000
    G1 F1000 X89.6220 Y119.3275 Z-3.0000 S1000
    G1 F1000 X89.7307 Y119.3572 Z-3.0000 S1000
    G1 F1000 X89.8412 Y119.3790 Z-3.0000 S1000
    G1 F1000 X89.9467 Y119.3925 Z-3.0000 S1000
    G1 F1000 X90.7752 Y119.4697 Z-3.0000 S1000
    G1 F1000 X90.8877 Y119.4761 Z-3.0000 S1000
    G1 F1000 X91.0004 Y119.4746 Z-3.0000 S1000
    G1 F1000 X91.0619 Y119.4704 Z-3.0000 S1000
    G1 F1000 X91.9243 Y119.3944 Z-3.0000 S1000
    G1 F1000 X92.0361 Y119.3805 Z-3.0000 S1000
    G1 F1000 X92.1466 Y119.3587 Z-3.0000 S1000
    G1 F1000 X92.2365 Y119.3349 Z-3.0000 S1000
    G1 F1000 X93.0042 Y119.1071 Z-3.0000 S1000
    G1 F1000 X93.1110 Y119.0712 Z-3.0000 S1000
    G1 F1000 X93.2150 Y119.0279 Z-3.0000 S1000
    G1 F1000 X93.3326 Y118.9679 Z-3.0000 S1000
    G1 F1000 X94.0057 Y118.5882 Z-3.0000 S1000
    G1 F1000 X94.1018 Y118.5294 Z-3.0000 S1000
    G1 F1000 X94.1935 Y118.4639 Z-3.0000 S1000
    G1 F1000 X94.2997 Y118.3745 Z-3.0000 S1000
    G1 F1000 X94.8782 Y117.8430 Z-3.0000 S1000
    G1 F1000 X94.9585 Y117.7639 Z-3.0000 S1000
    G1 F1000 X95.0329 Y117.6793 Z-3.0000 S1000
    G1 F1000 X95.1246 Y117.5553 Z-3.0000 S1000
    G1 F1000 X95.5893 Y116.8591 Z-3.0000 S1000
    G1 F1000 X95.6485 Y116.7633 Z-3.0000 S1000
    G1 F1000 X95.7007 Y116.6634 Z-3.0000 S1000
    G1 F1000 X95.7528 Y116.5419 Z-3.0000 S1000
    G1 F1000 X96.0848 Y115.6685 Z-3.0000 S1000
    G1 F1000 X96.1211 Y115.5618 Z-3.0000 S1000
    G1 F1000 X96.1606 Y115.4001 Z-3.0000 S1000
    G1 F1000 X96.3598 Y114.3493 Z-3.0000 S1000
    G1 F1000 X96.3769 Y114.2379 Z-3.0000 S1000
    G1 F1000 X96.3853 Y114.1393 Z-3.0000 S1000
    G1 F1000 X96.4517 Y112.9112 Z-3.0000 S1000
    G1 F1000 X96.4525 Y112.7557 Z-3.0000 S1000
    ; retracting back to z-safe
    G0 Z7
    ; Operation 1: CNC: Vector (path outside)
    G0 Z7
    G0 F1000 X-1.5496 Y19.1983
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X2.7255 Y-0.0171 Z-1.0000 S1000
    G1 F1000 X2.7538 Y-0.1261 Z-1.0000 S1000
    G1 F1000 X2.7899 Y-0.2329 Z-1.0000 S1000
    G1 F1000 X2.8334 Y-0.3368 Z-1.0000 S1000
    G1 F1000 X2.8841 Y-0.4374 Z-1.0000 S1000
    G1 F1000 X2.9419 Y-0.5341 Z-1.0000 S1000
    G1 F1000 X3.0064 Y-0.6265 Z-1.0000 S1000
    G1 F1000 X3.0773 Y-0.7141 Z-1.0000 S1000
    G1 F1000 X3.1542 Y-0.7965 Z-1.0000 S1000
    G1 F1000 X3.2368 Y-0.8731 Z-1.0000 S1000
    G1 F1000 X3.3246 Y-0.9438 Z-1.0000 S1000
    G1 F1000 X3.4171 Y-1.0080 Z-1.0000 S1000
    G1 F1000 X3.5141 Y-1.0655 Z-1.0000 S1000
    G1 F1000 X3.6148 Y-1.1160 Z-1.0000 S1000
    G1 F1000 X3.7189 Y-1.1592 Z-1.0000 S1000
    G1 F1000 X3.8257 Y-1.1949 Z-1.0000 S1000
    G1 F1000 X3.9349 Y-1.2229 Z-1.0000 S1000
    G1 F1000 X4.0457 Y-1.2431 Z-1.0000 S1000
    G1 F1000 X4.1577 Y-1.2555 Z-1.0000 S1000
    G1 F1000 X4.2751 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X10.0976 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X10.2102 Y-1.2558 Z-1.0000 S1000
    G1 F1000 X10.3222 Y-1.2438 Z-1.0000 S1000
    G1 F1000 X10.4332 Y-1.2239 Z-1.0000 S1000
    G1 F1000 X10.5424 Y-1.1962 Z-1.0000 S1000
    G1 F1000 X10.6493 Y-1.1608 Z-1.0000 S1000
    G1 F1000 X10.7535 Y-1.1179 Z-1.0000 S1000
    G1 F1000 X10.8544 Y-1.0678 Z-1.0000 S1000
    G1 F1000 X10.9515 Y-1.0106 Z-1.0000 S1000
    G1 F1000 X11.0443 Y-0.9466 Z-1.0000 S1000
    G1 F1000 X11.1323 Y-0.8763 Z-1.0000 S1000
    G1 F1000 X11.2151 Y-0.7999 Z-1.0000 S1000
    G1 F1000 X11.2923 Y-0.7177 Z-1.0000 S1000
    G1 F1000 X11.3634 Y-0.6304 Z-1.0000 S1000
    G1 F1000 X11.4282 Y-0.5382 Z-1.0000 S1000
    G1 F1000 X11.4862 Y-0.4416 Z-1.0000 S1000
    G1 F1000 X11.5373 Y-0.3412 Z-1.0000 S1000
    G1 F1000 X11.5811 Y-0.2374 Z-1.0000 S1000
    G1 F1000 X11.6273 Y-0.0968 Z-1.0000 S1000
    G1 F1000 X13.4577 Y6.4995 Z-1.0000 S1000
    G1 F1000 X15.2957 Y-0.0983 Z-1.0000 S1000
    G1 F1000 X15.3298 Y-0.2057 Z-1.0000 S1000
    G1 F1000 X15.3714 Y-0.3104 Z-1.0000 S1000
    G1 F1000 X15.4203 Y-0.4119 Z-1.0000 S1000
    G1 F1000 X15.4763 Y-0.5097 Z-1.0000 S1000
    G1 F1000 X15.5391 Y-0.6033 Z-1.0000 S1000
    G1 F1000 X15.6084 Y-0.6921 Z-1.0000 S1000
    G1 F1000 X15.6838 Y-0.7759 Z-1.0000 S1000
    G1 F1000 X15.7650 Y-0.8540 Z-1.0000 S1000
    G1 F1000 X15.8514 Y-0.9262 Z-1.0000 S1000
    G1 F1000 X15.9428 Y-0.9921 Z-1.0000 S1000
    G1 F1000 X16.0387 Y-1.0514 Z-1.0000 S1000
    G1 F1000 X16.1385 Y-1.1037 Z-1.0000 S1000
    G1 F1000 X16.2418 Y-1.1488 Z-1.0000 S1000
    G1 F1000 X16.3480 Y-1.1864 Z-1.0000 S1000
    G1 F1000 X16.4566 Y-1.2165 Z-1.0000 S1000
    G1 F1000 X16.5670 Y-1.2387 Z-1.0000 S1000
    G1 F1000 X16.6788 Y-1.2531 Z-1.0000 S1000
    G1 F1000 X16.8250 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X22.6476 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X22.7602 Y-1.2558 Z-1.0000 S1000
    G1 F1000 X22.8722 Y-1.2438 Z-1.0000 S1000
    G1 F1000 X22.9832 Y-1.2239 Z-1.0000 S1000
    G1 F1000 X23.0924 Y-1.1962 Z-1.0000 S1000
    G1 F1000 X23.1993 Y-1.1608 Z-1.0000 S1000
    G1 F1000 X23.3035 Y-1.1179 Z-1.0000 S1000
    G1 F1000 X23.4044 Y-1.0678 Z-1.0000 S1000
    G1 F1000 X23.5015 Y-1.0106 Z-1.0000 S1000
    G1 F1000 X23.5943 Y-0.9466 Z-1.0000 S1000
    G1 F1000 X23.6823 Y-0.8763 Z-1.0000 S1000
    G1 F1000 X23.7651 Y-0.7999 Z-1.0000 S1000
    G1 F1000 X23.8423 Y-0.7177 Z-1.0000 S1000
    G1 F1000 X23.9134 Y-0.6304 Z-1.0000 S1000
    G1 F1000 X23.9782 Y-0.5382 Z-1.0000 S1000
    G1 F1000 X24.0362 Y-0.4416 Z-1.0000 S1000
    G1 F1000 X24.0873 Y-0.3412 Z-1.0000 S1000
    G1 F1000 X24.1311 Y-0.2374 Z-1.0000 S1000
    G1 F1000 X24.1675 Y-0.1307 Z-1.0000 S1000
    G1 F1000 X24.1979 Y-0.0140 Z-1.0000 S1000
    G1 F1000 X26.5326 Y10.5773 Z-1.0000 S1000
    G1 F1000 X26.4929 Y10.0390 Z-1.0000 S1000
    G1 F1000 X26.4886 Y9.9264 Z-1.0000 S1000
    G1 F1000 X26.4907 Y9.8411 Z-1.0000 S1000
    G1 F1000 X26.5734 Y8.2273 Z-1.0000 S1000
    G1 F1000 X26.5831 Y8.1150 Z-1.0000 S1000
    G1 F1000 X26.5934 Y8.0447 Z-1.0000 S1000
    G1 F1000 X26.8416 Y6.5717 Z-1.0000 S1000
    G1 F1000 X26.8642 Y6.4613 Z-1.0000 S1000
    G1 F1000 X26.8909 Y6.3646 Z-1.0000 S1000
    G1 F1000 X27.3046 Y5.0326 Z-1.0000 S1000
    G1 F1000 X27.3419 Y4.9263 Z-1.0000 S1000
    G1 F1000 X27.3930 Y4.8093 Z-1.0000 S1000
    G1 F1000 X27.9722 Y3.6181 Z-1.0000 S1000
    G1 F1000 X28.0251 Y3.5186 Z-1.0000 S1000
    G1 F1000 X28.0880 Y3.4183 Z-1.0000 S1000
    G1 F1000 X28.8003 Y2.3730 Z-1.0000 S1000
    G1 F1000 X28.8670 Y2.2822 Z-1.0000 S1000
    G1 F1000 X28.9374 Y2.1993 Z-1.0000 S1000
    G1 F1000 X29.7505 Y1.3047 Z-1.0000 S1000
    G1 F1000 X29.8292 Y1.2240 Z-1.0000 S1000
    G1 F1000 X29.9231 Y1.1412 Z-1.0000 S1000
    G1 F1000 X30.8369 Y0.3974 Z-1.0000 S1000
    G1 F1000 X30.9268 Y0.3294 Z-1.0000 S1000
    G1 F1000 X31.0379 Y0.2581 Z-1.0000 S1000
    G1 F1000 X32.0525 Y-0.3350 Z-1.0000 S1000
    G1 F1000 X32.1518 Y-0.3884 Z-1.0000 S1000
    G1 F1000 X32.2652 Y-0.4389 Z-1.0000 S1000
    G1 F1000 X33.4002 Y-0.8919 Z-1.0000 S1000
    G1 F1000 X33.5063 Y-0.9299 Z-1.0000 S1000
    G1 F1000 X33.5982 Y-0.9562 Z-1.0000 S1000
    G1 F1000 X34.8733 Y-1.2798 Z-1.0000 S1000
    G1 F1000 X34.9834 Y-1.3036 Z-1.0000 S1000
    G1 F1000 X35.1260 Y-1.3226 Z-1.0000 S1000
    G1 F1000 X38.0965 Y-1.5815 Z-1.0000 S1000
    G1 F1000 X38.2090 Y-1.5873 Z-1.0000 S1000
    G1 F1000 X38.3119 Y-1.5856 Z-1.0000 S1000
    G1 F1000 X39.8451 Y-1.5106 Z-1.0000 S1000
    G1 F1000 X39.9573 Y-1.5011 Z-1.0000 S1000
    G1 F1000 X40.0190 Y-1.4925 Z-1.0000 S1000
    G1 F1000 X41.4202 Y-1.2677 Z-1.0000 S1000
    G1 F1000 X41.5307 Y-1.2459 Z-1.0000 S1000
    G1 F1000 X41.6182 Y-1.2227 Z-1.0000 S1000
    G1 F1000 X42.8876 Y-0.8479 Z-1.0000 S1000
    G1 F1000 X42.9945 Y-0.8122 Z-1.0000 S1000
    G1 F1000 X43.1030 Y-0.7669 Z-1.0000 S1000
    G1 F1000 X44.2405 Y-0.2422 Z-1.0000 S1000
    G1 F1000 X44.3411 Y-0.1914 Z-1.0000 S1000
    G1 F1000 X44.4445 Y-0.1293 Z-1.0000 S1000
    G1 F1000 X45.4529 Y0.5302 Z-1.0000 S1000
    G1 F1000 X45.5450 Y0.5952 Z-1.0000 S1000
    G1 F1000 X45.6348 Y0.6688 Z-1.0000 S1000
    G1 F1000 X46.5171 Y1.4479 Z-1.0000 S1000
    G1 F1000 X46.5988 Y1.5255 Z-1.0000 S1000
    G1 F1000 X46.6809 Y1.6157 Z-1.0000 S1000
    G1 F1000 X47.4371 Y2.5143 Z-1.0000 S1000
    G1 F1000 X47.5066 Y2.6031 Z-1.0000 S1000
    G1 F1000 X47.5726 Y2.7014 Z-1.0000 S1000
    G1 F1000 X48.2025 Y3.7197 Z-1.0000 S1000
    G1 F1000 X48.2583 Y3.8175 Z-1.0000 S1000
    G1 F1000 X48.3108 Y3.9278 Z-1.0000 S1000
    G1 F1000 X48.8069 Y5.0817 Z-1.0000 S1000
    G1 F1000 X48.8477 Y5.1867 Z-1.0000 S1000
    G1 F1000 X48.8806 Y5.2929 Z-1.0000 S1000
    G1 F1000 X49.2349 Y6.5983 Z-1.0000 S1000
    G1 F1000 X49.2605 Y6.7080 Z-1.0000 S1000
    G1 F1000 X49.2737 Y6.7849 Z-1.0000 S1000
    G1 F1000 X49.4863 Y8.2419 Z-1.0000 S1000
    G1 F1000 X49.5014 Y8.4013 Z-1.0000 S1000
    G1 F1000 X49.5722 Y10.0098 Z-1.0000 S1000
    G1 F1000 X49.5731 Y10.1225 Z-1.0000 S1000
    G1 F1000 X49.5694 Y10.1968 Z-1.0000 S1000
    G1 F1000 X49.4072 Y12.3878 Z-1.0000 S1000
    G1 F1000 X49.3949 Y12.4998 Z-1.0000 S1000
    G1 F1000 X49.3635 Y12.6582 Z-1.0000 S1000
    G1 F1000 X48.8769 Y14.5911 Z-1.0000 S1000
    G1 F1000 X48.8455 Y14.6993 Z-1.0000 S1000
    G1 F1000 X48.8065 Y14.8050 Z-1.0000 S1000
    G1 F1000 X48.7662 Y14.8953 Z-1.0000 S1000
    G1 F1000 X47.9552 Y16.5702 Z-1.0000 S1000
    G1 F1000 X47.9025 Y16.6699 Z-1.0000 S1000
    G1 F1000 X47.8429 Y16.7655 Z-1.0000 S1000
    G1 F1000 X47.7652 Y16.8711 Z-1.0000 S1000
    G1 F1000 X46.6298 Y18.2879 Z-1.0000 S1000
    G1 F1000 X46.5563 Y18.3733 Z-1.0000 S1000
    G1 F1000 X46.4768 Y18.4533 Z-1.0000 S1000
    G1 F1000 X46.3713 Y18.5438 Z-1.0000 S1000
    G1 F1000 X44.9360 Y19.6707 Z-1.0000 S1000
    G1 F1000 X44.8450 Y19.7371 Z-1.0000 S1000
    G1 F1000 X44.7495 Y19.7969 Z-1.0000 S1000
    G1 F1000 X44.6316 Y19.8585 Z-1.0000 S1000
    G1 F1000 X42.9211 Y20.6633 Z-1.0000 S1000
    G1 F1000 X42.8175 Y20.7077 Z-1.0000 S1000
    G1 F1000 X42.7110 Y20.7445 Z-1.0000 S1000
    G1 F1000 X42.6204 Y20.7694 Z-1.0000 S1000
    G1 F1000 X40.6346 Y21.2524 Z-1.0000 S1000
    G1 F1000 X40.5242 Y21.2752 Z-1.0000 S1000
    G1 F1000 X40.3721 Y21.2934 Z-1.0000 S1000
    G1 F1000 X38.1111 Y21.4543 Z-1.0000 S1000
    G1 F1000 X37.9985 Y21.4583 Z-1.0000 S1000
    G1 F1000 X37.8811 Y21.4540 Z-1.0000 S1000
    G1 F1000 X35.6700 Y21.2902 Z-1.0000 S1000
    G1 F1000 X35.5580 Y21.2779 Z-1.0000 S1000
    G1 F1000 X35.4000 Y21.2465 Z-1.0000 S1000
    G1 F1000 X33.4462 Y20.7550 Z-1.0000 S1000
    G1 F1000 X33.3380 Y20.7237 Z-1.0000 S1000
    G1 F1000 X33.2323 Y20.6847 Z-1.0000 S1000
    G1 F1000 X33.1432 Y20.6450 Z-1.0000 S1000
    G1 F1000 X31.4466 Y19.8257 Z-1.0000 S1000
    G1 F1000 X31.3469 Y19.7732 Z-1.0000 S1000
    G1 F1000 X31.2512 Y19.7137 Z-1.0000 S1000
    G1 F1000 X31.1476 Y19.6377 Z-1.0000 S1000
    G1 F1000 X29.7083 Y18.4908 Z-1.0000 S1000
    G1 F1000 X29.6227 Y18.4175 Z-1.0000 S1000
    G1 F1000 X29.5426 Y18.3383 Z-1.0000 S1000
    G1 F1000 X29.4555 Y18.2379 Z-1.0000 S1000
    G1 F1000 X28.3086 Y16.7970 Z-1.0000 S1000
    G1 F1000 X28.2416 Y16.7064 Z-1.0000 S1000
    G1 F1000 X28.1812 Y16.6113 Z-1.0000 S1000
    G1 F1000 X28.1204 Y16.4971 Z-1.0000 S1000
    G1 F1000 X27.5986 Y15.4134 Z-1.0000 S1000
    G1 F1000 X28.4336 Y19.2014 Z-1.0000 S1000
    G1 F1000 X28.4539 Y19.3122 Z-1.0000 S1000
    G1 F1000 X28.4663 Y19.4242 Z-1.0000 S1000
    G1 F1000 X28.4708 Y19.5368 Z-1.0000 S1000
    G1 F1000 X28.4672 Y19.6494 Z-1.0000 S1000
    G1 F1000 X28.4557 Y19.7615 Z-1.0000 S1000
    G1 F1000 X28.4363 Y19.8725 Z-1.0000 S1000
    G1 F1000 X28.4090 Y19.9818 Z-1.0000 S1000
    G1 F1000 X28.3740 Y20.0889 Z-1.0000 S1000
    G1 F1000 X28.3316 Y20.1933 Z-1.0000 S1000
    G1 F1000 X28.2818 Y20.2944 Z-1.0000 S1000
    G1 F1000 X28.2250 Y20.3917 Z-1.0000 S1000
    G1 F1000 X28.1614 Y20.4847 Z-1.0000 S1000
    G1 F1000 X28.0914 Y20.5730 Z-1.0000 S1000
    G1 F1000 X28.0153 Y20.6561 Z-1.0000 S1000
    G1 F1000 X27.9335 Y20.7336 Z-1.0000 S1000
    G1 F1000 X27.8464 Y20.8051 Z-1.0000 S1000
    G1 F1000 X27.7545 Y20.8702 Z-1.0000 S1000
    G1 F1000 X27.6581 Y20.9287 Z-1.0000 S1000
    G1 F1000 X27.5579 Y20.9801 Z-1.0000 S1000
    G1 F1000 X27.4543 Y21.0244 Z-1.0000 S1000
    G1 F1000 X27.3478 Y21.0611 Z-1.0000 S1000
    G1 F1000 X27.2389 Y21.0903 Z-1.0000 S1000
    G1 F1000 X27.1283 Y21.1116 Z-1.0000 S1000
    G1 F1000 X27.0164 Y21.1250 Z-1.0000 S1000
    G1 F1000 X26.8833 Y21.1306 Z-1.0000 S1000
    G1 F1000 X21.2729 Y21.1306 Z-1.0000 S1000
    G1 F1000 X21.1603 Y21.1266 Z-1.0000 S1000
    G1 F1000 X21.0483 Y21.1146 Z-1.0000 S1000
    G1 F1000 X20.9373 Y21.0947 Z-1.0000 S1000
    G1 F1000 X20.8281 Y21.0670 Z-1.0000 S1000
    G1 F1000 X20.7212 Y21.0316 Z-1.0000 S1000
    G1 F1000 X20.6170 Y20.9887 Z-1.0000 S1000
    G1 F1000 X20.5161 Y20.9386 Z-1.0000 S1000
    G1 F1000 X20.4190 Y20.8814 Z-1.0000 S1000
    G1 F1000 X20.3262 Y20.8174 Z-1.0000 S1000
    G1 F1000 X20.2382 Y20.7471 Z-1.0000 S1000
    G1 F1000 X20.1554 Y20.6707 Z-1.0000 S1000
    G1 F1000 X20.0782 Y20.5885 Z-1.0000 S1000
    G1 F1000 X20.0071 Y20.5012 Z-1.0000 S1000
    G1 F1000 X19.9423 Y20.4090 Z-1.0000 S1000
    G1 F1000 X19.8843 Y20.3124 Z-1.0000 S1000
    G1 F1000 X19.8332 Y20.2120 Z-1.0000 S1000
    G1 F1000 X19.7894 Y20.1082 Z-1.0000 S1000
    G1 F1000 X19.7530 Y20.0015 Z-1.0000 S1000
    G1 F1000 X19.7131 Y19.8382 Z-1.0000 S1000
    G1 F1000 X18.9480 Y15.7948 Z-1.0000 S1000
    G1 F1000 X17.7910 Y19.9673 Z-1.0000 S1000
    G1 F1000 X17.7570 Y20.0747 Z-1.0000 S1000
    G1 F1000 X17.7156 Y20.1795 Z-1.0000 S1000
    G1 F1000 X17.6667 Y20.2811 Z-1.0000 S1000
    G1 F1000 X17.6109 Y20.3789 Z-1.0000 S1000
    G1 F1000 X17.5482 Y20.4725 Z-1.0000 S1000
    G1 F1000 X17.4790 Y20.5615 Z-1.0000 S1000
    G1 F1000 X17.4037 Y20.6453 Z-1.0000 S1000
    G1 F1000 X17.3226 Y20.7236 Z-1.0000 S1000
    G1 F1000 X17.2362 Y20.7959 Z-1.0000 S1000
    G1 F1000 X17.1449 Y20.8619 Z-1.0000 S1000
    G1 F1000 X17.0491 Y20.9213 Z-1.0000 S1000
    G1 F1000 X16.9494 Y20.9737 Z-1.0000 S1000
    G1 F1000 X16.8462 Y21.0189 Z-1.0000 S1000
    G1 F1000 X16.7400 Y21.0567 Z-1.0000 S1000
    G1 F1000 X16.6315 Y21.0868 Z-1.0000 S1000
    G1 F1000 X16.5210 Y21.1092 Z-1.0000 S1000
    G1 F1000 X16.4093 Y21.1237 Z-1.0000 S1000
    G1 F1000 X16.2612 Y21.1306 Z-1.0000 S1000
    G1 F1000 X10.6418 Y21.1306 Z-1.0000 S1000
    G1 F1000 X10.5292 Y21.1266 Z-1.0000 S1000
    G1 F1000 X10.4172 Y21.1146 Z-1.0000 S1000
    G1 F1000 X10.3062 Y21.0947 Z-1.0000 S1000
    G1 F1000 X10.1970 Y21.0670 Z-1.0000 S1000
    G1 F1000 X10.0901 Y21.0316 Z-1.0000 S1000
    G1 F1000 X9.9859 Y20.9887 Z-1.0000 S1000
    G1 F1000 X9.8850 Y20.9386 Z-1.0000 S1000
    G1 F1000 X9.7879 Y20.8814 Z-1.0000 S1000
    G1 F1000 X9.6951 Y20.8174 Z-1.0000 S1000
    G1 F1000 X9.6071 Y20.7471 Z-1.0000 S1000
    G1 F1000 X9.5243 Y20.6707 Z-1.0000 S1000
    G1 F1000 X9.4471 Y20.5885 Z-1.0000 S1000
    G1 F1000 X9.3760 Y20.5012 Z-1.0000 S1000
    G1 F1000 X9.3112 Y20.4090 Z-1.0000 S1000
    G1 F1000 X9.2532 Y20.3124 Z-1.0000 S1000
    G1 F1000 X9.2021 Y20.2120 Z-1.0000 S1000
    G1 F1000 X9.1583 Y20.1082 Z-1.0000 S1000
    G1 F1000 X9.1116 Y19.9658 Z-1.0000 S1000
    G1 F1000 X7.9614 Y15.8021 Z-1.0000 S1000
    G1 F1000 X7.1997 Y19.8375 Z-1.0000 S1000
    G1 F1000 X7.1748 Y19.9474 Z-1.0000 S1000
    G1 F1000 X7.1423 Y20.0553 Z-1.0000 S1000
    G1 F1000 X7.1022 Y20.1606 Z-1.0000 S1000
    G1 F1000 X7.0547 Y20.2628 Z-1.0000 S1000
    G1 F1000 X7.0001 Y20.3614 Z-1.0000 S1000
    G1 F1000 X6.9386 Y20.4558 Z-1.0000 S1000
    G1 F1000 X6.8706 Y20.5456 Z-1.0000 S1000
    G1 F1000 X6.7964 Y20.6304 Z-1.0000 S1000
    G1 F1000 X6.7163 Y20.7097 Z-1.0000 S1000
    G1 F1000 X6.6309 Y20.7831 Z-1.0000 S1000
    G1 F1000 X6.5404 Y20.8503 Z-1.0000 S1000
    G1 F1000 X6.4454 Y20.9109 Z-1.0000 S1000
    G1 F1000 X6.3464 Y20.9646 Z-1.0000 S1000
    G1 F1000 X6.2438 Y21.0112 Z-1.0000 S1000
    G1 F1000 X6.1381 Y21.0503 Z-1.0000 S1000
    G1 F1000 X6.0299 Y21.0819 Z-1.0000 S1000
    G1 F1000 X5.9198 Y21.1057 Z-1.0000 S1000
    G1 F1000 X5.8083 Y21.1216 Z-1.0000 S1000
    G1 F1000 X5.6397 Y21.1306 Z-1.0000 S1000
    G1 F1000 X0.0000 Y21.1306 Z-1.0000 S1000
    G1 F1000 X-0.1126 Y21.1266 Z-1.0000 S1000
    G1 F1000 X-0.2246 Y21.1146 Z-1.0000 S1000
    G1 F1000 X-0.3356 Y21.0947 Z-1.0000 S1000
    G1 F1000 X-0.4448 Y21.0670 Z-1.0000 S1000
    G1 F1000 X-0.5517 Y21.0316 Z-1.0000 S1000
    G1 F1000 X-0.6559 Y20.9887 Z-1.0000 S1000
    G1 F1000 X-0.7568 Y20.9386 Z-1.0000 S1000
    G1 F1000 X-0.8539 Y20.8814 Z-1.0000 S1000
    G1 F1000 X-0.9467 Y20.8174 Z-1.0000 S1000
    G1 F1000 X-1.0347 Y20.7471 Z-1.0000 S1000
    G1 F1000 X-1.1175 Y20.6707 Z-1.0000 S1000
    G1 F1000 X-1.1947 Y20.5885 Z-1.0000 S1000
    G1 F1000 X-1.2658 Y20.5012 Z-1.0000 S1000
    G1 F1000 X-1.3306 Y20.4090 Z-1.0000 S1000
    G1 F1000 X-1.3886 Y20.3124 Z-1.0000 S1000
    G1 F1000 X-1.4397 Y20.2120 Z-1.0000 S1000
    G1 F1000 X-1.4835 Y20.1082 Z-1.0000 S1000
    G1 F1000 X-1.5199 Y20.0015 Z-1.0000 S1000
    G1 F1000 X-1.5486 Y19.8925 Z-1.0000 S1000
    G1 F1000 X-1.5694 Y19.7818 Z-1.0000 S1000
    G1 F1000 X-1.5824 Y19.6699 Z-1.0000 S1000
    G1 F1000 X-1.5874 Y19.5573 Z-1.0000 S1000
    G1 F1000 X-1.5844 Y19.4447 Z-1.0000 S1000
    G1 F1000 X-1.5735 Y19.3326 Z-1.0000 S1000
    G1 F1000 X-1.5496 Y19.1983 Z-1.0000 S1000
    G0 Z7
    G0 X49.6756 Y19.5431
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X49.6756 Y0.3277 Z-1.0000 S1000
    G1 F1000 X49.6796 Y0.2151 Z-1.0000 S1000
    G1 F1000 X49.6916 Y0.1031 Z-1.0000 S1000
    G1 F1000 X49.7115 Y-0.0079 Z-1.0000 S1000
    G1 F1000 X49.7392 Y-0.1171 Z-1.0000 S1000
    G1 F1000 X49.7746 Y-0.2240 Z-1.0000 S1000
    G1 F1000 X49.8175 Y-0.3282 Z-1.0000 S1000
    G1 F1000 X49.8676 Y-0.4291 Z-1.0000 S1000
    G1 F1000 X49.9248 Y-0.5262 Z-1.0000 S1000
    G1 F1000 X49.9888 Y-0.6190 Z-1.0000 S1000
    G1 F1000 X50.0591 Y-0.7070 Z-1.0000 S1000
    G1 F1000 X50.1355 Y-0.7898 Z-1.0000 S1000
    G1 F1000 X50.2177 Y-0.8670 Z-1.0000 S1000
    G1 F1000 X50.3050 Y-0.9381 Z-1.0000 S1000
    G1 F1000 X50.3972 Y-1.0029 Z-1.0000 S1000
    G1 F1000 X50.4938 Y-1.0609 Z-1.0000 S1000
    G1 F1000 X50.5942 Y-1.1120 Z-1.0000 S1000
    G1 F1000 X50.6980 Y-1.1558 Z-1.0000 S1000
    G1 F1000 X50.8047 Y-1.1922 Z-1.0000 S1000
    G1 F1000 X50.9137 Y-1.2209 Z-1.0000 S1000
    G1 F1000 X51.0244 Y-1.2417 Z-1.0000 S1000
    G1 F1000 X51.1363 Y-1.2547 Z-1.0000 S1000
    G1 F1000 X51.2631 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X57.2269 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X57.3395 Y-1.2558 Z-1.0000 S1000
    G1 F1000 X57.4515 Y-1.2438 Z-1.0000 S1000
    G1 F1000 X57.5625 Y-1.2239 Z-1.0000 S1000
    G1 F1000 X57.6717 Y-1.1962 Z-1.0000 S1000
    G1 F1000 X57.7786 Y-1.1608 Z-1.0000 S1000
    G1 F1000 X57.8828 Y-1.1179 Z-1.0000 S1000
    G1 F1000 X57.9837 Y-1.0678 Z-1.0000 S1000
    G1 F1000 X58.0808 Y-1.0106 Z-1.0000 S1000
    G1 F1000 X58.1736 Y-0.9466 Z-1.0000 S1000
    G1 F1000 X58.2616 Y-0.8763 Z-1.0000 S1000
    G1 F1000 X58.3444 Y-0.7999 Z-1.0000 S1000
    G1 F1000 X58.4216 Y-0.7177 Z-1.0000 S1000
    G1 F1000 X58.4927 Y-0.6304 Z-1.0000 S1000
    G1 F1000 X58.5575 Y-0.5382 Z-1.0000 S1000
    G1 F1000 X58.6155 Y-0.4416 Z-1.0000 S1000
    G1 F1000 X58.6666 Y-0.3412 Z-1.0000 S1000
    G1 F1000 X58.7104 Y-0.2374 Z-1.0000 S1000
    G1 F1000 X58.7468 Y-0.1307 Z-1.0000 S1000
    G1 F1000 X58.7755 Y-0.0217 Z-1.0000 S1000
    G1 F1000 X58.7963 Y0.0890 Z-1.0000 S1000
    G1 F1000 X58.8093 Y0.2009 Z-1.0000 S1000
    G1 F1000 X58.8144 Y0.3277 Z-1.0000 S1000
    G1 F1000 X58.8144 Y5.5568 Z-1.0000 S1000
    G1 F1000 X58.9029 Y5.4108 Z-1.0000 S1000
    G1 F1000 X62.0582 Y-0.4271 Z-1.0000 S1000
    G1 F1000 X62.1153 Y-0.5243 Z-1.0000 S1000
    G1 F1000 X62.1791 Y-0.6172 Z-1.0000 S1000
    G1 F1000 X62.2493 Y-0.7053 Z-1.0000 S1000
    G1 F1000 X62.3256 Y-0.7882 Z-1.0000 S1000
    G1 F1000 X62.4076 Y-0.8655 Z-1.0000 S1000
    G1 F1000 X62.4949 Y-0.9367 Z-1.0000 S1000
    G1 F1000 X62.5870 Y-1.0016 Z-1.0000 S1000
    G1 F1000 X62.6835 Y-1.0598 Z-1.0000 S1000
    G1 F1000 X62.7839 Y-1.1110 Z-1.0000 S1000
    G1 F1000 X62.8876 Y-1.1550 Z-1.0000 S1000
    G1 F1000 X62.9942 Y-1.1915 Z-1.0000 S1000
    G1 F1000 X63.1031 Y-1.2204 Z-1.0000 S1000
    G1 F1000 X63.2138 Y-1.2414 Z-1.0000 S1000
    G1 F1000 X63.3257 Y-1.2545 Z-1.0000 S1000
    G1 F1000 X63.4548 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X70.1640 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X70.2766 Y-1.2558 Z-1.0000 S1000
    G1 F1000 X70.3886 Y-1.2438 Z-1.0000 S1000
    G1 F1000 X70.4996 Y-1.2239 Z-1.0000 S1000
    G1 F1000 X70.6088 Y-1.1962 Z-1.0000 S1000
    G1 F1000 X70.7157 Y-1.1608 Z-1.0000 S1000
    G1 F1000 X70.8199 Y-1.1179 Z-1.0000 S1000
    G1 F1000 X70.9208 Y-1.0678 Z-1.0000 S1000
    G1 F1000 X71.0179 Y-1.0106 Z-1.0000 S1000
    G1 F1000 X71.1107 Y-0.9466 Z-1.0000 S1000
    G1 F1000 X71.1143 Y-0.9437 Z-1.0000 S1000
    G1 F1000 X71.1986 Y-1.0029 Z-1.0000 S1000
    G1 F1000 X71.2952 Y-1.0609 Z-1.0000 S1000
    G1 F1000 X71.3956 Y-1.1120 Z-1.0000 S1000
    G1 F1000 X71.4994 Y-1.1558 Z-1.0000 S1000
    G1 F1000 X71.6061 Y-1.1922 Z-1.0000 S1000
    G1 F1000 X71.7151 Y-1.2209 Z-1.0000 S1000
    G1 F1000 X71.8258 Y-1.2417 Z-1.0000 S1000
    G1 F1000 X71.9377 Y-1.2547 Z-1.0000 S1000
    G1 F1000 X72.0645 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X87.2691 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X87.3817 Y-1.2558 Z-1.0000 S1000
    G1 F1000 X87.4937 Y-1.2438 Z-1.0000 S1000
    G1 F1000 X87.6047 Y-1.2239 Z-1.0000 S1000
    G1 F1000 X87.7139 Y-1.1962 Z-1.0000 S1000
    G1 F1000 X87.8208 Y-1.1608 Z-1.0000 S1000
    G1 F1000 X87.9250 Y-1.1179 Z-1.0000 S1000
    G1 F1000 X88.0259 Y-1.0678 Z-1.0000 S1000
    G1 F1000 X88.1230 Y-1.0106 Z-1.0000 S1000
    G1 F1000 X88.2158 Y-0.9466 Z-1.0000 S1000
    G1 F1000 X88.3038 Y-0.8763 Z-1.0000 S1000
    G1 F1000 X88.3866 Y-0.7999 Z-1.0000 S1000
    G1 F1000 X88.4638 Y-0.7177 Z-1.0000 S1000
    G1 F1000 X88.5349 Y-0.6304 Z-1.0000 S1000
    G1 F1000 X88.5997 Y-0.5382 Z-1.0000 S1000
    G1 F1000 X88.6577 Y-0.4416 Z-1.0000 S1000
    G1 F1000 X88.6587 Y-0.4397 Z-1.0000 S1000
    G1 F1000 X88.7096 Y-0.5262 Z-1.0000 S1000
    G1 F1000 X88.7736 Y-0.6190 Z-1.0000 S1000
    G1 F1000 X88.8439 Y-0.7070 Z-1.0000 S1000
    G1 F1000 X88.9203 Y-0.7898 Z-1.0000 S1000
    G1 F1000 X89.0025 Y-0.8670 Z-1.0000 S1000
    G1 F1000 X89.0898 Y-0.9381 Z-1.0000 S1000
    G1 F1000 X89.1820 Y-1.0029 Z-1.0000 S1000
    G1 F1000 X89.2786 Y-1.0609 Z-1.0000 S1000
    G1 F1000 X89.3790 Y-1.1120 Z-1.0000 S1000
    G1 F1000 X89.4828 Y-1.1558 Z-1.0000 S1000
    G1 F1000 X89.5895 Y-1.1922 Z-1.0000 S1000
    G1 F1000 X89.6985 Y-1.2209 Z-1.0000 S1000
    G1 F1000 X89.8092 Y-1.2417 Z-1.0000 S1000
    G1 F1000 X89.9211 Y-1.2547 Z-1.0000 S1000
    G1 F1000 X90.0479 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X98.8692 Y-1.2598 Z-1.0000 S1000
    G1 F1000 X98.9929 Y-1.2550 Z-1.0000 S1000
    G1 F1000 X100.6706 Y-1.1239 Z-1.0000 S1000
    G1 F1000 X100.7825 Y-1.1111 Z-1.0000 S1000
    G1 F1000 X100.8750 Y-1.0944 Z-1.0000 S1000
    G1 F1000 X102.7363 Y-0.7012 Z-1.0000 S1000
    G1 F1000 X102.8457 Y-0.6740 Z-1.0000 S1000
    G1 F1000 X102.9528 Y-0.6392 Z-1.0000 S1000
    G1 F1000 X103.0148 Y-0.6150 Z-1.0000 S1000
    G1 F1000 X104.3976 Y-0.0432 Z-1.0000 S1000
    G1 F1000 X104.5002 Y0.0035 Z-1.0000 S1000
    G1 F1000 X104.5991 Y0.0574 Z-1.0000 S1000
    G1 F1000 X104.7352 Y0.1476 Z-1.0000 S1000
    G1 F1000 X106.0263 Y1.1028 Z-1.0000 S1000
    G1 F1000 X106.1144 Y1.1730 Z-1.0000 S1000
    G1 F1000 X106.1974 Y1.2493 Z-1.0000 S1000
    G1 F1000 X106.2836 Y1.3415 Z-1.0000 S1000
    G1 F1000 X107.3928 Y2.6260 Z-1.0000 S1000
    G1 F1000 X107.4634 Y2.7138 Z-1.0000 S1000
    G1 F1000 X107.5276 Y2.8064 Z-1.0000 S1000
    G1 F1000 X107.5901 Y2.9127 Z-1.0000 S1000
    G1 F1000 X108.4273 Y4.4725 Z-1.0000 S1000
    G1 F1000 X108.4770 Y4.5736 Z-1.0000 S1000
    G1 F1000 X108.5194 Y4.6780 Z-1.0000 S1000
    G1 F1000 X108.5659 Y4.8275 Z-1.0000 S1000
    G1 F1000 X109.0919 Y6.8706 Z-1.0000 S1000
    G1 F1000 X109.1161 Y6.9806 Z-1.0000 S1000
    G1 F1000 X109.1324 Y7.0921 Z-1.0000 S1000
    G1 F1000 X109.1387 Y7.1648 Z-1.0000 S1000
    G1 F1000 X109.3140 Y9.8994 Z-1.0000 S1000
    G1 F1000 X109.3173 Y10.0121 Z-1.0000 S1000
    G1 F1000 X109.3143 Y10.0987 Z-1.0000 S1000
    G1 F1000 X109.1963 Y12.0123 Z-1.0000 S1000
    G1 F1000 X109.1854 Y12.1245 Z-1.0000 S1000
    G1 F1000 X109.1698 Y12.2194 Z-1.0000 S1000
    G1 F1000 X108.8159 Y14.0283 Z-1.0000 S1000
    G1 F1000 X108.7903 Y14.1380 Z-1.0000 S1000
    G1 F1000 X108.7449 Y14.2793 Z-1.0000 S1000
    G1 F1000 X108.1289 Y15.9275 Z-1.0000 S1000
    G1 F1000 X108.0858 Y16.0315 Z-1.0000 S1000
    G1 F1000 X108.0353 Y16.1323 Z-1.0000 S1000
    G1 F1000 X107.9841 Y16.2194 Z-1.0000 S1000
    G1 F1000 X107.0797 Y17.6514 Z-1.0000 S1000
    G1 F1000 X107.0162 Y17.7445 Z-1.0000 S1000
    G1 F1000 X106.9463 Y17.8328 Z-1.0000 S1000
    G1 F1000 X106.8514 Y17.9348 Z-1.0000 S1000
    G1 F1000 X105.6635 Y19.1046 Z-1.0000 S1000
    G1 F1000 X105.5804 Y19.1808 Z-1.0000 S1000
    G1 F1000 X105.4922 Y19.2509 Z-1.0000 S1000
    G1 F1000 X105.3539 Y19.3421 Z-1.0000 S1000
    G1 F1000 X103.8875 Y20.2039 Z-1.0000 S1000
    G1 F1000 X103.7884 Y20.2575 Z-1.0000 S1000
    G1 F1000 X103.6858 Y20.3040 Z-1.0000 S1000
    G1 F1000 X103.5801 Y20.3430 Z-1.0000 S1000
    G1 F1000 X103.5197 Y20.3616 Z-1.0000 S1000
    G1 F1000 X101.6634 Y20.8925 Z-1.0000 S1000
    G1 F1000 X101.5541 Y20.9196 Z-1.0000 S1000
    G1 F1000 X101.4430 Y20.9389 Z-1.0000 S1000
    G1 F1000 X101.3457 Y20.9493 Z-1.0000 S1000
    G1 F1000 X98.9880 Y21.1262 Z-1.0000 S1000
    G1 F1000 X98.8692 Y21.1306 Z-1.0000 S1000
    G1 F1000 X90.0479 Y21.1306 Z-1.0000 S1000
    G1 F1000 X89.9353 Y21.1266 Z-1.0000 S1000
    G1 F1000 X89.8233 Y21.1146 Z-1.0000 S1000
    G1 F1000 X89.7123 Y21.0947 Z-1.0000 S1000
    G1 F1000 X89.6031 Y21.0670 Z-1.0000 S1000
    G1 F1000 X89.4962 Y21.0316 Z-1.0000 S1000
    G1 F1000 X89.3920 Y20.9887 Z-1.0000 S1000
    G1 F1000 X89.2911 Y20.9386 Z-1.0000 S1000
    G1 F1000 X89.1940 Y20.8814 Z-1.0000 S1000
    G1 F1000 X89.1012 Y20.8174 Z-1.0000 S1000
    G1 F1000 X89.0132 Y20.7471 Z-1.0000 S1000
    G1 F1000 X88.9304 Y20.6707 Z-1.0000 S1000
    G1 F1000 X88.8532 Y20.5885 Z-1.0000 S1000
    G1 F1000 X88.7821 Y20.5012 Z-1.0000 S1000
    G1 F1000 X88.7173 Y20.4090 Z-1.0000 S1000
    G1 F1000 X88.6593 Y20.3124 Z-1.0000 S1000
    G1 F1000 X88.6082 Y20.2120 Z-1.0000 S1000
    G1 F1000 X88.5644 Y20.1082 Z-1.0000 S1000
    G1 F1000 X88.5280 Y20.0015 Z-1.0000 S1000
    G1 F1000 X88.4993 Y19.8925 Z-1.0000 S1000
    G1 F1000 X88.4785 Y19.7818 Z-1.0000 S1000
    G1 F1000 X88.4655 Y19.6699 Z-1.0000 S1000
    G1 F1000 X88.4604 Y19.5431 Z-1.0000 S1000
    G1 F1000 X88.4604 Y6.1080 Z-1.0000 S1000
    G1 F1000 X88.3967 Y6.1770 Z-1.0000 S1000
    G1 F1000 X88.3145 Y6.2542 Z-1.0000 S1000
    G1 F1000 X88.2272 Y6.3253 Z-1.0000 S1000
    G1 F1000 X88.1350 Y6.3901 Z-1.0000 S1000
    G1 F1000 X88.0384 Y6.4481 Z-1.0000 S1000
    G1 F1000 X87.9380 Y6.4992 Z-1.0000 S1000
    G1 F1000 X87.8342 Y6.5430 Z-1.0000 S1000
    G1 F1000 X87.7275 Y6.5794 Z-1.0000 S1000
    G1 F1000 X87.6185 Y6.6081 Z-1.0000 S1000
    G1 F1000 X87.5078 Y6.6289 Z-1.0000 S1000
    G1 F1000 X87.3959 Y6.6419 Z-1.0000 S1000
    G1 F1000 X87.2691 Y6.6470 Z-1.0000 S1000
    G1 F1000 X79.5897 Y6.6470 Z-1.0000 S1000
    G1 F1000 X79.5897 Y19.5431 Z-1.0000 S1000
    G1 F1000 X79.5857 Y19.6557 Z-1.0000 S1000
    G1 F1000 X79.5737 Y19.7677 Z-1.0000 S1000
    G1 F1000 X79.5538 Y19.8787 Z-1.0000 S1000
    G1 F1000 X79.5261 Y19.9879 Z-1.0000 S1000
    G1 F1000 X79.4907 Y20.0948 Z-1.0000 S1000
    G1 F1000 X79.4478 Y20.1990 Z-1.0000 S1000
    G1 F1000 X79.3977 Y20.2999 Z-1.0000 S1000
    G1 F1000 X79.3405 Y20.3970 Z-1.0000 S1000
    G1 F1000 X79.2765 Y20.4898 Z-1.0000 S1000
    G1 F1000 X79.2062 Y20.5778 Z-1.0000 S1000
    G1 F1000 X79.1298 Y20.6606 Z-1.0000 S1000
    G1 F1000 X79.0476 Y20.7378 Z-1.0000 S1000
    G1 F1000 X78.9603 Y20.8089 Z-1.0000 S1000
    G1 F1000 X78.8681 Y20.8737 Z-1.0000 S1000
    G1 F1000 X78.7715 Y20.9317 Z-1.0000 S1000
    G1 F1000 X78.6711 Y20.9828 Z-1.0000 S1000
    G1 F1000 X78.5673 Y21.0266 Z-1.0000 S1000
    G1 F1000 X78.4606 Y21.0630 Z-1.0000 S1000
    G1 F1000 X78.3516 Y21.0917 Z-1.0000 S1000
    G1 F1000 X78.2409 Y21.1125 Z-1.0000 S1000
    G1 F1000 X78.1290 Y21.1255 Z-1.0000 S1000
    G1 F1000 X78.0022 Y21.1306 Z-1.0000 S1000
    G1 F1000 X72.0645 Y21.1306 Z-1.0000 S1000
    G1 F1000 X71.9519 Y21.1266 Z-1.0000 S1000
    G1 F1000 X71.8399 Y21.1146 Z-1.0000 S1000
    G1 F1000 X71.7289 Y21.0947 Z-1.0000 S1000
    G1 F1000 X71.6197 Y21.0670 Z-1.0000 S1000
    G1 F1000 X71.5128 Y21.0316 Z-1.0000 S1000
    G1 F1000 X71.4086 Y20.9887 Z-1.0000 S1000
    G1 F1000 X71.3077 Y20.9386 Z-1.0000 S1000
    G1 F1000 X71.2106 Y20.8814 Z-1.0000 S1000
    G1 F1000 X71.1178 Y20.8174 Z-1.0000 S1000
    G1 F1000 X71.0298 Y20.7471 Z-1.0000 S1000
    G1 F1000 X70.9470 Y20.6707 Z-1.0000 S1000
    G1 F1000 X70.8698 Y20.5885 Z-1.0000 S1000
    G1 F1000 X70.7987 Y20.5012 Z-1.0000 S1000
    G1 F1000 X70.7339 Y20.4090 Z-1.0000 S1000
    G1 F1000 X70.6759 Y20.3124 Z-1.0000 S1000
    G1 F1000 X70.6248 Y20.2120 Z-1.0000 S1000
    G1 F1000 X70.5810 Y20.1082 Z-1.0000 S1000
    G1 F1000 X70.5446 Y20.0015 Z-1.0000 S1000
    G1 F1000 X70.5159 Y19.8925 Z-1.0000 S1000
    G1 F1000 X70.4951 Y19.7818 Z-1.0000 S1000
    G1 F1000 X70.4821 Y19.6699 Z-1.0000 S1000
    G1 F1000 X70.4770 Y19.5431 Z-1.0000 S1000
    G1 F1000 X70.4770 Y3.1813 Z-1.0000 S1000
    G1 F1000 X68.6990 Y6.6241 Z-1.0000 S1000
    G1 F1000 X68.6438 Y6.7224 Z-1.0000 S1000
    G1 F1000 X68.5911 Y6.8031 Z-1.0000 S1000
    G1 F1000 X67.7594 Y7.9970 Z-1.0000 S1000
    G1 F1000 X67.6917 Y8.0871 Z-1.0000 S1000
    G1 F1000 X67.6134 Y8.1770 Z-1.0000 S1000
    G1 F1000 X67.2880 Y8.5231 Z-1.0000 S1000
    G1 F1000 X68.0884 Y9.1471 Z-1.0000 S1000
    G1 F1000 X68.1747 Y9.2195 Z-1.0000 S1000
    G1 F1000 X68.2557 Y9.2979 Z-1.0000 S1000
    G1 F1000 X68.3310 Y9.3817 Z-1.0000 S1000
    G1 F1000 X68.3694 Y9.4296 Z-1.0000 S1000
    G1 F1000 X69.1793 Y10.4798 Z-1.0000 S1000
    G1 F1000 X69.2449 Y10.5715 Z-1.0000 S1000
    G1 F1000 X69.3038 Y10.6675 Z-1.0000 S1000
    G1 F1000 X69.3558 Y10.7675 Z-1.0000 S1000
    G1 F1000 X69.3947 Y10.8561 Z-1.0000 S1000
    G1 F1000 X69.9062 Y12.1259 Z-1.0000 S1000
    G1 F1000 X69.9446 Y12.2319 Z-1.0000 S1000
    G1 F1000 X69.9753 Y12.3403 Z-1.0000 S1000
    G1 F1000 X69.9983 Y12.4506 Z-1.0000 S1000
    G1 F1000 X70.0109 Y12.5385 Z-1.0000 S1000
    G1 F1000 X70.1814 Y14.0278 Z-1.0000 S1000
    G1 F1000 X70.1902 Y14.1402 Z-1.0000 S1000
    G1 F1000 X70.1911 Y14.2528 Z-1.0000 S1000
    G1 F1000 X70.1782 Y14.4152 Z-1.0000 S1000
    G1 F1000 X69.9554 Y16.1110 Z-1.0000 S1000
    G1 F1000 X69.9367 Y16.2221 Z-1.0000 S1000
    G1 F1000 X69.9103 Y16.3316 Z-1.0000 S1000
    G1 F1000 X69.8761 Y16.4390 Z-1.0000 S1000
    G1 F1000 X69.8172 Y16.5815 Z-1.0000 S1000
    G1 F1000 X69.1487 Y17.9987 Z-1.0000 S1000
    G1 F1000 X69.0970 Y18.0988 Z-1.0000 S1000
    G1 F1000 X69.0384 Y18.1950 Z-1.0000 S1000
    G1 F1000 X68.9731 Y18.2868 Z-1.0000 S1000
    G1 F1000 X68.9014 Y18.3738 Z-1.0000 S1000
    G1 F1000 X68.8588 Y18.4201 Z-1.0000 S1000
    G1 F1000 X67.8266 Y19.4966 Z-1.0000 S1000
    G1 F1000 X67.7457 Y19.5751 Z-1.0000 S1000
    G1 F1000 X67.6596 Y19.6477 Z-1.0000 S1000
    G1 F1000 X67.5684 Y19.7140 Z-1.0000 S1000
    G1 F1000 X67.4728 Y19.7736 Z-1.0000 S1000
    G1 F1000 X67.4047 Y19.8107 Z-1.0000 S1000
    G1 F1000 X66.0906 Y20.4841 Z-1.0000 S1000
    G1 F1000 X65.9885 Y20.5319 Z-1.0000 S1000
    G1 F1000 X65.8834 Y20.5723 Z-1.0000 S1000
    G1 F1000 X65.7756 Y20.6052 Z-1.0000 S1000
    G1 F1000 X65.6763 Y20.6283 Z-1.0000 S1000
    G1 F1000 X63.8970 Y20.9822 Z-1.0000 S1000
    G1 F1000 X63.7858 Y21.0002 Z-1.0000 S1000
    G1 F1000 X63.6643 Y21.0108 Z-1.0000 S1000
    G1 F1000 X61.2362 Y21.1287 Z-1.0000 S1000
    G1 F1000 X61.1592 Y21.1306 Z-1.0000 S1000
    G1 F1000 X51.2631 Y21.1306 Z-1.0000 S1000
    G1 F1000 X51.1505 Y21.1266 Z-1.0000 S1000
    G1 F1000 X51.0385 Y21.1146 Z-1.0000 S1000
    G1 F1000 X50.9275 Y21.0947 Z-1.0000 S1000
    G1 F1000 X50.8183 Y21.0670 Z-1.0000 S1000
    G1 F1000 X50.7114 Y21.0316 Z-1.0000 S1000
    G1 F1000 X50.6072 Y20.9887 Z-1.0000 S1000
    G1 F1000 X50.5063 Y20.9386 Z-1.0000 S1000
    G1 F1000 X50.4092 Y20.8814 Z-1.0000 S1000
    G1 F1000 X50.3164 Y20.8174 Z-1.0000 S1000
    G1 F1000 X50.2284 Y20.7471 Z-1.0000 S1000
    G1 F1000 X50.1456 Y20.6707 Z-1.0000 S1000
    G1 F1000 X50.0684 Y20.5885 Z-1.0000 S1000
    G1 F1000 X49.9973 Y20.5012 Z-1.0000 S1000
    G1 F1000 X49.9325 Y20.4090 Z-1.0000 S1000
    G1 F1000 X49.8745 Y20.3124 Z-1.0000 S1000
    G1 F1000 X49.8234 Y20.2120 Z-1.0000 S1000
    G1 F1000 X49.7796 Y20.1082 Z-1.0000 S1000
    G1 F1000 X49.7432 Y20.0015 Z-1.0000 S1000
    G1 F1000 X49.7145 Y19.8925 Z-1.0000 S1000
    G1 F1000 X49.6937 Y19.7818 Z-1.0000 S1000
    G1 F1000 X49.6807 Y19.6699 Z-1.0000 S1000
    G1 F1000 X49.6756 Y19.5431 Z-1.0000 S1000
    G0 Z7
    G0 X60.8788 Y13.5581
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X59.5991 Y13.3448 Z-1.0000 S1000
    G1 F1000 X58.8144 Y13.3448 Z-1.0000 S1000
    G1 F1000 X58.8144 Y14.0759 Z-1.0000 S1000
    G1 F1000 X59.7635 Y14.0759 Z-1.0000 S1000
    G1 F1000 X60.7994 Y13.9814 Z-1.0000 S1000
    G1 F1000 X60.9993 Y13.8935 Z-1.0000 S1000
    G1 F1000 X61.0305 Y13.7195 Z-1.0000 S1000
    G1 F1000 X61.0207 Y13.6573 Z-1.0000 S1000
    G1 F1000 X60.9952 Y13.6099 Z-1.0000 S1000
    G1 F1000 X60.9835 Y13.5991 Z-1.0000 S1000
    G1 F1000 X60.8788 Y13.5581 Z-1.0000 S1000
    G0 Z7
    G0 X40.4592 Y10.1505
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X40.4009 Y8.8286 Z-1.0000 S1000
    G1 F1000 X40.2386 Y7.8039 Z-1.0000 S1000
    G1 F1000 X40.0093 Y7.1085 Z-1.0000 S1000
    G1 F1000 X39.7579 Y6.6995 Z-1.0000 S1000
    G1 F1000 X39.4723 Y6.4306 Z-1.0000 S1000
    G1 F1000 X39.1117 Y6.2261 Z-1.0000 S1000
    G1 F1000 X38.6454 Y6.0891 Z-1.0000 S1000
    G1 F1000 X38.0411 Y6.0370 Z-1.0000 S1000
    G1 F1000 X37.4610 Y6.0893 Z-1.0000 S1000
    G1 F1000 X37.0080 Y6.2270 Z-1.0000 S1000
    G1 F1000 X36.6395 Y6.4402 Z-1.0000 S1000
    G1 F1000 X36.3265 Y6.7355 Z-1.0000 S1000
    G1 F1000 X36.0558 Y7.1578 Z-1.0000 S1000
    G1 F1000 X35.8239 Y7.8049 Z-1.0000 S1000
    G1 F1000 X35.6618 Y8.7223 Z-1.0000 S1000
    G1 F1000 X35.6031 Y9.8963 Z-1.0000 S1000
    G1 F1000 X35.6623 Y11.0820 Z-1.0000 S1000
    G1 F1000 X35.8255 Y12.0067 Z-1.0000 S1000
    G1 F1000 X36.0588 Y12.6573 Z-1.0000 S1000
    G1 F1000 X36.3324 Y13.0826 Z-1.0000 S1000
    G1 F1000 X36.6492 Y13.3822 Z-1.0000 S1000
    G1 F1000 X37.0132 Y13.5959 Z-1.0000 S1000
    G1 F1000 X37.4444 Y13.7302 Z-1.0000 S1000
    G1 F1000 X37.9895 Y13.7810 Z-1.0000 S1000
    G1 F1000 X38.5754 Y13.7294 Z-1.0000 S1000
    G1 F1000 X39.0412 Y13.5912 Z-1.0000 S1000
    G1 F1000 X39.4184 Y13.3784 Z-1.0000 S1000
    G1 F1000 X39.7398 Y13.0831 Z-1.0000 S1000
    G1 F1000 X40.0128 Y12.6740 Z-1.0000 S1000
    G1 F1000 X40.2412 Y12.0731 Z-1.0000 S1000
    G1 F1000 X40.4007 Y11.2320 Z-1.0000 S1000
    G1 F1000 X40.4592 Y10.1505 Z-1.0000 S1000
    G0 Z7
    G0 X97.5731 Y6.2919
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X97.5731 Y13.5935 Z-1.0000 S1000
    G1 F1000 X98.3045 Y13.5454 Z-1.0000 S1000
    G1 F1000 X98.9205 Y13.4020 Z-1.0000 S1000
    G1 F1000 X99.3208 Y13.2124 Z-1.0000 S1000
    G1 F1000 X99.5596 Y13.0094 Z-1.0000 S1000
    G1 F1000 X99.7626 Y12.6907 Z-1.0000 S1000
    G1 F1000 X99.9703 Y12.0737 Z-1.0000 S1000
    G1 F1000 X100.1217 Y11.1288 Z-1.0000 S1000
    G1 F1000 X100.1764 Y9.8918 Z-1.0000 S1000
    G1 F1000 X100.0778 Y8.1332 Z-1.0000 S1000
    G1 F1000 X99.8376 Y7.1638 Z-1.0000 S1000
    G1 F1000 X99.5759 Y6.7326 Z-1.0000 S1000
    G1 F1000 X99.3368 Y6.5393 Z-1.0000 S1000
    G1 F1000 X98.7549 Y6.3685 Z-1.0000 S1000
    G1 F1000 X97.5731 Y6.2919 Z-1.0000 S1000
    G0 Z7
    G0 X-1.5496 Y19.1983
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X2.7255 Y-0.0171 Z-2.0000 S1000
    G1 F1000 X2.7538 Y-0.1261 Z-2.0000 S1000
    G1 F1000 X2.7899 Y-0.2329 Z-2.0000 S1000
    G1 F1000 X2.8334 Y-0.3368 Z-2.0000 S1000
    G1 F1000 X2.8841 Y-0.4374 Z-2.0000 S1000
    G1 F1000 X2.9419 Y-0.5341 Z-2.0000 S1000
    G1 F1000 X3.0064 Y-0.6265 Z-2.0000 S1000
    G1 F1000 X3.0773 Y-0.7141 Z-2.0000 S1000
    G1 F1000 X3.1542 Y-0.7965 Z-2.0000 S1000
    G1 F1000 X3.2368 Y-0.8731 Z-2.0000 S1000
    G1 F1000 X3.3246 Y-0.9438 Z-2.0000 S1000
    G1 F1000 X3.4171 Y-1.0080 Z-2.0000 S1000
    G1 F1000 X3.5141 Y-1.0655 Z-2.0000 S1000
    G1 F1000 X3.6148 Y-1.1160 Z-2.0000 S1000
    G1 F1000 X3.7189 Y-1.1592 Z-2.0000 S1000
    G1 F1000 X3.8257 Y-1.1949 Z-2.0000 S1000
    G1 F1000 X3.9349 Y-1.2229 Z-2.0000 S1000
    G1 F1000 X4.0457 Y-1.2431 Z-2.0000 S1000
    G1 F1000 X4.1577 Y-1.2555 Z-2.0000 S1000
    G1 F1000 X4.2751 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X10.0976 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X10.2102 Y-1.2558 Z-2.0000 S1000
    G1 F1000 X10.3222 Y-1.2438 Z-2.0000 S1000
    G1 F1000 X10.4332 Y-1.2239 Z-2.0000 S1000
    G1 F1000 X10.5424 Y-1.1962 Z-2.0000 S1000
    G1 F1000 X10.6493 Y-1.1608 Z-2.0000 S1000
    G1 F1000 X10.7535 Y-1.1179 Z-2.0000 S1000
    G1 F1000 X10.8544 Y-1.0678 Z-2.0000 S1000
    G1 F1000 X10.9515 Y-1.0106 Z-2.0000 S1000
    G1 F1000 X11.0443 Y-0.9466 Z-2.0000 S1000
    G1 F1000 X11.1323 Y-0.8763 Z-2.0000 S1000
    G1 F1000 X11.2151 Y-0.7999 Z-2.0000 S1000
    G1 F1000 X11.2923 Y-0.7177 Z-2.0000 S1000
    G1 F1000 X11.3634 Y-0.6304 Z-2.0000 S1000
    G1 F1000 X11.4282 Y-0.5382 Z-2.0000 S1000
    G1 F1000 X11.4862 Y-0.4416 Z-2.0000 S1000
    G1 F1000 X11.5373 Y-0.3412 Z-2.0000 S1000
    G1 F1000 X11.5811 Y-0.2374 Z-2.0000 S1000
    G1 F1000 X11.6273 Y-0.0968 Z-2.0000 S1000
    G1 F1000 X13.4577 Y6.4995 Z-2.0000 S1000
    G1 F1000 X15.2957 Y-0.0983 Z-2.0000 S1000
    G1 F1000 X15.3298 Y-0.2057 Z-2.0000 S1000
    G1 F1000 X15.3714 Y-0.3104 Z-2.0000 S1000
    G1 F1000 X15.4203 Y-0.4119 Z-2.0000 S1000
    G1 F1000 X15.4763 Y-0.5097 Z-2.0000 S1000
    G1 F1000 X15.5391 Y-0.6033 Z-2.0000 S1000
    G1 F1000 X15.6084 Y-0.6921 Z-2.0000 S1000
    G1 F1000 X15.6838 Y-0.7759 Z-2.0000 S1000
    G1 F1000 X15.7650 Y-0.8540 Z-2.0000 S1000
    G1 F1000 X15.8514 Y-0.9262 Z-2.0000 S1000
    G1 F1000 X15.9428 Y-0.9921 Z-2.0000 S1000
    G1 F1000 X16.0387 Y-1.0514 Z-2.0000 S1000
    G1 F1000 X16.1385 Y-1.1037 Z-2.0000 S1000
    G1 F1000 X16.2418 Y-1.1488 Z-2.0000 S1000
    G1 F1000 X16.3480 Y-1.1864 Z-2.0000 S1000
    G1 F1000 X16.4566 Y-1.2165 Z-2.0000 S1000
    G1 F1000 X16.5670 Y-1.2387 Z-2.0000 S1000
    G1 F1000 X16.6788 Y-1.2531 Z-2.0000 S1000
    G1 F1000 X16.8250 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X22.6476 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X22.7602 Y-1.2558 Z-2.0000 S1000
    G1 F1000 X22.8722 Y-1.2438 Z-2.0000 S1000
    G1 F1000 X22.9832 Y-1.2239 Z-2.0000 S1000
    G1 F1000 X23.0924 Y-1.1962 Z-2.0000 S1000
    G1 F1000 X23.1993 Y-1.1608 Z-2.0000 S1000
    G1 F1000 X23.3035 Y-1.1179 Z-2.0000 S1000
    G1 F1000 X23.4044 Y-1.0678 Z-2.0000 S1000
    G1 F1000 X23.5015 Y-1.0106 Z-2.0000 S1000
    G1 F1000 X23.5943 Y-0.9466 Z-2.0000 S1000
    G1 F1000 X23.6823 Y-0.8763 Z-2.0000 S1000
    G1 F1000 X23.7651 Y-0.7999 Z-2.0000 S1000
    G1 F1000 X23.8423 Y-0.7177 Z-2.0000 S1000
    G1 F1000 X23.9134 Y-0.6304 Z-2.0000 S1000
    G1 F1000 X23.9782 Y-0.5382 Z-2.0000 S1000
    G1 F1000 X24.0362 Y-0.4416 Z-2.0000 S1000
    G1 F1000 X24.0873 Y-0.3412 Z-2.0000 S1000
    G1 F1000 X24.1311 Y-0.2374 Z-2.0000 S1000
    G1 F1000 X24.1675 Y-0.1307 Z-2.0000 S1000
    G1 F1000 X24.1979 Y-0.0140 Z-2.0000 S1000
    G1 F1000 X26.5326 Y10.5773 Z-2.0000 S1000
    G1 F1000 X26.4929 Y10.0390 Z-2.0000 S1000
    G1 F1000 X26.4886 Y9.9264 Z-2.0000 S1000
    G1 F1000 X26.4907 Y9.8411 Z-2.0000 S1000
    G1 F1000 X26.5734 Y8.2273 Z-2.0000 S1000
    G1 F1000 X26.5831 Y8.1150 Z-2.0000 S1000
    G1 F1000 X26.5934 Y8.0447 Z-2.0000 S1000
    G1 F1000 X26.8416 Y6.5717 Z-2.0000 S1000
    G1 F1000 X26.8642 Y6.4613 Z-2.0000 S1000
    G1 F1000 X26.8909 Y6.3646 Z-2.0000 S1000
    G1 F1000 X27.3046 Y5.0326 Z-2.0000 S1000
    G1 F1000 X27.3419 Y4.9263 Z-2.0000 S1000
    G1 F1000 X27.3930 Y4.8093 Z-2.0000 S1000
    G1 F1000 X27.9722 Y3.6181 Z-2.0000 S1000
    G1 F1000 X28.0251 Y3.5186 Z-2.0000 S1000
    G1 F1000 X28.0880 Y3.4183 Z-2.0000 S1000
    G1 F1000 X28.8003 Y2.3730 Z-2.0000 S1000
    G1 F1000 X28.8670 Y2.2822 Z-2.0000 S1000
    G1 F1000 X28.9374 Y2.1993 Z-2.0000 S1000
    G1 F1000 X29.7505 Y1.3047 Z-2.0000 S1000
    G1 F1000 X29.8292 Y1.2240 Z-2.0000 S1000
    G1 F1000 X29.9231 Y1.1412 Z-2.0000 S1000
    G1 F1000 X30.8369 Y0.3974 Z-2.0000 S1000
    G1 F1000 X30.9268 Y0.3294 Z-2.0000 S1000
    G1 F1000 X31.0379 Y0.2581 Z-2.0000 S1000
    G1 F1000 X32.0525 Y-0.3350 Z-2.0000 S1000
    G1 F1000 X32.1518 Y-0.3884 Z-2.0000 S1000
    G1 F1000 X32.2652 Y-0.4389 Z-2.0000 S1000
    G1 F1000 X33.4002 Y-0.8919 Z-2.0000 S1000
    G1 F1000 X33.5063 Y-0.9299 Z-2.0000 S1000
    G1 F1000 X33.5982 Y-0.9562 Z-2.0000 S1000
    G1 F1000 X34.8733 Y-1.2798 Z-2.0000 S1000
    G1 F1000 X34.9834 Y-1.3036 Z-2.0000 S1000
    G1 F1000 X35.1260 Y-1.3226 Z-2.0000 S1000
    G1 F1000 X38.0965 Y-1.5815 Z-2.0000 S1000
    G1 F1000 X38.2090 Y-1.5873 Z-2.0000 S1000
    G1 F1000 X38.3119 Y-1.5856 Z-2.0000 S1000
    G1 F1000 X39.8451 Y-1.5106 Z-2.0000 S1000
    G1 F1000 X39.9573 Y-1.5011 Z-2.0000 S1000
    G1 F1000 X40.0190 Y-1.4925 Z-2.0000 S1000
    G1 F1000 X41.4202 Y-1.2677 Z-2.0000 S1000
    G1 F1000 X41.5307 Y-1.2459 Z-2.0000 S1000
    G1 F1000 X41.6182 Y-1.2227 Z-2.0000 S1000
    G1 F1000 X42.8876 Y-0.8479 Z-2.0000 S1000
    G1 F1000 X42.9945 Y-0.8122 Z-2.0000 S1000
    G1 F1000 X43.1030 Y-0.7669 Z-2.0000 S1000
    G1 F1000 X44.2405 Y-0.2422 Z-2.0000 S1000
    G1 F1000 X44.3411 Y-0.1914 Z-2.0000 S1000
    G1 F1000 X44.4445 Y-0.1293 Z-2.0000 S1000
    G1 F1000 X45.4529 Y0.5302 Z-2.0000 S1000
    G1 F1000 X45.5450 Y0.5952 Z-2.0000 S1000
    G1 F1000 X45.6348 Y0.6688 Z-2.0000 S1000
    G1 F1000 X46.5171 Y1.4479 Z-2.0000 S1000
    G1 F1000 X46.5988 Y1.5255 Z-2.0000 S1000
    G1 F1000 X46.6809 Y1.6157 Z-2.0000 S1000
    G1 F1000 X47.4371 Y2.5143 Z-2.0000 S1000
    G1 F1000 X47.5066 Y2.6031 Z-2.0000 S1000
    G1 F1000 X47.5726 Y2.7014 Z-2.0000 S1000
    G1 F1000 X48.2025 Y3.7197 Z-2.0000 S1000
    G1 F1000 X48.2583 Y3.8175 Z-2.0000 S1000
    G1 F1000 X48.3108 Y3.9278 Z-2.0000 S1000
    G1 F1000 X48.8069 Y5.0817 Z-2.0000 S1000
    G1 F1000 X48.8477 Y5.1867 Z-2.0000 S1000
    G1 F1000 X48.8806 Y5.2929 Z-2.0000 S1000
    G1 F1000 X49.2349 Y6.5983 Z-2.0000 S1000
    G1 F1000 X49.2605 Y6.7080 Z-2.0000 S1000
    G1 F1000 X49.2737 Y6.7849 Z-2.0000 S1000
    G1 F1000 X49.4863 Y8.2419 Z-2.0000 S1000
    G1 F1000 X49.5014 Y8.4013 Z-2.0000 S1000
    G1 F1000 X49.5722 Y10.0098 Z-2.0000 S1000
    G1 F1000 X49.5731 Y10.1225 Z-2.0000 S1000
    G1 F1000 X49.5694 Y10.1968 Z-2.0000 S1000
    G1 F1000 X49.4072 Y12.3878 Z-2.0000 S1000
    G1 F1000 X49.3949 Y12.4998 Z-2.0000 S1000
    G1 F1000 X49.3635 Y12.6582 Z-2.0000 S1000
    G1 F1000 X48.8769 Y14.5911 Z-2.0000 S1000
    G1 F1000 X48.8455 Y14.6993 Z-2.0000 S1000
    G1 F1000 X48.8065 Y14.8050 Z-2.0000 S1000
    G1 F1000 X48.7662 Y14.8953 Z-2.0000 S1000
    G1 F1000 X47.9552 Y16.5702 Z-2.0000 S1000
    G1 F1000 X47.9025 Y16.6699 Z-2.0000 S1000
    G1 F1000 X47.8429 Y16.7655 Z-2.0000 S1000
    G1 F1000 X47.7652 Y16.8711 Z-2.0000 S1000
    G1 F1000 X46.6298 Y18.2879 Z-2.0000 S1000
    G1 F1000 X46.5563 Y18.3733 Z-2.0000 S1000
    G1 F1000 X46.4768 Y18.4533 Z-2.0000 S1000
    G1 F1000 X46.3713 Y18.5438 Z-2.0000 S1000
    G1 F1000 X44.9360 Y19.6707 Z-2.0000 S1000
    G1 F1000 X44.8450 Y19.7371 Z-2.0000 S1000
    G1 F1000 X44.7495 Y19.7969 Z-2.0000 S1000
    G1 F1000 X44.6316 Y19.8585 Z-2.0000 S1000
    G1 F1000 X42.9211 Y20.6633 Z-2.0000 S1000
    G1 F1000 X42.8175 Y20.7077 Z-2.0000 S1000
    G1 F1000 X42.7110 Y20.7445 Z-2.0000 S1000
    G1 F1000 X42.6204 Y20.7694 Z-2.0000 S1000
    G1 F1000 X40.6346 Y21.2524 Z-2.0000 S1000
    G1 F1000 X40.5242 Y21.2752 Z-2.0000 S1000
    G1 F1000 X40.3721 Y21.2934 Z-2.0000 S1000
    G1 F1000 X38.1111 Y21.4543 Z-2.0000 S1000
    G1 F1000 X37.9985 Y21.4583 Z-2.0000 S1000
    G1 F1000 X37.8811 Y21.4540 Z-2.0000 S1000
    G1 F1000 X35.6700 Y21.2902 Z-2.0000 S1000
    G1 F1000 X35.5580 Y21.2779 Z-2.0000 S1000
    G1 F1000 X35.4000 Y21.2465 Z-2.0000 S1000
    G1 F1000 X33.4462 Y20.7550 Z-2.0000 S1000
    G1 F1000 X33.3380 Y20.7237 Z-2.0000 S1000
    G1 F1000 X33.2323 Y20.6847 Z-2.0000 S1000
    G1 F1000 X33.1432 Y20.6450 Z-2.0000 S1000
    G1 F1000 X31.4466 Y19.8257 Z-2.0000 S1000
    G1 F1000 X31.3469 Y19.7732 Z-2.0000 S1000
    G1 F1000 X31.2512 Y19.7137 Z-2.0000 S1000
    G1 F1000 X31.1476 Y19.6377 Z-2.0000 S1000
    G1 F1000 X29.7083 Y18.4908 Z-2.0000 S1000
    G1 F1000 X29.6227 Y18.4175 Z-2.0000 S1000
    G1 F1000 X29.5426 Y18.3383 Z-2.0000 S1000
    G1 F1000 X29.4555 Y18.2379 Z-2.0000 S1000
    G1 F1000 X28.3086 Y16.7970 Z-2.0000 S1000
    G1 F1000 X28.2416 Y16.7064 Z-2.0000 S1000
    G1 F1000 X28.1812 Y16.6113 Z-2.0000 S1000
    G1 F1000 X28.1204 Y16.4971 Z-2.0000 S1000
    G1 F1000 X27.5986 Y15.4134 Z-2.0000 S1000
    G1 F1000 X28.4336 Y19.2014 Z-2.0000 S1000
    G1 F1000 X28.4539 Y19.3122 Z-2.0000 S1000
    G1 F1000 X28.4663 Y19.4242 Z-2.0000 S1000
    G1 F1000 X28.4708 Y19.5368 Z-2.0000 S1000
    G1 F1000 X28.4672 Y19.6494 Z-2.0000 S1000
    G1 F1000 X28.4557 Y19.7615 Z-2.0000 S1000
    G1 F1000 X28.4363 Y19.8725 Z-2.0000 S1000
    G1 F1000 X28.4090 Y19.9818 Z-2.0000 S1000
    G1 F1000 X28.3740 Y20.0889 Z-2.0000 S1000
    G1 F1000 X28.3316 Y20.1933 Z-2.0000 S1000
    G1 F1000 X28.2818 Y20.2944 Z-2.0000 S1000
    G1 F1000 X28.2250 Y20.3917 Z-2.0000 S1000
    G1 F1000 X28.1614 Y20.4847 Z-2.0000 S1000
    G1 F1000 X28.0914 Y20.5730 Z-2.0000 S1000
    G1 F1000 X28.0153 Y20.6561 Z-2.0000 S1000
    G1 F1000 X27.9335 Y20.7336 Z-2.0000 S1000
    G1 F1000 X27.8464 Y20.8051 Z-2.0000 S1000
    G1 F1000 X27.7545 Y20.8702 Z-2.0000 S1000
    G1 F1000 X27.6581 Y20.9287 Z-2.0000 S1000
    G1 F1000 X27.5579 Y20.9801 Z-2.0000 S1000
    G1 F1000 X27.4543 Y21.0244 Z-2.0000 S1000
    G1 F1000 X27.3478 Y21.0611 Z-2.0000 S1000
    G1 F1000 X27.2389 Y21.0903 Z-2.0000 S1000
    G1 F1000 X27.1283 Y21.1116 Z-2.0000 S1000
    G1 F1000 X27.0164 Y21.1250 Z-2.0000 S1000
    G1 F1000 X26.8833 Y21.1306 Z-2.0000 S1000
    G1 F1000 X21.2729 Y21.1306 Z-2.0000 S1000
    G1 F1000 X21.1603 Y21.1266 Z-2.0000 S1000
    G1 F1000 X21.0483 Y21.1146 Z-2.0000 S1000
    G1 F1000 X20.9373 Y21.0947 Z-2.0000 S1000
    G1 F1000 X20.8281 Y21.0670 Z-2.0000 S1000
    G1 F1000 X20.7212 Y21.0316 Z-2.0000 S1000
    G1 F1000 X20.6170 Y20.9887 Z-2.0000 S1000
    G1 F1000 X20.5161 Y20.9386 Z-2.0000 S1000
    G1 F1000 X20.4190 Y20.8814 Z-2.0000 S1000
    G1 F1000 X20.3262 Y20.8174 Z-2.0000 S1000
    G1 F1000 X20.2382 Y20.7471 Z-2.0000 S1000
    G1 F1000 X20.1554 Y20.6707 Z-2.0000 S1000
    G1 F1000 X20.0782 Y20.5885 Z-2.0000 S1000
    G1 F1000 X20.0071 Y20.5012 Z-2.0000 S1000
    G1 F1000 X19.9423 Y20.4090 Z-2.0000 S1000
    G1 F1000 X19.8843 Y20.3124 Z-2.0000 S1000
    G1 F1000 X19.8332 Y20.2120 Z-2.0000 S1000
    G1 F1000 X19.7894 Y20.1082 Z-2.0000 S1000
    G1 F1000 X19.7530 Y20.0015 Z-2.0000 S1000
    G1 F1000 X19.7131 Y19.8382 Z-2.0000 S1000
    G1 F1000 X18.9480 Y15.7948 Z-2.0000 S1000
    G1 F1000 X17.7910 Y19.9673 Z-2.0000 S1000
    G1 F1000 X17.7570 Y20.0747 Z-2.0000 S1000
    G1 F1000 X17.7156 Y20.1795 Z-2.0000 S1000
    G1 F1000 X17.6667 Y20.2811 Z-2.0000 S1000
    G1 F1000 X17.6109 Y20.3789 Z-2.0000 S1000
    G1 F1000 X17.5482 Y20.4725 Z-2.0000 S1000
    G1 F1000 X17.4790 Y20.5615 Z-2.0000 S1000
    G1 F1000 X17.4037 Y20.6453 Z-2.0000 S1000
    G1 F1000 X17.3226 Y20.7236 Z-2.0000 S1000
    G1 F1000 X17.2362 Y20.7959 Z-2.0000 S1000
    G1 F1000 X17.1449 Y20.8619 Z-2.0000 S1000
    G1 F1000 X17.0491 Y20.9213 Z-2.0000 S1000
    G1 F1000 X16.9494 Y20.9737 Z-2.0000 S1000
    G1 F1000 X16.8462 Y21.0189 Z-2.0000 S1000
    G1 F1000 X16.7400 Y21.0567 Z-2.0000 S1000
    G1 F1000 X16.6315 Y21.0868 Z-2.0000 S1000
    G1 F1000 X16.5210 Y21.1092 Z-2.0000 S1000
    G1 F1000 X16.4093 Y21.1237 Z-2.0000 S1000
    G1 F1000 X16.2612 Y21.1306 Z-2.0000 S1000
    G1 F1000 X10.6418 Y21.1306 Z-2.0000 S1000
    G1 F1000 X10.5292 Y21.1266 Z-2.0000 S1000
    G1 F1000 X10.4172 Y21.1146 Z-2.0000 S1000
    G1 F1000 X10.3062 Y21.0947 Z-2.0000 S1000
    G1 F1000 X10.1970 Y21.0670 Z-2.0000 S1000
    G1 F1000 X10.0901 Y21.0316 Z-2.0000 S1000
    G1 F1000 X9.9859 Y20.9887 Z-2.0000 S1000
    G1 F1000 X9.8850 Y20.9386 Z-2.0000 S1000
    G1 F1000 X9.7879 Y20.8814 Z-2.0000 S1000
    G1 F1000 X9.6951 Y20.8174 Z-2.0000 S1000
    G1 F1000 X9.6071 Y20.7471 Z-2.0000 S1000
    G1 F1000 X9.5243 Y20.6707 Z-2.0000 S1000
    G1 F1000 X9.4471 Y20.5885 Z-2.0000 S1000
    G1 F1000 X9.3760 Y20.5012 Z-2.0000 S1000
    G1 F1000 X9.3112 Y20.4090 Z-2.0000 S1000
    G1 F1000 X9.2532 Y20.3124 Z-2.0000 S1000
    G1 F1000 X9.2021 Y20.2120 Z-2.0000 S1000
    G1 F1000 X9.1583 Y20.1082 Z-2.0000 S1000
    G1 F1000 X9.1116 Y19.9658 Z-2.0000 S1000
    G1 F1000 X7.9614 Y15.8021 Z-2.0000 S1000
    G1 F1000 X7.1997 Y19.8375 Z-2.0000 S1000
    G1 F1000 X7.1748 Y19.9474 Z-2.0000 S1000
    G1 F1000 X7.1423 Y20.0553 Z-2.0000 S1000
    G1 F1000 X7.1022 Y20.1606 Z-2.0000 S1000
    G1 F1000 X7.0547 Y20.2628 Z-2.0000 S1000
    G1 F1000 X7.0001 Y20.3614 Z-2.0000 S1000
    G1 F1000 X6.9386 Y20.4558 Z-2.0000 S1000
    G1 F1000 X6.8706 Y20.5456 Z-2.0000 S1000
    G1 F1000 X6.7964 Y20.6304 Z-2.0000 S1000
    G1 F1000 X6.7163 Y20.7097 Z-2.0000 S1000
    G1 F1000 X6.6309 Y20.7831 Z-2.0000 S1000
    G1 F1000 X6.5404 Y20.8503 Z-2.0000 S1000
    G1 F1000 X6.4454 Y20.9109 Z-2.0000 S1000
    G1 F1000 X6.3464 Y20.9646 Z-2.0000 S1000
    G1 F1000 X6.2438 Y21.0112 Z-2.0000 S1000
    G1 F1000 X6.1381 Y21.0503 Z-2.0000 S1000
    G1 F1000 X6.0299 Y21.0819 Z-2.0000 S1000
    G1 F1000 X5.9198 Y21.1057 Z-2.0000 S1000
    G1 F1000 X5.8083 Y21.1216 Z-2.0000 S1000
    G1 F1000 X5.6397 Y21.1306 Z-2.0000 S1000
    G1 F1000 X0.0000 Y21.1306 Z-2.0000 S1000
    G1 F1000 X-0.1126 Y21.1266 Z-2.0000 S1000
    G1 F1000 X-0.2246 Y21.1146 Z-2.0000 S1000
    G1 F1000 X-0.3356 Y21.0947 Z-2.0000 S1000
    G1 F1000 X-0.4448 Y21.0670 Z-2.0000 S1000
    G1 F1000 X-0.5517 Y21.0316 Z-2.0000 S1000
    G1 F1000 X-0.6559 Y20.9887 Z-2.0000 S1000
    G1 F1000 X-0.7568 Y20.9386 Z-2.0000 S1000
    G1 F1000 X-0.8539 Y20.8814 Z-2.0000 S1000
    G1 F1000 X-0.9467 Y20.8174 Z-2.0000 S1000
    G1 F1000 X-1.0347 Y20.7471 Z-2.0000 S1000
    G1 F1000 X-1.1175 Y20.6707 Z-2.0000 S1000
    G1 F1000 X-1.1947 Y20.5885 Z-2.0000 S1000
    G1 F1000 X-1.2658 Y20.5012 Z-2.0000 S1000
    G1 F1000 X-1.3306 Y20.4090 Z-2.0000 S1000
    G1 F1000 X-1.3886 Y20.3124 Z-2.0000 S1000
    G1 F1000 X-1.4397 Y20.2120 Z-2.0000 S1000
    G1 F1000 X-1.4835 Y20.1082 Z-2.0000 S1000
    G1 F1000 X-1.5199 Y20.0015 Z-2.0000 S1000
    G1 F1000 X-1.5486 Y19.8925 Z-2.0000 S1000
    G1 F1000 X-1.5694 Y19.7818 Z-2.0000 S1000
    G1 F1000 X-1.5824 Y19.6699 Z-2.0000 S1000
    G1 F1000 X-1.5874 Y19.5573 Z-2.0000 S1000
    G1 F1000 X-1.5844 Y19.4447 Z-2.0000 S1000
    G1 F1000 X-1.5735 Y19.3326 Z-2.0000 S1000
    G1 F1000 X-1.5496 Y19.1983 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X49.6756 Y0.3277 Z-2.0000 S1000
    G1 F1000 X49.6796 Y0.2151 Z-2.0000 S1000
    G1 F1000 X49.6916 Y0.1031 Z-2.0000 S1000
    G1 F1000 X49.7115 Y-0.0079 Z-2.0000 S1000
    G1 F1000 X49.7392 Y-0.1171 Z-2.0000 S1000
    G1 F1000 X49.7746 Y-0.2240 Z-2.0000 S1000
    G1 F1000 X49.8175 Y-0.3282 Z-2.0000 S1000
    G1 F1000 X49.8676 Y-0.4291 Z-2.0000 S1000
    G1 F1000 X49.9248 Y-0.5262 Z-2.0000 S1000
    G1 F1000 X49.9888 Y-0.6190 Z-2.0000 S1000
    G1 F1000 X50.0591 Y-0.7070 Z-2.0000 S1000
    G1 F1000 X50.1355 Y-0.7898 Z-2.0000 S1000
    G1 F1000 X50.2177 Y-0.8670 Z-2.0000 S1000
    G1 F1000 X50.3050 Y-0.9381 Z-2.0000 S1000
    G1 F1000 X50.3972 Y-1.0029 Z-2.0000 S1000
    G1 F1000 X50.4938 Y-1.0609 Z-2.0000 S1000
    G1 F1000 X50.5942 Y-1.1120 Z-2.0000 S1000
    G1 F1000 X50.6980 Y-1.1558 Z-2.0000 S1000
    G1 F1000 X50.8047 Y-1.1922 Z-2.0000 S1000
    G1 F1000 X50.9137 Y-1.2209 Z-2.0000 S1000
    G1 F1000 X51.0244 Y-1.2417 Z-2.0000 S1000
    G1 F1000 X51.1363 Y-1.2547 Z-2.0000 S1000
    G1 F1000 X51.2631 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X57.2269 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X57.3395 Y-1.2558 Z-2.0000 S1000
    G1 F1000 X57.4515 Y-1.2438 Z-2.0000 S1000
    G1 F1000 X57.5625 Y-1.2239 Z-2.0000 S1000
    G1 F1000 X57.6717 Y-1.1962 Z-2.0000 S1000
    G1 F1000 X57.7786 Y-1.1608 Z-2.0000 S1000
    G1 F1000 X57.8828 Y-1.1179 Z-2.0000 S1000
    G1 F1000 X57.9837 Y-1.0678 Z-2.0000 S1000
    G1 F1000 X58.0808 Y-1.0106 Z-2.0000 S1000
    G1 F1000 X58.1736 Y-0.9466 Z-2.0000 S1000
    G1 F1000 X58.2616 Y-0.8763 Z-2.0000 S1000
    G1 F1000 X58.3444 Y-0.7999 Z-2.0000 S1000
    G1 F1000 X58.4216 Y-0.7177 Z-2.0000 S1000
    G1 F1000 X58.4927 Y-0.6304 Z-2.0000 S1000
    G1 F1000 X58.5575 Y-0.5382 Z-2.0000 S1000
    G1 F1000 X58.6155 Y-0.4416 Z-2.0000 S1000
    G1 F1000 X58.6666 Y-0.3412 Z-2.0000 S1000
    G1 F1000 X58.7104 Y-0.2374 Z-2.0000 S1000
    G1 F1000 X58.7468 Y-0.1307 Z-2.0000 S1000
    G1 F1000 X58.7755 Y-0.0217 Z-2.0000 S1000
    G1 F1000 X58.7963 Y0.0890 Z-2.0000 S1000
    G1 F1000 X58.8093 Y0.2009 Z-2.0000 S1000
    G1 F1000 X58.8144 Y0.3277 Z-2.0000 S1000
    G1 F1000 X58.8144 Y5.5568 Z-2.0000 S1000
    G1 F1000 X58.9029 Y5.4108 Z-2.0000 S1000
    G1 F1000 X62.0582 Y-0.4271 Z-2.0000 S1000
    G1 F1000 X62.1153 Y-0.5243 Z-2.0000 S1000
    G1 F1000 X62.1791 Y-0.6172 Z-2.0000 S1000
    G1 F1000 X62.2493 Y-0.7053 Z-2.0000 S1000
    G1 F1000 X62.3256 Y-0.7882 Z-2.0000 S1000
    G1 F1000 X62.4076 Y-0.8655 Z-2.0000 S1000
    G1 F1000 X62.4949 Y-0.9367 Z-2.0000 S1000
    G1 F1000 X62.5870 Y-1.0016 Z-2.0000 S1000
    G1 F1000 X62.6835 Y-1.0598 Z-2.0000 S1000
    G1 F1000 X62.7839 Y-1.1110 Z-2.0000 S1000
    G1 F1000 X62.8876 Y-1.1550 Z-2.0000 S1000
    G1 F1000 X62.9942 Y-1.1915 Z-2.0000 S1000
    G1 F1000 X63.1031 Y-1.2204 Z-2.0000 S1000
    G1 F1000 X63.2138 Y-1.2414 Z-2.0000 S1000
    G1 F1000 X63.3257 Y-1.2545 Z-2.0000 S1000
    G1 F1000 X63.4548 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X70.1640 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X70.2766 Y-1.2558 Z-2.0000 S1000
    G1 F1000 X70.3886 Y-1.2438 Z-2.0000 S1000
    G1 F1000 X70.4996 Y-1.2239 Z-2.0000 S1000
    G1 F1000 X70.6088 Y-1.1962 Z-2.0000 S1000
    G1 F1000 X70.7157 Y-1.1608 Z-2.0000 S1000
    G1 F1000 X70.8199 Y-1.1179 Z-2.0000 S1000
    G1 F1000 X70.9208 Y-1.0678 Z-2.0000 S1000
    G1 F1000 X71.0179 Y-1.0106 Z-2.0000 S1000
    G1 F1000 X71.1107 Y-0.9466 Z-2.0000 S1000
    G1 F1000 X71.1143 Y-0.9437 Z-2.0000 S1000
    G1 F1000 X71.1986 Y-1.0029 Z-2.0000 S1000
    G1 F1000 X71.2952 Y-1.0609 Z-2.0000 S1000
    G1 F1000 X71.3956 Y-1.1120 Z-2.0000 S1000
    G1 F1000 X71.4994 Y-1.1558 Z-2.0000 S1000
    G1 F1000 X71.6061 Y-1.1922 Z-2.0000 S1000
    G1 F1000 X71.7151 Y-1.2209 Z-2.0000 S1000
    G1 F1000 X71.8258 Y-1.2417 Z-2.0000 S1000
    G1 F1000 X71.9377 Y-1.2547 Z-2.0000 S1000
    G1 F1000 X72.0645 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X87.2691 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X87.3817 Y-1.2558 Z-2.0000 S1000
    G1 F1000 X87.4937 Y-1.2438 Z-2.0000 S1000
    G1 F1000 X87.6047 Y-1.2239 Z-2.0000 S1000
    G1 F1000 X87.7139 Y-1.1962 Z-2.0000 S1000
    G1 F1000 X87.8208 Y-1.1608 Z-2.0000 S1000
    G1 F1000 X87.9250 Y-1.1179 Z-2.0000 S1000
    G1 F1000 X88.0259 Y-1.0678 Z-2.0000 S1000
    G1 F1000 X88.1230 Y-1.0106 Z-2.0000 S1000
    G1 F1000 X88.2158 Y-0.9466 Z-2.0000 S1000
    G1 F1000 X88.3038 Y-0.8763 Z-2.0000 S1000
    G1 F1000 X88.3866 Y-0.7999 Z-2.0000 S1000
    G1 F1000 X88.4638 Y-0.7177 Z-2.0000 S1000
    G1 F1000 X88.5349 Y-0.6304 Z-2.0000 S1000
    G1 F1000 X88.5997 Y-0.5382 Z-2.0000 S1000
    G1 F1000 X88.6577 Y-0.4416 Z-2.0000 S1000
    G1 F1000 X88.6587 Y-0.4397 Z-2.0000 S1000
    G1 F1000 X88.7096 Y-0.5262 Z-2.0000 S1000
    G1 F1000 X88.7736 Y-0.6190 Z-2.0000 S1000
    G1 F1000 X88.8439 Y-0.7070 Z-2.0000 S1000
    G1 F1000 X88.9203 Y-0.7898 Z-2.0000 S1000
    G1 F1000 X89.0025 Y-0.8670 Z-2.0000 S1000
    G1 F1000 X89.0898 Y-0.9381 Z-2.0000 S1000
    G1 F1000 X89.1820 Y-1.0029 Z-2.0000 S1000
    G1 F1000 X89.2786 Y-1.0609 Z-2.0000 S1000
    G1 F1000 X89.3790 Y-1.1120 Z-2.0000 S1000
    G1 F1000 X89.4828 Y-1.1558 Z-2.0000 S1000
    G1 F1000 X89.5895 Y-1.1922 Z-2.0000 S1000
    G1 F1000 X89.6985 Y-1.2209 Z-2.0000 S1000
    G1 F1000 X89.8092 Y-1.2417 Z-2.0000 S1000
    G1 F1000 X89.9211 Y-1.2547 Z-2.0000 S1000
    G1 F1000 X90.0479 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X98.8692 Y-1.2598 Z-2.0000 S1000
    G1 F1000 X98.9929 Y-1.2550 Z-2.0000 S1000
    G1 F1000 X100.6706 Y-1.1239 Z-2.0000 S1000
    G1 F1000 X100.7825 Y-1.1111 Z-2.0000 S1000
    G1 F1000 X100.8750 Y-1.0944 Z-2.0000 S1000
    G1 F1000 X102.7363 Y-0.7012 Z-2.0000 S1000
    G1 F1000 X102.8457 Y-0.6740 Z-2.0000 S1000
    G1 F1000 X102.9528 Y-0.6392 Z-2.0000 S1000
    G1 F1000 X103.0148 Y-0.6150 Z-2.0000 S1000
    G1 F1000 X104.3976 Y-0.0432 Z-2.0000 S1000
    G1 F1000 X104.5002 Y0.0035 Z-2.0000 S1000
    G1 F1000 X104.5991 Y0.0574 Z-2.0000 S1000
    G1 F1000 X104.7352 Y0.1476 Z-2.0000 S1000
    G1 F1000 X106.0263 Y1.1028 Z-2.0000 S1000
    G1 F1000 X106.1144 Y1.1730 Z-2.0000 S1000
    G1 F1000 X106.1974 Y1.2493 Z-2.0000 S1000
    G1 F1000 X106.2836 Y1.3415 Z-2.0000 S1000
    G1 F1000 X107.3928 Y2.6260 Z-2.0000 S1000
    G1 F1000 X107.4634 Y2.7138 Z-2.0000 S1000
    G1 F1000 X107.5276 Y2.8064 Z-2.0000 S1000
    G1 F1000 X107.5901 Y2.9127 Z-2.0000 S1000
    G1 F1000 X108.4273 Y4.4725 Z-2.0000 S1000
    G1 F1000 X108.4770 Y4.5736 Z-2.0000 S1000
    G1 F1000 X108.5194 Y4.6780 Z-2.0000 S1000
    G1 F1000 X108.5659 Y4.8275 Z-2.0000 S1000
    G1 F1000 X109.0919 Y6.8706 Z-2.0000 S1000
    G1 F1000 X109.1161 Y6.9806 Z-2.0000 S1000
    G1 F1000 X109.1324 Y7.0921 Z-2.0000 S1000
    G1 F1000 X109.1387 Y7.1648 Z-2.0000 S1000
    G1 F1000 X109.3140 Y9.8994 Z-2.0000 S1000
    G1 F1000 X109.3173 Y10.0121 Z-2.0000 S1000
    G1 F1000 X109.3143 Y10.0987 Z-2.0000 S1000
    G1 F1000 X109.1963 Y12.0123 Z-2.0000 S1000
    G1 F1000 X109.1854 Y12.1245 Z-2.0000 S1000
    G1 F1000 X109.1698 Y12.2194 Z-2.0000 S1000
    G1 F1000 X108.8159 Y14.0283 Z-2.0000 S1000
    G1 F1000 X108.7903 Y14.1380 Z-2.0000 S1000
    G1 F1000 X108.7449 Y14.2793 Z-2.0000 S1000
    G1 F1000 X108.1289 Y15.9275 Z-2.0000 S1000
    G1 F1000 X108.0858 Y16.0315 Z-2.0000 S1000
    G1 F1000 X108.0353 Y16.1323 Z-2.0000 S1000
    G1 F1000 X107.9841 Y16.2194 Z-2.0000 S1000
    G1 F1000 X107.0797 Y17.6514 Z-2.0000 S1000
    G1 F1000 X107.0162 Y17.7445 Z-2.0000 S1000
    G1 F1000 X106.9463 Y17.8328 Z-2.0000 S1000
    G1 F1000 X106.8514 Y17.9348 Z-2.0000 S1000
    G1 F1000 X105.6635 Y19.1046 Z-2.0000 S1000
    G1 F1000 X105.5804 Y19.1808 Z-2.0000 S1000
    G1 F1000 X105.4922 Y19.2509 Z-2.0000 S1000
    G1 F1000 X105.3539 Y19.3421 Z-2.0000 S1000
    G1 F1000 X103.8875 Y20.2039 Z-2.0000 S1000
    G1 F1000 X103.7884 Y20.2575 Z-2.0000 S1000
    G1 F1000 X103.6858 Y20.3040 Z-2.0000 S1000
    G1 F1000 X103.5801 Y20.3430 Z-2.0000 S1000
    G1 F1000 X103.5197 Y20.3616 Z-2.0000 S1000
    G1 F1000 X101.6634 Y20.8925 Z-2.0000 S1000
    G1 F1000 X101.5541 Y20.9196 Z-2.0000 S1000
    G1 F1000 X101.4430 Y20.9389 Z-2.0000 S1000
    G1 F1000 X101.3457 Y20.9493 Z-2.0000 S1000
    G1 F1000 X98.9880 Y21.1262 Z-2.0000 S1000
    G1 F1000 X98.8692 Y21.1306 Z-2.0000 S1000
    G1 F1000 X90.0479 Y21.1306 Z-2.0000 S1000
    G1 F1000 X89.9353 Y21.1266 Z-2.0000 S1000
    G1 F1000 X89.8233 Y21.1146 Z-2.0000 S1000
    G1 F1000 X89.7123 Y21.0947 Z-2.0000 S1000
    G1 F1000 X89.6031 Y21.0670 Z-2.0000 S1000
    G1 F1000 X89.4962 Y21.0316 Z-2.0000 S1000
    G1 F1000 X89.3920 Y20.9887 Z-2.0000 S1000
    G1 F1000 X89.2911 Y20.9386 Z-2.0000 S1000
    G1 F1000 X89.1940 Y20.8814 Z-2.0000 S1000
    G1 F1000 X89.1012 Y20.8174 Z-2.0000 S1000
    G1 F1000 X89.0132 Y20.7471 Z-2.0000 S1000
    G1 F1000 X88.9304 Y20.6707 Z-2.0000 S1000
    G1 F1000 X88.8532 Y20.5885 Z-2.0000 S1000
    G1 F1000 X88.7821 Y20.5012 Z-2.0000 S1000
    G1 F1000 X88.7173 Y20.4090 Z-2.0000 S1000
    G1 F1000 X88.6593 Y20.3124 Z-2.0000 S1000
    G1 F1000 X88.6082 Y20.2120 Z-2.0000 S1000
    G1 F1000 X88.5644 Y20.1082 Z-2.0000 S1000
    G1 F1000 X88.5280 Y20.0015 Z-2.0000 S1000
    G1 F1000 X88.4993 Y19.8925 Z-2.0000 S1000
    G1 F1000 X88.4785 Y19.7818 Z-2.0000 S1000
    G1 F1000 X88.4655 Y19.6699 Z-2.0000 S1000
    G1 F1000 X88.4604 Y19.5431 Z-2.0000 S1000
    G1 F1000 X88.4604 Y6.1080 Z-2.0000 S1000
    G1 F1000 X88.3967 Y6.1770 Z-2.0000 S1000
    G1 F1000 X88.3145 Y6.2542 Z-2.0000 S1000
    G1 F1000 X88.2272 Y6.3253 Z-2.0000 S1000
    G1 F1000 X88.1350 Y6.3901 Z-2.0000 S1000
    G1 F1000 X88.0384 Y6.4481 Z-2.0000 S1000
    G1 F1000 X87.9380 Y6.4992 Z-2.0000 S1000
    G1 F1000 X87.8342 Y6.5430 Z-2.0000 S1000
    G1 F1000 X87.7275 Y6.5794 Z-2.0000 S1000
    G1 F1000 X87.6185 Y6.6081 Z-2.0000 S1000
    G1 F1000 X87.5078 Y6.6289 Z-2.0000 S1000
    G1 F1000 X87.3959 Y6.6419 Z-2.0000 S1000
    G1 F1000 X87.2691 Y6.6470 Z-2.0000 S1000
    G1 F1000 X79.5897 Y6.6470 Z-2.0000 S1000
    G1 F1000 X79.5897 Y19.5431 Z-2.0000 S1000
    G1 F1000 X79.5857 Y19.6557 Z-2.0000 S1000
    G1 F1000 X79.5737 Y19.7677 Z-2.0000 S1000
    G1 F1000 X79.5538 Y19.8787 Z-2.0000 S1000
    G1 F1000 X79.5261 Y19.9879 Z-2.0000 S1000
    G1 F1000 X79.4907 Y20.0948 Z-2.0000 S1000
    G1 F1000 X79.4478 Y20.1990 Z-2.0000 S1000
    G1 F1000 X79.3977 Y20.2999 Z-2.0000 S1000
    G1 F1000 X79.3405 Y20.3970 Z-2.0000 S1000
    G1 F1000 X79.2765 Y20.4898 Z-2.0000 S1000
    G1 F1000 X79.2062 Y20.5778 Z-2.0000 S1000
    G1 F1000 X79.1298 Y20.6606 Z-2.0000 S1000
    G1 F1000 X79.0476 Y20.7378 Z-2.0000 S1000
    G1 F1000 X78.9603 Y20.8089 Z-2.0000 S1000
    G1 F1000 X78.8681 Y20.8737 Z-2.0000 S1000
    G1 F1000 X78.7715 Y20.9317 Z-2.0000 S1000
    G1 F1000 X78.6711 Y20.9828 Z-2.0000 S1000
    G1 F1000 X78.5673 Y21.0266 Z-2.0000 S1000
    G1 F1000 X78.4606 Y21.0630 Z-2.0000 S1000
    G1 F1000 X78.3516 Y21.0917 Z-2.0000 S1000
    G1 F1000 X78.2409 Y21.1125 Z-2.0000 S1000
    G1 F1000 X78.1290 Y21.1255 Z-2.0000 S1000
    G1 F1000 X78.0022 Y21.1306 Z-2.0000 S1000
    G1 F1000 X72.0645 Y21.1306 Z-2.0000 S1000
    G1 F1000 X71.9519 Y21.1266 Z-2.0000 S1000
    G1 F1000 X71.8399 Y21.1146 Z-2.0000 S1000
    G1 F1000 X71.7289 Y21.0947 Z-2.0000 S1000
    G1 F1000 X71.6197 Y21.0670 Z-2.0000 S1000
    G1 F1000 X71.5128 Y21.0316 Z-2.0000 S1000
    G1 F1000 X71.4086 Y20.9887 Z-2.0000 S1000
    G1 F1000 X71.3077 Y20.9386 Z-2.0000 S1000
    G1 F1000 X71.2106 Y20.8814 Z-2.0000 S1000
    G1 F1000 X71.1178 Y20.8174 Z-2.0000 S1000
    G1 F1000 X71.0298 Y20.7471 Z-2.0000 S1000
    G1 F1000 X70.9470 Y20.6707 Z-2.0000 S1000
    G1 F1000 X70.8698 Y20.5885 Z-2.0000 S1000
    G1 F1000 X70.7987 Y20.5012 Z-2.0000 S1000
    G1 F1000 X70.7339 Y20.4090 Z-2.0000 S1000
    G1 F1000 X70.6759 Y20.3124 Z-2.0000 S1000
    G1 F1000 X70.6248 Y20.2120 Z-2.0000 S1000
    G1 F1000 X70.5810 Y20.1082 Z-2.0000 S1000
    G1 F1000 X70.5446 Y20.0015 Z-2.0000 S1000
    G1 F1000 X70.5159 Y19.8925 Z-2.0000 S1000
    G1 F1000 X70.4951 Y19.7818 Z-2.0000 S1000
    G1 F1000 X70.4821 Y19.6699 Z-2.0000 S1000
    G1 F1000 X70.4770 Y19.5431 Z-2.0000 S1000
    G1 F1000 X70.4770 Y3.1813 Z-2.0000 S1000
    G1 F1000 X68.6990 Y6.6241 Z-2.0000 S1000
    G1 F1000 X68.6438 Y6.7224 Z-2.0000 S1000
    G1 F1000 X68.5911 Y6.8031 Z-2.0000 S1000
    G1 F1000 X67.7594 Y7.9970 Z-2.0000 S1000
    G1 F1000 X67.6917 Y8.0871 Z-2.0000 S1000
    G1 F1000 X67.6134 Y8.1770 Z-2.0000 S1000
    G1 F1000 X67.2880 Y8.5231 Z-2.0000 S1000
    G1 F1000 X68.0884 Y9.1471 Z-2.0000 S1000
    G1 F1000 X68.1747 Y9.2195 Z-2.0000 S1000
    G1 F1000 X68.2557 Y9.2979 Z-2.0000 S1000
    G1 F1000 X68.3310 Y9.3817 Z-2.0000 S1000
    G1 F1000 X68.3694 Y9.4296 Z-2.0000 S1000
    G1 F1000 X69.1793 Y10.4798 Z-2.0000 S1000
    G1 F1000 X69.2449 Y10.5715 Z-2.0000 S1000
    G1 F1000 X69.3038 Y10.6675 Z-2.0000 S1000
    G1 F1000 X69.3558 Y10.7675 Z-2.0000 S1000
    G1 F1000 X69.3947 Y10.8561 Z-2.0000 S1000
    G1 F1000 X69.9062 Y12.1259 Z-2.0000 S1000
    G1 F1000 X69.9446 Y12.2319 Z-2.0000 S1000
    G1 F1000 X69.9753 Y12.3403 Z-2.0000 S1000
    G1 F1000 X69.9983 Y12.4506 Z-2.0000 S1000
    G1 F1000 X70.0109 Y12.5385 Z-2.0000 S1000
    G1 F1000 X70.1814 Y14.0278 Z-2.0000 S1000
    G1 F1000 X70.1902 Y14.1402 Z-2.0000 S1000
    G1 F1000 X70.1911 Y14.2528 Z-2.0000 S1000
    G1 F1000 X70.1782 Y14.4152 Z-2.0000 S1000
    G1 F1000 X69.9554 Y16.1110 Z-2.0000 S1000
    G1 F1000 X69.9367 Y16.2221 Z-2.0000 S1000
    G1 F1000 X69.9103 Y16.3316 Z-2.0000 S1000
    G1 F1000 X69.8761 Y16.4390 Z-2.0000 S1000
    G1 F1000 X69.8172 Y16.5815 Z-2.0000 S1000
    G1 F1000 X69.1487 Y17.9987 Z-2.0000 S1000
    G1 F1000 X69.0970 Y18.0988 Z-2.0000 S1000
    G1 F1000 X69.0384 Y18.1950 Z-2.0000 S1000
    G1 F1000 X68.9731 Y18.2868 Z-2.0000 S1000
    G1 F1000 X68.9014 Y18.3738 Z-2.0000 S1000
    G1 F1000 X68.8588 Y18.4201 Z-2.0000 S1000
    G1 F1000 X67.8266 Y19.4966 Z-2.0000 S1000
    G1 F1000 X67.7457 Y19.5751 Z-2.0000 S1000
    G1 F1000 X67.6596 Y19.6477 Z-2.0000 S1000
    G1 F1000 X67.5684 Y19.7140 Z-2.0000 S1000
    G1 F1000 X67.4728 Y19.7736 Z-2.0000 S1000
    G1 F1000 X67.4047 Y19.8107 Z-2.0000 S1000
    G1 F1000 X66.0906 Y20.4841 Z-2.0000 S1000
    G1 F1000 X65.9885 Y20.5319 Z-2.0000 S1000
    G1 F1000 X65.8834 Y20.5723 Z-2.0000 S1000
    G1 F1000 X65.7756 Y20.6052 Z-2.0000 S1000
    G1 F1000 X65.6763 Y20.6283 Z-2.0000 S1000
    G1 F1000 X63.8970 Y20.9822 Z-2.0000 S1000
    G1 F1000 X63.7858 Y21.0002 Z-2.0000 S1000
    G1 F1000 X63.6643 Y21.0108 Z-2.0000 S1000
    G1 F1000 X61.2362 Y21.1287 Z-2.0000 S1000
    G1 F1000 X61.1592 Y21.1306 Z-2.0000 S1000
    G1 F1000 X51.2631 Y21.1306 Z-2.0000 S1000
    G1 F1000 X51.1505 Y21.1266 Z-2.0000 S1000
    G1 F1000 X51.0385 Y21.1146 Z-2.0000 S1000
    G1 F1000 X50.9275 Y21.0947 Z-2.0000 S1000
    G1 F1000 X50.8183 Y21.0670 Z-2.0000 S1000
    G1 F1000 X50.7114 Y21.0316 Z-2.0000 S1000
    G1 F1000 X50.6072 Y20.9887 Z-2.0000 S1000
    G1 F1000 X50.5063 Y20.9386 Z-2.0000 S1000
    G1 F1000 X50.4092 Y20.8814 Z-2.0000 S1000
    G1 F1000 X50.3164 Y20.8174 Z-2.0000 S1000
    G1 F1000 X50.2284 Y20.7471 Z-2.0000 S1000
    G1 F1000 X50.1456 Y20.6707 Z-2.0000 S1000
    G1 F1000 X50.0684 Y20.5885 Z-2.0000 S1000
    G1 F1000 X49.9973 Y20.5012 Z-2.0000 S1000
    G1 F1000 X49.9325 Y20.4090 Z-2.0000 S1000
    G1 F1000 X49.8745 Y20.3124 Z-2.0000 S1000
    G1 F1000 X49.8234 Y20.2120 Z-2.0000 S1000
    G1 F1000 X49.7796 Y20.1082 Z-2.0000 S1000
    G1 F1000 X49.7432 Y20.0015 Z-2.0000 S1000
    G1 F1000 X49.7145 Y19.8925 Z-2.0000 S1000
    G1 F1000 X49.6937 Y19.7818 Z-2.0000 S1000
    G1 F1000 X49.6807 Y19.6699 Z-2.0000 S1000
    G1 F1000 X49.6756 Y19.5431 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X59.5991 Y13.3448 Z-2.0000 S1000
    G1 F1000 X58.8144 Y13.3448 Z-2.0000 S1000
    G1 F1000 X58.8144 Y14.0759 Z-2.0000 S1000
    G1 F1000 X59.7635 Y14.0759 Z-2.0000 S1000
    G1 F1000 X60.7994 Y13.9814 Z-2.0000 S1000
    G1 F1000 X60.9993 Y13.8935 Z-2.0000 S1000
    G1 F1000 X61.0305 Y13.7195 Z-2.0000 S1000
    G1 F1000 X61.0207 Y13.6573 Z-2.0000 S1000
    G1 F1000 X60.9952 Y13.6099 Z-2.0000 S1000
    G1 F1000 X60.9835 Y13.5991 Z-2.0000 S1000
    G1 F1000 X60.8788 Y13.5581 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X40.4009 Y8.8286 Z-2.0000 S1000
    G1 F1000 X40.2386 Y7.8039 Z-2.0000 S1000
    G1 F1000 X40.0093 Y7.1085 Z-2.0000 S1000
    G1 F1000 X39.7579 Y6.6995 Z-2.0000 S1000
    G1 F1000 X39.4723 Y6.4306 Z-2.0000 S1000
    G1 F1000 X39.1117 Y6.2261 Z-2.0000 S1000
    G1 F1000 X38.6454 Y6.0891 Z-2.0000 S1000
    G1 F1000 X38.0411 Y6.0370 Z-2.0000 S1000
    G1 F1000 X37.4610 Y6.0893 Z-2.0000 S1000
    G1 F1000 X37.0080 Y6.2270 Z-2.0000 S1000
    G1 F1000 X36.6395 Y6.4402 Z-2.0000 S1000
    G1 F1000 X36.3265 Y6.7355 Z-2.0000 S1000
    G1 F1000 X36.0558 Y7.1578 Z-2.0000 S1000
    G1 F1000 X35.8239 Y7.8049 Z-2.0000 S1000
    G1 F1000 X35.6618 Y8.7223 Z-2.0000 S1000
    G1 F1000 X35.6031 Y9.8963 Z-2.0000 S1000
    G1 F1000 X35.6623 Y11.0820 Z-2.0000 S1000
    G1 F1000 X35.8255 Y12.0067 Z-2.0000 S1000
    G1 F1000 X36.0588 Y12.6573 Z-2.0000 S1000
    G1 F1000 X36.3324 Y13.0826 Z-2.0000 S1000
    G1 F1000 X36.6492 Y13.3822 Z-2.0000 S1000
    G1 F1000 X37.0132 Y13.5959 Z-2.0000 S1000
    G1 F1000 X37.4444 Y13.7302 Z-2.0000 S1000
    G1 F1000 X37.9895 Y13.7810 Z-2.0000 S1000
    G1 F1000 X38.5754 Y13.7294 Z-2.0000 S1000
    G1 F1000 X39.0412 Y13.5912 Z-2.0000 S1000
    G1 F1000 X39.4184 Y13.3784 Z-2.0000 S1000
    G1 F1000 X39.7398 Y13.0831 Z-2.0000 S1000
    G1 F1000 X40.0128 Y12.6740 Z-2.0000 S1000
    G1 F1000 X40.2412 Y12.0731 Z-2.0000 S1000
    G1 F1000 X40.4007 Y11.2320 Z-2.0000 S1000
    G1 F1000 X40.4592 Y10.1505 Z-2.0000 S1000
    G0 Z7
    G0 X97.5731 Y6.2919
    G0 Z0
    G1 F700 Z-2.0000
    G1 F1000 X97.5731 Y13.5935 Z-2.0000 S1000
    G1 F1000 X98.3045 Y13.5454 Z-2.0000 S1000
    G1 F1000 X98.9205 Y13.4020 Z-2.0000 S1000
    G1 F1000 X99.3208 Y13.2124 Z-2.0000 S1000
    G1 F1000 X99.5596 Y13.0094 Z-2.0000 S1000
    G1 F1000 X99.7626 Y12.6907 Z-2.0000 S1000
    G1 F1000 X99.9703 Y12.0737 Z-2.0000 S1000
    G1 F1000 X100.1217 Y11.1288 Z-2.0000 S1000
    G1 F1000 X100.1764 Y9.8918 Z-2.0000 S1000
    G1 F1000 X100.0778 Y8.1332 Z-2.0000 S1000
    G1 F1000 X99.8376 Y7.1638 Z-2.0000 S1000
    G1 F1000 X99.5759 Y6.7326 Z-2.0000 S1000
    G1 F1000 X99.3368 Y6.5393 Z-2.0000 S1000
    G1 F1000 X98.7549 Y6.3685 Z-2.0000 S1000
    G1 F1000 X97.5731 Y6.2919 Z-2.0000 S1000
    G0 Z7
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X2.7255 Y-0.0171 Z-3.0000 S1000
    G1 F1000 X2.7538 Y-0.1261 Z-3.0000 S1000
    G1 F1000 X2.7899 Y-0.2329 Z-3.0000 S1000
    G1 F1000 X2.8334 Y-0.3368 Z-3.0000 S1000
    G1 F1000 X2.8841 Y-0.4374 Z-3.0000 S1000
    G1 F1000 X2.9419 Y-0.5341 Z-3.0000 S1000
    G1 F1000 X3.0064 Y-0.6265 Z-3.0000 S1000
    G1 F1000 X3.0773 Y-0.7141 Z-3.0000 S1000
    G1 F1000 X3.1542 Y-0.7965 Z-3.0000 S1000
    G1 F1000 X3.2368 Y-0.8731 Z-3.0000 S1000
    G1 F1000 X3.3246 Y-0.9438 Z-3.0000 S1000
    G1 F1000 X3.4171 Y-1.0080 Z-3.0000 S1000
    G1 F1000 X3.5141 Y-1.0655 Z-3.0000 S1000
    G1 F1000 X3.6148 Y-1.1160 Z-3.0000 S1000
    G1 F1000 X3.7189 Y-1.1592 Z-3.0000 S1000
    G1 F1000 X3.8257 Y-1.1949 Z-3.0000 S1000
    G1 F1000 X3.9349 Y-1.2229 Z-3.0000 S1000
    G1 F1000 X4.0457 Y-1.2431 Z-3.0000 S1000
    G1 F1000 X4.1577 Y-1.2555 Z-3.0000 S1000
    G1 F1000 X4.2751 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X10.0976 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X10.2102 Y-1.2558 Z-3.0000 S1000
    G1 F1000 X10.3222 Y-1.2438 Z-3.0000 S1000
    G1 F1000 X10.4332 Y-1.2239 Z-3.0000 S1000
    G1 F1000 X10.5424 Y-1.1962 Z-3.0000 S1000
    G1 F1000 X10.6493 Y-1.1608 Z-3.0000 S1000
    G1 F1000 X10.7535 Y-1.1179 Z-3.0000 S1000
    G1 F1000 X10.8544 Y-1.0678 Z-3.0000 S1000
    G1 F1000 X10.9515 Y-1.0106 Z-3.0000 S1000
    G1 F1000 X11.0443 Y-0.9466 Z-3.0000 S1000
    G1 F1000 X11.1323 Y-0.8763 Z-3.0000 S1000
    G1 F1000 X11.2151 Y-0.7999 Z-3.0000 S1000
    G1 F1000 X11.2923 Y-0.7177 Z-3.0000 S1000
    G1 F1000 X11.3634 Y-0.6304 Z-3.0000 S1000
    G1 F1000 X11.4282 Y-0.5382 Z-3.0000 S1000
    G1 F1000 X11.4862 Y-0.4416 Z-3.0000 S1000
    G1 F1000 X11.5373 Y-0.3412 Z-3.0000 S1000
    G1 F1000 X11.5811 Y-0.2374 Z-3.0000 S1000
    G1 F1000 X11.6273 Y-0.0968 Z-3.0000 S1000
    G1 F1000 X13.4577 Y6.4995 Z-3.0000 S1000
    G1 F1000 X15.2957 Y-0.0983 Z-3.0000 S1000
    G1 F1000 X15.3298 Y-0.2057 Z-3.0000 S1000
    G1 F1000 X15.3714 Y-0.3104 Z-3.0000 S1000
    G1 F1000 X15.4203 Y-0.4119 Z-3.0000 S1000
    G1 F1000 X15.4763 Y-0.5097 Z-3.0000 S1000
    G1 F1000 X15.5391 Y-0.6033 Z-3.0000 S1000
    G1 F1000 X15.6084 Y-0.6921 Z-3.0000 S1000
    G1 F1000 X15.6838 Y-0.7759 Z-3.0000 S1000
    G1 F1000 X15.7650 Y-0.8540 Z-3.0000 S1000
    G1 F1000 X15.8514 Y-0.9262 Z-3.0000 S1000
    G1 F1000 X15.9428 Y-0.9921 Z-3.0000 S1000
    G1 F1000 X16.0387 Y-1.0514 Z-3.0000 S1000
    G1 F1000 X16.1385 Y-1.1037 Z-3.0000 S1000
    G1 F1000 X16.2418 Y-1.1488 Z-3.0000 S1000
    G1 F1000 X16.3480 Y-1.1864 Z-3.0000 S1000
    G1 F1000 X16.4566 Y-1.2165 Z-3.0000 S1000
    G1 F1000 X16.5670 Y-1.2387 Z-3.0000 S1000
    G1 F1000 X16.6788 Y-1.2531 Z-3.0000 S1000
    G1 F1000 X16.8250 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X22.6476 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X22.7602 Y-1.2558 Z-3.0000 S1000
    G1 F1000 X22.8722 Y-1.2438 Z-3.0000 S1000
    G1 F1000 X22.9832 Y-1.2239 Z-3.0000 S1000
    G1 F1000 X23.0924 Y-1.1962 Z-3.0000 S1000
    G1 F1000 X23.1993 Y-1.1608 Z-3.0000 S1000
    G1 F1000 X23.3035 Y-1.1179 Z-3.0000 S1000
    G1 F1000 X23.4044 Y-1.0678 Z-3.0000 S1000
    G1 F1000 X23.5015 Y-1.0106 Z-3.0000 S1000
    G1 F1000 X23.5943 Y-0.9466 Z-3.0000 S1000
    G1 F1000 X23.6823 Y-0.8763 Z-3.0000 S1000
    G1 F1000 X23.7651 Y-0.7999 Z-3.0000 S1000
    G1 F1000 X23.8423 Y-0.7177 Z-3.0000 S1000
    G1 F1000 X23.9134 Y-0.6304 Z-3.0000 S1000
    G1 F1000 X23.9782 Y-0.5382 Z-3.0000 S1000
    G1 F1000 X24.0362 Y-0.4416 Z-3.0000 S1000
    G1 F1000 X24.0873 Y-0.3412 Z-3.0000 S1000
    G1 F1000 X24.1311 Y-0.2374 Z-3.0000 S1000
    G1 F1000 X24.1675 Y-0.1307 Z-3.0000 S1000
    G1 F1000 X24.1979 Y-0.0140 Z-3.0000 S1000
    G1 F1000 X26.5326 Y10.5773 Z-3.0000 S1000
    G1 F1000 X26.4929 Y10.0390 Z-3.0000 S1000
    G1 F1000 X26.4886 Y9.9264 Z-3.0000 S1000
    G1 F1000 X26.4907 Y9.8411 Z-3.0000 S1000
    G1 F1000 X26.5734 Y8.2273 Z-3.0000 S1000
    G1 F1000 X26.5831 Y8.1150 Z-3.0000 S1000
    G1 F1000 X26.5934 Y8.0447 Z-3.0000 S1000
    G1 F1000 X26.8416 Y6.5717 Z-3.0000 S1000
    G1 F1000 X26.8642 Y6.4613 Z-3.0000 S1000
    G1 F1000 X26.8909 Y6.3646 Z-3.0000 S1000
    G1 F1000 X27.3046 Y5.0326 Z-3.0000 S1000
    G1 F1000 X27.3419 Y4.9263 Z-3.0000 S1000
    G1 F1000 X27.3930 Y4.8093 Z-3.0000 S1000
    G1 F1000 X27.9722 Y3.6181 Z-3.0000 S1000
    G1 F1000 X28.0251 Y3.5186 Z-3.0000 S1000
    G1 F1000 X28.0880 Y3.4183 Z-3.0000 S1000
    G1 F1000 X28.8003 Y2.3730 Z-3.0000 S1000
    G1 F1000 X28.8670 Y2.2822 Z-3.0000 S1000
    G1 F1000 X28.9374 Y2.1993 Z-3.0000 S1000
    G1 F1000 X29.7505 Y1.3047 Z-3.0000 S1000
    G1 F1000 X29.8292 Y1.2240 Z-3.0000 S1000
    G1 F1000 X29.9231 Y1.1412 Z-3.0000 S1000
    G1 F1000 X30.8369 Y0.3974 Z-3.0000 S1000
    G1 F1000 X30.9268 Y0.3294 Z-3.0000 S1000
    G1 F1000 X31.0379 Y0.2581 Z-3.0000 S1000
    G1 F1000 X32.0525 Y-0.3350 Z-3.0000 S1000
    G1 F1000 X32.1518 Y-0.3884 Z-3.0000 S1000
    G1 F1000 X32.2652 Y-0.4389 Z-3.0000 S1000
    G1 F1000 X33.4002 Y-0.8919 Z-3.0000 S1000
    G1 F1000 X33.5063 Y-0.9299 Z-3.0000 S1000
    G1 F1000 X33.5982 Y-0.9562 Z-3.0000 S1000
    G1 F1000 X34.8733 Y-1.2798 Z-3.0000 S1000
    G1 F1000 X34.9834 Y-1.3036 Z-3.0000 S1000
    G1 F1000 X35.1260 Y-1.3226 Z-3.0000 S1000
    G1 F1000 X38.0965 Y-1.5815 Z-3.0000 S1000
    G1 F1000 X38.2090 Y-1.5873 Z-3.0000 S1000
    G1 F1000 X38.3119 Y-1.5856 Z-3.0000 S1000
    G1 F1000 X39.8451 Y-1.5106 Z-3.0000 S1000
    G1 F1000 X39.9573 Y-1.5011 Z-3.0000 S1000
    G1 F1000 X40.0190 Y-1.4925 Z-3.0000 S1000
    G1 F1000 X41.4202 Y-1.2677 Z-3.0000 S1000
    G1 F1000 X41.5307 Y-1.2459 Z-3.0000 S1000
    G1 F1000 X41.6182 Y-1.2227 Z-3.0000 S1000
    G1 F1000 X42.8876 Y-0.8479 Z-3.0000 S1000
    G1 F1000 X42.9945 Y-0.8122 Z-3.0000 S1000
    G1 F1000 X43.1030 Y-0.7669 Z-3.0000 S1000
    G1 F1000 X44.2405 Y-0.2422 Z-3.0000 S1000
    G1 F1000 X44.3411 Y-0.1914 Z-3.0000 S1000
    G1 F1000 X44.4445 Y-0.1293 Z-3.0000 S1000
    G1 F1000 X45.4529 Y0.5302 Z-3.0000 S1000
    G1 F1000 X45.5450 Y0.5952 Z-3.0000 S1000
    G1 F1000 X45.6348 Y0.6688 Z-3.0000 S1000
    G1 F1000 X46.5171 Y1.4479 Z-3.0000 S1000
    G1 F1000 X46.5988 Y1.5255 Z-3.0000 S1000
    G1 F1000 X46.6809 Y1.6157 Z-3.0000 S1000
    G1 F1000 X47.4371 Y2.5143 Z-3.0000 S1000
    G1 F1000 X47.5066 Y2.6031 Z-3.0000 S1000
    G1 F1000 X47.5726 Y2.7014 Z-3.0000 S1000
    G1 F1000 X48.2025 Y3.7197 Z-3.0000 S1000
    G1 F1000 X48.2583 Y3.8175 Z-3.0000 S1000
    G1 F1000 X48.3108 Y3.9278 Z-3.0000 S1000
    G1 F1000 X48.8069 Y5.0817 Z-3.0000 S1000
    G1 F1000 X48.8477 Y5.1867 Z-3.0000 S1000
    G1 F1000 X48.8806 Y5.2929 Z-3.0000 S1000
    G1 F1000 X49.2349 Y6.5983 Z-3.0000 S1000
    G1 F1000 X49.2605 Y6.7080 Z-3.0000 S1000
    G1 F1000 X49.2737 Y6.7849 Z-3.0000 S1000
    G1 F1000 X49.4863 Y8.2419 Z-3.0000 S1000
    G1 F1000 X49.5014 Y8.4013 Z-3.0000 S1000
    G1 F1000 X49.5722 Y10.0098 Z-3.0000 S1000
    G1 F1000 X49.5731 Y10.1225 Z-3.0000 S1000
    G1 F1000 X49.5694 Y10.1968 Z-3.0000 S1000
    G1 F1000 X49.4072 Y12.3878 Z-3.0000 S1000
    G1 F1000 X49.3949 Y12.4998 Z-3.0000 S1000
    G1 F1000 X49.3635 Y12.6582 Z-3.0000 S1000
    G1 F1000 X48.8769 Y14.5911 Z-3.0000 S1000
    G1 F1000 X48.8455 Y14.6993 Z-3.0000 S1000
    G1 F1000 X48.8065 Y14.8050 Z-3.0000 S1000
    G1 F1000 X48.7662 Y14.8953 Z-3.0000 S1000
    G1 F1000 X47.9552 Y16.5702 Z-3.0000 S1000
    G1 F1000 X47.9025 Y16.6699 Z-3.0000 S1000
    G1 F1000 X47.8429 Y16.7655 Z-3.0000 S1000
    G1 F1000 X47.7652 Y16.8711 Z-3.0000 S1000
    G1 F1000 X46.6298 Y18.2879 Z-3.0000 S1000
    G1 F1000 X46.5563 Y18.3733 Z-3.0000 S1000
    G1 F1000 X46.4768 Y18.4533 Z-3.0000 S1000
    G1 F1000 X46.3713 Y18.5438 Z-3.0000 S1000
    G1 F1000 X44.9360 Y19.6707 Z-3.0000 S1000
    G1 F1000 X44.8450 Y19.7371 Z-3.0000 S1000
    G1 F1000 X44.7495 Y19.7969 Z-3.0000 S1000
    G1 F1000 X44.6316 Y19.8585 Z-3.0000 S1000
    G1 F1000 X42.9211 Y20.6633 Z-3.0000 S1000
    G1 F1000 X42.8175 Y20.7077 Z-3.0000 S1000
    G1 F1000 X42.7110 Y20.7445 Z-3.0000 S1000
    G1 F1000 X42.6204 Y20.7694 Z-3.0000 S1000
    G1 F1000 X40.6346 Y21.2524 Z-3.0000 S1000
    G1 F1000 X40.5242 Y21.2752 Z-3.0000 S1000
    G1 F1000 X40.3721 Y21.2934 Z-3.0000 S1000
    G1 F1000 X38.1111 Y21.4543 Z-3.0000 S1000
    G1 F1000 X37.9985 Y21.4583 Z-3.0000 S1000
    G1 F1000 X37.8811 Y21.4540 Z-3.0000 S1000
    G1 F1000 X35.6700 Y21.2902 Z-3.0000 S1000
    G1 F1000 X35.5580 Y21.2779 Z-3.0000 S1000
    G1 F1000 X35.4000 Y21.2465 Z-3.0000 S1000
    G1 F1000 X33.4462 Y20.7550 Z-3.0000 S1000
    G1 F1000 X33.3380 Y20.7237 Z-3.0000 S1000
    G1 F1000 X33.2323 Y20.6847 Z-3.0000 S1000
    G1 F1000 X33.1432 Y20.6450 Z-3.0000 S1000
    G1 F1000 X31.4466 Y19.8257 Z-3.0000 S1000
    G1 F1000 X31.3469 Y19.7732 Z-3.0000 S1000
    G1 F1000 X31.2512 Y19.7137 Z-3.0000 S1000
    G1 F1000 X31.1476 Y19.6377 Z-3.0000 S1000
    G1 F1000 X29.7083 Y18.4908 Z-3.0000 S1000
    G1 F1000 X29.6227 Y18.4175 Z-3.0000 S1000
    G1 F1000 X29.5426 Y18.3383 Z-3.0000 S1000
    G1 F1000 X29.4555 Y18.2379 Z-3.0000 S1000
    G1 F1000 X28.3086 Y16.7970 Z-3.0000 S1000
    G1 F1000 X28.2416 Y16.7064 Z-3.0000 S1000
    G1 F1000 X28.1812 Y16.6113 Z-3.0000 S1000
    G1 F1000 X28.1204 Y16.4971 Z-3.0000 S1000
    G1 F1000 X27.5986 Y15.4134 Z-3.0000 S1000
    G1 F1000 X28.4336 Y19.2014 Z-3.0000 S1000
    G1 F1000 X28.4539 Y19.3122 Z-3.0000 S1000
    G1 F1000 X28.4663 Y19.4242 Z-3.0000 S1000
    G1 F1000 X28.4708 Y19.5368 Z-3.0000 S1000
    G1 F1000 X28.4672 Y19.6494 Z-3.0000 S1000
    G1 F1000 X28.4557 Y19.7615 Z-3.0000 S1000
    G1 F1000 X28.4363 Y19.8725 Z-3.0000 S1000
    G1 F1000 X28.4090 Y19.9818 Z-3.0000 S1000
    G1 F1000 X28.3740 Y20.0889 Z-3.0000 S1000
    G1 F1000 X28.3316 Y20.1933 Z-3.0000 S1000
    G1 F1000 X28.2818 Y20.2944 Z-3.0000 S1000
    G1 F1000 X28.2250 Y20.3917 Z-3.0000 S1000
    G1 F1000 X28.1614 Y20.4847 Z-3.0000 S1000
    G1 F1000 X28.0914 Y20.5730 Z-3.0000 S1000
    G1 F1000 X28.0153 Y20.6561 Z-3.0000 S1000
    G1 F1000 X27.9335 Y20.7336 Z-3.0000 S1000
    G1 F1000 X27.8464 Y20.8051 Z-3.0000 S1000
    G1 F1000 X27.7545 Y20.8702 Z-3.0000 S1000
    G1 F1000 X27.6581 Y20.9287 Z-3.0000 S1000
    G1 F1000 X27.5579 Y20.9801 Z-3.0000 S1000
    G1 F1000 X27.4543 Y21.0244 Z-3.0000 S1000
    G1 F1000 X27.3478 Y21.0611 Z-3.0000 S1000
    G1 F1000 X27.2389 Y21.0903 Z-3.0000 S1000
    G1 F1000 X27.1283 Y21.1116 Z-3.0000 S1000
    G1 F1000 X27.0164 Y21.1250 Z-3.0000 S1000
    G1 F1000 X26.8833 Y21.1306 Z-3.0000 S1000
    G1 F1000 X21.2729 Y21.1306 Z-3.0000 S1000
    G1 F1000 X21.1603 Y21.1266 Z-3.0000 S1000
    G1 F1000 X21.0483 Y21.1146 Z-3.0000 S1000
    G1 F1000 X20.9373 Y21.0947 Z-3.0000 S1000
    G1 F1000 X20.8281 Y21.0670 Z-3.0000 S1000
    G1 F1000 X20.7212 Y21.0316 Z-3.0000 S1000
    G1 F1000 X20.6170 Y20.9887 Z-3.0000 S1000
    G1 F1000 X20.5161 Y20.9386 Z-3.0000 S1000
    G1 F1000 X20.4190 Y20.8814 Z-3.0000 S1000
    G1 F1000 X20.3262 Y20.8174 Z-3.0000 S1000
    G1 F1000 X20.2382 Y20.7471 Z-3.0000 S1000
    G1 F1000 X20.1554 Y20.6707 Z-3.0000 S1000
    G1 F1000 X20.0782 Y20.5885 Z-3.0000 S1000
    G1 F1000 X20.0071 Y20.5012 Z-3.0000 S1000
    G1 F1000 X19.9423 Y20.4090 Z-3.0000 S1000
    G1 F1000 X19.8843 Y20.3124 Z-3.0000 S1000
    G1 F1000 X19.8332 Y20.2120 Z-3.0000 S1000
    G1 F1000 X19.7894 Y20.1082 Z-3.0000 S1000
    G1 F1000 X19.7530 Y20.0015 Z-3.0000 S1000
    G1 F1000 X19.7131 Y19.8382 Z-3.0000 S1000
    G1 F1000 X18.9480 Y15.7948 Z-3.0000 S1000
    G1 F1000 X17.7910 Y19.9673 Z-3.0000 S1000
    G1 F1000 X17.7570 Y20.0747 Z-3.0000 S1000
    G1 F1000 X17.7156 Y20.1795 Z-3.0000 S1000
    G1 F1000 X17.6667 Y20.2811 Z-3.0000 S1000
    G1 F1000 X17.6109 Y20.3789 Z-3.0000 S1000
    G1 F1000 X17.5482 Y20.4725 Z-3.0000 S1000
    G1 F1000 X17.4790 Y20.5615 Z-3.0000 S1000
    G1 F1000 X17.4037 Y20.6453 Z-3.0000 S1000
    G1 F1000 X17.3226 Y20.7236 Z-3.0000 S1000
    G1 F1000 X17.2362 Y20.7959 Z-3.0000 S1000
    G1 F1000 X17.1449 Y20.8619 Z-3.0000 S1000
    G1 F1000 X17.0491 Y20.9213 Z-3.0000 S1000
    G1 F1000 X16.9494 Y20.9737 Z-3.0000 S1000
    G1 F1000 X16.8462 Y21.0189 Z-3.0000 S1000
    G1 F1000 X16.7400 Y21.0567 Z-3.0000 S1000
    G1 F1000 X16.6315 Y21.0868 Z-3.0000 S1000
    G1 F1000 X16.5210 Y21.1092 Z-3.0000 S1000
    G1 F1000 X16.4093 Y21.1237 Z-3.0000 S1000
    G1 F1000 X16.2612 Y21.1306 Z-3.0000 S1000
    G1 F1000 X10.6418 Y21.1306 Z-3.0000 S1000
    G1 F1000 X10.5292 Y21.1266 Z-3.0000 S1000
    G1 F1000 X10.4172 Y21.1146 Z-3.0000 S1000
    G1 F1000 X10.3062 Y21.0947 Z-3.0000 S1000
    G1 F1000 X10.1970 Y21.0670 Z-3.0000 S1000
    G1 F1000 X10.0901 Y21.0316 Z-3.0000 S1000
    G1 F1000 X9.9859 Y20.9887 Z-3.0000 S1000
    G1 F1000 X9.8850 Y20.9386 Z-3.0000 S1000
    G1 F1000 X9.7879 Y20.8814 Z-3.0000 S1000
    G1 F1000 X9.6951 Y20.8174 Z-3.0000 S1000
    G1 F1000 X9.6071 Y20.7471 Z-3.0000 S1000
    G1 F1000 X9.5243 Y20.6707 Z-3.0000 S1000
    G1 F1000 X9.4471 Y20.5885 Z-3.0000 S1000
    G1 F1000 X9.3760 Y20.5012 Z-3.0000 S1000
    G1 F1000 X9.3112 Y20.4090 Z-3.0000 S1000
    G1 F1000 X9.2532 Y20.3124 Z-3.0000 S1000
    G1 F1000 X9.2021 Y20.2120 Z-3.0000 S1000
    G1 F1000 X9.1583 Y20.1082 Z-3.0000 S1000
    G1 F1000 X9.1116 Y19.9658 Z-3.0000 S1000
    G1 F1000 X7.9614 Y15.8021 Z-3.0000 S1000
    G1 F1000 X7.1997 Y19.8375 Z-3.0000 S1000
    G1 F1000 X7.1748 Y19.9474 Z-3.0000 S1000
    G1 F1000 X7.1423 Y20.0553 Z-3.0000 S1000
    G1 F1000 X7.1022 Y20.1606 Z-3.0000 S1000
    G1 F1000 X7.0547 Y20.2628 Z-3.0000 S1000
    G1 F1000 X7.0001 Y20.3614 Z-3.0000 S1000
    G1 F1000 X6.9386 Y20.4558 Z-3.0000 S1000
    G1 F1000 X6.8706 Y20.5456 Z-3.0000 S1000
    G1 F1000 X6.7964 Y20.6304 Z-3.0000 S1000
    G1 F1000 X6.7163 Y20.7097 Z-3.0000 S1000
    G1 F1000 X6.6309 Y20.7831 Z-3.0000 S1000
    G1 F1000 X6.5404 Y20.8503 Z-3.0000 S1000
    G1 F1000 X6.4454 Y20.9109 Z-3.0000 S1000
    G1 F1000 X6.3464 Y20.9646 Z-3.0000 S1000
    G1 F1000 X6.2438 Y21.0112 Z-3.0000 S1000
    G1 F1000 X6.1381 Y21.0503 Z-3.0000 S1000
    G1 F1000 X6.0299 Y21.0819 Z-3.0000 S1000
    G1 F1000 X5.9198 Y21.1057 Z-3.0000 S1000
    G1 F1000 X5.8083 Y21.1216 Z-3.0000 S1000
    G1 F1000 X5.6397 Y21.1306 Z-3.0000 S1000
    G1 F1000 X0.0000 Y21.1306 Z-3.0000 S1000
    G1 F1000 X-0.1126 Y21.1266 Z-3.0000 S1000
    G1 F1000 X-0.2246 Y21.1146 Z-3.0000 S1000
    G1 F1000 X-0.3356 Y21.0947 Z-3.0000 S1000
    G1 F1000 X-0.4448 Y21.0670 Z-3.0000 S1000
    G1 F1000 X-0.5517 Y21.0316 Z-3.0000 S1000
    G1 F1000 X-0.6559 Y20.9887 Z-3.0000 S1000
    G1 F1000 X-0.7568 Y20.9386 Z-3.0000 S1000
    G1 F1000 X-0.8539 Y20.8814 Z-3.0000 S1000
    G1 F1000 X-0.9467 Y20.8174 Z-3.0000 S1000
    G1 F1000 X-1.0347 Y20.7471 Z-3.0000 S1000
    G1 F1000 X-1.1175 Y20.6707 Z-3.0000 S1000
    G1 F1000 X-1.1947 Y20.5885 Z-3.0000 S1000
    G1 F1000 X-1.2658 Y20.5012 Z-3.0000 S1000
    G1 F1000 X-1.3306 Y20.4090 Z-3.0000 S1000
    G1 F1000 X-1.3886 Y20.3124 Z-3.0000 S1000
    G1 F1000 X-1.4397 Y20.2120 Z-3.0000 S1000
    G1 F1000 X-1.4835 Y20.1082 Z-3.0000 S1000
    G1 F1000 X-1.5199 Y20.0015 Z-3.0000 S1000
    G1 F1000 X-1.5486 Y19.8925 Z-3.0000 S1000
    G1 F1000 X-1.5694 Y19.7818 Z-3.0000 S1000
    G1 F1000 X-1.5824 Y19.6699 Z-3.0000 S1000
    G1 F1000 X-1.5874 Y19.5573 Z-3.0000 S1000
    G1 F1000 X-1.5844 Y19.4447 Z-3.0000 S1000
    G1 F1000 X-1.5735 Y19.3326 Z-3.0000 S1000
    G1 F1000 X-1.5496 Y19.1983 Z-3.0000 S1000
    G0 Z7
    G0 X49.6756 Y19.5431
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X49.6756 Y0.3277 Z-3.0000 S1000
    G1 F1000 X49.6796 Y0.2151 Z-3.0000 S1000
    G1 F1000 X49.6916 Y0.1031 Z-3.0000 S1000
    G1 F1000 X49.7115 Y-0.0079 Z-3.0000 S1000
    G1 F1000 X49.7392 Y-0.1171 Z-3.0000 S1000
    G1 F1000 X49.7746 Y-0.2240 Z-3.0000 S1000
    G1 F1000 X49.8175 Y-0.3282 Z-3.0000 S1000
    G1 F1000 X49.8676 Y-0.4291 Z-3.0000 S1000
    G1 F1000 X49.9248 Y-0.5262 Z-3.0000 S1000
    G1 F1000 X49.9888 Y-0.6190 Z-3.0000 S1000
    G1 F1000 X50.0591 Y-0.7070 Z-3.0000 S1000
    G1 F1000 X50.1355 Y-0.7898 Z-3.0000 S1000
    G1 F1000 X50.2177 Y-0.8670 Z-3.0000 S1000
    G1 F1000 X50.3050 Y-0.9381 Z-3.0000 S1000
    G1 F1000 X50.3972 Y-1.0029 Z-3.0000 S1000
    G1 F1000 X50.4938 Y-1.0609 Z-3.0000 S1000
    G1 F1000 X50.5942 Y-1.1120 Z-3.0000 S1000
    G1 F1000 X50.6980 Y-1.1558 Z-3.0000 S1000
    G1 F1000 X50.8047 Y-1.1922 Z-3.0000 S1000
    G1 F1000 X50.9137 Y-1.2209 Z-3.0000 S1000
    G1 F1000 X51.0244 Y-1.2417 Z-3.0000 S1000
    G1 F1000 X51.1363 Y-1.2547 Z-3.0000 S1000
    G1 F1000 X51.2631 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X57.2269 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X57.3395 Y-1.2558 Z-3.0000 S1000
    G1 F1000 X57.4515 Y-1.2438 Z-3.0000 S1000
    G1 F1000 X57.5625 Y-1.2239 Z-3.0000 S1000
    G1 F1000 X57.6717 Y-1.1962 Z-3.0000 S1000
    G1 F1000 X57.7786 Y-1.1608 Z-3.0000 S1000
    G1 F1000 X57.8828 Y-1.1179 Z-3.0000 S1000
    G1 F1000 X57.9837 Y-1.0678 Z-3.0000 S1000
    G1 F1000 X58.0808 Y-1.0106 Z-3.0000 S1000
    G1 F1000 X58.1736 Y-0.9466 Z-3.0000 S1000
    G1 F1000 X58.2616 Y-0.8763 Z-3.0000 S1000
    G1 F1000 X58.3444 Y-0.7999 Z-3.0000 S1000
    G1 F1000 X58.4216 Y-0.7177 Z-3.0000 S1000
    G1 F1000 X58.4927 Y-0.6304 Z-3.0000 S1000
    G1 F1000 X58.5575 Y-0.5382 Z-3.0000 S1000
    G1 F1000 X58.6155 Y-0.4416 Z-3.0000 S1000
    G1 F1000 X58.6666 Y-0.3412 Z-3.0000 S1000
    G1 F1000 X58.7104 Y-0.2374 Z-3.0000 S1000
    G1 F1000 X58.7468 Y-0.1307 Z-3.0000 S1000
    G1 F1000 X58.7755 Y-0.0217 Z-3.0000 S1000
    G1 F1000 X58.7963 Y0.0890 Z-3.0000 S1000
    G1 F1000 X58.8093 Y0.2009 Z-3.0000 S1000
    G1 F1000 X58.8144 Y0.3277 Z-3.0000 S1000
    G1 F1000 X58.8144 Y5.5568 Z-3.0000 S1000
    G1 F1000 X58.9029 Y5.4108 Z-3.0000 S1000
    G1 F1000 X62.0582 Y-0.4271 Z-3.0000 S1000
    G1 F1000 X62.1153 Y-0.5243 Z-3.0000 S1000
    G1 F1000 X62.1791 Y-0.6172 Z-3.0000 S1000
    G1 F1000 X62.2493 Y-0.7053 Z-3.0000 S1000
    G1 F1000 X62.3256 Y-0.7882 Z-3.0000 S1000
    G1 F1000 X62.4076 Y-0.8655 Z-3.0000 S1000
    G1 F1000 X62.4949 Y-0.9367 Z-3.0000 S1000
    G1 F1000 X62.5870 Y-1.0016 Z-3.0000 S1000
    G1 F1000 X62.6835 Y-1.0598 Z-3.0000 S1000
    G1 F1000 X62.7839 Y-1.1110 Z-3.0000 S1000
    G1 F1000 X62.8876 Y-1.1550 Z-3.0000 S1000
    G1 F1000 X62.9942 Y-1.1915 Z-3.0000 S1000
    G1 F1000 X63.1031 Y-1.2204 Z-3.0000 S1000
    G1 F1000 X63.2138 Y-1.2414 Z-3.0000 S1000
    G1 F1000 X63.3257 Y-1.2545 Z-3.0000 S1000
    G1 F1000 X63.4548 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X70.1640 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X70.2766 Y-1.2558 Z-3.0000 S1000
    G1 F1000 X70.3886 Y-1.2438 Z-3.0000 S1000
    G1 F1000 X70.4996 Y-1.2239 Z-3.0000 S1000
    G1 F1000 X70.6088 Y-1.1962 Z-3.0000 S1000
    G1 F1000 X70.7157 Y-1.1608 Z-3.0000 S1000
    G1 F1000 X70.8199 Y-1.1179 Z-3.0000 S1000
    G1 F1000 X70.9208 Y-1.0678 Z-3.0000 S1000
    G1 F1000 X71.0179 Y-1.0106 Z-3.0000 S1000
    G1 F1000 X71.1107 Y-0.9466 Z-3.0000 S1000
    G1 F1000 X71.1143 Y-0.9437 Z-3.0000 S1000
    G1 F1000 X71.1986 Y-1.0029 Z-3.0000 S1000
    G1 F1000 X71.2952 Y-1.0609 Z-3.0000 S1000
    G1 F1000 X71.3956 Y-1.1120 Z-3.0000 S1000
    G1 F1000 X71.4994 Y-1.1558 Z-3.0000 S1000
    G1 F1000 X71.6061 Y-1.1922 Z-3.0000 S1000
    G1 F1000 X71.7151 Y-1.2209 Z-3.0000 S1000
    G1 F1000 X71.8258 Y-1.2417 Z-3.0000 S1000
    G1 F1000 X71.9377 Y-1.2547 Z-3.0000 S1000
    G1 F1000 X72.0645 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X87.2691 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X87.3817 Y-1.2558 Z-3.0000 S1000
    G1 F1000 X87.4937 Y-1.2438 Z-3.0000 S1000
    G1 F1000 X87.6047 Y-1.2239 Z-3.0000 S1000
    G1 F1000 X87.7139 Y-1.1962 Z-3.0000 S1000
    G1 F1000 X87.8208 Y-1.1608 Z-3.0000 S1000
    G1 F1000 X87.9250 Y-1.1179 Z-3.0000 S1000
    G1 F1000 X88.0259 Y-1.0678 Z-3.0000 S1000
    G1 F1000 X88.1230 Y-1.0106 Z-3.0000 S1000
    G1 F1000 X88.2158 Y-0.9466 Z-3.0000 S1000
    G1 F1000 X88.3038 Y-0.8763 Z-3.0000 S1000
    G1 F1000 X88.3866 Y-0.7999 Z-3.0000 S1000
    G1 F1000 X88.4638 Y-0.7177 Z-3.0000 S1000
    G1 F1000 X88.5349 Y-0.6304 Z-3.0000 S1000
    G1 F1000 X88.5997 Y-0.5382 Z-3.0000 S1000
    G1 F1000 X88.6577 Y-0.4416 Z-3.0000 S1000
    G1 F1000 X88.6587 Y-0.4397 Z-3.0000 S1000
    G1 F1000 X88.7096 Y-0.5262 Z-3.0000 S1000
    G1 F1000 X88.7736 Y-0.6190 Z-3.0000 S1000
    G1 F1000 X88.8439 Y-0.7070 Z-3.0000 S1000
    G1 F1000 X88.9203 Y-0.7898 Z-3.0000 S1000
    G1 F1000 X89.0025 Y-0.8670 Z-3.0000 S1000
    G1 F1000 X89.0898 Y-0.9381 Z-3.0000 S1000
    G1 F1000 X89.1820 Y-1.0029 Z-3.0000 S1000
    G1 F1000 X89.2786 Y-1.0609 Z-3.0000 S1000
    G1 F1000 X89.3790 Y-1.1120 Z-3.0000 S1000
    G1 F1000 X89.4828 Y-1.1558 Z-3.0000 S1000
    G1 F1000 X89.5895 Y-1.1922 Z-3.0000 S1000
    G1 F1000 X89.6985 Y-1.2209 Z-3.0000 S1000
    G1 F1000 X89.8092 Y-1.2417 Z-3.0000 S1000
    G1 F1000 X89.9211 Y-1.2547 Z-3.0000 S1000
    G1 F1000 X90.0479 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X98.8692 Y-1.2598 Z-3.0000 S1000
    G1 F1000 X98.9929 Y-1.2550 Z-3.0000 S1000
    G1 F1000 X100.6706 Y-1.1239 Z-3.0000 S1000
    G1 F1000 X100.7825 Y-1.1111 Z-3.0000 S1000
    G1 F1000 X100.8750 Y-1.0944 Z-3.0000 S1000
    G1 F1000 X102.7363 Y-0.7012 Z-3.0000 S1000
    G1 F1000 X102.8457 Y-0.6740 Z-3.0000 S1000
    G1 F1000 X102.9528 Y-0.6392 Z-3.0000 S1000
    G1 F1000 X103.0148 Y-0.6150 Z-3.0000 S1000
    G1 F1000 X104.3976 Y-0.0432 Z-3.0000 S1000
    G1 F1000 X104.5002 Y0.0035 Z-3.0000 S1000
    G1 F1000 X104.5991 Y0.0574 Z-3.0000 S1000
    G1 F1000 X104.7352 Y0.1476 Z-3.0000 S1000
    G1 F1000 X106.0263 Y1.1028 Z-3.0000 S1000
    G1 F1000 X106.1144 Y1.1730 Z-3.0000 S1000
    G1 F1000 X106.1974 Y1.2493 Z-3.0000 S1000
    G1 F1000 X106.2836 Y1.3415 Z-3.0000 S1000
    G1 F1000 X107.3928 Y2.6260 Z-3.0000 S1000
    G1 F1000 X107.4634 Y2.7138 Z-3.0000 S1000
    G1 F1000 X107.5276 Y2.8064 Z-3.0000 S1000
    G1 F1000 X107.5901 Y2.9127 Z-3.0000 S1000
    G1 F1000 X108.4273 Y4.4725 Z-3.0000 S1000
    G1 F1000 X108.4770 Y4.5736 Z-3.0000 S1000
    G1 F1000 X108.5194 Y4.6780 Z-3.0000 S1000
    G1 F1000 X108.5659 Y4.8275 Z-3.0000 S1000
    G1 F1000 X109.0919 Y6.8706 Z-3.0000 S1000
    G1 F1000 X109.1161 Y6.9806 Z-3.0000 S1000
    G1 F1000 X109.1324 Y7.0921 Z-3.0000 S1000
    G1 F1000 X109.1387 Y7.1648 Z-3.0000 S1000
    G1 F1000 X109.3140 Y9.8994 Z-3.0000 S1000
    G1 F1000 X109.3173 Y10.0121 Z-3.0000 S1000
    G1 F1000 X109.3143 Y10.0987 Z-3.0000 S1000
    G1 F1000 X109.1963 Y12.0123 Z-3.0000 S1000
    G1 F1000 X109.1854 Y12.1245 Z-3.0000 S1000
    G1 F1000 X109.1698 Y12.2194 Z-3.0000 S1000
    G1 F1000 X108.8159 Y14.0283 Z-3.0000 S1000
    G1 F1000 X108.7903 Y14.1380 Z-3.0000 S1000
    G1 F1000 X108.7449 Y14.2793 Z-3.0000 S1000
    G1 F1000 X108.1289 Y15.9275 Z-3.0000 S1000
    G1 F1000 X108.0858 Y16.0315 Z-3.0000 S1000
    G1 F1000 X108.0353 Y16.1323 Z-3.0000 S1000
    G1 F1000 X107.9841 Y16.2194 Z-3.0000 S1000
    G1 F1000 X107.0797 Y17.6514 Z-3.0000 S1000
    G1 F1000 X107.0162 Y17.7445 Z-3.0000 S1000
    G1 F1000 X106.9463 Y17.8328 Z-3.0000 S1000
    G1 F1000 X106.8514 Y17.9348 Z-3.0000 S1000
    G1 F1000 X105.6635 Y19.1046 Z-3.0000 S1000
    G1 F1000 X105.5804 Y19.1808 Z-3.0000 S1000
    G1 F1000 X105.4922 Y19.2509 Z-3.0000 S1000
    G1 F1000 X105.3539 Y19.3421 Z-3.0000 S1000
    G1 F1000 X103.8875 Y20.2039 Z-3.0000 S1000
    G1 F1000 X103.7884 Y20.2575 Z-3.0000 S1000
    G1 F1000 X103.6858 Y20.3040 Z-3.0000 S1000
    G1 F1000 X103.5801 Y20.3430 Z-3.0000 S1000
    G1 F1000 X103.5197 Y20.3616 Z-3.0000 S1000
    G1 F1000 X101.6634 Y20.8925 Z-3.0000 S1000
    G1 F1000 X101.5541 Y20.9196 Z-3.0000 S1000
    G1 F1000 X101.4430 Y20.9389 Z-3.0000 S1000
    G1 F1000 X101.3457 Y20.9493 Z-3.0000 S1000
    G1 F1000 X98.9880 Y21.1262 Z-3.0000 S1000
    G1 F1000 X98.8692 Y21.1306 Z-3.0000 S1000
    G1 F1000 X90.0479 Y21.1306 Z-3.0000 S1000
    G1 F1000 X89.9353 Y21.1266 Z-3.0000 S1000
    G1 F1000 X89.8233 Y21.1146 Z-3.0000 S1000
    G1 F1000 X89.7123 Y21.0947 Z-3.0000 S1000
    G1 F1000 X89.6031 Y21.0670 Z-3.0000 S1000
    G1 F1000 X89.4962 Y21.0316 Z-3.0000 S1000
    G1 F1000 X89.3920 Y20.9887 Z-3.0000 S1000
    G1 F1000 X89.2911 Y20.9386 Z-3.0000 S1000
    G1 F1000 X89.1940 Y20.8814 Z-3.0000 S1000
    G1 F1000 X89.1012 Y20.8174 Z-3.0000 S1000
    G1 F1000 X89.0132 Y20.7471 Z-3.0000 S1000
    G1 F1000 X88.9304 Y20.6707 Z-3.0000 S1000
    G1 F1000 X88.8532 Y20.5885 Z-3.0000 S1000
    G1 F1000 X88.7821 Y20.5012 Z-3.0000 S1000
    G1 F1000 X88.7173 Y20.4090 Z-3.0000 S1000
    G1 F1000 X88.6593 Y20.3124 Z-3.0000 S1000
    G1 F1000 X88.6082 Y20.2120 Z-3.0000 S1000
    G1 F1000 X88.5644 Y20.1082 Z-3.0000 S1000
    G1 F1000 X88.5280 Y20.0015 Z-3.0000 S1000
    G1 F1000 X88.4993 Y19.8925 Z-3.0000 S1000
    G1 F1000 X88.4785 Y19.7818 Z-3.0000 S1000
    G1 F1000 X88.4655 Y19.6699 Z-3.0000 S1000
    G1 F1000 X88.4604 Y19.5431 Z-3.0000 S1000
    G1 F1000 X88.4604 Y6.1080 Z-3.0000 S1000
    G1 F1000 X88.3967 Y6.1770 Z-3.0000 S1000
    G1 F1000 X88.3145 Y6.2542 Z-3.0000 S1000
    G1 F1000 X88.2272 Y6.3253 Z-3.0000 S1000
    G1 F1000 X88.1350 Y6.3901 Z-3.0000 S1000
    G1 F1000 X88.0384 Y6.4481 Z-3.0000 S1000
    G1 F1000 X87.9380 Y6.4992 Z-3.0000 S1000
    G1 F1000 X87.8342 Y6.5430 Z-3.0000 S1000
    G1 F1000 X87.7275 Y6.5794 Z-3.0000 S1000
    G1 F1000 X87.6185 Y6.6081 Z-3.0000 S1000
    G1 F1000 X87.5078 Y6.6289 Z-3.0000 S1000
    G1 F1000 X87.3959 Y6.6419 Z-3.0000 S1000
    G1 F1000 X87.2691 Y6.6470 Z-3.0000 S1000
    G1 F1000 X79.5897 Y6.6470 Z-3.0000 S1000
    G1 F1000 X79.5897 Y19.5431 Z-3.0000 S1000
    G1 F1000 X79.5857 Y19.6557 Z-3.0000 S1000
    G1 F1000 X79.5737 Y19.7677 Z-3.0000 S1000
    G1 F1000 X79.5538 Y19.8787 Z-3.0000 S1000
    G1 F1000 X79.5261 Y19.9879 Z-3.0000 S1000
    G1 F1000 X79.4907 Y20.0948 Z-3.0000 S1000
    G1 F1000 X79.4478 Y20.1990 Z-3.0000 S1000
    G1 F1000 X79.3977 Y20.2999 Z-3.0000 S1000
    G1 F1000 X79.3405 Y20.3970 Z-3.0000 S1000
    G1 F1000 X79.2765 Y20.4898 Z-3.0000 S1000
    G1 F1000 X79.2062 Y20.5778 Z-3.0000 S1000
    G1 F1000 X79.1298 Y20.6606 Z-3.0000 S1000
    G1 F1000 X79.0476 Y20.7378 Z-3.0000 S1000
    G1 F1000 X78.9603 Y20.8089 Z-3.0000 S1000
    G1 F1000 X78.8681 Y20.8737 Z-3.0000 S1000
    G1 F1000 X78.7715 Y20.9317 Z-3.0000 S1000
    G1 F1000 X78.6711 Y20.9828 Z-3.0000 S1000
    G1 F1000 X78.5673 Y21.0266 Z-3.0000 S1000
    G1 F1000 X78.4606 Y21.0630 Z-3.0000 S1000
    G1 F1000 X78.3516 Y21.0917 Z-3.0000 S1000
    G1 F1000 X78.2409 Y21.1125 Z-3.0000 S1000
    G1 F1000 X78.1290 Y21.1255 Z-3.0000 S1000
    G1 F1000 X78.0022 Y21.1306 Z-3.0000 S1000
    G1 F1000 X72.0645 Y21.1306 Z-3.0000 S1000
    G1 F1000 X71.9519 Y21.1266 Z-3.0000 S1000
    G1 F1000 X71.8399 Y21.1146 Z-3.0000 S1000
    G1 F1000 X71.7289 Y21.0947 Z-3.0000 S1000
    G1 F1000 X71.6197 Y21.0670 Z-3.0000 S1000
    G1 F1000 X71.5128 Y21.0316 Z-3.0000 S1000
    G1 F1000 X71.4086 Y20.9887 Z-3.0000 S1000
    G1 F1000 X71.3077 Y20.9386 Z-3.0000 S1000
    G1 F1000 X71.2106 Y20.8814 Z-3.0000 S1000
    G1 F1000 X71.1178 Y20.8174 Z-3.0000 S1000
    G1 F1000 X71.0298 Y20.7471 Z-3.0000 S1000
    G1 F1000 X70.9470 Y20.6707 Z-3.0000 S1000
    G1 F1000 X70.8698 Y20.5885 Z-3.0000 S1000
    G1 F1000 X70.7987 Y20.5012 Z-3.0000 S1000
    G1 F1000 X70.7339 Y20.4090 Z-3.0000 S1000
    G1 F1000 X70.6759 Y20.3124 Z-3.0000 S1000
    G1 F1000 X70.6248 Y20.2120 Z-3.0000 S1000
    G1 F1000 X70.5810 Y20.1082 Z-3.0000 S1000
    G1 F1000 X70.5446 Y20.0015 Z-3.0000 S1000
    G1 F1000 X70.5159 Y19.8925 Z-3.0000 S1000
    G1 F1000 X70.4951 Y19.7818 Z-3.0000 S1000
    G1 F1000 X70.4821 Y19.6699 Z-3.0000 S1000
    G1 F1000 X70.4770 Y19.5431 Z-3.0000 S1000
    G1 F1000 X70.4770 Y3.1813 Z-3.0000 S1000
    G1 F1000 X68.6990 Y6.6241 Z-3.0000 S1000
    G1 F1000 X68.6438 Y6.7224 Z-3.0000 S1000
    G1 F1000 X68.5911 Y6.8031 Z-3.0000 S1000
    G1 F1000 X67.7594 Y7.9970 Z-3.0000 S1000
    G1 F1000 X67.6917 Y8.0871 Z-3.0000 S1000
    G1 F1000 X67.6134 Y8.1770 Z-3.0000 S1000
    G1 F1000 X67.2880 Y8.5231 Z-3.0000 S1000
    G1 F1000 X68.0884 Y9.1471 Z-3.0000 S1000
    G1 F1000 X68.1747 Y9.2195 Z-3.0000 S1000
    G1 F1000 X68.2557 Y9.2979 Z-3.0000 S1000
    G1 F1000 X68.3310 Y9.3817 Z-3.0000 S1000
    G1 F1000 X68.3694 Y9.4296 Z-3.0000 S1000
    G1 F1000 X69.1793 Y10.4798 Z-3.0000 S1000
    G1 F1000 X69.2449 Y10.5715 Z-3.0000 S1000
    G1 F1000 X69.3038 Y10.6675 Z-3.0000 S1000
    G1 F1000 X69.3558 Y10.7675 Z-3.0000 S1000
    G1 F1000 X69.3947 Y10.8561 Z-3.0000 S1000
    G1 F1000 X69.9062 Y12.1259 Z-3.0000 S1000
    G1 F1000 X69.9446 Y12.2319 Z-3.0000 S1000
    G1 F1000 X69.9753 Y12.3403 Z-3.0000 S1000
    G1 F1000 X69.9983 Y12.4506 Z-3.0000 S1000
    G1 F1000 X70.0109 Y12.5385 Z-3.0000 S1000
    G1 F1000 X70.1814 Y14.0278 Z-3.0000 S1000
    G1 F1000 X70.1902 Y14.1402 Z-3.0000 S1000
    G1 F1000 X70.1911 Y14.2528 Z-3.0000 S1000
    G1 F1000 X70.1782 Y14.4152 Z-3.0000 S1000
    G1 F1000 X69.9554 Y16.1110 Z-3.0000 S1000
    G1 F1000 X69.9367 Y16.2221 Z-3.0000 S1000
    G1 F1000 X69.9103 Y16.3316 Z-3.0000 S1000
    G1 F1000 X69.8761 Y16.4390 Z-3.0000 S1000
    G1 F1000 X69.8172 Y16.5815 Z-3.0000 S1000
    G1 F1000 X69.1487 Y17.9987 Z-3.0000 S1000
    G1 F1000 X69.0970 Y18.0988 Z-3.0000 S1000
    G1 F1000 X69.0384 Y18.1950 Z-3.0000 S1000
    G1 F1000 X68.9731 Y18.2868 Z-3.0000 S1000
    G1 F1000 X68.9014 Y18.3738 Z-3.0000 S1000
    G1 F1000 X68.8588 Y18.4201 Z-3.0000 S1000
    G1 F1000 X67.8266 Y19.4966 Z-3.0000 S1000
    G1 F1000 X67.7457 Y19.5751 Z-3.0000 S1000
    G1 F1000 X67.6596 Y19.6477 Z-3.0000 S1000
    G1 F1000 X67.5684 Y19.7140 Z-3.0000 S1000
    G1 F1000 X67.4728 Y19.7736 Z-3.0000 S1000
    G1 F1000 X67.4047 Y19.8107 Z-3.0000 S1000
    G1 F1000 X66.0906 Y20.4841 Z-3.0000 S1000
    G1 F1000 X65.9885 Y20.5319 Z-3.0000 S1000
    G1 F1000 X65.8834 Y20.5723 Z-3.0000 S1000
    G1 F1000 X65.7756 Y20.6052 Z-3.0000 S1000
    G1 F1000 X65.6763 Y20.6283 Z-3.0000 S1000
    G1 F1000 X63.8970 Y20.9822 Z-3.0000 S1000
    G1 F1000 X63.7858 Y21.0002 Z-3.0000 S1000
    G1 F1000 X63.6643 Y21.0108 Z-3.0000 S1000
    G1 F1000 X61.2362 Y21.1287 Z-3.0000 S1000
    G1 F1000 X61.1592 Y21.1306 Z-3.0000 S1000
    G1 F1000 X51.2631 Y21.1306 Z-3.0000 S1000
    G1 F1000 X51.1505 Y21.1266 Z-3.0000 S1000
    G1 F1000 X51.0385 Y21.1146 Z-3.0000 S1000
    G1 F1000 X50.9275 Y21.0947 Z-3.0000 S1000
    G1 F1000 X50.8183 Y21.0670 Z-3.0000 S1000
    G1 F1000 X50.7114 Y21.0316 Z-3.0000 S1000
    G1 F1000 X50.6072 Y20.9887 Z-3.0000 S1000
    G1 F1000 X50.5063 Y20.9386 Z-3.0000 S1000
    G1 F1000 X50.4092 Y20.8814 Z-3.0000 S1000
    G1 F1000 X50.3164 Y20.8174 Z-3.0000 S1000
    G1 F1000 X50.2284 Y20.7471 Z-3.0000 S1000
    G1 F1000 X50.1456 Y20.6707 Z-3.0000 S1000
    G1 F1000 X50.0684 Y20.5885 Z-3.0000 S1000
    G1 F1000 X49.9973 Y20.5012 Z-3.0000 S1000
    G1 F1000 X49.9325 Y20.4090 Z-3.0000 S1000
    G1 F1000 X49.8745 Y20.3124 Z-3.0000 S1000
    G1 F1000 X49.8234 Y20.2120 Z-3.0000 S1000
    G1 F1000 X49.7796 Y20.1082 Z-3.0000 S1000
    G1 F1000 X49.7432 Y20.0015 Z-3.0000 S1000
    G1 F1000 X49.7145 Y19.8925 Z-3.0000 S1000
    G1 F1000 X49.6937 Y19.7818 Z-3.0000 S1000
    G1 F1000 X49.6807 Y19.6699 Z-3.0000 S1000
    G1 F1000 X49.6756 Y19.5431 Z-3.0000 S1000
    G0 Z7
    G0 X60.8788 Y13.5581
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X59.5991 Y13.3448 Z-3.0000 S1000
    G1 F1000 X58.8144 Y13.3448 Z-3.0000 S1000
    G1 F1000 X58.8144 Y14.0759 Z-3.0000 S1000
    G1 F1000 X59.7635 Y14.0759 Z-3.0000 S1000
    G1 F1000 X60.7994 Y13.9814 Z-3.0000 S1000
    G1 F1000 X60.9993 Y13.8935 Z-3.0000 S1000
    G1 F1000 X61.0305 Y13.7195 Z-3.0000 S1000
    G1 F1000 X61.0207 Y13.6573 Z-3.0000 S1000
    G1 F1000 X60.9952 Y13.6099 Z-3.0000 S1000
    G1 F1000 X60.9835 Y13.5991 Z-3.0000 S1000
    G1 F1000 X60.8788 Y13.5581 Z-3.0000 S1000
    G0 Z7
    G0 X40.4592 Y10.1505
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X40.4009 Y8.8286 Z-3.0000 S1000
    G1 F1000 X40.2386 Y7.8039 Z-3.0000 S1000
    G1 F1000 X40.0093 Y7.1085 Z-3.0000 S1000
    G1 F1000 X39.7579 Y6.6995 Z-3.0000 S1000
    G1 F1000 X39.4723 Y6.4306 Z-3.0000 S1000
    G1 F1000 X39.1117 Y6.2261 Z-3.0000 S1000
    G1 F1000 X38.6454 Y6.0891 Z-3.0000 S1000
    G1 F1000 X38.0411 Y6.0370 Z-3.0000 S1000
    G1 F1000 X37.4610 Y6.0893 Z-3.0000 S1000
    G1 F1000 X37.0080 Y6.2270 Z-3.0000 S1000
    G1 F1000 X36.6395 Y6.4402 Z-3.0000 S1000
    G1 F1000 X36.3265 Y6.7355 Z-3.0000 S1000
    G1 F1000 X36.0558 Y7.1578 Z-3.0000 S1000
    G1 F1000 X35.8239 Y7.8049 Z-3.0000 S1000
    G1 F1000 X35.6618 Y8.7223 Z-3.0000 S1000
    G1 F1000 X35.6031 Y9.8963 Z-3.0000 S1000
    G1 F1000 X35.6623 Y11.0820 Z-3.0000 S1000
    G1 F1000 X35.8255 Y12.0067 Z-3.0000 S1000
    G1 F1000 X36.0588 Y12.6573 Z-3.0000 S1000
    G1 F1000 X36.3324 Y13.0826 Z-3.0000 S1000
    G1 F1000 X36.6492 Y13.3822 Z-3.0000 S1000
    G1 F1000 X37.0132 Y13.5959 Z-3.0000 S1000
    G1 F1000 X37.4444 Y13.7302 Z-3.0000 S1000
    G1 F1000 X37.9895 Y13.7810 Z-3.0000 S1000
    G1 F1000 X38.5754 Y13.7294 Z-3.0000 S1000
    G1 F1000 X39.0412 Y13.5912 Z-3.0000 S1000
    G1 F1000 X39.4184 Y13.3784 Z-3.0000 S1000
    G1 F1000 X39.7398 Y13.0831 Z-3.0000 S1000
    G1 F1000 X40.0128 Y12.6740 Z-3.0000 S1000
    G1 F1000 X40.2412 Y12.0731 Z-3.0000 S1000
    G1 F1000 X40.4007 Y11.2320 Z-3.0000 S1000
    G1 F1000 X40.4592 Y10.1505 Z-3.0000 S1000
    G0 Z7
    G0 X97.5731 Y6.2919
    G0 Z0
    G1 F700 Z-3.0000
    G1 F1000 X97.5731 Y13.5935 Z-3.0000 S1000
    G1 F1000 X98.3045 Y13.5454 Z-3.0000 S1000
    G1 F1000 X98.9205 Y13.4020 Z-3.0000 S1000
    G1 F1000 X99.3208 Y13.2124 Z-3.0000 S1000
    G1 F1000 X99.5596 Y13.0094 Z-3.0000 S1000
    G1 F1000 X99.7626 Y12.6907 Z-3.0000 S1000
    G1 F1000 X99.9703 Y12.0737 Z-3.0000 S1000
    G1 F1000 X100.1217 Y11.1288 Z-3.0000 S1000
    G1 F1000 X100.1764 Y9.8918 Z-3.0000 S1000
    G1 F1000 X100.0778 Y8.1332 Z-3.0000 S1000
    G1 F1000 X99.8376 Y7.1638 Z-3.0000 S1000
    G1 F1000 X99.5759 Y6.7326 Z-3.0000 S1000
    G1 F1000 X99.3368 Y6.5393 Z-3.0000 S1000
    G1 F1000 X98.7549 Y6.3685 Z-3.0000 S1000
    G1 F1000 X97.5731 Y6.2919 Z-3.0000 S1000
    ; retracting back to z-safe
    G0 Z7
    ; Operation 2: CNC: Pocket
    ; Tool Diameter: 3.175
    G0 Z7
    G0 F1000 X33.9838 Y49.1596
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X36.3584 Y44.4989 Z-1.0000 S1000
    G1 F1000 X36.4802 Y44.2511 Z-1.0000 S1000
    G1 F1000 X36.5947 Y44.0000 Z-1.0000 S1000
    G1 F1000 X36.7018 Y43.7456 Z-1.0000 S1000
    G1 F1000 X36.8016 Y43.4882 Z-1.0000 S1000
    G1 F1000 X36.8939 Y43.2281 Z-1.0000 S1000
    G1 F1000 X36.9786 Y42.9653 Z-1.0000 S1000
    G1 F1000 X37.0556 Y42.7003 Z-1.0000 S1000
    G1 F1000 X37.1249 Y42.4331 Z-1.0000 S1000
    G1 F1000 X37.1865 Y42.1640 Z-1.0000 S1000
    G1 F1000 X37.2402 Y41.8932 Z-1.0000 S1000
    G1 F1000 X37.2861 Y41.6210 Z-1.0000 S1000
    G1 F1000 X37.2909 Y41.5865 Z-1.0000 S1000
    G1 F1000 X38.2222 Y43.5836 Z-1.0000 S1000
    G1 F1000 X37.2387 Y44.7983 Z-1.0000 S1000
    G1 F1000 X37.0681 Y45.0154 Z-1.0000 S1000
    G1 F1000 X36.9039 Y45.2373 Z-1.0000 S1000
    G1 F1000 X36.7462 Y45.4638 Z-1.0000 S1000
    G1 F1000 X36.5951 Y45.6948 Z-1.0000 S1000
    G1 F1000 X36.4508 Y45.9301 Z-1.0000 S1000
    G1 F1000 X36.3133 Y46.1695 Z-1.0000 S1000
    G1 F1000 X36.1544 Y46.4681 Z-1.0000 S1000
    G1 F1000 X35.1069 Y48.5241 Z-1.0000 S1000
    G1 F1000 X34.9852 Y48.7719 Z-1.0000 S1000
    G1 F1000 X34.8707 Y49.0230 Z-1.0000 S1000
    G1 F1000 X34.7635 Y49.2774 Z-1.0000 S1000
    G1 F1000 X34.6637 Y49.5348 Z-1.0000 S1000
    G1 F1000 X34.5715 Y49.7949 Z-1.0000 S1000
    G1 F1000 X34.4868 Y50.0577 Z-1.0000 S1000
    G1 F1000 X34.3933 Y50.3833 Z-1.0000 S1000
    G1 F1000 X33.7959 Y52.6133 Z-1.0000 S1000
    G1 F1000 X33.7284 Y52.8810 Z-1.0000 S1000
    G1 F1000 X33.6686 Y53.1505 Z-1.0000 S1000
    G1 F1000 X33.6167 Y53.4216 Z-1.0000 S1000
    G1 F1000 X33.5726 Y53.6941 Z-1.0000 S1000
    G1 F1000 X33.5364 Y53.9677 Z-1.0000 S1000
    G1 F1000 X33.5082 Y54.2423 Z-1.0000 S1000
    G1 F1000 X33.4846 Y54.5787 Z-1.0000 S1000
    G1 F1000 X33.3636 Y56.8833 Z-1.0000 S1000
    G1 F1000 X33.3531 Y57.1591 Z-1.0000 S1000
    G1 F1000 X33.3506 Y57.4352 Z-1.0000 S1000
    G1 F1000 X33.3562 Y57.7111 Z-1.0000 S1000
    G1 F1000 X33.3697 Y57.9868 Z-1.0000 S1000
    G1 F1000 X33.3912 Y58.2620 Z-1.0000 S1000
    G1 F1000 X33.4206 Y58.5365 Z-1.0000 S1000
    G1 F1000 X33.4679 Y58.8734 Z-1.0000 S1000
    G1 F1000 X33.8291 Y61.1529 Z-1.0000 S1000
    G1 F1000 X33.8762 Y61.4249 Z-1.0000 S1000
    G1 F1000 X33.9312 Y61.6954 Z-1.0000 S1000
    G1 F1000 X33.9940 Y61.9642 Z-1.0000 S1000
    G1 F1000 X34.0646 Y62.2310 Z-1.0000 S1000
    G1 F1000 X34.1429 Y62.4957 Z-1.0000 S1000
    G1 F1000 X34.2289 Y62.7580 Z-1.0000 S1000
    G1 F1000 X34.3445 Y63.0760 Z-1.0000 S1000
    G1 F1000 X35.1716 Y65.2304 Z-1.0000 S1000
    G1 F1000 X35.2742 Y65.4867 Z-1.0000 S1000
    G1 F1000 X35.3843 Y65.7398 Z-1.0000 S1000
    G1 F1000 X35.5016 Y65.9897 Z-1.0000 S1000
    G1 F1000 X35.6261 Y66.2360 Z-1.0000 S1000
    G1 F1000 X35.7577 Y66.4787 Z-1.0000 S1000
    G1 F1000 X35.8963 Y66.7174 Z-1.0000 S1000
    G1 F1000 X36.0760 Y67.0051 Z-1.0000 S1000
    G1 F1000 X37.3332 Y68.9406 Z-1.0000 S1000
    G1 F1000 X37.4869 Y69.1699 Z-1.0000 S1000
    G1 F1000 X37.6472 Y69.3946 Z-1.0000 S1000
    G1 F1000 X37.8139 Y69.6146 Z-1.0000 S1000
    G1 F1000 X37.9869 Y69.8297 Z-1.0000 S1000
    G1 F1000 X38.1661 Y70.0396 Z-1.0000 S1000
    G1 F1000 X38.3513 Y70.2443 Z-1.0000 S1000
    G1 F1000 X38.5858 Y70.4873 Z-1.0000 S1000
    G1 F1000 X40.2174 Y72.1189 Z-1.0000 S1000
    G1 F1000 X40.4154 Y72.3112 Z-1.0000 S1000
    G1 F1000 X40.6189 Y72.4978 Z-1.0000 S1000
    G1 F1000 X40.8277 Y72.6783 Z-1.0000 S1000
    G1 F1000 X41.0416 Y72.8527 Z-1.0000 S1000
    G1 F1000 X41.2606 Y73.0209 Z-1.0000 S1000
    G1 F1000 X41.4842 Y73.1826 Z-1.0000 S1000
    G1 F1000 X41.7641 Y73.3715 Z-1.0000 S1000
    G1 F1000 X43.6996 Y74.6287 Z-1.0000 S1000
    G1 F1000 X43.9333 Y74.7757 Z-1.0000 S1000
    G1 F1000 X44.1711 Y74.9159 Z-1.0000 S1000
    G1 F1000 X44.4128 Y75.0491 Z-1.0000 S1000
    G1 F1000 X44.6584 Y75.1752 Z-1.0000 S1000
    G1 F1000 X44.9074 Y75.2942 Z-1.0000 S1000
    G1 F1000 X45.1599 Y75.4059 Z-1.0000 S1000
    G1 F1000 X45.4743 Y75.5331 Z-1.0000 S1000
    G1 F1000 X47.6287 Y76.3602 Z-1.0000 S1000
    G1 F1000 X47.8878 Y76.4554 Z-1.0000 S1000
    G1 F1000 X48.1495 Y76.5430 Z-1.0000 S1000
    G1 F1000 X48.4137 Y76.6231 Z-1.0000 S1000
    G1 F1000 X48.6801 Y76.6954 Z-1.0000 S1000
    G1 F1000 X48.9485 Y76.7600 Z-1.0000 S1000
    G1 F1000 X49.2186 Y76.8167 Z-1.0000 S1000
    G1 F1000 X49.5518 Y76.8756 Z-1.0000 S1000
    G1 F1000 X51.8313 Y77.2368 Z-1.0000 S1000
    G1 F1000 X52.1045 Y77.2761 Z-1.0000 S1000
    G1 F1000 X52.3788 Y77.3074 Z-1.0000 S1000
    G1 F1000 X52.6538 Y77.3307 Z-1.0000 S1000
    G1 F1000 X52.9294 Y77.3461 Z-1.0000 S1000
    G1 F1000 X53.2054 Y77.3535 Z-1.0000 S1000
    G1 F1000 X53.4814 Y77.3529 Z-1.0000 S1000
    G1 F1000 X53.8214 Y77.3411 Z-1.0000 S1000
    G1 F1000 X56.1260 Y77.2201 Z-1.0000 S1000
    G1 F1000 X56.4014 Y77.2016 Z-1.0000 S1000
    G1 F1000 X56.6762 Y77.1752 Z-1.0000 S1000
    G1 F1000 X56.9501 Y77.1408 Z-1.0000 S1000
    G1 F1000 X57.2229 Y77.0985 Z-1.0000 S1000
    G1 F1000 X57.4943 Y77.0483 Z-1.0000 S1000
    G1 F1000 X57.7642 Y76.9903 Z-1.0000 S1000
    G1 F1000 X58.0914 Y76.9088 Z-1.0000 S1000
    G1 F1000 X60.3214 Y76.3114 Z-1.0000 S1000
    G1 F1000 X60.5869 Y76.2361 Z-1.0000 S1000
    G1 F1000 X60.8502 Y76.1531 Z-1.0000 S1000
    G1 F1000 X61.1110 Y76.0626 Z-1.0000 S1000
    G1 F1000 X61.3690 Y75.9645 Z-1.0000 S1000
    G1 F1000 X61.6241 Y75.8590 Z-1.0000 S1000
    G1 F1000 X61.8760 Y75.7462 Z-1.0000 S1000
    G1 F1000 X62.1806 Y75.5978 Z-1.0000 S1000
    G1 F1000 X64.2366 Y74.5503 Z-1.0000 S1000
    G1 F1000 X64.4807 Y74.4214 Z-1.0000 S1000
    G1 F1000 X64.7210 Y74.2855 Z-1.0000 S1000
    G1 F1000 X64.9572 Y74.1428 Z-1.0000 S1000
    G1 F1000 X65.1892 Y73.9932 Z-1.0000 S1000
    G1 F1000 X65.4168 Y73.8369 Z-1.0000 S1000
    G1 F1000 X65.6397 Y73.6742 Z-1.0000 S1000
    G1 F1000 X65.9064 Y73.4660 Z-1.0000 S1000
    G1 F1000 X67.7001 Y72.0137 Z-1.0000 S1000
    G1 F1000 X67.9120 Y71.8369 Z-1.0000 S1000
    G1 F1000 X68.1188 Y71.6541 Z-1.0000 S1000
    G1 F1000 X68.3202 Y71.4653 Z-1.0000 S1000
    G1 F1000 X68.5161 Y71.2708 Z-1.0000 S1000
    G1 F1000 X68.7062 Y71.0707 Z-1.0000 S1000
    G1 F1000 X68.8904 Y70.8651 Z-1.0000 S1000
    G1 F1000 X69.1090 Y70.6048 Z-1.0000 S1000
    G1 F1000 X70.5613 Y68.8111 Z-1.0000 S1000
    G1 F1000 X70.7319 Y68.5940 Z-1.0000 S1000
    G1 F1000 X70.8961 Y68.3721 Z-1.0000 S1000
    G1 F1000 X71.0538 Y68.1456 Z-1.0000 S1000
    G1 F1000 X71.2049 Y67.9146 Z-1.0000 S1000
    G1 F1000 X71.3492 Y67.6793 Z-1.0000 S1000
    G1 F1000 X71.4867 Y67.4399 Z-1.0000 S1000
    G1 F1000 X71.6456 Y67.1413 Z-1.0000 S1000
    G1 F1000 X72.6931 Y65.0853 Z-1.0000 S1000
    G1 F1000 X72.8148 Y64.8375 Z-1.0000 S1000
    G1 F1000 X72.9293 Y64.5864 Z-1.0000 S1000
    G1 F1000 X73.0365 Y64.3320 Z-1.0000 S1000
    G1 F1000 X73.1363 Y64.0746 Z-1.0000 S1000
    G1 F1000 X73.2285 Y63.8145 Z-1.0000 S1000
    G1 F1000 X73.3132 Y63.5517 Z-1.0000 S1000
    G1 F1000 X73.4067 Y63.2261 Z-1.0000 S1000
    G1 F1000 X74.0041 Y60.9961 Z-1.0000 S1000
    G1 F1000 X74.0716 Y60.7284 Z-1.0000 S1000
    G1 F1000 X74.1314 Y60.4589 Z-1.0000 S1000
    G1 F1000 X74.1833 Y60.1878 Z-1.0000 S1000
    G1 F1000 X74.2274 Y59.9153 Z-1.0000 S1000
    G1 F1000 X74.2636 Y59.6417 Z-1.0000 S1000
    G1 F1000 X74.2918 Y59.3671 Z-1.0000 S1000
    G1 F1000 X74.3154 Y59.0307 Z-1.0000 S1000
    G1 F1000 X74.4364 Y56.7261 Z-1.0000 S1000
    G1 F1000 X74.4469 Y56.4503 Z-1.0000 S1000
    G1 F1000 X74.4494 Y56.1742 Z-1.0000 S1000
    G1 F1000 X74.4438 Y55.8983 Z-1.0000 S1000
    G1 F1000 X74.4303 Y55.6226 Z-1.0000 S1000
    G1 F1000 X74.4088 Y55.3474 Z-1.0000 S1000
    G1 F1000 X74.3794 Y55.0729 Z-1.0000 S1000
    G1 F1000 X74.3321 Y54.7360 Z-1.0000 S1000
    G1 F1000 X73.9709 Y52.4565 Z-1.0000 S1000
    G1 F1000 X73.9238 Y52.1845 Z-1.0000 S1000
    G1 F1000 X73.8688 Y51.9140 Z-1.0000 S1000
    G1 F1000 X73.8060 Y51.6452 Z-1.0000 S1000
    G1 F1000 X73.7354 Y51.3784 Z-1.0000 S1000
    G1 F1000 X73.6571 Y51.1137 Z-1.0000 S1000
    G1 F1000 X73.5711 Y50.8514 Z-1.0000 S1000
    G1 F1000 X73.4555 Y50.5334 Z-1.0000 S1000
    G1 F1000 X72.6284 Y48.3790 Z-1.0000 S1000
    G1 F1000 X72.5258 Y48.1227 Z-1.0000 S1000
    G1 F1000 X72.4157 Y47.8696 Z-1.0000 S1000
    G1 F1000 X72.2984 Y47.6197 Z-1.0000 S1000
    G1 F1000 X72.1739 Y47.3734 Z-1.0000 S1000
    G1 F1000 X72.0423 Y47.1307 Z-1.0000 S1000
    G1 F1000 X71.9037 Y46.8920 Z-1.0000 S1000
    G1 F1000 X71.7240 Y46.6043 Z-1.0000 S1000
    G1 F1000 X70.4668 Y44.6688 Z-1.0000 S1000
    G1 F1000 X70.3131 Y44.4395 Z-1.0000 S1000
    G1 F1000 X70.2300 Y44.3230 Z-1.0000 S1000
    G1 F1000 X70.7598 Y43.1868 Z-1.0000 S1000
    G1 F1000 X70.7756 Y43.2380 Z-1.0000 S1000
    G1 F1000 X70.8646 Y43.4993 Z-1.0000 S1000
    G1 F1000 X70.9611 Y43.7579 Z-1.0000 S1000
    G1 F1000 X71.0650 Y44.0136 Z-1.0000 S1000
    G1 F1000 X71.1764 Y44.2662 Z-1.0000 S1000
    G1 F1000 X71.2950 Y44.5155 Z-1.0000 S1000
    G1 F1000 X71.4207 Y44.7612 Z-1.0000 S1000
    G1 F1000 X71.5536 Y45.0032 Z-1.0000 S1000
    G1 F1000 X71.6934 Y45.2412 Z-1.0000 S1000
    G1 F1000 X71.8471 Y45.4860 Z-1.0000 S1000
    G1 F1000 X72.9078 Y47.1196 Z-1.0000 S1000
    G1 F1000 X74.5064 Y51.2836 Z-1.0000 S1000
    G1 F1000 X74.5622 Y51.6357 Z-1.0000 S1000
    G1 F1000 X74.6094 Y51.9077 Z-1.0000 S1000
    G1 F1000 X74.6644 Y52.1782 Z-1.0000 S1000
    G1 F1000 X74.7272 Y52.4470 Z-1.0000 S1000
    G1 F1000 X74.7978 Y52.7139 Z-1.0000 S1000
    G1 F1000 X74.8761 Y52.9786 Z-1.0000 S1000
    G1 F1000 X74.9620 Y53.2409 Z-1.0000 S1000
    G1 F1000 X75.0555 Y53.5006 Z-1.0000 S1000
    G1 F1000 X75.1565 Y53.7575 Z-1.0000 S1000
    G1 F1000 X75.2648 Y54.0114 Z-1.0000 S1000
    G1 F1000 X75.3805 Y54.2620 Z-1.0000 S1000
    G1 F1000 X75.5034 Y54.5092 Z-1.0000 S1000
    G1 F1000 X75.6334 Y54.7527 Z-1.0000 S1000
    G1 F1000 X75.7704 Y54.9923 Z-1.0000 S1000
    G1 F1000 X75.9143 Y55.2279 Z-1.0000 S1000
    G1 F1000 X76.0650 Y55.4592 Z-1.0000 S1000
    G1 F1000 X76.2223 Y55.6860 Z-1.0000 S1000
    G1 F1000 X76.3861 Y55.9082 Z-1.0000 S1000
    G1 F1000 X76.5563 Y56.1255 Z-1.0000 S1000
    G1 F1000 X76.7327 Y56.3378 Z-1.0000 S1000
    G1 F1000 X76.9152 Y56.5449 Z-1.0000 S1000
    G1 F1000 X77.1036 Y56.7467 Z-1.0000 S1000
    G1 F1000 X77.1482 Y56.7918 Z-1.0000 S1000
    G1 F1000 X77.0464 Y56.8955 Z-1.0000 S1000
    G1 F1000 X76.8589 Y57.0980 Z-1.0000 S1000
    G1 F1000 X76.6773 Y57.3059 Z-1.0000 S1000
    G1 F1000 X76.5017 Y57.5189 Z-1.0000 S1000
    G1 F1000 X76.3325 Y57.7370 Z-1.0000 S1000
    G1 F1000 X76.1696 Y57.9599 Z-1.0000 S1000
    G1 F1000 X76.0132 Y58.1873 Z-1.0000 S1000
    G1 F1000 X75.8636 Y58.4193 Z-1.0000 S1000
    G1 F1000 X75.7206 Y58.6554 Z-1.0000 S1000
    G1 F1000 X75.5846 Y58.8956 Z-1.0000 S1000
    G1 F1000 X75.4556 Y59.1397 Z-1.0000 S1000
    G1 F1000 X75.3338 Y59.3873 Z-1.0000 S1000
    G1 F1000 X75.2191 Y59.6385 Z-1.0000 S1000
    G1 F1000 X75.1118 Y59.8928 Z-1.0000 S1000
    G1 F1000 X75.0119 Y60.1501 Z-1.0000 S1000
    G1 F1000 X74.9195 Y60.4102 Z-1.0000 S1000
    G1 F1000 X74.8347 Y60.6729 Z-1.0000 S1000
    G1 F1000 X74.7398 Y61.0030 Z-1.0000 S1000
    G1 F1000 X73.8162 Y64.4499 Z-1.0000 S1000
    G1 F1000 X71.4416 Y69.1105 Z-1.0000 S1000
    G1 F1000 X71.3199 Y69.3582 Z-1.0000 S1000
    G1 F1000 X71.2054 Y69.6094 Z-1.0000 S1000
    G1 F1000 X71.0982 Y69.8637 Z-1.0000 S1000
    G1 F1000 X70.9984 Y70.1211 Z-1.0000 S1000
    G1 F1000 X70.9061 Y70.3813 Z-1.0000 S1000
    G1 F1000 X70.8215 Y70.6440 Z-1.0000 S1000
    G1 F1000 X70.7444 Y70.9091 Z-1.0000 S1000
    G1 F1000 X70.6751 Y71.1763 Z-1.0000 S1000
    G1 F1000 X70.6135 Y71.4453 Z-1.0000 S1000
    G1 F1000 X70.5598 Y71.7161 Z-1.0000 S1000
    G1 F1000 X70.5139 Y71.9883 Z-1.0000 S1000
    G1 F1000 X70.4760 Y72.2617 Z-1.0000 S1000
    G1 F1000 X70.4460 Y72.5361 Z-1.0000 S1000
    G1 F1000 X70.4239 Y72.8113 Z-1.0000 S1000
    G1 F1000 X70.4098 Y73.0869 Z-1.0000 S1000
    G1 F1000 X70.4050 Y73.3099 Z-1.0000 S1000
    G1 F1000 X70.3027 Y73.3109 Z-1.0000 S1000
    G1 F1000 X70.0269 Y73.3215 Z-1.0000 S1000
    G1 F1000 X69.7514 Y73.3401 Z-1.0000 S1000
    G1 F1000 X69.4767 Y73.3666 Z-1.0000 S1000
    G1 F1000 X69.2028 Y73.4011 Z-1.0000 S1000
    G1 F1000 X68.9301 Y73.4435 Z-1.0000 S1000
    G1 F1000 X68.6586 Y73.4938 Z-1.0000 S1000
    G1 F1000 X68.3888 Y73.5520 Z-1.0000 S1000
    G1 F1000 X68.1208 Y73.6179 Z-1.0000 S1000
    G1 F1000 X67.8547 Y73.6916 Z-1.0000 S1000
    G1 F1000 X67.5910 Y73.7729 Z-1.0000 S1000
    G1 F1000 X67.3297 Y73.8619 Z-1.0000 S1000
    G1 F1000 X67.0710 Y73.9584 Z-1.0000 S1000
    G1 F1000 X66.8153 Y74.0624 Z-1.0000 S1000
    G1 F1000 X66.5627 Y74.1737 Z-1.0000 S1000
    G1 F1000 X66.2058 Y74.3463 Z-1.0000 S1000
    G1 F1000 X61.5452 Y76.7209 Z-1.0000 S1000
    G1 F1000 X58.0983 Y77.6445 Z-1.0000 S1000
    G1 F1000 X57.8327 Y77.7198 Z-1.0000 S1000
    G1 F1000 X57.5694 Y77.8028 Z-1.0000 S1000
    G1 F1000 X57.3087 Y77.8934 Z-1.0000 S1000
    G1 F1000 X57.0507 Y77.9914 Z-1.0000 S1000
    G1 F1000 X56.7956 Y78.0969 Z-1.0000 S1000
    G1 F1000 X56.5437 Y78.2098 Z-1.0000 S1000
    G1 F1000 X56.2951 Y78.3299 Z-1.0000 S1000
    G1 F1000 X56.0502 Y78.4572 Z-1.0000 S1000
    G1 F1000 X55.8090 Y78.5915 Z-1.0000 S1000
    G1 F1000 X55.5719 Y78.7327 Z-1.0000 S1000
    G1 F1000 X55.3389 Y78.8808 Z-1.0000 S1000
    G1 F1000 X55.1103 Y79.0355 Z-1.0000 S1000
    G1 F1000 X54.8863 Y79.1968 Z-1.0000 S1000
    G1 F1000 X54.6671 Y79.3645 Z-1.0000 S1000
    G1 F1000 X54.4528 Y79.5385 Z-1.0000 S1000
    G1 F1000 X54.2436 Y79.7187 Z-1.0000 S1000
    G1 F1000 X54.0398 Y79.9048 Z-1.0000 S1000
    G1 F1000 X53.8867 Y80.0529 Z-1.0000 S1000
    G1 F1000 X53.8130 Y79.9806 Z-1.0000 S1000
    G1 F1000 X53.6105 Y79.7930 Z-1.0000 S1000
    G1 F1000 X53.4026 Y79.6114 Z-1.0000 S1000
    G1 F1000 X53.1896 Y79.4359 Z-1.0000 S1000
    G1 F1000 X52.9715 Y79.2666 Z-1.0000 S1000
    G1 F1000 X52.7486 Y79.1038 Z-1.0000 S1000
    G1 F1000 X52.5212 Y78.9474 Z-1.0000 S1000
    G1 F1000 X52.2892 Y78.7977 Z-1.0000 S1000
    G1 F1000 X52.0531 Y78.6548 Z-1.0000 S1000
    G1 F1000 X51.8129 Y78.5188 Z-1.0000 S1000
    G1 F1000 X51.5688 Y78.3898 Z-1.0000 S1000
    G1 F1000 X51.3211 Y78.2680 Z-1.0000 S1000
    G1 F1000 X51.0700 Y78.1533 Z-1.0000 S1000
    G1 F1000 X50.8157 Y78.0460 Z-1.0000 S1000
    G1 F1000 X50.5584 Y77.9461 Z-1.0000 S1000
    G1 F1000 X50.2983 Y77.8537 Z-1.0000 S1000
    G1 F1000 X50.0356 Y77.7689 Z-1.0000 S1000
    G1 F1000 X49.7705 Y77.6918 Z-1.0000 S1000
    G1 F1000 X49.5034 Y77.6223 Z-1.0000 S1000
    G1 F1000 X49.2343 Y77.5606 Z-1.0000 S1000
    G1 F1000 X48.9636 Y77.5068 Z-1.0000 S1000
    G1 F1000 X48.7310 Y77.4669 Z-1.0000 S1000
    G1 F1000 X48.3789 Y77.4111 Z-1.0000 S1000
    G1 F1000 X44.2149 Y75.8125 Z-1.0000 S1000
    G1 F1000 X42.5813 Y74.7518 Z-1.0000 S1000
    G1 F1000 X42.3476 Y74.6048 Z-1.0000 S1000
    G1 F1000 X42.1098 Y74.4647 Z-1.0000 S1000
    G1 F1000 X41.8680 Y74.3315 Z-1.0000 S1000
    G1 F1000 X41.6225 Y74.2054 Z-1.0000 S1000
    G1 F1000 X41.3734 Y74.0865 Z-1.0000 S1000
    G1 F1000 X41.1209 Y73.9748 Z-1.0000 S1000
    G1 F1000 X40.8654 Y73.8705 Z-1.0000 S1000
    G1 F1000 X40.6069 Y73.7737 Z-1.0000 S1000
    G1 F1000 X40.3457 Y73.6843 Z-1.0000 S1000
    G1 F1000 X40.0820 Y73.6026 Z-1.0000 S1000
    G1 F1000 X39.8161 Y73.5286 Z-1.0000 S1000
    G1 F1000 X39.5482 Y73.4622 Z-1.0000 S1000
    G1 F1000 X39.2784 Y73.4037 Z-1.0000 S1000
    G1 F1000 X39.0071 Y73.3530 Z-1.0000 S1000
    G1 F1000 X38.7344 Y73.3103 Z-1.0000 S1000
    G1 F1000 X38.4605 Y73.2754 Z-1.0000 S1000
    G1 F1000 X38.1858 Y73.2485 Z-1.0000 S1000
    G1 F1000 X37.9104 Y73.2295 Z-1.0000 S1000
    G1 F1000 X37.6346 Y73.2185 Z-1.0000 S1000
    G1 F1000 X37.4878 Y73.2170 Z-1.0000 S1000
    G1 F1000 X37.4865 Y73.0833 Z-1.0000 S1000
    G1 F1000 X37.4759 Y72.8074 Z-1.0000 S1000
    G1 F1000 X37.4573 Y72.5320 Z-1.0000 S1000
    G1 F1000 X37.4308 Y72.2573 Z-1.0000 S1000
    G1 F1000 X37.3963 Y71.9834 Z-1.0000 S1000
    G1 F1000 X37.3539 Y71.7106 Z-1.0000 S1000
    G1 F1000 X37.3036 Y71.4392 Z-1.0000 S1000
    G1 F1000 X37.2454 Y71.1694 Z-1.0000 S1000
    G1 F1000 X37.1795 Y70.9014 Z-1.0000 S1000
    G1 F1000 X37.1058 Y70.6353 Z-1.0000 S1000
    G1 F1000 X37.0244 Y70.3716 Z-1.0000 S1000
    G1 F1000 X36.9355 Y70.1103 Z-1.0000 S1000
    G1 F1000 X36.8389 Y69.8516 Z-1.0000 S1000
    G1 F1000 X36.7350 Y69.5959 Z-1.0000 S1000
    G1 F1000 X36.6237 Y69.3433 Z-1.0000 S1000
    G1 F1000 X36.5051 Y69.0941 Z-1.0000 S1000
    G1 F1000 X36.3793 Y68.8483 Z-1.0000 S1000
    G1 F1000 X36.2465 Y68.6064 Z-1.0000 S1000
    G1 F1000 X36.1067 Y68.3684 Z-1.0000 S1000
    G1 F1000 X35.9530 Y68.1236 Z-1.0000 S1000
    G1 F1000 X34.8922 Y66.4897 Z-1.0000 S1000
    G1 F1000 X33.2936 Y62.3258 Z-1.0000 S1000
    G1 F1000 X33.2378 Y61.9737 Z-1.0000 S1000
    G1 F1000 X33.1906 Y61.7017 Z-1.0000 S1000
    G1 F1000 X33.1356 Y61.4312 Z-1.0000 S1000
    G1 F1000 X33.0728 Y61.1624 Z-1.0000 S1000
    G1 F1000 X33.0022 Y60.8955 Z-1.0000 S1000
    G1 F1000 X32.9239 Y60.6308 Z-1.0000 S1000
    G1 F1000 X32.8380 Y60.3685 Z-1.0000 S1000
    G1 F1000 X32.7445 Y60.1088 Z-1.0000 S1000
    G1 F1000 X32.6435 Y59.8519 Z-1.0000 S1000
    G1 F1000 X32.5352 Y59.5980 Z-1.0000 S1000
    G1 F1000 X32.4195 Y59.3474 Z-1.0000 S1000
    G1 F1000 X32.2966 Y59.1002 Z-1.0000 S1000
    G1 F1000 X32.1666 Y58.8567 Z-1.0000 S1000
    G1 F1000 X32.0296 Y58.6171 Z-1.0000 S1000
    G1 F1000 X31.8857 Y58.3815 Z-1.0000 S1000
    G1 F1000 X31.7350 Y58.1502 Z-1.0000 S1000
    G1 F1000 X31.5777 Y57.9234 Z-1.0000 S1000
    G1 F1000 X31.4139 Y57.7012 Z-1.0000 S1000
    G1 F1000 X31.2437 Y57.4839 Z-1.0000 S1000
    G1 F1000 X31.0673 Y57.2716 Z-1.0000 S1000
    G1 F1000 X30.8848 Y57.0645 Z-1.0000 S1000
    G1 F1000 X30.6964 Y56.8627 Z-1.0000 S1000
    G1 F1000 X30.6518 Y56.8177 Z-1.0000 S1000
    G1 F1000 X30.7535 Y56.7141 Z-1.0000 S1000
    G1 F1000 X30.9411 Y56.5115 Z-1.0000 S1000
    G1 F1000 X31.1227 Y56.3037 Z-1.0000 S1000
    G1 F1000 X31.2982 Y56.0906 Z-1.0000 S1000
    G1 F1000 X31.4675 Y55.8726 Z-1.0000 S1000
    G1 F1000 X31.6303 Y55.6497 Z-1.0000 S1000
    G1 F1000 X31.7867 Y55.4222 Z-1.0000 S1000
    G1 F1000 X31.9364 Y55.1903 Z-1.0000 S1000
    G1 F1000 X32.0793 Y54.9542 Z-1.0000 S1000
    G1 F1000 X32.2153 Y54.7140 Z-1.0000 S1000
    G1 F1000 X32.3443 Y54.4699 Z-1.0000 S1000
    G1 F1000 X32.4662 Y54.2222 Z-1.0000 S1000
    G1 F1000 X32.5808 Y53.9711 Z-1.0000 S1000
    G1 F1000 X32.6881 Y53.7168 Z-1.0000 S1000
    G1 F1000 X32.7880 Y53.4595 Z-1.0000 S1000
    G1 F1000 X32.8804 Y53.1994 Z-1.0000 S1000
    G1 F1000 X32.9653 Y52.9367 Z-1.0000 S1000
    G1 F1000 X33.0602 Y52.6065 Z-1.0000 S1000
    G1 F1000 X33.9838 Y49.1596 Z-1.0000 S1000
    G1 F700 Z-2.0000
    G1 F1000 X36.3584 Y44.4989 Z-2.0000 S1000
    G1 F1000 X36.4802 Y44.2511 Z-2.0000 S1000
    G1 F1000 X36.5947 Y44.0000 Z-2.0000 S1000
    G1 F1000 X36.7018 Y43.7456 Z-2.0000 S1000
    G1 F1000 X36.8016 Y43.4882 Z-2.0000 S1000
    G1 F1000 X36.8939 Y43.2281 Z-2.0000 S1000
    G1 F1000 X36.9786 Y42.9653 Z-2.0000 S1000
    G1 F1000 X37.0556 Y42.7003 Z-2.0000 S1000
    G1 F1000 X37.1249 Y42.4331 Z-2.0000 S1000
    G1 F1000 X37.1865 Y42.1640 Z-2.0000 S1000
    G1 F1000 X37.2402 Y41.8932 Z-2.0000 S1000
    G1 F1000 X37.2861 Y41.6210 Z-2.0000 S1000
    G1 F1000 X37.2909 Y41.5865 Z-2.0000 S1000
    G1 F1000 X38.2222 Y43.5836 Z-2.0000 S1000
    G1 F1000 X37.2387 Y44.7983 Z-2.0000 S1000
    G1 F1000 X37.0681 Y45.0154 Z-2.0000 S1000
    G1 F1000 X36.9039 Y45.2373 Z-2.0000 S1000
    G1 F1000 X36.7462 Y45.4638 Z-2.0000 S1000
    G1 F1000 X36.5951 Y45.6948 Z-2.0000 S1000
    G1 F1000 X36.4508 Y45.9301 Z-2.0000 S1000
    G1 F1000 X36.3133 Y46.1695 Z-2.0000 S1000
    G1 F1000 X36.1544 Y46.4681 Z-2.0000 S1000
    G1 F1000 X35.1069 Y48.5241 Z-2.0000 S1000
    G1 F1000 X34.9852 Y48.7719 Z-2.0000 S1000
    G1 F1000 X34.8707 Y49.0230 Z-2.0000 S1000
    G1 F1000 X34.7635 Y49.2774 Z-2.0000 S1000
    G1 F1000 X34.6637 Y49.5348 Z-2.0000 S1000
    G1 F1000 X34.5715 Y49.7949 Z-2.0000 S1000
    G1 F1000 X34.4868 Y50.0577 Z-2.0000 S1000
    G1 F1000 X34.3933 Y50.3833 Z-2.0000 S1000
    G1 F1000 X33.7959 Y52.6133 Z-2.0000 S1000
    G1 F1000 X33.7284 Y52.8810 Z-2.0000 S1000
    G1 F1000 X33.6686 Y53.1505 Z-2.0000 S1000
    G1 F1000 X33.6167 Y53.4216 Z-2.0000 S1000
    G1 F1000 X33.5726 Y53.6941 Z-2.0000 S1000
    G1 F1000 X33.5364 Y53.9677 Z-2.0000 S1000
    G1 F1000 X33.5082 Y54.2423 Z-2.0000 S1000
    G1 F1000 X33.4846 Y54.5787 Z-2.0000 S1000
    G1 F1000 X33.3636 Y56.8833 Z-2.0000 S1000
    G1 F1000 X33.3531 Y57.1591 Z-2.0000 S1000
    G1 F1000 X33.3506 Y57.4352 Z-2.0000 S1000
    G1 F1000 X33.3562 Y57.7111 Z-2.0000 S1000
    G1 F1000 X33.3697 Y57.9868 Z-2.0000 S1000
    G1 F1000 X33.3912 Y58.2620 Z-2.0000 S1000
    G1 F1000 X33.4206 Y58.5365 Z-2.0000 S1000
    G1 F1000 X33.4679 Y58.8734 Z-2.0000 S1000
    G1 F1000 X33.8291 Y61.1529 Z-2.0000 S1000
    G1 F1000 X33.8762 Y61.4249 Z-2.0000 S1000
    G1 F1000 X33.9312 Y61.6954 Z-2.0000 S1000
    G1 F1000 X33.9940 Y61.9642 Z-2.0000 S1000
    G1 F1000 X34.0646 Y62.2310 Z-2.0000 S1000
    G1 F1000 X34.1429 Y62.4957 Z-2.0000 S1000
    G1 F1000 X34.2289 Y62.7580 Z-2.0000 S1000
    G1 F1000 X34.3445 Y63.0760 Z-2.0000 S1000
    G1 F1000 X35.1716 Y65.2304 Z-2.0000 S1000
    G1 F1000 X35.2742 Y65.4867 Z-2.0000 S1000
    G1 F1000 X35.3843 Y65.7398 Z-2.0000 S1000
    G1 F1000 X35.5016 Y65.9897 Z-2.0000 S1000
    G1 F1000 X35.6261 Y66.2360 Z-2.0000 S1000
    G1 F1000 X35.7577 Y66.4787 Z-2.0000 S1000
    G1 F1000 X35.8963 Y66.7174 Z-2.0000 S1000
    G1 F1000 X36.0760 Y67.0051 Z-2.0000 S1000
    G1 F1000 X37.3332 Y68.9406 Z-2.0000 S1000
    G1 F1000 X37.4869 Y69.1699 Z-2.0000 S1000
    G1 F1000 X37.6472 Y69.3946 Z-2.0000 S1000
    G1 F1000 X37.8139 Y69.6146 Z-2.0000 S1000
    G1 F1000 X37.9869 Y69.8297 Z-2.0000 S1000
    G1 F1000 X38.1661 Y70.0396 Z-2.0000 S1000
    G1 F1000 X38.3513 Y70.2443 Z-2.0000 S1000
    G1 F1000 X38.5858 Y70.4873 Z-2.0000 S1000
    G1 F1000 X40.2174 Y72.1189 Z-2.0000 S1000
    G1 F1000 X40.4154 Y72.3112 Z-2.0000 S1000
    G1 F1000 X40.6189 Y72.4978 Z-2.0000 S1000
    G1 F1000 X40.8277 Y72.6783 Z-2.0000 S1000
    G1 F1000 X41.0416 Y72.8527 Z-2.0000 S1000
    G1 F1000 X41.2606 Y73.0209 Z-2.0000 S1000
    G1 F1000 X41.4842 Y73.1826 Z-2.0000 S1000
    G1 F1000 X41.7641 Y73.3715 Z-2.0000 S1000
    G1 F1000 X43.6996 Y74.6287 Z-2.0000 S1000
    G1 F1000 X43.9333 Y74.7757 Z-2.0000 S1000
    G1 F1000 X44.1711 Y74.9159 Z-2.0000 S1000
    G1 F1000 X44.4128 Y75.0491 Z-2.0000 S1000
    G1 F1000 X44.6584 Y75.1752 Z-2.0000 S1000
    G1 F1000 X44.9074 Y75.2942 Z-2.0000 S1000
    G1 F1000 X45.1599 Y75.4059 Z-2.0000 S1000
    G1 F1000 X45.4743 Y75.5331 Z-2.0000 S1000
    G1 F1000 X47.6287 Y76.3602 Z-2.0000 S1000
    G1 F1000 X47.8878 Y76.4554 Z-2.0000 S1000
    G1 F1000 X48.1495 Y76.5430 Z-2.0000 S1000
    G1 F1000 X48.4137 Y76.6231 Z-2.0000 S1000
    G1 F1000 X48.6801 Y76.6954 Z-2.0000 S1000
    G1 F1000 X48.9485 Y76.7600 Z-2.0000 S1000
    G1 F1000 X49.2186 Y76.8167 Z-2.0000 S1000
    G1 F1000 X49.5518 Y76.8756 Z-2.0000 S1000
    G1 F1000 X51.8313 Y77.2368 Z-2.0000 S1000
    G1 F1000 X52.1045 Y77.2761 Z-2.0000 S1000
    G1 F1000 X52.3788 Y77.3074 Z-2.0000 S1000
    G1 F1000 X52.6538 Y77.3307 Z-2.0000 S1000
    G1 F1000 X52.9294 Y77.3461 Z-2.0000 S1000
    G1 F1000 X53.2054 Y77.3535 Z-2.0000 S1000
    G1 F1000 X53.4814 Y77.3529 Z-2.0000 S1000
    G1 F1000 X53.8214 Y77.3411 Z-2.0000 S1000
    G1 F1000 X56.1260 Y77.2201 Z-2.0000 S1000
    G1 F1000 X56.4014 Y77.2016 Z-2.0000 S1000
    G1 F1000 X56.6762 Y77.1752 Z-2.0000 S1000
    G1 F1000 X56.9501 Y77.1408 Z-2.0000 S1000
    G1 F1000 X57.2229 Y77.0985 Z-2.0000 S1000
    G1 F1000 X57.4943 Y77.0483 Z-2.0000 S1000
    G1 F1000 X57.7642 Y76.9903 Z-2.0000 S1000
    G1 F1000 X58.0914 Y76.9088 Z-2.0000 S1000
    G1 F1000 X60.3214 Y76.3114 Z-2.0000 S1000
    G1 F1000 X60.5869 Y76.2361 Z-2.0000 S1000
    G1 F1000 X60.8502 Y76.1531 Z-2.0000 S1000
    G1 F1000 X61.1110 Y76.0626 Z-2.0000 S1000
    G1 F1000 X61.3690 Y75.9645 Z-2.0000 S1000
    G1 F1000 X61.6241 Y75.8590 Z-2.0000 S1000
    G1 F1000 X61.8760 Y75.7462 Z-2.0000 S1000
    G1 F1000 X62.1806 Y75.5978 Z-2.0000 S1000
    G1 F1000 X64.2366 Y74.5503 Z-2.0000 S1000
    G1 F1000 X64.4807 Y74.4214 Z-2.0000 S1000
    G1 F1000 X64.7210 Y74.2855 Z-2.0000 S1000
    G1 F1000 X64.9572 Y74.1428 Z-2.0000 S1000
    G1 F1000 X65.1892 Y73.9932 Z-2.0000 S1000
    G1 F1000 X65.4168 Y73.8369 Z-2.0000 S1000
    G1 F1000 X65.6397 Y73.6742 Z-2.0000 S1000
    G1 F1000 X65.9064 Y73.4660 Z-2.0000 S1000
    G1 F1000 X67.7001 Y72.0137 Z-2.0000 S1000
    G1 F1000 X67.9120 Y71.8369 Z-2.0000 S1000
    G1 F1000 X68.1188 Y71.6541 Z-2.0000 S1000
    G1 F1000 X68.3202 Y71.4653 Z-2.0000 S1000
    G1 F1000 X68.5161 Y71.2708 Z-2.0000 S1000
    G1 F1000 X68.7062 Y71.0707 Z-2.0000 S1000
    G1 F1000 X68.8904 Y70.8651 Z-2.0000 S1000
    G1 F1000 X69.1090 Y70.6048 Z-2.0000 S1000
    G1 F1000 X70.5613 Y68.8111 Z-2.0000 S1000
    G1 F1000 X70.7319 Y68.5940 Z-2.0000 S1000
    G1 F1000 X70.8961 Y68.3721 Z-2.0000 S1000
    G1 F1000 X71.0538 Y68.1456 Z-2.0000 S1000
    G1 F1000 X71.2049 Y67.9146 Z-2.0000 S1000
    G1 F1000 X71.3492 Y67.6793 Z-2.0000 S1000
    G1 F1000 X71.4867 Y67.4399 Z-2.0000 S1000
    G1 F1000 X71.6456 Y67.1413 Z-2.0000 S1000
    G1 F1000 X72.6931 Y65.0853 Z-2.0000 S1000
    G1 F1000 X72.8148 Y64.8375 Z-2.0000 S1000
    G1 F1000 X72.9293 Y64.5864 Z-2.0000 S1000
    G1 F1000 X73.0365 Y64.3320 Z-2.0000 S1000
    G1 F1000 X73.1363 Y64.0746 Z-2.0000 S1000
    G1 F1000 X73.2285 Y63.8145 Z-2.0000 S1000
    G1 F1000 X73.3132 Y63.5517 Z-2.0000 S1000
    G1 F1000 X73.4067 Y63.2261 Z-2.0000 S1000
    G1 F1000 X74.0041 Y60.9961 Z-2.0000 S1000
    G1 F1000 X74.0716 Y60.7284 Z-2.0000 S1000
    G1 F1000 X74.1314 Y60.4589 Z-2.0000 S1000
    G1 F1000 X74.1833 Y60.1878 Z-2.0000 S1000
    G1 F1000 X74.2274 Y59.9153 Z-2.0000 S1000
    G1 F1000 X74.2636 Y59.6417 Z-2.0000 S1000
    G1 F1000 X74.2918 Y59.3671 Z-2.0000 S1000
    G1 F1000 X74.3154 Y59.0307 Z-2.0000 S1000
    G1 F1000 X74.4364 Y56.7261 Z-2.0000 S1000
    G1 F1000 X74.4469 Y56.4503 Z-2.0000 S1000
    G1 F1000 X74.4494 Y56.1742 Z-2.0000 S1000
    G1 F1000 X74.4438 Y55.8983 Z-2.0000 S1000
    G1 F1000 X74.4303 Y55.6226 Z-2.0000 S1000
    G1 F1000 X74.4088 Y55.3474 Z-2.0000 S1000
    G1 F1000 X74.3794 Y55.0729 Z-2.0000 S1000
    G1 F1000 X74.3321 Y54.7360 Z-2.0000 S1000
    G1 F1000 X73.9709 Y52.4565 Z-2.0000 S1000
    G1 F1000 X73.9238 Y52.1845 Z-2.0000 S1000
    G1 F1000 X73.8688 Y51.9140 Z-2.0000 S1000
    G1 F1000 X73.8060 Y51.6452 Z-2.0000 S1000
    G1 F1000 X73.7354 Y51.3784 Z-2.0000 S1000
    G1 F1000 X73.6571 Y51.1137 Z-2.0000 S1000
    G1 F1000 X73.5711 Y50.8514 Z-2.0000 S1000
    G1 F1000 X73.4555 Y50.5334 Z-2.0000 S1000
    G1 F1000 X72.6284 Y48.3790 Z-2.0000 S1000
    G1 F1000 X72.5258 Y48.1227 Z-2.0000 S1000
    G1 F1000 X72.4157 Y47.8696 Z-2.0000 S1000
    G1 F1000 X72.2984 Y47.6197 Z-2.0000 S1000
    G1 F1000 X72.1739 Y47.3734 Z-2.0000 S1000
    G1 F1000 X72.0423 Y47.1307 Z-2.0000 S1000
    G1 F1000 X71.9037 Y46.8920 Z-2.0000 S1000
    G1 F1000 X71.7240 Y46.6043 Z-2.0000 S1000
    G1 F1000 X70.4668 Y44.6688 Z-2.0000 S1000
    G1 F1000 X70.3131 Y44.4395 Z-2.0000 S1000
    G1 F1000 X70.2300 Y44.3230 Z-2.0000 S1000
    G1 F1000 X70.7598 Y43.1868 Z-2.0000 S1000
    G1 F1000 X70.7756 Y43.2380 Z-2.0000 S1000
    G1 F1000 X70.8646 Y43.4993 Z-2.0000 S1000
    G1 F1000 X70.9611 Y43.7579 Z-2.0000 S1000
    G1 F1000 X71.0650 Y44.0136 Z-2.0000 S1000
    G1 F1000 X71.1764 Y44.2662 Z-2.0000 S1000
    G1 F1000 X71.2950 Y44.5155 Z-2.0000 S1000
    G1 F1000 X71.4207 Y44.7612 Z-2.0000 S1000
    G1 F1000 X71.5536 Y45.0032 Z-2.0000 S1000
    G1 F1000 X71.6934 Y45.2412 Z-2.0000 S1000
    G1 F1000 X71.8471 Y45.4860 Z-2.0000 S1000
    G1 F1000 X72.9078 Y47.1196 Z-2.0000 S1000
    G1 F1000 X74.5064 Y51.2836 Z-2.0000 S1000
    G1 F1000 X74.5622 Y51.6357 Z-2.0000 S1000
    G1 F1000 X74.6094 Y51.9077 Z-2.0000 S1000
    G1 F1000 X74.6644 Y52.1782 Z-2.0000 S1000
    G1 F1000 X74.7272 Y52.4470 Z-2.0000 S1000
    G1 F1000 X74.7978 Y52.7139 Z-2.0000 S1000
    G1 F1000 X74.8761 Y52.9786 Z-2.0000 S1000
    G1 F1000 X74.9620 Y53.2409 Z-2.0000 S1000
    G1 F1000 X75.0555 Y53.5006 Z-2.0000 S1000
    G1 F1000 X75.1565 Y53.7575 Z-2.0000 S1000
    G1 F1000 X75.2648 Y54.0114 Z-2.0000 S1000
    G1 F1000 X75.3805 Y54.2620 Z-2.0000 S1000
    G1 F1000 X75.5034 Y54.5092 Z-2.0000 S1000
    G1 F1000 X75.6334 Y54.7527 Z-2.0000 S1000
    G1 F1000 X75.7704 Y54.9923 Z-2.0000 S1000
    G1 F1000 X75.9143 Y55.2279 Z-2.0000 S1000
    G1 F1000 X76.0650 Y55.4592 Z-2.0000 S1000
    G1 F1000 X76.2223 Y55.6860 Z-2.0000 S1000
    G1 F1000 X76.3861 Y55.9082 Z-2.0000 S1000
    G1 F1000 X76.5563 Y56.1255 Z-2.0000 S1000
    G1 F1000 X76.7327 Y56.3378 Z-2.0000 S1000
    G1 F1000 X76.9152 Y56.5449 Z-2.0000 S1000
    G1 F1000 X77.1036 Y56.7467 Z-2.0000 S1000
    G1 F1000 X77.1482 Y56.7918 Z-2.0000 S1000
    G1 F1000 X77.0464 Y56.8955 Z-2.0000 S1000
    G1 F1000 X76.8589 Y57.0980 Z-2.0000 S1000
    G1 F1000 X76.6773 Y57.3059 Z-2.0000 S1000
    G1 F1000 X76.5017 Y57.5189 Z-2.0000 S1000
    G1 F1000 X76.3325 Y57.7370 Z-2.0000 S1000
    G1 F1000 X76.1696 Y57.9599 Z-2.0000 S1000
    G1 F1000 X76.0132 Y58.1873 Z-2.0000 S1000
    G1 F1000 X75.8636 Y58.4193 Z-2.0000 S1000
    G1 F1000 X75.7206 Y58.6554 Z-2.0000 S1000
    G1 F1000 X75.5846 Y58.8956 Z-2.0000 S1000
    G1 F1000 X75.4556 Y59.1397 Z-2.0000 S1000
    G1 F1000 X75.3338 Y59.3873 Z-2.0000 S1000
    G1 F1000 X75.2191 Y59.6385 Z-2.0000 S1000
    G1 F1000 X75.1118 Y59.8928 Z-2.0000 S1000
    G1 F1000 X75.0119 Y60.1501 Z-2.0000 S1000
    G1 F1000 X74.9195 Y60.4102 Z-2.0000 S1000
    G1 F1000 X74.8347 Y60.6729 Z-2.0000 S1000
    G1 F1000 X74.7398 Y61.0030 Z-2.0000 S1000
    G1 F1000 X73.8162 Y64.4499 Z-2.0000 S1000
    G1 F1000 X71.4416 Y69.1105 Z-2.0000 S1000
    G1 F1000 X71.3199 Y69.3582 Z-2.0000 S1000
    G1 F1000 X71.2054 Y69.6094 Z-2.0000 S1000
    G1 F1000 X71.0982 Y69.8637 Z-2.0000 S1000
    G1 F1000 X70.9984 Y70.1211 Z-2.0000 S1000
    G1 F1000 X70.9061 Y70.3813 Z-2.0000 S1000
    G1 F1000 X70.8215 Y70.6440 Z-2.0000 S1000
    G1 F1000 X70.7444 Y70.9091 Z-2.0000 S1000
    G1 F1000 X70.6751 Y71.1763 Z-2.0000 S1000
    G1 F1000 X70.6135 Y71.4453 Z-2.0000 S1000
    G1 F1000 X70.5598 Y71.7161 Z-2.0000 S1000
    G1 F1000 X70.5139 Y71.9883 Z-2.0000 S1000
    G1 F1000 X70.4760 Y72.2617 Z-2.0000 S1000
    G1 F1000 X70.4460 Y72.5361 Z-2.0000 S1000
    G1 F1000 X70.4239 Y72.8113 Z-2.0000 S1000
    G1 F1000 X70.4098 Y73.0869 Z-2.0000 S1000
    G1 F1000 X70.4050 Y73.3099 Z-2.0000 S1000
    G1 F1000 X70.3027 Y73.3109 Z-2.0000 S1000
    G1 F1000 X70.0269 Y73.3215 Z-2.0000 S1000
    G1 F1000 X69.7514 Y73.3401 Z-2.0000 S1000
    G1 F1000 X69.4767 Y73.3666 Z-2.0000 S1000
    G1 F1000 X69.2028 Y73.4011 Z-2.0000 S1000
    G1 F1000 X68.9301 Y73.4435 Z-2.0000 S1000
    G1 F1000 X68.6586 Y73.4938 Z-2.0000 S1000
    G1 F1000 X68.3888 Y73.5520 Z-2.0000 S1000
    G1 F1000 X68.1208 Y73.6179 Z-2.0000 S1000
    G1 F1000 X67.8547 Y73.6916 Z-2.0000 S1000
    G1 F1000 X67.5910 Y73.7729 Z-2.0000 S1000
    G1 F1000 X67.3297 Y73.8619 Z-2.0000 S1000
    G1 F1000 X67.0710 Y73.9584 Z-2.0000 S1000
    G1 F1000 X66.8153 Y74.0624 Z-2.0000 S1000
    G1 F1000 X66.5627 Y74.1737 Z-2.0000 S1000
    G1 F1000 X66.2058 Y74.3463 Z-2.0000 S1000
    G1 F1000 X61.5452 Y76.7209 Z-2.0000 S1000
    G1 F1000 X58.0983 Y77.6445 Z-2.0000 S1000
    G1 F1000 X57.8327 Y77.7198 Z-2.0000 S1000
    G1 F1000 X57.5694 Y77.8028 Z-2.0000 S1000
    G1 F1000 X57.3087 Y77.8934 Z-2.0000 S1000
    G1 F1000 X57.0507 Y77.9914 Z-2.0000 S1000
    G1 F1000 X56.7956 Y78.0969 Z-2.0000 S1000
    G1 F1000 X56.5437 Y78.2098 Z-2.0000 S1000
    G1 F1000 X56.2951 Y78.3299 Z-2.0000 S1000
    G1 F1000 X56.0502 Y78.4572 Z-2.0000 S1000
    G1 F1000 X55.8090 Y78.5915 Z-2.0000 S1000
    G1 F1000 X55.5719 Y78.7327 Z-2.0000 S1000
    G1 F1000 X55.3389 Y78.8808 Z-2.0000 S1000
    G1 F1000 X55.1103 Y79.0355 Z-2.0000 S1000
    G1 F1000 X54.8863 Y79.1968 Z-2.0000 S1000
    G1 F1000 X54.6671 Y79.3645 Z-2.0000 S1000
    G1 F1000 X54.4528 Y79.5385 Z-2.0000 S1000
    G1 F1000 X54.2436 Y79.7187 Z-2.0000 S1000
    G1 F1000 X54.0398 Y79.9048 Z-2.0000 S1000
    G1 F1000 X53.8867 Y80.0529 Z-2.0000 S1000
    G1 F1000 X53.8130 Y79.9806 Z-2.0000 S1000
    G1 F1000 X53.6105 Y79.7930 Z-2.0000 S1000
    G1 F1000 X53.4026 Y79.6114 Z-2.0000 S1000
    G1 F1000 X53.1896 Y79.4359 Z-2.0000 S1000
    G1 F1000 X52.9715 Y79.2666 Z-2.0000 S1000
    G1 F1000 X52.7486 Y79.1038 Z-2.0000 S1000
    G1 F1000 X52.5212 Y78.9474 Z-2.0000 S1000
    G1 F1000 X52.2892 Y78.7977 Z-2.0000 S1000
    G1 F1000 X52.0531 Y78.6548 Z-2.0000 S1000
    G1 F1000 X51.8129 Y78.5188 Z-2.0000 S1000
    G1 F1000 X51.5688 Y78.3898 Z-2.0000 S1000
    G1 F1000 X51.3211 Y78.2680 Z-2.0000 S1000
    G1 F1000 X51.0700 Y78.1533 Z-2.0000 S1000
    G1 F1000 X50.8157 Y78.0460 Z-2.0000 S1000
    G1 F1000 X50.5584 Y77.9461 Z-2.0000 S1000
    G1 F1000 X50.2983 Y77.8537 Z-2.0000 S1000
    G1 F1000 X50.0356 Y77.7689 Z-2.0000 S1000
    G1 F1000 X49.7705 Y77.6918 Z-2.0000 S1000
    G1 F1000 X49.5034 Y77.6223 Z-2.0000 S1000
    G1 F1000 X49.2343 Y77.5606 Z-2.0000 S1000
    G1 F1000 X48.9636 Y77.5068 Z-2.0000 S1000
    G1 F1000 X48.7310 Y77.4669 Z-2.0000 S1000
    G1 F1000 X48.3789 Y77.4111 Z-2.0000 S1000
    G1 F1000 X44.2149 Y75.8125 Z-2.0000 S1000
    G1 F1000 X42.5813 Y74.7518 Z-2.0000 S1000
    G1 F1000 X42.3476 Y74.6048 Z-2.0000 S1000
    G1 F1000 X42.1098 Y74.4647 Z-2.0000 S1000
    G1 F1000 X41.8680 Y74.3315 Z-2.0000 S1000
    G1 F1000 X41.6225 Y74.2054 Z-2.0000 S1000
    G1 F1000 X41.3734 Y74.0865 Z-2.0000 S1000
    G1 F1000 X41.1209 Y73.9748 Z-2.0000 S1000
    G1 F1000 X40.8654 Y73.8705 Z-2.0000 S1000
    G1 F1000 X40.6069 Y73.7737 Z-2.0000 S1000
    G1 F1000 X40.3457 Y73.6843 Z-2.0000 S1000
    G1 F1000 X40.0820 Y73.6026 Z-2.0000 S1000
    G1 F1000 X39.8161 Y73.5286 Z-2.0000 S1000
    G1 F1000 X39.5482 Y73.4622 Z-2.0000 S1000
    G1 F1000 X39.2784 Y73.4037 Z-2.0000 S1000
    G1 F1000 X39.0071 Y73.3530 Z-2.0000 S1000
    G1 F1000 X38.7344 Y73.3103 Z-2.0000 S1000
    G1 F1000 X38.4605 Y73.2754 Z-2.0000 S1000
    G1 F1000 X38.1858 Y73.2485 Z-2.0000 S1000
    G1 F1000 X37.9104 Y73.2295 Z-2.0000 S1000
    G1 F1000 X37.6346 Y73.2185 Z-2.0000 S1000
    G1 F1000 X37.4878 Y73.2170 Z-2.0000 S1000
    G1 F1000 X37.4865 Y73.0833 Z-2.0000 S1000
    G1 F1000 X37.4759 Y72.8074 Z-2.0000 S1000
    G1 F1000 X37.4573 Y72.5320 Z-2.0000 S1000
    G1 F1000 X37.4308 Y72.2573 Z-2.0000 S1000
    G1 F1000 X37.3963 Y71.9834 Z-2.0000 S1000
    G1 F1000 X37.3539 Y71.7106 Z-2.0000 S1000
    G1 F1000 X37.3036 Y71.4392 Z-2.0000 S1000
    G1 F1000 X37.2454 Y71.1694 Z-2.0000 S1000
    G1 F1000 X37.1795 Y70.9014 Z-2.0000 S1000
    G1 F1000 X37.1058 Y70.6353 Z-2.0000 S1000
    G1 F1000 X37.0244 Y70.3716 Z-2.0000 S1000
    G1 F1000 X36.9355 Y70.1103 Z-2.0000 S1000
    G1 F1000 X36.8389 Y69.8516 Z-2.0000 S1000
    G1 F1000 X36.7350 Y69.5959 Z-2.0000 S1000
    G1 F1000 X36.6237 Y69.3433 Z-2.0000 S1000
    G1 F1000 X36.5051 Y69.0941 Z-2.0000 S1000
    G1 F1000 X36.3793 Y68.8483 Z-2.0000 S1000
    G1 F1000 X36.2465 Y68.6064 Z-2.0000 S1000
    G1 F1000 X36.1067 Y68.3684 Z-2.0000 S1000
    G1 F1000 X35.9530 Y68.1236 Z-2.0000 S1000
    G1 F1000 X34.8922 Y66.4897 Z-2.0000 S1000
    G1 F1000 X33.2936 Y62.3258 Z-2.0000 S1000
    G1 F1000 X33.2378 Y61.9737 Z-2.0000 S1000
    G1 F1000 X33.1906 Y61.7017 Z-2.0000 S1000
    G1 F1000 X33.1356 Y61.4312 Z-2.0000 S1000
    G1 F1000 X33.0728 Y61.1624 Z-2.0000 S1000
    G1 F1000 X33.0022 Y60.8955 Z-2.0000 S1000
    G1 F1000 X32.9239 Y60.6308 Z-2.0000 S1000
    G1 F1000 X32.8380 Y60.3685 Z-2.0000 S1000
    G1 F1000 X32.7445 Y60.1088 Z-2.0000 S1000
    G1 F1000 X32.6435 Y59.8519 Z-2.0000 S1000
    G1 F1000 X32.5352 Y59.5980 Z-2.0000 S1000
    G1 F1000 X32.4195 Y59.3474 Z-2.0000 S1000
    G1 F1000 X32.2966 Y59.1002 Z-2.0000 S1000
    G1 F1000 X32.1666 Y58.8567 Z-2.0000 S1000
    G1 F1000 X32.0296 Y58.6171 Z-2.0000 S1000
    G1 F1000 X31.8857 Y58.3815 Z-2.0000 S1000
    G1 F1000 X31.7350 Y58.1502 Z-2.0000 S1000
    G1 F1000 X31.5777 Y57.9234 Z-2.0000 S1000
    G1 F1000 X31.4139 Y57.7012 Z-2.0000 S1000
    G1 F1000 X31.2437 Y57.4839 Z-2.0000 S1000
    G1 F1000 X31.0673 Y57.2716 Z-2.0000 S1000
    G1 F1000 X30.8848 Y57.0645 Z-2.0000 S1000
    G1 F1000 X30.6964 Y56.8627 Z-2.0000 S1000
    G1 F1000 X30.6518 Y56.8177 Z-2.0000 S1000
    G1 F1000 X30.7535 Y56.7141 Z-2.0000 S1000
    G1 F1000 X30.9411 Y56.5115 Z-2.0000 S1000
    G1 F1000 X31.1227 Y56.3037 Z-2.0000 S1000
    G1 F1000 X31.2982 Y56.0906 Z-2.0000 S1000
    G1 F1000 X31.4675 Y55.8726 Z-2.0000 S1000
    G1 F1000 X31.6303 Y55.6497 Z-2.0000 S1000
    G1 F1000 X31.7867 Y55.4222 Z-2.0000 S1000
    G1 F1000 X31.9364 Y55.1903 Z-2.0000 S1000
    G1 F1000 X32.0793 Y54.9542 Z-2.0000 S1000
    G1 F1000 X32.2153 Y54.7140 Z-2.0000 S1000
    G1 F1000 X32.3443 Y54.4699 Z-2.0000 S1000
    G1 F1000 X32.4662 Y54.2222 Z-2.0000 S1000
    G1 F1000 X32.5808 Y53.9711 Z-2.0000 S1000
    G1 F1000 X32.6881 Y53.7168 Z-2.0000 S1000
    G1 F1000 X32.7880 Y53.4595 Z-2.0000 S1000
    G1 F1000 X32.8804 Y53.1994 Z-2.0000 S1000
    G1 F1000 X32.9653 Y52.9367 Z-2.0000 S1000
    G1 F1000 X33.0602 Y52.6065 Z-2.0000 S1000
    G1 F1000 X33.9838 Y49.1596 Z-2.0000 S1000
    G1 F700 Z-3.0000
    G1 F1000 X36.3584 Y44.4989 Z-3.0000 S1000
    G1 F1000 X36.4802 Y44.2511 Z-3.0000 S1000
    G1 F1000 X36.5947 Y44.0000 Z-3.0000 S1000
    G1 F1000 X36.7018 Y43.7456 Z-3.0000 S1000
    G1 F1000 X36.8016 Y43.4882 Z-3.0000 S1000
    G1 F1000 X36.8939 Y43.2281 Z-3.0000 S1000
    G1 F1000 X36.9786 Y42.9653 Z-3.0000 S1000
    G1 F1000 X37.0556 Y42.7003 Z-3.0000 S1000
    G1 F1000 X37.1249 Y42.4331 Z-3.0000 S1000
    G1 F1000 X37.1865 Y42.1640 Z-3.0000 S1000
    G1 F1000 X37.2402 Y41.8932 Z-3.0000 S1000
    G1 F1000 X37.2861 Y41.6210 Z-3.0000 S1000
    G1 F1000 X37.2909 Y41.5865 Z-3.0000 S1000
    G1 F1000 X38.2222 Y43.5836 Z-3.0000 S1000
    G1 F1000 X37.2387 Y44.7983 Z-3.0000 S1000
    G1 F1000 X37.0681 Y45.0154 Z-3.0000 S1000
    G1 F1000 X36.9039 Y45.2373 Z-3.0000 S1000
    G1 F1000 X36.7462 Y45.4638 Z-3.0000 S1000
    G1 F1000 X36.5951 Y45.6948 Z-3.0000 S1000
    G1 F1000 X36.4508 Y45.9301 Z-3.0000 S1000
    G1 F1000 X36.3133 Y46.1695 Z-3.0000 S1000
    G1 F1000 X36.1544 Y46.4681 Z-3.0000 S1000
    G1 F1000 X35.1069 Y48.5241 Z-3.0000 S1000
    G1 F1000 X34.9852 Y48.7719 Z-3.0000 S1000
    G1 F1000 X34.8707 Y49.0230 Z-3.0000 S1000
    G1 F1000 X34.7635 Y49.2774 Z-3.0000 S1000
    G1 F1000 X34.6637 Y49.5348 Z-3.0000 S1000
    G1 F1000 X34.5715 Y49.7949 Z-3.0000 S1000
    G1 F1000 X34.4868 Y50.0577 Z-3.0000 S1000
    G1 F1000 X34.3933 Y50.3833 Z-3.0000 S1000
    G1 F1000 X33.7959 Y52.6133 Z-3.0000 S1000
    G1 F1000 X33.7284 Y52.8810 Z-3.0000 S1000
    G1 F1000 X33.6686 Y53.1505 Z-3.0000 S1000
    G1 F1000 X33.6167 Y53.4216 Z-3.0000 S1000
    G1 F1000 X33.5726 Y53.6941 Z-3.0000 S1000
    G1 F1000 X33.5364 Y53.9677 Z-3.0000 S1000
    G1 F1000 X33.5082 Y54.2423 Z-3.0000 S1000
    G1 F1000 X33.4846 Y54.5787 Z-3.0000 S1000
    G1 F1000 X33.3636 Y56.8833 Z-3.0000 S1000
    G1 F1000 X33.3531 Y57.1591 Z-3.0000 S1000
    G1 F1000 X33.3506 Y57.4352 Z-3.0000 S1000
    G1 F1000 X33.3562 Y57.7111 Z-3.0000 S1000
    G1 F1000 X33.3697 Y57.9868 Z-3.0000 S1000
    G1 F1000 X33.3912 Y58.2620 Z-3.0000 S1000
    G1 F1000 X33.4206 Y58.5365 Z-3.0000 S1000
    G1 F1000 X33.4679 Y58.8734 Z-3.0000 S1000
    G1 F1000 X33.8291 Y61.1529 Z-3.0000 S1000
    G1 F1000 X33.8762 Y61.4249 Z-3.0000 S1000
    G1 F1000 X33.9312 Y61.6954 Z-3.0000 S1000
    G1 F1000 X33.9940 Y61.9642 Z-3.0000 S1000
    G1 F1000 X34.0646 Y62.2310 Z-3.0000 S1000
    G1 F1000 X34.1429 Y62.4957 Z-3.0000 S1000
    G1 F1000 X34.2289 Y62.7580 Z-3.0000 S1000
    G1 F1000 X34.3445 Y63.0760 Z-3.0000 S1000
    G1 F1000 X35.1716 Y65.2304 Z-3.0000 S1000
    G1 F1000 X35.2742 Y65.4867 Z-3.0000 S1000
    G1 F1000 X35.3843 Y65.7398 Z-3.0000 S1000
    G1 F1000 X35.5016 Y65.9897 Z-3.0000 S1000
    G1 F1000 X35.6261 Y66.2360 Z-3.0000 S1000
    G1 F1000 X35.7577 Y66.4787 Z-3.0000 S1000
    G1 F1000 X35.8963 Y66.7174 Z-3.0000 S1000
    G1 F1000 X36.0760 Y67.0051 Z-3.0000 S1000
    G1 F1000 X37.3332 Y68.9406 Z-3.0000 S1000
    G1 F1000 X37.4869 Y69.1699 Z-3.0000 S1000
    G1 F1000 X37.6472 Y69.3946 Z-3.0000 S1000
    G1 F1000 X37.8139 Y69.6146 Z-3.0000 S1000
    G1 F1000 X37.9869 Y69.8297 Z-3.0000 S1000
    G1 F1000 X38.1661 Y70.0396 Z-3.0000 S1000
    G1 F1000 X38.3513 Y70.2443 Z-3.0000 S1000
    G1 F1000 X38.5858 Y70.4873 Z-3.0000 S1000
    G1 F1000 X40.2174 Y72.1189 Z-3.0000 S1000
    G1 F1000 X40.4154 Y72.3112 Z-3.0000 S1000
    G1 F1000 X40.6189 Y72.4978 Z-3.0000 S1000
    G1 F1000 X40.8277 Y72.6783 Z-3.0000 S1000
    G1 F1000 X41.0416 Y72.8527 Z-3.0000 S1000
    G1 F1000 X41.2606 Y73.0209 Z-3.0000 S1000
    G1 F1000 X41.4842 Y73.1826 Z-3.0000 S1000
    G1 F1000 X41.7641 Y73.3715 Z-3.0000 S1000
    G1 F1000 X43.6996 Y74.6287 Z-3.0000 S1000
    G1 F1000 X43.9333 Y74.7757 Z-3.0000 S1000
    G1 F1000 X44.1711 Y74.9159 Z-3.0000 S1000
    G1 F1000 X44.4128 Y75.0491 Z-3.0000 S1000
    G1 F1000 X44.6584 Y75.1752 Z-3.0000 S1000
    G1 F1000 X44.9074 Y75.2942 Z-3.0000 S1000
    G1 F1000 X45.1599 Y75.4059 Z-3.0000 S1000
    G1 F1000 X45.4743 Y75.5331 Z-3.0000 S1000
    G1 F1000 X47.6287 Y76.3602 Z-3.0000 S1000
    G1 F1000 X47.8878 Y76.4554 Z-3.0000 S1000
    G1 F1000 X48.1495 Y76.5430 Z-3.0000 S1000
    G1 F1000 X48.4137 Y76.6231 Z-3.0000 S1000
    G1 F1000 X48.6801 Y76.6954 Z-3.0000 S1000
    G1 F1000 X48.9485 Y76.7600 Z-3.0000 S1000
    G1 F1000 X49.2186 Y76.8167 Z-3.0000 S1000
    G1 F1000 X49.5518 Y76.8756 Z-3.0000 S1000
    G1 F1000 X51.8313 Y77.2368 Z-3.0000 S1000
    G1 F1000 X52.1045 Y77.2761 Z-3.0000 S1000
    G1 F1000 X52.3788 Y77.3074 Z-3.0000 S1000
    G1 F1000 X52.6538 Y77.3307 Z-3.0000 S1000
    G1 F1000 X52.9294 Y77.3461 Z-3.0000 S1000
    G1 F1000 X53.2054 Y77.3535 Z-3.0000 S1000
    G1 F1000 X53.4814 Y77.3529 Z-3.0000 S1000
    G1 F1000 X53.8214 Y77.3411 Z-3.0000 S1000
    G1 F1000 X56.1260 Y77.2201 Z-3.0000 S1000
    G1 F1000 X56.4014 Y77.2016 Z-3.0000 S1000
    G1 F1000 X56.6762 Y77.1752 Z-3.0000 S1000
    G1 F1000 X56.9501 Y77.1408 Z-3.0000 S1000
    G1 F1000 X57.2229 Y77.0985 Z-3.0000 S1000
    G1 F1000 X57.4943 Y77.0483 Z-3.0000 S1000
    G1 F1000 X57.7642 Y76.9903 Z-3.0000 S1000
    G1 F1000 X58.0914 Y76.9088 Z-3.0000 S1000
    G1 F1000 X60.3214 Y76.3114 Z-3.0000 S1000
    G1 F1000 X60.5869 Y76.2361 Z-3.0000 S1000
    G1 F1000 X60.8502 Y76.1531 Z-3.0000 S1000
    G1 F1000 X61.1110 Y76.0626 Z-3.0000 S1000
    G1 F1000 X61.3690 Y75.9645 Z-3.0000 S1000
    G1 F1000 X61.6241 Y75.8590 Z-3.0000 S1000
    G1 F1000 X61.8760 Y75.7462 Z-3.0000 S1000
    G1 F1000 X62.1806 Y75.5978 Z-3.0000 S1000
    G1 F1000 X64.2366 Y74.5503 Z-3.0000 S1000
    G1 F1000 X64.4807 Y74.4214 Z-3.0000 S1000
    G1 F1000 X64.7210 Y74.2855 Z-3.0000 S1000
    G1 F1000 X64.9572 Y74.1428 Z-3.0000 S1000
    G1 F1000 X65.1892 Y73.9932 Z-3.0000 S1000
    G1 F1000 X65.4168 Y73.8369 Z-3.0000 S1000
    G1 F1000 X65.6397 Y73.6742 Z-3.0000 S1000
    G1 F1000 X65.9064 Y73.4660 Z-3.0000 S1000
    G1 F1000 X67.7001 Y72.0137 Z-3.0000 S1000
    G1 F1000 X67.9120 Y71.8369 Z-3.0000 S1000
    G1 F1000 X68.1188 Y71.6541 Z-3.0000 S1000
    G1 F1000 X68.3202 Y71.4653 Z-3.0000 S1000
    G1 F1000 X68.5161 Y71.2708 Z-3.0000 S1000
    G1 F1000 X68.7062 Y71.0707 Z-3.0000 S1000
    G1 F1000 X68.8904 Y70.8651 Z-3.0000 S1000
    G1 F1000 X69.1090 Y70.6048 Z-3.0000 S1000
    G1 F1000 X70.5613 Y68.8111 Z-3.0000 S1000
    G1 F1000 X70.7319 Y68.5940 Z-3.0000 S1000
    G1 F1000 X70.8961 Y68.3721 Z-3.0000 S1000
    G1 F1000 X71.0538 Y68.1456 Z-3.0000 S1000
    G1 F1000 X71.2049 Y67.9146 Z-3.0000 S1000
    G1 F1000 X71.3492 Y67.6793 Z-3.0000 S1000
    G1 F1000 X71.4867 Y67.4399 Z-3.0000 S1000
    G1 F1000 X71.6456 Y67.1413 Z-3.0000 S1000
    G1 F1000 X72.6931 Y65.0853 Z-3.0000 S1000
    G1 F1000 X72.8148 Y64.8375 Z-3.0000 S1000
    G1 F1000 X72.9293 Y64.5864 Z-3.0000 S1000
    G1 F1000 X73.0365 Y64.3320 Z-3.0000 S1000
    G1 F1000 X73.1363 Y64.0746 Z-3.0000 S1000
    G1 F1000 X73.2285 Y63.8145 Z-3.0000 S1000
    G1 F1000 X73.3132 Y63.5517 Z-3.0000 S1000
    G1 F1000 X73.4067 Y63.2261 Z-3.0000 S1000
    G1 F1000 X74.0041 Y60.9961 Z-3.0000 S1000
    G1 F1000 X74.0716 Y60.7284 Z-3.0000 S1000
    G1 F1000 X74.1314 Y60.4589 Z-3.0000 S1000
    G1 F1000 X74.1833 Y60.1878 Z-3.0000 S1000
    G1 F1000 X74.2274 Y59.9153 Z-3.0000 S1000
    G1 F1000 X74.2636 Y59.6417 Z-3.0000 S1000
    G1 F1000 X74.2918 Y59.3671 Z-3.0000 S1000
    G1 F1000 X74.3154 Y59.0307 Z-3.0000 S1000
    G1 F1000 X74.4364 Y56.7261 Z-3.0000 S1000
    G1 F1000 X74.4469 Y56.4503 Z-3.0000 S1000
    G1 F1000 X74.4494 Y56.1742 Z-3.0000 S1000
    G1 F1000 X74.4438 Y55.8983 Z-3.0000 S1000
    G1 F1000 X74.4303 Y55.6226 Z-3.0000 S1000
    G1 F1000 X74.4088 Y55.3474 Z-3.0000 S1000
    G1 F1000 X74.3794 Y55.0729 Z-3.0000 S1000
    G1 F1000 X74.3321 Y54.7360 Z-3.0000 S1000
    G1 F1000 X73.9709 Y52.4565 Z-3.0000 S1000
    G1 F1000 X73.9238 Y52.1845 Z-3.0000 S1000
    G1 F1000 X73.8688 Y51.9140 Z-3.0000 S1000
    G1 F1000 X73.8060 Y51.6452 Z-3.0000 S1000
    G1 F1000 X73.7354 Y51.3784 Z-3.0000 S1000
    G1 F1000 X73.6571 Y51.1137 Z-3.0000 S1000
    G1 F1000 X73.5711 Y50.8514 Z-3.0000 S1000
    G1 F1000 X73.4555 Y50.5334 Z-3.0000 S1000
    G1 F1000 X72.6284 Y48.3790 Z-3.0000 S1000
    G1 F1000 X72.5258 Y48.1227 Z-3.0000 S1000
    G1 F1000 X72.4157 Y47.8696 Z-3.0000 S1000
    G1 F1000 X72.2984 Y47.6197 Z-3.0000 S1000
    G1 F1000 X72.1739 Y47.3734 Z-3.0000 S1000
    G1 F1000 X72.0423 Y47.1307 Z-3.0000 S1000
    G1 F1000 X71.9037 Y46.8920 Z-3.0000 S1000
    G1 F1000 X71.7240 Y46.6043 Z-3.0000 S1000
    G1 F1000 X70.4668 Y44.6688 Z-3.0000 S1000
    G1 F1000 X70.3131 Y44.4395 Z-3.0000 S1000
    G1 F1000 X70.2300 Y44.3230 Z-3.0000 S1000
    G1 F1000 X70.7598 Y43.1868 Z-3.0000 S1000
    G1 F1000 X70.7756 Y43.2380 Z-3.0000 S1000
    G1 F1000 X70.8646 Y43.4993 Z-3.0000 S1000
    G1 F1000 X70.9611 Y43.7579 Z-3.0000 S1000
    G1 F1000 X71.0650 Y44.0136 Z-3.0000 S1000
    G1 F1000 X71.1764 Y44.2662 Z-3.0000 S1000
    G1 F1000 X71.2950 Y44.5155 Z-3.0000 S1000
    G1 F1000 X71.4207 Y44.7612 Z-3.0000 S1000
    G1 F1000 X71.5536 Y45.0032 Z-3.0000 S1000
    G1 F1000 X71.6934 Y45.2412 Z-3.0000 S1000
    G1 F1000 X71.8471 Y45.4860 Z-3.0000 S1000
    G1 F1000 X72.9078 Y47.1196 Z-3.0000 S1000
    G1 F1000 X74.5064 Y51.2836 Z-3.0000 S1000
    G1 F1000 X74.5622 Y51.6357 Z-3.0000 S1000
    G1 F1000 X74.6094 Y51.9077 Z-3.0000 S1000
    G1 F1000 X74.6644 Y52.1782 Z-3.0000 S1000
    G1 F1000 X74.7272 Y52.4470 Z-3.0000 S1000
    G1 F1000 X74.7978 Y52.7139 Z-3.0000 S1000
    G1 F1000 X74.8761 Y52.9786 Z-3.0000 S1000
    G1 F1000 X74.9620 Y53.2409 Z-3.0000 S1000
    G1 F1000 X75.0555 Y53.5006 Z-3.0000 S1000
    G1 F1000 X75.1565 Y53.7575 Z-3.0000 S1000
    G1 F1000 X75.2648 Y54.0114 Z-3.0000 S1000
    G1 F1000 X75.3805 Y54.2620 Z-3.0000 S1000
    G1 F1000 X75.5034 Y54.5092 Z-3.0000 S1000
    G1 F1000 X75.6334 Y54.7527 Z-3.0000 S1000
    G1 F1000 X75.7704 Y54.9923 Z-3.0000 S1000
    G1 F1000 X75.9143 Y55.2279 Z-3.0000 S1000
    G1 F1000 X76.0650 Y55.4592 Z-3.0000 S1000
    G1 F1000 X76.2223 Y55.6860 Z-3.0000 S1000
    G1 F1000 X76.3861 Y55.9082 Z-3.0000 S1000
    G1 F1000 X76.5563 Y56.1255 Z-3.0000 S1000
    G1 F1000 X76.7327 Y56.3378 Z-3.0000 S1000
    G1 F1000 X76.9152 Y56.5449 Z-3.0000 S1000
    G1 F1000 X77.1036 Y56.7467 Z-3.0000 S1000
    G1 F1000 X77.1482 Y56.7918 Z-3.0000 S1000
    G1 F1000 X77.0464 Y56.8955 Z-3.0000 S1000
    G1 F1000 X76.8589 Y57.0980 Z-3.0000 S1000
    G1 F1000 X76.6773 Y57.3059 Z-3.0000 S1000
    G1 F1000 X76.5017 Y57.5189 Z-3.0000 S1000
    G1 F1000 X76.3325 Y57.7370 Z-3.0000 S1000
    G1 F1000 X76.1696 Y57.9599 Z-3.0000 S1000
    G1 F1000 X76.0132 Y58.1873 Z-3.0000 S1000
    G1 F1000 X75.8636 Y58.4193 Z-3.0000 S1000
    G1 F1000 X75.7206 Y58.6554 Z-3.0000 S1000
    G1 F1000 X75.5846 Y58.8956 Z-3.0000 S1000
    G1 F1000 X75.4556 Y59.1397 Z-3.0000 S1000
    G1 F1000 X75.3338 Y59.3873 Z-3.0000 S1000
    G1 F1000 X75.2191 Y59.6385 Z-3.0000 S1000
    G1 F1000 X75.1118 Y59.8928 Z-3.0000 S1000
    G1 F1000 X75.0119 Y60.1501 Z-3.0000 S1000
    G1 F1000 X74.9195 Y60.4102 Z-3.0000 S1000
    G1 F1000 X74.8347 Y60.6729 Z-3.0000 S1000
    G1 F1000 X74.7398 Y61.0030 Z-3.0000 S1000
    G1 F1000 X73.8162 Y64.4499 Z-3.0000 S1000
    G1 F1000 X71.4416 Y69.1105 Z-3.0000 S1000
    G1 F1000 X71.3199 Y69.3582 Z-3.0000 S1000
    G1 F1000 X71.2054 Y69.6094 Z-3.0000 S1000
    G1 F1000 X71.0982 Y69.8637 Z-3.0000 S1000
    G1 F1000 X70.9984 Y70.1211 Z-3.0000 S1000
    G1 F1000 X70.9061 Y70.3813 Z-3.0000 S1000
    G1 F1000 X70.8215 Y70.6440 Z-3.0000 S1000
    G1 F1000 X70.7444 Y70.9091 Z-3.0000 S1000
    G1 F1000 X70.6751 Y71.1763 Z-3.0000 S1000
    G1 F1000 X70.6135 Y71.4453 Z-3.0000 S1000
    G1 F1000 X70.5598 Y71.7161 Z-3.0000 S1000
    G1 F1000 X70.5139 Y71.9883 Z-3.0000 S1000
    G1 F1000 X70.4760 Y72.2617 Z-3.0000 S1000
    G1 F1000 X70.4460 Y72.5361 Z-3.0000 S1000
    G1 F1000 X70.4239 Y72.8113 Z-3.0000 S1000
    G1 F1000 X70.4098 Y73.0869 Z-3.0000 S1000
    G1 F1000 X70.4050 Y73.3099 Z-3.0000 S1000
    G1 F1000 X70.3027 Y73.3109 Z-3.0000 S1000
    G1 F1000 X70.0269 Y73.3215 Z-3.0000 S1000
    G1 F1000 X69.7514 Y73.3401 Z-3.0000 S1000
    G1 F1000 X69.4767 Y73.3666 Z-3.0000 S1000
    G1 F1000 X69.2028 Y73.4011 Z-3.0000 S1000
    G1 F1000 X68.9301 Y73.4435 Z-3.0000 S1000
    G1 F1000 X68.6586 Y73.4938 Z-3.0000 S1000
    G1 F1000 X68.3888 Y73.5520 Z-3.0000 S1000
    G1 F1000 X68.1208 Y73.6179 Z-3.0000 S1000
    G1 F1000 X67.8547 Y73.6916 Z-3.0000 S1000
    G1 F1000 X67.5910 Y73.7729 Z-3.0000 S1000
    G1 F1000 X67.3297 Y73.8619 Z-3.0000 S1000
    G1 F1000 X67.0710 Y73.9584 Z-3.0000 S1000
    G1 F1000 X66.8153 Y74.0624 Z-3.0000 S1000
    G1 F1000 X66.5627 Y74.1737 Z-3.0000 S1000
    G1 F1000 X66.2058 Y74.3463 Z-3.0000 S1000
    G1 F1000 X61.5452 Y76.7209 Z-3.0000 S1000
    G1 F1000 X58.0983 Y77.6445 Z-3.0000 S1000
    G1 F1000 X57.8327 Y77.7198 Z-3.0000 S1000
    G1 F1000 X57.5694 Y77.8028 Z-3.0000 S1000
    G1 F1000 X57.3087 Y77.8934 Z-3.0000 S1000
    G1 F1000 X57.0507 Y77.9914 Z-3.0000 S1000
    G1 F1000 X56.7956 Y78.0969 Z-3.0000 S1000
    G1 F1000 X56.5437 Y78.2098 Z-3.0000 S1000
    G1 F1000 X56.2951 Y78.3299 Z-3.0000 S1000
    G1 F1000 X56.0502 Y78.4572 Z-3.0000 S1000
    G1 F1000 X55.8090 Y78.5915 Z-3.0000 S1000
    G1 F1000 X55.5719 Y78.7327 Z-3.0000 S1000
    G1 F1000 X55.3389 Y78.8808 Z-3.0000 S1000
    G1 F1000 X55.1103 Y79.0355 Z-3.0000 S1000
    G1 F1000 X54.8863 Y79.1968 Z-3.0000 S1000
    G1 F1000 X54.6671 Y79.3645 Z-3.0000 S1000
    G1 F1000 X54.4528 Y79.5385 Z-3.0000 S1000
    G1 F1000 X54.2436 Y79.7187 Z-3.0000 S1000
    G1 F1000 X54.0398 Y79.9048 Z-3.0000 S1000
    G1 F1000 X53.8867 Y80.0529 Z-3.0000 S1000
    G1 F1000 X53.8130 Y79.9806 Z-3.0000 S1000
    G1 F1000 X53.6105 Y79.7930 Z-3.0000 S1000
    G1 F1000 X53.4026 Y79.6114 Z-3.0000 S1000
    G1 F1000 X53.1896 Y79.4359 Z-3.0000 S1000
    G1 F1000 X52.9715 Y79.2666 Z-3.0000 S1000
    G1 F1000 X52.7486 Y79.1038 Z-3.0000 S1000
    G1 F1000 X52.5212 Y78.9474 Z-3.0000 S1000
    G1 F1000 X52.2892 Y78.7977 Z-3.0000 S1000
    G1 F1000 X52.0531 Y78.6548 Z-3.0000 S1000
    G1 F1000 X51.8129 Y78.5188 Z-3.0000 S1000
    G1 F1000 X51.5688 Y78.3898 Z-3.0000 S1000
    G1 F1000 X51.3211 Y78.2680 Z-3.0000 S1000
    G1 F1000 X51.0700 Y78.1533 Z-3.0000 S1000
    G1 F1000 X50.8157 Y78.0460 Z-3.0000 S1000
    G1 F1000 X50.5584 Y77.9461 Z-3.0000 S1000
    G1 F1000 X50.2983 Y77.8537 Z-3.0000 S1000
    G1 F1000 X50.0356 Y77.7689 Z-3.0000 S1000
    G1 F1000 X49.7705 Y77.6918 Z-3.0000 S1000
    G1 F1000 X49.5034 Y77.6223 Z-3.0000 S1000
    G1 F1000 X49.2343 Y77.5606 Z-3.0000 S1000
    G1 F1000 X48.9636 Y77.5068 Z-3.0000 S1000
    G1 F1000 X48.7310 Y77.4669 Z-3.0000 S1000
    G1 F1000 X48.3789 Y77.4111 Z-3.0000 S1000
    G1 F1000 X44.2149 Y75.8125 Z-3.0000 S1000
    G1 F1000 X42.5813 Y74.7518 Z-3.0000 S1000
    G1 F1000 X42.3476 Y74.6048 Z-3.0000 S1000
    G1 F1000 X42.1098 Y74.4647 Z-3.0000 S1000
    G1 F1000 X41.8680 Y74.3315 Z-3.0000 S1000
    G1 F1000 X41.6225 Y74.2054 Z-3.0000 S1000
    G1 F1000 X41.3734 Y74.0865 Z-3.0000 S1000
    G1 F1000 X41.1209 Y73.9748 Z-3.0000 S1000
    G1 F1000 X40.8654 Y73.8705 Z-3.0000 S1000
    G1 F1000 X40.6069 Y73.7737 Z-3.0000 S1000
    G1 F1000 X40.3457 Y73.6843 Z-3.0000 S1000
    G1 F1000 X40.0820 Y73.6026 Z-3.0000 S1000
    G1 F1000 X39.8161 Y73.5286 Z-3.0000 S1000
    G1 F1000 X39.5482 Y73.4622 Z-3.0000 S1000
    G1 F1000 X39.2784 Y73.4037 Z-3.0000 S1000
    G1 F1000 X39.0071 Y73.3530 Z-3.0000 S1000
    G1 F1000 X38.7344 Y73.3103 Z-3.0000 S1000
    G1 F1000 X38.4605 Y73.2754 Z-3.0000 S1000
    G1 F1000 X38.1858 Y73.2485 Z-3.0000 S1000
    G1 F1000 X37.9104 Y73.2295 Z-3.0000 S1000
    G1 F1000 X37.6346 Y73.2185 Z-3.0000 S1000
    G1 F1000 X37.4878 Y73.2170 Z-3.0000 S1000
    G1 F1000 X37.4865 Y73.0833 Z-3.0000 S1000
    G1 F1000 X37.4759 Y72.8074 Z-3.0000 S1000
    G1 F1000 X37.4573 Y72.5320 Z-3.0000 S1000
    G1 F1000 X37.4308 Y72.2573 Z-3.0000 S1000
    G1 F1000 X37.3963 Y71.9834 Z-3.0000 S1000
    G1 F1000 X37.3539 Y71.7106 Z-3.0000 S1000
    G1 F1000 X37.3036 Y71.4392 Z-3.0000 S1000
    G1 F1000 X37.2454 Y71.1694 Z-3.0000 S1000
    G1 F1000 X37.1795 Y70.9014 Z-3.0000 S1000
    G1 F1000 X37.1058 Y70.6353 Z-3.0000 S1000
    G1 F1000 X37.0244 Y70.3716 Z-3.0000 S1000
    G1 F1000 X36.9355 Y70.1103 Z-3.0000 S1000
    G1 F1000 X36.8389 Y69.8516 Z-3.0000 S1000
    G1 F1000 X36.7350 Y69.5959 Z-3.0000 S1000
    G1 F1000 X36.6237 Y69.3433 Z-3.0000 S1000
    G1 F1000 X36.5051 Y69.0941 Z-3.0000 S1000
    G1 F1000 X36.3793 Y68.8483 Z-3.0000 S1000
    G1 F1000 X36.2465 Y68.6064 Z-3.0000 S1000
    G1 F1000 X36.1067 Y68.3684 Z-3.0000 S1000
    G1 F1000 X35.9530 Y68.1236 Z-3.0000 S1000
    G1 F1000 X34.8922 Y66.4897 Z-3.0000 S1000
    G1 F1000 X33.2936 Y62.3258 Z-3.0000 S1000
    G1 F1000 X33.2378 Y61.9737 Z-3.0000 S1000
    G1 F1000 X33.1906 Y61.7017 Z-3.0000 S1000
    G1 F1000 X33.1356 Y61.4312 Z-3.0000 S1000
    G1 F1000 X33.0728 Y61.1624 Z-3.0000 S1000
    G1 F1000 X33.0022 Y60.8955 Z-3.0000 S1000
    G1 F1000 X32.9239 Y60.6308 Z-3.0000 S1000
    G1 F1000 X32.8380 Y60.3685 Z-3.0000 S1000
    G1 F1000 X32.7445 Y60.1088 Z-3.0000 S1000
    G1 F1000 X32.6435 Y59.8519 Z-3.0000 S1000
    G1 F1000 X32.5352 Y59.5980 Z-3.0000 S1000
    G1 F1000 X32.4195 Y59.3474 Z-3.0000 S1000
    G1 F1000 X32.2966 Y59.1002 Z-3.0000 S1000
    G1 F1000 X32.1666 Y58.8567 Z-3.0000 S1000
    G1 F1000 X32.0296 Y58.6171 Z-3.0000 S1000
    G1 F1000 X31.8857 Y58.3815 Z-3.0000 S1000
    G1 F1000 X31.7350 Y58.1502 Z-3.0000 S1000
    G1 F1000 X31.5777 Y57.9234 Z-3.0000 S1000
    G1 F1000 X31.4139 Y57.7012 Z-3.0000 S1000
    G1 F1000 X31.2437 Y57.4839 Z-3.0000 S1000
    G1 F1000 X31.0673 Y57.2716 Z-3.0000 S1000
    G1 F1000 X30.8848 Y57.0645 Z-3.0000 S1000
    G1 F1000 X30.6964 Y56.8627 Z-3.0000 S1000
    G1 F1000 X30.6518 Y56.8177 Z-3.0000 S1000
    G1 F1000 X30.7535 Y56.7141 Z-3.0000 S1000
    G1 F1000 X30.9411 Y56.5115 Z-3.0000 S1000
    G1 F1000 X31.1227 Y56.3037 Z-3.0000 S1000
    G1 F1000 X31.2982 Y56.0906 Z-3.0000 S1000
    G1 F1000 X31.4675 Y55.8726 Z-3.0000 S1000
    G1 F1000 X31.6303 Y55.6497 Z-3.0000 S1000
    G1 F1000 X31.7867 Y55.4222 Z-3.0000 S1000
    G1 F1000 X31.9364 Y55.1903 Z-3.0000 S1000
    G1 F1000 X32.0793 Y54.9542 Z-3.0000 S1000
    G1 F1000 X32.2153 Y54.7140 Z-3.0000 S1000
    G1 F1000 X32.3443 Y54.4699 Z-3.0000 S1000
    G1 F1000 X32.4662 Y54.2222 Z-3.0000 S1000
    G1 F1000 X32.5808 Y53.9711 Z-3.0000 S1000
    G1 F1000 X32.6881 Y53.7168 Z-3.0000 S1000
    G1 F1000 X32.7880 Y53.4595 Z-3.0000 S1000
    G1 F1000 X32.8804 Y53.1994 Z-3.0000 S1000
    G1 F1000 X32.9653 Y52.9367 Z-3.0000 S1000
    G1 F1000 X33.0602 Y52.6065 Z-3.0000 S1000
    G1 F1000 X33.9838 Y49.1596 Z-3.0000 S1000
    G0 Z7
    G0 X68.3754 Y44.5437
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X71.0638 Y38.7783 Z-1.0000 S1000
    G1 F1000 X71.1256 Y38.7737 Z-1.0000 S1000
    G1 F1000 X71.3762 Y38.7469 Z-1.0000 S1000
    G1 F1000 X71.6257 Y38.7121 Z-1.0000 S1000
    G1 F1000 X71.8741 Y38.6694 Z-1.0000 S1000
    G1 F1000 X72.0772 Y38.6278 Z-1.0000 S1000
    G1 F1000 X72.0537 Y38.7357 Z-1.0000 S1000
    G1 F1000 X72.0080 Y38.9835 Z-1.0000 S1000
    G1 F1000 X71.9702 Y39.2327 Z-1.0000 S1000
    G1 F1000 X71.9404 Y39.4829 Z-1.0000 S1000
    G1 F1000 X71.9184 Y39.7339 Z-1.0000 S1000
    G1 F1000 X71.9045 Y39.9855 Z-1.0000 S1000
    G1 F1000 X71.8985 Y40.2374 Z-1.0000 S1000
    G1 F1000 X71.9006 Y40.4894 Z-1.0000 S1000
    G1 F1000 X71.9106 Y40.7412 Z-1.0000 S1000
    G1 F1000 X71.9287 Y40.9925 Z-1.0000 S1000
    G1 F1000 X71.9547 Y41.2432 Z-1.0000 S1000
    G1 F1000 X71.9886 Y41.4928 Z-1.0000 S1000
    G1 F1000 X72.0305 Y41.7413 Z-1.0000 S1000
    G1 F1000 X72.0802 Y41.9884 Z-1.0000 S1000
    G1 F1000 X72.1377 Y42.2337 Z-1.0000 S1000
    G1 F1000 X72.2030 Y42.4771 Z-1.0000 S1000
    G1 F1000 X72.2760 Y42.7182 Z-1.0000 S1000
    G1 F1000 X72.3566 Y42.9570 Z-1.0000 S1000
    G1 F1000 X72.4447 Y43.1931 Z-1.0000 S1000
    G1 F1000 X72.5403 Y43.4262 Z-1.0000 S1000
    G1 F1000 X72.6433 Y43.6562 Z-1.0000 S1000
    G1 F1000 X72.7535 Y43.8828 Z-1.0000 S1000
    G1 F1000 X72.8708 Y44.1058 Z-1.0000 S1000
    G1 F1000 X72.9951 Y44.3250 Z-1.0000 S1000
    G1 F1000 X73.1785 Y44.6215 Z-1.0000 S1000
    G1 F1000 X74.3300 Y46.3950 Z-1.0000 S1000
    G1 F1000 X76.0484 Y50.8709 Z-1.0000 S1000
    G1 F1000 X76.1302 Y51.3873 Z-1.0000 S1000
    G1 F1000 X76.1736 Y51.6355 Z-1.0000 S1000
    G1 F1000 X76.2248 Y51.8822 Z-1.0000 S1000
    G1 F1000 X76.2838 Y52.1272 Z-1.0000 S1000
    G1 F1000 X76.3506 Y52.3702 Z-1.0000 S1000
    G1 F1000 X76.4251 Y52.6109 Z-1.0000 S1000
    G1 F1000 X76.5072 Y52.8492 Z-1.0000 S1000
    G1 F1000 X76.5967 Y53.0847 Z-1.0000 S1000
    G1 F1000 X76.6938 Y53.3172 Z-1.0000 S1000
    G1 F1000 X76.7981 Y53.5466 Z-1.0000 S1000
    G1 F1000 X76.9097 Y53.7725 Z-1.0000 S1000
    G1 F1000 X77.0284 Y53.9948 Z-1.0000 S1000
    G1 F1000 X77.1541 Y54.2132 Z-1.0000 S1000
    G1 F1000 X77.2867 Y54.4275 Z-1.0000 S1000
    G1 F1000 X77.4259 Y54.6375 Z-1.0000 S1000
    G1 F1000 X77.5718 Y54.8429 Z-1.0000 S1000
    G1 F1000 X77.7242 Y55.0437 Z-1.0000 S1000
    G1 F1000 X77.8828 Y55.2394 Z-1.0000 S1000
    G1 F1000 X78.0476 Y55.4301 Z-1.0000 S1000
    G1 F1000 X78.2183 Y55.6154 Z-1.0000 S1000
    G1 F1000 X78.3949 Y55.7952 Z-1.0000 S1000
    G1 F1000 X78.5770 Y55.9693 Z-1.0000 S1000
    G1 F1000 X78.7646 Y56.1376 Z-1.0000 S1000
    G1 F1000 X78.9574 Y56.2998 Z-1.0000 S1000
    G1 F1000 X79.1553 Y56.4558 Z-1.0000 S1000
    G1 F1000 X79.3581 Y56.6054 Z-1.0000 S1000
    G1 F1000 X79.5654 Y56.7486 Z-1.0000 S1000
    G1 F1000 X79.6408 Y56.7972 Z-1.0000 S1000
    G1 F1000 X79.5431 Y56.8600 Z-1.0000 S1000
    G1 F1000 X79.3355 Y57.0029 Z-1.0000 S1000
    G1 F1000 X79.1326 Y57.1523 Z-1.0000 S1000
    G1 F1000 X78.9346 Y57.3081 Z-1.0000 S1000
    G1 F1000 X78.7416 Y57.4701 Z-1.0000 S1000
    G1 F1000 X78.5538 Y57.6381 Z-1.0000 S1000
    G1 F1000 X78.3715 Y57.8121 Z-1.0000 S1000
    G1 F1000 X78.1947 Y57.9917 Z-1.0000 S1000
    G1 F1000 X78.0238 Y58.1768 Z-1.0000 S1000
    G1 F1000 X77.8588 Y58.3673 Z-1.0000 S1000
    G1 F1000 X77.7000 Y58.5629 Z-1.0000 S1000
    G1 F1000 X77.5474 Y58.7634 Z-1.0000 S1000
    G1 F1000 X77.4013 Y58.9687 Z-1.0000 S1000
    G1 F1000 X77.2618 Y59.1786 Z-1.0000 S1000
    G1 F1000 X77.1290 Y59.3927 Z-1.0000 S1000
    G1 F1000 X77.0030 Y59.6110 Z-1.0000 S1000
    G1 F1000 X76.8841 Y59.8331 Z-1.0000 S1000
    G1 F1000 X76.7723 Y60.0589 Z-1.0000 S1000
    G1 F1000 X76.6677 Y60.2882 Z-1.0000 S1000
    G1 F1000 X76.5704 Y60.5206 Z-1.0000 S1000
    G1 F1000 X76.4805 Y60.7561 Z-1.0000 S1000
    G1 F1000 X76.3982 Y60.9942 Z-1.0000 S1000
    G1 F1000 X76.3235 Y61.2349 Z-1.0000 S1000
    G1 F1000 X76.2733 Y61.4139 Z-1.0000 S1000
    G1 F1000 X75.3067 Y65.0214 Z-1.0000 S1000
    G1 F1000 X72.8561 Y69.8311 Z-1.0000 S1000
    G1 F1000 X72.7453 Y70.0575 Z-1.0000 S1000
    G1 F1000 X72.6417 Y70.2872 Z-1.0000 S1000
    G1 F1000 X72.5455 Y70.5200 Z-1.0000 S1000
    G1 F1000 X72.4567 Y70.7559 Z-1.0000 S1000
    G1 F1000 X72.3754 Y70.9944 Z-1.0000 S1000
    G1 F1000 X72.3018 Y71.2354 Z-1.0000 S1000
    G1 F1000 X72.2358 Y71.4786 Z-1.0000 S1000
    G1 F1000 X72.1776 Y71.7237 Z-1.0000 S1000
    G1 F1000 X72.1272 Y71.9706 Z-1.0000 S1000
    G1 F1000 X72.0846 Y72.2190 Z-1.0000 S1000
    G1 F1000 X72.0500 Y72.4686 Z-1.0000 S1000
    G1 F1000 X72.0233 Y72.7192 Z-1.0000 S1000
    G1 F1000 X72.0046 Y72.9704 Z-1.0000 S1000
    G1 F1000 X71.9938 Y73.2222 Z-1.0000 S1000
    G1 F1000 X71.9911 Y73.4742 Z-1.0000 S1000
    G1 F1000 X71.9964 Y73.7261 Z-1.0000 S1000
    G1 F1000 X72.0096 Y73.9777 Z-1.0000 S1000
    G1 F1000 X72.0308 Y74.2288 Z-1.0000 S1000
    G1 F1000 X72.0600 Y74.4791 Z-1.0000 S1000
    G1 F1000 X72.0971 Y74.7283 Z-1.0000 S1000
    G1 F1000 X72.1422 Y74.9763 Z-1.0000 S1000
    G1 F1000 X72.1614 Y75.0660 Z-1.0000 S1000
    G1 F1000 X72.0932 Y75.0512 Z-1.0000 S1000
    G1 F1000 X71.8454 Y75.0055 Z-1.0000 S1000
    G1 F1000 X71.5963 Y74.9677 Z-1.0000 S1000
    G1 F1000 X71.3461 Y74.9378 Z-1.0000 S1000
    G1 F1000 X71.0950 Y74.9158 Z-1.0000 S1000
    G1 F1000 X70.8434 Y74.9019 Z-1.0000 S1000
    G1 F1000 X70.5915 Y74.8959 Z-1.0000 S1000
    G1 F1000 X70.3396 Y74.8980 Z-1.0000 S1000
    G1 F1000 X70.0878 Y74.9080 Z-1.0000 S1000
    G1 F1000 X69.8364 Y74.9261 Z-1.0000 S1000
    G1 F1000 X69.5858 Y74.9520 Z-1.0000 S1000
    G1 F1000 X69.3361 Y74.9860 Z-1.0000 S1000
    G1 F1000 X69.0876 Y75.0278 Z-1.0000 S1000
    G1 F1000 X68.8406 Y75.0775 Z-1.0000 S1000
    G1 F1000 X68.5953 Y75.1351 Z-1.0000 S1000
    G1 F1000 X68.3519 Y75.2004 Z-1.0000 S1000
    G1 F1000 X68.1107 Y75.2733 Z-1.0000 S1000
    G1 F1000 X67.8719 Y75.3539 Z-1.0000 S1000
    G1 F1000 X67.6359 Y75.4421 Z-1.0000 S1000
    G1 F1000 X67.4027 Y75.5377 Z-1.0000 S1000
    G1 F1000 X67.1727 Y75.6406 Z-1.0000 S1000
    G1 F1000 X66.9264 Y75.7608 Z-1.0000 S1000
    G1 F1000 X62.1167 Y78.2114 Z-1.0000 S1000
    G1 F1000 X58.5092 Y79.1780 Z-1.0000 S1000
    G1 F1000 X58.2668 Y79.2470 Z-1.0000 S1000
    G1 F1000 X58.0268 Y79.3238 Z-1.0000 S1000
    G1 F1000 X57.7893 Y79.4081 Z-1.0000 S1000
    G1 F1000 X57.5547 Y79.4999 Z-1.0000 S1000
    G1 F1000 X57.3230 Y79.5991 Z-1.0000 S1000
    G1 F1000 X57.0947 Y79.7056 Z-1.0000 S1000
    G1 F1000 X56.8698 Y79.8193 Z-1.0000 S1000
    G1 F1000 X56.6487 Y79.9401 Z-1.0000 S1000
    G1 F1000 X56.4315 Y80.0678 Z-1.0000 S1000
    G1 F1000 X56.2184 Y80.2024 Z-1.0000 S1000
    G1 F1000 X56.0098 Y80.3437 Z-1.0000 S1000
    G1 F1000 X55.8057 Y80.4915 Z-1.0000 S1000
    G1 F1000 X55.6064 Y80.6457 Z-1.0000 S1000
    G1 F1000 X55.4121 Y80.8062 Z-1.0000 S1000
    G1 F1000 X55.2230 Y80.9727 Z-1.0000 S1000
    G1 F1000 X55.0393 Y81.1452 Z-1.0000 S1000
    G1 F1000 X54.8612 Y81.3234 Z-1.0000 S1000
    G1 F1000 X54.6888 Y81.5072 Z-1.0000 S1000
    G1 F1000 X54.5223 Y81.6964 Z-1.0000 S1000
    G1 F1000 X54.3619 Y81.8907 Z-1.0000 S1000
    G1 F1000 X54.2078 Y82.0901 Z-1.0000 S1000
    G1 F1000 X54.0601 Y82.2942 Z-1.0000 S1000
    G1 F1000 X53.9189 Y82.5030 Z-1.0000 S1000
    G1 F1000 X53.8923 Y82.5452 Z-1.0000 S1000
    G1 F1000 X53.8486 Y82.4772 Z-1.0000 S1000
    G1 F1000 X53.7057 Y82.2697 Z-1.0000 S1000
    G1 F1000 X53.5563 Y82.0668 Z-1.0000 S1000
    G1 F1000 X53.4005 Y81.8687 Z-1.0000 S1000
    G1 F1000 X53.2385 Y81.6757 Z-1.0000 S1000
    G1 F1000 X53.0704 Y81.4879 Z-1.0000 S1000
    G1 F1000 X52.8965 Y81.3056 Z-1.0000 S1000
    G1 F1000 X52.7169 Y81.1289 Z-1.0000 S1000
    G1 F1000 X52.5317 Y80.9579 Z-1.0000 S1000
    G1 F1000 X52.3413 Y80.7930 Z-1.0000 S1000
    G1 F1000 X52.1456 Y80.6341 Z-1.0000 S1000
    G1 F1000 X51.9451 Y80.4816 Z-1.0000 S1000
    G1 F1000 X51.7398 Y80.3355 Z-1.0000 S1000
    G1 F1000 X51.5300 Y80.1959 Z-1.0000 S1000
    G1 F1000 X51.3158 Y80.0632 Z-1.0000 S1000
    G1 F1000 X51.0975 Y79.9372 Z-1.0000 S1000
    G1 F1000 X50.8754 Y79.8183 Z-1.0000 S1000
    G1 F1000 X50.6496 Y79.7065 Z-1.0000 S1000
    G1 F1000 X50.4203 Y79.6019 Z-1.0000 S1000
    G1 F1000 X50.1879 Y79.5046 Z-1.0000 S1000
    G1 F1000 X49.9524 Y79.4148 Z-1.0000 S1000
    G1 F1000 X49.7143 Y79.3324 Z-1.0000 S1000
    G1 F1000 X49.4736 Y79.2577 Z-1.0000 S1000
    G1 F1000 X49.2307 Y79.1907 Z-1.0000 S1000
    G1 F1000 X48.9858 Y79.1314 Z-1.0000 S1000
    G1 F1000 X48.7392 Y79.0799 Z-1.0000 S1000
    G1 F1000 X48.4826 Y79.0349 Z-1.0000 S1000
    G1 F1000 X47.9662 Y78.9531 Z-1.0000 S1000
    G1 F1000 X43.4903 Y77.2347 Z-1.0000 S1000
    G1 F1000 X41.7168 Y76.0832 Z-1.0000 S1000
    G1 F1000 X41.5033 Y75.9494 Z-1.0000 S1000
    G1 F1000 X41.2857 Y75.8224 Z-1.0000 S1000
    G1 F1000 X41.0641 Y75.7023 Z-1.0000 S1000
    G1 F1000 X40.8389 Y75.5894 Z-1.0000 S1000
    G1 F1000 X40.6101 Y75.4837 Z-1.0000 S1000
    G1 F1000 X40.3782 Y75.3852 Z-1.0000 S1000
    G1 F1000 X40.1432 Y75.2942 Z-1.0000 S1000
    G1 F1000 X39.9054 Y75.2107 Z-1.0000 S1000
    G1 F1000 X39.6652 Y75.1348 Z-1.0000 S1000
    G1 F1000 X39.4226 Y75.0665 Z-1.0000 S1000
    G1 F1000 X39.1780 Y75.0060 Z-1.0000 S1000
    G1 F1000 X38.9316 Y74.9533 Z-1.0000 S1000
    G1 F1000 X38.6836 Y74.9084 Z-1.0000 S1000
    G1 F1000 X38.4344 Y74.8714 Z-1.0000 S1000
    G1 F1000 X38.1841 Y74.8424 Z-1.0000 S1000
    G1 F1000 X37.9330 Y74.8213 Z-1.0000 S1000
    G1 F1000 X37.6813 Y74.8082 Z-1.0000 S1000
    G1 F1000 X37.4294 Y74.8031 Z-1.0000 S1000
    G1 F1000 X37.1774 Y74.8060 Z-1.0000 S1000
    G1 F1000 X36.9257 Y74.8168 Z-1.0000 S1000
    G1 F1000 X36.6744 Y74.8357 Z-1.0000 S1000
    G1 F1000 X36.4238 Y74.8625 Z-1.0000 S1000
    G1 F1000 X36.1743 Y74.8973 Z-1.0000 S1000
    G1 F1000 X35.9259 Y74.9400 Z-1.0000 S1000
    G1 F1000 X35.7228 Y74.9816 Z-1.0000 S1000
    G1 F1000 X35.7462 Y74.8738 Z-1.0000 S1000
    G1 F1000 X35.7919 Y74.6260 Z-1.0000 S1000
    G1 F1000 X35.8298 Y74.3769 Z-1.0000 S1000
    G1 F1000 X35.8596 Y74.1267 Z-1.0000 S1000
    G1 F1000 X35.8816 Y73.8756 Z-1.0000 S1000
    G1 F1000 X35.8955 Y73.6240 Z-1.0000 S1000
    G1 F1000 X35.9015 Y73.3721 Z-1.0000 S1000
    G1 F1000 X35.8994 Y73.1202 Z-1.0000 S1000
    G1 F1000 X35.8894 Y72.8684 Z-1.0000 S1000
    G1 F1000 X35.8713 Y72.6170 Z-1.0000 S1000
    G1 F1000 X35.8453 Y72.3664 Z-1.0000 S1000
    G1 F1000 X35.8114 Y72.1167 Z-1.0000 S1000
    G1 F1000 X35.7695 Y71.8682 Z-1.0000 S1000
    G1 F1000 X35.7198 Y71.6212 Z-1.0000 S1000
    G1 F1000 X35.6623 Y71.3759 Z-1.0000 S1000
    G1 F1000 X35.5970 Y71.1325 Z-1.0000 S1000
    G1 F1000 X35.5240 Y70.8913 Z-1.0000 S1000
    G1 F1000 X35.4434 Y70.6526 Z-1.0000 S1000
    G1 F1000 X35.3553 Y70.4165 Z-1.0000 S1000
    G1 F1000 X35.2597 Y70.1833 Z-1.0000 S1000
    G1 F1000 X35.1567 Y69.9533 Z-1.0000 S1000
    G1 F1000 X35.0466 Y69.7267 Z-1.0000 S1000
    G1 F1000 X34.9292 Y69.5037 Z-1.0000 S1000
    G1 F1000 X34.8049 Y69.2846 Z-1.0000 S1000
    G1 F1000 X34.6215 Y68.9881 Z-1.0000 S1000
    G1 F1000 X33.4701 Y67.2147 Z-1.0000 S1000
    G1 F1000 X31.7516 Y62.7385 Z-1.0000 S1000
    G1 F1000 X31.6698 Y62.2221 Z-1.0000 S1000
    G1 F1000 X31.6264 Y61.9739 Z-1.0000 S1000
    G1 F1000 X31.5752 Y61.7272 Z-1.0000 S1000
    G1 F1000 X31.5162 Y61.4822 Z-1.0000 S1000
    G1 F1000 X31.4494 Y61.2392 Z-1.0000 S1000
    G1 F1000 X31.3749 Y60.9985 Z-1.0000 S1000
    G1 F1000 X31.2928 Y60.7602 Z-1.0000 S1000
    G1 F1000 X31.2033 Y60.5247 Z-1.0000 S1000
    G1 F1000 X31.1062 Y60.2922 Z-1.0000 S1000
    G1 F1000 X31.0019 Y60.0628 Z-1.0000 S1000
    G1 F1000 X30.8903 Y59.8369 Z-1.0000 S1000
    G1 F1000 X30.7716 Y59.6146 Z-1.0000 S1000
    G1 F1000 X30.6459 Y59.3962 Z-1.0000 S1000
    G1 F1000 X30.5133 Y59.1819 Z-1.0000 S1000
    G1 F1000 X30.3741 Y58.9719 Z-1.0000 S1000
    G1 F1000 X30.2282 Y58.7665 Z-1.0000 S1000
    G1 F1000 X30.0758 Y58.5657 Z-1.0000 S1000
    G1 F1000 X29.9172 Y58.3700 Z-1.0000 S1000
    G1 F1000 X29.7524 Y58.1793 Z-1.0000 S1000
    G1 F1000 X29.5817 Y57.9940 Z-1.0000 S1000
    G1 F1000 X29.4051 Y57.8142 Z-1.0000 S1000
    G1 F1000 X29.2230 Y57.6401 Z-1.0000 S1000
    G1 F1000 X29.0354 Y57.4718 Z-1.0000 S1000
    G1 F1000 X28.8426 Y57.3096 Z-1.0000 S1000
    G1 F1000 X28.6447 Y57.1536 Z-1.0000 S1000
    G1 F1000 X28.4419 Y57.0040 Z-1.0000 S1000
    G1 F1000 X28.2346 Y56.8608 Z-1.0000 S1000
    G1 F1000 X28.1593 Y56.8123 Z-1.0000 S1000
    G1 F1000 X28.2569 Y56.7495 Z-1.0000 S1000
    G1 F1000 X28.4644 Y56.6066 Z-1.0000 S1000
    G1 F1000 X28.6673 Y56.4572 Z-1.0000 S1000
    G1 F1000 X28.8654 Y56.3014 Z-1.0000 S1000
    G1 F1000 X29.0584 Y56.1394 Z-1.0000 S1000
    G1 F1000 X29.2461 Y55.9714 Z-1.0000 S1000
    G1 F1000 X29.4285 Y55.7975 Z-1.0000 S1000
    G1 F1000 X29.6052 Y55.6179 Z-1.0000 S1000
    G1 F1000 X29.7762 Y55.4327 Z-1.0000 S1000
    G1 F1000 X29.9411 Y55.2423 Z-1.0000 S1000
    G1 F1000 X30.1000 Y55.0467 Z-1.0000 S1000
    G1 F1000 X30.2526 Y54.8461 Z-1.0000 S1000
    G1 F1000 X30.3987 Y54.6408 Z-1.0000 S1000
    G1 F1000 X30.5382 Y54.4310 Z-1.0000 S1000
    G1 F1000 X30.6710 Y54.2168 Z-1.0000 S1000
    G1 F1000 X30.7969 Y53.9986 Z-1.0000 S1000
    G1 F1000 X30.9159 Y53.7764 Z-1.0000 S1000
    G1 F1000 X31.0277 Y53.5506 Z-1.0000 S1000
    G1 F1000 X31.1323 Y53.3214 Z-1.0000 S1000
    G1 F1000 X31.2296 Y53.0889 Z-1.0000 S1000
    G1 F1000 X31.3194 Y52.8535 Z-1.0000 S1000
    G1 F1000 X31.4018 Y52.6154 Z-1.0000 S1000
    G1 F1000 X31.4765 Y52.3747 Z-1.0000 S1000
    G1 F1000 X31.5267 Y52.1956 Z-1.0000 S1000
    G1 F1000 X32.4934 Y48.5879 Z-1.0000 S1000
    G1 F1000 X34.9439 Y43.7782 Z-1.0000 S1000
    G1 F1000 X35.0548 Y43.5519 Z-1.0000 S1000
    G1 F1000 X35.1583 Y43.3222 Z-1.0000 S1000
    G1 F1000 X35.2546 Y43.0893 Z-1.0000 S1000
    G1 F1000 X35.3434 Y42.8535 Z-1.0000 S1000
    G1 F1000 X35.4246 Y42.6150 Z-1.0000 S1000
    G1 F1000 X35.4983 Y42.3740 Z-1.0000 S1000
    G1 F1000 X35.5642 Y42.1308 Z-1.0000 S1000
    G1 F1000 X35.6224 Y41.8856 Z-1.0000 S1000
    G1 F1000 X35.6728 Y41.6387 Z-1.0000 S1000
    G1 F1000 X35.7154 Y41.3903 Z-1.0000 S1000
    G1 F1000 X35.7500 Y41.1408 Z-1.0000 S1000
    G1 F1000 X35.7767 Y40.8902 Z-1.0000 S1000
    G1 F1000 X35.7954 Y40.6389 Z-1.0000 S1000
    G1 F1000 X35.8062 Y40.3871 Z-1.0000 S1000
    G1 F1000 X35.8089 Y40.1352 Z-1.0000 S1000
    G1 F1000 X35.8036 Y39.8832 Z-1.0000 S1000
    G1 F1000 X35.7904 Y39.6316 Z-1.0000 S1000
    G1 F1000 X35.7692 Y39.3805 Z-1.0000 S1000
    G1 F1000 X35.7400 Y39.1302 Z-1.0000 S1000
    G1 F1000 X35.7028 Y38.8810 Z-1.0000 S1000
    G1 F1000 X35.6578 Y38.6331 Z-1.0000 S1000
    G1 F1000 X35.6386 Y38.5434 Z-1.0000 S1000
    G1 F1000 X35.7069 Y38.5582 Z-1.0000 S1000
    G1 F1000 X35.9547 Y38.6039 Z-1.0000 S1000
    G1 F1000 X36.2038 Y38.6418 Z-1.0000 S1000
    G1 F1000 X36.4540 Y38.6716 Z-1.0000 S1000
    G1 F1000 X36.7050 Y38.6936 Z-1.0000 S1000
    G1 F1000 X36.9566 Y38.7075 Z-1.0000 S1000
    G1 F1000 X37.2085 Y38.7135 Z-1.0000 S1000
    G1 F1000 X37.4605 Y38.7114 Z-1.0000 S1000
    G1 F1000 X37.6975 Y38.7020 Z-1.0000 S1000
    G1 F1000 X40.0824 Y43.8164 Z-1.0000 S1000
    G1 F1000 X40.0213 Y43.8867 Z-1.0000 S1000
    G1 F1000 X39.9248 Y44.0036 Z-1.0000 S1000
    G1 F1000 X38.4725 Y45.7973 Z-1.0000 S1000
    G1 F1000 X38.3170 Y45.9956 Z-1.0000 S1000
    G1 F1000 X38.1680 Y46.1988 Z-1.0000 S1000
    G1 F1000 X38.0254 Y46.4066 Z-1.0000 S1000
    G1 F1000 X37.8895 Y46.6188 Z-1.0000 S1000
    G1 F1000 X37.7605 Y46.8352 Z-1.0000 S1000
    G1 F1000 X37.6383 Y47.0556 Z-1.0000 S1000
    G1 F1000 X37.5689 Y47.1888 Z-1.0000 S1000
    G1 F1000 X36.5214 Y49.2448 Z-1.0000 S1000
    G1 F1000 X36.4106 Y49.4711 Z-1.0000 S1000
    G1 F1000 X36.3070 Y49.7008 Z-1.0000 S1000
    G1 F1000 X36.2108 Y49.9337 Z-1.0000 S1000
    G1 F1000 X36.1220 Y50.1695 Z-1.0000 S1000
    G1 F1000 X36.0408 Y50.4080 Z-1.0000 S1000
    G1 F1000 X35.9671 Y50.6490 Z-1.0000 S1000
    G1 F1000 X35.9268 Y50.7941 Z-1.0000 S1000
    G1 F1000 X35.3294 Y53.0241 Z-1.0000 S1000
    G1 F1000 X35.2680 Y53.2685 Z-1.0000 S1000
    G1 F1000 X35.2145 Y53.5148 Z-1.0000 S1000
    G1 F1000 X35.1688 Y53.7626 Z-1.0000 S1000
    G1 F1000 X35.1310 Y54.0117 Z-1.0000 S1000
    G1 F1000 X35.1011 Y54.2619 Z-1.0000 S1000
    G1 F1000 X35.0791 Y54.5129 Z-1.0000 S1000
    G1 F1000 X35.0699 Y54.6619 Z-1.0000 S1000
    G1 F1000 X34.9489 Y56.9665 Z-1.0000 S1000
    G1 F1000 X34.9397 Y57.2183 Z-1.0000 S1000
    G1 F1000 X34.9385 Y57.4703 Z-1.0000 S1000
    G1 F1000 X34.9453 Y57.7222 Z-1.0000 S1000
    G1 F1000 X34.9600 Y57.9738 Z-1.0000 S1000
    G1 F1000 X34.9828 Y58.2247 Z-1.0000 S1000
    G1 F1000 X35.0135 Y58.4748 Z-1.0000 S1000
    G1 F1000 X35.0358 Y58.6249 Z-1.0000 S1000
    G1 F1000 X35.3970 Y60.9044 Z-1.0000 S1000
    G1 F1000 X35.4404 Y61.1527 Z-1.0000 S1000
    G1 F1000 X35.4916 Y61.3994 Z-1.0000 S1000
    G1 F1000 X35.5507 Y61.6444 Z-1.0000 S1000
    G1 F1000 X35.6175 Y61.8873 Z-1.0000 S1000
    G1 F1000 X35.6919 Y62.1281 Z-1.0000 S1000
    G1 F1000 X35.7740 Y62.3663 Z-1.0000 S1000
    G1 F1000 X35.8265 Y62.5071 Z-1.0000 S1000
    G1 F1000 X36.6536 Y64.6615 Z-1.0000 S1000
    G1 F1000 X36.7477 Y64.8952 Z-1.0000 S1000
    G1 F1000 X36.8491 Y65.1259 Z-1.0000 S1000
    G1 F1000 X36.9577 Y65.3533 Z-1.0000 S1000
    G1 F1000 X37.0736 Y65.5770 Z-1.0000 S1000
    G1 F1000 X37.1965 Y65.7970 Z-1.0000 S1000
    G1 F1000 X37.3263 Y66.0130 Z-1.0000 S1000
    G1 F1000 X37.4073 Y66.1403 Z-1.0000 S1000
    G1 F1000 X38.6645 Y68.0758 Z-1.0000 S1000
    G1 F1000 X38.8051 Y68.2849 Z-1.0000 S1000
    G1 F1000 X38.9522 Y68.4895 Z-1.0000 S1000
    G1 F1000 X39.1058 Y68.6893 Z-1.0000 S1000
    G1 F1000 X39.2657 Y68.8841 Z-1.0000 S1000
    G1 F1000 X39.4316 Y69.0737 Z-1.0000 S1000
    G1 F1000 X39.6035 Y69.2579 Z-1.0000 S1000
    G1 F1000 X39.7083 Y69.3648 Z-1.0000 S1000
    G1 F1000 X41.3399 Y70.9964 Z-1.0000 S1000
    G1 F1000 X41.5209 Y71.1717 Z-1.0000 S1000
    G1 F1000 X41.7074 Y71.3412 Z-1.0000 S1000
    G1 F1000 X41.8991 Y71.5047 Z-1.0000 S1000
    G1 F1000 X42.0960 Y71.6620 Z-1.0000 S1000
    G1 F1000 X42.2977 Y71.8130 Z-1.0000 S1000
    G1 F1000 X42.5041 Y71.9575 Z-1.0000 S1000
    G1 F1000 X42.6289 Y72.0402 Z-1.0000 S1000
    G1 F1000 X44.5644 Y73.2974 Z-1.0000 S1000
    G1 F1000 X44.7778 Y73.4313 Z-1.0000 S1000
    G1 F1000 X44.9955 Y73.5584 Z-1.0000 S1000
    G1 F1000 X45.2170 Y73.6784 Z-1.0000 S1000
    G1 F1000 X45.4422 Y73.7914 Z-1.0000 S1000
    G1 F1000 X45.6709 Y73.8972 Z-1.0000 S1000
    G1 F1000 X45.9029 Y73.9957 Z-1.0000 S1000
    G1 F1000 X46.0432 Y74.0511 Z-1.0000 S1000
    G1 F1000 X48.1976 Y74.8782 Z-1.0000 S1000
    G1 F1000 X48.4343 Y74.9647 Z-1.0000 S1000
    G1 F1000 X48.6736 Y75.0438 Z-1.0000 S1000
    G1 F1000 X48.9152 Y75.1151 Z-1.0000 S1000
    G1 F1000 X49.1590 Y75.1788 Z-1.0000 S1000
    G1 F1000 X49.4047 Y75.2347 Z-1.0000 S1000
    G1 F1000 X49.6521 Y75.2828 Z-1.0000 S1000
    G1 F1000 X49.8003 Y75.3077 Z-1.0000 S1000
    G1 F1000 X52.0798 Y75.6689 Z-1.0000 S1000
    G1 F1000 X52.3292 Y75.7044 Z-1.0000 S1000
    G1 F1000 X52.5797 Y75.7319 Z-1.0000 S1000
    G1 F1000 X52.8309 Y75.7515 Z-1.0000 S1000
    G1 F1000 X53.0826 Y75.7631 Z-1.0000 S1000
    G1 F1000 X53.3346 Y75.7667 Z-1.0000 S1000
    G1 F1000 X53.5865 Y75.7623 Z-1.0000 S1000
    G1 F1000 X53.7382 Y75.7558 Z-1.0000 S1000
    G1 F1000 X56.0428 Y75.6348 Z-1.0000 S1000
    G1 F1000 X56.2942 Y75.6176 Z-1.0000 S1000
    G1 F1000 X56.5449 Y75.5924 Z-1.0000 S1000
    G1 F1000 X56.7947 Y75.5593 Z-1.0000 S1000
    G1 F1000 X57.0433 Y75.5182 Z-1.0000 S1000
    G1 F1000 X57.2905 Y75.4693 Z-1.0000 S1000
    G1 F1000 X57.5360 Y75.4126 Z-1.0000 S1000
    G1 F1000 X57.6806 Y75.3753 Z-1.0000 S1000
    G1 F1000 X59.9106 Y74.7779 Z-1.0000 S1000
    G1 F1000 X60.1529 Y74.7089 Z-1.0000 S1000
    G1 F1000 X60.3929 Y74.6322 Z-1.0000 S1000
    G1 F1000 X60.6304 Y74.5479 Z-1.0000 S1000
    G1 F1000 X60.8651 Y74.4561 Z-1.0000 S1000
    G1 F1000 X61.0967 Y74.3569 Z-1.0000 S1000
    G1 F1000 X61.3251 Y74.2504 Z-1.0000 S1000
    G1 F1000 X61.4599 Y74.1833 Z-1.0000 S1000
    G1 F1000 X63.5159 Y73.1358 Z-1.0000 S1000
    G1 F1000 X63.7386 Y73.0178 Z-1.0000 S1000
    G1 F1000 X63.9574 Y72.8929 Z-1.0000 S1000
    G1 F1000 X64.1722 Y72.7611 Z-1.0000 S1000
    G1 F1000 X64.3826 Y72.6225 Z-1.0000 S1000
    G1 F1000 X64.5886 Y72.4773 Z-1.0000 S1000
    G1 F1000 X64.7898 Y72.3256 Z-1.0000 S1000
    G1 F1000 X64.9074 Y72.2322 Z-1.0000 S1000
    G1 F1000 X66.7011 Y70.7799 Z-1.0000 S1000
    G1 F1000 X66.8944 Y70.6183 Z-1.0000 S1000
    G1 F1000 X67.0825 Y70.4506 Z-1.0000 S1000
    G1 F1000 X67.2651 Y70.2770 Z-1.0000 S1000
    G1 F1000 X67.4422 Y70.0977 Z-1.0000 S1000
    G1 F1000 X67.6134 Y69.9129 Z-1.0000 S1000
    G1 F1000 X67.7787 Y69.7227 Z-1.0000 S1000
    G1 F1000 X67.8752 Y69.6058 Z-1.0000 S1000
    G1 F1000 X69.3275 Y67.8121 Z-1.0000 S1000
    G1 F1000 X69.4830 Y67.6138 Z-1.0000 S1000
    G1 F1000 X69.6320 Y67.4106 Z-1.0000 S1000
    G1 F1000 X69.7746 Y67.2028 Z-1.0000 S1000
    G1 F1000 X69.9105 Y66.9906 Z-1.0000 S1000
    G1 F1000 X70.0395 Y66.7742 Z-1.0000 S1000
    G1 F1000 X70.1617 Y66.5538 Z-1.0000 S1000
    G1 F1000 X70.2311 Y66.4206 Z-1.0000 S1000
    G1 F1000 X71.2786 Y64.3646 Z-1.0000 S1000
    G1 F1000 X71.3894 Y64.1383 Z-1.0000 S1000
    G1 F1000 X71.4930 Y63.9086 Z-1.0000 S1000
    G1 F1000 X71.5892 Y63.6757 Z-1.0000 S1000
    G1 F1000 X71.6780 Y63.4399 Z-1.0000 S1000
    G1 F1000 X71.7592 Y63.2014 Z-1.0000 S1000
    G1 F1000 X71.8329 Y62.9604 Z-1.0000 S1000
    G1 F1000 X71.8732 Y62.8153 Z-1.0000 S1000
    G1 F1000 X72.4706 Y60.5853 Z-1.0000 S1000
    G1 F1000 X72.5320 Y60.3409 Z-1.0000 S1000
    G1 F1000 X72.5855 Y60.0946 Z-1.0000 S1000
    G1 F1000 X72.6312 Y59.8468 Z-1.0000 S1000
    G1 F1000 X72.6690 Y59.5977 Z-1.0000 S1000
    G1 F1000 X72.6989 Y59.3475 Z-1.0000 S1000
    G1 F1000 X72.7209 Y59.0965 Z-1.0000 S1000
    G1 F1000 X72.7301 Y58.9475 Z-1.0000 S1000
    G1 F1000 X72.8511 Y56.6429 Z-1.0000 S1000
    G1 F1000 X72.8603 Y56.3911 Z-1.0000 S1000
    G1 F1000 X72.8615 Y56.1391 Z-1.0000 S1000
    G1 F1000 X72.8547 Y55.8872 Z-1.0000 S1000
    G1 F1000 X72.8400 Y55.6356 Z-1.0000 S1000
    G1 F1000 X72.8172 Y55.3847 Z-1.0000 S1000
    G1 F1000 X72.7865 Y55.1346 Z-1.0000 S1000
    G1 F1000 X72.7642 Y54.9845 Z-1.0000 S1000
    G1 F1000 X72.4030 Y52.7050 Z-1.0000 S1000
    G1 F1000 X72.3596 Y52.4567 Z-1.0000 S1000
    G1 F1000 X72.3084 Y52.2100 Z-1.0000 S1000
    G1 F1000 X72.2493 Y51.9650 Z-1.0000 S1000
    G1 F1000 X72.1825 Y51.7221 Z-1.0000 S1000
    G1 F1000 X72.1081 Y51.4813 Z-1.0000 S1000
    G1 F1000 X72.0260 Y51.2431 Z-1.0000 S1000
    G1 F1000 X71.9735 Y51.1023 Z-1.0000 S1000
    G1 F1000 X71.1464 Y48.9479 Z-1.0000 S1000
    G1 F1000 X71.0523 Y48.7142 Z-1.0000 S1000
    G1 F1000 X70.9509 Y48.4835 Z-1.0000 S1000
    G1 F1000 X70.8423 Y48.2561 Z-1.0000 S1000
    G1 F1000 X70.7264 Y48.0324 Z-1.0000 S1000
    G1 F1000 X70.6035 Y47.8124 Z-1.0000 S1000
    G1 F1000 X70.4737 Y47.5964 Z-1.0000 S1000
    G1 F1000 X70.3927 Y47.4691 Z-1.0000 S1000
    G1 F1000 X69.1355 Y45.5336 Z-1.0000 S1000
    G1 F1000 X68.9949 Y45.3245 Z-1.0000 S1000
    G1 F1000 X68.8478 Y45.1199 Z-1.0000 S1000
    G1 F1000 X68.6942 Y44.9201 Z-1.0000 S1000
    G1 F1000 X68.5343 Y44.7253 Z-1.0000 S1000
    G1 F1000 X68.3754 Y44.5437 Z-1.0000 S1000
    G1 F700 Z-2.0000
    G1 F1000 X71.0638 Y38.7783 Z-2.0000 S1000
    G1 F1000 X71.1256 Y38.7737 Z-2.0000 S1000
    G1 F1000 X71.3762 Y38.7469 Z-2.0000 S1000
    G1 F1000 X71.6257 Y38.7121 Z-2.0000 S1000
    G1 F1000 X71.8741 Y38.6694 Z-2.0000 S1000
    G1 F1000 X72.0772 Y38.6278 Z-2.0000 S1000
    G1 F1000 X72.0537 Y38.7357 Z-2.0000 S1000
    G1 F1000 X72.0080 Y38.9835 Z-2.0000 S1000
    G1 F1000 X71.9702 Y39.2327 Z-2.0000 S1000
    G1 F1000 X71.9404 Y39.4829 Z-2.0000 S1000
    G1 F1000 X71.9184 Y39.7339 Z-2.0000 S1000
    G1 F1000 X71.9045 Y39.9855 Z-2.0000 S1000
    G1 F1000 X71.8985 Y40.2374 Z-2.0000 S1000
    G1 F1000 X71.9006 Y40.4894 Z-2.0000 S1000
    G1 F1000 X71.9106 Y40.7412 Z-2.0000 S1000
    G1 F1000 X71.9287 Y40.9925 Z-2.0000 S1000
    G1 F1000 X71.9547 Y41.2432 Z-2.0000 S1000
    G1 F1000 X71.9886 Y41.4928 Z-2.0000 S1000
    G1 F1000 X72.0305 Y41.7413 Z-2.0000 S1000
    G1 F1000 X72.0802 Y41.9884 Z-2.0000 S1000
    G1 F1000 X72.1377 Y42.2337 Z-2.0000 S1000
    G1 F1000 X72.2030 Y42.4771 Z-2.0000 S1000
    G1 F1000 X72.2760 Y42.7182 Z-2.0000 S1000
    G1 F1000 X72.3566 Y42.9570 Z-2.0000 S1000
    G1 F1000 X72.4447 Y43.1931 Z-2.0000 S1000
    G1 F1000 X72.5403 Y43.4262 Z-2.0000 S1000
    G1 F1000 X72.6433 Y43.6562 Z-2.0000 S1000
    G1 F1000 X72.7535 Y43.8828 Z-2.0000 S1000
    G1 F1000 X72.8708 Y44.1058 Z-2.0000 S1000
    G1 F1000 X72.9951 Y44.3250 Z-2.0000 S1000
    G1 F1000 X73.1785 Y44.6215 Z-2.0000 S1000
    G1 F1000 X74.3300 Y46.3950 Z-2.0000 S1000
    G1 F1000 X76.0484 Y50.8709 Z-2.0000 S1000
    G1 F1000 X76.1302 Y51.3873 Z-2.0000 S1000
    G1 F1000 X76.1736 Y51.6355 Z-2.0000 S1000
    G1 F1000 X76.2248 Y51.8822 Z-2.0000 S1000
    G1 F1000 X76.2838 Y52.1272 Z-2.0000 S1000
    G1 F1000 X76.3506 Y52.3702 Z-2.0000 S1000
    G1 F1000 X76.4251 Y52.6109 Z-2.0000 S1000
    G1 F1000 X76.5072 Y52.8492 Z-2.0000 S1000
    G1 F1000 X76.5967 Y53.0847 Z-2.0000 S1000
    G1 F1000 X76.6938 Y53.3172 Z-2.0000 S1000
    G1 F1000 X76.7981 Y53.5466 Z-2.0000 S1000
    G1 F1000 X76.9097 Y53.7725 Z-2.0000 S1000
    G1 F1000 X77.0284 Y53.9948 Z-2.0000 S1000
    G1 F1000 X77.1541 Y54.2132 Z-2.0000 S1000
    G1 F1000 X77.2867 Y54.4275 Z-2.0000 S1000
    G1 F1000 X77.4259 Y54.6375 Z-2.0000 S1000
    G1 F1000 X77.5718 Y54.8429 Z-2.0000 S1000
    G1 F1000 X77.7242 Y55.0437 Z-2.0000 S1000
    G1 F1000 X77.8828 Y55.2394 Z-2.0000 S1000
    G1 F1000 X78.0476 Y55.4301 Z-2.0000 S1000
    G1 F1000 X78.2183 Y55.6154 Z-2.0000 S1000
    G1 F1000 X78.3949 Y55.7952 Z-2.0000 S1000
    G1 F1000 X78.5770 Y55.9693 Z-2.0000 S1000
    G1 F1000 X78.7646 Y56.1376 Z-2.0000 S1000
    G1 F1000 X78.9574 Y56.2998 Z-2.0000 S1000
    G1 F1000 X79.1553 Y56.4558 Z-2.0000 S1000
    G1 F1000 X79.3581 Y56.6054 Z-2.0000 S1000
    G1 F1000 X79.5654 Y56.7486 Z-2.0000 S1000
    G1 F1000 X79.6408 Y56.7972 Z-2.0000 S1000
    G1 F1000 X79.5431 Y56.8600 Z-2.0000 S1000
    G1 F1000 X79.3355 Y57.0029 Z-2.0000 S1000
    G1 F1000 X79.1326 Y57.1523 Z-2.0000 S1000
    G1 F1000 X78.9346 Y57.3081 Z-2.0000 S1000
    G1 F1000 X78.7416 Y57.4701 Z-2.0000 S1000
    G1 F1000 X78.5538 Y57.6381 Z-2.0000 S1000
    G1 F1000 X78.3715 Y57.8121 Z-2.0000 S1000
    G1 F1000 X78.1947 Y57.9917 Z-2.0000 S1000
    G1 F1000 X78.0238 Y58.1768 Z-2.0000 S1000
    G1 F1000 X77.8588 Y58.3673 Z-2.0000 S1000
    G1 F1000 X77.7000 Y58.5629 Z-2.0000 S1000
    G1 F1000 X77.5474 Y58.7634 Z-2.0000 S1000
    G1 F1000 X77.4013 Y58.9687 Z-2.0000 S1000
    G1 F1000 X77.2618 Y59.1786 Z-2.0000 S1000
    G1 F1000 X77.1290 Y59.3927 Z-2.0000 S1000
    G1 F1000 X77.0030 Y59.6110 Z-2.0000 S1000
    G1 F1000 X76.8841 Y59.8331 Z-2.0000 S1000
    G1 F1000 X76.7723 Y60.0589 Z-2.0000 S1000
    G1 F1000 X76.6677 Y60.2882 Z-2.0000 S1000
    G1 F1000 X76.5704 Y60.5206 Z-2.0000 S1000
    G1 F1000 X76.4805 Y60.7561 Z-2.0000 S1000
    G1 F1000 X76.3982 Y60.9942 Z-2.0000 S1000
    G1 F1000 X76.3235 Y61.2349 Z-2.0000 S1000
    G1 F1000 X76.2733 Y61.4139 Z-2.0000 S1000
    G1 F1000 X75.3067 Y65.0214 Z-2.0000 S1000
    G1 F1000 X72.8561 Y69.8311 Z-2.0000 S1000
    G1 F1000 X72.7453 Y70.0575 Z-2.0000 S1000
    G1 F1000 X72.6417 Y70.2872 Z-2.0000 S1000
    G1 F1000 X72.5455 Y70.5200 Z-2.0000 S1000
    G1 F1000 X72.4567 Y70.7559 Z-2.0000 S1000
    G1 F1000 X72.3754 Y70.9944 Z-2.0000 S1000
    G1 F1000 X72.3018 Y71.2354 Z-2.0000 S1000
    G1 F1000 X72.2358 Y71.4786 Z-2.0000 S1000
    G1 F1000 X72.1776 Y71.7237 Z-2.0000 S1000
    G1 F1000 X72.1272 Y71.9706 Z-2.0000 S1000
    G1 F1000 X72.0846 Y72.2190 Z-2.0000 S1000
    G1 F1000 X72.0500 Y72.4686 Z-2.0000 S1000
    G1 F1000 X72.0233 Y72.7192 Z-2.0000 S1000
    G1 F1000 X72.0046 Y72.9704 Z-2.0000 S1000
    G1 F1000 X71.9938 Y73.2222 Z-2.0000 S1000
    G1 F1000 X71.9911 Y73.4742 Z-2.0000 S1000
    G1 F1000 X71.9964 Y73.7261 Z-2.0000 S1000
    G1 F1000 X72.0096 Y73.9777 Z-2.0000 S1000
    G1 F1000 X72.0308 Y74.2288 Z-2.0000 S1000
    G1 F1000 X72.0600 Y74.4791 Z-2.0000 S1000
    G1 F1000 X72.0971 Y74.7283 Z-2.0000 S1000
    G1 F1000 X72.1422 Y74.9763 Z-2.0000 S1000
    G1 F1000 X72.1614 Y75.0660 Z-2.0000 S1000
    G1 F1000 X72.0932 Y75.0512 Z-2.0000 S1000
    G1 F1000 X71.8454 Y75.0055 Z-2.0000 S1000
    G1 F1000 X71.5963 Y74.9677 Z-2.0000 S1000
    G1 F1000 X71.3461 Y74.9378 Z-2.0000 S1000
    G1 F1000 X71.0950 Y74.9158 Z-2.0000 S1000
    G1 F1000 X70.8434 Y74.9019 Z-2.0000 S1000
    G1 F1000 X70.5915 Y74.8959 Z-2.0000 S1000
    G1 F1000 X70.3396 Y74.8980 Z-2.0000 S1000
    G1 F1000 X70.0878 Y74.9080 Z-2.0000 S1000
    G1 F1000 X69.8364 Y74.9261 Z-2.0000 S1000
    G1 F1000 X69.5858 Y74.9520 Z-2.0000 S1000
    G1 F1000 X69.3361 Y74.9860 Z-2.0000 S1000
    G1 F1000 X69.0876 Y75.0278 Z-2.0000 S1000
    G1 F1000 X68.8406 Y75.0775 Z-2.0000 S1000
    G1 F1000 X68.5953 Y75.1351 Z-2.0000 S1000
    G1 F1000 X68.3519 Y75.2004 Z-2.0000 S1000
    G1 F1000 X68.1107 Y75.2733 Z-2.0000 S1000
    G1 F1000 X67.8719 Y75.3539 Z-2.0000 S1000
    G1 F1000 X67.6359 Y75.4421 Z-2.0000 S1000
    G1 F1000 X67.4027 Y75.5377 Z-2.0000 S1000
    G1 F1000 X67.1727 Y75.6406 Z-2.0000 S1000
    G1 F1000 X66.9264 Y75.7608 Z-2.0000 S1000
    G1 F1000 X62.1167 Y78.2114 Z-2.0000 S1000
    G1 F1000 X58.5092 Y79.1780 Z-2.0000 S1000
    G1 F1000 X58.2668 Y79.2470 Z-2.0000 S1000
    G1 F1000 X58.0268 Y79.3238 Z-2.0000 S1000
    G1 F1000 X57.7893 Y79.4081 Z-2.0000 S1000
    G1 F1000 X57.5547 Y79.4999 Z-2.0000 S1000
    G1 F1000 X57.3230 Y79.5991 Z-2.0000 S1000
    G1 F1000 X57.0947 Y79.7056 Z-2.0000 S1000
    G1 F1000 X56.8698 Y79.8193 Z-2.0000 S1000
    G1 F1000 X56.6487 Y79.9401 Z-2.0000 S1000
    G1 F1000 X56.4315 Y80.0678 Z-2.0000 S1000
    G1 F1000 X56.2184 Y80.2024 Z-2.0000 S1000
    G1 F1000 X56.0098 Y80.3437 Z-2.0000 S1000
    G1 F1000 X55.8057 Y80.4915 Z-2.0000 S1000
    G1 F1000 X55.6064 Y80.6457 Z-2.0000 S1000
    G1 F1000 X55.4121 Y80.8062 Z-2.0000 S1000
    G1 F1000 X55.2230 Y80.9727 Z-2.0000 S1000
    G1 F1000 X55.0393 Y81.1452 Z-2.0000 S1000
    G1 F1000 X54.8612 Y81.3234 Z-2.0000 S1000
    G1 F1000 X54.6888 Y81.5072 Z-2.0000 S1000
    G1 F1000 X54.5223 Y81.6964 Z-2.0000 S1000
    G1 F1000 X54.3619 Y81.8907 Z-2.0000 S1000
    G1 F1000 X54.2078 Y82.0901 Z-2.0000 S1000
    G1 F1000 X54.0601 Y82.2942 Z-2.0000 S1000
    G1 F1000 X53.9189 Y82.5030 Z-2.0000 S1000
    G1 F1000 X53.8923 Y82.5452 Z-2.0000 S1000
    G1 F1000 X53.8486 Y82.4772 Z-2.0000 S1000
    G1 F1000 X53.7057 Y82.2697 Z-2.0000 S1000
    G1 F1000 X53.5563 Y82.0668 Z-2.0000 S1000
    G1 F1000 X53.4005 Y81.8687 Z-2.0000 S1000
    G1 F1000 X53.2385 Y81.6757 Z-2.0000 S1000
    G1 F1000 X53.0704 Y81.4879 Z-2.0000 S1000
    G1 F1000 X52.8965 Y81.3056 Z-2.0000 S1000
    G1 F1000 X52.7169 Y81.1289 Z-2.0000 S1000
    G1 F1000 X52.5317 Y80.9579 Z-2.0000 S1000
    G1 F1000 X52.3413 Y80.7930 Z-2.0000 S1000
    G1 F1000 X52.1456 Y80.6341 Z-2.0000 S1000
    G1 F1000 X51.9451 Y80.4816 Z-2.0000 S1000
    G1 F1000 X51.7398 Y80.3355 Z-2.0000 S1000
    G1 F1000 X51.5300 Y80.1959 Z-2.0000 S1000
    G1 F1000 X51.3158 Y80.0632 Z-2.0000 S1000
    G1 F1000 X51.0975 Y79.9372 Z-2.0000 S1000
    G1 F1000 X50.8754 Y79.8183 Z-2.0000 S1000
    G1 F1000 X50.6496 Y79.7065 Z-2.0000 S1000
    G1 F1000 X50.4203 Y79.6019 Z-2.0000 S1000
    G1 F1000 X50.1879 Y79.5046 Z-2.0000 S1000
    G1 F1000 X49.9524 Y79.4148 Z-2.0000 S1000
    G1 F1000 X49.7143 Y79.3324 Z-2.0000 S1000
    G1 F1000 X49.4736 Y79.2577 Z-2.0000 S1000
    G1 F1000 X49.2307 Y79.1907 Z-2.0000 S1000
    G1 F1000 X48.9858 Y79.1314 Z-2.0000 S1000
    G1 F1000 X48.7392 Y79.0799 Z-2.0000 S1000
    G1 F1000 X48.4826 Y79.0349 Z-2.0000 S1000
    G1 F1000 X47.9662 Y78.9531 Z-2.0000 S1000
    G1 F1000 X43.4903 Y77.2347 Z-2.0000 S1000
    G1 F1000 X41.7168 Y76.0832 Z-2.0000 S1000
    G1 F1000 X41.5033 Y75.9494 Z-2.0000 S1000
    G1 F1000 X41.2857 Y75.8224 Z-2.0000 S1000
    G1 F1000 X41.0641 Y75.7023 Z-2.0000 S1000
    G1 F1000 X40.8389 Y75.5894 Z-2.0000 S1000
    G1 F1000 X40.6101 Y75.4837 Z-2.0000 S1000
    G1 F1000 X40.3782 Y75.3852 Z-2.0000 S1000
    G1 F1000 X40.1432 Y75.2942 Z-2.0000 S1000
    G1 F1000 X39.9054 Y75.2107 Z-2.0000 S1000
    G1 F1000 X39.6652 Y75.1348 Z-2.0000 S1000
    G1 F1000 X39.4226 Y75.0665 Z-2.0000 S1000
    G1 F1000 X39.1780 Y75.0060 Z-2.0000 S1000
    G1 F1000 X38.9316 Y74.9533 Z-2.0000 S1000
    G1 F1000 X38.6836 Y74.9084 Z-2.0000 S1000
    G1 F1000 X38.4344 Y74.8714 Z-2.0000 S1000
    G1 F1000 X38.1841 Y74.8424 Z-2.0000 S1000
    G1 F1000 X37.9330 Y74.8213 Z-2.0000 S1000
    G1 F1000 X37.6813 Y74.8082 Z-2.0000 S1000
    G1 F1000 X37.4294 Y74.8031 Z-2.0000 S1000
    G1 F1000 X37.1774 Y74.8060 Z-2.0000 S1000
    G1 F1000 X36.9257 Y74.8168 Z-2.0000 S1000
    G1 F1000 X36.6744 Y74.8357 Z-2.0000 S1000
    G1 F1000 X36.4238 Y74.8625 Z-2.0000 S1000
    G1 F1000 X36.1743 Y74.8973 Z-2.0000 S1000
    G1 F1000 X35.9259 Y74.9400 Z-2.0000 S1000
    G1 F1000 X35.7228 Y74.9816 Z-2.0000 S1000
    G1 F1000 X35.7462 Y74.8738 Z-2.0000 S1000
    G1 F1000 X35.7919 Y74.6260 Z-2.0000 S1000
    G1 F1000 X35.8298 Y74.3769 Z-2.0000 S1000
    G1 F1000 X35.8596 Y74.1267 Z-2.0000 S1000
    G1 F1000 X35.8816 Y73.8756 Z-2.0000 S1000
    G1 F1000 X35.8955 Y73.6240 Z-2.0000 S1000
    G1 F1000 X35.9015 Y73.3721 Z-2.0000 S1000
    G1 F1000 X35.8994 Y73.1202 Z-2.0000 S1000
    G1 F1000 X35.8894 Y72.8684 Z-2.0000 S1000
    G1 F1000 X35.8713 Y72.6170 Z-2.0000 S1000
    G1 F1000 X35.8453 Y72.3664 Z-2.0000 S1000
    G1 F1000 X35.8114 Y72.1167 Z-2.0000 S1000
    G1 F1000 X35.7695 Y71.8682 Z-2.0000 S1000
    G1 F1000 X35.7198 Y71.6212 Z-2.0000 S1000
    G1 F1000 X35.6623 Y71.3759 Z-2.0000 S1000
    G1 F1000 X35.5970 Y71.1325 Z-2.0000 S1000
    G1 F1000 X35.5240 Y70.8913 Z-2.0000 S1000
    G1 F1000 X35.4434 Y70.6526 Z-2.0000 S1000
    G1 F1000 X35.3553 Y70.4165 Z-2.0000 S1000
    G1 F1000 X35.2597 Y70.1833 Z-2.0000 S1000
    G1 F1000 X35.1567 Y69.9533 Z-2.0000 S1000
    G1 F1000 X35.0466 Y69.7267 Z-2.0000 S1000
    G1 F1000 X34.9292 Y69.5037 Z-2.0000 S1000
    G1 F1000 X34.8049 Y69.2846 Z-2.0000 S1000
    G1 F1000 X34.6215 Y68.9881 Z-2.0000 S1000
    G1 F1000 X33.4701 Y67.2147 Z-2.0000 S1000
    G1 F1000 X31.7516 Y62.7385 Z-2.0000 S1000
    G1 F1000 X31.6698 Y62.2221 Z-2.0000 S1000
    G1 F1000 X31.6264 Y61.9739 Z-2.0000 S1000
    G1 F1000 X31.5752 Y61.7272 Z-2.0000 S1000
    G1 F1000 X31.5162 Y61.4822 Z-2.0000 S1000
    G1 F1000 X31.4494 Y61.2392 Z-2.0000 S1000
    G1 F1000 X31.3749 Y60.9985 Z-2.0000 S1000
    G1 F1000 X31.2928 Y60.7602 Z-2.0000 S1000
    G1 F1000 X31.2033 Y60.5247 Z-2.0000 S1000
    G1 F1000 X31.1062 Y60.2922 Z-2.0000 S1000
    G1 F1000 X31.0019 Y60.0628 Z-2.0000 S1000
    G1 F1000 X30.8903 Y59.8369 Z-2.0000 S1000
    G1 F1000 X30.7716 Y59.6146 Z-2.0000 S1000
    G1 F1000 X30.6459 Y59.3962 Z-2.0000 S1000
    G1 F1000 X30.5133 Y59.1819 Z-2.0000 S1000
    G1 F1000 X30.3741 Y58.9719 Z-2.0000 S1000
    G1 F1000 X30.2282 Y58.7665 Z-2.0000 S1000
    G1 F1000 X30.0758 Y58.5657 Z-2.0000 S1000
    G1 F1000 X29.9172 Y58.3700 Z-2.0000 S1000
    G1 F1000 X29.7524 Y58.1793 Z-2.0000 S1000
    G1 F1000 X29.5817 Y57.9940 Z-2.0000 S1000
    G1 F1000 X29.4051 Y57.8142 Z-2.0000 S1000
    G1 F1000 X29.2230 Y57.6401 Z-2.0000 S1000
    G1 F1000 X29.0354 Y57.4718 Z-2.0000 S1000
    G1 F1000 X28.8426 Y57.3096 Z-2.0000 S1000
    G1 F1000 X28.6447 Y57.1536 Z-2.0000 S1000
    G1 F1000 X28.4419 Y57.0040 Z-2.0000 S1000
    G1 F1000 X28.2346 Y56.8608 Z-2.0000 S1000
    G1 F1000 X28.1593 Y56.8123 Z-2.0000 S1000
    G1 F1000 X28.2569 Y56.7495 Z-2.0000 S1000
    G1 F1000 X28.4644 Y56.6066 Z-2.0000 S1000
    G1 F1000 X28.6673 Y56.4572 Z-2.0000 S1000
    G1 F1000 X28.8654 Y56.3014 Z-2.0000 S1000
    G1 F1000 X29.0584 Y56.1394 Z-2.0000 S1000
    G1 F1000 X29.2461 Y55.9714 Z-2.0000 S1000
    G1 F1000 X29.4285 Y55.7975 Z-2.0000 S1000
    G1 F1000 X29.6052 Y55.6179 Z-2.0000 S1000
    G1 F1000 X29.7762 Y55.4327 Z-2.0000 S1000
    G1 F1000 X29.9411 Y55.2423 Z-2.0000 S1000
    G1 F1000 X30.1000 Y55.0467 Z-2.0000 S1000
    G1 F1000 X30.2526 Y54.8461 Z-2.0000 S1000
    G1 F1000 X30.3987 Y54.6408 Z-2.0000 S1000
    G1 F1000 X30.5382 Y54.4310 Z-2.0000 S1000
    G1 F1000 X30.6710 Y54.2168 Z-2.0000 S1000
    G1 F1000 X30.7969 Y53.9986 Z-2.0000 S1000
    G1 F1000 X30.9159 Y53.7764 Z-2.0000 S1000
    G1 F1000 X31.0277 Y53.5506 Z-2.0000 S1000
    G1 F1000 X31.1323 Y53.3214 Z-2.0000 S1000
    G1 F1000 X31.2296 Y53.0889 Z-2.0000 S1000
    G1 F1000 X31.3194 Y52.8535 Z-2.0000 S1000
    G1 F1000 X31.4018 Y52.6154 Z-2.0000 S1000
    G1 F1000 X31.4765 Y52.3747 Z-2.0000 S1000
    G1 F1000 X31.5267 Y52.1956 Z-2.0000 S1000
    G1 F1000 X32.4934 Y48.5879 Z-2.0000 S1000
    G1 F1000 X34.9439 Y43.7782 Z-2.0000 S1000
    G1 F1000 X35.0548 Y43.5519 Z-2.0000 S1000
    G1 F1000 X35.1583 Y43.3222 Z-2.0000 S1000
    G1 F1000 X35.2546 Y43.0893 Z-2.0000 S1000
    G1 F1000 X35.3434 Y42.8535 Z-2.0000 S1000
    G1 F1000 X35.4246 Y42.6150 Z-2.0000 S1000
    G1 F1000 X35.4983 Y42.3740 Z-2.0000 S1000
    G1 F1000 X35.5642 Y42.1308 Z-2.0000 S1000
    G1 F1000 X35.6224 Y41.8856 Z-2.0000 S1000
    G1 F1000 X35.6728 Y41.6387 Z-2.0000 S1000
    G1 F1000 X35.7154 Y41.3903 Z-2.0000 S1000
    G1 F1000 X35.7500 Y41.1408 Z-2.0000 S1000
    G1 F1000 X35.7767 Y40.8902 Z-2.0000 S1000
    G1 F1000 X35.7954 Y40.6389 Z-2.0000 S1000
    G1 F1000 X35.8062 Y40.3871 Z-2.0000 S1000
    G1 F1000 X35.8089 Y40.1352 Z-2.0000 S1000
    G1 F1000 X35.8036 Y39.8832 Z-2.0000 S1000
    G1 F1000 X35.7904 Y39.6316 Z-2.0000 S1000
    G1 F1000 X35.7692 Y39.3805 Z-2.0000 S1000
    G1 F1000 X35.7400 Y39.1302 Z-2.0000 S1000
    G1 F1000 X35.7028 Y38.8810 Z-2.0000 S1000
    G1 F1000 X35.6578 Y38.6331 Z-2.0000 S1000
    G1 F1000 X35.6386 Y38.5434 Z-2.0000 S1000
    G1 F1000 X35.7069 Y38.5582 Z-2.0000 S1000
    G1 F1000 X35.9547 Y38.6039 Z-2.0000 S1000
    G1 F1000 X36.2038 Y38.6418 Z-2.0000 S1000
    G1 F1000 X36.4540 Y38.6716 Z-2.0000 S1000
    G1 F1000 X36.7050 Y38.6936 Z-2.0000 S1000
    G1 F1000 X36.9566 Y38.7075 Z-2.0000 S1000
    G1 F1000 X37.2085 Y38.7135 Z-2.0000 S1000
    G1 F1000 X37.4605 Y38.7114 Z-2.0000 S1000
    G1 F1000 X37.6975 Y38.7020 Z-2.0000 S1000
    G1 F1000 X40.0824 Y43.8164 Z-2.0000 S1000
    G1 F1000 X40.0213 Y43.8867 Z-2.0000 S1000
    G1 F1000 X39.9248 Y44.0036 Z-2.0000 S1000
    G1 F1000 X38.4725 Y45.7973 Z-2.0000 S1000
    G1 F1000 X38.3170 Y45.9956 Z-2.0000 S1000
    G1 F1000 X38.1680 Y46.1988 Z-2.0000 S1000
    G1 F1000 X38.0254 Y46.4066 Z-2.0000 S1000
    G1 F1000 X37.8895 Y46.6188 Z-2.0000 S1000
    G1 F1000 X37.7605 Y46.8352 Z-2.0000 S1000
    G1 F1000 X37.6383 Y47.0556 Z-2.0000 S1000
    G1 F1000 X37.5689 Y47.1888 Z-2.0000 S1000
    G1 F1000 X36.5214 Y49.2448 Z-2.0000 S1000
    G1 F1000 X36.4106 Y49.4711 Z-2.0000 S1000
    G1 F1000 X36.3070 Y49.7008 Z-2.0000 S1000
    G1 F1000 X36.2108 Y49.9337 Z-2.0000 S1000
    G1 F1000 X36.1220 Y50.1695 Z-2.0000 S1000
    G1 F1000 X36.0408 Y50.4080 Z-2.0000 S1000
    G1 F1000 X35.9671 Y50.6490 Z-2.0000 S1000
    G1 F1000 X35.9268 Y50.7941 Z-2.0000 S1000
    G1 F1000 X35.3294 Y53.0241 Z-2.0000 S1000
    G1 F1000 X35.2680 Y53.2685 Z-2.0000 S1000
    G1 F1000 X35.2145 Y53.5148 Z-2.0000 S1000
    G1 F1000 X35.1688 Y53.7626 Z-2.0000 S1000
    G1 F1000 X35.1310 Y54.0117 Z-2.0000 S1000
    G1 F1000 X35.1011 Y54.2619 Z-2.0000 S1000
    G1 F1000 X35.0791 Y54.5129 Z-2.0000 S1000
    G1 F1000 X35.0699 Y54.6619 Z-2.0000 S1000
    G1 F1000 X34.9489 Y56.9665 Z-2.0000 S1000
    G1 F1000 X34.9397 Y57.2183 Z-2.0000 S1000
    G1 F1000 X34.9385 Y57.4703 Z-2.0000 S1000
    G1 F1000 X34.9453 Y57.7222 Z-2.0000 S1000
    G1 F1000 X34.9600 Y57.9738 Z-2.0000 S1000
    G1 F1000 X34.9828 Y58.2247 Z-2.0000 S1000
    G1 F1000 X35.0135 Y58.4748 Z-2.0000 S1000
    G1 F1000 X35.0358 Y58.6249 Z-2.0000 S1000
    G1 F1000 X35.3970 Y60.9044 Z-2.0000 S1000
    G1 F1000 X35.4404 Y61.1527 Z-2.0000 S1000
    G1 F1000 X35.4916 Y61.3994 Z-2.0000 S1000
    G1 F1000 X35.5507 Y61.6444 Z-2.0000 S1000
    G1 F1000 X35.6175 Y61.8873 Z-2.0000 S1000
    G1 F1000 X35.6919 Y62.1281 Z-2.0000 S1000
    G1 F1000 X35.7740 Y62.3663 Z-2.0000 S1000
    G1 F1000 X35.8265 Y62.5071 Z-2.0000 S1000
    G1 F1000 X36.6536 Y64.6615 Z-2.0000 S1000
    G1 F1000 X36.7477 Y64.8952 Z-2.0000 S1000
    G1 F1000 X36.8491 Y65.1259 Z-2.0000 S1000
    G1 F1000 X36.9577 Y65.3533 Z-2.0000 S1000
    G1 F1000 X37.0736 Y65.5770 Z-2.0000 S1000
    G1 F1000 X37.1965 Y65.7970 Z-2.0000 S1000
    G1 F1000 X37.3263 Y66.0130 Z-2.0000 S1000
    G1 F1000 X37.4073 Y66.1403 Z-2.0000 S1000
    G1 F1000 X38.6645 Y68.0758 Z-2.0000 S1000
    G1 F1000 X38.8051 Y68.2849 Z-2.0000 S1000
    G1 F1000 X38.9522 Y68.4895 Z-2.0000 S1000
    G1 F1000 X39.1058 Y68.6893 Z-2.0000 S1000
    G1 F1000 X39.2657 Y68.8841 Z-2.0000 S1000
    G1 F1000 X39.4316 Y69.0737 Z-2.0000 S1000
    G1 F1000 X39.6035 Y69.2579 Z-2.0000 S1000
    G1 F1000 X39.7083 Y69.3648 Z-2.0000 S1000
    G1 F1000 X41.3399 Y70.9964 Z-2.0000 S1000
    G1 F1000 X41.5209 Y71.1717 Z-2.0000 S1000
    G1 F1000 X41.7074 Y71.3412 Z-2.0000 S1000
    G1 F1000 X41.8991 Y71.5047 Z-2.0000 S1000
    G1 F1000 X42.0960 Y71.6620 Z-2.0000 S1000
    G1 F1000 X42.2977 Y71.8130 Z-2.0000 S1000
    G1 F1000 X42.5041 Y71.9575 Z-2.0000 S1000
    G1 F1000 X42.6289 Y72.0402 Z-2.0000 S1000
    G1 F1000 X44.5644 Y73.2974 Z-2.0000 S1000
    G1 F1000 X44.7778 Y73.4313 Z-2.0000 S1000
    G1 F1000 X44.9955 Y73.5584 Z-2.0000 S1000
    G1 F1000 X45.2170 Y73.6784 Z-2.0000 S1000
    G1 F1000 X45.4422 Y73.7914 Z-2.0000 S1000
    G1 F1000 X45.6709 Y73.8972 Z-2.0000 S1000
    G1 F1000 X45.9029 Y73.9957 Z-2.0000 S1000
    G1 F1000 X46.0432 Y74.0511 Z-2.0000 S1000
    G1 F1000 X48.1976 Y74.8782 Z-2.0000 S1000
    G1 F1000 X48.4343 Y74.9647 Z-2.0000 S1000
    G1 F1000 X48.6736 Y75.0438 Z-2.0000 S1000
    G1 F1000 X48.9152 Y75.1151 Z-2.0000 S1000
    G1 F1000 X49.1590 Y75.1788 Z-2.0000 S1000
    G1 F1000 X49.4047 Y75.2347 Z-2.0000 S1000
    G1 F1000 X49.6521 Y75.2828 Z-2.0000 S1000
    G1 F1000 X49.8003 Y75.3077 Z-2.0000 S1000
    G1 F1000 X52.0798 Y75.6689 Z-2.0000 S1000
    G1 F1000 X52.3292 Y75.7044 Z-2.0000 S1000
    G1 F1000 X52.5797 Y75.7319 Z-2.0000 S1000
    G1 F1000 X52.8309 Y75.7515 Z-2.0000 S1000
    G1 F1000 X53.0826 Y75.7631 Z-2.0000 S1000
    G1 F1000 X53.3346 Y75.7667 Z-2.0000 S1000
    G1 F1000 X53.5865 Y75.7623 Z-2.0000 S1000
    G1 F1000 X53.7382 Y75.7558 Z-2.0000 S1000
    G1 F1000 X56.0428 Y75.6348 Z-2.0000 S1000
    G1 F1000 X56.2942 Y75.6176 Z-2.0000 S1000
    G1 F1000 X56.5449 Y75.5924 Z-2.0000 S1000
    G1 F1000 X56.7947 Y75.5593 Z-2.0000 S1000
    G1 F1000 X57.0433 Y75.5182 Z-2.0000 S1000
    G1 F1000 X57.2905 Y75.4693 Z-2.0000 S1000
    G1 F1000 X57.5360 Y75.4126 Z-2.0000 S1000
    G1 F1000 X57.6806 Y75.3753 Z-2.0000 S1000
    G1 F1000 X59.9106 Y74.7779 Z-2.0000 S1000
    G1 F1000 X60.1529 Y74.7089 Z-2.0000 S1000
    G1 F1000 X60.3929 Y74.6322 Z-2.0000 S1000
    G1 F1000 X60.6304 Y74.5479 Z-2.0000 S1000
    G1 F1000 X60.8651 Y74.4561 Z-2.0000 S1000
    G1 F1000 X61.0967 Y74.3569 Z-2.0000 S1000
    G1 F1000 X61.3251 Y74.2504 Z-2.0000 S1000
    G1 F1000 X61.4599 Y74.1833 Z-2.0000 S1000
    G1 F1000 X63.5159 Y73.1358 Z-2.0000 S1000
    G1 F1000 X63.7386 Y73.0178 Z-2.0000 S1000
    G1 F1000 X63.9574 Y72.8929 Z-2.0000 S1000
    G1 F1000 X64.1722 Y72.7611 Z-2.0000 S1000
    G1 F1000 X64.3826 Y72.6225 Z-2.0000 S1000
    G1 F1000 X64.5886 Y72.4773 Z-2.0000 S1000
    G1 F1000 X64.7898 Y72.3256 Z-2.0000 S1000
    G1 F1000 X64.9074 Y72.2322 Z-2.0000 S1000
    G1 F1000 X66.7011 Y70.7799 Z-2.0000 S1000
    G1 F1000 X66.8944 Y70.6183 Z-2.0000 S1000
    G1 F1000 X67.0825 Y70.4506 Z-2.0000 S1000
    G1 F1000 X67.2651 Y70.2770 Z-2.0000 S1000
    G1 F1000 X67.4422 Y70.0977 Z-2.0000 S1000
    G1 F1000 X67.6134 Y69.9129 Z-2.0000 S1000
    G1 F1000 X67.7787 Y69.7227 Z-2.0000 S1000
    G1 F1000 X67.8752 Y69.6058 Z-2.0000 S1000
    G1 F1000 X69.3275 Y67.8121 Z-2.0000 S1000
    G1 F1000 X69.4830 Y67.6138 Z-2.0000 S1000
    G1 F1000 X69.6320 Y67.4106 Z-2.0000 S1000
    G1 F1000 X69.7746 Y67.2028 Z-2.0000 S1000
    G1 F1000 X69.9105 Y66.9906 Z-2.0000 S1000
    G1 F1000 X70.0395 Y66.7742 Z-2.0000 S1000
    G1 F1000 X70.1617 Y66.5538 Z-2.0000 S1000
    G1 F1000 X70.2311 Y66.4206 Z-2.0000 S1000
    G1 F1000 X71.2786 Y64.3646 Z-2.0000 S1000
    G1 F1000 X71.3894 Y64.1383 Z-2.0000 S1000
    G1 F1000 X71.4930 Y63.9086 Z-2.0000 S1000
    G1 F1000 X71.5892 Y63.6757 Z-2.0000 S1000
    G1 F1000 X71.6780 Y63.4399 Z-2.0000 S1000
    G1 F1000 X71.7592 Y63.2014 Z-2.0000 S1000
    G1 F1000 X71.8329 Y62.9604 Z-2.0000 S1000
    G1 F1000 X71.8732 Y62.8153 Z-2.0000 S1000
    G1 F1000 X72.4706 Y60.5853 Z-2.0000 S1000
    G1 F1000 X72.5320 Y60.3409 Z-2.0000 S1000
    G1 F1000 X72.5855 Y60.0946 Z-2.0000 S1000
    G1 F1000 X72.6312 Y59.8468 Z-2.0000 S1000
    G1 F1000 X72.6690 Y59.5977 Z-2.0000 S1000
    G1 F1000 X72.6989 Y59.3475 Z-2.0000 S1000
    G1 F1000 X72.7209 Y59.0965 Z-2.0000 S1000
    G1 F1000 X72.7301 Y58.9475 Z-2.0000 S1000
    G1 F1000 X72.8511 Y56.6429 Z-2.0000 S1000
    G1 F1000 X72.8603 Y56.3911 Z-2.0000 S1000
    G1 F1000 X72.8615 Y56.1391 Z-2.0000 S1000
    G1 F1000 X72.8547 Y55.8872 Z-2.0000 S1000
    G1 F1000 X72.8400 Y55.6356 Z-2.0000 S1000
    G1 F1000 X72.8172 Y55.3847 Z-2.0000 S1000
    G1 F1000 X72.7865 Y55.1346 Z-2.0000 S1000
    G1 F1000 X72.7642 Y54.9845 Z-2.0000 S1000
    G1 F1000 X72.4030 Y52.7050 Z-2.0000 S1000
    G1 F1000 X72.3596 Y52.4567 Z-2.0000 S1000
    G1 F1000 X72.3084 Y52.2100 Z-2.0000 S1000
    G1 F1000 X72.2493 Y51.9650 Z-2.0000 S1000
    G1 F1000 X72.1825 Y51.7221 Z-2.0000 S1000
    G1 F1000 X72.1081 Y51.4813 Z-2.0000 S1000
    G1 F1000 X72.0260 Y51.2431 Z-2.0000 S1000
    G1 F1000 X71.9735 Y51.1023 Z-2.0000 S1000
    G1 F1000 X71.1464 Y48.9479 Z-2.0000 S1000
    G1 F1000 X71.0523 Y48.7142 Z-2.0000 S1000
    G1 F1000 X70.9509 Y48.4835 Z-2.0000 S1000
    G1 F1000 X70.8423 Y48.2561 Z-2.0000 S1000
    G1 F1000 X70.7264 Y48.0324 Z-2.0000 S1000
    G1 F1000 X70.6035 Y47.8124 Z-2.0000 S1000
    G1 F1000 X70.4737 Y47.5964 Z-2.0000 S1000
    G1 F1000 X70.3927 Y47.4691 Z-2.0000 S1000
    G1 F1000 X69.1355 Y45.5336 Z-2.0000 S1000
    G1 F1000 X68.9949 Y45.3245 Z-2.0000 S1000
    G1 F1000 X68.8478 Y45.1199 Z-2.0000 S1000
    G1 F1000 X68.6942 Y44.9201 Z-2.0000 S1000
    G1 F1000 X68.5343 Y44.7253 Z-2.0000 S1000
    G1 F1000 X68.3754 Y44.5437 Z-2.0000 S1000
    G1 F700 Z-3.0000
    G1 F1000 X71.0638 Y38.7783 Z-3.0000 S1000
    G1 F1000 X71.1256 Y38.7737 Z-3.0000 S1000
    G1 F1000 X71.3762 Y38.7469 Z-3.0000 S1000
    G1 F1000 X71.6257 Y38.7121 Z-3.0000 S1000
    G1 F1000 X71.8741 Y38.6694 Z-3.0000 S1000
    G1 F1000 X72.0772 Y38.6278 Z-3.0000 S1000
    G1 F1000 X72.0537 Y38.7357 Z-3.0000 S1000
    G1 F1000 X72.0080 Y38.9835 Z-3.0000 S1000
    G1 F1000 X71.9702 Y39.2327 Z-3.0000 S1000
    G1 F1000 X71.9404 Y39.4829 Z-3.0000 S1000
    G1 F1000 X71.9184 Y39.7339 Z-3.0000 S1000
    G1 F1000 X71.9045 Y39.9855 Z-3.0000 S1000
    G1 F1000 X71.8985 Y40.2374 Z-3.0000 S1000
    G1 F1000 X71.9006 Y40.4894 Z-3.0000 S1000
    G1 F1000 X71.9106 Y40.7412 Z-3.0000 S1000
    G1 F1000 X71.9287 Y40.9925 Z-3.0000 S1000
    G1 F1000 X71.9547 Y41.2432 Z-3.0000 S1000
    G1 F1000 X71.9886 Y41.4928 Z-3.0000 S1000
    G1 F1000 X72.0305 Y41.7413 Z-3.0000 S1000
    G1 F1000 X72.0802 Y41.9884 Z-3.0000 S1000
    G1 F1000 X72.1377 Y42.2337 Z-3.0000 S1000
    G1 F1000 X72.2030 Y42.4771 Z-3.0000 S1000
    G1 F1000 X72.2760 Y42.7182 Z-3.0000 S1000
    G1 F1000 X72.3566 Y42.9570 Z-3.0000 S1000
    G1 F1000 X72.4447 Y43.1931 Z-3.0000 S1000
    G1 F1000 X72.5403 Y43.4262 Z-3.0000 S1000
    G1 F1000 X72.6433 Y43.6562 Z-3.0000 S1000
    G1 F1000 X72.7535 Y43.8828 Z-3.0000 S1000
    G1 F1000 X72.8708 Y44.1058 Z-3.0000 S1000
    G1 F1000 X72.9951 Y44.3250 Z-3.0000 S1000
    G1 F1000 X73.1785 Y44.6215 Z-3.0000 S1000
    G1 F1000 X74.3300 Y46.3950 Z-3.0000 S1000
    G1 F1000 X76.0484 Y50.8709 Z-3.0000 S1000
    G1 F1000 X76.1302 Y51.3873 Z-3.0000 S1000
    G1 F1000 X76.1736 Y51.6355 Z-3.0000 S1000
    G1 F1000 X76.2248 Y51.8822 Z-3.0000 S1000
    G1 F1000 X76.2838 Y52.1272 Z-3.0000 S1000
    G1 F1000 X76.3506 Y52.3702 Z-3.0000 S1000
    G1 F1000 X76.4251 Y52.6109 Z-3.0000 S1000
    G1 F1000 X76.5072 Y52.8492 Z-3.0000 S1000
    G1 F1000 X76.5967 Y53.0847 Z-3.0000 S1000
    G1 F1000 X76.6938 Y53.3172 Z-3.0000 S1000
    G1 F1000 X76.7981 Y53.5466 Z-3.0000 S1000
    G1 F1000 X76.9097 Y53.7725 Z-3.0000 S1000
    G1 F1000 X77.0284 Y53.9948 Z-3.0000 S1000
    G1 F1000 X77.1541 Y54.2132 Z-3.0000 S1000
    G1 F1000 X77.2867 Y54.4275 Z-3.0000 S1000
    G1 F1000 X77.4259 Y54.6375 Z-3.0000 S1000
    G1 F1000 X77.5718 Y54.8429 Z-3.0000 S1000
    G1 F1000 X77.7242 Y55.0437 Z-3.0000 S1000
    G1 F1000 X77.8828 Y55.2394 Z-3.0000 S1000
    G1 F1000 X78.0476 Y55.4301 Z-3.0000 S1000
    G1 F1000 X78.2183 Y55.6154 Z-3.0000 S1000
    G1 F1000 X78.3949 Y55.7952 Z-3.0000 S1000
    G1 F1000 X78.5770 Y55.9693 Z-3.0000 S1000
    G1 F1000 X78.7646 Y56.1376 Z-3.0000 S1000
    G1 F1000 X78.9574 Y56.2998 Z-3.0000 S1000
    G1 F1000 X79.1553 Y56.4558 Z-3.0000 S1000
    G1 F1000 X79.3581 Y56.6054 Z-3.0000 S1000
    G1 F1000 X79.5654 Y56.7486 Z-3.0000 S1000
    G1 F1000 X79.6408 Y56.7972 Z-3.0000 S1000
    G1 F1000 X79.5431 Y56.8600 Z-3.0000 S1000
    G1 F1000 X79.3355 Y57.0029 Z-3.0000 S1000
    G1 F1000 X79.1326 Y57.1523 Z-3.0000 S1000
    G1 F1000 X78.9346 Y57.3081 Z-3.0000 S1000
    G1 F1000 X78.7416 Y57.4701 Z-3.0000 S1000
    G1 F1000 X78.5538 Y57.6381 Z-3.0000 S1000
    G1 F1000 X78.3715 Y57.8121 Z-3.0000 S1000
    G1 F1000 X78.1947 Y57.9917 Z-3.0000 S1000
    G1 F1000 X78.0238 Y58.1768 Z-3.0000 S1000
    G1 F1000 X77.8588 Y58.3673 Z-3.0000 S1000
    G1 F1000 X77.7000 Y58.5629 Z-3.0000 S1000
    G1 F1000 X77.5474 Y58.7634 Z-3.0000 S1000
    G1 F1000 X77.4013 Y58.9687 Z-3.0000 S1000
    G1 F1000 X77.2618 Y59.1786 Z-3.0000 S1000
    G1 F1000 X77.1290 Y59.3927 Z-3.0000 S1000
    G1 F1000 X77.0030 Y59.6110 Z-3.0000 S1000
    G1 F1000 X76.8841 Y59.8331 Z-3.0000 S1000
    G1 F1000 X76.7723 Y60.0589 Z-3.0000 S1000
    G1 F1000 X76.6677 Y60.2882 Z-3.0000 S1000
    G1 F1000 X76.5704 Y60.5206 Z-3.0000 S1000
    G1 F1000 X76.4805 Y60.7561 Z-3.0000 S1000
    G1 F1000 X76.3982 Y60.9942 Z-3.0000 S1000
    G1 F1000 X76.3235 Y61.2349 Z-3.0000 S1000
    G1 F1000 X76.2733 Y61.4139 Z-3.0000 S1000
    G1 F1000 X75.3067 Y65.0214 Z-3.0000 S1000
    G1 F1000 X72.8561 Y69.8311 Z-3.0000 S1000
    G1 F1000 X72.7453 Y70.0575 Z-3.0000 S1000
    G1 F1000 X72.6417 Y70.2872 Z-3.0000 S1000
    G1 F1000 X72.5455 Y70.5200 Z-3.0000 S1000
    G1 F1000 X72.4567 Y70.7559 Z-3.0000 S1000
    G1 F1000 X72.3754 Y70.9944 Z-3.0000 S1000
    G1 F1000 X72.3018 Y71.2354 Z-3.0000 S1000
    G1 F1000 X72.2358 Y71.4786 Z-3.0000 S1000
    G1 F1000 X72.1776 Y71.7237 Z-3.0000 S1000
    G1 F1000 X72.1272 Y71.9706 Z-3.0000 S1000
    G1 F1000 X72.0846 Y72.2190 Z-3.0000 S1000
    G1 F1000 X72.0500 Y72.4686 Z-3.0000 S1000
    G1 F1000 X72.0233 Y72.7192 Z-3.0000 S1000
    G1 F1000 X72.0046 Y72.9704 Z-3.0000 S1000
    G1 F1000 X71.9938 Y73.2222 Z-3.0000 S1000
    G1 F1000 X71.9911 Y73.4742 Z-3.0000 S1000
    G1 F1000 X71.9964 Y73.7261 Z-3.0000 S1000
    G1 F1000 X72.0096 Y73.9777 Z-3.0000 S1000
    G1 F1000 X72.0308 Y74.2288 Z-3.0000 S1000
    G1 F1000 X72.0600 Y74.4791 Z-3.0000 S1000
    G1 F1000 X72.0971 Y74.7283 Z-3.0000 S1000
    G1 F1000 X72.1422 Y74.9763 Z-3.0000 S1000
    G1 F1000 X72.1614 Y75.0660 Z-3.0000 S1000
    G1 F1000 X72.0932 Y75.0512 Z-3.0000 S1000
    G1 F1000 X71.8454 Y75.0055 Z-3.0000 S1000
    G1 F1000 X71.5963 Y74.9677 Z-3.0000 S1000
    G1 F1000 X71.3461 Y74.9378 Z-3.0000 S1000
    G1 F1000 X71.0950 Y74.9158 Z-3.0000 S1000
    G1 F1000 X70.8434 Y74.9019 Z-3.0000 S1000
    G1 F1000 X70.5915 Y74.8959 Z-3.0000 S1000
    G1 F1000 X70.3396 Y74.8980 Z-3.0000 S1000
    G1 F1000 X70.0878 Y74.9080 Z-3.0000 S1000
    G1 F1000 X69.8364 Y74.9261 Z-3.0000 S1000
    G1 F1000 X69.5858 Y74.9520 Z-3.0000 S1000
    G1 F1000 X69.3361 Y74.9860 Z-3.0000 S1000
    G1 F1000 X69.0876 Y75.0278 Z-3.0000 S1000
    G1 F1000 X68.8406 Y75.0775 Z-3.0000 S1000
    G1 F1000 X68.5953 Y75.1351 Z-3.0000 S1000
    G1 F1000 X68.3519 Y75.2004 Z-3.0000 S1000
    G1 F1000 X68.1107 Y75.2733 Z-3.0000 S1000
    G1 F1000 X67.8719 Y75.3539 Z-3.0000 S1000
    G1 F1000 X67.6359 Y75.4421 Z-3.0000 S1000
    G1 F1000 X67.4027 Y75.5377 Z-3.0000 S1000
    G1 F1000 X67.1727 Y75.6406 Z-3.0000 S1000
    G1 F1000 X66.9264 Y75.7608 Z-3.0000 S1000
    G1 F1000 X62.1167 Y78.2114 Z-3.0000 S1000
    G1 F1000 X58.5092 Y79.1780 Z-3.0000 S1000
    G1 F1000 X58.2668 Y79.2470 Z-3.0000 S1000
    G1 F1000 X58.0268 Y79.3238 Z-3.0000 S1000
    G1 F1000 X57.7893 Y79.4081 Z-3.0000 S1000
    G1 F1000 X57.5547 Y79.4999 Z-3.0000 S1000
    G1 F1000 X57.3230 Y79.5991 Z-3.0000 S1000
    G1 F1000 X57.0947 Y79.7056 Z-3.0000 S1000
    G1 F1000 X56.8698 Y79.8193 Z-3.0000 S1000
    G1 F1000 X56.6487 Y79.9401 Z-3.0000 S1000
    G1 F1000 X56.4315 Y80.0678 Z-3.0000 S1000
    G1 F1000 X56.2184 Y80.2024 Z-3.0000 S1000
    G1 F1000 X56.0098 Y80.3437 Z-3.0000 S1000
    G1 F1000 X55.8057 Y80.4915 Z-3.0000 S1000
    G1 F1000 X55.6064 Y80.6457 Z-3.0000 S1000
    G1 F1000 X55.4121 Y80.8062 Z-3.0000 S1000
    G1 F1000 X55.2230 Y80.9727 Z-3.0000 S1000
    G1 F1000 X55.0393 Y81.1452 Z-3.0000 S1000
    G1 F1000 X54.8612 Y81.3234 Z-3.0000 S1000
    G1 F1000 X54.6888 Y81.5072 Z-3.0000 S1000
    G1 F1000 X54.5223 Y81.6964 Z-3.0000 S1000
    G1 F1000 X54.3619 Y81.8907 Z-3.0000 S1000
    G1 F1000 X54.2078 Y82.0901 Z-3.0000 S1000
    G1 F1000 X54.0601 Y82.2942 Z-3.0000 S1000
    G1 F1000 X53.9189 Y82.5030 Z-3.0000 S1000
    G1 F1000 X53.8923 Y82.5452 Z-3.0000 S1000
    G1 F1000 X53.8486 Y82.4772 Z-3.0000 S1000
    G1 F1000 X53.7057 Y82.2697 Z-3.0000 S1000
    G1 F1000 X53.5563 Y82.0668 Z-3.0000 S1000
    G1 F1000 X53.4005 Y81.8687 Z-3.0000 S1000
    G1 F1000 X53.2385 Y81.6757 Z-3.0000 S1000
    G1 F1000 X53.0704 Y81.4879 Z-3.0000 S1000
    G1 F1000 X52.8965 Y81.3056 Z-3.0000 S1000
    G1 F1000 X52.7169 Y81.1289 Z-3.0000 S1000
    G1 F1000 X52.5317 Y80.9579 Z-3.0000 S1000
    G1 F1000 X52.3413 Y80.7930 Z-3.0000 S1000
    G1 F1000 X52.1456 Y80.6341 Z-3.0000 S1000
    G1 F1000 X51.9451 Y80.4816 Z-3.0000 S1000
    G1 F1000 X51.7398 Y80.3355 Z-3.0000 S1000
    G1 F1000 X51.5300 Y80.1959 Z-3.0000 S1000
    G1 F1000 X51.3158 Y80.0632 Z-3.0000 S1000
    G1 F1000 X51.0975 Y79.9372 Z-3.0000 S1000
    G1 F1000 X50.8754 Y79.8183 Z-3.0000 S1000
    G1 F1000 X50.6496 Y79.7065 Z-3.0000 S1000
    G1 F1000 X50.4203 Y79.6019 Z-3.0000 S1000
    G1 F1000 X50.1879 Y79.5046 Z-3.0000 S1000
    G1 F1000 X49.9524 Y79.4148 Z-3.0000 S1000
    G1 F1000 X49.7143 Y79.3324 Z-3.0000 S1000
    G1 F1000 X49.4736 Y79.2577 Z-3.0000 S1000
    G1 F1000 X49.2307 Y79.1907 Z-3.0000 S1000
    G1 F1000 X48.9858 Y79.1314 Z-3.0000 S1000
    G1 F1000 X48.7392 Y79.0799 Z-3.0000 S1000
    G1 F1000 X48.4826 Y79.0349 Z-3.0000 S1000
    G1 F1000 X47.9662 Y78.9531 Z-3.0000 S1000
    G1 F1000 X43.4903 Y77.2347 Z-3.0000 S1000
    G1 F1000 X41.7168 Y76.0832 Z-3.0000 S1000
    G1 F1000 X41.5033 Y75.9494 Z-3.0000 S1000
    G1 F1000 X41.2857 Y75.8224 Z-3.0000 S1000
    G1 F1000 X41.0641 Y75.7023 Z-3.0000 S1000
    G1 F1000 X40.8389 Y75.5894 Z-3.0000 S1000
    G1 F1000 X40.6101 Y75.4837 Z-3.0000 S1000
    G1 F1000 X40.3782 Y75.3852 Z-3.0000 S1000
    G1 F1000 X40.1432 Y75.2942 Z-3.0000 S1000
    G1 F1000 X39.9054 Y75.2107 Z-3.0000 S1000
    G1 F1000 X39.6652 Y75.1348 Z-3.0000 S1000
    G1 F1000 X39.4226 Y75.0665 Z-3.0000 S1000
    G1 F1000 X39.1780 Y75.0060 Z-3.0000 S1000
    G1 F1000 X38.9316 Y74.9533 Z-3.0000 S1000
    G1 F1000 X38.6836 Y74.9084 Z-3.0000 S1000
    G1 F1000 X38.4344 Y74.8714 Z-3.0000 S1000
    G1 F1000 X38.1841 Y74.8424 Z-3.0000 S1000
    G1 F1000 X37.9330 Y74.8213 Z-3.0000 S1000
    G1 F1000 X37.6813 Y74.8082 Z-3.0000 S1000
    G1 F1000 X37.4294 Y74.8031 Z-3.0000 S1000
    G1 F1000 X37.1774 Y74.8060 Z-3.0000 S1000
    G1 F1000 X36.9257 Y74.8168 Z-3.0000 S1000
    G1 F1000 X36.6744 Y74.8357 Z-3.0000 S1000
    G1 F1000 X36.4238 Y74.8625 Z-3.0000 S1000
    G1 F1000 X36.1743 Y74.8973 Z-3.0000 S1000
    G1 F1000 X35.9259 Y74.9400 Z-3.0000 S1000
    G1 F1000 X35.7228 Y74.9816 Z-3.0000 S1000
    G1 F1000 X35.7462 Y74.8738 Z-3.0000 S1000
    G1 F1000 X35.7919 Y74.6260 Z-3.0000 S1000
    G1 F1000 X35.8298 Y74.3769 Z-3.0000 S1000
    G1 F1000 X35.8596 Y74.1267 Z-3.0000 S1000
    G1 F1000 X35.8816 Y73.8756 Z-3.0000 S1000
    G1 F1000 X35.8955 Y73.6240 Z-3.0000 S1000
    G1 F1000 X35.9015 Y73.3721 Z-3.0000 S1000
    G1 F1000 X35.8994 Y73.1202 Z-3.0000 S1000
    G1 F1000 X35.8894 Y72.8684 Z-3.0000 S1000
    G1 F1000 X35.8713 Y72.6170 Z-3.0000 S1000
    G1 F1000 X35.8453 Y72.3664 Z-3.0000 S1000
    G1 F1000 X35.8114 Y72.1167 Z-3.0000 S1000
    G1 F1000 X35.7695 Y71.8682 Z-3.0000 S1000
    G1 F1000 X35.7198 Y71.6212 Z-3.0000 S1000
    G1 F1000 X35.6623 Y71.3759 Z-3.0000 S1000
    G1 F1000 X35.5970 Y71.1325 Z-3.0000 S1000
    G1 F1000 X35.5240 Y70.8913 Z-3.0000 S1000
    G1 F1000 X35.4434 Y70.6526 Z-3.0000 S1000
    G1 F1000 X35.3553 Y70.4165 Z-3.0000 S1000
    G1 F1000 X35.2597 Y70.1833 Z-3.0000 S1000
    G1 F1000 X35.1567 Y69.9533 Z-3.0000 S1000
    G1 F1000 X35.0466 Y69.7267 Z-3.0000 S1000
    G1 F1000 X34.9292 Y69.5037 Z-3.0000 S1000
    G1 F1000 X34.8049 Y69.2846 Z-3.0000 S1000
    G1 F1000 X34.6215 Y68.9881 Z-3.0000 S1000
    G1 F1000 X33.4701 Y67.2147 Z-3.0000 S1000
    G1 F1000 X31.7516 Y62.7385 Z-3.0000 S1000
    G1 F1000 X31.6698 Y62.2221 Z-3.0000 S1000
    G1 F1000 X31.6264 Y61.9739 Z-3.0000 S1000
    G1 F1000 X31.5752 Y61.7272 Z-3.0000 S1000
    G1 F1000 X31.5162 Y61.4822 Z-3.0000 S1000
    G1 F1000 X31.4494 Y61.2392 Z-3.0000 S1000
    G1 F1000 X31.3749 Y60.9985 Z-3.0000 S1000
    G1 F1000 X31.2928 Y60.7602 Z-3.0000 S1000
    G1 F1000 X31.2033 Y60.5247 Z-3.0000 S1000
    G1 F1000 X31.1062 Y60.2922 Z-3.0000 S1000
    G1 F1000 X31.0019 Y60.0628 Z-3.0000 S1000
    G1 F1000 X30.8903 Y59.8369 Z-3.0000 S1000
    G1 F1000 X30.7716 Y59.6146 Z-3.0000 S1000
    G1 F1000 X30.6459 Y59.3962 Z-3.0000 S1000
    G1 F1000 X30.5133 Y59.1819 Z-3.0000 S1000
    G1 F1000 X30.3741 Y58.9719 Z-3.0000 S1000
    G1 F1000 X30.2282 Y58.7665 Z-3.0000 S1000
    G1 F1000 X30.0758 Y58.5657 Z-3.0000 S1000
    G1 F1000 X29.9172 Y58.3700 Z-3.0000 S1000
    G1 F1000 X29.7524 Y58.1793 Z-3.0000 S1000
    G1 F1000 X29.5817 Y57.9940 Z-3.0000 S1000
    G1 F1000 X29.4051 Y57.8142 Z-3.0000 S1000
    G1 F1000 X29.2230 Y57.6401 Z-3.0000 S1000
    G1 F1000 X29.0354 Y57.4718 Z-3.0000 S1000
    G1 F1000 X28.8426 Y57.3096 Z-3.0000 S1000
    G1 F1000 X28.6447 Y57.1536 Z-3.0000 S1000
    G1 F1000 X28.4419 Y57.0040 Z-3.0000 S1000
    G1 F1000 X28.2346 Y56.8608 Z-3.0000 S1000
    G1 F1000 X28.1593 Y56.8123 Z-3.0000 S1000
    G1 F1000 X28.2569 Y56.7495 Z-3.0000 S1000
    G1 F1000 X28.4644 Y56.6066 Z-3.0000 S1000
    G1 F1000 X28.6673 Y56.4572 Z-3.0000 S1000
    G1 F1000 X28.8654 Y56.3014 Z-3.0000 S1000
    G1 F1000 X29.0584 Y56.1394 Z-3.0000 S1000
    G1 F1000 X29.2461 Y55.9714 Z-3.0000 S1000
    G1 F1000 X29.4285 Y55.7975 Z-3.0000 S1000
    G1 F1000 X29.6052 Y55.6179 Z-3.0000 S1000
    G1 F1000 X29.7762 Y55.4327 Z-3.0000 S1000
    G1 F1000 X29.9411 Y55.2423 Z-3.0000 S1000
    G1 F1000 X30.1000 Y55.0467 Z-3.0000 S1000
    G1 F1000 X30.2526 Y54.8461 Z-3.0000 S1000
    G1 F1000 X30.3987 Y54.6408 Z-3.0000 S1000
    G1 F1000 X30.5382 Y54.4310 Z-3.0000 S1000
    G1 F1000 X30.6710 Y54.2168 Z-3.0000 S1000
    G1 F1000 X30.7969 Y53.9986 Z-3.0000 S1000
    G1 F1000 X30.9159 Y53.7764 Z-3.0000 S1000
    G1 F1000 X31.0277 Y53.5506 Z-3.0000 S1000
    G1 F1000 X31.1323 Y53.3214 Z-3.0000 S1000
    G1 F1000 X31.2296 Y53.0889 Z-3.0000 S1000
    G1 F1000 X31.3194 Y52.8535 Z-3.0000 S1000
    G1 F1000 X31.4018 Y52.6154 Z-3.0000 S1000
    G1 F1000 X31.4765 Y52.3747 Z-3.0000 S1000
    G1 F1000 X31.5267 Y52.1956 Z-3.0000 S1000
    G1 F1000 X32.4934 Y48.5879 Z-3.0000 S1000
    G1 F1000 X34.9439 Y43.7782 Z-3.0000 S1000
    G1 F1000 X35.0548 Y43.5519 Z-3.0000 S1000
    G1 F1000 X35.1583 Y43.3222 Z-3.0000 S1000
    G1 F1000 X35.2546 Y43.0893 Z-3.0000 S1000
    G1 F1000 X35.3434 Y42.8535 Z-3.0000 S1000
    G1 F1000 X35.4246 Y42.6150 Z-3.0000 S1000
    G1 F1000 X35.4983 Y42.3740 Z-3.0000 S1000
    G1 F1000 X35.5642 Y42.1308 Z-3.0000 S1000
    G1 F1000 X35.6224 Y41.8856 Z-3.0000 S1000
    G1 F1000 X35.6728 Y41.6387 Z-3.0000 S1000
    G1 F1000 X35.7154 Y41.3903 Z-3.0000 S1000
    G1 F1000 X35.7500 Y41.1408 Z-3.0000 S1000
    G1 F1000 X35.7767 Y40.8902 Z-3.0000 S1000
    G1 F1000 X35.7954 Y40.6389 Z-3.0000 S1000
    G1 F1000 X35.8062 Y40.3871 Z-3.0000 S1000
    G1 F1000 X35.8089 Y40.1352 Z-3.0000 S1000
    G1 F1000 X35.8036 Y39.8832 Z-3.0000 S1000
    G1 F1000 X35.7904 Y39.6316 Z-3.0000 S1000
    G1 F1000 X35.7692 Y39.3805 Z-3.0000 S1000
    G1 F1000 X35.7400 Y39.1302 Z-3.0000 S1000
    G1 F1000 X35.7028 Y38.8810 Z-3.0000 S1000
    G1 F1000 X35.6578 Y38.6331 Z-3.0000 S1000
    G1 F1000 X35.6386 Y38.5434 Z-3.0000 S1000
    G1 F1000 X35.7069 Y38.5582 Z-3.0000 S1000
    G1 F1000 X35.9547 Y38.6039 Z-3.0000 S1000
    G1 F1000 X36.2038 Y38.6418 Z-3.0000 S1000
    G1 F1000 X36.4540 Y38.6716 Z-3.0000 S1000
    G1 F1000 X36.7050 Y38.6936 Z-3.0000 S1000
    G1 F1000 X36.9566 Y38.7075 Z-3.0000 S1000
    G1 F1000 X37.2085 Y38.7135 Z-3.0000 S1000
    G1 F1000 X37.4605 Y38.7114 Z-3.0000 S1000
    G1 F1000 X37.6975 Y38.7020 Z-3.0000 S1000
    G1 F1000 X40.0824 Y43.8164 Z-3.0000 S1000
    G1 F1000 X40.0213 Y43.8867 Z-3.0000 S1000
    G1 F1000 X39.9248 Y44.0036 Z-3.0000 S1000
    G1 F1000 X38.4725 Y45.7973 Z-3.0000 S1000
    G1 F1000 X38.3170 Y45.9956 Z-3.0000 S1000
    G1 F1000 X38.1680 Y46.1988 Z-3.0000 S1000
    G1 F1000 X38.0254 Y46.4066 Z-3.0000 S1000
    G1 F1000 X37.8895 Y46.6188 Z-3.0000 S1000
    G1 F1000 X37.7605 Y46.8352 Z-3.0000 S1000
    G1 F1000 X37.6383 Y47.0556 Z-3.0000 S1000
    G1 F1000 X37.5689 Y47.1888 Z-3.0000 S1000
    G1 F1000 X36.5214 Y49.2448 Z-3.0000 S1000
    G1 F1000 X36.4106 Y49.4711 Z-3.0000 S1000
    G1 F1000 X36.3070 Y49.7008 Z-3.0000 S1000
    G1 F1000 X36.2108 Y49.9337 Z-3.0000 S1000
    G1 F1000 X36.1220 Y50.1695 Z-3.0000 S1000
    G1 F1000 X36.0408 Y50.4080 Z-3.0000 S1000
    G1 F1000 X35.9671 Y50.6490 Z-3.0000 S1000
    G1 F1000 X35.9268 Y50.7941 Z-3.0000 S1000
    G1 F1000 X35.3294 Y53.0241 Z-3.0000 S1000
    G1 F1000 X35.2680 Y53.2685 Z-3.0000 S1000
    G1 F1000 X35.2145 Y53.5148 Z-3.0000 S1000
    G1 F1000 X35.1688 Y53.7626 Z-3.0000 S1000
    G1 F1000 X35.1310 Y54.0117 Z-3.0000 S1000
    G1 F1000 X35.1011 Y54.2619 Z-3.0000 S1000
    G1 F1000 X35.0791 Y54.5129 Z-3.0000 S1000
    G1 F1000 X35.0699 Y54.6619 Z-3.0000 S1000
    G1 F1000 X34.9489 Y56.9665 Z-3.0000 S1000
    G1 F1000 X34.9397 Y57.2183 Z-3.0000 S1000
    G1 F1000 X34.9385 Y57.4703 Z-3.0000 S1000
    G1 F1000 X34.9453 Y57.7222 Z-3.0000 S1000
    G1 F1000 X34.9600 Y57.9738 Z-3.0000 S1000
    G1 F1000 X34.9828 Y58.2247 Z-3.0000 S1000
    G1 F1000 X35.0135 Y58.4748 Z-3.0000 S1000
    G1 F1000 X35.0358 Y58.6249 Z-3.0000 S1000
    G1 F1000 X35.3970 Y60.9044 Z-3.0000 S1000
    G1 F1000 X35.4404 Y61.1527 Z-3.0000 S1000
    G1 F1000 X35.4916 Y61.3994 Z-3.0000 S1000
    G1 F1000 X35.5507 Y61.6444 Z-3.0000 S1000
    G1 F1000 X35.6175 Y61.8873 Z-3.0000 S1000
    G1 F1000 X35.6919 Y62.1281 Z-3.0000 S1000
    G1 F1000 X35.7740 Y62.3663 Z-3.0000 S1000
    G1 F1000 X35.8265 Y62.5071 Z-3.0000 S1000
    G1 F1000 X36.6536 Y64.6615 Z-3.0000 S1000
    G1 F1000 X36.7477 Y64.8952 Z-3.0000 S1000
    G1 F1000 X36.8491 Y65.1259 Z-3.0000 S1000
    G1 F1000 X36.9577 Y65.3533 Z-3.0000 S1000
    G1 F1000 X37.0736 Y65.5770 Z-3.0000 S1000
    G1 F1000 X37.1965 Y65.7970 Z-3.0000 S1000
    G1 F1000 X37.3263 Y66.0130 Z-3.0000 S1000
    G1 F1000 X37.4073 Y66.1403 Z-3.0000 S1000
    G1 F1000 X38.6645 Y68.0758 Z-3.0000 S1000
    G1 F1000 X38.8051 Y68.2849 Z-3.0000 S1000
    G1 F1000 X38.9522 Y68.4895 Z-3.0000 S1000
    G1 F1000 X39.1058 Y68.6893 Z-3.0000 S1000
    G1 F1000 X39.2657 Y68.8841 Z-3.0000 S1000
    G1 F1000 X39.4316 Y69.0737 Z-3.0000 S1000
    G1 F1000 X39.6035 Y69.2579 Z-3.0000 S1000
    G1 F1000 X39.7083 Y69.3648 Z-3.0000 S1000
    G1 F1000 X41.3399 Y70.9964 Z-3.0000 S1000
    G1 F1000 X41.5209 Y71.1717 Z-3.0000 S1000
    G1 F1000 X41.7074 Y71.3412 Z-3.0000 S1000
    G1 F1000 X41.8991 Y71.5047 Z-3.0000 S1000
    G1 F1000 X42.0960 Y71.6620 Z-3.0000 S1000
    G1 F1000 X42.2977 Y71.8130 Z-3.0000 S1000
    G1 F1000 X42.5041 Y71.9575 Z-3.0000 S1000
    G1 F1000 X42.6289 Y72.0402 Z-3.0000 S1000
    G1 F1000 X44.5644 Y73.2974 Z-3.0000 S1000
    G1 F1000 X44.7778 Y73.4313 Z-3.0000 S1000
    G1 F1000 X44.9955 Y73.5584 Z-3.0000 S1000
    G1 F1000 X45.2170 Y73.6784 Z-3.0000 S1000
    G1 F1000 X45.4422 Y73.7914 Z-3.0000 S1000
    G1 F1000 X45.6709 Y73.8972 Z-3.0000 S1000
    G1 F1000 X45.9029 Y73.9957 Z-3.0000 S1000
    G1 F1000 X46.0432 Y74.0511 Z-3.0000 S1000
    G1 F1000 X48.1976 Y74.8782 Z-3.0000 S1000
    G1 F1000 X48.4343 Y74.9647 Z-3.0000 S1000
    G1 F1000 X48.6736 Y75.0438 Z-3.0000 S1000
    G1 F1000 X48.9152 Y75.1151 Z-3.0000 S1000
    G1 F1000 X49.1590 Y75.1788 Z-3.0000 S1000
    G1 F1000 X49.4047 Y75.2347 Z-3.0000 S1000
    G1 F1000 X49.6521 Y75.2828 Z-3.0000 S1000
    G1 F1000 X49.8003 Y75.3077 Z-3.0000 S1000
    G1 F1000 X52.0798 Y75.6689 Z-3.0000 S1000
    G1 F1000 X52.3292 Y75.7044 Z-3.0000 S1000
    G1 F1000 X52.5797 Y75.7319 Z-3.0000 S1000
    G1 F1000 X52.8309 Y75.7515 Z-3.0000 S1000
    G1 F1000 X53.0826 Y75.7631 Z-3.0000 S1000
    G1 F1000 X53.3346 Y75.7667 Z-3.0000 S1000
    G1 F1000 X53.5865 Y75.7623 Z-3.0000 S1000
    G1 F1000 X53.7382 Y75.7558 Z-3.0000 S1000
    G1 F1000 X56.0428 Y75.6348 Z-3.0000 S1000
    G1 F1000 X56.2942 Y75.6176 Z-3.0000 S1000
    G1 F1000 X56.5449 Y75.5924 Z-3.0000 S1000
    G1 F1000 X56.7947 Y75.5593 Z-3.0000 S1000
    G1 F1000 X57.0433 Y75.5182 Z-3.0000 S1000
    G1 F1000 X57.2905 Y75.4693 Z-3.0000 S1000
    G1 F1000 X57.5360 Y75.4126 Z-3.0000 S1000
    G1 F1000 X57.6806 Y75.3753 Z-3.0000 S1000
    G1 F1000 X59.9106 Y74.7779 Z-3.0000 S1000
    G1 F1000 X60.1529 Y74.7089 Z-3.0000 S1000
    G1 F1000 X60.3929 Y74.6322 Z-3.0000 S1000
    G1 F1000 X60.6304 Y74.5479 Z-3.0000 S1000
    G1 F1000 X60.8651 Y74.4561 Z-3.0000 S1000
    G1 F1000 X61.0967 Y74.3569 Z-3.0000 S1000
    G1 F1000 X61.3251 Y74.2504 Z-3.0000 S1000
    G1 F1000 X61.4599 Y74.1833 Z-3.0000 S1000
    G1 F1000 X63.5159 Y73.1358 Z-3.0000 S1000
    G1 F1000 X63.7386 Y73.0178 Z-3.0000 S1000
    G1 F1000 X63.9574 Y72.8929 Z-3.0000 S1000
    G1 F1000 X64.1722 Y72.7611 Z-3.0000 S1000
    G1 F1000 X64.3826 Y72.6225 Z-3.0000 S1000
    G1 F1000 X64.5886 Y72.4773 Z-3.0000 S1000
    G1 F1000 X64.7898 Y72.3256 Z-3.0000 S1000
    G1 F1000 X64.9074 Y72.2322 Z-3.0000 S1000
    G1 F1000 X66.7011 Y70.7799 Z-3.0000 S1000
    G1 F1000 X66.8944 Y70.6183 Z-3.0000 S1000
    G1 F1000 X67.0825 Y70.4506 Z-3.0000 S1000
    G1 F1000 X67.2651 Y70.2770 Z-3.0000 S1000
    G1 F1000 X67.4422 Y70.0977 Z-3.0000 S1000
    G1 F1000 X67.6134 Y69.9129 Z-3.0000 S1000
    G1 F1000 X67.7787 Y69.7227 Z-3.0000 S1000
    G1 F1000 X67.8752 Y69.6058 Z-3.0000 S1000
    G1 F1000 X69.3275 Y67.8121 Z-3.0000 S1000
    G1 F1000 X69.4830 Y67.6138 Z-3.0000 S1000
    G1 F1000 X69.6320 Y67.4106 Z-3.0000 S1000
    G1 F1000 X69.7746 Y67.2028 Z-3.0000 S1000
    G1 F1000 X69.9105 Y66.9906 Z-3.0000 S1000
    G1 F1000 X70.0395 Y66.7742 Z-3.0000 S1000
    G1 F1000 X70.1617 Y66.5538 Z-3.0000 S1000
    G1 F1000 X70.2311 Y66.4206 Z-3.0000 S1000
    G1 F1000 X71.2786 Y64.3646 Z-3.0000 S1000
    G1 F1000 X71.3894 Y64.1383 Z-3.0000 S1000
    G1 F1000 X71.4930 Y63.9086 Z-3.0000 S1000
    G1 F1000 X71.5892 Y63.6757 Z-3.0000 S1000
    G1 F1000 X71.6780 Y63.4399 Z-3.0000 S1000
    G1 F1000 X71.7592 Y63.2014 Z-3.0000 S1000
    G1 F1000 X71.8329 Y62.9604 Z-3.0000 S1000
    G1 F1000 X71.8732 Y62.8153 Z-3.0000 S1000
    G1 F1000 X72.4706 Y60.5853 Z-3.0000 S1000
    G1 F1000 X72.5320 Y60.3409 Z-3.0000 S1000
    G1 F1000 X72.5855 Y60.0946 Z-3.0000 S1000
    G1 F1000 X72.6312 Y59.8468 Z-3.0000 S1000
    G1 F1000 X72.6690 Y59.5977 Z-3.0000 S1000
    G1 F1000 X72.6989 Y59.3475 Z-3.0000 S1000
    G1 F1000 X72.7209 Y59.0965 Z-3.0000 S1000
    G1 F1000 X72.7301 Y58.9475 Z-3.0000 S1000
    G1 F1000 X72.8511 Y56.6429 Z-3.0000 S1000
    G1 F1000 X72.8603 Y56.3911 Z-3.0000 S1000
    G1 F1000 X72.8615 Y56.1391 Z-3.0000 S1000
    G1 F1000 X72.8547 Y55.8872 Z-3.0000 S1000
    G1 F1000 X72.8400 Y55.6356 Z-3.0000 S1000
    G1 F1000 X72.8172 Y55.3847 Z-3.0000 S1000
    G1 F1000 X72.7865 Y55.1346 Z-3.0000 S1000
    G1 F1000 X72.7642 Y54.9845 Z-3.0000 S1000
    G1 F1000 X72.4030 Y52.7050 Z-3.0000 S1000
    G1 F1000 X72.3596 Y52.4567 Z-3.0000 S1000
    G1 F1000 X72.3084 Y52.2100 Z-3.0000 S1000
    G1 F1000 X72.2493 Y51.9650 Z-3.0000 S1000
    G1 F1000 X72.1825 Y51.7221 Z-3.0000 S1000
    G1 F1000 X72.1081 Y51.4813 Z-3.0000 S1000
    G1 F1000 X72.0260 Y51.2431 Z-3.0000 S1000
    G1 F1000 X71.9735 Y51.1023 Z-3.0000 S1000
    G1 F1000 X71.1464 Y48.9479 Z-3.0000 S1000
    G1 F1000 X71.0523 Y48.7142 Z-3.0000 S1000
    G1 F1000 X70.9509 Y48.4835 Z-3.0000 S1000
    G1 F1000 X70.8423 Y48.2561 Z-3.0000 S1000
    G1 F1000 X70.7264 Y48.0324 Z-3.0000 S1000
    G1 F1000 X70.6035 Y47.8124 Z-3.0000 S1000
    G1 F1000 X70.4737 Y47.5964 Z-3.0000 S1000
    G1 F1000 X70.3927 Y47.4691 Z-3.0000 S1000
    G1 F1000 X69.1355 Y45.5336 Z-3.0000 S1000
    G1 F1000 X68.9949 Y45.3245 Z-3.0000 S1000
    G1 F1000 X68.8478 Y45.1199 Z-3.0000 S1000
    G1 F1000 X68.6942 Y44.9201 Z-3.0000 S1000
    G1 F1000 X68.5343 Y44.7253 Z-3.0000 S1000
    G1 F1000 X68.3754 Y44.5437 Z-3.0000 S1000
    G0 Z7
    G0 X66.4718 Y44.8699
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X70.0447 Y37.2077 Z-1.0000 S1000
    G1 F1000 X70.1299 Y37.2129 Z-1.0000 S1000
    G1 F1000 X70.3552 Y37.2187 Z-1.0000 S1000
    G1 F1000 X70.5806 Y37.2165 Z-1.0000 S1000
    G1 F1000 X70.8057 Y37.2063 Z-1.0000 S1000
    G1 F1000 X71.0304 Y37.1881 Z-1.0000 S1000
    G1 F1000 X71.2542 Y37.1620 Z-1.0000 S1000
    G1 F1000 X71.4770 Y37.1279 Z-1.0000 S1000
    G1 F1000 X71.6984 Y37.0859 Z-1.0000 S1000
    G1 F1000 X71.9182 Y37.0362 Z-1.0000 S1000
    G1 F1000 X72.1362 Y36.9786 Z-1.0000 S1000
    G1 F1000 X72.3519 Y36.9133 Z-1.0000 S1000
    G1 F1000 X72.5652 Y36.8405 Z-1.0000 S1000
    G1 F1000 X72.7757 Y36.7601 Z-1.0000 S1000
    G1 F1000 X72.9833 Y36.6723 Z-1.0000 S1000
    G1 F1000 X73.1876 Y36.5771 Z-1.0000 S1000
    G1 F1000 X73.3884 Y36.4748 Z-1.0000 S1000
    G1 F1000 X73.5855 Y36.3655 Z-1.0000 S1000
    G1 F1000 X73.7785 Y36.2492 Z-1.0000 S1000
    G1 F1000 X73.9673 Y36.1261 Z-1.0000 S1000
    G1 F1000 X74.2117 Y35.9520 Z-1.0000 S1000
    G1 F1000 X76.3648 Y34.3399 Z-1.0000 S1000
    G1 F1000 X74.7527 Y36.4930 Z-1.0000 S1000
    G1 F1000 X74.6209 Y36.6758 Z-1.0000 S1000
    G1 F1000 X74.4956 Y36.8631 Z-1.0000 S1000
    G1 F1000 X74.3770 Y37.0548 Z-1.0000 S1000
    G1 F1000 X74.2653 Y37.2506 Z-1.0000 S1000
    G1 F1000 X74.1607 Y37.4502 Z-1.0000 S1000
    G1 F1000 X74.0631 Y37.6534 Z-1.0000 S1000
    G1 F1000 X73.9729 Y37.8599 Z-1.0000 S1000
    G1 F1000 X73.8900 Y38.0695 Z-1.0000 S1000
    G1 F1000 X73.8147 Y38.2819 Z-1.0000 S1000
    G1 F1000 X73.7469 Y38.4968 Z-1.0000 S1000
    G1 F1000 X73.6868 Y38.7140 Z-1.0000 S1000
    G1 F1000 X73.6344 Y38.9332 Z-1.0000 S1000
    G1 F1000 X73.5898 Y39.1542 Z-1.0000 S1000
    G1 F1000 X73.5531 Y39.3766 Z-1.0000 S1000
    G1 F1000 X73.5244 Y39.6001 Z-1.0000 S1000
    G1 F1000 X73.5035 Y39.8245 Z-1.0000 S1000
    G1 F1000 X73.4907 Y40.0495 Z-1.0000 S1000
    G1 F1000 X73.4858 Y40.2748 Z-1.0000 S1000
    G1 F1000 X73.4890 Y40.5002 Z-1.0000 S1000
    G1 F1000 X73.5001 Y40.7253 Z-1.0000 S1000
    G1 F1000 X73.5193 Y40.9499 Z-1.0000 S1000
    G1 F1000 X73.5463 Y41.1736 Z-1.0000 S1000
    G1 F1000 X73.5813 Y41.3963 Z-1.0000 S1000
    G1 F1000 X73.6242 Y41.6175 Z-1.0000 S1000
    G1 F1000 X73.6749 Y41.8371 Z-1.0000 S1000
    G1 F1000 X73.7334 Y42.0548 Z-1.0000 S1000
    G1 F1000 X73.7996 Y42.2702 Z-1.0000 S1000
    G1 F1000 X73.8733 Y42.4832 Z-1.0000 S1000
    G1 F1000 X73.9546 Y42.6934 Z-1.0000 S1000
    G1 F1000 X74.0433 Y42.9006 Z-1.0000 S1000
    G1 F1000 X74.1392 Y43.1046 Z-1.0000 S1000
    G1 F1000 X74.2424 Y43.3049 Z-1.0000 S1000
    G1 F1000 X74.3526 Y43.5015 Z-1.0000 S1000
    G1 F1000 X74.5100 Y43.7570 Z-1.0000 S1000
    G1 F1000 X75.7524 Y45.6705 Z-1.0000 S1000
    G1 F1000 X77.5901 Y50.4571 Z-1.0000 S1000
    G1 F1000 X77.6981 Y51.1389 Z-1.0000 S1000
    G1 F1000 X77.7373 Y51.3608 Z-1.0000 S1000
    G1 F1000 X77.7844 Y51.5812 Z-1.0000 S1000
    G1 F1000 X77.8393 Y51.7998 Z-1.0000 S1000
    G1 F1000 X77.9018 Y52.0163 Z-1.0000 S1000
    G1 F1000 X77.9721 Y52.2305 Z-1.0000 S1000
    G1 F1000 X78.0498 Y52.4420 Z-1.0000 S1000
    G1 F1000 X78.1351 Y52.6507 Z-1.0000 S1000
    G1 F1000 X78.2277 Y52.8562 Z-1.0000 S1000
    G1 F1000 X78.3275 Y53.0582 Z-1.0000 S1000
    G1 F1000 X78.4344 Y53.2566 Z-1.0000 S1000
    G1 F1000 X78.5483 Y53.4511 Z-1.0000 S1000
    G1 F1000 X78.6691 Y53.6414 Z-1.0000 S1000
    G1 F1000 X78.7965 Y53.8273 Z-1.0000 S1000
    G1 F1000 X78.9304 Y54.0086 Z-1.0000 S1000
    G1 F1000 X79.0707 Y54.1850 Z-1.0000 S1000
    G1 F1000 X79.2171 Y54.3563 Z-1.0000 S1000
    G1 F1000 X79.3696 Y54.5223 Z-1.0000 S1000
    G1 F1000 X79.5278 Y54.6828 Z-1.0000 S1000
    G1 F1000 X79.6916 Y54.8376 Z-1.0000 S1000
    G1 F1000 X79.8608 Y54.9865 Z-1.0000 S1000
    G1 F1000 X80.0352 Y55.1293 Z-1.0000 S1000
    G1 F1000 X80.2146 Y55.2657 Z-1.0000 S1000
    G1 F1000 X80.3987 Y55.3958 Z-1.0000 S1000
    G1 F1000 X80.5872 Y55.5192 Z-1.0000 S1000
    G1 F1000 X80.7801 Y55.6359 Z-1.0000 S1000
    G1 F1000 X80.9769 Y55.7456 Z-1.0000 S1000
    G1 F1000 X81.1776 Y55.8483 Z-1.0000 S1000
    G1 F1000 X81.3817 Y55.9438 Z-1.0000 S1000
    G1 F1000 X81.5891 Y56.0320 Z-1.0000 S1000
    G1 F1000 X81.7995 Y56.1128 Z-1.0000 S1000
    G1 F1000 X82.0127 Y56.1860 Z-1.0000 S1000
    G1 F1000 X82.2283 Y56.2517 Z-1.0000 S1000
    G1 F1000 X82.4461 Y56.3096 Z-1.0000 S1000
    G1 F1000 X82.6658 Y56.3598 Z-1.0000 S1000
    G1 F1000 X82.8871 Y56.4022 Z-1.0000 S1000
    G1 F1000 X83.0668 Y56.4307 Z-1.0000 S1000
    G1 F1000 X85.6693 Y56.8046 Z-1.0000 S1000
    G1 F1000 X83.0374 Y57.1827 Z-1.0000 S1000
    G1 F1000 X82.8149 Y57.2187 Z-1.0000 S1000
    G1 F1000 X82.5938 Y57.2626 Z-1.0000 S1000
    G1 F1000 X82.3745 Y57.3143 Z-1.0000 S1000
    G1 F1000 X82.1571 Y57.3737 Z-1.0000 S1000
    G1 F1000 X81.9419 Y57.4409 Z-1.0000 S1000
    G1 F1000 X81.7293 Y57.5156 Z-1.0000 S1000
    G1 F1000 X81.5194 Y57.5978 Z-1.0000 S1000
    G1 F1000 X81.3126 Y57.6874 Z-1.0000 S1000
    G1 F1000 X81.1091 Y57.7843 Z-1.0000 S1000
    G1 F1000 X80.9092 Y57.8883 Z-1.0000 S1000
    G1 F1000 X80.7131 Y57.9994 Z-1.0000 S1000
    G1 F1000 X80.5211 Y58.1174 Z-1.0000 S1000
    G1 F1000 X80.3333 Y58.2421 Z-1.0000 S1000
    G1 F1000 X80.1501 Y58.3734 Z-1.0000 S1000
    G1 F1000 X79.9717 Y58.5111 Z-1.0000 S1000
    G1 F1000 X79.7983 Y58.6550 Z-1.0000 S1000
    G1 F1000 X79.6301 Y58.8051 Z-1.0000 S1000
    G1 F1000 X79.4673 Y58.9610 Z-1.0000 S1000
    G1 F1000 X79.3102 Y59.1225 Z-1.0000 S1000
    G1 F1000 X79.1589 Y59.2896 Z-1.0000 S1000
    G1 F1000 X79.0136 Y59.4619 Z-1.0000 S1000
    G1 F1000 X78.8746 Y59.6392 Z-1.0000 S1000
    G1 F1000 X78.7419 Y59.8214 Z-1.0000 S1000
    G1 F1000 X78.6157 Y60.0082 Z-1.0000 S1000
    G1 F1000 X78.4963 Y60.1993 Z-1.0000 S1000
    G1 F1000 X78.3837 Y60.3946 Z-1.0000 S1000
    G1 F1000 X78.2782 Y60.5937 Z-1.0000 S1000
    G1 F1000 X78.1797 Y60.7965 Z-1.0000 S1000
    G1 F1000 X78.0885 Y61.0026 Z-1.0000 S1000
    G1 F1000 X78.0047 Y61.2118 Z-1.0000 S1000
    G1 F1000 X77.9284 Y61.4238 Z-1.0000 S1000
    G1 F1000 X77.8596 Y61.6385 Z-1.0000 S1000
    G1 F1000 X77.8067 Y61.8247 Z-1.0000 S1000
    G1 F1000 X76.7968 Y65.5936 Z-1.0000 S1000
    G1 F1000 X74.2706 Y70.5518 Z-1.0000 S1000
    G1 F1000 X74.1718 Y70.7544 Z-1.0000 S1000
    G1 F1000 X74.0803 Y70.9604 Z-1.0000 S1000
    G1 F1000 X73.9962 Y71.1695 Z-1.0000 S1000
    G1 F1000 X73.9196 Y71.3815 Z-1.0000 S1000
    G1 F1000 X73.8505 Y71.5960 Z-1.0000 S1000
    G1 F1000 X73.7891 Y71.8128 Z-1.0000 S1000
    G1 F1000 X73.7354 Y72.0317 Z-1.0000 S1000
    G1 F1000 X73.6895 Y72.2524 Z-1.0000 S1000
    G1 F1000 X73.6515 Y72.4745 Z-1.0000 S1000
    G1 F1000 X73.6214 Y72.6979 Z-1.0000 S1000
    G1 F1000 X73.5992 Y72.9222 Z-1.0000 S1000
    G1 F1000 X73.5850 Y73.1471 Z-1.0000 S1000
    G1 F1000 X73.5788 Y73.3724 Z-1.0000 S1000
    G1 F1000 X73.5806 Y73.5978 Z-1.0000 S1000
    G1 F1000 X73.5904 Y73.8229 Z-1.0000 S1000
    G1 F1000 X73.6082 Y74.0476 Z-1.0000 S1000
    G1 F1000 X73.6339 Y74.2715 Z-1.0000 S1000
    G1 F1000 X73.6676 Y74.4944 Z-1.0000 S1000
    G1 F1000 X73.7091 Y74.7159 Z-1.0000 S1000
    G1 F1000 X73.7585 Y74.9358 Z-1.0000 S1000
    G1 F1000 X73.8157 Y75.1538 Z-1.0000 S1000
    G1 F1000 X73.8805 Y75.3697 Z-1.0000 S1000
    G1 F1000 X73.9530 Y75.5831 Z-1.0000 S1000
    G1 F1000 X74.0330 Y75.7938 Z-1.0000 S1000
    G1 F1000 X74.1204 Y76.0015 Z-1.0000 S1000
    G1 F1000 X74.2152 Y76.2060 Z-1.0000 S1000
    G1 F1000 X74.3171 Y76.4070 Z-1.0000 S1000
    G1 F1000 X74.4262 Y76.6043 Z-1.0000 S1000
    G1 F1000 X74.5421 Y76.7975 Z-1.0000 S1000
    G1 F1000 X74.6648 Y76.9865 Z-1.0000 S1000
    G1 F1000 X74.8455 Y77.2406 Z-1.0000 S1000
    G1 F1000 X76.3643 Y79.2690 Z-1.0000 S1000
    G1 F1000 X74.3359 Y77.7502 Z-1.0000 S1000
    G1 F1000 X74.1531 Y77.6183 Z-1.0000 S1000
    G1 F1000 X73.9658 Y77.4930 Z-1.0000 S1000
    G1 F1000 X73.7741 Y77.3745 Z-1.0000 S1000
    G1 F1000 X73.5783 Y77.2628 Z-1.0000 S1000
    G1 F1000 X73.3787 Y77.1581 Z-1.0000 S1000
    G1 F1000 X73.1755 Y77.0606 Z-1.0000 S1000
    G1 F1000 X72.9690 Y76.9703 Z-1.0000 S1000
    G1 F1000 X72.7594 Y76.8875 Z-1.0000 S1000
    G1 F1000 X72.5470 Y76.8121 Z-1.0000 S1000
    G1 F1000 X72.3321 Y76.7443 Z-1.0000 S1000
    G1 F1000 X72.1149 Y76.6842 Z-1.0000 S1000
    G1 F1000 X71.8957 Y76.6318 Z-1.0000 S1000
    G1 F1000 X71.6747 Y76.5873 Z-1.0000 S1000
    G1 F1000 X71.4524 Y76.5506 Z-1.0000 S1000
    G1 F1000 X71.2288 Y76.5218 Z-1.0000 S1000
    G1 F1000 X71.0044 Y76.5010 Z-1.0000 S1000
    G1 F1000 X70.7794 Y76.4881 Z-1.0000 S1000
    G1 F1000 X70.5541 Y76.4832 Z-1.0000 S1000
    G1 F1000 X70.3287 Y76.4864 Z-1.0000 S1000
    G1 F1000 X70.1036 Y76.4975 Z-1.0000 S1000
    G1 F1000 X69.8790 Y76.5166 Z-1.0000 S1000
    G1 F1000 X69.6553 Y76.5437 Z-1.0000 S1000
    G1 F1000 X69.4326 Y76.5787 Z-1.0000 S1000
    G1 F1000 X69.2114 Y76.6216 Z-1.0000 S1000
    G1 F1000 X68.9918 Y76.6723 Z-1.0000 S1000
    G1 F1000 X68.7741 Y76.7308 Z-1.0000 S1000
    G1 F1000 X68.5587 Y76.7969 Z-1.0000 S1000
    G1 F1000 X68.3457 Y76.8707 Z-1.0000 S1000
    G1 F1000 X68.1355 Y76.9519 Z-1.0000 S1000
    G1 F1000 X67.9283 Y77.0406 Z-1.0000 S1000
    G1 F1000 X67.6471 Y77.1753 Z-1.0000 S1000
    G1 F1000 X62.6889 Y79.7015 Z-1.0000 S1000
    G1 F1000 X58.9200 Y80.7114 Z-1.0000 S1000
    G1 F1000 X58.7034 Y80.7735 Z-1.0000 S1000
    G1 F1000 X58.4891 Y80.8434 Z-1.0000 S1000
    G1 F1000 X58.2774 Y80.9208 Z-1.0000 S1000
    G1 F1000 X58.0686 Y81.0056 Z-1.0000 S1000
    G1 F1000 X57.8630 Y81.0979 Z-1.0000 S1000
    G1 F1000 X57.6607 Y81.1973 Z-1.0000 S1000
    G1 F1000 X57.4621 Y81.3039 Z-1.0000 S1000
    G1 F1000 X57.2675 Y81.4174 Z-1.0000 S1000
    G1 F1000 X57.0769 Y81.5378 Z-1.0000 S1000
    G1 F1000 X56.8908 Y81.6649 Z-1.0000 S1000
    G1 F1000 X56.7093 Y81.7985 Z-1.0000 S1000
    G1 F1000 X56.5326 Y81.9384 Z-1.0000 S1000
    G1 F1000 X56.3610 Y82.0846 Z-1.0000 S1000
    G1 F1000 X56.1947 Y82.2367 Z-1.0000 S1000
    G1 F1000 X56.0340 Y82.3946 Z-1.0000 S1000
    G1 F1000 X55.8789 Y82.5582 Z-1.0000 S1000
    G1 F1000 X55.7297 Y82.7271 Z-1.0000 S1000
    G1 F1000 X55.5866 Y82.9013 Z-1.0000 S1000
    G1 F1000 X55.4498 Y83.0804 Z-1.0000 S1000
    G1 F1000 X55.3194 Y83.2642 Z-1.0000 S1000
    G1 F1000 X55.1956 Y83.4526 Z-1.0000 S1000
    G1 F1000 X55.0786 Y83.6452 Z-1.0000 S1000
    G1 F1000 X54.9685 Y83.8418 Z-1.0000 S1000
    G1 F1000 X54.8655 Y84.0423 Z-1.0000 S1000
    G1 F1000 X54.7696 Y84.2463 Z-1.0000 S1000
    G1 F1000 X54.6810 Y84.4535 Z-1.0000 S1000
    G1 F1000 X54.5999 Y84.6638 Z-1.0000 S1000
    G1 F1000 X54.5262 Y84.8768 Z-1.0000 S1000
    G1 F1000 X54.4602 Y85.0923 Z-1.0000 S1000
    G1 F1000 X54.4018 Y85.3099 Z-1.0000 S1000
    G1 F1000 X54.3512 Y85.5296 Z-1.0000 S1000
    G1 F1000 X54.3085 Y85.7509 Z-1.0000 S1000
    G1 F1000 X54.2780 Y85.9421 Z-1.0000 S1000
    G1 F1000 X53.8999 Y88.5740 Z-1.0000 S1000
    G1 F1000 X53.5260 Y85.9715 Z-1.0000 S1000
    G1 F1000 X53.4899 Y85.7490 Z-1.0000 S1000
    G1 F1000 X53.4461 Y85.5280 Z-1.0000 S1000
    G1 F1000 X53.3944 Y85.3086 Z-1.0000 S1000
    G1 F1000 X53.3349 Y85.0912 Z-1.0000 S1000
    G1 F1000 X53.2678 Y84.8761 Z-1.0000 S1000
    G1 F1000 X53.1931 Y84.6634 Z-1.0000 S1000
    G1 F1000 X53.1109 Y84.4536 Z-1.0000 S1000
    G1 F1000 X53.0212 Y84.2468 Z-1.0000 S1000
    G1 F1000 X52.9244 Y84.0433 Z-1.0000 S1000
    G1 F1000 X52.8203 Y83.8434 Z-1.0000 S1000
    G1 F1000 X52.7092 Y83.6473 Z-1.0000 S1000
    G1 F1000 X52.5912 Y83.4552 Z-1.0000 S1000
    G1 F1000 X52.4665 Y83.2675 Z-1.0000 S1000
    G1 F1000 X52.3352 Y83.0843 Z-1.0000 S1000
    G1 F1000 X52.1975 Y82.9059 Z-1.0000 S1000
    G1 F1000 X52.0535 Y82.7325 Z-1.0000 S1000
    G1 F1000 X51.9035 Y82.5643 Z-1.0000 S1000
    G1 F1000 X51.7476 Y82.4015 Z-1.0000 S1000
    G1 F1000 X51.5861 Y82.2444 Z-1.0000 S1000
    G1 F1000 X51.4190 Y82.0931 Z-1.0000 S1000
    G1 F1000 X51.2467 Y81.9478 Z-1.0000 S1000
    G1 F1000 X51.0693 Y81.8088 Z-1.0000 S1000
    G1 F1000 X50.8871 Y81.6761 Z-1.0000 S1000
    G1 F1000 X50.7004 Y81.5500 Z-1.0000 S1000
    G1 F1000 X50.5092 Y81.4305 Z-1.0000 S1000
    G1 F1000 X50.3140 Y81.3180 Z-1.0000 S1000
    G1 F1000 X50.1148 Y81.2124 Z-1.0000 S1000
    G1 F1000 X49.9121 Y81.1140 Z-1.0000 S1000
    G1 F1000 X49.7060 Y81.0228 Z-1.0000 S1000
    G1 F1000 X49.4968 Y80.9390 Z-1.0000 S1000
    G1 F1000 X49.2847 Y80.8626 Z-1.0000 S1000
    G1 F1000 X49.0701 Y80.7939 Z-1.0000 S1000
    G1 F1000 X48.8531 Y80.7328 Z-1.0000 S1000
    G1 F1000 X48.6342 Y80.6794 Z-1.0000 S1000
    G1 F1000 X48.4134 Y80.6339 Z-1.0000 S1000
    G1 F1000 X48.2342 Y80.6028 Z-1.0000 S1000
    G1 F1000 X47.5524 Y80.4948 Z-1.0000 S1000
    G1 F1000 X42.7658 Y78.6571 Z-1.0000 S1000
    G1 F1000 X40.8523 Y77.4147 Z-1.0000 S1000
    G1 F1000 X40.6611 Y77.2953 Z-1.0000 S1000
    G1 F1000 X40.4658 Y77.1828 Z-1.0000 S1000
    G1 F1000 X40.2666 Y77.0773 Z-1.0000 S1000
    G1 F1000 X40.0639 Y76.9790 Z-1.0000 S1000
    G1 F1000 X39.8577 Y76.8878 Z-1.0000 S1000
    G1 F1000 X39.6485 Y76.8041 Z-1.0000 S1000
    G1 F1000 X39.4364 Y76.7278 Z-1.0000 S1000
    G1 F1000 X39.2217 Y76.6592 Z-1.0000 S1000
    G1 F1000 X39.0048 Y76.5981 Z-1.0000 S1000
    G1 F1000 X38.7858 Y76.5449 Z-1.0000 S1000
    G1 F1000 X38.5650 Y76.4994 Z-1.0000 S1000
    G1 F1000 X38.3428 Y76.4618 Z-1.0000 S1000
    G1 F1000 X38.1194 Y76.4320 Z-1.0000 S1000
    G1 F1000 X37.8951 Y76.4103 Z-1.0000 S1000
    G1 F1000 X37.6701 Y76.3965 Z-1.0000 S1000
    G1 F1000 X37.4448 Y76.3907 Z-1.0000 S1000
    G1 F1000 X37.2194 Y76.3929 Z-1.0000 S1000
    G1 F1000 X36.9943 Y76.4031 Z-1.0000 S1000
    G1 F1000 X36.7696 Y76.4213 Z-1.0000 S1000
    G1 F1000 X36.5458 Y76.4474 Z-1.0000 S1000
    G1 F1000 X36.3230 Y76.4815 Z-1.0000 S1000
    G1 F1000 X36.1016 Y76.5235 Z-1.0000 S1000
    G1 F1000 X35.8818 Y76.5732 Z-1.0000 S1000
    G1 F1000 X35.6638 Y76.6308 Z-1.0000 S1000
    G1 F1000 X35.4481 Y76.6961 Z-1.0000 S1000
    G1 F1000 X35.2348 Y76.7689 Z-1.0000 S1000
    G1 F1000 X35.0243 Y76.8493 Z-1.0000 S1000
    G1 F1000 X34.8167 Y76.9371 Z-1.0000 S1000
    G1 F1000 X34.6124 Y77.0323 Z-1.0000 S1000
    G1 F1000 X34.4116 Y77.1346 Z-1.0000 S1000
    G1 F1000 X34.2145 Y77.2439 Z-1.0000 S1000
    G1 F1000 X34.0215 Y77.3602 Z-1.0000 S1000
    G1 F1000 X33.8327 Y77.4833 Z-1.0000 S1000
    G1 F1000 X33.5883 Y77.6574 Z-1.0000 S1000
    G1 F1000 X31.4353 Y79.2694 Z-1.0000 S1000
    G1 F1000 X33.0473 Y77.1165 Z-1.0000 S1000
    G1 F1000 X33.1791 Y76.9337 Z-1.0000 S1000
    G1 F1000 X33.3044 Y76.7464 Z-1.0000 S1000
    G1 F1000 X33.4230 Y76.5547 Z-1.0000 S1000
    G1 F1000 X33.5347 Y76.3590 Z-1.0000 S1000
    G1 F1000 X33.6393 Y76.1594 Z-1.0000 S1000
    G1 F1000 X33.7368 Y75.9562 Z-1.0000 S1000
    G1 F1000 X33.8271 Y75.7497 Z-1.0000 S1000
    G1 F1000 X33.9100 Y75.5401 Z-1.0000 S1000
    G1 F1000 X33.9853 Y75.3277 Z-1.0000 S1000
    G1 F1000 X34.0531 Y75.1127 Z-1.0000 S1000
    G1 F1000 X34.1132 Y74.8955 Z-1.0000 S1000
    G1 F1000 X34.1656 Y74.6763 Z-1.0000 S1000
    G1 F1000 X34.2102 Y74.4554 Z-1.0000 S1000
    G1 F1000 X34.2469 Y74.2330 Z-1.0000 S1000
    G1 F1000 X34.2756 Y74.0095 Z-1.0000 S1000
    G1 F1000 X34.2965 Y73.7850 Z-1.0000 S1000
    G1 F1000 X34.3093 Y73.5600 Z-1.0000 S1000
    G1 F1000 X34.3142 Y73.3347 Z-1.0000 S1000
    G1 F1000 X34.3110 Y73.1093 Z-1.0000 S1000
    G1 F1000 X34.2999 Y72.8842 Z-1.0000 S1000
    G1 F1000 X34.2807 Y72.6597 Z-1.0000 S1000
    G1 F1000 X34.2537 Y72.4359 Z-1.0000 S1000
    G1 F1000 X34.2187 Y72.2133 Z-1.0000 S1000
    G1 F1000 X34.1758 Y71.9920 Z-1.0000 S1000
    G1 F1000 X34.1251 Y71.7724 Z-1.0000 S1000
    G1 F1000 X34.0666 Y71.5547 Z-1.0000 S1000
    G1 F1000 X34.0005 Y71.3393 Z-1.0000 S1000
    G1 F1000 X33.9267 Y71.1263 Z-1.0000 S1000
    G1 F1000 X33.8454 Y70.9161 Z-1.0000 S1000
    G1 F1000 X33.7568 Y70.7089 Z-1.0000 S1000
    G1 F1000 X33.6608 Y70.5050 Z-1.0000 S1000
    G1 F1000 X33.5576 Y70.3046 Z-1.0000 S1000
    G1 F1000 X33.4474 Y70.1080 Z-1.0000 S1000
    G1 F1000 X33.2901 Y69.8526 Z-1.0000 S1000
    G1 F1000 X32.0475 Y67.9388 Z-1.0000 S1000
    G1 F1000 X30.2099 Y63.1523 Z-1.0000 S1000
    G1 F1000 X30.1019 Y62.4705 Z-1.0000 S1000
    G1 F1000 X30.0627 Y62.2486 Z-1.0000 S1000
    G1 F1000 X30.0156 Y62.0282 Z-1.0000 S1000
    G1 F1000 X29.9607 Y61.8096 Z-1.0000 S1000
    G1 F1000 X29.8982 Y61.5931 Z-1.0000 S1000
    G1 F1000 X29.8279 Y61.3789 Z-1.0000 S1000
    G1 F1000 X29.7502 Y61.1674 Z-1.0000 S1000
    G1 F1000 X29.6649 Y60.9587 Z-1.0000 S1000
    G1 F1000 X29.5723 Y60.7532 Z-1.0000 S1000
    G1 F1000 X29.4725 Y60.5512 Z-1.0000 S1000
    G1 F1000 X29.3656 Y60.3528 Z-1.0000 S1000
    G1 F1000 X29.2517 Y60.1583 Z-1.0000 S1000
    G1 F1000 X29.1309 Y59.9680 Z-1.0000 S1000
    G1 F1000 X29.0035 Y59.7821 Z-1.0000 S1000
    G1 F1000 X28.8696 Y59.6008 Z-1.0000 S1000
    G1 F1000 X28.7293 Y59.4244 Z-1.0000 S1000
    G1 F1000 X28.5829 Y59.2531 Z-1.0000 S1000
    G1 F1000 X28.4304 Y59.0871 Z-1.0000 S1000
    G1 F1000 X28.2722 Y58.9266 Z-1.0000 S1000
    G1 F1000 X28.1084 Y58.7718 Z-1.0000 S1000
    G1 F1000 X27.9392 Y58.6229 Z-1.0000 S1000
    G1 F1000 X27.7648 Y58.4801 Z-1.0000 S1000
    G1 F1000 X27.5854 Y58.3437 Z-1.0000 S1000
    G1 F1000 X27.4013 Y58.2136 Z-1.0000 S1000
    G1 F1000 X27.2128 Y58.0902 Z-1.0000 S1000
    G1 F1000 X27.0199 Y57.9735 Z-1.0000 S1000
    G1 F1000 X26.8231 Y57.8638 Z-1.0000 S1000
    G1 F1000 X26.6224 Y57.7611 Z-1.0000 S1000
    G1 F1000 X26.4183 Y57.6656 Z-1.0000 S1000
    G1 F1000 X26.2109 Y57.5774 Z-1.0000 S1000
    G1 F1000 X26.0005 Y57.4966 Z-1.0000 S1000
    G1 F1000 X25.7873 Y57.4234 Z-1.0000 S1000
    G1 F1000 X25.5717 Y57.3577 Z-1.0000 S1000
    G1 F1000 X25.3539 Y57.2998 Z-1.0000 S1000
    G1 F1000 X25.1342 Y57.2496 Z-1.0000 S1000
    G1 F1000 X24.9129 Y57.2072 Z-1.0000 S1000
    G1 F1000 X24.7332 Y57.1787 Z-1.0000 S1000
    G1 F1000 X22.1309 Y56.8048 Z-1.0000 S1000
    G1 F1000 X24.7626 Y56.4268 Z-1.0000 S1000
    G1 F1000 X24.9850 Y56.3908 Z-1.0000 S1000
    G1 F1000 X25.2061 Y56.3469 Z-1.0000 S1000
    G1 F1000 X25.4255 Y56.2952 Z-1.0000 S1000
    G1 F1000 X25.6429 Y56.2358 Z-1.0000 S1000
    G1 F1000 X25.8580 Y56.1687 Z-1.0000 S1000
    G1 F1000 X26.0707 Y56.0940 Z-1.0000 S1000
    G1 F1000 X26.2805 Y56.0117 Z-1.0000 S1000
    G1 F1000 X26.4873 Y55.9221 Z-1.0000 S1000
    G1 F1000 X26.6908 Y55.8253 Z-1.0000 S1000
    G1 F1000 X26.8907 Y55.7212 Z-1.0000 S1000
    G1 F1000 X27.0868 Y55.6101 Z-1.0000 S1000
    G1 F1000 X27.2789 Y55.4922 Z-1.0000 S1000
    G1 F1000 X27.4666 Y55.3675 Z-1.0000 S1000
    G1 F1000 X27.6498 Y55.2362 Z-1.0000 S1000
    G1 F1000 X27.8282 Y55.0984 Z-1.0000 S1000
    G1 F1000 X28.0016 Y54.9545 Z-1.0000 S1000
    G1 F1000 X28.1698 Y54.8045 Z-1.0000 S1000
    G1 F1000 X28.3326 Y54.6486 Z-1.0000 S1000
    G1 F1000 X28.4897 Y54.4870 Z-1.0000 S1000
    G1 F1000 X28.6410 Y54.3200 Z-1.0000 S1000
    G1 F1000 X28.7863 Y54.1477 Z-1.0000 S1000
    G1 F1000 X28.9254 Y53.9703 Z-1.0000 S1000
    G1 F1000 X29.0581 Y53.7881 Z-1.0000 S1000
    G1 F1000 X29.1842 Y53.6014 Z-1.0000 S1000
    G1 F1000 X29.3037 Y53.4102 Z-1.0000 S1000
    G1 F1000 X29.4162 Y53.2150 Z-1.0000 S1000
    G1 F1000 X29.5218 Y53.0158 Z-1.0000 S1000
    G1 F1000 X29.6203 Y52.8131 Z-1.0000 S1000
    G1 F1000 X29.7114 Y52.6070 Z-1.0000 S1000
    G1 F1000 X29.7953 Y52.3978 Z-1.0000 S1000
    G1 F1000 X29.8716 Y52.1857 Z-1.0000 S1000
    G1 F1000 X29.9404 Y51.9711 Z-1.0000 S1000
    G1 F1000 X29.9933 Y51.7848 Z-1.0000 S1000
    G1 F1000 X31.0031 Y48.0161 Z-1.0000 S1000
    G1 F1000 X33.5295 Y43.0575 Z-1.0000 S1000
    G1 F1000 X33.6282 Y42.8549 Z-1.0000 S1000
    G1 F1000 X33.7197 Y42.6489 Z-1.0000 S1000
    G1 F1000 X33.8038 Y42.4399 Z-1.0000 S1000
    G1 F1000 X33.8804 Y42.2279 Z-1.0000 S1000
    G1 F1000 X33.9495 Y42.0134 Z-1.0000 S1000
    G1 F1000 X34.0109 Y41.7965 Z-1.0000 S1000
    G1 F1000 X34.0646 Y41.5776 Z-1.0000 S1000
    G1 F1000 X34.1105 Y41.3570 Z-1.0000 S1000
    G1 F1000 X34.1485 Y41.1348 Z-1.0000 S1000
    G1 F1000 X34.1786 Y40.9115 Z-1.0000 S1000
    G1 F1000 X34.2008 Y40.6872 Z-1.0000 S1000
    G1 F1000 X34.2150 Y40.4622 Z-1.0000 S1000
    G1 F1000 X34.2212 Y40.2369 Z-1.0000 S1000
    G1 F1000 X34.2194 Y40.0116 Z-1.0000 S1000
    G1 F1000 X34.2096 Y39.7864 Z-1.0000 S1000
    G1 F1000 X34.1918 Y39.5617 Z-1.0000 S1000
    G1 F1000 X34.1661 Y39.3378 Z-1.0000 S1000
    G1 F1000 X34.1324 Y39.1150 Z-1.0000 S1000
    G1 F1000 X34.0909 Y38.8935 Z-1.0000 S1000
    G1 F1000 X34.0415 Y38.6736 Z-1.0000 S1000
    G1 F1000 X33.9843 Y38.4555 Z-1.0000 S1000
    G1 F1000 X33.9195 Y38.2397 Z-1.0000 S1000
    G1 F1000 X33.8470 Y38.0263 Z-1.0000 S1000
    G1 F1000 X33.7670 Y37.8156 Z-1.0000 S1000
    G1 F1000 X33.6795 Y37.6079 Z-1.0000 S1000
    G1 F1000 X33.5848 Y37.4034 Z-1.0000 S1000
    G1 F1000 X33.4828 Y37.2024 Z-1.0000 S1000
    G1 F1000 X33.3738 Y37.0051 Z-1.0000 S1000
    G1 F1000 X33.2579 Y36.8118 Z-1.0000 S1000
    G1 F1000 X33.1351 Y36.6228 Z-1.0000 S1000
    G1 F1000 X32.9545 Y36.3688 Z-1.0000 S1000
    G1 F1000 X31.4356 Y34.3403 Z-1.0000 S1000
    G1 F1000 X33.4642 Y35.8592 Z-1.0000 S1000
    G1 F1000 X33.6469 Y35.9911 Z-1.0000 S1000
    G1 F1000 X33.8343 Y36.1164 Z-1.0000 S1000
    G1 F1000 X34.0260 Y36.2350 Z-1.0000 S1000
    G1 F1000 X34.2217 Y36.3466 Z-1.0000 S1000
    G1 F1000 X34.4213 Y36.4513 Z-1.0000 S1000
    G1 F1000 X34.6245 Y36.5488 Z-1.0000 S1000
    G1 F1000 X34.8310 Y36.6391 Z-1.0000 S1000
    G1 F1000 X35.0406 Y36.7219 Z-1.0000 S1000
    G1 F1000 X35.2530 Y36.7973 Z-1.0000 S1000
    G1 F1000 X35.4680 Y36.8651 Z-1.0000 S1000
    G1 F1000 X35.6852 Y36.9252 Z-1.0000 S1000
    G1 F1000 X35.9044 Y36.9776 Z-1.0000 S1000
    G1 F1000 X36.1253 Y37.0222 Z-1.0000 S1000
    G1 F1000 X36.3477 Y37.0588 Z-1.0000 S1000
    G1 F1000 X36.5712 Y37.0876 Z-1.0000 S1000
    G1 F1000 X36.7956 Y37.1084 Z-1.0000 S1000
    G1 F1000 X37.0207 Y37.1213 Z-1.0000 S1000
    G1 F1000 X37.2460 Y37.1262 Z-1.0000 S1000
    G1 F1000 X37.4713 Y37.1230 Z-1.0000 S1000
    G1 F1000 X37.6964 Y37.1119 Z-1.0000 S1000
    G1 F1000 X37.9210 Y37.0928 Z-1.0000 S1000
    G1 F1000 X38.1448 Y37.0657 Z-1.0000 S1000
    G1 F1000 X38.3674 Y37.0307 Z-1.0000 S1000
    G1 F1000 X38.5887 Y36.9878 Z-1.0000 S1000
    G1 F1000 X38.6438 Y36.9751 Z-1.0000 S1000
    G1 F1000 X41.9909 Y44.1530 Z-1.0000 S1000
    G1 F1000 X41.9252 Y44.2082 Z-1.0000 S1000
    G1 F1000 X41.7579 Y44.3591 Z-1.0000 S1000
    G1 F1000 X41.5960 Y44.5159 Z-1.0000 S1000
    G1 F1000 X41.4397 Y44.6783 Z-1.0000 S1000
    G1 F1000 X41.2894 Y44.8462 Z-1.0000 S1000
    G1 F1000 X41.1585 Y45.0026 Z-1.0000 S1000
    G1 F1000 X39.7062 Y46.7963 Z-1.0000 S1000
    G1 F1000 X39.5675 Y46.9739 Z-1.0000 S1000
    G1 F1000 X39.4352 Y47.1564 Z-1.0000 S1000
    G1 F1000 X39.3095 Y47.3434 Z-1.0000 S1000
    G1 F1000 X39.1905 Y47.5348 Z-1.0000 S1000
    G1 F1000 X39.0783 Y47.7303 Z-1.0000 S1000
    G1 F1000 X38.9834 Y47.9094 Z-1.0000 S1000
    G1 F1000 X37.9359 Y49.9654 Z-1.0000 S1000
    G1 F1000 X37.8372 Y50.1680 Z-1.0000 S1000
    G1 F1000 X37.7457 Y50.3740 Z-1.0000 S1000
    G1 F1000 X37.6616 Y50.5831 Z-1.0000 S1000
    G1 F1000 X37.5849 Y50.7951 Z-1.0000 S1000
    G1 F1000 X37.5159 Y51.0096 Z-1.0000 S1000
    G1 F1000 X37.4602 Y51.2049 Z-1.0000 S1000
    G1 F1000 X36.8628 Y53.4349 Z-1.0000 S1000
    G1 F1000 X36.8083 Y53.6536 Z-1.0000 S1000
    G1 F1000 X36.7617 Y53.8741 Z-1.0000 S1000
    G1 F1000 X36.7229 Y54.0961 Z-1.0000 S1000
    G1 F1000 X36.6920 Y54.3194 Z-1.0000 S1000
    G1 F1000 X36.6690 Y54.5436 Z-1.0000 S1000
    G1 F1000 X36.6552 Y54.7452 Z-1.0000 S1000
    G1 F1000 X36.5342 Y57.0498 Z-1.0000 S1000
    G1 F1000 X36.5264 Y57.2750 Z-1.0000 S1000
    G1 F1000 X36.5266 Y57.5004 Z-1.0000 S1000
    G1 F1000 X36.5348 Y57.7256 Z-1.0000 S1000
    G1 F1000 X36.5509 Y57.9504 Z-1.0000 S1000
    G1 F1000 X36.5751 Y58.1745 Z-1.0000 S1000
    G1 F1000 X36.6037 Y58.3765 Z-1.0000 S1000
    G1 F1000 X36.9649 Y60.6560 Z-1.0000 S1000
    G1 F1000 X37.0042 Y60.8779 Z-1.0000 S1000
    G1 F1000 X37.0512 Y61.0983 Z-1.0000 S1000
    G1 F1000 X37.1061 Y61.3169 Z-1.0000 S1000
    G1 F1000 X37.1687 Y61.5335 Z-1.0000 S1000
    G1 F1000 X37.2389 Y61.7476 Z-1.0000 S1000
    G1 F1000 X37.3086 Y61.9381 Z-1.0000 S1000
    G1 F1000 X38.1357 Y64.0925 Z-1.0000 S1000
    G1 F1000 X38.2202 Y64.3014 Z-1.0000 S1000
    G1 F1000 X38.3120 Y64.5072 Z-1.0000 S1000
    G1 F1000 X38.4111 Y64.7097 Z-1.0000 S1000
    G1 F1000 X38.5174 Y64.9084 Z-1.0000 S1000
    G1 F1000 X38.6306 Y65.1033 Z-1.0000 S1000
    G1 F1000 X38.7386 Y65.2756 Z-1.0000 S1000
    G1 F1000 X39.9958 Y67.2111 Z-1.0000 S1000
    G1 F1000 X40.1219 Y67.3979 Z-1.0000 S1000
    G1 F1000 X40.2545 Y67.5801 Z-1.0000 S1000
    G1 F1000 X40.3936 Y67.7575 Z-1.0000 S1000
    G1 F1000 X40.5388 Y67.9298 Z-1.0000 S1000
    G1 F1000 X40.6901 Y68.0969 Z-1.0000 S1000
    G1 F1000 X40.8309 Y68.2422 Z-1.0000 S1000
    G1 F1000 X42.4625 Y69.8738 Z-1.0000 S1000
    G1 F1000 X42.6246 Y70.0303 Z-1.0000 S1000
    G1 F1000 X42.7923 Y70.1810 Z-1.0000 S1000
    G1 F1000 X42.9651 Y70.3256 Z-1.0000 S1000
    G1 F1000 X43.1430 Y70.4640 Z-1.0000 S1000
    G1 F1000 X43.3257 Y70.5960 Z-1.0000 S1000
    G1 F1000 X43.4936 Y70.7089 Z-1.0000 S1000
    G1 F1000 X45.4291 Y71.9661 Z-1.0000 S1000
    G1 F1000 X45.6203 Y72.0855 Z-1.0000 S1000
    G1 F1000 X45.8155 Y72.1980 Z-1.0000 S1000
    G1 F1000 X46.0147 Y72.3036 Z-1.0000 S1000
    G1 F1000 X46.2175 Y72.4020 Z-1.0000 S1000
    G1 F1000 X46.4236 Y72.4931 Z-1.0000 S1000
    G1 F1000 X46.6122 Y72.5690 Z-1.0000 S1000
    G1 F1000 X48.7666 Y73.3961 Z-1.0000 S1000
    G1 F1000 X48.9784 Y73.4732 Z-1.0000 S1000
    G1 F1000 X49.1928 Y73.5426 Z-1.0000 S1000
    G1 F1000 X49.4096 Y73.6045 Z-1.0000 S1000
    G1 F1000 X49.6284 Y73.6585 Z-1.0000 S1000
    G1 F1000 X49.8489 Y73.7048 Z-1.0000 S1000
    G1 F1000 X50.0487 Y73.7398 Z-1.0000 S1000
    G1 F1000 X52.3282 Y74.1010 Z-1.0000 S1000
    G1 F1000 X52.5514 Y74.1323 Z-1.0000 S1000
    G1 F1000 X52.7756 Y74.1556 Z-1.0000 S1000
    G1 F1000 X53.0004 Y74.1711 Z-1.0000 S1000
    G1 F1000 X53.2257 Y74.1785 Z-1.0000 S1000
    G1 F1000 X53.4511 Y74.1779 Z-1.0000 S1000
    G1 F1000 X53.6549 Y74.1705 Z-1.0000 S1000
    G1 F1000 X55.9595 Y74.0495 Z-1.0000 S1000
    G1 F1000 X56.1844 Y74.0337 Z-1.0000 S1000
    G1 F1000 X56.4085 Y74.0099 Z-1.0000 S1000
    G1 F1000 X56.6316 Y73.9782 Z-1.0000 S1000
    G1 F1000 X56.8535 Y73.9385 Z-1.0000 S1000
    G1 F1000 X57.0738 Y73.8911 Z-1.0000 S1000
    G1 F1000 X57.2698 Y73.8419 Z-1.0000 S1000
    G1 F1000 X59.4998 Y73.2445 Z-1.0000 S1000
    G1 F1000 X59.7164 Y73.1823 Z-1.0000 S1000
    G1 F1000 X59.9307 Y73.1125 Z-1.0000 S1000
    G1 F1000 X60.1424 Y73.0351 Z-1.0000 S1000
    G1 F1000 X60.3512 Y72.9503 Z-1.0000 S1000
    G1 F1000 X60.5568 Y72.8581 Z-1.0000 S1000
    G1 F1000 X60.7393 Y72.7688 Z-1.0000 S1000
    G1 F1000 X62.7953 Y71.7213 Z-1.0000 S1000
    G1 F1000 X62.9942 Y71.6154 Z-1.0000 S1000
    G1 F1000 X63.1893 Y71.5026 Z-1.0000 S1000
    G1 F1000 X63.3803 Y71.3829 Z-1.0000 S1000
    G1 F1000 X63.5669 Y71.2565 Z-1.0000 S1000
    G1 F1000 X63.7489 Y71.1235 Z-1.0000 S1000
    G1 F1000 X63.9084 Y70.9985 Z-1.0000 S1000
    G1 F1000 X65.7021 Y69.5462 Z-1.0000 S1000
    G1 F1000 X65.8748 Y69.4012 Z-1.0000 S1000
    G1 F1000 X66.0421 Y69.2503 Z-1.0000 S1000
    G1 F1000 X66.2040 Y69.0935 Z-1.0000 S1000
    G1 F1000 X66.3603 Y68.9311 Z-1.0000 S1000
    G1 F1000 X66.5106 Y68.7632 Z-1.0000 S1000
    G1 F1000 X66.6415 Y68.6068 Z-1.0000 S1000
    G1 F1000 X68.0938 Y66.8131 Z-1.0000 S1000
    G1 F1000 X68.2325 Y66.6355 Z-1.0000 S1000
    G1 F1000 X68.3648 Y66.4530 Z-1.0000 S1000
    G1 F1000 X68.4905 Y66.2660 Z-1.0000 S1000
    G1 F1000 X68.6095 Y66.0746 Z-1.0000 S1000
    G1 F1000 X68.7217 Y65.8791 Z-1.0000 S1000
    G1 F1000 X68.8166 Y65.7000 Z-1.0000 S1000
    G1 F1000 X69.8641 Y63.6440 Z-1.0000 S1000
    G1 F1000 X69.9628 Y63.4414 Z-1.0000 S1000
    G1 F1000 X70.0543 Y63.2354 Z-1.0000 S1000
    G1 F1000 X70.1384 Y63.0263 Z-1.0000 S1000
    G1 F1000 X70.2151 Y62.8143 Z-1.0000 S1000
    G1 F1000 X70.2841 Y62.5998 Z-1.0000 S1000
    G1 F1000 X70.3398 Y62.4045 Z-1.0000 S1000
    G1 F1000 X70.9372 Y60.1745 Z-1.0000 S1000
    G1 F1000 X70.9917 Y59.9558 Z-1.0000 S1000
    G1 F1000 X71.0383 Y59.7353 Z-1.0000 S1000
    G1 F1000 X71.0771 Y59.5133 Z-1.0000 S1000
    G1 F1000 X71.1080 Y59.2900 Z-1.0000 S1000
    G1 F1000 X71.1310 Y59.0658 Z-1.0000 S1000
    G1 F1000 X71.1448 Y58.8642 Z-1.0000 S1000
    G1 F1000 X71.2658 Y56.5596 Z-1.0000 S1000
    G1 F1000 X71.2736 Y56.3344 Z-1.0000 S1000
    G1 F1000 X71.2734 Y56.1090 Z-1.0000 S1000
    G1 F1000 X71.2652 Y55.8838 Z-1.0000 S1000
    G1 F1000 X71.2491 Y55.6590 Z-1.0000 S1000
    G1 F1000 X71.2249 Y55.4349 Z-1.0000 S1000
    G1 F1000 X71.1963 Y55.2329 Z-1.0000 S1000
    G1 F1000 X70.8351 Y52.9534 Z-1.0000 S1000
    G1 F1000 X70.7958 Y52.7315 Z-1.0000 S1000
    G1 F1000 X70.7488 Y52.5111 Z-1.0000 S1000
    G1 F1000 X70.6939 Y52.2925 Z-1.0000 S1000
    G1 F1000 X70.6313 Y52.0759 Z-1.0000 S1000
    G1 F1000 X70.5611 Y51.8618 Z-1.0000 S1000
    G1 F1000 X70.4914 Y51.6713 Z-1.0000 S1000
    G1 F1000 X69.6643 Y49.5169 Z-1.0000 S1000
    G1 F1000 X69.5798 Y49.3080 Z-1.0000 S1000
    G1 F1000 X69.4880 Y49.1022 Z-1.0000 S1000
    G1 F1000 X69.3889 Y48.8997 Z-1.0000 S1000
    G1 F1000 X69.2826 Y48.7010 Z-1.0000 S1000
    G1 F1000 X69.1694 Y48.5061 Z-1.0000 S1000
    G1 F1000 X69.0614 Y48.3338 Z-1.0000 S1000
    G1 F1000 X67.8042 Y46.3983 Z-1.0000 S1000
    G1 F1000 X67.6781 Y46.2115 Z-1.0000 S1000
    G1 F1000 X67.5455 Y46.0293 Z-1.0000 S1000
    G1 F1000 X67.4064 Y45.8519 Z-1.0000 S1000
    G1 F1000 X67.2612 Y45.6796 Z-1.0000 S1000
    G1 F1000 X67.1099 Y45.5125 Z-1.0000 S1000
    G1 F1000 X66.9691 Y45.3672 Z-1.0000 S1000
    G1 F1000 X66.4718 Y44.8699 Z-1.0000 S1000
    G1 F700 Z-2.0000
    G1 F1000 X70.0447 Y37.2077 Z-2.0000 S1000
    G1 F1000 X70.1299 Y37.2129 Z-2.0000 S1000
    G1 F1000 X70.3552 Y37.2187 Z-2.0000 S1000
    G1 F1000 X70.5806 Y37.2165 Z-2.0000 S1000
    G1 F1000 X70.8057 Y37.2063 Z-2.0000 S1000
    G1 F1000 X71.0304 Y37.1881 Z-2.0000 S1000
    G1 F1000 X71.2542 Y37.1620 Z-2.0000 S1000
    G1 F1000 X71.4770 Y37.1279 Z-2.0000 S1000
    G1 F1000 X71.6984 Y37.0859 Z-2.0000 S1000
    G1 F1000 X71.9182 Y37.0362 Z-2.0000 S1000
    G1 F1000 X72.1362 Y36.9786 Z-2.0000 S1000
    G1 F1000 X72.3519 Y36.9133 Z-2.0000 S1000
    G1 F1000 X72.5652 Y36.8405 Z-2.0000 S1000
    G1 F1000 X72.7757 Y36.7601 Z-2.0000 S1000
    G1 F1000 X72.9833 Y36.6723 Z-2.0000 S1000
    G1 F1000 X73.1876 Y36.5771 Z-2.0000 S1000
    G1 F1000 X73.3884 Y36.4748 Z-2.0000 S1000
    G1 F1000 X73.5855 Y36.3655 Z-2.0000 S1000
    G1 F1000 X73.7785 Y36.2492 Z-2.0000 S1000
    G1 F1000 X73.9673 Y36.1261 Z-2.0000 S1000
    G1 F1000 X74.2117 Y35.9520 Z-2.0000 S1000
    G1 F1000 X76.3648 Y34.3399 Z-2.0000 S1000
    G1 F1000 X74.7527 Y36.4930 Z-2.0000 S1000
    G1 F1000 X74.6209 Y36.6758 Z-2.0000 S1000
    G1 F1000 X74.4956 Y36.8631 Z-2.0000 S1000
    G1 F1000 X74.3770 Y37.0548 Z-2.0000 S1000
    G1 F1000 X74.2653 Y37.2506 Z-2.0000 S1000
    G1 F1000 X74.1607 Y37.4502 Z-2.0000 S1000
    G1 F1000 X74.0631 Y37.6534 Z-2.0000 S1000
    G1 F1000 X73.9729 Y37.8599 Z-2.0000 S1000
    G1 F1000 X73.8900 Y38.0695 Z-2.0000 S1000
    G1 F1000 X73.8147 Y38.2819 Z-2.0000 S1000
    G1 F1000 X73.7469 Y38.4968 Z-2.0000 S1000
    G1 F1000 X73.6868 Y38.7140 Z-2.0000 S1000
    G1 F1000 X73.6344 Y38.9332 Z-2.0000 S1000
    G1 F1000 X73.5898 Y39.1542 Z-2.0000 S1000
    G1 F1000 X73.5531 Y39.3766 Z-2.0000 S1000
    G1 F1000 X73.5244 Y39.6001 Z-2.0000 S1000
    G1 F1000 X73.5035 Y39.8245 Z-2.0000 S1000
    G1 F1000 X73.4907 Y40.0495 Z-2.0000 S1000
    G1 F1000 X73.4858 Y40.2748 Z-2.0000 S1000
    G1 F1000 X73.4890 Y40.5002 Z-2.0000 S1000
    G1 F1000 X73.5001 Y40.7253 Z-2.0000 S1000
    G1 F1000 X73.5193 Y40.9499 Z-2.0000 S1000
    G1 F1000 X73.5463 Y41.1736 Z-2.0000 S1000
    G1 F1000 X73.5813 Y41.3963 Z-2.0000 S1000
    G1 F1000 X73.6242 Y41.6175 Z-2.0000 S1000
    G1 F1000 X73.6749 Y41.8371 Z-2.0000 S1000
    G1 F1000 X73.7334 Y42.0548 Z-2.0000 S1000
    G1 F1000 X73.7996 Y42.2702 Z-2.0000 S1000
    G1 F1000 X73.8733 Y42.4832 Z-2.0000 S1000
    G1 F1000 X73.9546 Y42.6934 Z-2.0000 S1000
    G1 F1000 X74.0433 Y42.9006 Z-2.0000 S1000
    G1 F1000 X74.1392 Y43.1046 Z-2.0000 S1000
    G1 F1000 X74.2424 Y43.3049 Z-2.0000 S1000
    G1 F1000 X74.3526 Y43.5015 Z-2.0000 S1000
    G1 F1000 X74.5100 Y43.7570 Z-2.0000 S1000
    G1 F1000 X75.7524 Y45.6705 Z-2.0000 S1000
    G1 F1000 X77.5901 Y50.4571 Z-2.0000 S1000
    G1 F1000 X77.6981 Y51.1389 Z-2.0000 S1000
    G1 F1000 X77.7373 Y51.3608 Z-2.0000 S1000
    G1 F1000 X77.7844 Y51.5812 Z-2.0000 S1000
    G1 F1000 X77.8393 Y51.7998 Z-2.0000 S1000
    G1 F1000 X77.9018 Y52.0163 Z-2.0000 S1000
    G1 F1000 X77.9721 Y52.2305 Z-2.0000 S1000
    G1 F1000 X78.0498 Y52.4420 Z-2.0000 S1000
    G1 F1000 X78.1351 Y52.6507 Z-2.0000 S1000
    G1 F1000 X78.2277 Y52.8562 Z-2.0000 S1000
    G1 F1000 X78.3275 Y53.0582 Z-2.0000 S1000
    G1 F1000 X78.4344 Y53.2566 Z-2.0000 S1000
    G1 F1000 X78.5483 Y53.4511 Z-2.0000 S1000
    G1 F1000 X78.6691 Y53.6414 Z-2.0000 S1000
    G1 F1000 X78.7965 Y53.8273 Z-2.0000 S1000
    G1 F1000 X78.9304 Y54.0086 Z-2.0000 S1000
    G1 F1000 X79.0707 Y54.1850 Z-2.0000 S1000
    G1 F1000 X79.2171 Y54.3563 Z-2.0000 S1000
    G1 F1000 X79.3696 Y54.5223 Z-2.0000 S1000
    G1 F1000 X79.5278 Y54.6828 Z-2.0000 S1000
    G1 F1000 X79.6916 Y54.8376 Z-2.0000 S1000
    G1 F1000 X79.8608 Y54.9865 Z-2.0000 S1000
    G1 F1000 X80.0352 Y55.1293 Z-2.0000 S1000
    G1 F1000 X80.2146 Y55.2657 Z-2.0000 S1000
    G1 F1000 X80.3987 Y55.3958 Z-2.0000 S1000
    G1 F1000 X80.5872 Y55.5192 Z-2.0000 S1000
    G1 F1000 X80.7801 Y55.6359 Z-2.0000 S1000
    G1 F1000 X80.9769 Y55.7456 Z-2.0000 S1000
    G1 F1000 X81.1776 Y55.8483 Z-2.0000 S1000
    G1 F1000 X81.3817 Y55.9438 Z-2.0000 S1000
    G1 F1000 X81.5891 Y56.0320 Z-2.0000 S1000
    G1 F1000 X81.7995 Y56.1128 Z-2.0000 S1000
    G1 F1000 X82.0127 Y56.1860 Z-2.0000 S1000
    G1 F1000 X82.2283 Y56.2517 Z-2.0000 S1000
    G1 F1000 X82.4461 Y56.3096 Z-2.0000 S1000
    G1 F1000 X82.6658 Y56.3598 Z-2.0000 S1000
    G1 F1000 X82.8871 Y56.4022 Z-2.0000 S1000
    G1 F1000 X83.0668 Y56.4307 Z-2.0000 S1000
    G1 F1000 X85.6693 Y56.8046 Z-2.0000 S1000
    G1 F1000 X83.0374 Y57.1827 Z-2.0000 S1000
    G1 F1000 X82.8149 Y57.2187 Z-2.0000 S1000
    G1 F1000 X82.5938 Y57.2626 Z-2.0000 S1000
    G1 F1000 X82.3745 Y57.3143 Z-2.0000 S1000
    G1 F1000 X82.1571 Y57.3737 Z-2.0000 S1000
    G1 F1000 X81.9419 Y57.4409 Z-2.0000 S1000
    G1 F1000 X81.7293 Y57.5156 Z-2.0000 S1000
    G1 F1000 X81.5194 Y57.5978 Z-2.0000 S1000
    G1 F1000 X81.3126 Y57.6874 Z-2.0000 S1000
    G1 F1000 X81.1091 Y57.7843 Z-2.0000 S1000
    G1 F1000 X80.9092 Y57.8883 Z-2.0000 S1000
    G1 F1000 X80.7131 Y57.9994 Z-2.0000 S1000
    G1 F1000 X80.5211 Y58.1174 Z-2.0000 S1000
    G1 F1000 X80.3333 Y58.2421 Z-2.0000 S1000
    G1 F1000 X80.1501 Y58.3734 Z-2.0000 S1000
    G1 F1000 X79.9717 Y58.5111 Z-2.0000 S1000
    G1 F1000 X79.7983 Y58.6550 Z-2.0000 S1000
    G1 F1000 X79.6301 Y58.8051 Z-2.0000 S1000
    G1 F1000 X79.4673 Y58.9610 Z-2.0000 S1000
    G1 F1000 X79.3102 Y59.1225 Z-2.0000 S1000
    G1 F1000 X79.1589 Y59.2896 Z-2.0000 S1000
    G1 F1000 X79.0136 Y59.4619 Z-2.0000 S1000
    G1 F1000 X78.8746 Y59.6392 Z-2.0000 S1000
    G1 F1000 X78.7419 Y59.8214 Z-2.0000 S1000
    G1 F1000 X78.6157 Y60.0082 Z-2.0000 S1000
    G1 F1000 X78.4963 Y60.1993 Z-2.0000 S1000
    G1 F1000 X78.3837 Y60.3946 Z-2.0000 S1000
    G1 F1000 X78.2782 Y60.5937 Z-2.0000 S1000
    G1 F1000 X78.1797 Y60.7965 Z-2.0000 S1000
    G1 F1000 X78.0885 Y61.0026 Z-2.0000 S1000
    G1 F1000 X78.0047 Y61.2118 Z-2.0000 S1000
    G1 F1000 X77.9284 Y61.4238 Z-2.0000 S1000
    G1 F1000 X77.8596 Y61.6385 Z-2.0000 S1000
    G1 F1000 X77.8067 Y61.8247 Z-2.0000 S1000
    G1 F1000 X76.7968 Y65.5936 Z-2.0000 S1000
    G1 F1000 X74.2706 Y70.5518 Z-2.0000 S1000
    G1 F1000 X74.1718 Y70.7544 Z-2.0000 S1000
    G1 F1000 X74.0803 Y70.9604 Z-2.0000 S1000
    G1 F1000 X73.9962 Y71.1695 Z-2.0000 S1000
    G1 F1000 X73.9196 Y71.3815 Z-2.0000 S1000
    G1 F1000 X73.8505 Y71.5960 Z-2.0000 S1000
    G1 F1000 X73.7891 Y71.8128 Z-2.0000 S1000
    G1 F1000 X73.7354 Y72.0317 Z-2.0000 S1000
    G1 F1000 X73.6895 Y72.2524 Z-2.0000 S1000
    G1 F1000 X73.6515 Y72.4745 Z-2.0000 S1000
    G1 F1000 X73.6214 Y72.6979 Z-2.0000 S1000
    G1 F1000 X73.5992 Y72.9222 Z-2.0000 S1000
    G1 F1000 X73.5850 Y73.1471 Z-2.0000 S1000
    G1 F1000 X73.5788 Y73.3724 Z-2.0000 S1000
    G1 F1000 X73.5806 Y73.5978 Z-2.0000 S1000
    G1 F1000 X73.5904 Y73.8229 Z-2.0000 S1000
    G1 F1000 X73.6082 Y74.0476 Z-2.0000 S1000
    G1 F1000 X73.6339 Y74.2715 Z-2.0000 S1000
    G1 F1000 X73.6676 Y74.4944 Z-2.0000 S1000
    G1 F1000 X73.7091 Y74.7159 Z-2.0000 S1000
    G1 F1000 X73.7585 Y74.9358 Z-2.0000 S1000
    G1 F1000 X73.8157 Y75.1538 Z-2.0000 S1000
    G1 F1000 X73.8805 Y75.3697 Z-2.0000 S1000
    G1 F1000 X73.9530 Y75.5831 Z-2.0000 S1000
    G1 F1000 X74.0330 Y75.7938 Z-2.0000 S1000
    G1 F1000 X74.1204 Y76.0015 Z-2.0000 S1000
    G1 F1000 X74.2152 Y76.2060 Z-2.0000 S1000
    G1 F1000 X74.3171 Y76.4070 Z-2.0000 S1000
    G1 F1000 X74.4262 Y76.6043 Z-2.0000 S1000
    G1 F1000 X74.5421 Y76.7975 Z-2.0000 S1000
    G1 F1000 X74.6648 Y76.9865 Z-2.0000 S1000
    G1 F1000 X74.8455 Y77.2406 Z-2.0000 S1000
    G1 F1000 X76.3643 Y79.2690 Z-2.0000 S1000
    G1 F1000 X74.3359 Y77.7502 Z-2.0000 S1000
    G1 F1000 X74.1531 Y77.6183 Z-2.0000 S1000
    G1 F1000 X73.9658 Y77.4930 Z-2.0000 S1000
    G1 F1000 X73.7741 Y77.3745 Z-2.0000 S1000
    G1 F1000 X73.5783 Y77.2628 Z-2.0000 S1000
    G1 F1000 X73.3787 Y77.1581 Z-2.0000 S1000
    G1 F1000 X73.1755 Y77.0606 Z-2.0000 S1000
    G1 F1000 X72.9690 Y76.9703 Z-2.0000 S1000
    G1 F1000 X72.7594 Y76.8875 Z-2.0000 S1000
    G1 F1000 X72.5470 Y76.8121 Z-2.0000 S1000
    G1 F1000 X72.3321 Y76.7443 Z-2.0000 S1000
    G1 F1000 X72.1149 Y76.6842 Z-2.0000 S1000
    G1 F1000 X71.8957 Y76.6318 Z-2.0000 S1000
    G1 F1000 X71.6747 Y76.5873 Z-2.0000 S1000
    G1 F1000 X71.4524 Y76.5506 Z-2.0000 S1000
    G1 F1000 X71.2288 Y76.5218 Z-2.0000 S1000
    G1 F1000 X71.0044 Y76.5010 Z-2.0000 S1000
    G1 F1000 X70.7794 Y76.4881 Z-2.0000 S1000
    G1 F1000 X70.5541 Y76.4832 Z-2.0000 S1000
    G1 F1000 X70.3287 Y76.4864 Z-2.0000 S1000
    G1 F1000 X70.1036 Y76.4975 Z-2.0000 S1000
    G1 F1000 X69.8790 Y76.5166 Z-2.0000 S1000
    G1 F1000 X69.6553 Y76.5437 Z-2.0000 S1000
    G1 F1000 X69.4326 Y76.5787 Z-2.0000 S1000
    G1 F1000 X69.2114 Y76.6216 Z-2.0000 S1000
    G1 F1000 X68.9918 Y76.6723 Z-2.0000 S1000
    G1 F1000 X68.7741 Y76.7308 Z-2.0000 S1000
    G1 F1000 X68.5587 Y76.7969 Z-2.0000 S1000
    G1 F1000 X68.3457 Y76.8707 Z-2.0000 S1000
    G1 F1000 X68.1355 Y76.9519 Z-2.0000 S1000
    G1 F1000 X67.9283 Y77.0406 Z-2.0000 S1000
    G1 F1000 X67.6471 Y77.1753 Z-2.0000 S1000
    G1 F1000 X62.6889 Y79.7015 Z-2.0000 S1000
    G1 F1000 X58.9200 Y80.7114 Z-2.0000 S1000
    G1 F1000 X58.7034 Y80.7735 Z-2.0000 S1000
    G1 F1000 X58.4891 Y80.8434 Z-2.0000 S1000
    G1 F1000 X58.2774 Y80.9208 Z-2.0000 S1000
    G1 F1000 X58.0686 Y81.0056 Z-2.0000 S1000
    G1 F1000 X57.8630 Y81.0979 Z-2.0000 S1000
    G1 F1000 X57.6607 Y81.1973 Z-2.0000 S1000
    G1 F1000 X57.4621 Y81.3039 Z-2.0000 S1000
    G1 F1000 X57.2675 Y81.4174 Z-2.0000 S1000
    G1 F1000 X57.0769 Y81.5378 Z-2.0000 S1000
    G1 F1000 X56.8908 Y81.6649 Z-2.0000 S1000
    G1 F1000 X56.7093 Y81.7985 Z-2.0000 S1000
    G1 F1000 X56.5326 Y81.9384 Z-2.0000 S1000
    G1 F1000 X56.3610 Y82.0846 Z-2.0000 S1000
    G1 F1000 X56.1947 Y82.2367 Z-2.0000 S1000
    G1 F1000 X56.0340 Y82.3946 Z-2.0000 S1000
    G1 F1000 X55.8789 Y82.5582 Z-2.0000 S1000
    G1 F1000 X55.7297 Y82.7271 Z-2.0000 S1000
    G1 F1000 X55.5866 Y82.9013 Z-2.0000 S1000
    G1 F1000 X55.4498 Y83.0804 Z-2.0000 S1000
    G1 F1000 X55.3194 Y83.2642 Z-2.0000 S1000
    G1 F1000 X55.1956 Y83.4526 Z-2.0000 S1000
    G1 F1000 X55.0786 Y83.6452 Z-2.0000 S1000
    G1 F1000 X54.9685 Y83.8418 Z-2.0000 S1000
    G1 F1000 X54.8655 Y84.0423 Z-2.0000 S1000
    G1 F1000 X54.7696 Y84.2463 Z-2.0000 S1000
    G1 F1000 X54.6810 Y84.4535 Z-2.0000 S1000
    G1 F1000 X54.5999 Y84.6638 Z-2.0000 S1000
    G1 F1000 X54.5262 Y84.8768 Z-2.0000 S1000
    G1 F1000 X54.4602 Y85.0923 Z-2.0000 S1000
    G1 F1000 X54.4018 Y85.3099 Z-2.0000 S1000
    G1 F1000 X54.3512 Y85.5296 Z-2.0000 S1000
    G1 F1000 X54.3085 Y85.7509 Z-2.0000 S1000
    G1 F1000 X54.2780 Y85.9421 Z-2.0000 S1000
    G1 F1000 X53.8999 Y88.5740 Z-2.0000 S1000
    G1 F1000 X53.5260 Y85.9715 Z-2.0000 S1000
    G1 F1000 X53.4899 Y85.7490 Z-2.0000 S1000
    G1 F1000 X53.4461 Y85.5280 Z-2.0000 S1000
    G1 F1000 X53.3944 Y85.3086 Z-2.0000 S1000
    G1 F1000 X53.3349 Y85.0912 Z-2.0000 S1000
    G1 F1000 X53.2678 Y84.8761 Z-2.0000 S1000
    G1 F1000 X53.1931 Y84.6634 Z-2.0000 S1000
    G1 F1000 X53.1109 Y84.4536 Z-2.0000 S1000
    G1 F1000 X53.0212 Y84.2468 Z-2.0000 S1000
    G1 F1000 X52.9244 Y84.0433 Z-2.0000 S1000
    G1 F1000 X52.8203 Y83.8434 Z-2.0000 S1000
    G1 F1000 X52.7092 Y83.6473 Z-2.0000 S1000
    G1 F1000 X52.5912 Y83.4552 Z-2.0000 S1000
    G1 F1000 X52.4665 Y83.2675 Z-2.0000 S1000
    G1 F1000 X52.3352 Y83.0843 Z-2.0000 S1000
    G1 F1000 X52.1975 Y82.9059 Z-2.0000 S1000
    G1 F1000 X52.0535 Y82.7325 Z-2.0000 S1000
    G1 F1000 X51.9035 Y82.5643 Z-2.0000 S1000
    G1 F1000 X51.7476 Y82.4015 Z-2.0000 S1000
    G1 F1000 X51.5861 Y82.2444 Z-2.0000 S1000
    G1 F1000 X51.4190 Y82.0931 Z-2.0000 S1000
    G1 F1000 X51.2467 Y81.9478 Z-2.0000 S1000
    G1 F1000 X51.0693 Y81.8088 Z-2.0000 S1000
    G1 F1000 X50.8871 Y81.6761 Z-2.0000 S1000
    G1 F1000 X50.7004 Y81.5500 Z-2.0000 S1000
    G1 F1000 X50.5092 Y81.4305 Z-2.0000 S1000
    G1 F1000 X50.3140 Y81.3180 Z-2.0000 S1000
    G1 F1000 X50.1148 Y81.2124 Z-2.0000 S1000
    G1 F1000 X49.9121 Y81.1140 Z-2.0000 S1000
    G1 F1000 X49.7060 Y81.0228 Z-2.0000 S1000
    G1 F1000 X49.4968 Y80.9390 Z-2.0000 S1000
    G1 F1000 X49.2847 Y80.8626 Z-2.0000 S1000
    G1 F1000 X49.0701 Y80.7939 Z-2.0000 S1000
    G1 F1000 X48.8531 Y80.7328 Z-2.0000 S1000
    G1 F1000 X48.6342 Y80.6794 Z-2.0000 S1000
    G1 F1000 X48.4134 Y80.6339 Z-2.0000 S1000
    G1 F1000 X48.2342 Y80.6028 Z-2.0000 S1000
    G1 F1000 X47.5524 Y80.4948 Z-2.0000 S1000
    G1 F1000 X42.7658 Y78.6571 Z-2.0000 S1000
    G1 F1000 X40.8523 Y77.4147 Z-2.0000 S1000
    G1 F1000 X40.6611 Y77.2953 Z-2.0000 S1000
    G1 F1000 X40.4658 Y77.1828 Z-2.0000 S1000
    G1 F1000 X40.2666 Y77.0773 Z-2.0000 S1000
    G1 F1000 X40.0639 Y76.9790 Z-2.0000 S1000
    G1 F1000 X39.8577 Y76.8878 Z-2.0000 S1000
    G1 F1000 X39.6485 Y76.8041 Z-2.0000 S1000
    G1 F1000 X39.4364 Y76.7278 Z-2.0000 S1000
    G1 F1000 X39.2217 Y76.6592 Z-2.0000 S1000
    G1 F1000 X39.0048 Y76.5981 Z-2.0000 S1000
    G1 F1000 X38.7858 Y76.5449 Z-2.0000 S1000
    G1 F1000 X38.5650 Y76.4994 Z-2.0000 S1000
    G1 F1000 X38.3428 Y76.4618 Z-2.0000 S1000
    G1 F1000 X38.1194 Y76.4320 Z-2.0000 S1000
    G1 F1000 X37.8951 Y76.4103 Z-2.0000 S1000
    G1 F1000 X37.6701 Y76.3965 Z-2.0000 S1000
    G1 F1000 X37.4448 Y76.3907 Z-2.0000 S1000
    G1 F1000 X37.2194 Y76.3929 Z-2.0000 S1000
    G1 F1000 X36.9943 Y76.4031 Z-2.0000 S1000
    G1 F1000 X36.7696 Y76.4213 Z-2.0000 S1000
    G1 F1000 X36.5458 Y76.4474 Z-2.0000 S1000
    G1 F1000 X36.3230 Y76.4815 Z-2.0000 S1000
    G1 F1000 X36.1016 Y76.5235 Z-2.0000 S1000
    G1 F1000 X35.8818 Y76.5732 Z-2.0000 S1000
    G1 F1000 X35.6638 Y76.6308 Z-2.0000 S1000
    G1 F1000 X35.4481 Y76.6961 Z-2.0000 S1000
    G1 F1000 X35.2348 Y76.7689 Z-2.0000 S1000
    G1 F1000 X35.0243 Y76.8493 Z-2.0000 S1000
    G1 F1000 X34.8167 Y76.9371 Z-2.0000 S1000
    G1 F1000 X34.6124 Y77.0323 Z-2.0000 S1000
    G1 F1000 X34.4116 Y77.1346 Z-2.0000 S1000
    G1 F1000 X34.2145 Y77.2439 Z-2.0000 S1000
    G1 F1000 X34.0215 Y77.3602 Z-2.0000 S1000
    G1 F1000 X33.8327 Y77.4833 Z-2.0000 S1000
    G1 F1000 X33.5883 Y77.6574 Z-2.0000 S1000
    G1 F1000 X31.4353 Y79.2694 Z-2.0000 S1000
    G1 F1000 X33.0473 Y77.1165 Z-2.0000 S1000
    G1 F1000 X33.1791 Y76.9337 Z-2.0000 S1000
    G1 F1000 X33.3044 Y76.7464 Z-2.0000 S1000
    G1 F1000 X33.4230 Y76.5547 Z-2.0000 S1000
    G1 F1000 X33.5347 Y76.3590 Z-2.0000 S1000
    G1 F1000 X33.6393 Y76.1594 Z-2.0000 S1000
    G1 F1000 X33.7368 Y75.9562 Z-2.0000 S1000
    G1 F1000 X33.8271 Y75.7497 Z-2.0000 S1000
    G1 F1000 X33.9100 Y75.5401 Z-2.0000 S1000
    G1 F1000 X33.9853 Y75.3277 Z-2.0000 S1000
    G1 F1000 X34.0531 Y75.1127 Z-2.0000 S1000
    G1 F1000 X34.1132 Y74.8955 Z-2.0000 S1000
    G1 F1000 X34.1656 Y74.6763 Z-2.0000 S1000
    G1 F1000 X34.2102 Y74.4554 Z-2.0000 S1000
    G1 F1000 X34.2469 Y74.2330 Z-2.0000 S1000
    G1 F1000 X34.2756 Y74.0095 Z-2.0000 S1000
    G1 F1000 X34.2965 Y73.7850 Z-2.0000 S1000
    G1 F1000 X34.3093 Y73.5600 Z-2.0000 S1000
    G1 F1000 X34.3142 Y73.3347 Z-2.0000 S1000
    G1 F1000 X34.3110 Y73.1093 Z-2.0000 S1000
    G1 F1000 X34.2999 Y72.8842 Z-2.0000 S1000
    G1 F1000 X34.2807 Y72.6597 Z-2.0000 S1000
    G1 F1000 X34.2537 Y72.4359 Z-2.0000 S1000
    G1 F1000 X34.2187 Y72.2133 Z-2.0000 S1000
    G1 F1000 X34.1758 Y71.9920 Z-2.0000 S1000
    G1 F1000 X34.1251 Y71.7724 Z-2.0000 S1000
    G1 F1000 X34.0666 Y71.5547 Z-2.0000 S1000
    G1 F1000 X34.0005 Y71.3393 Z-2.0000 S1000
    G1 F1000 X33.9267 Y71.1263 Z-2.0000 S1000
    G1 F1000 X33.8454 Y70.9161 Z-2.0000 S1000
    G1 F1000 X33.7568 Y70.7089 Z-2.0000 S1000
    G1 F1000 X33.6608 Y70.5050 Z-2.0000 S1000
    G1 F1000 X33.5576 Y70.3046 Z-2.0000 S1000
    G1 F1000 X33.4474 Y70.1080 Z-2.0000 S1000
    G1 F1000 X33.2901 Y69.8526 Z-2.0000 S1000
    G1 F1000 X32.0475 Y67.9388 Z-2.0000 S1000
    G1 F1000 X30.2099 Y63.1523 Z-2.0000 S1000
    G1 F1000 X30.1019 Y62.4705 Z-2.0000 S1000
    G1 F1000 X30.0627 Y62.2486 Z-2.0000 S1000
    G1 F1000 X30.0156 Y62.0282 Z-2.0000 S1000
    G1 F1000 X29.9607 Y61.8096 Z-2.0000 S1000
    G1 F1000 X29.8982 Y61.5931 Z-2.0000 S1000
    G1 F1000 X29.8279 Y61.3789 Z-2.0000 S1000
    G1 F1000 X29.7502 Y61.1674 Z-2.0000 S1000
    G1 F1000 X29.6649 Y60.9587 Z-2.0000 S1000
    G1 F1000 X29.5723 Y60.7532 Z-2.0000 S1000
    G1 F1000 X29.4725 Y60.5512 Z-2.0000 S1000
    G1 F1000 X29.3656 Y60.3528 Z-2.0000 S1000
    G1 F1000 X29.2517 Y60.1583 Z-2.0000 S1000
    G1 F1000 X29.1309 Y59.9680 Z-2.0000 S1000
    G1 F1000 X29.0035 Y59.7821 Z-2.0000 S1000
    G1 F1000 X28.8696 Y59.6008 Z-2.0000 S1000
    G1 F1000 X28.7293 Y59.4244 Z-2.0000 S1000
    G1 F1000 X28.5829 Y59.2531 Z-2.0000 S1000
    G1 F1000 X28.4304 Y59.0871 Z-2.0000 S1000
    G1 F1000 X28.2722 Y58.9266 Z-2.0000 S1000
    G1 F1000 X28.1084 Y58.7718 Z-2.0000 S1000
    G1 F1000 X27.9392 Y58.6229 Z-2.0000 S1000
    G1 F1000 X27.7648 Y58.4801 Z-2.0000 S1000
    G1 F1000 X27.5854 Y58.3437 Z-2.0000 S1000
    G1 F1000 X27.4013 Y58.2136 Z-2.0000 S1000
    G1 F1000 X27.2128 Y58.0902 Z-2.0000 S1000
    G1 F1000 X27.0199 Y57.9735 Z-2.0000 S1000
    G1 F1000 X26.8231 Y57.8638 Z-2.0000 S1000
    G1 F1000 X26.6224 Y57.7611 Z-2.0000 S1000
    G1 F1000 X26.4183 Y57.6656 Z-2.0000 S1000
    G1 F1000 X26.2109 Y57.5774 Z-2.0000 S1000
    G1 F1000 X26.0005 Y57.4966 Z-2.0000 S1000
    G1 F1000 X25.7873 Y57.4234 Z-2.0000 S1000
    G1 F1000 X25.5717 Y57.3577 Z-2.0000 S1000
    G1 F1000 X25.3539 Y57.2998 Z-2.0000 S1000
    G1 F1000 X25.1342 Y57.2496 Z-2.0000 S1000
    G1 F1000 X24.9129 Y57.2072 Z-2.0000 S1000
    G1 F1000 X24.7332 Y57.1787 Z-2.0000 S1000
    G1 F1000 X22.1309 Y56.8048 Z-2.0000 S1000
    G1 F1000 X24.7626 Y56.4268 Z-2.0000 S1000
    G1 F1000 X24.9850 Y56.3908 Z-2.0000 S1000
    G1 F1000 X25.2061 Y56.3469 Z-2.0000 S1000
    G1 F1000 X25.4255 Y56.2952 Z-2.0000 S1000
    G1 F1000 X25.6429 Y56.2358 Z-2.0000 S1000
    G1 F1000 X25.8580 Y56.1687 Z-2.0000 S1000
    G1 F1000 X26.0707 Y56.0940 Z-2.0000 S1000
    G1 F1000 X26.2805 Y56.0117 Z-2.0000 S1000
    G1 F1000 X26.4873 Y55.9221 Z-2.0000 S1000
    G1 F1000 X26.6908 Y55.8253 Z-2.0000 S1000
    G1 F1000 X26.8907 Y55.7212 Z-2.0000 S1000
    G1 F1000 X27.0868 Y55.6101 Z-2.0000 S1000
    G1 F1000 X27.2789 Y55.4922 Z-2.0000 S1000
    G1 F1000 X27.4666 Y55.3675 Z-2.0000 S1000
    G1 F1000 X27.6498 Y55.2362 Z-2.0000 S1000
    G1 F1000 X27.8282 Y55.0984 Z-2.0000 S1000
    G1 F1000 X28.0016 Y54.9545 Z-2.0000 S1000
    G1 F1000 X28.1698 Y54.8045 Z-2.0000 S1000
    G1 F1000 X28.3326 Y54.6486 Z-2.0000 S1000
    G1 F1000 X28.4897 Y54.4870 Z-2.0000 S1000
    G1 F1000 X28.6410 Y54.3200 Z-2.0000 S1000
    G1 F1000 X28.7863 Y54.1477 Z-2.0000 S1000
    G1 F1000 X28.9254 Y53.9703 Z-2.0000 S1000
    G1 F1000 X29.0581 Y53.7881 Z-2.0000 S1000
    G1 F1000 X29.1842 Y53.6014 Z-2.0000 S1000
    G1 F1000 X29.3037 Y53.4102 Z-2.0000 S1000
    G1 F1000 X29.4162 Y53.2150 Z-2.0000 S1000
    G1 F1000 X29.5218 Y53.0158 Z-2.0000 S1000
    G1 F1000 X29.6203 Y52.8131 Z-2.0000 S1000
    G1 F1000 X29.7114 Y52.6070 Z-2.0000 S1000
    G1 F1000 X29.7953 Y52.3978 Z-2.0000 S1000
    G1 F1000 X29.8716 Y52.1857 Z-2.0000 S1000
    G1 F1000 X29.9404 Y51.9711 Z-2.0000 S1000
    G1 F1000 X29.9933 Y51.7848 Z-2.0000 S1000
    G1 F1000 X31.0031 Y48.0161 Z-2.0000 S1000
    G1 F1000 X33.5295 Y43.0575 Z-2.0000 S1000
    G1 F1000 X33.6282 Y42.8549 Z-2.0000 S1000
    G1 F1000 X33.7197 Y42.6489 Z-2.0000 S1000
    G1 F1000 X33.8038 Y42.4399 Z-2.0000 S1000
    G1 F1000 X33.8804 Y42.2279 Z-2.0000 S1000
    G1 F1000 X33.9495 Y42.0134 Z-2.0000 S1000
    G1 F1000 X34.0109 Y41.7965 Z-2.0000 S1000
    G1 F1000 X34.0646 Y41.5776 Z-2.0000 S1000
    G1 F1000 X34.1105 Y41.3570 Z-2.0000 S1000
    G1 F1000 X34.1485 Y41.1348 Z-2.0000 S1000
    G1 F1000 X34.1786 Y40.9115 Z-2.0000 S1000
    G1 F1000 X34.2008 Y40.6872 Z-2.0000 S1000
    G1 F1000 X34.2150 Y40.4622 Z-2.0000 S1000
    G1 F1000 X34.2212 Y40.2369 Z-2.0000 S1000
    G1 F1000 X34.2194 Y40.0116 Z-2.0000 S1000
    G1 F1000 X34.2096 Y39.7864 Z-2.0000 S1000
    G1 F1000 X34.1918 Y39.5617 Z-2.0000 S1000
    G1 F1000 X34.1661 Y39.3378 Z-2.0000 S1000
    G1 F1000 X34.1324 Y39.1150 Z-2.0000 S1000
    G1 F1000 X34.0909 Y38.8935 Z-2.0000 S1000
    G1 F1000 X34.0415 Y38.6736 Z-2.0000 S1000
    G1 F1000 X33.9843 Y38.4555 Z-2.0000 S1000
    G1 F1000 X33.9195 Y38.2397 Z-2.0000 S1000
    G1 F1000 X33.8470 Y38.0263 Z-2.0000 S1000
    G1 F1000 X33.7670 Y37.8156 Z-2.0000 S1000
    G1 F1000 X33.6795 Y37.6079 Z-2.0000 S1000
    G1 F1000 X33.5848 Y37.4034 Z-2.0000 S1000
    G1 F1000 X33.4828 Y37.2024 Z-2.0000 S1000
    G1 F1000 X33.3738 Y37.0051 Z-2.0000 S1000
    G1 F1000 X33.2579 Y36.8118 Z-2.0000 S1000
    G1 F1000 X33.1351 Y36.6228 Z-2.0000 S1000
    G1 F1000 X32.9545 Y36.3688 Z-2.0000 S1000
    G1 F1000 X31.4356 Y34.3403 Z-2.0000 S1000
    G1 F1000 X33.4642 Y35.8592 Z-2.0000 S1000
    G1 F1000 X33.6469 Y35.9911 Z-2.0000 S1000
    G1 F1000 X33.8343 Y36.1164 Z-2.0000 S1000
    G1 F1000 X34.0260 Y36.2350 Z-2.0000 S1000
    G1 F1000 X34.2217 Y36.3466 Z-2.0000 S1000
    G1 F1000 X34.4213 Y36.4513 Z-2.0000 S1000
    G1 F1000 X34.6245 Y36.5488 Z-2.0000 S1000
    G1 F1000 X34.8310 Y36.6391 Z-2.0000 S1000
    G1 F1000 X35.0406 Y36.7219 Z-2.0000 S1000
    G1 F1000 X35.2530 Y36.7973 Z-2.0000 S1000
    G1 F1000 X35.4680 Y36.8651 Z-2.0000 S1000
    G1 F1000 X35.6852 Y36.9252 Z-2.0000 S1000
    G1 F1000 X35.9044 Y36.9776 Z-2.0000 S1000
    G1 F1000 X36.1253 Y37.0222 Z-2.0000 S1000
    G1 F1000 X36.3477 Y37.0588 Z-2.0000 S1000
    G1 F1000 X36.5712 Y37.0876 Z-2.0000 S1000
    G1 F1000 X36.7956 Y37.1084 Z-2.0000 S1000
    G1 F1000 X37.0207 Y37.1213 Z-2.0000 S1000
    G1 F1000 X37.2460 Y37.1262 Z-2.0000 S1000
    G1 F1000 X37.4713 Y37.1230 Z-2.0000 S1000
    G1 F1000 X37.6964 Y37.1119 Z-2.0000 S1000
    G1 F1000 X37.9210 Y37.0928 Z-2.0000 S1000
    G1 F1000 X38.1448 Y37.0657 Z-2.0000 S1000
    G1 F1000 X38.3674 Y37.0307 Z-2.0000 S1000
    G1 F1000 X38.5887 Y36.9878 Z-2.0000 S1000
    G1 F1000 X38.6438 Y36.9751 Z-2.0000 S1000
    G1 F1000 X41.9909 Y44.1530 Z-2.0000 S1000
    G1 F1000 X41.9252 Y44.2082 Z-2.0000 S1000
    G1 F1000 X41.7579 Y44.3591 Z-2.0000 S1000
    G1 F1000 X41.5960 Y44.5159 Z-2.0000 S1000
    G1 F1000 X41.4397 Y44.6783 Z-2.0000 S1000
    G1 F1000 X41.2894 Y44.8462 Z-2.0000 S1000
    G1 F1000 X41.1585 Y45.0026 Z-2.0000 S1000
    G1 F1000 X39.7062 Y46.7963 Z-2.0000 S1000
    G1 F1000 X39.5675 Y46.9739 Z-2.0000 S1000
    G1 F1000 X39.4352 Y47.1564 Z-2.0000 S1000
    G1 F1000 X39.3095 Y47.3434 Z-2.0000 S1000
    G1 F1000 X39.1905 Y47.5348 Z-2.0000 S1000
    G1 F1000 X39.0783 Y47.7303 Z-2.0000 S1000
    G1 F1000 X38.9834 Y47.9094 Z-2.0000 S1000
    G1 F1000 X37.9359 Y49.9654 Z-2.0000 S1000
    G1 F1000 X37.8372 Y50.1680 Z-2.0000 S1000
    G1 F1000 X37.7457 Y50.3740 Z-2.0000 S1000
    G1 F1000 X37.6616 Y50.5831 Z-2.0000 S1000
    G1 F1000 X37.5849 Y50.7951 Z-2.0000 S1000
    G1 F1000 X37.5159 Y51.0096 Z-2.0000 S1000
    G1 F1000 X37.4602 Y51.2049 Z-2.0000 S1000
    G1 F1000 X36.8628 Y53.4349 Z-2.0000 S1000
    G1 F1000 X36.8083 Y53.6536 Z-2.0000 S1000
    G1 F1000 X36.7617 Y53.8741 Z-2.0000 S1000
    G1 F1000 X36.7229 Y54.0961 Z-2.0000 S1000
    G1 F1000 X36.6920 Y54.3194 Z-2.0000 S1000
    G1 F1000 X36.6690 Y54.5436 Z-2.0000 S1000
    G1 F1000 X36.6552 Y54.7452 Z-2.0000 S1000
    G1 F1000 X36.5342 Y57.0498 Z-2.0000 S1000
    G1 F1000 X36.5264 Y57.2750 Z-2.0000 S1000
    G1 F1000 X36.5266 Y57.5004 Z-2.0000 S1000
    G1 F1000 X36.5348 Y57.7256 Z-2.0000 S1000
    G1 F1000 X36.5509 Y57.9504 Z-2.0000 S1000
    G1 F1000 X36.5751 Y58.1745 Z-2.0000 S1000
    G1 F1000 X36.6037 Y58.3765 Z-2.0000 S1000
    G1 F1000 X36.9649 Y60.6560 Z-2.0000 S1000
    G1 F1000 X37.0042 Y60.8779 Z-2.0000 S1000
    G1 F1000 X37.0512 Y61.0983 Z-2.0000 S1000
    G1 F1000 X37.1061 Y61.3169 Z-2.0000 S1000
    G1 F1000 X37.1687 Y61.5335 Z-2.0000 S1000
    G1 F1000 X37.2389 Y61.7476 Z-2.0000 S1000
    G1 F1000 X37.3086 Y61.9381 Z-2.0000 S1000
    G1 F1000 X38.1357 Y64.0925 Z-2.0000 S1000
    G1 F1000 X38.2202 Y64.3014 Z-2.0000 S1000
    G1 F1000 X38.3120 Y64.5072 Z-2.0000 S1000
    G1 F1000 X38.4111 Y64.7097 Z-2.0000 S1000
    G1 F1000 X38.5174 Y64.9084 Z-2.0000 S1000
    G1 F1000 X38.6306 Y65.1033 Z-2.0000 S1000
    G1 F1000 X38.7386 Y65.2756 Z-2.0000 S1000
    G1 F1000 X39.9958 Y67.2111 Z-2.0000 S1000
    G1 F1000 X40.1219 Y67.3979 Z-2.0000 S1000
    G1 F1000 X40.2545 Y67.5801 Z-2.0000 S1000
    G1 F1000 X40.3936 Y67.7575 Z-2.0000 S1000
    G1 F1000 X40.5388 Y67.9298 Z-2.0000 S1000
    G1 F1000 X40.6901 Y68.0969 Z-2.0000 S1000
    G1 F1000 X40.8309 Y68.2422 Z-2.0000 S1000
    G1 F1000 X42.4625 Y69.8738 Z-2.0000 S1000
    G1 F1000 X42.6246 Y70.0303 Z-2.0000 S1000
    G1 F1000 X42.7923 Y70.1810 Z-2.0000 S1000
    G1 F1000 X42.9651 Y70.3256 Z-2.0000 S1000
    G1 F1000 X43.1430 Y70.4640 Z-2.0000 S1000
    G1 F1000 X43.3257 Y70.5960 Z-2.0000 S1000
    G1 F1000 X43.4936 Y70.7089 Z-2.0000 S1000
    G1 F1000 X45.4291 Y71.9661 Z-2.0000 S1000
    G1 F1000 X45.6203 Y72.0855 Z-2.0000 S1000
    G1 F1000 X45.8155 Y72.1980 Z-2.0000 S1000
    G1 F1000 X46.0147 Y72.3036 Z-2.0000 S1000
    G1 F1000 X46.2175 Y72.4020 Z-2.0000 S1000
    G1 F1000 X46.4236 Y72.4931 Z-2.0000 S1000
    G1 F1000 X46.6122 Y72.5690 Z-2.0000 S1000
    G1 F1000 X48.7666 Y73.3961 Z-2.0000 S1000
    G1 F1000 X48.9784 Y73.4732 Z-2.0000 S1000
    G1 F1000 X49.1928 Y73.5426 Z-2.0000 S1000
    G1 F1000 X49.4096 Y73.6045 Z-2.0000 S1000
    G1 F1000 X49.6284 Y73.6585 Z-2.0000 S1000
    G1 F1000 X49.8489 Y73.7048 Z-2.0000 S1000
    G1 F1000 X50.0487 Y73.7398 Z-2.0000 S1000
    G1 F1000 X52.3282 Y74.1010 Z-2.0000 S1000
    G1 F1000 X52.5514 Y74.1323 Z-2.0000 S1000
    G1 F1000 X52.7756 Y74.1556 Z-2.0000 S1000
    G1 F1000 X53.0004 Y74.1711 Z-2.0000 S1000
    G1 F1000 X53.2257 Y74.1785 Z-2.0000 S1000
    G1 F1000 X53.4511 Y74.1779 Z-2.0000 S1000
    G1 F1000 X53.6549 Y74.1705 Z-2.0000 S1000
    G1 F1000 X55.9595 Y74.0495 Z-2.0000 S1000
    G1 F1000 X56.1844 Y74.0337 Z-2.0000 S1000
    G1 F1000 X56.4085 Y74.0099 Z-2.0000 S1000
    G1 F1000 X56.6316 Y73.9782 Z-2.0000 S1000
    G1 F1000 X56.8535 Y73.9385 Z-2.0000 S1000
    G1 F1000 X57.0738 Y73.8911 Z-2.0000 S1000
    G1 F1000 X57.2698 Y73.8419 Z-2.0000 S1000
    G1 F1000 X59.4998 Y73.2445 Z-2.0000 S1000
    G1 F1000 X59.7164 Y73.1823 Z-2.0000 S1000
    G1 F1000 X59.9307 Y73.1125 Z-2.0000 S1000
    G1 F1000 X60.1424 Y73.0351 Z-2.0000 S1000
    G1 F1000 X60.3512 Y72.9503 Z-2.0000 S1000
    G1 F1000 X60.5568 Y72.8581 Z-2.0000 S1000
    G1 F1000 X60.7393 Y72.7688 Z-2.0000 S1000
    G1 F1000 X62.7953 Y71.7213 Z-2.0000 S1000
    G1 F1000 X62.9942 Y71.6154 Z-2.0000 S1000
    G1 F1000 X63.1893 Y71.5026 Z-2.0000 S1000
    G1 F1000 X63.3803 Y71.3829 Z-2.0000 S1000
    G1 F1000 X63.5669 Y71.2565 Z-2.0000 S1000
    G1 F1000 X63.7489 Y71.1235 Z-2.0000 S1000
    G1 F1000 X63.9084 Y70.9985 Z-2.0000 S1000
    G1 F1000 X65.7021 Y69.5462 Z-2.0000 S1000
    G1 F1000 X65.8748 Y69.4012 Z-2.0000 S1000
    G1 F1000 X66.0421 Y69.2503 Z-2.0000 S1000
    G1 F1000 X66.2040 Y69.0935 Z-2.0000 S1000
    G1 F1000 X66.3603 Y68.9311 Z-2.0000 S1000
    G1 F1000 X66.5106 Y68.7632 Z-2.0000 S1000
    G1 F1000 X66.6415 Y68.6068 Z-2.0000 S1000
    G1 F1000 X68.0938 Y66.8131 Z-2.0000 S1000
    G1 F1000 X68.2325 Y66.6355 Z-2.0000 S1000
    G1 F1000 X68.3648 Y66.4530 Z-2.0000 S1000
    G1 F1000 X68.4905 Y66.2660 Z-2.0000 S1000
    G1 F1000 X68.6095 Y66.0746 Z-2.0000 S1000
    G1 F1000 X68.7217 Y65.8791 Z-2.0000 S1000
    G1 F1000 X68.8166 Y65.7000 Z-2.0000 S1000
    G1 F1000 X69.8641 Y63.6440 Z-2.0000 S1000
    G1 F1000 X69.9628 Y63.4414 Z-2.0000 S1000
    G1 F1000 X70.0543 Y63.2354 Z-2.0000 S1000
    G1 F1000 X70.1384 Y63.0263 Z-2.0000 S1000
    G1 F1000 X70.2151 Y62.8143 Z-2.0000 S1000
    G1 F1000 X70.2841 Y62.5998 Z-2.0000 S1000
    G1 F1000 X70.3398 Y62.4045 Z-2.0000 S1000
    G1 F1000 X70.9372 Y60.1745 Z-2.0000 S1000
    G1 F1000 X70.9917 Y59.9558 Z-2.0000 S1000
    G1 F1000 X71.0383 Y59.7353 Z-2.0000 S1000
    G1 F1000 X71.0771 Y59.5133 Z-2.0000 S1000
    G1 F1000 X71.1080 Y59.2900 Z-2.0000 S1000
    G1 F1000 X71.1310 Y59.0658 Z-2.0000 S1000
    G1 F1000 X71.1448 Y58.8642 Z-2.0000 S1000
    G1 F1000 X71.2658 Y56.5596 Z-2.0000 S1000
    G1 F1000 X71.2736 Y56.3344 Z-2.0000 S1000
    G1 F1000 X71.2734 Y56.1090 Z-2.0000 S1000
    G1 F1000 X71.2652 Y55.8838 Z-2.0000 S1000
    G1 F1000 X71.2491 Y55.6590 Z-2.0000 S1000
    G1 F1000 X71.2249 Y55.4349 Z-2.0000 S1000
    G1 F1000 X71.1963 Y55.2329 Z-2.0000 S1000
    G1 F1000 X70.8351 Y52.9534 Z-2.0000 S1000
    G1 F1000 X70.7958 Y52.7315 Z-2.0000 S1000
    G1 F1000 X70.7488 Y52.5111 Z-2.0000 S1000
    G1 F1000 X70.6939 Y52.2925 Z-2.0000 S1000
    G1 F1000 X70.6313 Y52.0759 Z-2.0000 S1000
    G1 F1000 X70.5611 Y51.8618 Z-2.0000 S1000
    G1 F1000 X70.4914 Y51.6713 Z-2.0000 S1000
    G1 F1000 X69.6643 Y49.5169 Z-2.0000 S1000
    G1 F1000 X69.5798 Y49.3080 Z-2.0000 S1000
    G1 F1000 X69.4880 Y49.1022 Z-2.0000 S1000
    G1 F1000 X69.3889 Y48.8997 Z-2.0000 S1000
    G1 F1000 X69.2826 Y48.7010 Z-2.0000 S1000
    G1 F1000 X69.1694 Y48.5061 Z-2.0000 S1000
    G1 F1000 X69.0614 Y48.3338 Z-2.0000 S1000
    G1 F1000 X67.8042 Y46.3983 Z-2.0000 S1000
    G1 F1000 X67.6781 Y46.2115 Z-2.0000 S1000
    G1 F1000 X67.5455 Y46.0293 Z-2.0000 S1000
    G1 F1000 X67.4064 Y45.8519 Z-2.0000 S1000
    G1 F1000 X67.2612 Y45.6796 Z-2.0000 S1000
    G1 F1000 X67.1099 Y45.5125 Z-2.0000 S1000
    G1 F1000 X66.9691 Y45.3672 Z-2.0000 S1000
    G1 F1000 X66.4718 Y44.8699 Z-2.0000 S1000
    G1 F700 Z-3.0000
    G1 F1000 X70.0447 Y37.2077 Z-3.0000 S1000
    G1 F1000 X70.1299 Y37.2129 Z-3.0000 S1000
    G1 F1000 X70.3552 Y37.2187 Z-3.0000 S1000
    G1 F1000 X70.5806 Y37.2165 Z-3.0000 S1000
    G1 F1000 X70.8057 Y37.2063 Z-3.0000 S1000
    G1 F1000 X71.0304 Y37.1881 Z-3.0000 S1000
    G1 F1000 X71.2542 Y37.1620 Z-3.0000 S1000
    G1 F1000 X71.4770 Y37.1279 Z-3.0000 S1000
    G1 F1000 X71.6984 Y37.0859 Z-3.0000 S1000
    G1 F1000 X71.9182 Y37.0362 Z-3.0000 S1000
    G1 F1000 X72.1362 Y36.9786 Z-3.0000 S1000
    G1 F1000 X72.3519 Y36.9133 Z-3.0000 S1000
    G1 F1000 X72.5652 Y36.8405 Z-3.0000 S1000
    G1 F1000 X72.7757 Y36.7601 Z-3.0000 S1000
    G1 F1000 X72.9833 Y36.6723 Z-3.0000 S1000
    G1 F1000 X73.1876 Y36.5771 Z-3.0000 S1000
    G1 F1000 X73.3884 Y36.4748 Z-3.0000 S1000
    G1 F1000 X73.5855 Y36.3655 Z-3.0000 S1000
    G1 F1000 X73.7785 Y36.2492 Z-3.0000 S1000
    G1 F1000 X73.9673 Y36.1261 Z-3.0000 S1000
    G1 F1000 X74.2117 Y35.9520 Z-3.0000 S1000
    G1 F1000 X76.3648 Y34.3399 Z-3.0000 S1000
    G1 F1000 X74.7527 Y36.4930 Z-3.0000 S1000
    G1 F1000 X74.6209 Y36.6758 Z-3.0000 S1000
    G1 F1000 X74.4956 Y36.8631 Z-3.0000 S1000
    G1 F1000 X74.3770 Y37.0548 Z-3.0000 S1000
    G1 F1000 X74.2653 Y37.2506 Z-3.0000 S1000
    G1 F1000 X74.1607 Y37.4502 Z-3.0000 S1000
    G1 F1000 X74.0631 Y37.6534 Z-3.0000 S1000
    G1 F1000 X73.9729 Y37.8599 Z-3.0000 S1000
    G1 F1000 X73.8900 Y38.0695 Z-3.0000 S1000
    G1 F1000 X73.8147 Y38.2819 Z-3.0000 S1000
    G1 F1000 X73.7469 Y38.4968 Z-3.0000 S1000
    G1 F1000 X73.6868 Y38.7140 Z-3.0000 S1000
    G1 F1000 X73.6344 Y38.9332 Z-3.0000 S1000
    G1 F1000 X73.5898 Y39.1542 Z-3.0000 S1000
    G1 F1000 X73.5531 Y39.3766 Z-3.0000 S1000
    G1 F1000 X73.5244 Y39.6001 Z-3.0000 S1000
    G1 F1000 X73.5035 Y39.8245 Z-3.0000 S1000
    G1 F1000 X73.4907 Y40.0495 Z-3.0000 S1000
    G1 F1000 X73.4858 Y40.2748 Z-3.0000 S1000
    G1 F1000 X73.4890 Y40.5002 Z-3.0000 S1000
    G1 F1000 X73.5001 Y40.7253 Z-3.0000 S1000
    G1 F1000 X73.5193 Y40.9499 Z-3.0000 S1000
    G1 F1000 X73.5463 Y41.1736 Z-3.0000 S1000
    G1 F1000 X73.5813 Y41.3963 Z-3.0000 S1000
    G1 F1000 X73.6242 Y41.6175 Z-3.0000 S1000
    G1 F1000 X73.6749 Y41.8371 Z-3.0000 S1000
    G1 F1000 X73.7334 Y42.0548 Z-3.0000 S1000
    G1 F1000 X73.7996 Y42.2702 Z-3.0000 S1000
    G1 F1000 X73.8733 Y42.4832 Z-3.0000 S1000
    G1 F1000 X73.9546 Y42.6934 Z-3.0000 S1000
    G1 F1000 X74.0433 Y42.9006 Z-3.0000 S1000
    G1 F1000 X74.1392 Y43.1046 Z-3.0000 S1000
    G1 F1000 X74.2424 Y43.3049 Z-3.0000 S1000
    G1 F1000 X74.3526 Y43.5015 Z-3.0000 S1000
    G1 F1000 X74.5100 Y43.7570 Z-3.0000 S1000
    G1 F1000 X75.7524 Y45.6705 Z-3.0000 S1000
    G1 F1000 X77.5901 Y50.4571 Z-3.0000 S1000
    G1 F1000 X77.6981 Y51.1389 Z-3.0000 S1000
    G1 F1000 X77.7373 Y51.3608 Z-3.0000 S1000
    G1 F1000 X77.7844 Y51.5812 Z-3.0000 S1000
    G1 F1000 X77.8393 Y51.7998 Z-3.0000 S1000
    G1 F1000 X77.9018 Y52.0163 Z-3.0000 S1000
    G1 F1000 X77.9721 Y52.2305 Z-3.0000 S1000
    G1 F1000 X78.0498 Y52.4420 Z-3.0000 S1000
    G1 F1000 X78.1351 Y52.6507 Z-3.0000 S1000
    G1 F1000 X78.2277 Y52.8562 Z-3.0000 S1000
    G1 F1000 X78.3275 Y53.0582 Z-3.0000 S1000
    G1 F1000 X78.4344 Y53.2566 Z-3.0000 S1000
    G1 F1000 X78.5483 Y53.4511 Z-3.0000 S1000
    G1 F1000 X78.6691 Y53.6414 Z-3.0000 S1000
    G1 F1000 X78.7965 Y53.8273 Z-3.0000 S1000
    G1 F1000 X78.9304 Y54.0086 Z-3.0000 S1000
    G1 F1000 X79.0707 Y54.1850 Z-3.0000 S1000
    G1 F1000 X79.2171 Y54.3563 Z-3.0000 S1000
    G1 F1000 X79.3696 Y54.5223 Z-3.0000 S1000
    G1 F1000 X79.5278 Y54.6828 Z-3.0000 S1000
    G1 F1000 X79.6916 Y54.8376 Z-3.0000 S1000
    G1 F1000 X79.8608 Y54.9865 Z-3.0000 S1000
    G1 F1000 X80.0352 Y55.1293 Z-3.0000 S1000
    G1 F1000 X80.2146 Y55.2657 Z-3.0000 S1000
    G1 F1000 X80.3987 Y55.3958 Z-3.0000 S1000
    G1 F1000 X80.5872 Y55.5192 Z-3.0000 S1000
    G1 F1000 X80.7801 Y55.6359 Z-3.0000 S1000
    G1 F1000 X80.9769 Y55.7456 Z-3.0000 S1000
    G1 F1000 X81.1776 Y55.8483 Z-3.0000 S1000
    G1 F1000 X81.3817 Y55.9438 Z-3.0000 S1000
    G1 F1000 X81.5891 Y56.0320 Z-3.0000 S1000
    G1 F1000 X81.7995 Y56.1128 Z-3.0000 S1000
    G1 F1000 X82.0127 Y56.1860 Z-3.0000 S1000
    G1 F1000 X82.2283 Y56.2517 Z-3.0000 S1000
    G1 F1000 X82.4461 Y56.3096 Z-3.0000 S1000
    G1 F1000 X82.6658 Y56.3598 Z-3.0000 S1000
    G1 F1000 X82.8871 Y56.4022 Z-3.0000 S1000
    G1 F1000 X83.0668 Y56.4307 Z-3.0000 S1000
    G1 F1000 X85.6693 Y56.8046 Z-3.0000 S1000
    G1 F1000 X83.0374 Y57.1827 Z-3.0000 S1000
    G1 F1000 X82.8149 Y57.2187 Z-3.0000 S1000
    G1 F1000 X82.5938 Y57.2626 Z-3.0000 S1000
    G1 F1000 X82.3745 Y57.3143 Z-3.0000 S1000
    G1 F1000 X82.1571 Y57.3737 Z-3.0000 S1000
    G1 F1000 X81.9419 Y57.4409 Z-3.0000 S1000
    G1 F1000 X81.7293 Y57.5156 Z-3.0000 S1000
    G1 F1000 X81.5194 Y57.5978 Z-3.0000 S1000
    G1 F1000 X81.3126 Y57.6874 Z-3.0000 S1000
    G1 F1000 X81.1091 Y57.7843 Z-3.0000 S1000
    G1 F1000 X80.9092 Y57.8883 Z-3.0000 S1000
    G1 F1000 X80.7131 Y57.9994 Z-3.0000 S1000
    G1 F1000 X80.5211 Y58.1174 Z-3.0000 S1000
    G1 F1000 X80.3333 Y58.2421 Z-3.0000 S1000
    G1 F1000 X80.1501 Y58.3734 Z-3.0000 S1000
    G1 F1000 X79.9717 Y58.5111 Z-3.0000 S1000
    G1 F1000 X79.7983 Y58.6550 Z-3.0000 S1000
    G1 F1000 X79.6301 Y58.8051 Z-3.0000 S1000
    G1 F1000 X79.4673 Y58.9610 Z-3.0000 S1000
    G1 F1000 X79.3102 Y59.1225 Z-3.0000 S1000
    G1 F1000 X79.1589 Y59.2896 Z-3.0000 S1000
    G1 F1000 X79.0136 Y59.4619 Z-3.0000 S1000
    G1 F1000 X78.8746 Y59.6392 Z-3.0000 S1000
    G1 F1000 X78.7419 Y59.8214 Z-3.0000 S1000
    G1 F1000 X78.6157 Y60.0082 Z-3.0000 S1000
    G1 F1000 X78.4963 Y60.1993 Z-3.0000 S1000
    G1 F1000 X78.3837 Y60.3946 Z-3.0000 S1000
    G1 F1000 X78.2782 Y60.5937 Z-3.0000 S1000
    G1 F1000 X78.1797 Y60.7965 Z-3.0000 S1000
    G1 F1000 X78.0885 Y61.0026 Z-3.0000 S1000
    G1 F1000 X78.0047 Y61.2118 Z-3.0000 S1000
    G1 F1000 X77.9284 Y61.4238 Z-3.0000 S1000
    G1 F1000 X77.8596 Y61.6385 Z-3.0000 S1000
    G1 F1000 X77.8067 Y61.8247 Z-3.0000 S1000
    G1 F1000 X76.7968 Y65.5936 Z-3.0000 S1000
    G1 F1000 X74.2706 Y70.5518 Z-3.0000 S1000
    G1 F1000 X74.1718 Y70.7544 Z-3.0000 S1000
    G1 F1000 X74.0803 Y70.9604 Z-3.0000 S1000
    G1 F1000 X73.9962 Y71.1695 Z-3.0000 S1000
    G1 F1000 X73.9196 Y71.3815 Z-3.0000 S1000
    G1 F1000 X73.8505 Y71.5960 Z-3.0000 S1000
    G1 F1000 X73.7891 Y71.8128 Z-3.0000 S1000
    G1 F1000 X73.7354 Y72.0317 Z-3.0000 S1000
    G1 F1000 X73.6895 Y72.2524 Z-3.0000 S1000
    G1 F1000 X73.6515 Y72.4745 Z-3.0000 S1000
    G1 F1000 X73.6214 Y72.6979 Z-3.0000 S1000
    G1 F1000 X73.5992 Y72.9222 Z-3.0000 S1000
    G1 F1000 X73.5850 Y73.1471 Z-3.0000 S1000
    G1 F1000 X73.5788 Y73.3724 Z-3.0000 S1000
    G1 F1000 X73.5806 Y73.5978 Z-3.0000 S1000
    G1 F1000 X73.5904 Y73.8229 Z-3.0000 S1000
    G1 F1000 X73.6082 Y74.0476 Z-3.0000 S1000
    G1 F1000 X73.6339 Y74.2715 Z-3.0000 S1000
    G1 F1000 X73.6676 Y74.4944 Z-3.0000 S1000
    G1 F1000 X73.7091 Y74.7159 Z-3.0000 S1000
    G1 F1000 X73.7585 Y74.9358 Z-3.0000 S1000
    G1 F1000 X73.8157 Y75.1538 Z-3.0000 S1000
    G1 F1000 X73.8805 Y75.3697 Z-3.0000 S1000
    G1 F1000 X73.9530 Y75.5831 Z-3.0000 S1000
    G1 F1000 X74.0330 Y75.7938 Z-3.0000 S1000
    G1 F1000 X74.1204 Y76.0015 Z-3.0000 S1000
    G1 F1000 X74.2152 Y76.2060 Z-3.0000 S1000
    G1 F1000 X74.3171 Y76.4070 Z-3.0000 S1000
    G1 F1000 X74.4262 Y76.6043 Z-3.0000 S1000
    G1 F1000 X74.5421 Y76.7975 Z-3.0000 S1000
    G1 F1000 X74.6648 Y76.9865 Z-3.0000 S1000
    G1 F1000 X74.8455 Y77.2406 Z-3.0000 S1000
    G1 F1000 X76.3643 Y79.2690 Z-3.0000 S1000
    G1 F1000 X74.3359 Y77.7502 Z-3.0000 S1000
    G1 F1000 X74.1531 Y77.6183 Z-3.0000 S1000
    G1 F1000 X73.9658 Y77.4930 Z-3.0000 S1000
    G1 F1000 X73.7741 Y77.3745 Z-3.0000 S1000
    G1 F1000 X73.5783 Y77.2628 Z-3.0000 S1000
    G1 F1000 X73.3787 Y77.1581 Z-3.0000 S1000
    G1 F1000 X73.1755 Y77.0606 Z-3.0000 S1000
    G1 F1000 X72.9690 Y76.9703 Z-3.0000 S1000
    G1 F1000 X72.7594 Y76.8875 Z-3.0000 S1000
    G1 F1000 X72.5470 Y76.8121 Z-3.0000 S1000
    G1 F1000 X72.3321 Y76.7443 Z-3.0000 S1000
    G1 F1000 X72.1149 Y76.6842 Z-3.0000 S1000
    G1 F1000 X71.8957 Y76.6318 Z-3.0000 S1000
    G1 F1000 X71.6747 Y76.5873 Z-3.0000 S1000
    G1 F1000 X71.4524 Y76.5506 Z-3.0000 S1000
    G1 F1000 X71.2288 Y76.5218 Z-3.0000 S1000
    G1 F1000 X71.0044 Y76.5010 Z-3.0000 S1000
    G1 F1000 X70.7794 Y76.4881 Z-3.0000 S1000
    G1 F1000 X70.5541 Y76.4832 Z-3.0000 S1000
    G1 F1000 X70.3287 Y76.4864 Z-3.0000 S1000
    G1 F1000 X70.1036 Y76.4975 Z-3.0000 S1000
    G1 F1000 X69.8790 Y76.5166 Z-3.0000 S1000
    G1 F1000 X69.6553 Y76.5437 Z-3.0000 S1000
    G1 F1000 X69.4326 Y76.5787 Z-3.0000 S1000
    G1 F1000 X69.2114 Y76.6216 Z-3.0000 S1000
    G1 F1000 X68.9918 Y76.6723 Z-3.0000 S1000
    G1 F1000 X68.7741 Y76.7308 Z-3.0000 S1000
    G1 F1000 X68.5587 Y76.7969 Z-3.0000 S1000
    G1 F1000 X68.3457 Y76.8707 Z-3.0000 S1000
    G1 F1000 X68.1355 Y76.9519 Z-3.0000 S1000
    G1 F1000 X67.9283 Y77.0406 Z-3.0000 S1000
    G1 F1000 X67.6471 Y77.1753 Z-3.0000 S1000
    G1 F1000 X62.6889 Y79.7015 Z-3.0000 S1000
    G1 F1000 X58.9200 Y80.7114 Z-3.0000 S1000
    G1 F1000 X58.7034 Y80.7735 Z-3.0000 S1000
    G1 F1000 X58.4891 Y80.8434 Z-3.0000 S1000
    G1 F1000 X58.2774 Y80.9208 Z-3.0000 S1000
    G1 F1000 X58.0686 Y81.0056 Z-3.0000 S1000
    G1 F1000 X57.8630 Y81.0979 Z-3.0000 S1000
    G1 F1000 X57.6607 Y81.1973 Z-3.0000 S1000
    G1 F1000 X57.4621 Y81.3039 Z-3.0000 S1000
    G1 F1000 X57.2675 Y81.4174 Z-3.0000 S1000
    G1 F1000 X57.0769 Y81.5378 Z-3.0000 S1000
    G1 F1000 X56.8908 Y81.6649 Z-3.0000 S1000
    G1 F1000 X56.7093 Y81.7985 Z-3.0000 S1000
    G1 F1000 X56.5326 Y81.9384 Z-3.0000 S1000
    G1 F1000 X56.3610 Y82.0846 Z-3.0000 S1000
    G1 F1000 X56.1947 Y82.2367 Z-3.0000 S1000
    G1 F1000 X56.0340 Y82.3946 Z-3.0000 S1000
    G1 F1000 X55.8789 Y82.5582 Z-3.0000 S1000
    G1 F1000 X55.7297 Y82.7271 Z-3.0000 S1000
    G1 F1000 X55.5866 Y82.9013 Z-3.0000 S1000
    G1 F1000 X55.4498 Y83.0804 Z-3.0000 S1000
    G1 F1000 X55.3194 Y83.2642 Z-3.0000 S1000
    G1 F1000 X55.1956 Y83.4526 Z-3.0000 S1000
    G1 F1000 X55.0786 Y83.6452 Z-3.0000 S1000
    G1 F1000 X54.9685 Y83.8418 Z-3.0000 S1000
    G1 F1000 X54.8655 Y84.0423 Z-3.0000 S1000
    G1 F1000 X54.7696 Y84.2463 Z-3.0000 S1000
    G1 F1000 X54.6810 Y84.4535 Z-3.0000 S1000
    G1 F1000 X54.5999 Y84.6638 Z-3.0000 S1000
    G1 F1000 X54.5262 Y84.8768 Z-3.0000 S1000
    G1 F1000 X54.4602 Y85.0923 Z-3.0000 S1000
    G1 F1000 X54.4018 Y85.3099 Z-3.0000 S1000
    G1 F1000 X54.3512 Y85.5296 Z-3.0000 S1000
    G1 F1000 X54.3085 Y85.7509 Z-3.0000 S1000
    G1 F1000 X54.2780 Y85.9421 Z-3.0000 S1000
    G1 F1000 X53.8999 Y88.5740 Z-3.0000 S1000
    G1 F1000 X53.5260 Y85.9715 Z-3.0000 S1000
    G1 F1000 X53.4899 Y85.7490 Z-3.0000 S1000
    G1 F1000 X53.4461 Y85.5280 Z-3.0000 S1000
    G1 F1000 X53.3944 Y85.3086 Z-3.0000 S1000
    G1 F1000 X53.3349 Y85.0912 Z-3.0000 S1000
    G1 F1000 X53.2678 Y84.8761 Z-3.0000 S1000
    G1 F1000 X53.1931 Y84.6634 Z-3.0000 S1000
    G1 F1000 X53.1109 Y84.4536 Z-3.0000 S1000
    G1 F1000 X53.0212 Y84.2468 Z-3.0000 S1000
    G1 F1000 X52.9244 Y84.0433 Z-3.0000 S1000
    G1 F1000 X52.8203 Y83.8434 Z-3.0000 S1000
    G1 F1000 X52.7092 Y83.6473 Z-3.0000 S1000
    G1 F1000 X52.5912 Y83.4552 Z-3.0000 S1000
    G1 F1000 X52.4665 Y83.2675 Z-3.0000 S1000
    G1 F1000 X52.3352 Y83.0843 Z-3.0000 S1000
    G1 F1000 X52.1975 Y82.9059 Z-3.0000 S1000
    G1 F1000 X52.0535 Y82.7325 Z-3.0000 S1000
    G1 F1000 X51.9035 Y82.5643 Z-3.0000 S1000
    G1 F1000 X51.7476 Y82.4015 Z-3.0000 S1000
    G1 F1000 X51.5861 Y82.2444 Z-3.0000 S1000
    G1 F1000 X51.4190 Y82.0931 Z-3.0000 S1000
    G1 F1000 X51.2467 Y81.9478 Z-3.0000 S1000
    G1 F1000 X51.0693 Y81.8088 Z-3.0000 S1000
    G1 F1000 X50.8871 Y81.6761 Z-3.0000 S1000
    G1 F1000 X50.7004 Y81.5500 Z-3.0000 S1000
    G1 F1000 X50.5092 Y81.4305 Z-3.0000 S1000
    G1 F1000 X50.3140 Y81.3180 Z-3.0000 S1000
    G1 F1000 X50.1148 Y81.2124 Z-3.0000 S1000
    G1 F1000 X49.9121 Y81.1140 Z-3.0000 S1000
    G1 F1000 X49.7060 Y81.0228 Z-3.0000 S1000
    G1 F1000 X49.4968 Y80.9390 Z-3.0000 S1000
    G1 F1000 X49.2847 Y80.8626 Z-3.0000 S1000
    G1 F1000 X49.0701 Y80.7939 Z-3.0000 S1000
    G1 F1000 X48.8531 Y80.7328 Z-3.0000 S1000
    G1 F1000 X48.6342 Y80.6794 Z-3.0000 S1000
    G1 F1000 X48.4134 Y80.6339 Z-3.0000 S1000
    G1 F1000 X48.2342 Y80.6028 Z-3.0000 S1000
    G1 F1000 X47.5524 Y80.4948 Z-3.0000 S1000
    G1 F1000 X42.7658 Y78.6571 Z-3.0000 S1000
    G1 F1000 X40.8523 Y77.4147 Z-3.0000 S1000
    G1 F1000 X40.6611 Y77.2953 Z-3.0000 S1000
    G1 F1000 X40.4658 Y77.1828 Z-3.0000 S1000
    G1 F1000 X40.2666 Y77.0773 Z-3.0000 S1000
    G1 F1000 X40.0639 Y76.9790 Z-3.0000 S1000
    G1 F1000 X39.8577 Y76.8878 Z-3.0000 S1000
    G1 F1000 X39.6485 Y76.8041 Z-3.0000 S1000
    G1 F1000 X39.4364 Y76.7278 Z-3.0000 S1000
    G1 F1000 X39.2217 Y76.6592 Z-3.0000 S1000
    G1 F1000 X39.0048 Y76.5981 Z-3.0000 S1000
    G1 F1000 X38.7858 Y76.5449 Z-3.0000 S1000
    G1 F1000 X38.5650 Y76.4994 Z-3.0000 S1000
    G1 F1000 X38.3428 Y76.4618 Z-3.0000 S1000
    G1 F1000 X38.1194 Y76.4320 Z-3.0000 S1000
    G1 F1000 X37.8951 Y76.4103 Z-3.0000 S1000
    G1 F1000 X37.6701 Y76.3965 Z-3.0000 S1000
    G1 F1000 X37.4448 Y76.3907 Z-3.0000 S1000
    G1 F1000 X37.2194 Y76.3929 Z-3.0000 S1000
    G1 F1000 X36.9943 Y76.4031 Z-3.0000 S1000
    G1 F1000 X36.7696 Y76.4213 Z-3.0000 S1000
    G1 F1000 X36.5458 Y76.4474 Z-3.0000 S1000
    G1 F1000 X36.3230 Y76.4815 Z-3.0000 S1000
    G1 F1000 X36.1016 Y76.5235 Z-3.0000 S1000
    G1 F1000 X35.8818 Y76.5732 Z-3.0000 S1000
    G1 F1000 X35.6638 Y76.6308 Z-3.0000 S1000
    G1 F1000 X35.4481 Y76.6961 Z-3.0000 S1000
    G1 F1000 X35.2348 Y76.7689 Z-3.0000 S1000
    G1 F1000 X35.0243 Y76.8493 Z-3.0000 S1000
    G1 F1000 X34.8167 Y76.9371 Z-3.0000 S1000
    G1 F1000 X34.6124 Y77.0323 Z-3.0000 S1000
    G1 F1000 X34.4116 Y77.1346 Z-3.0000 S1000
    G1 F1000 X34.2145 Y77.2439 Z-3.0000 S1000
    G1 F1000 X34.0215 Y77.3602 Z-3.0000 S1000
    G1 F1000 X33.8327 Y77.4833 Z-3.0000 S1000
    G1 F1000 X33.5883 Y77.6574 Z-3.0000 S1000
    G1 F1000 X31.4353 Y79.2694 Z-3.0000 S1000
    G1 F1000 X33.0473 Y77.1165 Z-3.0000 S1000
    G1 F1000 X33.1791 Y76.9337 Z-3.0000 S1000
    G1 F1000 X33.3044 Y76.7464 Z-3.0000 S1000
    G1 F1000 X33.4230 Y76.5547 Z-3.0000 S1000
    G1 F1000 X33.5347 Y76.3590 Z-3.0000 S1000
    G1 F1000 X33.6393 Y76.1594 Z-3.0000 S1000
    G1 F1000 X33.7368 Y75.9562 Z-3.0000 S1000
    G1 F1000 X33.8271 Y75.7497 Z-3.0000 S1000
    G1 F1000 X33.9100 Y75.5401 Z-3.0000 S1000
    G1 F1000 X33.9853 Y75.3277 Z-3.0000 S1000
    G1 F1000 X34.0531 Y75.1127 Z-3.0000 S1000
    G1 F1000 X34.1132 Y74.8955 Z-3.0000 S1000
    G1 F1000 X34.1656 Y74.6763 Z-3.0000 S1000
    G1 F1000 X34.2102 Y74.4554 Z-3.0000 S1000
    G1 F1000 X34.2469 Y74.2330 Z-3.0000 S1000
    G1 F1000 X34.2756 Y74.0095 Z-3.0000 S1000
    G1 F1000 X34.2965 Y73.7850 Z-3.0000 S1000
    G1 F1000 X34.3093 Y73.5600 Z-3.0000 S1000
    G1 F1000 X34.3142 Y73.3347 Z-3.0000 S1000
    G1 F1000 X34.3110 Y73.1093 Z-3.0000 S1000
    G1 F1000 X34.2999 Y72.8842 Z-3.0000 S1000
    G1 F1000 X34.2807 Y72.6597 Z-3.0000 S1000
    G1 F1000 X34.2537 Y72.4359 Z-3.0000 S1000
    G1 F1000 X34.2187 Y72.2133 Z-3.0000 S1000
    G1 F1000 X34.1758 Y71.9920 Z-3.0000 S1000
    G1 F1000 X34.1251 Y71.7724 Z-3.0000 S1000
    G1 F1000 X34.0666 Y71.5547 Z-3.0000 S1000
    G1 F1000 X34.0005 Y71.3393 Z-3.0000 S1000
    G1 F1000 X33.9267 Y71.1263 Z-3.0000 S1000
    G1 F1000 X33.8454 Y70.9161 Z-3.0000 S1000
    G1 F1000 X33.7568 Y70.7089 Z-3.0000 S1000
    G1 F1000 X33.6608 Y70.5050 Z-3.0000 S1000
    G1 F1000 X33.5576 Y70.3046 Z-3.0000 S1000
    G1 F1000 X33.4474 Y70.1080 Z-3.0000 S1000
    G1 F1000 X33.2901 Y69.8526 Z-3.0000 S1000
    G1 F1000 X32.0475 Y67.9388 Z-3.0000 S1000
    G1 F1000 X30.2099 Y63.1523 Z-3.0000 S1000
    G1 F1000 X30.1019 Y62.4705 Z-3.0000 S1000
    G1 F1000 X30.0627 Y62.2486 Z-3.0000 S1000
    G1 F1000 X30.0156 Y62.0282 Z-3.0000 S1000
    G1 F1000 X29.9607 Y61.8096 Z-3.0000 S1000
    G1 F1000 X29.8982 Y61.5931 Z-3.0000 S1000
    G1 F1000 X29.8279 Y61.3789 Z-3.0000 S1000
    G1 F1000 X29.7502 Y61.1674 Z-3.0000 S1000
    G1 F1000 X29.6649 Y60.9587 Z-3.0000 S1000
    G1 F1000 X29.5723 Y60.7532 Z-3.0000 S1000
    G1 F1000 X29.4725 Y60.5512 Z-3.0000 S1000
    G1 F1000 X29.3656 Y60.3528 Z-3.0000 S1000
    G1 F1000 X29.2517 Y60.1583 Z-3.0000 S1000
    G1 F1000 X29.1309 Y59.9680 Z-3.0000 S1000
    G1 F1000 X29.0035 Y59.7821 Z-3.0000 S1000
    G1 F1000 X28.8696 Y59.6008 Z-3.0000 S1000
    G1 F1000 X28.7293 Y59.4244 Z-3.0000 S1000
    G1 F1000 X28.5829 Y59.2531 Z-3.0000 S1000
    G1 F1000 X28.4304 Y59.0871 Z-3.0000 S1000
    G1 F1000 X28.2722 Y58.9266 Z-3.0000 S1000
    G1 F1000 X28.1084 Y58.7718 Z-3.0000 S1000
    G1 F1000 X27.9392 Y58.6229 Z-3.0000 S1000
    G1 F1000 X27.7648 Y58.4801 Z-3.0000 S1000
    G1 F1000 X27.5854 Y58.3437 Z-3.0000 S1000
    G1 F1000 X27.4013 Y58.2136 Z-3.0000 S1000
    G1 F1000 X27.2128 Y58.0902 Z-3.0000 S1000
    G1 F1000 X27.0199 Y57.9735 Z-3.0000 S1000
    G1 F1000 X26.8231 Y57.8638 Z-3.0000 S1000
    G1 F1000 X26.6224 Y57.7611 Z-3.0000 S1000
    G1 F1000 X26.4183 Y57.6656 Z-3.0000 S1000
    G1 F1000 X26.2109 Y57.5774 Z-3.0000 S1000
    G1 F1000 X26.0005 Y57.4966 Z-3.0000 S1000
    G1 F1000 X25.7873 Y57.4234 Z-3.0000 S1000
    G1 F1000 X25.5717 Y57.3577 Z-3.0000 S1000
    G1 F1000 X25.3539 Y57.2998 Z-3.0000 S1000
    G1 F1000 X25.1342 Y57.2496 Z-3.0000 S1000
    G1 F1000 X24.9129 Y57.2072 Z-3.0000 S1000
    G1 F1000 X24.7332 Y57.1787 Z-3.0000 S1000
    G1 F1000 X22.1309 Y56.8048 Z-3.0000 S1000
    G1 F1000 X24.7626 Y56.4268 Z-3.0000 S1000
    G1 F1000 X24.9850 Y56.3908 Z-3.0000 S1000
    G1 F1000 X25.2061 Y56.3469 Z-3.0000 S1000
    G1 F1000 X25.4255 Y56.2952 Z-3.0000 S1000
    G1 F1000 X25.6429 Y56.2358 Z-3.0000 S1000
    G1 F1000 X25.8580 Y56.1687 Z-3.0000 S1000
    G1 F1000 X26.0707 Y56.0940 Z-3.0000 S1000
    G1 F1000 X26.2805 Y56.0117 Z-3.0000 S1000
    G1 F1000 X26.4873 Y55.9221 Z-3.0000 S1000
    G1 F1000 X26.6908 Y55.8253 Z-3.0000 S1000
    G1 F1000 X26.8907 Y55.7212 Z-3.0000 S1000
    G1 F1000 X27.0868 Y55.6101 Z-3.0000 S1000
    G1 F1000 X27.2789 Y55.4922 Z-3.0000 S1000
    G1 F1000 X27.4666 Y55.3675 Z-3.0000 S1000
    G1 F1000 X27.6498 Y55.2362 Z-3.0000 S1000
    G1 F1000 X27.8282 Y55.0984 Z-3.0000 S1000
    G1 F1000 X28.0016 Y54.9545 Z-3.0000 S1000
    G1 F1000 X28.1698 Y54.8045 Z-3.0000 S1000
    G1 F1000 X28.3326 Y54.6486 Z-3.0000 S1000
    G1 F1000 X28.4897 Y54.4870 Z-3.0000 S1000
    G1 F1000 X28.6410 Y54.3200 Z-3.0000 S1000
    G1 F1000 X28.7863 Y54.1477 Z-3.0000 S1000
    G1 F1000 X28.9254 Y53.9703 Z-3.0000 S1000
    G1 F1000 X29.0581 Y53.7881 Z-3.0000 S1000
    G1 F1000 X29.1842 Y53.6014 Z-3.0000 S1000
    G1 F1000 X29.3037 Y53.4102 Z-3.0000 S1000
    G1 F1000 X29.4162 Y53.2150 Z-3.0000 S1000
    G1 F1000 X29.5218 Y53.0158 Z-3.0000 S1000
    G1 F1000 X29.6203 Y52.8131 Z-3.0000 S1000
    G1 F1000 X29.7114 Y52.6070 Z-3.0000 S1000
    G1 F1000 X29.7953 Y52.3978 Z-3.0000 S1000
    G1 F1000 X29.8716 Y52.1857 Z-3.0000 S1000
    G1 F1000 X29.9404 Y51.9711 Z-3.0000 S1000
    G1 F1000 X29.9933 Y51.7848 Z-3.0000 S1000
    G1 F1000 X31.0031 Y48.0161 Z-3.0000 S1000
    G1 F1000 X33.5295 Y43.0575 Z-3.0000 S1000
    G1 F1000 X33.6282 Y42.8549 Z-3.0000 S1000
    G1 F1000 X33.7197 Y42.6489 Z-3.0000 S1000
    G1 F1000 X33.8038 Y42.4399 Z-3.0000 S1000
    G1 F1000 X33.8804 Y42.2279 Z-3.0000 S1000
    G1 F1000 X33.9495 Y42.0134 Z-3.0000 S1000
    G1 F1000 X34.0109 Y41.7965 Z-3.0000 S1000
    G1 F1000 X34.0646 Y41.5776 Z-3.0000 S1000
    G1 F1000 X34.1105 Y41.3570 Z-3.0000 S1000
    G1 F1000 X34.1485 Y41.1348 Z-3.0000 S1000
    G1 F1000 X34.1786 Y40.9115 Z-3.0000 S1000
    G1 F1000 X34.2008 Y40.6872 Z-3.0000 S1000
    G1 F1000 X34.2150 Y40.4622 Z-3.0000 S1000
    G1 F1000 X34.2212 Y40.2369 Z-3.0000 S1000
    G1 F1000 X34.2194 Y40.0116 Z-3.0000 S1000
    G1 F1000 X34.2096 Y39.7864 Z-3.0000 S1000
    G1 F1000 X34.1918 Y39.5617 Z-3.0000 S1000
    G1 F1000 X34.1661 Y39.3378 Z-3.0000 S1000
    G1 F1000 X34.1324 Y39.1150 Z-3.0000 S1000
    G1 F1000 X34.0909 Y38.8935 Z-3.0000 S1000
    G1 F1000 X34.0415 Y38.6736 Z-3.0000 S1000
    G1 F1000 X33.9843 Y38.4555 Z-3.0000 S1000
    G1 F1000 X33.9195 Y38.2397 Z-3.0000 S1000
    G1 F1000 X33.8470 Y38.0263 Z-3.0000 S1000
    G1 F1000 X33.7670 Y37.8156 Z-3.0000 S1000
    G1 F1000 X33.6795 Y37.6079 Z-3.0000 S1000
    G1 F1000 X33.5848 Y37.4034 Z-3.0000 S1000
    G1 F1000 X33.4828 Y37.2024 Z-3.0000 S1000
    G1 F1000 X33.3738 Y37.0051 Z-3.0000 S1000
    G1 F1000 X33.2579 Y36.8118 Z-3.0000 S1000
    G1 F1000 X33.1351 Y36.6228 Z-3.0000 S1000
    G1 F1000 X32.9545 Y36.3688 Z-3.0000 S1000
    G1 F1000 X31.4356 Y34.3403 Z-3.0000 S1000
    G1 F1000 X33.4642 Y35.8592 Z-3.0000 S1000
    G1 F1000 X33.6469 Y35.9911 Z-3.0000 S1000
    G1 F1000 X33.8343 Y36.1164 Z-3.0000 S1000
    G1 F1000 X34.0260 Y36.2350 Z-3.0000 S1000
    G1 F1000 X34.2217 Y36.3466 Z-3.0000 S1000
    G1 F1000 X34.4213 Y36.4513 Z-3.0000 S1000
    G1 F1000 X34.6245 Y36.5488 Z-3.0000 S1000
    G1 F1000 X34.8310 Y36.6391 Z-3.0000 S1000
    G1 F1000 X35.0406 Y36.7219 Z-3.0000 S1000
    G1 F1000 X35.2530 Y36.7973 Z-3.0000 S1000
    G1 F1000 X35.4680 Y36.8651 Z-3.0000 S1000
    G1 F1000 X35.6852 Y36.9252 Z-3.0000 S1000
    G1 F1000 X35.9044 Y36.9776 Z-3.0000 S1000
    G1 F1000 X36.1253 Y37.0222 Z-3.0000 S1000
    G1 F1000 X36.3477 Y37.0588 Z-3.0000 S1000
    G1 F1000 X36.5712 Y37.0876 Z-3.0000 S1000
    G1 F1000 X36.7956 Y37.1084 Z-3.0000 S1000
    G1 F1000 X37.0207 Y37.1213 Z-3.0000 S1000
    G1 F1000 X37.2460 Y37.1262 Z-3.0000 S1000
    G1 F1000 X37.4713 Y37.1230 Z-3.0000 S1000
    G1 F1000 X37.6964 Y37.1119 Z-3.0000 S1000
    G1 F1000 X37.9210 Y37.0928 Z-3.0000 S1000
    G1 F1000 X38.1448 Y37.0657 Z-3.0000 S1000
    G1 F1000 X38.3674 Y37.0307 Z-3.0000 S1000
    G1 F1000 X38.5887 Y36.9878 Z-3.0000 S1000
    G1 F1000 X38.6438 Y36.9751 Z-3.0000 S1000
    G1 F1000 X41.9909 Y44.1530 Z-3.0000 S1000
    G1 F1000 X41.9252 Y44.2082 Z-3.0000 S1000
    G1 F1000 X41.7579 Y44.3591 Z-3.0000 S1000
    G1 F1000 X41.5960 Y44.5159 Z-3.0000 S1000
    G1 F1000 X41.4397 Y44.6783 Z-3.0000 S1000
    G1 F1000 X41.2894 Y44.8462 Z-3.0000 S1000
    G1 F1000 X41.1585 Y45.0026 Z-3.0000 S1000
    G1 F1000 X39.7062 Y46.7963 Z-3.0000 S1000
    G1 F1000 X39.5675 Y46.9739 Z-3.0000 S1000
    G1 F1000 X39.4352 Y47.1564 Z-3.0000 S1000
    G1 F1000 X39.3095 Y47.3434 Z-3.0000 S1000
    G1 F1000 X39.1905 Y47.5348 Z-3.0000 S1000
    G1 F1000 X39.0783 Y47.7303 Z-3.0000 S1000
    G1 F1000 X38.9834 Y47.9094 Z-3.0000 S1000
    G1 F1000 X37.9359 Y49.9654 Z-3.0000 S1000
    G1 F1000 X37.8372 Y50.1680 Z-3.0000 S1000
    G1 F1000 X37.7457 Y50.3740 Z-3.0000 S1000
    G1 F1000 X37.6616 Y50.5831 Z-3.0000 S1000
    G1 F1000 X37.5849 Y50.7951 Z-3.0000 S1000
    G1 F1000 X37.5159 Y51.0096 Z-3.0000 S1000
    G1 F1000 X37.4602 Y51.2049 Z-3.0000 S1000
    G1 F1000 X36.8628 Y53.4349 Z-3.0000 S1000
    G1 F1000 X36.8083 Y53.6536 Z-3.0000 S1000
    G1 F1000 X36.7617 Y53.8741 Z-3.0000 S1000
    G1 F1000 X36.7229 Y54.0961 Z-3.0000 S1000
    G1 F1000 X36.6920 Y54.3194 Z-3.0000 S1000
    G1 F1000 X36.6690 Y54.5436 Z-3.0000 S1000
    G1 F1000 X36.6552 Y54.7452 Z-3.0000 S1000
    G1 F1000 X36.5342 Y57.0498 Z-3.0000 S1000
    G1 F1000 X36.5264 Y57.2750 Z-3.0000 S1000
    G1 F1000 X36.5266 Y57.5004 Z-3.0000 S1000
    G1 F1000 X36.5348 Y57.7256 Z-3.0000 S1000
    G1 F1000 X36.5509 Y57.9504 Z-3.0000 S1000
    G1 F1000 X36.5751 Y58.1745 Z-3.0000 S1000
    G1 F1000 X36.6037 Y58.3765 Z-3.0000 S1000
    G1 F1000 X36.9649 Y60.6560 Z-3.0000 S1000
    G1 F1000 X37.0042 Y60.8779 Z-3.0000 S1000
    G1 F1000 X37.0512 Y61.0983 Z-3.0000 S1000
    G1 F1000 X37.1061 Y61.3169 Z-3.0000 S1000
    G1 F1000 X37.1687 Y61.5335 Z-3.0000 S1000
    G1 F1000 X37.2389 Y61.7476 Z-3.0000 S1000
    G1 F1000 X37.3086 Y61.9381 Z-3.0000 S1000
    G1 F1000 X38.1357 Y64.0925 Z-3.0000 S1000
    G1 F1000 X38.2202 Y64.3014 Z-3.0000 S1000
    G1 F1000 X38.3120 Y64.5072 Z-3.0000 S1000
    G1 F1000 X38.4111 Y64.7097 Z-3.0000 S1000
    G1 F1000 X38.5174 Y64.9084 Z-3.0000 S1000
    G1 F1000 X38.6306 Y65.1033 Z-3.0000 S1000
    G1 F1000 X38.7386 Y65.2756 Z-3.0000 S1000
    G1 F1000 X39.9958 Y67.2111 Z-3.0000 S1000
    G1 F1000 X40.1219 Y67.3979 Z-3.0000 S1000
    G1 F1000 X40.2545 Y67.5801 Z-3.0000 S1000
    G1 F1000 X40.3936 Y67.7575 Z-3.0000 S1000
    G1 F1000 X40.5388 Y67.9298 Z-3.0000 S1000
    G1 F1000 X40.6901 Y68.0969 Z-3.0000 S1000
    G1 F1000 X40.8309 Y68.2422 Z-3.0000 S1000
    G1 F1000 X42.4625 Y69.8738 Z-3.0000 S1000
    G1 F1000 X42.6246 Y70.0303 Z-3.0000 S1000
    G1 F1000 X42.7923 Y70.1810 Z-3.0000 S1000
    G1 F1000 X42.9651 Y70.3256 Z-3.0000 S1000
    G1 F1000 X43.1430 Y70.4640 Z-3.0000 S1000
    G1 F1000 X43.3257 Y70.5960 Z-3.0000 S1000
    G1 F1000 X43.4936 Y70.7089 Z-3.0000 S1000
    G1 F1000 X45.4291 Y71.9661 Z-3.0000 S1000
    G1 F1000 X45.6203 Y72.0855 Z-3.0000 S1000
    G1 F1000 X45.8155 Y72.1980 Z-3.0000 S1000
    G1 F1000 X46.0147 Y72.3036 Z-3.0000 S1000
    G1 F1000 X46.2175 Y72.4020 Z-3.0000 S1000
    G1 F1000 X46.4236 Y72.4931 Z-3.0000 S1000
    G1 F1000 X46.6122 Y72.5690 Z-3.0000 S1000
    G1 F1000 X48.7666 Y73.3961 Z-3.0000 S1000
    G1 F1000 X48.9784 Y73.4732 Z-3.0000 S1000
    G1 F1000 X49.1928 Y73.5426 Z-3.0000 S1000
    G1 F1000 X49.4096 Y73.6045 Z-3.0000 S1000
    G1 F1000 X49.6284 Y73.6585 Z-3.0000 S1000
    G1 F1000 X49.8489 Y73.7048 Z-3.0000 S1000
    G1 F1000 X50.0487 Y73.7398 Z-3.0000 S1000
    G1 F1000 X52.3282 Y74.1010 Z-3.0000 S1000
    G1 F1000 X52.5514 Y74.1323 Z-3.0000 S1000
    G1 F1000 X52.7756 Y74.1556 Z-3.0000 S1000
    G1 F1000 X53.0004 Y74.1711 Z-3.0000 S1000
    G1 F1000 X53.2257 Y74.1785 Z-3.0000 S1000
    G1 F1000 X53.4511 Y74.1779 Z-3.0000 S1000
    G1 F1000 X53.6549 Y74.1705 Z-3.0000 S1000
    G1 F1000 X55.9595 Y74.0495 Z-3.0000 S1000
    G1 F1000 X56.1844 Y74.0337 Z-3.0000 S1000
    G1 F1000 X56.4085 Y74.0099 Z-3.0000 S1000
    G1 F1000 X56.6316 Y73.9782 Z-3.0000 S1000
    G1 F1000 X56.8535 Y73.9385 Z-3.0000 S1000
    G1 F1000 X57.0738 Y73.8911 Z-3.0000 S1000
    G1 F1000 X57.2698 Y73.8419 Z-3.0000 S1000
    G1 F1000 X59.4998 Y73.2445 Z-3.0000 S1000
    G1 F1000 X59.7164 Y73.1823 Z-3.0000 S1000
    G1 F1000 X59.9307 Y73.1125 Z-3.0000 S1000
    G1 F1000 X60.1424 Y73.0351 Z-3.0000 S1000
    G1 F1000 X60.3512 Y72.9503 Z-3.0000 S1000
    G1 F1000 X60.5568 Y72.8581 Z-3.0000 S1000
    G1 F1000 X60.7393 Y72.7688 Z-3.0000 S1000
    G1 F1000 X62.7953 Y71.7213 Z-3.0000 S1000
    G1 F1000 X62.9942 Y71.6154 Z-3.0000 S1000
    G1 F1000 X63.1893 Y71.5026 Z-3.0000 S1000
    G1 F1000 X63.3803 Y71.3829 Z-3.0000 S1000
    G1 F1000 X63.5669 Y71.2565 Z-3.0000 S1000
    G1 F1000 X63.7489 Y71.1235 Z-3.0000 S1000
    G1 F1000 X63.9084 Y70.9985 Z-3.0000 S1000
    G1 F1000 X65.7021 Y69.5462 Z-3.0000 S1000
    G1 F1000 X65.8748 Y69.4012 Z-3.0000 S1000
    G1 F1000 X66.0421 Y69.2503 Z-3.0000 S1000
    G1 F1000 X66.2040 Y69.0935 Z-3.0000 S1000
    G1 F1000 X66.3603 Y68.9311 Z-3.0000 S1000
    G1 F1000 X66.5106 Y68.7632 Z-3.0000 S1000
    G1 F1000 X66.6415 Y68.6068 Z-3.0000 S1000
    G1 F1000 X68.0938 Y66.8131 Z-3.0000 S1000
    G1 F1000 X68.2325 Y66.6355 Z-3.0000 S1000
    G1 F1000 X68.3648 Y66.4530 Z-3.0000 S1000
    G1 F1000 X68.4905 Y66.2660 Z-3.0000 S1000
    G1 F1000 X68.6095 Y66.0746 Z-3.0000 S1000
    G1 F1000 X68.7217 Y65.8791 Z-3.0000 S1000
    G1 F1000 X68.8166 Y65.7000 Z-3.0000 S1000
    G1 F1000 X69.8641 Y63.6440 Z-3.0000 S1000
    G1 F1000 X69.9628 Y63.4414 Z-3.0000 S1000
    G1 F1000 X70.0543 Y63.2354 Z-3.0000 S1000
    G1 F1000 X70.1384 Y63.0263 Z-3.0000 S1000
    G1 F1000 X70.2151 Y62.8143 Z-3.0000 S1000
    G1 F1000 X70.2841 Y62.5998 Z-3.0000 S1000
    G1 F1000 X70.3398 Y62.4045 Z-3.0000 S1000
    G1 F1000 X70.9372 Y60.1745 Z-3.0000 S1000
    G1 F1000 X70.9917 Y59.9558 Z-3.0000 S1000
    G1 F1000 X71.0383 Y59.7353 Z-3.0000 S1000
    G1 F1000 X71.0771 Y59.5133 Z-3.0000 S1000
    G1 F1000 X71.1080 Y59.2900 Z-3.0000 S1000
    G1 F1000 X71.1310 Y59.0658 Z-3.0000 S1000
    G1 F1000 X71.1448 Y58.8642 Z-3.0000 S1000
    G1 F1000 X71.2658 Y56.5596 Z-3.0000 S1000
    G1 F1000 X71.2736 Y56.3344 Z-3.0000 S1000
    G1 F1000 X71.2734 Y56.1090 Z-3.0000 S1000
    G1 F1000 X71.2652 Y55.8838 Z-3.0000 S1000
    G1 F1000 X71.2491 Y55.6590 Z-3.0000 S1000
    G1 F1000 X71.2249 Y55.4349 Z-3.0000 S1000
    G1 F1000 X71.1963 Y55.2329 Z-3.0000 S1000
    G1 F1000 X70.8351 Y52.9534 Z-3.0000 S1000
    G1 F1000 X70.7958 Y52.7315 Z-3.0000 S1000
    G1 F1000 X70.7488 Y52.5111 Z-3.0000 S1000
    G1 F1000 X70.6939 Y52.2925 Z-3.0000 S1000
    G1 F1000 X70.6313 Y52.0759 Z-3.0000 S1000
    G1 F1000 X70.5611 Y51.8618 Z-3.0000 S1000
    G1 F1000 X70.4914 Y51.6713 Z-3.0000 S1000
    G1 F1000 X69.6643 Y49.5169 Z-3.0000 S1000
    G1 F1000 X69.5798 Y49.3080 Z-3.0000 S1000
    G1 F1000 X69.4880 Y49.1022 Z-3.0000 S1000
    G1 F1000 X69.3889 Y48.8997 Z-3.0000 S1000
    G1 F1000 X69.2826 Y48.7010 Z-3.0000 S1000
    G1 F1000 X69.1694 Y48.5061 Z-3.0000 S1000
    G1 F1000 X69.0614 Y48.3338 Z-3.0000 S1000
    G1 F1000 X67.8042 Y46.3983 Z-3.0000 S1000
    G1 F1000 X67.6781 Y46.2115 Z-3.0000 S1000
    G1 F1000 X67.5455 Y46.0293 Z-3.0000 S1000
    G1 F1000 X67.4064 Y45.8519 Z-3.0000 S1000
    G1 F1000 X67.2612 Y45.6796 Z-3.0000 S1000
    G1 F1000 X67.1099 Y45.5125 Z-3.0000 S1000
    G1 F1000 X66.9691 Y45.3672 Z-3.0000 S1000
    G1 F1000 X66.4718 Y44.8699 Z-3.0000 S1000
    G0 Z7
    G0 X64.5633 Y45.2064
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X69.1120 Y35.4514 Z-1.0000 S1000
    G1 F1000 X69.2368 Y35.4857 Z-1.0000 S1000
    G1 F1000 X69.4269 Y35.5297 Z-1.0000 S1000
    G1 F1000 X69.6187 Y35.5659 Z-1.0000 S1000
    G1 F1000 X69.8118 Y35.5942 Z-1.0000 S1000
    G1 F1000 X70.0060 Y35.6146 Z-1.0000 S1000
    G1 F1000 X70.2007 Y35.6270 Z-1.0000 S1000
    G1 F1000 X70.3959 Y35.6314 Z-1.0000 S1000
    G1 F1000 X70.5910 Y35.6278 Z-1.0000 S1000
    G1 F1000 X70.7859 Y35.6162 Z-1.0000 S1000
    G1 F1000 X70.9801 Y35.5967 Z-1.0000 S1000
    G1 F1000 X71.1733 Y35.5691 Z-1.0000 S1000
    G1 F1000 X71.3652 Y35.5338 Z-1.0000 S1000
    G1 F1000 X71.5556 Y35.4905 Z-1.0000 S1000
    G1 F1000 X71.7440 Y35.4395 Z-1.0000 S1000
    G1 F1000 X71.9301 Y35.3809 Z-1.0000 S1000
    G1 F1000 X72.1137 Y35.3146 Z-1.0000 S1000
    G1 F1000 X72.2945 Y35.2409 Z-1.0000 S1000
    G1 F1000 X72.4720 Y35.1598 Z-1.0000 S1000
    G1 F1000 X72.6461 Y35.0716 Z-1.0000 S1000
    G1 F1000 X72.8164 Y34.9762 Z-1.0000 S1000
    G1 F1000 X72.9827 Y34.8740 Z-1.0000 S1000
    G1 F1000 X73.1446 Y34.7651 Z-1.0000 S1000
    G1 F1000 X73.2602 Y34.6812 Z-1.0000 S1000
    G1 F1000 X77.8264 Y31.2624 Z-1.0000 S1000
    G1 F1000 X79.4424 Y32.8783 Z-1.0000 S1000
    G1 F1000 X76.0235 Y37.4445 Z-1.0000 S1000
    G1 F1000 X75.9097 Y37.6031 Z-1.0000 S1000
    G1 F1000 X75.8026 Y37.7662 Z-1.0000 S1000
    G1 F1000 X75.7022 Y37.9336 Z-1.0000 S1000
    G1 F1000 X75.6087 Y38.1050 Z-1.0000 S1000
    G1 F1000 X75.5224 Y38.2800 Z-1.0000 S1000
    G1 F1000 X75.4433 Y38.4584 Z-1.0000 S1000
    G1 F1000 X75.3716 Y38.6400 Z-1.0000 S1000
    G1 F1000 X75.3073 Y38.8243 Z-1.0000 S1000
    G1 F1000 X75.2507 Y39.0111 Z-1.0000 S1000
    G1 F1000 X75.2018 Y39.2000 Z-1.0000 S1000
    G1 F1000 X75.1607 Y39.3908 Z-1.0000 S1000
    G1 F1000 X75.1274 Y39.5831 Z-1.0000 S1000
    G1 F1000 X75.1020 Y39.7767 Z-1.0000 S1000
    G1 F1000 X75.0846 Y39.9711 Z-1.0000 S1000
    G1 F1000 X75.0752 Y40.1660 Z-1.0000 S1000
    G1 F1000 X75.0737 Y40.3612 Z-1.0000 S1000
    G1 F1000 X75.0803 Y40.5563 Z-1.0000 S1000
    G1 F1000 X75.0948 Y40.7509 Z-1.0000 S1000
    G1 F1000 X75.1173 Y40.9448 Z-1.0000 S1000
    G1 F1000 X75.1477 Y41.1376 Z-1.0000 S1000
    G1 F1000 X75.1860 Y41.3290 Z-1.0000 S1000
    G1 F1000 X75.2321 Y41.5186 Z-1.0000 S1000
    G1 F1000 X75.2860 Y41.7062 Z-1.0000 S1000
    G1 F1000 X75.3475 Y41.8915 Z-1.0000 S1000
    G1 F1000 X75.4165 Y42.0741 Z-1.0000 S1000
    G1 F1000 X75.4929 Y42.2536 Z-1.0000 S1000
    G1 F1000 X75.5767 Y42.4299 Z-1.0000 S1000
    G1 F1000 X75.6676 Y42.6027 Z-1.0000 S1000
    G1 F1000 X75.7655 Y42.7715 Z-1.0000 S1000
    G1 F1000 X75.8414 Y42.8925 Z-1.0000 S1000
    G1 F1000 X77.1747 Y44.9460 Z-1.0000 S1000
    G1 F1000 X79.1320 Y50.0443 Z-1.0000 S1000
    G1 F1000 X79.2661 Y50.8905 Z-1.0000 S1000
    G1 F1000 X79.3006 Y51.0826 Z-1.0000 S1000
    G1 F1000 X79.3429 Y51.2731 Z-1.0000 S1000
    G1 F1000 X79.3930 Y51.4617 Z-1.0000 S1000
    G1 F1000 X79.4508 Y51.6482 Z-1.0000 S1000
    G1 F1000 X79.5162 Y51.8321 Z-1.0000 S1000
    G1 F1000 X79.5890 Y52.0132 Z-1.0000 S1000
    G1 F1000 X79.6692 Y52.1911 Z-1.0000 S1000
    G1 F1000 X79.7567 Y52.3656 Z-1.0000 S1000
    G1 F1000 X79.8512 Y52.5364 Z-1.0000 S1000
    G1 F1000 X79.9526 Y52.7031 Z-1.0000 S1000
    G1 F1000 X80.0608 Y52.8656 Z-1.0000 S1000
    G1 F1000 X80.1756 Y53.0235 Z-1.0000 S1000
    G1 F1000 X80.2967 Y53.1765 Z-1.0000 S1000
    G1 F1000 X80.4240 Y53.3245 Z-1.0000 S1000
    G1 F1000 X80.5572 Y53.4671 Z-1.0000 S1000
    G1 F1000 X80.6962 Y53.6041 Z-1.0000 S1000
    G1 F1000 X80.8407 Y53.7354 Z-1.0000 S1000
    G1 F1000 X80.9904 Y53.8606 Z-1.0000 S1000
    G1 F1000 X81.1452 Y53.9795 Z-1.0000 S1000
    G1 F1000 X81.3046 Y54.0921 Z-1.0000 S1000
    G1 F1000 X81.4686 Y54.1980 Z-1.0000 S1000
    G1 F1000 X81.6368 Y54.2970 Z-1.0000 S1000
    G1 F1000 X81.8088 Y54.3892 Z-1.0000 S1000
    G1 F1000 X81.9845 Y54.4741 Z-1.0000 S1000
    G1 F1000 X82.1636 Y54.5519 Z-1.0000 S1000
    G1 F1000 X82.3457 Y54.6222 Z-1.0000 S1000
    G1 F1000 X82.5305 Y54.6850 Z-1.0000 S1000
    G1 F1000 X82.7177 Y54.7401 Z-1.0000 S1000
    G1 F1000 X82.9070 Y54.7876 Z-1.0000 S1000
    G1 F1000 X83.0981 Y54.8272 Z-1.0000 S1000
    G1 F1000 X83.2926 Y54.8593 Z-1.0000 S1000
    G1 F1000 X88.8798 Y55.6621 Z-1.0000 S1000
    G1 F1000 X88.8798 Y57.9473 Z-1.0000 S1000
    G1 F1000 X83.2631 Y58.7541 Z-1.0000 S1000
    G1 F1000 X83.0705 Y58.7858 Z-1.0000 S1000
    G1 F1000 X82.8794 Y58.8254 Z-1.0000 S1000
    G1 F1000 X82.6900 Y58.8727 Z-1.0000 S1000
    G1 F1000 X82.5028 Y58.9278 Z-1.0000 S1000
    G1 F1000 X82.3180 Y58.9905 Z-1.0000 S1000
    G1 F1000 X82.1359 Y59.0608 Z-1.0000 S1000
    G1 F1000 X81.9568 Y59.1384 Z-1.0000 S1000
    G1 F1000 X81.7810 Y59.2233 Z-1.0000 S1000
    G1 F1000 X81.6089 Y59.3154 Z-1.0000 S1000
    G1 F1000 X81.4407 Y59.4144 Z-1.0000 S1000
    G1 F1000 X81.2767 Y59.5202 Z-1.0000 S1000
    G1 F1000 X81.1172 Y59.6327 Z-1.0000 S1000
    G1 F1000 X80.9624 Y59.7515 Z-1.0000 S1000
    G1 F1000 X80.8126 Y59.8767 Z-1.0000 S1000
    G1 F1000 X80.6681 Y60.0079 Z-1.0000 S1000
    G1 F1000 X80.5290 Y60.1448 Z-1.0000 S1000
    G1 F1000 X80.3957 Y60.2874 Z-1.0000 S1000
    G1 F1000 X80.2684 Y60.4353 Z-1.0000 S1000
    G1 F1000 X80.1472 Y60.5883 Z-1.0000 S1000
    G1 F1000 X80.0324 Y60.7462 Z-1.0000 S1000
    G1 F1000 X79.9241 Y60.9086 Z-1.0000 S1000
    G1 F1000 X79.8226 Y61.0753 Z-1.0000 S1000
    G1 F1000 X79.7280 Y61.2460 Z-1.0000 S1000
    G1 F1000 X79.6405 Y61.4205 Z-1.0000 S1000
    G1 F1000 X79.5602 Y61.5984 Z-1.0000 S1000
    G1 F1000 X79.4873 Y61.7794 Z-1.0000 S1000
    G1 F1000 X79.4218 Y61.9633 Z-1.0000 S1000
    G1 F1000 X79.3401 Y62.2356 Z-1.0000 S1000
    G1 F1000 X78.2870 Y66.1657 Z-1.0000 S1000
    G1 F1000 X75.6851 Y71.2725 Z-1.0000 S1000
    G1 F1000 X75.6000 Y71.4482 Z-1.0000 S1000
    G1 F1000 X75.5223 Y71.6272 Z-1.0000 S1000
    G1 F1000 X75.4519 Y71.8093 Z-1.0000 S1000
    G1 F1000 X75.3891 Y71.9941 Z-1.0000 S1000
    G1 F1000 X75.3339 Y72.1813 Z-1.0000 S1000
    G1 F1000 X75.2864 Y72.3706 Z-1.0000 S1000
    G1 F1000 X75.2467 Y72.5617 Z-1.0000 S1000
    G1 F1000 X75.2148 Y72.7543 Z-1.0000 S1000
    G1 F1000 X75.1909 Y72.9480 Z-1.0000 S1000
    G1 F1000 X75.1750 Y73.1425 Z-1.0000 S1000
    G1 F1000 X75.1670 Y73.3375 Z-1.0000 S1000
    G1 F1000 X75.1670 Y73.5327 Z-1.0000 S1000
    G1 F1000 X75.1750 Y73.7277 Z-1.0000 S1000
    G1 F1000 X75.1910 Y73.9223 Z-1.0000 S1000
    G1 F1000 X75.2150 Y74.1160 Z-1.0000 S1000
    G1 F1000 X75.2469 Y74.3085 Z-1.0000 S1000
    G1 F1000 X75.2866 Y74.4996 Z-1.0000 S1000
    G1 F1000 X75.3342 Y74.6889 Z-1.0000 S1000
    G1 F1000 X75.3894 Y74.8761 Z-1.0000 S1000
    G1 F1000 X75.4523 Y75.0609 Z-1.0000 S1000
    G1 F1000 X75.5227 Y75.2430 Z-1.0000 S1000
    G1 F1000 X75.6005 Y75.4220 Z-1.0000 S1000
    G1 F1000 X75.6855 Y75.5976 Z-1.0000 S1000
    G1 F1000 X75.7777 Y75.7697 Z-1.0000 S1000
    G1 F1000 X75.8769 Y75.9378 Z-1.0000 S1000
    G1 F1000 X75.9829 Y76.1017 Z-1.0000 S1000
    G1 F1000 X76.1162 Y76.2891 Z-1.0000 S1000
    G1 F1000 X79.4423 Y80.7312 Z-1.0000 S1000
    G1 F1000 X77.8265 Y82.3470 Z-1.0000 S1000
    G1 F1000 X73.3844 Y79.0209 Z-1.0000 S1000
    G1 F1000 X73.2258 Y78.9072 Z-1.0000 S1000
    G1 F1000 X73.0627 Y78.8000 Z-1.0000 S1000
    G1 F1000 X72.8953 Y78.6996 Z-1.0000 S1000
    G1 F1000 X72.7239 Y78.6062 Z-1.0000 S1000
    G1 F1000 X72.5489 Y78.5198 Z-1.0000 S1000
    G1 F1000 X72.3704 Y78.4407 Z-1.0000 S1000
    G1 F1000 X72.1889 Y78.3690 Z-1.0000 S1000
    G1 F1000 X72.0046 Y78.3048 Z-1.0000 S1000
    G1 F1000 X71.8178 Y78.2482 Z-1.0000 S1000
    G1 F1000 X71.6289 Y78.1992 Z-1.0000 S1000
    G1 F1000 X71.4381 Y78.1581 Z-1.0000 S1000
    G1 F1000 X71.2457 Y78.1248 Z-1.0000 S1000
    G1 F1000 X71.0522 Y78.0994 Z-1.0000 S1000
    G1 F1000 X70.8578 Y78.0820 Z-1.0000 S1000
    G1 F1000 X70.6629 Y78.0726 Z-1.0000 S1000
    G1 F1000 X70.4677 Y78.0711 Z-1.0000 S1000
    G1 F1000 X70.2726 Y78.0777 Z-1.0000 S1000
    G1 F1000 X70.0780 Y78.0922 Z-1.0000 S1000
    G1 F1000 X69.8841 Y78.1147 Z-1.0000 S1000
    G1 F1000 X69.6913 Y78.1451 Z-1.0000 S1000
    G1 F1000 X69.4999 Y78.1834 Z-1.0000 S1000
    G1 F1000 X69.3103 Y78.2295 Z-1.0000 S1000
    G1 F1000 X69.1226 Y78.2834 Z-1.0000 S1000
    G1 F1000 X68.9374 Y78.3448 Z-1.0000 S1000
    G1 F1000 X68.7548 Y78.4139 Z-1.0000 S1000
    G1 F1000 X68.5752 Y78.4903 Z-1.0000 S1000
    G1 F1000 X68.3678 Y78.5898 Z-1.0000 S1000
    G1 F1000 X63.2610 Y81.1917 Z-1.0000 S1000
    G1 F1000 X59.3309 Y82.2448 Z-1.0000 S1000
    G1 F1000 X59.1434 Y82.2991 Z-1.0000 S1000
    G1 F1000 X58.9584 Y82.3611 Z-1.0000 S1000
    G1 F1000 X58.7760 Y82.4307 Z-1.0000 S1000
    G1 F1000 X58.5966 Y82.5076 Z-1.0000 S1000
    G1 F1000 X58.4205 Y82.5919 Z-1.0000 S1000
    G1 F1000 X58.2481 Y82.6832 Z-1.0000 S1000
    G1 F1000 X58.0795 Y82.7816 Z-1.0000 S1000
    G1 F1000 X57.9151 Y82.8868 Z-1.0000 S1000
    G1 F1000 X57.7551 Y82.9986 Z-1.0000 S1000
    G1 F1000 X57.5999 Y83.1169 Z-1.0000 S1000
    G1 F1000 X57.4496 Y83.2415 Z-1.0000 S1000
    G1 F1000 X57.3046 Y83.3721 Z-1.0000 S1000
    G1 F1000 X57.1650 Y83.5086 Z-1.0000 S1000
    G1 F1000 X57.0312 Y83.6506 Z-1.0000 S1000
    G1 F1000 X56.9032 Y83.7980 Z-1.0000 S1000
    G1 F1000 X56.7815 Y83.9506 Z-1.0000 S1000
    G1 F1000 X56.6660 Y84.1080 Z-1.0000 S1000
    G1 F1000 X56.5572 Y84.2700 Z-1.0000 S1000
    G1 F1000 X56.4550 Y84.4363 Z-1.0000 S1000
    G1 F1000 X56.3598 Y84.6067 Z-1.0000 S1000
    G1 F1000 X56.2716 Y84.7808 Z-1.0000 S1000
    G1 F1000 X56.1906 Y84.9584 Z-1.0000 S1000
    G1 F1000 X56.1170 Y85.1391 Z-1.0000 S1000
    G1 F1000 X56.0508 Y85.3228 Z-1.0000 S1000
    G1 F1000 X55.9922 Y85.5089 Z-1.0000 S1000
    G1 F1000 X55.9413 Y85.6974 Z-1.0000 S1000
    G1 F1000 X55.8982 Y85.8877 Z-1.0000 S1000
    G1 F1000 X55.8494 Y86.1678 Z-1.0000 S1000
    G1 F1000 X55.0426 Y91.7845 Z-1.0000 S1000
    G1 F1000 X52.7574 Y91.7845 Z-1.0000 S1000
    G1 F1000 X51.9546 Y86.1973 Z-1.0000 S1000
    G1 F1000 X51.9229 Y86.0047 Z-1.0000 S1000
    G1 F1000 X51.8833 Y85.8136 Z-1.0000 S1000
    G1 F1000 X51.8359 Y85.6242 Z-1.0000 S1000
    G1 F1000 X51.7808 Y85.4370 Z-1.0000 S1000
    G1 F1000 X51.7181 Y85.2522 Z-1.0000 S1000
    G1 F1000 X51.6479 Y85.0701 Z-1.0000 S1000
    G1 F1000 X51.5702 Y84.8910 Z-1.0000 S1000
    G1 F1000 X51.4853 Y84.7152 Z-1.0000 S1000
    G1 F1000 X51.3933 Y84.5431 Z-1.0000 S1000
    G1 F1000 X51.2943 Y84.3749 Z-1.0000 S1000
    G1 F1000 X51.1884 Y84.2109 Z-1.0000 S1000
    G1 F1000 X51.0760 Y84.0514 Z-1.0000 S1000
    G1 F1000 X50.9571 Y83.8966 Z-1.0000 S1000
    G1 F1000 X50.8319 Y83.7468 Z-1.0000 S1000
    G1 F1000 X50.7008 Y83.6023 Z-1.0000 S1000
    G1 F1000 X50.5638 Y83.4633 Z-1.0000 S1000
    G1 F1000 X50.4212 Y83.3299 Z-1.0000 S1000
    G1 F1000 X50.2733 Y83.2026 Z-1.0000 S1000
    G1 F1000 X50.1203 Y83.0814 Z-1.0000 S1000
    G1 F1000 X49.9624 Y82.9666 Z-1.0000 S1000
    G1 F1000 X49.8000 Y82.8584 Z-1.0000 S1000
    G1 F1000 X49.6333 Y82.7569 Z-1.0000 S1000
    G1 F1000 X49.4626 Y82.6623 Z-1.0000 S1000
    G1 F1000 X49.2881 Y82.5748 Z-1.0000 S1000
    G1 F1000 X49.1102 Y82.4945 Z-1.0000 S1000
    G1 F1000 X48.9292 Y82.4215 Z-1.0000 S1000
    G1 F1000 X48.7453 Y82.3561 Z-1.0000 S1000
    G1 F1000 X48.5589 Y82.2982 Z-1.0000 S1000
    G1 F1000 X48.3703 Y82.2480 Z-1.0000 S1000
    G1 F1000 X48.1797 Y82.2056 Z-1.0000 S1000
    G1 F1000 X47.9858 Y82.1708 Z-1.0000 S1000
    G1 F1000 X47.1396 Y82.0367 Z-1.0000 S1000
    G1 F1000 X42.0413 Y80.0794 Z-1.0000 S1000
    G1 F1000 X39.9878 Y78.7461 Z-1.0000 S1000
    G1 F1000 X39.8219 Y78.6432 Z-1.0000 S1000
    G1 F1000 X39.6520 Y78.5472 Z-1.0000 S1000
    G1 F1000 X39.4783 Y78.4582 Z-1.0000 S1000
    G1 F1000 X39.3011 Y78.3764 Z-1.0000 S1000
    G1 F1000 X39.1206 Y78.3019 Z-1.0000 S1000
    G1 F1000 X38.9373 Y78.2349 Z-1.0000 S1000
    G1 F1000 X38.7514 Y78.1755 Z-1.0000 S1000
    G1 F1000 X38.5632 Y78.1237 Z-1.0000 S1000
    G1 F1000 X38.3731 Y78.0797 Z-1.0000 S1000
    G1 F1000 X38.1813 Y78.0435 Z-1.0000 S1000
    G1 F1000 X37.9882 Y78.0152 Z-1.0000 S1000
    G1 F1000 X37.7940 Y77.9948 Z-1.0000 S1000
    G1 F1000 X37.5993 Y77.9824 Z-1.0000 S1000
    G1 F1000 X37.4041 Y77.9780 Z-1.0000 S1000
    G1 F1000 X37.2090 Y77.9816 Z-1.0000 S1000
    G1 F1000 X37.0141 Y77.9932 Z-1.0000 S1000
    G1 F1000 X36.8199 Y78.0127 Z-1.0000 S1000
    G1 F1000 X36.6267 Y78.0403 Z-1.0000 S1000
    G1 F1000 X36.4348 Y78.0756 Z-1.0000 S1000
    G1 F1000 X36.2444 Y78.1189 Z-1.0000 S1000
    G1 F1000 X36.0560 Y78.1699 Z-1.0000 S1000
    G1 F1000 X35.8699 Y78.2285 Z-1.0000 S1000
    G1 F1000 X35.6863 Y78.2948 Z-1.0000 S1000
    G1 F1000 X35.5055 Y78.3685 Z-1.0000 S1000
    G1 F1000 X35.3280 Y78.4496 Z-1.0000 S1000
    G1 F1000 X35.1539 Y78.5378 Z-1.0000 S1000
    G1 F1000 X34.9836 Y78.6332 Z-1.0000 S1000
    G1 F1000 X34.8173 Y78.7354 Z-1.0000 S1000
    G1 F1000 X34.6554 Y78.8443 Z-1.0000 S1000
    G1 F1000 X34.5398 Y78.9282 Z-1.0000 S1000
    G1 F1000 X29.9736 Y82.3471 Z-1.0000 S1000
    G1 F1000 X28.3576 Y80.7311 Z-1.0000 S1000
    G1 F1000 X31.7765 Y76.1650 Z-1.0000 S1000
    G1 F1000 X31.8902 Y76.0064 Z-1.0000 S1000
    G1 F1000 X31.9974 Y75.8433 Z-1.0000 S1000
    G1 F1000 X32.0978 Y75.6759 Z-1.0000 S1000
    G1 F1000 X32.1912 Y75.5046 Z-1.0000 S1000
    G1 F1000 X32.2776 Y75.3295 Z-1.0000 S1000
    G1 F1000 X32.3567 Y75.1511 Z-1.0000 S1000
    G1 F1000 X32.4284 Y74.9696 Z-1.0000 S1000
    G1 F1000 X32.4926 Y74.7852 Z-1.0000 S1000
    G1 F1000 X32.5493 Y74.5985 Z-1.0000 S1000
    G1 F1000 X32.5982 Y74.4095 Z-1.0000 S1000
    G1 F1000 X32.6393 Y74.2187 Z-1.0000 S1000
    G1 F1000 X32.6726 Y74.0264 Z-1.0000 S1000
    G1 F1000 X32.6980 Y73.8329 Z-1.0000 S1000
    G1 F1000 X32.7154 Y73.6385 Z-1.0000 S1000
    G1 F1000 X32.7248 Y73.4435 Z-1.0000 S1000
    G1 F1000 X32.7263 Y73.2483 Z-1.0000 S1000
    G1 F1000 X32.7197 Y73.0533 Z-1.0000 S1000
    G1 F1000 X32.7052 Y72.8586 Z-1.0000 S1000
    G1 F1000 X32.6827 Y72.6647 Z-1.0000 S1000
    G1 F1000 X32.6523 Y72.4719 Z-1.0000 S1000
    G1 F1000 X32.6140 Y72.2806 Z-1.0000 S1000
    G1 F1000 X32.5679 Y72.0909 Z-1.0000 S1000
    G1 F1000 X32.5140 Y71.9033 Z-1.0000 S1000
    G1 F1000 X32.4525 Y71.7180 Z-1.0000 S1000
    G1 F1000 X32.3835 Y71.5355 Z-1.0000 S1000
    G1 F1000 X32.3071 Y71.3559 Z-1.0000 S1000
    G1 F1000 X32.2233 Y71.1796 Z-1.0000 S1000
    G1 F1000 X32.1324 Y71.0069 Z-1.0000 S1000
    G1 F1000 X32.0345 Y70.8380 Z-1.0000 S1000
    G1 F1000 X31.9586 Y70.7171 Z-1.0000 S1000
    G1 F1000 X30.6254 Y68.6637 Z-1.0000 S1000
    G1 F1000 X28.6680 Y63.5651 Z-1.0000 S1000
    G1 F1000 X28.5339 Y62.7189 Z-1.0000 S1000
    G1 F1000 X28.4994 Y62.5268 Z-1.0000 S1000
    G1 F1000 X28.4571 Y62.3363 Z-1.0000 S1000
    G1 F1000 X28.4070 Y62.1477 Z-1.0000 S1000
    G1 F1000 X28.3492 Y61.9612 Z-1.0000 S1000
    G1 F1000 X28.2838 Y61.7773 Z-1.0000 S1000
    G1 F1000 X28.2110 Y61.5962 Z-1.0000 S1000
    G1 F1000 X28.1308 Y61.4183 Z-1.0000 S1000
    G1 F1000 X28.0433 Y61.2438 Z-1.0000 S1000
    G1 F1000 X27.9488 Y61.0730 Z-1.0000 S1000
    G1 F1000 X27.8474 Y60.9063 Z-1.0000 S1000
    G1 F1000 X27.7392 Y60.7438 Z-1.0000 S1000
    G1 F1000 X27.6244 Y60.5859 Z-1.0000 S1000
    G1 F1000 X27.5033 Y60.4329 Z-1.0000 S1000
    G1 F1000 X27.3760 Y60.2849 Z-1.0000 S1000
    G1 F1000 X27.2428 Y60.1423 Z-1.0000 S1000
    G1 F1000 X27.1038 Y60.0053 Z-1.0000 S1000
    G1 F1000 X26.9593 Y59.8740 Z-1.0000 S1000
    G1 F1000 X26.8096 Y59.7488 Z-1.0000 S1000
    G1 F1000 X26.6548 Y59.6299 Z-1.0000 S1000
    G1 F1000 X26.4954 Y59.5173 Z-1.0000 S1000
    G1 F1000 X26.3314 Y59.4114 Z-1.0000 S1000
    G1 F1000 X26.1632 Y59.3124 Z-1.0000 S1000
    G1 F1000 X25.9912 Y59.2202 Z-1.0000 S1000
    G1 F1000 X25.8155 Y59.1353 Z-1.0000 S1000
    G1 F1000 X25.6364 Y59.0575 Z-1.0000 S1000
    G1 F1000 X25.4543 Y58.9872 Z-1.0000 S1000
    G1 F1000 X25.2695 Y58.9244 Z-1.0000 S1000
    G1 F1000 X25.0823 Y58.8693 Z-1.0000 S1000
    G1 F1000 X24.8930 Y58.8218 Z-1.0000 S1000
    G1 F1000 X24.7019 Y58.7822 Z-1.0000 S1000
    G1 F1000 X24.5074 Y58.7501 Z-1.0000 S1000
    G1 F1000 X18.9202 Y57.9473 Z-1.0000 S1000
    G1 F1000 X18.9202 Y55.6622 Z-1.0000 S1000
    G1 F1000 X24.5368 Y54.8554 Z-1.0000 S1000
    G1 F1000 X24.7294 Y54.8237 Z-1.0000 S1000
    G1 F1000 X24.9206 Y54.7841 Z-1.0000 S1000
    G1 F1000 X25.1099 Y54.7368 Z-1.0000 S1000
    G1 F1000 X25.2972 Y54.6817 Z-1.0000 S1000
    G1 F1000 X25.4820 Y54.6190 Z-1.0000 S1000
    G1 F1000 X25.6641 Y54.5487 Z-1.0000 S1000
    G1 F1000 X25.8432 Y54.4711 Z-1.0000 S1000
    G1 F1000 X26.0189 Y54.3862 Z-1.0000 S1000
    G1 F1000 X26.1910 Y54.2942 Z-1.0000 S1000
    G1 F1000 X26.3592 Y54.1952 Z-1.0000 S1000
    G1 F1000 X26.5232 Y54.0893 Z-1.0000 S1000
    G1 F1000 X26.6828 Y53.9769 Z-1.0000 S1000
    G1 F1000 X26.8376 Y53.8580 Z-1.0000 S1000
    G1 F1000 X26.9874 Y53.7328 Z-1.0000 S1000
    G1 F1000 X27.1319 Y53.6017 Z-1.0000 S1000
    G1 F1000 X27.2709 Y53.4647 Z-1.0000 S1000
    G1 F1000 X27.4042 Y53.3221 Z-1.0000 S1000
    G1 F1000 X27.5316 Y53.1742 Z-1.0000 S1000
    G1 F1000 X27.6528 Y53.0212 Z-1.0000 S1000
    G1 F1000 X27.7676 Y52.8634 Z-1.0000 S1000
    G1 F1000 X27.8759 Y52.7010 Z-1.0000 S1000
    G1 F1000 X27.9774 Y52.5343 Z-1.0000 S1000
    G1 F1000 X28.0720 Y52.3635 Z-1.0000 S1000
    G1 F1000 X28.1595 Y52.1891 Z-1.0000 S1000
    G1 F1000 X28.2398 Y52.0112 Z-1.0000 S1000
    G1 F1000 X28.3127 Y51.8301 Z-1.0000 S1000
    G1 F1000 X28.3782 Y51.6463 Z-1.0000 S1000
    G1 F1000 X28.4599 Y51.3739 Z-1.0000 S1000
    G1 F1000 X29.5129 Y47.4440 Z-1.0000 S1000
    G1 F1000 X32.1150 Y42.3368 Z-1.0000 S1000
    G1 F1000 X32.2000 Y42.1612 Z-1.0000 S1000
    G1 F1000 X32.2777 Y41.9821 Z-1.0000 S1000
    G1 F1000 X32.3481 Y41.8001 Z-1.0000 S1000
    G1 F1000 X32.4109 Y41.6153 Z-1.0000 S1000
    G1 F1000 X32.4661 Y41.4281 Z-1.0000 S1000
    G1 F1000 X32.5136 Y41.2387 Z-1.0000 S1000
    G1 F1000 X32.5533 Y41.0476 Z-1.0000 S1000
    G1 F1000 X32.5852 Y40.8551 Z-1.0000 S1000
    G1 F1000 X32.6091 Y40.6614 Z-1.0000 S1000
    G1 F1000 X32.6250 Y40.4668 Z-1.0000 S1000
    G1 F1000 X32.6330 Y40.2718 Z-1.0000 S1000
    G1 F1000 X32.6330 Y40.0766 Z-1.0000 S1000
    G1 F1000 X32.6250 Y39.8816 Z-1.0000 S1000
    G1 F1000 X32.6090 Y39.6871 Z-1.0000 S1000
    G1 F1000 X32.5850 Y39.4934 Z-1.0000 S1000
    G1 F1000 X32.5531 Y39.3008 Z-1.0000 S1000
    G1 F1000 X32.5134 Y39.1097 Z-1.0000 S1000
    G1 F1000 X32.4658 Y38.9204 Z-1.0000 S1000
    G1 F1000 X32.4106 Y38.7332 Z-1.0000 S1000
    G1 F1000 X32.3477 Y38.5485 Z-1.0000 S1000
    G1 F1000 X32.2773 Y38.3664 Z-1.0000 S1000
    G1 F1000 X32.1995 Y38.1874 Z-1.0000 S1000
    G1 F1000 X32.1144 Y38.0117 Z-1.0000 S1000
    G1 F1000 X32.0222 Y37.8397 Z-1.0000 S1000
    G1 F1000 X31.9231 Y37.6716 Z-1.0000 S1000
    G1 F1000 X31.8171 Y37.5077 Z-1.0000 S1000
    G1 F1000 X31.6838 Y37.3203 Z-1.0000 S1000
    G1 F1000 X28.3577 Y32.8782 Z-1.0000 S1000
    G1 F1000 X29.9735 Y31.2625 Z-1.0000 S1000
    G1 F1000 X34.4156 Y34.5885 Z-1.0000 S1000
    G1 F1000 X34.5742 Y34.7022 Z-1.0000 S1000
    G1 F1000 X34.7374 Y34.8094 Z-1.0000 S1000
    G1 F1000 X34.9048 Y34.9098 Z-1.0000 S1000
    G1 F1000 X35.0761 Y35.0032 Z-1.0000 S1000
    G1 F1000 X35.2512 Y35.0896 Z-1.0000 S1000
    G1 F1000 X35.4296 Y35.1687 Z-1.0000 S1000
    G1 F1000 X35.6111 Y35.2404 Z-1.0000 S1000
    G1 F1000 X35.7954 Y35.3046 Z-1.0000 S1000
    G1 F1000 X35.9822 Y35.3613 Z-1.0000 S1000
    G1 F1000 X36.1712 Y35.4102 Z-1.0000 S1000
    G1 F1000 X36.3620 Y35.4513 Z-1.0000 S1000
    G1 F1000 X36.5543 Y35.4846 Z-1.0000 S1000
    G1 F1000 X36.7478 Y35.5100 Z-1.0000 S1000
    G1 F1000 X36.9422 Y35.5274 Z-1.0000 S1000
    G1 F1000 X37.1372 Y35.5368 Z-1.0000 S1000
    G1 F1000 X37.3324 Y35.5383 Z-1.0000 S1000
    G1 F1000 X37.5274 Y35.5317 Z-1.0000 S1000
    G1 F1000 X37.7221 Y35.5172 Z-1.0000 S1000
    G1 F1000 X37.9159 Y35.4947 Z-1.0000 S1000
    G1 F1000 X38.1087 Y35.4643 Z-1.0000 S1000
    G1 F1000 X38.3001 Y35.4260 Z-1.0000 S1000
    G1 F1000 X38.4898 Y35.3799 Z-1.0000 S1000
    G1 F1000 X38.6774 Y35.3260 Z-1.0000 S1000
    G1 F1000 X38.8626 Y35.2645 Z-1.0000 S1000
    G1 F1000 X39.0452 Y35.1955 Z-1.0000 S1000
    G1 F1000 X39.2248 Y35.1191 Z-1.0000 S1000
    G1 F1000 X39.4323 Y35.0196 Z-1.0000 S1000
    G1 F1000 X39.4737 Y34.9985 Z-1.0000 S1000
    G1 F1000 X43.9528 Y44.6039 Z-1.0000 S1000
    G1 F1000 X43.0968 Y45.2970 Z-1.0000 S1000
    G1 F1000 X42.9477 Y45.4229 Z-1.0000 S1000
    G1 F1000 X42.8038 Y45.5548 Z-1.0000 S1000
    G1 F1000 X42.6655 Y45.6925 Z-1.0000 S1000
    G1 F1000 X42.5329 Y45.8358 Z-1.0000 S1000
    G1 F1000 X42.3923 Y46.0015 Z-1.0000 S1000
    G1 F1000 X40.9400 Y47.7952 Z-1.0000 S1000
    G1 F1000 X40.8203 Y47.9494 Z-1.0000 S1000
    G1 F1000 X40.7071 Y48.1084 Z-1.0000 S1000
    G1 F1000 X40.6004 Y48.2718 Z-1.0000 S1000
    G1 F1000 X40.5005 Y48.4395 Z-1.0000 S1000
    G1 F1000 X40.3979 Y48.6301 Z-1.0000 S1000
    G1 F1000 X39.3504 Y50.6861 Z-1.0000 S1000
    G1 F1000 X39.2654 Y50.8618 Z-1.0000 S1000
    G1 F1000 X39.1876 Y51.0408 Z-1.0000 S1000
    G1 F1000 X39.1173 Y51.2229 Z-1.0000 S1000
    G1 F1000 X39.0545 Y51.4077 Z-1.0000 S1000
    G1 F1000 X38.9936 Y51.6157 Z-1.0000 S1000
    G1 F1000 X38.3962 Y53.8457 Z-1.0000 S1000
    G1 F1000 X38.3496 Y54.0352 Z-1.0000 S1000
    G1 F1000 X38.3108 Y54.2265 Z-1.0000 S1000
    G1 F1000 X38.2798 Y54.4192 Z-1.0000 S1000
    G1 F1000 X38.2568 Y54.6131 Z-1.0000 S1000
    G1 F1000 X38.2406 Y54.8284 Z-1.0000 S1000
    G1 F1000 X38.1196 Y57.1330 Z-1.0000 S1000
    G1 F1000 X38.1133 Y57.3281 Z-1.0000 S1000
    G1 F1000 X38.1151 Y57.5233 Z-1.0000 S1000
    G1 F1000 X38.1248 Y57.7182 Z-1.0000 S1000
    G1 F1000 X38.1426 Y57.9126 Z-1.0000 S1000
    G1 F1000 X38.1717 Y58.1280 Z-1.0000 S1000
    G1 F1000 X38.5329 Y60.4075 Z-1.0000 S1000
    G1 F1000 X38.5674 Y60.5997 Z-1.0000 S1000
    G1 F1000 X38.6097 Y60.7902 Z-1.0000 S1000
    G1 F1000 X38.6598 Y60.9788 Z-1.0000 S1000
    G1 F1000 X38.7176 Y61.1653 Z-1.0000 S1000
    G1 F1000 X38.7906 Y61.3691 Z-1.0000 S1000
    G1 F1000 X39.6177 Y63.5235 Z-1.0000 S1000
    G1 F1000 X39.6914 Y63.7043 Z-1.0000 S1000
    G1 F1000 X39.7724 Y63.8818 Z-1.0000 S1000
    G1 F1000 X39.8606 Y64.0559 Z-1.0000 S1000
    G1 F1000 X39.9559 Y64.2263 Z-1.0000 S1000
    G1 F1000 X40.0699 Y64.4108 Z-1.0000 S1000
    G1 F1000 X41.3271 Y66.3463 Z-1.0000 S1000
    G1 F1000 X41.4367 Y66.5078 Z-1.0000 S1000
    G1 F1000 X41.5529 Y66.6646 Z-1.0000 S1000
    G1 F1000 X41.6754 Y66.8166 Z-1.0000 S1000
    G1 F1000 X41.8040 Y66.9634 Z-1.0000 S1000
    G1 F1000 X41.9534 Y67.1197 Z-1.0000 S1000
    G1 F1000 X43.5850 Y68.7513 Z-1.0000 S1000
    G1 F1000 X43.7258 Y68.8865 Z-1.0000 S1000
    G1 F1000 X43.8721 Y69.0157 Z-1.0000 S1000
    G1 F1000 X44.0235 Y69.1389 Z-1.0000 S1000
    G1 F1000 X44.1798 Y69.2558 Z-1.0000 S1000
    G1 F1000 X44.3584 Y69.3776 Z-1.0000 S1000
    G1 F1000 X46.2939 Y70.6348 Z-1.0000 S1000
    G1 F1000 X46.4597 Y70.7378 Z-1.0000 S1000
    G1 F1000 X46.6296 Y70.8338 Z-1.0000 S1000
    G1 F1000 X46.8033 Y70.9228 Z-1.0000 S1000
    G1 F1000 X46.9805 Y71.0047 Z-1.0000 S1000
    G1 F1000 X47.1812 Y71.0870 Z-1.0000 S1000
    G1 F1000 X49.3356 Y71.9141 Z-1.0000 S1000
    G1 F1000 X49.5192 Y71.9803 Z-1.0000 S1000
    G1 F1000 X49.7054 Y72.0389 Z-1.0000 S1000
    G1 F1000 X49.8938 Y72.0899 Z-1.0000 S1000
    G1 F1000 X50.0841 Y72.1331 Z-1.0000 S1000
    G1 F1000 X50.2972 Y72.1718 Z-1.0000 S1000
    G1 F1000 X52.5767 Y72.5330 Z-1.0000 S1000
    G1 F1000 X52.7700 Y72.5596 Z-1.0000 S1000
    G1 F1000 X52.9643 Y72.5782 Z-1.0000 S1000
    G1 F1000 X53.1592 Y72.5889 Z-1.0000 S1000
    G1 F1000 X53.3544 Y72.5916 Z-1.0000 S1000
    G1 F1000 X53.5717 Y72.5851 Z-1.0000 S1000
    G1 F1000 X55.8763 Y72.4641 Z-1.0000 S1000
    G1 F1000 X56.0710 Y72.4499 Z-1.0000 S1000
    G1 F1000 X56.2649 Y72.4277 Z-1.0000 S1000
    G1 F1000 X56.4577 Y72.3976 Z-1.0000 S1000
    G1 F1000 X56.6492 Y72.3596 Z-1.0000 S1000
    G1 F1000 X56.8590 Y72.3085 Z-1.0000 S1000
    G1 F1000 X59.0890 Y71.7111 Z-1.0000 S1000
    G1 F1000 X59.2764 Y71.6567 Z-1.0000 S1000
    G1 F1000 X59.4615 Y71.5947 Z-1.0000 S1000
    G1 F1000 X59.6439 Y71.5252 Z-1.0000 S1000
    G1 F1000 X59.8233 Y71.4483 Z-1.0000 S1000
    G1 F1000 X60.0186 Y71.3543 Z-1.0000 S1000
    G1 F1000 X62.0746 Y70.3068 Z-1.0000 S1000
    G1 F1000 X62.2467 Y70.2146 Z-1.0000 S1000
    G1 F1000 X62.4148 Y70.1155 Z-1.0000 S1000
    G1 F1000 X62.5787 Y70.0096 Z-1.0000 S1000
    G1 F1000 X62.7382 Y69.8970 Z-1.0000 S1000
    G1 F1000 X62.9095 Y69.7647 Z-1.0000 S1000
    G1 F1000 X64.7032 Y68.3124 Z-1.0000 S1000
    G1 F1000 X64.8523 Y68.1865 Z-1.0000 S1000
    G1 F1000 X64.9962 Y68.0546 Z-1.0000 S1000
    G1 F1000 X65.1345 Y67.9169 Z-1.0000 S1000
    G1 F1000 X65.2671 Y67.7736 Z-1.0000 S1000
    G1 F1000 X65.4077 Y67.6079 Z-1.0000 S1000
    G1 F1000 X66.8600 Y65.8142 Z-1.0000 S1000
    G1 F1000 X66.9797 Y65.6600 Z-1.0000 S1000
    G1 F1000 X67.0929 Y65.5010 Z-1.0000 S1000
    G1 F1000 X67.1996 Y65.3376 Z-1.0000 S1000
    G1 F1000 X67.2995 Y65.1699 Z-1.0000 S1000
    G1 F1000 X67.4021 Y64.9793 Z-1.0000 S1000
    G1 F1000 X68.4496 Y62.9233 Z-1.0000 S1000
    G1 F1000 X68.5346 Y62.7476 Z-1.0000 S1000
    G1 F1000 X68.6124 Y62.5686 Z-1.0000 S1000
    G1 F1000 X68.6827 Y62.3865 Z-1.0000 S1000
    G1 F1000 X68.7455 Y62.2017 Z-1.0000 S1000
    G1 F1000 X68.8064 Y61.9937 Z-1.0000 S1000
    G1 F1000 X69.4038 Y59.7637 Z-1.0000 S1000
    G1 F1000 X69.4504 Y59.5742 Z-1.0000 S1000
    G1 F1000 X69.4892 Y59.3829 Z-1.0000 S1000
    G1 F1000 X69.5202 Y59.1902 Z-1.0000 S1000
    G1 F1000 X69.5432 Y58.9963 Z-1.0000 S1000
    G1 F1000 X69.5594 Y58.7810 Z-1.0000 S1000
    G1 F1000 X69.6804 Y56.4764 Z-1.0000 S1000
    G1 F1000 X69.6867 Y56.2813 Z-1.0000 S1000
    G1 F1000 X69.6849 Y56.0861 Z-1.0000 S1000
    G1 F1000 X69.6752 Y55.8912 Z-1.0000 S1000
    G1 F1000 X69.6574 Y55.6968 Z-1.0000 S1000
    G1 F1000 X69.6283 Y55.4814 Z-1.0000 S1000
    G1 F1000 X69.2671 Y53.2019 Z-1.0000 S1000
    G1 F1000 X69.2326 Y53.0097 Z-1.0000 S1000
    G1 F1000 X69.1903 Y52.8192 Z-1.0000 S1000
    G1 F1000 X69.1402 Y52.6306 Z-1.0000 S1000
    G1 F1000 X69.0824 Y52.4441 Z-1.0000 S1000
    G1 F1000 X69.0094 Y52.2403 Z-1.0000 S1000
    G1 F1000 X68.1823 Y50.0859 Z-1.0000 S1000
    G1 F1000 X68.1086 Y49.9051 Z-1.0000 S1000
    G1 F1000 X68.0276 Y49.7276 Z-1.0000 S1000
    G1 F1000 X67.9394 Y49.5535 Z-1.0000 S1000
    G1 F1000 X67.8441 Y49.3831 Z-1.0000 S1000
    G1 F1000 X67.7301 Y49.1986 Z-1.0000 S1000
    G1 F1000 X66.4729 Y47.2631 Z-1.0000 S1000
    G1 F1000 X66.3633 Y47.1016 Z-1.0000 S1000
    G1 F1000 X66.2471 Y46.9448 Z-1.0000 S1000
    G1 F1000 X66.1246 Y46.7928 Z-1.0000 S1000
    G1 F1000 X65.9960 Y46.6460 Z-1.0000 S1000
    G1 F1000 X65.8466 Y46.4897 Z-1.0000 S1000
    G1 F1000 X64.5633 Y45.2064 Z-1.0000 S1000
    G1 F700 Z-2.0000
    G1 F1000 X69.1120 Y35.4514 Z-2.0000 S1000
    G1 F1000 X69.2368 Y35.4857 Z-2.0000 S1000
    G1 F1000 X69.4269 Y35.5297 Z-2.0000 S1000
    G1 F1000 X69.6187 Y35.5659 Z-2.0000 S1000
    G1 F1000 X69.8118 Y35.5942 Z-2.0000 S1000
    G1 F1000 X70.0060 Y35.6146 Z-2.0000 S1000
    G1 F1000 X70.2007 Y35.6270 Z-2.0000 S1000
    G1 F1000 X70.3959 Y35.6314 Z-2.0000 S1000
    G1 F1000 X70.5910 Y35.6278 Z-2.0000 S1000
    G1 F1000 X70.7859 Y35.6162 Z-2.0000 S1000
    G1 F1000 X70.9801 Y35.5967 Z-2.0000 S1000
    G1 F1000 X71.1733 Y35.5691 Z-2.0000 S1000
    G1 F1000 X71.3652 Y35.5338 Z-2.0000 S1000
    G1 F1000 X71.5556 Y35.4905 Z-2.0000 S1000
    G1 F1000 X71.7440 Y35.4395 Z-2.0000 S1000
    G1 F1000 X71.9301 Y35.3809 Z-2.0000 S1000
    G1 F1000 X72.1137 Y35.3146 Z-2.0000 S1000
    G1 F1000 X72.2945 Y35.2409 Z-2.0000 S1000
    G1 F1000 X72.4720 Y35.1598 Z-2.0000 S1000
    G1 F1000 X72.6461 Y35.0716 Z-2.0000 S1000
    G1 F1000 X72.8164 Y34.9762 Z-2.0000 S1000
    G1 F1000 X72.9827 Y34.8740 Z-2.0000 S1000
    G1 F1000 X73.1446 Y34.7651 Z-2.0000 S1000
    G1 F1000 X73.2602 Y34.6812 Z-2.0000 S1000
    G1 F1000 X77.8264 Y31.2624 Z-2.0000 S1000
    G1 F1000 X79.4424 Y32.8783 Z-2.0000 S1000
    G1 F1000 X76.0235 Y37.4445 Z-2.0000 S1000
    G1 F1000 X75.9097 Y37.6031 Z-2.0000 S1000
    G1 F1000 X75.8026 Y37.7662 Z-2.0000 S1000
    G1 F1000 X75.7022 Y37.9336 Z-2.0000 S1000
    G1 F1000 X75.6087 Y38.1050 Z-2.0000 S1000
    G1 F1000 X75.5224 Y38.2800 Z-2.0000 S1000
    G1 F1000 X75.4433 Y38.4584 Z-2.0000 S1000
    G1 F1000 X75.3716 Y38.6400 Z-2.0000 S1000
    G1 F1000 X75.3073 Y38.8243 Z-2.0000 S1000
    G1 F1000 X75.2507 Y39.0111 Z-2.0000 S1000
    G1 F1000 X75.2018 Y39.2000 Z-2.0000 S1000
    G1 F1000 X75.1607 Y39.3908 Z-2.0000 S1000
    G1 F1000 X75.1274 Y39.5831 Z-2.0000 S1000
    G1 F1000 X75.1020 Y39.7767 Z-2.0000 S1000
    G1 F1000 X75.0846 Y39.9711 Z-2.0000 S1000
    G1 F1000 X75.0752 Y40.1660 Z-2.0000 S1000
    G1 F1000 X75.0737 Y40.3612 Z-2.0000 S1000
    G1 F1000 X75.0803 Y40.5563 Z-2.0000 S1000
    G1 F1000 X75.0948 Y40.7509 Z-2.0000 S1000
    G1 F1000 X75.1173 Y40.9448 Z-2.0000 S1000
    G1 F1000 X75.1477 Y41.1376 Z-2.0000 S1000
    G1 F1000 X75.1860 Y41.3290 Z-2.0000 S1000
    G1 F1000 X75.2321 Y41.5186 Z-2.0000 S1000
    G1 F1000 X75.2860 Y41.7062 Z-2.0000 S1000
    G1 F1000 X75.3475 Y41.8915 Z-2.0000 S1000
    G1 F1000 X75.4165 Y42.0741 Z-2.0000 S1000
    G1 F1000 X75.4929 Y42.2536 Z-2.0000 S1000
    G1 F1000 X75.5767 Y42.4299 Z-2.0000 S1000
    G1 F1000 X75.6676 Y42.6027 Z-2.0000 S1000
    G1 F1000 X75.7655 Y42.7715 Z-2.0000 S1000
    G1 F1000 X75.8414 Y42.8925 Z-2.0000 S1000
    G1 F1000 X77.1747 Y44.9460 Z-2.0000 S1000
    G1 F1000 X79.1320 Y50.0443 Z-2.0000 S1000
    G1 F1000 X79.2661 Y50.8905 Z-2.0000 S1000
    G1 F1000 X79.3006 Y51.0826 Z-2.0000 S1000
    G1 F1000 X79.3429 Y51.2731 Z-2.0000 S1000
    G1 F1000 X79.3930 Y51.4617 Z-2.0000 S1000
    G1 F1000 X79.4508 Y51.6482 Z-2.0000 S1000
    G1 F1000 X79.5162 Y51.8321 Z-2.0000 S1000
    G1 F1000 X79.5890 Y52.0132 Z-2.0000 S1000
    G1 F1000 X79.6692 Y52.1911 Z-2.0000 S1000
    G1 F1000 X79.7567 Y52.3656 Z-2.0000 S1000
    G1 F1000 X79.8512 Y52.5364 Z-2.0000 S1000
    G1 F1000 X79.9526 Y52.7031 Z-2.0000 S1000
    G1 F1000 X80.0608 Y52.8656 Z-2.0000 S1000
    G1 F1000 X80.1756 Y53.0235 Z-2.0000 S1000
    G1 F1000 X80.2967 Y53.1765 Z-2.0000 S1000
    G1 F1000 X80.4240 Y53.3245 Z-2.0000 S1000
    G1 F1000 X80.5572 Y53.4671 Z-2.0000 S1000
    G1 F1000 X80.6962 Y53.6041 Z-2.0000 S1000
    G1 F1000 X80.8407 Y53.7354 Z-2.0000 S1000
    G1 F1000 X80.9904 Y53.8606 Z-2.0000 S1000
    G1 F1000 X81.1452 Y53.9795 Z-2.0000 S1000
    G1 F1000 X81.3046 Y54.0921 Z-2.0000 S1000
    G1 F1000 X81.4686 Y54.1980 Z-2.0000 S1000
    G1 F1000 X81.6368 Y54.2970 Z-2.0000 S1000
    G1 F1000 X81.8088 Y54.3892 Z-2.0000 S1000
    G1 F1000 X81.9845 Y54.4741 Z-2.0000 S1000
    G1 F1000 X82.1636 Y54.5519 Z-2.0000 S1000
    G1 F1000 X82.3457 Y54.6222 Z-2.0000 S1000
    G1 F1000 X82.5305 Y54.6850 Z-2.0000 S1000
    G1 F1000 X82.7177 Y54.7401 Z-2.0000 S1000
    G1 F1000 X82.9070 Y54.7876 Z-2.0000 S1000
    G1 F1000 X83.0981 Y54.8272 Z-2.0000 S1000
    G1 F1000 X83.2926 Y54.8593 Z-2.0000 S1000
    G1 F1000 X88.8798 Y55.6621 Z-2.0000 S1000
    G1 F1000 X88.8798 Y57.9473 Z-2.0000 S1000
    G1 F1000 X83.2631 Y58.7541 Z-2.0000 S1000
    G1 F1000 X83.0705 Y58.7858 Z-2.0000 S1000
    G1 F1000 X82.8794 Y58.8254 Z-2.0000 S1000
    G1 F1000 X82.6900 Y58.8727 Z-2.0000 S1000
    G1 F1000 X82.5028 Y58.9278 Z-2.0000 S1000
    G1 F1000 X82.3180 Y58.9905 Z-2.0000 S1000
    G1 F1000 X82.1359 Y59.0608 Z-2.0000 S1000
    G1 F1000 X81.9568 Y59.1384 Z-2.0000 S1000
    G1 F1000 X81.7810 Y59.2233 Z-2.0000 S1000
    G1 F1000 X81.6089 Y59.3154 Z-2.0000 S1000
    G1 F1000 X81.4407 Y59.4144 Z-2.0000 S1000
    G1 F1000 X81.2767 Y59.5202 Z-2.0000 S1000
    G1 F1000 X81.1172 Y59.6327 Z-2.0000 S1000
    G1 F1000 X80.9624 Y59.7515 Z-2.0000 S1000
    G1 F1000 X80.8126 Y59.8767 Z-2.0000 S1000
    G1 F1000 X80.6681 Y60.0079 Z-2.0000 S1000
    G1 F1000 X80.5290 Y60.1448 Z-2.0000 S1000
    G1 F1000 X80.3957 Y60.2874 Z-2.0000 S1000
    G1 F1000 X80.2684 Y60.4353 Z-2.0000 S1000
    G1 F1000 X80.1472 Y60.5883 Z-2.0000 S1000
    G1 F1000 X80.0324 Y60.7462 Z-2.0000 S1000
    G1 F1000 X79.9241 Y60.9086 Z-2.0000 S1000
    G1 F1000 X79.8226 Y61.0753 Z-2.0000 S1000
    G1 F1000 X79.7280 Y61.2460 Z-2.0000 S1000
    G1 F1000 X79.6405 Y61.4205 Z-2.0000 S1000
    G1 F1000 X79.5602 Y61.5984 Z-2.0000 S1000
    G1 F1000 X79.4873 Y61.7794 Z-2.0000 S1000
    G1 F1000 X79.4218 Y61.9633 Z-2.0000 S1000
    G1 F1000 X79.3401 Y62.2356 Z-2.0000 S1000
    G1 F1000 X78.2870 Y66.1657 Z-2.0000 S1000
    G1 F1000 X75.6851 Y71.2725 Z-2.0000 S1000
    G1 F1000 X75.6000 Y71.4482 Z-2.0000 S1000
    G1 F1000 X75.5223 Y71.6272 Z-2.0000 S1000
    G1 F1000 X75.4519 Y71.8093 Z-2.0000 S1000
    G1 F1000 X75.3891 Y71.9941 Z-2.0000 S1000
    G1 F1000 X75.3339 Y72.1813 Z-2.0000 S1000
    G1 F1000 X75.2864 Y72.3706 Z-2.0000 S1000
    G1 F1000 X75.2467 Y72.5617 Z-2.0000 S1000
    G1 F1000 X75.2148 Y72.7543 Z-2.0000 S1000
    G1 F1000 X75.1909 Y72.9480 Z-2.0000 S1000
    G1 F1000 X75.1750 Y73.1425 Z-2.0000 S1000
    G1 F1000 X75.1670 Y73.3375 Z-2.0000 S1000
    G1 F1000 X75.1670 Y73.5327 Z-2.0000 S1000
    G1 F1000 X75.1750 Y73.7277 Z-2.0000 S1000
    G1 F1000 X75.1910 Y73.9223 Z-2.0000 S1000
    G1 F1000 X75.2150 Y74.1160 Z-2.0000 S1000
    G1 F1000 X75.2469 Y74.3085 Z-2.0000 S1000
    G1 F1000 X75.2866 Y74.4996 Z-2.0000 S1000
    G1 F1000 X75.3342 Y74.6889 Z-2.0000 S1000
    G1 F1000 X75.3894 Y74.8761 Z-2.0000 S1000
    G1 F1000 X75.4523 Y75.0609 Z-2.0000 S1000
    G1 F1000 X75.5227 Y75.2430 Z-2.0000 S1000
    G1 F1000 X75.6005 Y75.4220 Z-2.0000 S1000
    G1 F1000 X75.6855 Y75.5976 Z-2.0000 S1000
    G1 F1000 X75.7777 Y75.7697 Z-2.0000 S1000
    G1 F1000 X75.8769 Y75.9378 Z-2.0000 S1000
    G1 F1000 X75.9829 Y76.1017 Z-2.0000 S1000
    G1 F1000 X76.1162 Y76.2891 Z-2.0000 S1000
    G1 F1000 X79.4423 Y80.7312 Z-2.0000 S1000
    G1 F1000 X77.8265 Y82.3470 Z-2.0000 S1000
    G1 F1000 X73.3844 Y79.0209 Z-2.0000 S1000
    G1 F1000 X73.2258 Y78.9072 Z-2.0000 S1000
    G1 F1000 X73.0627 Y78.8000 Z-2.0000 S1000
    G1 F1000 X72.8953 Y78.6996 Z-2.0000 S1000
    G1 F1000 X72.7239 Y78.6062 Z-2.0000 S1000
    G1 F1000 X72.5489 Y78.5198 Z-2.0000 S1000
    G1 F1000 X72.3704 Y78.4407 Z-2.0000 S1000
    G1 F1000 X72.1889 Y78.3690 Z-2.0000 S1000
    G1 F1000 X72.0046 Y78.3048 Z-2.0000 S1000
    G1 F1000 X71.8178 Y78.2482 Z-2.0000 S1000
    G1 F1000 X71.6289 Y78.1992 Z-2.0000 S1000
    G1 F1000 X71.4381 Y78.1581 Z-2.0000 S1000
    G1 F1000 X71.2457 Y78.1248 Z-2.0000 S1000
    G1 F1000 X71.0522 Y78.0994 Z-2.0000 S1000
    G1 F1000 X70.8578 Y78.0820 Z-2.0000 S1000
    G1 F1000 X70.6629 Y78.0726 Z-2.0000 S1000
    G1 F1000 X70.4677 Y78.0711 Z-2.0000 S1000
    G1 F1000 X70.2726 Y78.0777 Z-2.0000 S1000
    G1 F1000 X70.0780 Y78.0922 Z-2.0000 S1000
    G1 F1000 X69.8841 Y78.1147 Z-2.0000 S1000
    G1 F1000 X69.6913 Y78.1451 Z-2.0000 S1000
    G1 F1000 X69.4999 Y78.1834 Z-2.0000 S1000
    G1 F1000 X69.3103 Y78.2295 Z-2.0000 S1000
    G1 F1000 X69.1226 Y78.2834 Z-2.0000 S1000
    G1 F1000 X68.9374 Y78.3448 Z-2.0000 S1000
    G1 F1000 X68.7548 Y78.4139 Z-2.0000 S1000
    G1 F1000 X68.5752 Y78.4903 Z-2.0000 S1000
    G1 F1000 X68.3678 Y78.5898 Z-2.0000 S1000
    G1 F1000 X63.2610 Y81.1917 Z-2.0000 S1000
    G1 F1000 X59.3309 Y82.2448 Z-2.0000 S1000
    G1 F1000 X59.1434 Y82.2991 Z-2.0000 S1000
    G1 F1000 X58.9584 Y82.3611 Z-2.0000 S1000
    G1 F1000 X58.7760 Y82.4307 Z-2.0000 S1000
    G1 F1000 X58.5966 Y82.5076 Z-2.0000 S1000
    G1 F1000 X58.4205 Y82.5919 Z-2.0000 S1000
    G1 F1000 X58.2481 Y82.6832 Z-2.0000 S1000
    G1 F1000 X58.0795 Y82.7816 Z-2.0000 S1000
    G1 F1000 X57.9151 Y82.8868 Z-2.0000 S1000
    G1 F1000 X57.7551 Y82.9986 Z-2.0000 S1000
    G1 F1000 X57.5999 Y83.1169 Z-2.0000 S1000
    G1 F1000 X57.4496 Y83.2415 Z-2.0000 S1000
    G1 F1000 X57.3046 Y83.3721 Z-2.0000 S1000
    G1 F1000 X57.1650 Y83.5086 Z-2.0000 S1000
    G1 F1000 X57.0312 Y83.6506 Z-2.0000 S1000
    G1 F1000 X56.9032 Y83.7980 Z-2.0000 S1000
    G1 F1000 X56.7815 Y83.9506 Z-2.0000 S1000
    G1 F1000 X56.6660 Y84.1080 Z-2.0000 S1000
    G1 F1000 X56.5572 Y84.2700 Z-2.0000 S1000
    G1 F1000 X56.4550 Y84.4363 Z-2.0000 S1000
    G1 F1000 X56.3598 Y84.6067 Z-2.0000 S1000
    G1 F1000 X56.2716 Y84.7808 Z-2.0000 S1000
    G1 F1000 X56.1906 Y84.9584 Z-2.0000 S1000
    G1 F1000 X56.1170 Y85.1391 Z-2.0000 S1000
    G1 F1000 X56.0508 Y85.3228 Z-2.0000 S1000
    G1 F1000 X55.9922 Y85.5089 Z-2.0000 S1000
    G1 F1000 X55.9413 Y85.6974 Z-2.0000 S1000
    G1 F1000 X55.8982 Y85.8877 Z-2.0000 S1000
    G1 F1000 X55.8494 Y86.1678 Z-2.0000 S1000
    G1 F1000 X55.0426 Y91.7845 Z-2.0000 S1000
    G1 F1000 X52.7574 Y91.7845 Z-2.0000 S1000
    G1 F1000 X51.9546 Y86.1973 Z-2.0000 S1000
    G1 F1000 X51.9229 Y86.0047 Z-2.0000 S1000
    G1 F1000 X51.8833 Y85.8136 Z-2.0000 S1000
    G1 F1000 X51.8359 Y85.6242 Z-2.0000 S1000
    G1 F1000 X51.7808 Y85.4370 Z-2.0000 S1000
    G1 F1000 X51.7181 Y85.2522 Z-2.0000 S1000
    G1 F1000 X51.6479 Y85.0701 Z-2.0000 S1000
    G1 F1000 X51.5702 Y84.8910 Z-2.0000 S1000
    G1 F1000 X51.4853 Y84.7152 Z-2.0000 S1000
    G1 F1000 X51.3933 Y84.5431 Z-2.0000 S1000
    G1 F1000 X51.2943 Y84.3749 Z-2.0000 S1000
    G1 F1000 X51.1884 Y84.2109 Z-2.0000 S1000
    G1 F1000 X51.0760 Y84.0514 Z-2.0000 S1000
    G1 F1000 X50.9571 Y83.8966 Z-2.0000 S1000
    G1 F1000 X50.8319 Y83.7468 Z-2.0000 S1000
    G1 F1000 X50.7008 Y83.6023 Z-2.0000 S1000
    G1 F1000 X50.5638 Y83.4633 Z-2.0000 S1000
    G1 F1000 X50.4212 Y83.3299 Z-2.0000 S1000
    G1 F1000 X50.2733 Y83.2026 Z-2.0000 S1000
    G1 F1000 X50.1203 Y83.0814 Z-2.0000 S1000
    G1 F1000 X49.9624 Y82.9666 Z-2.0000 S1000
    G1 F1000 X49.8000 Y82.8584 Z-2.0000 S1000
    G1 F1000 X49.6333 Y82.7569 Z-2.0000 S1000
    G1 F1000 X49.4626 Y82.6623 Z-2.0000 S1000
    G1 F1000 X49.2881 Y82.5748 Z-2.0000 S1000
    G1 F1000 X49.1102 Y82.4945 Z-2.0000 S1000
    G1 F1000 X48.9292 Y82.4215 Z-2.0000 S1000
    G1 F1000 X48.7453 Y82.3561 Z-2.0000 S1000
    G1 F1000 X48.5589 Y82.2982 Z-2.0000 S1000
    G1 F1000 X48.3703 Y82.2480 Z-2.0000 S1000
    G1 F1000 X48.1797 Y82.2056 Z-2.0000 S1000
    G1 F1000 X47.9858 Y82.1708 Z-2.0000 S1000
    G1 F1000 X47.1396 Y82.0367 Z-2.0000 S1000
    G1 F1000 X42.0413 Y80.0794 Z-2.0000 S1000
    G1 F1000 X39.9878 Y78.7461 Z-2.0000 S1000
    G1 F1000 X39.8219 Y78.6432 Z-2.0000 S1000
    G1 F1000 X39.6520 Y78.5472 Z-2.0000 S1000
    G1 F1000 X39.4783 Y78.4582 Z-2.0000 S1000
    G1 F1000 X39.3011 Y78.3764 Z-2.0000 S1000
    G1 F1000 X39.1206 Y78.3019 Z-2.0000 S1000
    G1 F1000 X38.9373 Y78.2349 Z-2.0000 S1000
    G1 F1000 X38.7514 Y78.1755 Z-2.0000 S1000
    G1 F1000 X38.5632 Y78.1237 Z-2.0000 S1000
    G1 F1000 X38.3731 Y78.0797 Z-2.0000 S1000
    G1 F1000 X38.1813 Y78.0435 Z-2.0000 S1000
    G1 F1000 X37.9882 Y78.0152 Z-2.0000 S1000
    G1 F1000 X37.7940 Y77.9948 Z-2.0000 S1000
    G1 F1000 X37.5993 Y77.9824 Z-2.0000 S1000
    G1 F1000 X37.4041 Y77.9780 Z-2.0000 S1000
    G1 F1000 X37.2090 Y77.9816 Z-2.0000 S1000
    G1 F1000 X37.0141 Y77.9932 Z-2.0000 S1000
    G1 F1000 X36.8199 Y78.0127 Z-2.0000 S1000
    G1 F1000 X36.6267 Y78.0403 Z-2.0000 S1000
    G1 F1000 X36.4348 Y78.0756 Z-2.0000 S1000
    G1 F1000 X36.2444 Y78.1189 Z-2.0000 S1000
    G1 F1000 X36.0560 Y78.1699 Z-2.0000 S1000
    G1 F1000 X35.8699 Y78.2285 Z-2.0000 S1000
    G1 F1000 X35.6863 Y78.2948 Z-2.0000 S1000
    G1 F1000 X35.5055 Y78.3685 Z-2.0000 S1000
    G1 F1000 X35.3280 Y78.4496 Z-2.0000 S1000
    G1 F1000 X35.1539 Y78.5378 Z-2.0000 S1000
    G1 F1000 X34.9836 Y78.6332 Z-2.0000 S1000
    G1 F1000 X34.8173 Y78.7354 Z-2.0000 S1000
    G1 F1000 X34.6554 Y78.8443 Z-2.0000 S1000
    G1 F1000 X34.5398 Y78.9282 Z-2.0000 S1000
    G1 F1000 X29.9736 Y82.3471 Z-2.0000 S1000
    G1 F1000 X28.3576 Y80.7311 Z-2.0000 S1000
    G1 F1000 X31.7765 Y76.1650 Z-2.0000 S1000
    G1 F1000 X31.8902 Y76.0064 Z-2.0000 S1000
    G1 F1000 X31.9974 Y75.8433 Z-2.0000 S1000
    G1 F1000 X32.0978 Y75.6759 Z-2.0000 S1000
    G1 F1000 X32.1912 Y75.5046 Z-2.0000 S1000
    G1 F1000 X32.2776 Y75.3295 Z-2.0000 S1000
    G1 F1000 X32.3567 Y75.1511 Z-2.0000 S1000
    G1 F1000 X32.4284 Y74.9696 Z-2.0000 S1000
    G1 F1000 X32.4926 Y74.7852 Z-2.0000 S1000
    G1 F1000 X32.5493 Y74.5985 Z-2.0000 S1000
    G1 F1000 X32.5982 Y74.4095 Z-2.0000 S1000
    G1 F1000 X32.6393 Y74.2187 Z-2.0000 S1000
    G1 F1000 X32.6726 Y74.0264 Z-2.0000 S1000
    G1 F1000 X32.6980 Y73.8329 Z-2.0000 S1000
    G1 F1000 X32.7154 Y73.6385 Z-2.0000 S1000
    G1 F1000 X32.7248 Y73.4435 Z-2.0000 S1000
    G1 F1000 X32.7263 Y73.2483 Z-2.0000 S1000
    G1 F1000 X32.7197 Y73.0533 Z-2.0000 S1000
    G1 F1000 X32.7052 Y72.8586 Z-2.0000 S1000
    G1 F1000 X32.6827 Y72.6647 Z-2.0000 S1000
    G1 F1000 X32.6523 Y72.4719 Z-2.0000 S1000
    G1 F1000 X32.6140 Y72.2806 Z-2.0000 S1000
    G1 F1000 X32.5679 Y72.0909 Z-2.0000 S1000
    G1 F1000 X32.5140 Y71.9033 Z-2.0000 S1000
    G1 F1000 X32.4525 Y71.7180 Z-2.0000 S1000
    G1 F1000 X32.3835 Y71.5355 Z-2.0000 S1000
    G1 F1000 X32.3071 Y71.3559 Z-2.0000 S1000
    G1 F1000 X32.2233 Y71.1796 Z-2.0000 S1000
    G1 F1000 X32.1324 Y71.0069 Z-2.0000 S1000
    G1 F1000 X32.0345 Y70.8380 Z-2.0000 S1000
    G1 F1000 X31.9586 Y70.7171 Z-2.0000 S1000
    G1 F1000 X30.6254 Y68.6637 Z-2.0000 S1000
    G1 F1000 X28.6680 Y63.5651 Z-2.0000 S1000
    G1 F1000 X28.5339 Y62.7189 Z-2.0000 S1000
    G1 F1000 X28.4994 Y62.5268 Z-2.0000 S1000
    G1 F1000 X28.4571 Y62.3363 Z-2.0000 S1000
    G1 F1000 X28.4070 Y62.1477 Z-2.0000 S1000
    G1 F1000 X28.3492 Y61.9612 Z-2.0000 S1000
    G1 F1000 X28.2838 Y61.7773 Z-2.0000 S1000
    G1 F1000 X28.2110 Y61.5962 Z-2.0000 S1000
    G1 F1000 X28.1308 Y61.4183 Z-2.0000 S1000
    G1 F1000 X28.0433 Y61.2438 Z-2.0000 S1000
    G1 F1000 X27.9488 Y61.0730 Z-2.0000 S1000
    G1 F1000 X27.8474 Y60.9063 Z-2.0000 S1000
    G1 F1000 X27.7392 Y60.7438 Z-2.0000 S1000
    G1 F1000 X27.6244 Y60.5859 Z-2.0000 S1000
    G1 F1000 X27.5033 Y60.4329 Z-2.0000 S1000
    G1 F1000 X27.3760 Y60.2849 Z-2.0000 S1000
    G1 F1000 X27.2428 Y60.1423 Z-2.0000 S1000
    G1 F1000 X27.1038 Y60.0053 Z-2.0000 S1000
    G1 F1000 X26.9593 Y59.8740 Z-2.0000 S1000
    G1 F1000 X26.8096 Y59.7488 Z-2.0000 S1000
    G1 F1000 X26.6548 Y59.6299 Z-2.0000 S1000
    G1 F1000 X26.4954 Y59.5173 Z-2.0000 S1000
    G1 F1000 X26.3314 Y59.4114 Z-2.0000 S1000
    G1 F1000 X26.1632 Y59.3124 Z-2.0000 S1000
    G1 F1000 X25.9912 Y59.2202 Z-2.0000 S1000
    G1 F1000 X25.8155 Y59.1353 Z-2.0000 S1000
    G1 F1000 X25.6364 Y59.0575 Z-2.0000 S1000
    G1 F1000 X25.4543 Y58.9872 Z-2.0000 S1000
    G1 F1000 X25.2695 Y58.9244 Z-2.0000 S1000
    G1 F1000 X25.0823 Y58.8693 Z-2.0000 S1000
    G1 F1000 X24.8930 Y58.8218 Z-2.0000 S1000
    G1 F1000 X24.7019 Y58.7822 Z-2.0000 S1000
    G1 F1000 X24.5074 Y58.7501 Z-2.0000 S1000
    G1 F1000 X18.9202 Y57.9473 Z-2.0000 S1000
    G1 F1000 X18.9202 Y55.6622 Z-2.0000 S1000
    G1 F1000 X24.5368 Y54.8554 Z-2.0000 S1000
    G1 F1000 X24.7294 Y54.8237 Z-2.0000 S1000
    G1 F1000 X24.9206 Y54.7841 Z-2.0000 S1000
    G1 F1000 X25.1099 Y54.7368 Z-2.0000 S1000
    G1 F1000 X25.2972 Y54.6817 Z-2.0000 S1000
    G1 F1000 X25.4820 Y54.6190 Z-2.0000 S1000
    G1 F1000 X25.6641 Y54.5487 Z-2.0000 S1000
    G1 F1000 X25.8432 Y54.4711 Z-2.0000 S1000
    G1 F1000 X26.0189 Y54.3862 Z-2.0000 S1000
    G1 F1000 X26.1910 Y54.2942 Z-2.0000 S1000
    G1 F1000 X26.3592 Y54.1952 Z-2.0000 S1000
    G1 F1000 X26.5232 Y54.0893 Z-2.0000 S1000
    G1 F1000 X26.6828 Y53.9769 Z-2.0000 S1000
    G1 F1000 X26.8376 Y53.8580 Z-2.0000 S1000
    G1 F1000 X26.9874 Y53.7328 Z-2.0000 S1000
    G1 F1000 X27.1319 Y53.6017 Z-2.0000 S1000
    G1 F1000 X27.2709 Y53.4647 Z-2.0000 S1000
    G1 F1000 X27.4042 Y53.3221 Z-2.0000 S1000
    G1 F1000 X27.5316 Y53.1742 Z-2.0000 S1000
    G1 F1000 X27.6528 Y53.0212 Z-2.0000 S1000
    G1 F1000 X27.7676 Y52.8634 Z-2.0000 S1000
    G1 F1000 X27.8759 Y52.7010 Z-2.0000 S1000
    G1 F1000 X27.9774 Y52.5343 Z-2.0000 S1000
    G1 F1000 X28.0720 Y52.3635 Z-2.0000 S1000
    G1 F1000 X28.1595 Y52.1891 Z-2.0000 S1000
    G1 F1000 X28.2398 Y52.0112 Z-2.0000 S1000
    G1 F1000 X28.3127 Y51.8301 Z-2.0000 S1000
    G1 F1000 X28.3782 Y51.6463 Z-2.0000 S1000
    G1 F1000 X28.4599 Y51.3739 Z-2.0000 S1000
    G1 F1000 X29.5129 Y47.4440 Z-2.0000 S1000
    G1 F1000 X32.1150 Y42.3368 Z-2.0000 S1000
    G1 F1000 X32.2000 Y42.1612 Z-2.0000 S1000
    G1 F1000 X32.2777 Y41.9821 Z-2.0000 S1000
    G1 F1000 X32.3481 Y41.8001 Z-2.0000 S1000
    G1 F1000 X32.4109 Y41.6153 Z-2.0000 S1000
    G1 F1000 X32.4661 Y41.4281 Z-2.0000 S1000
    G1 F1000 X32.5136 Y41.2387 Z-2.0000 S1000
    G1 F1000 X32.5533 Y41.0476 Z-2.0000 S1000
    G1 F1000 X32.5852 Y40.8551 Z-2.0000 S1000
    G1 F1000 X32.6091 Y40.6614 Z-2.0000 S1000
    G1 F1000 X32.6250 Y40.4668 Z-2.0000 S1000
    G1 F1000 X32.6330 Y40.2718 Z-2.0000 S1000
    G1 F1000 X32.6330 Y40.0766 Z-2.0000 S1000
    G1 F1000 X32.6250 Y39.8816 Z-2.0000 S1000
    G1 F1000 X32.6090 Y39.6871 Z-2.0000 S1000
    G1 F1000 X32.5850 Y39.4934 Z-2.0000 S1000
    G1 F1000 X32.5531 Y39.3008 Z-2.0000 S1000
    G1 F1000 X32.5134 Y39.1097 Z-2.0000 S1000
    G1 F1000 X32.4658 Y38.9204 Z-2.0000 S1000
    G1 F1000 X32.4106 Y38.7332 Z-2.0000 S1000
    G1 F1000 X32.3477 Y38.5485 Z-2.0000 S1000
    G1 F1000 X32.2773 Y38.3664 Z-2.0000 S1000
    G1 F1000 X32.1995 Y38.1874 Z-2.0000 S1000
    G1 F1000 X32.1144 Y38.0117 Z-2.0000 S1000
    G1 F1000 X32.0222 Y37.8397 Z-2.0000 S1000
    G1 F1000 X31.9231 Y37.6716 Z-2.0000 S1000
    G1 F1000 X31.8171 Y37.5077 Z-2.0000 S1000
    G1 F1000 X31.6838 Y37.3203 Z-2.0000 S1000
    G1 F1000 X28.3577 Y32.8782 Z-2.0000 S1000
    G1 F1000 X29.9735 Y31.2625 Z-2.0000 S1000
    G1 F1000 X34.4156 Y34.5885 Z-2.0000 S1000
    G1 F1000 X34.5742 Y34.7022 Z-2.0000 S1000
    G1 F1000 X34.7374 Y34.8094 Z-2.0000 S1000
    G1 F1000 X34.9048 Y34.9098 Z-2.0000 S1000
    G1 F1000 X35.0761 Y35.0032 Z-2.0000 S1000
    G1 F1000 X35.2512 Y35.0896 Z-2.0000 S1000
    G1 F1000 X35.4296 Y35.1687 Z-2.0000 S1000
    G1 F1000 X35.6111 Y35.2404 Z-2.0000 S1000
    G1 F1000 X35.7954 Y35.3046 Z-2.0000 S1000
    G1 F1000 X35.9822 Y35.3613 Z-2.0000 S1000
    G1 F1000 X36.1712 Y35.4102 Z-2.0000 S1000
    G1 F1000 X36.3620 Y35.4513 Z-2.0000 S1000
    G1 F1000 X36.5543 Y35.4846 Z-2.0000 S1000
    G1 F1000 X36.7478 Y35.5100 Z-2.0000 S1000
    G1 F1000 X36.9422 Y35.5274 Z-2.0000 S1000
    G1 F1000 X37.1372 Y35.5368 Z-2.0000 S1000
    G1 F1000 X37.3324 Y35.5383 Z-2.0000 S1000
    G1 F1000 X37.5274 Y35.5317 Z-2.0000 S1000
    G1 F1000 X37.7221 Y35.5172 Z-2.0000 S1000
    G1 F1000 X37.9159 Y35.4947 Z-2.0000 S1000
    G1 F1000 X38.1087 Y35.4643 Z-2.0000 S1000
    G1 F1000 X38.3001 Y35.4260 Z-2.0000 S1000
    G1 F1000 X38.4898 Y35.3799 Z-2.0000 S1000
    G1 F1000 X38.6774 Y35.3260 Z-2.0000 S1000
    G1 F1000 X38.8626 Y35.2645 Z-2.0000 S1000
    G1 F1000 X39.0452 Y35.1955 Z-2.0000 S1000
    G1 F1000 X39.2248 Y35.1191 Z-2.0000 S1000
    G1 F1000 X39.4323 Y35.0196 Z-2.0000 S1000
    G1 F1000 X39.4737 Y34.9985 Z-2.0000 S1000
    G1 F1000 X43.9528 Y44.6039 Z-2.0000 S1000
    G1 F1000 X43.0968 Y45.2970 Z-2.0000 S1000
    G1 F1000 X42.9477 Y45.4229 Z-2.0000 S1000
    G1 F1000 X42.8038 Y45.5548 Z-2.0000 S1000
    G1 F1000 X42.6655 Y45.6925 Z-2.0000 S1000
    G1 F1000 X42.5329 Y45.8358 Z-2.0000 S1000
    G1 F1000 X42.3923 Y46.0015 Z-2.0000 S1000
    G1 F1000 X40.9400 Y47.7952 Z-2.0000 S1000
    G1 F1000 X40.8203 Y47.9494 Z-2.0000 S1000
    G1 F1000 X40.7071 Y48.1084 Z-2.0000 S1000
    G1 F1000 X40.6004 Y48.2718 Z-2.0000 S1000
    G1 F1000 X40.5005 Y48.4395 Z-2.0000 S1000
    G1 F1000 X40.3979 Y48.6301 Z-2.0000 S1000
    G1 F1000 X39.3504 Y50.6861 Z-2.0000 S1000
    G1 F1000 X39.2654 Y50.8618 Z-2.0000 S1000
    G1 F1000 X39.1876 Y51.0408 Z-2.0000 S1000
    G1 F1000 X39.1173 Y51.2229 Z-2.0000 S1000
    G1 F1000 X39.0545 Y51.4077 Z-2.0000 S1000
    G1 F1000 X38.9936 Y51.6157 Z-2.0000 S1000
    G1 F1000 X38.3962 Y53.8457 Z-2.0000 S1000
    G1 F1000 X38.3496 Y54.0352 Z-2.0000 S1000
    G1 F1000 X38.3108 Y54.2265 Z-2.0000 S1000
    G1 F1000 X38.2798 Y54.4192 Z-2.0000 S1000
    G1 F1000 X38.2568 Y54.6131 Z-2.0000 S1000
    G1 F1000 X38.2406 Y54.8284 Z-2.0000 S1000
    G1 F1000 X38.1196 Y57.1330 Z-2.0000 S1000
    G1 F1000 X38.1133 Y57.3281 Z-2.0000 S1000
    G1 F1000 X38.1151 Y57.5233 Z-2.0000 S1000
    G1 F1000 X38.1248 Y57.7182 Z-2.0000 S1000
    G1 F1000 X38.1426 Y57.9126 Z-2.0000 S1000
    G1 F1000 X38.1717 Y58.1280 Z-2.0000 S1000
    G1 F1000 X38.5329 Y60.4075 Z-2.0000 S1000
    G1 F1000 X38.5674 Y60.5997 Z-2.0000 S1000
    G1 F1000 X38.6097 Y60.7902 Z-2.0000 S1000
    G1 F1000 X38.6598 Y60.9788 Z-2.0000 S1000
    G1 F1000 X38.7176 Y61.1653 Z-2.0000 S1000
    G1 F1000 X38.7906 Y61.3691 Z-2.0000 S1000
    G1 F1000 X39.6177 Y63.5235 Z-2.0000 S1000
    G1 F1000 X39.6914 Y63.7043 Z-2.0000 S1000
    G1 F1000 X39.7724 Y63.8818 Z-2.0000 S1000
    G1 F1000 X39.8606 Y64.0559 Z-2.0000 S1000
    G1 F1000 X39.9559 Y64.2263 Z-2.0000 S1000
    G1 F1000 X40.0699 Y64.4108 Z-2.0000 S1000
    G1 F1000 X41.3271 Y66.3463 Z-2.0000 S1000
    G1 F1000 X41.4367 Y66.5078 Z-2.0000 S1000
    G1 F1000 X41.5529 Y66.6646 Z-2.0000 S1000
    G1 F1000 X41.6754 Y66.8166 Z-2.0000 S1000
    G1 F1000 X41.8040 Y66.9634 Z-2.0000 S1000
    G1 F1000 X41.9534 Y67.1197 Z-2.0000 S1000
    G1 F1000 X43.5850 Y68.7513 Z-2.0000 S1000
    G1 F1000 X43.7258 Y68.8865 Z-2.0000 S1000
    G1 F1000 X43.8721 Y69.0157 Z-2.0000 S1000
    G1 F1000 X44.0235 Y69.1389 Z-2.0000 S1000
    G1 F1000 X44.1798 Y69.2558 Z-2.0000 S1000
    G1 F1000 X44.3584 Y69.3776 Z-2.0000 S1000
    G1 F1000 X46.2939 Y70.6348 Z-2.0000 S1000
    G1 F1000 X46.4597 Y70.7378 Z-2.0000 S1000
    G1 F1000 X46.6296 Y70.8338 Z-2.0000 S1000
    G1 F1000 X46.8033 Y70.9228 Z-2.0000 S1000
    G1 F1000 X46.9805 Y71.0047 Z-2.0000 S1000
    G1 F1000 X47.1812 Y71.0870 Z-2.0000 S1000
    G1 F1000 X49.3356 Y71.9141 Z-2.0000 S1000
    G1 F1000 X49.5192 Y71.9803 Z-2.0000 S1000
    G1 F1000 X49.7054 Y72.0389 Z-2.0000 S1000
    G1 F1000 X49.8938 Y72.0899 Z-2.0000 S1000
    G1 F1000 X50.0841 Y72.1331 Z-2.0000 S1000
    G1 F1000 X50.2972 Y72.1718 Z-2.0000 S1000
    G1 F1000 X52.5767 Y72.5330 Z-2.0000 S1000
    G1 F1000 X52.7700 Y72.5596 Z-2.0000 S1000
    G1 F1000 X52.9643 Y72.5782 Z-2.0000 S1000
    G1 F1000 X53.1592 Y72.5889 Z-2.0000 S1000
    G1 F1000 X53.3544 Y72.5916 Z-2.0000 S1000
    G1 F1000 X53.5717 Y72.5851 Z-2.0000 S1000
    G1 F1000 X55.8763 Y72.4641 Z-2.0000 S1000
    G1 F1000 X56.0710 Y72.4499 Z-2.0000 S1000
    G1 F1000 X56.2649 Y72.4277 Z-2.0000 S1000
    G1 F1000 X56.4577 Y72.3976 Z-2.0000 S1000
    G1 F1000 X56.6492 Y72.3596 Z-2.0000 S1000
    G1 F1000 X56.8590 Y72.3085 Z-2.0000 S1000
    G1 F1000 X59.0890 Y71.7111 Z-2.0000 S1000
    G1 F1000 X59.2764 Y71.6567 Z-2.0000 S1000
    G1 F1000 X59.4615 Y71.5947 Z-2.0000 S1000
    G1 F1000 X59.6439 Y71.5252 Z-2.0000 S1000
    G1 F1000 X59.8233 Y71.4483 Z-2.0000 S1000
    G1 F1000 X60.0186 Y71.3543 Z-2.0000 S1000
    G1 F1000 X62.0746 Y70.3068 Z-2.0000 S1000
    G1 F1000 X62.2467 Y70.2146 Z-2.0000 S1000
    G1 F1000 X62.4148 Y70.1155 Z-2.0000 S1000
    G1 F1000 X62.5787 Y70.0096 Z-2.0000 S1000
    G1 F1000 X62.7382 Y69.8970 Z-2.0000 S1000
    G1 F1000 X62.9095 Y69.7647 Z-2.0000 S1000
    G1 F1000 X64.7032 Y68.3124 Z-2.0000 S1000
    G1 F1000 X64.8523 Y68.1865 Z-2.0000 S1000
    G1 F1000 X64.9962 Y68.0546 Z-2.0000 S1000
    G1 F1000 X65.1345 Y67.9169 Z-2.0000 S1000
    G1 F1000 X65.2671 Y67.7736 Z-2.0000 S1000
    G1 F1000 X65.4077 Y67.6079 Z-2.0000 S1000
    G1 F1000 X66.8600 Y65.8142 Z-2.0000 S1000
    G1 F1000 X66.9797 Y65.6600 Z-2.0000 S1000
    G1 F1000 X67.0929 Y65.5010 Z-2.0000 S1000
    G1 F1000 X67.1996 Y65.3376 Z-2.0000 S1000
    G1 F1000 X67.2995 Y65.1699 Z-2.0000 S1000
    G1 F1000 X67.4021 Y64.9793 Z-2.0000 S1000
    G1 F1000 X68.4496 Y62.9233 Z-2.0000 S1000
    G1 F1000 X68.5346 Y62.7476 Z-2.0000 S1000
    G1 F1000 X68.6124 Y62.5686 Z-2.0000 S1000
    G1 F1000 X68.6827 Y62.3865 Z-2.0000 S1000
    G1 F1000 X68.7455 Y62.2017 Z-2.0000 S1000
    G1 F1000 X68.8064 Y61.9937 Z-2.0000 S1000
    G1 F1000 X69.4038 Y59.7637 Z-2.0000 S1000
    G1 F1000 X69.4504 Y59.5742 Z-2.0000 S1000
    G1 F1000 X69.4892 Y59.3829 Z-2.0000 S1000
    G1 F1000 X69.5202 Y59.1902 Z-2.0000 S1000
    G1 F1000 X69.5432 Y58.9963 Z-2.0000 S1000
    G1 F1000 X69.5594 Y58.7810 Z-2.0000 S1000
    G1 F1000 X69.6804 Y56.4764 Z-2.0000 S1000
    G1 F1000 X69.6867 Y56.2813 Z-2.0000 S1000
    G1 F1000 X69.6849 Y56.0861 Z-2.0000 S1000
    G1 F1000 X69.6752 Y55.8912 Z-2.0000 S1000
    G1 F1000 X69.6574 Y55.6968 Z-2.0000 S1000
    G1 F1000 X69.6283 Y55.4814 Z-2.0000 S1000
    G1 F1000 X69.2671 Y53.2019 Z-2.0000 S1000
    G1 F1000 X69.2326 Y53.0097 Z-2.0000 S1000
    G1 F1000 X69.1903 Y52.8192 Z-2.0000 S1000
    G1 F1000 X69.1402 Y52.6306 Z-2.0000 S1000
    G1 F1000 X69.0824 Y52.4441 Z-2.0000 S1000
    G1 F1000 X69.0094 Y52.2403 Z-2.0000 S1000
    G1 F1000 X68.1823 Y50.0859 Z-2.0000 S1000
    G1 F1000 X68.1086 Y49.9051 Z-2.0000 S1000
    G1 F1000 X68.0276 Y49.7276 Z-2.0000 S1000
    G1 F1000 X67.9394 Y49.5535 Z-2.0000 S1000
    G1 F1000 X67.8441 Y49.3831 Z-2.0000 S1000
    G1 F1000 X67.7301 Y49.1986 Z-2.0000 S1000
    G1 F1000 X66.4729 Y47.2631 Z-2.0000 S1000
    G1 F1000 X66.3633 Y47.1016 Z-2.0000 S1000
    G1 F1000 X66.2471 Y46.9448 Z-2.0000 S1000
    G1 F1000 X66.1246 Y46.7928 Z-2.0000 S1000
    G1 F1000 X65.9960 Y46.6460 Z-2.0000 S1000
    G1 F1000 X65.8466 Y46.4897 Z-2.0000 S1000
    G1 F1000 X64.5633 Y45.2064 Z-2.0000 S1000
    G1 F700 Z-3.0000
    G1 F1000 X69.1120 Y35.4514 Z-3.0000 S1000
    G1 F1000 X69.2368 Y35.4857 Z-3.0000 S1000
    G1 F1000 X69.4269 Y35.5297 Z-3.0000 S1000
    G1 F1000 X69.6187 Y35.5659 Z-3.0000 S1000
    G1 F1000 X69.8118 Y35.5942 Z-3.0000 S1000
    G1 F1000 X70.0060 Y35.6146 Z-3.0000 S1000
    G1 F1000 X70.2007 Y35.6270 Z-3.0000 S1000
    G1 F1000 X70.3959 Y35.6314 Z-3.0000 S1000
    G1 F1000 X70.5910 Y35.6278 Z-3.0000 S1000
    G1 F1000 X70.7859 Y35.6162 Z-3.0000 S1000
    G1 F1000 X70.9801 Y35.5967 Z-3.0000 S1000
    G1 F1000 X71.1733 Y35.5691 Z-3.0000 S1000
    G1 F1000 X71.3652 Y35.5338 Z-3.0000 S1000
    G1 F1000 X71.5556 Y35.4905 Z-3.0000 S1000
    G1 F1000 X71.7440 Y35.4395 Z-3.0000 S1000
    G1 F1000 X71.9301 Y35.3809 Z-3.0000 S1000
    G1 F1000 X72.1137 Y35.3146 Z-3.0000 S1000
    G1 F1000 X72.2945 Y35.2409 Z-3.0000 S1000
    G1 F1000 X72.4720 Y35.1598 Z-3.0000 S1000
    G1 F1000 X72.6461 Y35.0716 Z-3.0000 S1000
    G1 F1000 X72.8164 Y34.9762 Z-3.0000 S1000
    G1 F1000 X72.9827 Y34.8740 Z-3.0000 S1000
    G1 F1000 X73.1446 Y34.7651 Z-3.0000 S1000
    G1 F1000 X73.2602 Y34.6812 Z-3.0000 S1000
    G1 F1000 X77.8264 Y31.2624 Z-3.0000 S1000
    G1 F1000 X79.4424 Y32.8783 Z-3.0000 S1000
    G1 F1000 X76.0235 Y37.4445 Z-3.0000 S1000
    G1 F1000 X75.9097 Y37.6031 Z-3.0000 S1000
    G1 F1000 X75.8026 Y37.7662 Z-3.0000 S1000
    G1 F1000 X75.7022 Y37.9336 Z-3.0000 S1000
    G1 F1000 X75.6087 Y38.1050 Z-3.0000 S1000
    G1 F1000 X75.5224 Y38.2800 Z-3.0000 S1000
    G1 F1000 X75.4433 Y38.4584 Z-3.0000 S1000
    G1 F1000 X75.3716 Y38.6400 Z-3.0000 S1000
    G1 F1000 X75.3073 Y38.8243 Z-3.0000 S1000
    G1 F1000 X75.2507 Y39.0111 Z-3.0000 S1000
    G1 F1000 X75.2018 Y39.2000 Z-3.0000 S1000
    G1 F1000 X75.1607 Y39.3908 Z-3.0000 S1000
    G1 F1000 X75.1274 Y39.5831 Z-3.0000 S1000
    G1 F1000 X75.1020 Y39.7767 Z-3.0000 S1000
    G1 F1000 X75.0846 Y39.9711 Z-3.0000 S1000
    G1 F1000 X75.0752 Y40.1660 Z-3.0000 S1000
    G1 F1000 X75.0737 Y40.3612 Z-3.0000 S1000
    G1 F1000 X75.0803 Y40.5563 Z-3.0000 S1000
    G1 F1000 X75.0948 Y40.7509 Z-3.0000 S1000
    G1 F1000 X75.1173 Y40.9448 Z-3.0000 S1000
    G1 F1000 X75.1477 Y41.1376 Z-3.0000 S1000
    G1 F1000 X75.1860 Y41.3290 Z-3.0000 S1000
    G1 F1000 X75.2321 Y41.5186 Z-3.0000 S1000
    G1 F1000 X75.2860 Y41.7062 Z-3.0000 S1000
    G1 F1000 X75.3475 Y41.8915 Z-3.0000 S1000
    G1 F1000 X75.4165 Y42.0741 Z-3.0000 S1000
    G1 F1000 X75.4929 Y42.2536 Z-3.0000 S1000
    G1 F1000 X75.5767 Y42.4299 Z-3.0000 S1000
    G1 F1000 X75.6676 Y42.6027 Z-3.0000 S1000
    G1 F1000 X75.7655 Y42.7715 Z-3.0000 S1000
    G1 F1000 X75.8414 Y42.8925 Z-3.0000 S1000
    G1 F1000 X77.1747 Y44.9460 Z-3.0000 S1000
    G1 F1000 X79.1320 Y50.0443 Z-3.0000 S1000
    G1 F1000 X79.2661 Y50.8905 Z-3.0000 S1000
    G1 F1000 X79.3006 Y51.0826 Z-3.0000 S1000
    G1 F1000 X79.3429 Y51.2731 Z-3.0000 S1000
    G1 F1000 X79.3930 Y51.4617 Z-3.0000 S1000
    G1 F1000 X79.4508 Y51.6482 Z-3.0000 S1000
    G1 F1000 X79.5162 Y51.8321 Z-3.0000 S1000
    G1 F1000 X79.5890 Y52.0132 Z-3.0000 S1000
    G1 F1000 X79.6692 Y52.1911 Z-3.0000 S1000
    G1 F1000 X79.7567 Y52.3656 Z-3.0000 S1000
    G1 F1000 X79.8512 Y52.5364 Z-3.0000 S1000
    G1 F1000 X79.9526 Y52.7031 Z-3.0000 S1000
    G1 F1000 X80.0608 Y52.8656 Z-3.0000 S1000
    G1 F1000 X80.1756 Y53.0235 Z-3.0000 S1000
    G1 F1000 X80.2967 Y53.1765 Z-3.0000 S1000
    G1 F1000 X80.4240 Y53.3245 Z-3.0000 S1000
    G1 F1000 X80.5572 Y53.4671 Z-3.0000 S1000
    G1 F1000 X80.6962 Y53.6041 Z-3.0000 S1000
    G1 F1000 X80.8407 Y53.7354 Z-3.0000 S1000
    G1 F1000 X80.9904 Y53.8606 Z-3.0000 S1000
    G1 F1000 X81.1452 Y53.9795 Z-3.0000 S1000
    G1 F1000 X81.3046 Y54.0921 Z-3.0000 S1000
    G1 F1000 X81.4686 Y54.1980 Z-3.0000 S1000
    G1 F1000 X81.6368 Y54.2970 Z-3.0000 S1000
    G1 F1000 X81.8088 Y54.3892 Z-3.0000 S1000
    G1 F1000 X81.9845 Y54.4741 Z-3.0000 S1000
    G1 F1000 X82.1636 Y54.5519 Z-3.0000 S1000
    G1 F1000 X82.3457 Y54.6222 Z-3.0000 S1000
    G1 F1000 X82.5305 Y54.6850 Z-3.0000 S1000
    G1 F1000 X82.7177 Y54.7401 Z-3.0000 S1000
    G1 F1000 X82.9070 Y54.7876 Z-3.0000 S1000
    G1 F1000 X83.0981 Y54.8272 Z-3.0000 S1000
    G1 F1000 X83.2926 Y54.8593 Z-3.0000 S1000
    G1 F1000 X88.8798 Y55.6621 Z-3.0000 S1000
    G1 F1000 X88.8798 Y57.9473 Z-3.0000 S1000
    G1 F1000 X83.2631 Y58.7541 Z-3.0000 S1000
    G1 F1000 X83.0705 Y58.7858 Z-3.0000 S1000
    G1 F1000 X82.8794 Y58.8254 Z-3.0000 S1000
    G1 F1000 X82.6900 Y58.8727 Z-3.0000 S1000
    G1 F1000 X82.5028 Y58.9278 Z-3.0000 S1000
    G1 F1000 X82.3180 Y58.9905 Z-3.0000 S1000
    G1 F1000 X82.1359 Y59.0608 Z-3.0000 S1000
    G1 F1000 X81.9568 Y59.1384 Z-3.0000 S1000
    G1 F1000 X81.7810 Y59.2233 Z-3.0000 S1000
    G1 F1000 X81.6089 Y59.3154 Z-3.0000 S1000
    G1 F1000 X81.4407 Y59.4144 Z-3.0000 S1000
    G1 F1000 X81.2767 Y59.5202 Z-3.0000 S1000
    G1 F1000 X81.1172 Y59.6327 Z-3.0000 S1000
    G1 F1000 X80.9624 Y59.7515 Z-3.0000 S1000
    G1 F1000 X80.8126 Y59.8767 Z-3.0000 S1000
    G1 F1000 X80.6681 Y60.0079 Z-3.0000 S1000
    G1 F1000 X80.5290 Y60.1448 Z-3.0000 S1000
    G1 F1000 X80.3957 Y60.2874 Z-3.0000 S1000
    G1 F1000 X80.2684 Y60.4353 Z-3.0000 S1000
    G1 F1000 X80.1472 Y60.5883 Z-3.0000 S1000
    G1 F1000 X80.0324 Y60.7462 Z-3.0000 S1000
    G1 F1000 X79.9241 Y60.9086 Z-3.0000 S1000
    G1 F1000 X79.8226 Y61.0753 Z-3.0000 S1000
    G1 F1000 X79.7280 Y61.2460 Z-3.0000 S1000
    G1 F1000 X79.6405 Y61.4205 Z-3.0000 S1000
    G1 F1000 X79.5602 Y61.5984 Z-3.0000 S1000
    G1 F1000 X79.4873 Y61.7794 Z-3.0000 S1000
    G1 F1000 X79.4218 Y61.9633 Z-3.0000 S1000
    G1 F1000 X79.3401 Y62.2356 Z-3.0000 S1000
    G1 F1000 X78.2870 Y66.1657 Z-3.0000 S1000
    G1 F1000 X75.6851 Y71.2725 Z-3.0000 S1000
    G1 F1000 X75.6000 Y71.4482 Z-3.0000 S1000
    G1 F1000 X75.5223 Y71.6272 Z-3.0000 S1000
    G1 F1000 X75.4519 Y71.8093 Z-3.0000 S1000
    G1 F1000 X75.3891 Y71.9941 Z-3.0000 S1000
    G1 F1000 X75.3339 Y72.1813 Z-3.0000 S1000
    G1 F1000 X75.2864 Y72.3706 Z-3.0000 S1000
    G1 F1000 X75.2467 Y72.5617 Z-3.0000 S1000
    G1 F1000 X75.2148 Y72.7543 Z-3.0000 S1000
    G1 F1000 X75.1909 Y72.9480 Z-3.0000 S1000
    G1 F1000 X75.1750 Y73.1425 Z-3.0000 S1000
    G1 F1000 X75.1670 Y73.3375 Z-3.0000 S1000
    G1 F1000 X75.1670 Y73.5327 Z-3.0000 S1000
    G1 F1000 X75.1750 Y73.7277 Z-3.0000 S1000
    G1 F1000 X75.1910 Y73.9223 Z-3.0000 S1000
    G1 F1000 X75.2150 Y74.1160 Z-3.0000 S1000
    G1 F1000 X75.2469 Y74.3085 Z-3.0000 S1000
    G1 F1000 X75.2866 Y74.4996 Z-3.0000 S1000
    G1 F1000 X75.3342 Y74.6889 Z-3.0000 S1000
    G1 F1000 X75.3894 Y74.8761 Z-3.0000 S1000
    G1 F1000 X75.4523 Y75.0609 Z-3.0000 S1000
    G1 F1000 X75.5227 Y75.2430 Z-3.0000 S1000
    G1 F1000 X75.6005 Y75.4220 Z-3.0000 S1000
    G1 F1000 X75.6855 Y75.5976 Z-3.0000 S1000
    G1 F1000 X75.7777 Y75.7697 Z-3.0000 S1000
    G1 F1000 X75.8769 Y75.9378 Z-3.0000 S1000
    G1 F1000 X75.9829 Y76.1017 Z-3.0000 S1000
    G1 F1000 X76.1162 Y76.2891 Z-3.0000 S1000
    G1 F1000 X79.4423 Y80.7312 Z-3.0000 S1000
    G1 F1000 X77.8265 Y82.3470 Z-3.0000 S1000
    G1 F1000 X73.3844 Y79.0209 Z-3.0000 S1000
    G1 F1000 X73.2258 Y78.9072 Z-3.0000 S1000
    G1 F1000 X73.0627 Y78.8000 Z-3.0000 S1000
    G1 F1000 X72.8953 Y78.6996 Z-3.0000 S1000
    G1 F1000 X72.7239 Y78.6062 Z-3.0000 S1000
    G1 F1000 X72.5489 Y78.5198 Z-3.0000 S1000
    G1 F1000 X72.3704 Y78.4407 Z-3.0000 S1000
    G1 F1000 X72.1889 Y78.3690 Z-3.0000 S1000
    G1 F1000 X72.0046 Y78.3048 Z-3.0000 S1000
    G1 F1000 X71.8178 Y78.2482 Z-3.0000 S1000
    G1 F1000 X71.6289 Y78.1992 Z-3.0000 S1000
    G1 F1000 X71.4381 Y78.1581 Z-3.0000 S1000
    G1 F1000 X71.2457 Y78.1248 Z-3.0000 S1000
    G1 F1000 X71.0522 Y78.0994 Z-3.0000 S1000
    G1 F1000 X70.8578 Y78.0820 Z-3.0000 S1000
    G1 F1000 X70.6629 Y78.0726 Z-3.0000 S1000
    G1 F1000 X70.4677 Y78.0711 Z-3.0000 S1000
    G1 F1000 X70.2726 Y78.0777 Z-3.0000 S1000
    G1 F1000 X70.0780 Y78.0922 Z-3.0000 S1000
    G1 F1000 X69.8841 Y78.1147 Z-3.0000 S1000
    G1 F1000 X69.6913 Y78.1451 Z-3.0000 S1000
    G1 F1000 X69.4999 Y78.1834 Z-3.0000 S1000
    G1 F1000 X69.3103 Y78.2295 Z-3.0000 S1000
    G1 F1000 X69.1226 Y78.2834 Z-3.0000 S1000
    G1 F1000 X68.9374 Y78.3448 Z-3.0000 S1000
    G1 F1000 X68.7548 Y78.4139 Z-3.0000 S1000
    G1 F1000 X68.5752 Y78.4903 Z-3.0000 S1000
    G1 F1000 X68.3678 Y78.5898 Z-3.0000 S1000
    G1 F1000 X63.2610 Y81.1917 Z-3.0000 S1000
    G1 F1000 X59.3309 Y82.2448 Z-3.0000 S1000
    G1 F1000 X59.1434 Y82.2991 Z-3.0000 S1000
    G1 F1000 X58.9584 Y82.3611 Z-3.0000 S1000
    G1 F1000 X58.7760 Y82.4307 Z-3.0000 S1000
    G1 F1000 X58.5966 Y82.5076 Z-3.0000 S1000
    G1 F1000 X58.4205 Y82.5919 Z-3.0000 S1000
    G1 F1000 X58.2481 Y82.6832 Z-3.0000 S1000
    G1 F1000 X58.0795 Y82.7816 Z-3.0000 S1000
    G1 F1000 X57.9151 Y82.8868 Z-3.0000 S1000
    G1 F1000 X57.7551 Y82.9986 Z-3.0000 S1000
    G1 F1000 X57.5999 Y83.1169 Z-3.0000 S1000
    G1 F1000 X57.4496 Y83.2415 Z-3.0000 S1000
    G1 F1000 X57.3046 Y83.3721 Z-3.0000 S1000
    G1 F1000 X57.1650 Y83.5086 Z-3.0000 S1000
    G1 F1000 X57.0312 Y83.6506 Z-3.0000 S1000
    G1 F1000 X56.9032 Y83.7980 Z-3.0000 S1000
    G1 F1000 X56.7815 Y83.9506 Z-3.0000 S1000
    G1 F1000 X56.6660 Y84.1080 Z-3.0000 S1000
    G1 F1000 X56.5572 Y84.2700 Z-3.0000 S1000
    G1 F1000 X56.4550 Y84.4363 Z-3.0000 S1000
    G1 F1000 X56.3598 Y84.6067 Z-3.0000 S1000
    G1 F1000 X56.2716 Y84.7808 Z-3.0000 S1000
    G1 F1000 X56.1906 Y84.9584 Z-3.0000 S1000
    G1 F1000 X56.1170 Y85.1391 Z-3.0000 S1000
    G1 F1000 X56.0508 Y85.3228 Z-3.0000 S1000
    G1 F1000 X55.9922 Y85.5089 Z-3.0000 S1000
    G1 F1000 X55.9413 Y85.6974 Z-3.0000 S1000
    G1 F1000 X55.8982 Y85.8877 Z-3.0000 S1000
    G1 F1000 X55.8494 Y86.1678 Z-3.0000 S1000
    G1 F1000 X55.0426 Y91.7845 Z-3.0000 S1000
    G1 F1000 X52.7574 Y91.7845 Z-3.0000 S1000
    G1 F1000 X51.9546 Y86.1973 Z-3.0000 S1000
    G1 F1000 X51.9229 Y86.0047 Z-3.0000 S1000
    G1 F1000 X51.8833 Y85.8136 Z-3.0000 S1000
    G1 F1000 X51.8359 Y85.6242 Z-3.0000 S1000
    G1 F1000 X51.7808 Y85.4370 Z-3.0000 S1000
    G1 F1000 X51.7181 Y85.2522 Z-3.0000 S1000
    G1 F1000 X51.6479 Y85.0701 Z-3.0000 S1000
    G1 F1000 X51.5702 Y84.8910 Z-3.0000 S1000
    G1 F1000 X51.4853 Y84.7152 Z-3.0000 S1000
    G1 F1000 X51.3933 Y84.5431 Z-3.0000 S1000
    G1 F1000 X51.2943 Y84.3749 Z-3.0000 S1000
    G1 F1000 X51.1884 Y84.2109 Z-3.0000 S1000
    G1 F1000 X51.0760 Y84.0514 Z-3.0000 S1000
    G1 F1000 X50.9571 Y83.8966 Z-3.0000 S1000
    G1 F1000 X50.8319 Y83.7468 Z-3.0000 S1000
    G1 F1000 X50.7008 Y83.6023 Z-3.0000 S1000
    G1 F1000 X50.5638 Y83.4633 Z-3.0000 S1000
    G1 F1000 X50.4212 Y83.3299 Z-3.0000 S1000
    G1 F1000 X50.2733 Y83.2026 Z-3.0000 S1000
    G1 F1000 X50.1203 Y83.0814 Z-3.0000 S1000
    G1 F1000 X49.9624 Y82.9666 Z-3.0000 S1000
    G1 F1000 X49.8000 Y82.8584 Z-3.0000 S1000
    G1 F1000 X49.6333 Y82.7569 Z-3.0000 S1000
    G1 F1000 X49.4626 Y82.6623 Z-3.0000 S1000
    G1 F1000 X49.2881 Y82.5748 Z-3.0000 S1000
    G1 F1000 X49.1102 Y82.4945 Z-3.0000 S1000
    G1 F1000 X48.9292 Y82.4215 Z-3.0000 S1000
    G1 F1000 X48.7453 Y82.3561 Z-3.0000 S1000
    G1 F1000 X48.5589 Y82.2982 Z-3.0000 S1000
    G1 F1000 X48.3703 Y82.2480 Z-3.0000 S1000
    G1 F1000 X48.1797 Y82.2056 Z-3.0000 S1000
    G1 F1000 X47.9858 Y82.1708 Z-3.0000 S1000
    G1 F1000 X47.1396 Y82.0367 Z-3.0000 S1000
    G1 F1000 X42.0413 Y80.0794 Z-3.0000 S1000
    G1 F1000 X39.9878 Y78.7461 Z-3.0000 S1000
    G1 F1000 X39.8219 Y78.6432 Z-3.0000 S1000
    G1 F1000 X39.6520 Y78.5472 Z-3.0000 S1000
    G1 F1000 X39.4783 Y78.4582 Z-3.0000 S1000
    G1 F1000 X39.3011 Y78.3764 Z-3.0000 S1000
    G1 F1000 X39.1206 Y78.3019 Z-3.0000 S1000
    G1 F1000 X38.9373 Y78.2349 Z-3.0000 S1000
    G1 F1000 X38.7514 Y78.1755 Z-3.0000 S1000
    G1 F1000 X38.5632 Y78.1237 Z-3.0000 S1000
    G1 F1000 X38.3731 Y78.0797 Z-3.0000 S1000
    G1 F1000 X38.1813 Y78.0435 Z-3.0000 S1000
    G1 F1000 X37.9882 Y78.0152 Z-3.0000 S1000
    G1 F1000 X37.7940 Y77.9948 Z-3.0000 S1000
    G1 F1000 X37.5993 Y77.9824 Z-3.0000 S1000
    G1 F1000 X37.4041 Y77.9780 Z-3.0000 S1000
    G1 F1000 X37.2090 Y77.9816 Z-3.0000 S1000
    G1 F1000 X37.0141 Y77.9932 Z-3.0000 S1000
    G1 F1000 X36.8199 Y78.0127 Z-3.0000 S1000
    G1 F1000 X36.6267 Y78.0403 Z-3.0000 S1000
    G1 F1000 X36.4348 Y78.0756 Z-3.0000 S1000
    G1 F1000 X36.2444 Y78.1189 Z-3.0000 S1000
    G1 F1000 X36.0560 Y78.1699 Z-3.0000 S1000
    G1 F1000 X35.8699 Y78.2285 Z-3.0000 S1000
    G1 F1000 X35.6863 Y78.2948 Z-3.0000 S1000
    G1 F1000 X35.5055 Y78.3685 Z-3.0000 S1000
    G1 F1000 X35.3280 Y78.4496 Z-3.0000 S1000
    G1 F1000 X35.1539 Y78.5378 Z-3.0000 S1000
    G1 F1000 X34.9836 Y78.6332 Z-3.0000 S1000
    G1 F1000 X34.8173 Y78.7354 Z-3.0000 S1000
    G1 F1000 X34.6554 Y78.8443 Z-3.0000 S1000
    G1 F1000 X34.5398 Y78.9282 Z-3.0000 S1000
    G1 F1000 X29.9736 Y82.3471 Z-3.0000 S1000
    G1 F1000 X28.3576 Y80.7311 Z-3.0000 S1000
    G1 F1000 X31.7765 Y76.1650 Z-3.0000 S1000
    G1 F1000 X31.8902 Y76.0064 Z-3.0000 S1000
    G1 F1000 X31.9974 Y75.8433 Z-3.0000 S1000
    G1 F1000 X32.0978 Y75.6759 Z-3.0000 S1000
    G1 F1000 X32.1912 Y75.5046 Z-3.0000 S1000
    G1 F1000 X32.2776 Y75.3295 Z-3.0000 S1000
    G1 F1000 X32.3567 Y75.1511 Z-3.0000 S1000
    G1 F1000 X32.4284 Y74.9696 Z-3.0000 S1000
    G1 F1000 X32.4926 Y74.7852 Z-3.0000 S1000
    G1 F1000 X32.5493 Y74.5985 Z-3.0000 S1000
    G1 F1000 X32.5982 Y74.4095 Z-3.0000 S1000
    G1 F1000 X32.6393 Y74.2187 Z-3.0000 S1000
    G1 F1000 X32.6726 Y74.0264 Z-3.0000 S1000
    G1 F1000 X32.6980 Y73.8329 Z-3.0000 S1000
    G1 F1000 X32.7154 Y73.6385 Z-3.0000 S1000
    G1 F1000 X32.7248 Y73.4435 Z-3.0000 S1000
    G1 F1000 X32.7263 Y73.2483 Z-3.0000 S1000
    G1 F1000 X32.7197 Y73.0533 Z-3.0000 S1000
    G1 F1000 X32.7052 Y72.8586 Z-3.0000 S1000
    G1 F1000 X32.6827 Y72.6647 Z-3.0000 S1000
    G1 F1000 X32.6523 Y72.4719 Z-3.0000 S1000
    G1 F1000 X32.6140 Y72.2806 Z-3.0000 S1000
    G1 F1000 X32.5679 Y72.0909 Z-3.0000 S1000
    G1 F1000 X32.5140 Y71.9033 Z-3.0000 S1000
    G1 F1000 X32.4525 Y71.7180 Z-3.0000 S1000
    G1 F1000 X32.3835 Y71.5355 Z-3.0000 S1000
    G1 F1000 X32.3071 Y71.3559 Z-3.0000 S1000
    G1 F1000 X32.2233 Y71.1796 Z-3.0000 S1000
    G1 F1000 X32.1324 Y71.0069 Z-3.0000 S1000
    G1 F1000 X32.0345 Y70.8380 Z-3.0000 S1000
    G1 F1000 X31.9586 Y70.7171 Z-3.0000 S1000
    G1 F1000 X30.6254 Y68.6637 Z-3.0000 S1000
    G1 F1000 X28.6680 Y63.5651 Z-3.0000 S1000
    G1 F1000 X28.5339 Y62.7189 Z-3.0000 S1000
    G1 F1000 X28.4994 Y62.5268 Z-3.0000 S1000
    G1 F1000 X28.4571 Y62.3363 Z-3.0000 S1000
    G1 F1000 X28.4070 Y62.1477 Z-3.0000 S1000
    G1 F1000 X28.3492 Y61.9612 Z-3.0000 S1000
    G1 F1000 X28.2838 Y61.7773 Z-3.0000 S1000
    G1 F1000 X28.2110 Y61.5962 Z-3.0000 S1000
    G1 F1000 X28.1308 Y61.4183 Z-3.0000 S1000
    G1 F1000 X28.0433 Y61.2438 Z-3.0000 S1000
    G1 F1000 X27.9488 Y61.0730 Z-3.0000 S1000
    G1 F1000 X27.8474 Y60.9063 Z-3.0000 S1000
    G1 F1000 X27.7392 Y60.7438 Z-3.0000 S1000
    G1 F1000 X27.6244 Y60.5859 Z-3.0000 S1000
    G1 F1000 X27.5033 Y60.4329 Z-3.0000 S1000
    G1 F1000 X27.3760 Y60.2849 Z-3.0000 S1000
    G1 F1000 X27.2428 Y60.1423 Z-3.0000 S1000
    G1 F1000 X27.1038 Y60.0053 Z-3.0000 S1000
    G1 F1000 X26.9593 Y59.8740 Z-3.0000 S1000
    G1 F1000 X26.8096 Y59.7488 Z-3.0000 S1000
    G1 F1000 X26.6548 Y59.6299 Z-3.0000 S1000
    G1 F1000 X26.4954 Y59.5173 Z-3.0000 S1000
    G1 F1000 X26.3314 Y59.4114 Z-3.0000 S1000
    G1 F1000 X26.1632 Y59.3124 Z-3.0000 S1000
    G1 F1000 X25.9912 Y59.2202 Z-3.0000 S1000
    G1 F1000 X25.8155 Y59.1353 Z-3.0000 S1000
    G1 F1000 X25.6364 Y59.0575 Z-3.0000 S1000
    G1 F1000 X25.4543 Y58.9872 Z-3.0000 S1000
    G1 F1000 X25.2695 Y58.9244 Z-3.0000 S1000
    G1 F1000 X25.0823 Y58.8693 Z-3.0000 S1000
    G1 F1000 X24.8930 Y58.8218 Z-3.0000 S1000
    G1 F1000 X24.7019 Y58.7822 Z-3.0000 S1000
    G1 F1000 X24.5074 Y58.7501 Z-3.0000 S1000
    G1 F1000 X18.9202 Y57.9473 Z-3.0000 S1000
    G1 F1000 X18.9202 Y55.6622 Z-3.0000 S1000
    G1 F1000 X24.5368 Y54.8554 Z-3.0000 S1000
    G1 F1000 X24.7294 Y54.8237 Z-3.0000 S1000
    G1 F1000 X24.9206 Y54.7841 Z-3.0000 S1000
    G1 F1000 X25.1099 Y54.7368 Z-3.0000 S1000
    G1 F1000 X25.2972 Y54.6817 Z-3.0000 S1000
    G1 F1000 X25.4820 Y54.6190 Z-3.0000 S1000
    G1 F1000 X25.6641 Y54.5487 Z-3.0000 S1000
    G1 F1000 X25.8432 Y54.4711 Z-3.0000 S1000
    G1 F1000 X26.0189 Y54.3862 Z-3.0000 S1000
    G1 F1000 X26.1910 Y54.2942 Z-3.0000 S1000
    G1 F1000 X26.3592 Y54.1952 Z-3.0000 S1000
    G1 F1000 X26.5232 Y54.0893 Z-3.0000 S1000
    G1 F1000 X26.6828 Y53.9769 Z-3.0000 S1000
    G1 F1000 X26.8376 Y53.8580 Z-3.0000 S1000
    G1 F1000 X26.9874 Y53.7328 Z-3.0000 S1000
    G1 F1000 X27.1319 Y53.6017 Z-3.0000 S1000
    G1 F1000 X27.2709 Y53.4647 Z-3.0000 S1000
    G1 F1000 X27.4042 Y53.3221 Z-3.0000 S1000
    G1 F1000 X27.5316 Y53.1742 Z-3.0000 S1000
    G1 F1000 X27.6528 Y53.0212 Z-3.0000 S1000
    G1 F1000 X27.7676 Y52.8634 Z-3.0000 S1000
    G1 F1000 X27.8759 Y52.7010 Z-3.0000 S1000
    G1 F1000 X27.9774 Y52.5343 Z-3.0000 S1000
    G1 F1000 X28.0720 Y52.3635 Z-3.0000 S1000
    G1 F1000 X28.1595 Y52.1891 Z-3.0000 S1000
    G1 F1000 X28.2398 Y52.0112 Z-3.0000 S1000
    G1 F1000 X28.3127 Y51.8301 Z-3.0000 S1000
    G1 F1000 X28.3782 Y51.6463 Z-3.0000 S1000
    G1 F1000 X28.4599 Y51.3739 Z-3.0000 S1000
    G1 F1000 X29.5129 Y47.4440 Z-3.0000 S1000
    G1 F1000 X32.1150 Y42.3368 Z-3.0000 S1000
    G1 F1000 X32.2000 Y42.1612 Z-3.0000 S1000
    G1 F1000 X32.2777 Y41.9821 Z-3.0000 S1000
    G1 F1000 X32.3481 Y41.8001 Z-3.0000 S1000
    G1 F1000 X32.4109 Y41.6153 Z-3.0000 S1000
    G1 F1000 X32.4661 Y41.4281 Z-3.0000 S1000
    G1 F1000 X32.5136 Y41.2387 Z-3.0000 S1000
    G1 F1000 X32.5533 Y41.0476 Z-3.0000 S1000
    G1 F1000 X32.5852 Y40.8551 Z-3.0000 S1000
    G1 F1000 X32.6091 Y40.6614 Z-3.0000 S1000
    G1 F1000 X32.6250 Y40.4668 Z-3.0000 S1000
    G1 F1000 X32.6330 Y40.2718 Z-3.0000 S1000
    G1 F1000 X32.6330 Y40.0766 Z-3.0000 S1000
    G1 F1000 X32.6250 Y39.8816 Z-3.0000 S1000
    G1 F1000 X32.6090 Y39.6871 Z-3.0000 S1000
    G1 F1000 X32.5850 Y39.4934 Z-3.0000 S1000
    G1 F1000 X32.5531 Y39.3008 Z-3.0000 S1000
    G1 F1000 X32.5134 Y39.1097 Z-3.0000 S1000
    G1 F1000 X32.4658 Y38.9204 Z-3.0000 S1000
    G1 F1000 X32.4106 Y38.7332 Z-3.0000 S1000
    G1 F1000 X32.3477 Y38.5485 Z-3.0000 S1000
    G1 F1000 X32.2773 Y38.3664 Z-3.0000 S1000
    G1 F1000 X32.1995 Y38.1874 Z-3.0000 S1000
    G1 F1000 X32.1144 Y38.0117 Z-3.0000 S1000
    G1 F1000 X32.0222 Y37.8397 Z-3.0000 S1000
    G1 F1000 X31.9231 Y37.6716 Z-3.0000 S1000
    G1 F1000 X31.8171 Y37.5077 Z-3.0000 S1000
    G1 F1000 X31.6838 Y37.3203 Z-3.0000 S1000
    G1 F1000 X28.3577 Y32.8782 Z-3.0000 S1000
    G1 F1000 X29.9735 Y31.2625 Z-3.0000 S1000
    G1 F1000 X34.4156 Y34.5885 Z-3.0000 S1000
    G1 F1000 X34.5742 Y34.7022 Z-3.0000 S1000
    G1 F1000 X34.7374 Y34.8094 Z-3.0000 S1000
    G1 F1000 X34.9048 Y34.9098 Z-3.0000 S1000
    G1 F1000 X35.0761 Y35.0032 Z-3.0000 S1000
    G1 F1000 X35.2512 Y35.0896 Z-3.0000 S1000
    G1 F1000 X35.4296 Y35.1687 Z-3.0000 S1000
    G1 F1000 X35.6111 Y35.2404 Z-3.0000 S1000
    G1 F1000 X35.7954 Y35.3046 Z-3.0000 S1000
    G1 F1000 X35.9822 Y35.3613 Z-3.0000 S1000
    G1 F1000 X36.1712 Y35.4102 Z-3.0000 S1000
    G1 F1000 X36.3620 Y35.4513 Z-3.0000 S1000
    G1 F1000 X36.5543 Y35.4846 Z-3.0000 S1000
    G1 F1000 X36.7478 Y35.5100 Z-3.0000 S1000
    G1 F1000 X36.9422 Y35.5274 Z-3.0000 S1000
    G1 F1000 X37.1372 Y35.5368 Z-3.0000 S1000
    G1 F1000 X37.3324 Y35.5383 Z-3.0000 S1000
    G1 F1000 X37.5274 Y35.5317 Z-3.0000 S1000
    G1 F1000 X37.7221 Y35.5172 Z-3.0000 S1000
    G1 F1000 X37.9159 Y35.4947 Z-3.0000 S1000
    G1 F1000 X38.1087 Y35.4643 Z-3.0000 S1000
    G1 F1000 X38.3001 Y35.4260 Z-3.0000 S1000
    G1 F1000 X38.4898 Y35.3799 Z-3.0000 S1000
    G1 F1000 X38.6774 Y35.3260 Z-3.0000 S1000
    G1 F1000 X38.8626 Y35.2645 Z-3.0000 S1000
    G1 F1000 X39.0452 Y35.1955 Z-3.0000 S1000
    G1 F1000 X39.2248 Y35.1191 Z-3.0000 S1000
    G1 F1000 X39.4323 Y35.0196 Z-3.0000 S1000
    G1 F1000 X39.4737 Y34.9985 Z-3.0000 S1000
    G1 F1000 X43.9528 Y44.6039 Z-3.0000 S1000
    G1 F1000 X43.0968 Y45.2970 Z-3.0000 S1000
    G1 F1000 X42.9477 Y45.4229 Z-3.0000 S1000
    G1 F1000 X42.8038 Y45.5548 Z-3.0000 S1000
    G1 F1000 X42.6655 Y45.6925 Z-3.0000 S1000
    G1 F1000 X42.5329 Y45.8358 Z-3.0000 S1000
    G1 F1000 X42.3923 Y46.0015 Z-3.0000 S1000
    G1 F1000 X40.9400 Y47.7952 Z-3.0000 S1000
    G1 F1000 X40.8203 Y47.9494 Z-3.0000 S1000
    G1 F1000 X40.7071 Y48.1084 Z-3.0000 S1000
    G1 F1000 X40.6004 Y48.2718 Z-3.0000 S1000
    G1 F1000 X40.5005 Y48.4395 Z-3.0000 S1000
    G1 F1000 X40.3979 Y48.6301 Z-3.0000 S1000
    G1 F1000 X39.3504 Y50.6861 Z-3.0000 S1000
    G1 F1000 X39.2654 Y50.8618 Z-3.0000 S1000
    G1 F1000 X39.1876 Y51.0408 Z-3.0000 S1000
    G1 F1000 X39.1173 Y51.2229 Z-3.0000 S1000
    G1 F1000 X39.0545 Y51.4077 Z-3.0000 S1000
    G1 F1000 X38.9936 Y51.6157 Z-3.0000 S1000
    G1 F1000 X38.3962 Y53.8457 Z-3.0000 S1000
    G1 F1000 X38.3496 Y54.0352 Z-3.0000 S1000
    G1 F1000 X38.3108 Y54.2265 Z-3.0000 S1000
    G1 F1000 X38.2798 Y54.4192 Z-3.0000 S1000
    G1 F1000 X38.2568 Y54.6131 Z-3.0000 S1000
    G1 F1000 X38.2406 Y54.8284 Z-3.0000 S1000
    G1 F1000 X38.1196 Y57.1330 Z-3.0000 S1000
    G1 F1000 X38.1133 Y57.3281 Z-3.0000 S1000
    G1 F1000 X38.1151 Y57.5233 Z-3.0000 S1000
    G1 F1000 X38.1248 Y57.7182 Z-3.0000 S1000
    G1 F1000 X38.1426 Y57.9126 Z-3.0000 S1000
    G1 F1000 X38.1717 Y58.1280 Z-3.0000 S1000
    G1 F1000 X38.5329 Y60.4075 Z-3.0000 S1000
    G1 F1000 X38.5674 Y60.5997 Z-3.0000 S1000
    G1 F1000 X38.6097 Y60.7902 Z-3.0000 S1000
    G1 F1000 X38.6598 Y60.9788 Z-3.0000 S1000
    G1 F1000 X38.7176 Y61.1653 Z-3.0000 S1000
    G1 F1000 X38.7906 Y61.3691 Z-3.0000 S1000
    G1 F1000 X39.6177 Y63.5235 Z-3.0000 S1000
    G1 F1000 X39.6914 Y63.7043 Z-3.0000 S1000
    G1 F1000 X39.7724 Y63.8818 Z-3.0000 S1000
    G1 F1000 X39.8606 Y64.0559 Z-3.0000 S1000
    G1 F1000 X39.9559 Y64.2263 Z-3.0000 S1000
    G1 F1000 X40.0699 Y64.4108 Z-3.0000 S1000
    G1 F1000 X41.3271 Y66.3463 Z-3.0000 S1000
    G1 F1000 X41.4367 Y66.5078 Z-3.0000 S1000
    G1 F1000 X41.5529 Y66.6646 Z-3.0000 S1000
    G1 F1000 X41.6754 Y66.8166 Z-3.0000 S1000
    G1 F1000 X41.8040 Y66.9634 Z-3.0000 S1000
    G1 F1000 X41.9534 Y67.1197 Z-3.0000 S1000
    G1 F1000 X43.5850 Y68.7513 Z-3.0000 S1000
    G1 F1000 X43.7258 Y68.8865 Z-3.0000 S1000
    G1 F1000 X43.8721 Y69.0157 Z-3.0000 S1000
    G1 F1000 X44.0235 Y69.1389 Z-3.0000 S1000
    G1 F1000 X44.1798 Y69.2558 Z-3.0000 S1000
    G1 F1000 X44.3584 Y69.3776 Z-3.0000 S1000
    G1 F1000 X46.2939 Y70.6348 Z-3.0000 S1000
    G1 F1000 X46.4597 Y70.7378 Z-3.0000 S1000
    G1 F1000 X46.6296 Y70.8338 Z-3.0000 S1000
    G1 F1000 X46.8033 Y70.9228 Z-3.0000 S1000
    G1 F1000 X46.9805 Y71.0047 Z-3.0000 S1000
    G1 F1000 X47.1812 Y71.0870 Z-3.0000 S1000
    G1 F1000 X49.3356 Y71.9141 Z-3.0000 S1000
    G1 F1000 X49.5192 Y71.9803 Z-3.0000 S1000
    G1 F1000 X49.7054 Y72.0389 Z-3.0000 S1000
    G1 F1000 X49.8938 Y72.0899 Z-3.0000 S1000
    G1 F1000 X50.0841 Y72.1331 Z-3.0000 S1000
    G1 F1000 X50.2972 Y72.1718 Z-3.0000 S1000
    G1 F1000 X52.5767 Y72.5330 Z-3.0000 S1000
    G1 F1000 X52.7700 Y72.5596 Z-3.0000 S1000
    G1 F1000 X52.9643 Y72.5782 Z-3.0000 S1000
    G1 F1000 X53.1592 Y72.5889 Z-3.0000 S1000
    G1 F1000 X53.3544 Y72.5916 Z-3.0000 S1000
    G1 F1000 X53.5717 Y72.5851 Z-3.0000 S1000
    G1 F1000 X55.8763 Y72.4641 Z-3.0000 S1000
    G1 F1000 X56.0710 Y72.4499 Z-3.0000 S1000
    G1 F1000 X56.2649 Y72.4277 Z-3.0000 S1000
    G1 F1000 X56.4577 Y72.3976 Z-3.0000 S1000
    G1 F1000 X56.6492 Y72.3596 Z-3.0000 S1000
    G1 F1000 X56.8590 Y72.3085 Z-3.0000 S1000
    G1 F1000 X59.0890 Y71.7111 Z-3.0000 S1000
    G1 F1000 X59.2764 Y71.6567 Z-3.0000 S1000
    G1 F1000 X59.4615 Y71.5947 Z-3.0000 S1000
    G1 F1000 X59.6439 Y71.5252 Z-3.0000 S1000
    G1 F1000 X59.8233 Y71.4483 Z-3.0000 S1000
    G1 F1000 X60.0186 Y71.3543 Z-3.0000 S1000
    G1 F1000 X62.0746 Y70.3068 Z-3.0000 S1000
    G1 F1000 X62.2467 Y70.2146 Z-3.0000 S1000
    G1 F1000 X62.4148 Y70.1155 Z-3.0000 S1000
    G1 F1000 X62.5787 Y70.0096 Z-3.0000 S1000
    G1 F1000 X62.7382 Y69.8970 Z-3.0000 S1000
    G1 F1000 X62.9095 Y69.7647 Z-3.0000 S1000
    G1 F1000 X64.7032 Y68.3124 Z-3.0000 S1000
    G1 F1000 X64.8523 Y68.1865 Z-3.0000 S1000
    G1 F1000 X64.9962 Y68.0546 Z-3.0000 S1000
    G1 F1000 X65.1345 Y67.9169 Z-3.0000 S1000
    G1 F1000 X65.2671 Y67.7736 Z-3.0000 S1000
    G1 F1000 X65.4077 Y67.6079 Z-3.0000 S1000
    G1 F1000 X66.8600 Y65.8142 Z-3.0000 S1000
    G1 F1000 X66.9797 Y65.6600 Z-3.0000 S1000
    G1 F1000 X67.0929 Y65.5010 Z-3.0000 S1000
    G1 F1000 X67.1996 Y65.3376 Z-3.0000 S1000
    G1 F1000 X67.2995 Y65.1699 Z-3.0000 S1000
    G1 F1000 X67.4021 Y64.9793 Z-3.0000 S1000
    G1 F1000 X68.4496 Y62.9233 Z-3.0000 S1000
    G1 F1000 X68.5346 Y62.7476 Z-3.0000 S1000
    G1 F1000 X68.6124 Y62.5686 Z-3.0000 S1000
    G1 F1000 X68.6827 Y62.3865 Z-3.0000 S1000
    G1 F1000 X68.7455 Y62.2017 Z-3.0000 S1000
    G1 F1000 X68.8064 Y61.9937 Z-3.0000 S1000
    G1 F1000 X69.4038 Y59.7637 Z-3.0000 S1000
    G1 F1000 X69.4504 Y59.5742 Z-3.0000 S1000
    G1 F1000 X69.4892 Y59.3829 Z-3.0000 S1000
    G1 F1000 X69.5202 Y59.1902 Z-3.0000 S1000
    G1 F1000 X69.5432 Y58.9963 Z-3.0000 S1000
    G1 F1000 X69.5594 Y58.7810 Z-3.0000 S1000
    G1 F1000 X69.6804 Y56.4764 Z-3.0000 S1000
    G1 F1000 X69.6867 Y56.2813 Z-3.0000 S1000
    G1 F1000 X69.6849 Y56.0861 Z-3.0000 S1000
    G1 F1000 X69.6752 Y55.8912 Z-3.0000 S1000
    G1 F1000 X69.6574 Y55.6968 Z-3.0000 S1000
    G1 F1000 X69.6283 Y55.4814 Z-3.0000 S1000
    G1 F1000 X69.2671 Y53.2019 Z-3.0000 S1000
    G1 F1000 X69.2326 Y53.0097 Z-3.0000 S1000
    G1 F1000 X69.1903 Y52.8192 Z-3.0000 S1000
    G1 F1000 X69.1402 Y52.6306 Z-3.0000 S1000
    G1 F1000 X69.0824 Y52.4441 Z-3.0000 S1000
    G1 F1000 X69.0094 Y52.2403 Z-3.0000 S1000
    G1 F1000 X68.1823 Y50.0859 Z-3.0000 S1000
    G1 F1000 X68.1086 Y49.9051 Z-3.0000 S1000
    G1 F1000 X68.0276 Y49.7276 Z-3.0000 S1000
    G1 F1000 X67.9394 Y49.5535 Z-3.0000 S1000
    G1 F1000 X67.8441 Y49.3831 Z-3.0000 S1000
    G1 F1000 X67.7301 Y49.1986 Z-3.0000 S1000
    G1 F1000 X66.4729 Y47.2631 Z-3.0000 S1000
    G1 F1000 X66.3633 Y47.1016 Z-3.0000 S1000
    G1 F1000 X66.2471 Y46.9448 Z-3.0000 S1000
    G1 F1000 X66.1246 Y46.7928 Z-3.0000 S1000
    G1 F1000 X65.9960 Y46.6460 Z-3.0000 S1000
    G1 F1000 X65.8466 Y46.4897 Z-3.0000 S1000
    G1 F1000 X64.5633 Y45.2064 Z-3.0000 S1000
    G0 Z7
    G0 X62.6286 Y45.5989
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X68.3534 Y33.3218 Z-1.0000 S1000
    G1 F1000 X68.6768 Y33.5318 Z-1.0000 S1000
    G1 F1000 X68.8126 Y33.6152 Z-1.0000 S1000
    G1 F1000 X68.9524 Y33.6917 Z-1.0000 S1000
    G1 F1000 X69.0958 Y33.7611 Z-1.0000 S1000
    G1 F1000 X69.2426 Y33.8232 Z-1.0000 S1000
    G1 F1000 X69.3923 Y33.8778 Z-1.0000 S1000
    G1 F1000 X69.5446 Y33.9249 Z-1.0000 S1000
    G1 F1000 X69.6990 Y33.9642 Z-1.0000 S1000
    G1 F1000 X69.8552 Y33.9958 Z-1.0000 S1000
    G1 F1000 X70.0128 Y34.0195 Z-1.0000 S1000
    G1 F1000 X70.1714 Y34.0352 Z-1.0000 S1000
    G1 F1000 X70.3305 Y34.0430 Z-1.0000 S1000
    G1 F1000 X70.4899 Y34.0428 Z-1.0000 S1000
    G1 F1000 X70.6490 Y34.0346 Z-1.0000 S1000
    G1 F1000 X70.8076 Y34.0184 Z-1.0000 S1000
    G1 F1000 X70.9651 Y33.9942 Z-1.0000 S1000
    G1 F1000 X71.1212 Y33.9622 Z-1.0000 S1000
    G1 F1000 X71.2755 Y33.9225 Z-1.0000 S1000
    G1 F1000 X71.4276 Y33.8750 Z-1.0000 S1000
    G1 F1000 X71.5772 Y33.8199 Z-1.0000 S1000
    G1 F1000 X71.7238 Y33.7574 Z-1.0000 S1000
    G1 F1000 X71.8671 Y33.6876 Z-1.0000 S1000
    G1 F1000 X72.0067 Y33.6108 Z-1.0000 S1000
    G1 F1000 X72.1422 Y33.5270 Z-1.0000 S1000
    G1 F1000 X72.3087 Y33.4105 Z-1.0000 S1000
    G1 F1000 X77.9762 Y29.1671 Z-1.0000 S1000
    G1 F1000 X81.5377 Y32.7286 Z-1.0000 S1000
    G1 F1000 X77.2943 Y38.3960 Z-1.0000 S1000
    G1 F1000 X77.2020 Y38.5259 Z-1.0000 S1000
    G1 F1000 X77.1163 Y38.6603 Z-1.0000 S1000
    G1 F1000 X77.0375 Y38.7988 Z-1.0000 S1000
    G1 F1000 X76.9658 Y38.9411 Z-1.0000 S1000
    G1 F1000 X76.9013 Y39.0868 Z-1.0000 S1000
    G1 F1000 X76.8442 Y39.2356 Z-1.0000 S1000
    G1 F1000 X76.7946 Y39.3870 Z-1.0000 S1000
    G1 F1000 X76.7526 Y39.5408 Z-1.0000 S1000
    G1 F1000 X76.7185 Y39.6964 Z-1.0000 S1000
    G1 F1000 X76.6922 Y39.8536 Z-1.0000 S1000
    G1 F1000 X76.6738 Y40.0119 Z-1.0000 S1000
    G1 F1000 X76.6634 Y40.1709 Z-1.0000 S1000
    G1 F1000 X76.6610 Y40.3303 Z-1.0000 S1000
    G1 F1000 X76.6665 Y40.4895 Z-1.0000 S1000
    G1 F1000 X76.6801 Y40.6483 Z-1.0000 S1000
    G1 F1000 X76.7016 Y40.8062 Z-1.0000 S1000
    G1 F1000 X76.7310 Y40.9628 Z-1.0000 S1000
    G1 F1000 X76.7682 Y41.1178 Z-1.0000 S1000
    G1 F1000 X76.8132 Y41.2707 Z-1.0000 S1000
    G1 F1000 X76.8657 Y41.4211 Z-1.0000 S1000
    G1 F1000 X76.9258 Y41.5687 Z-1.0000 S1000
    G1 F1000 X76.9932 Y41.7131 Z-1.0000 S1000
    G1 F1000 X77.0677 Y41.8540 Z-1.0000 S1000
    G1 F1000 X77.1729 Y42.0279 Z-1.0000 S1000
    G1 F1000 X78.5968 Y44.2209 Z-1.0000 S1000
    G1 F1000 X80.6738 Y49.6310 Z-1.0000 S1000
    G1 F1000 X80.8340 Y50.6420 Z-1.0000 S1000
    G1 F1000 X80.8629 Y50.7988 Z-1.0000 S1000
    G1 F1000 X80.8996 Y50.9538 Z-1.0000 S1000
    G1 F1000 X80.9440 Y51.1069 Z-1.0000 S1000
    G1 F1000 X80.9961 Y51.2575 Z-1.0000 S1000
    G1 F1000 X81.0557 Y51.4053 Z-1.0000 S1000
    G1 F1000 X81.1226 Y51.5499 Z-1.0000 S1000
    G1 F1000 X81.1966 Y51.6910 Z-1.0000 S1000
    G1 F1000 X81.2777 Y51.8283 Z-1.0000 S1000
    G1 F1000 X81.3655 Y51.9612 Z-1.0000 S1000
    G1 F1000 X81.4599 Y52.0896 Z-1.0000 S1000
    G1 F1000 X81.5607 Y52.2131 Z-1.0000 S1000
    G1 F1000 X81.6675 Y52.3314 Z-1.0000 S1000
    G1 F1000 X81.7801 Y52.4442 Z-1.0000 S1000
    G1 F1000 X81.8982 Y52.5511 Z-1.0000 S1000
    G1 F1000 X82.0215 Y52.6521 Z-1.0000 S1000
    G1 F1000 X82.1497 Y52.7467 Z-1.0000 S1000
    G1 F1000 X82.2826 Y52.8347 Z-1.0000 S1000
    G1 F1000 X82.4196 Y52.9160 Z-1.0000 S1000
    G1 F1000 X82.5606 Y52.9903 Z-1.0000 S1000
    G1 F1000 X82.7052 Y53.0574 Z-1.0000 S1000
    G1 F1000 X82.8529 Y53.1172 Z-1.0000 S1000
    G1 F1000 X83.0034 Y53.1695 Z-1.0000 S1000
    G1 F1000 X83.1564 Y53.2142 Z-1.0000 S1000
    G1 F1000 X83.3114 Y53.2512 Z-1.0000 S1000
    G1 F1000 X83.5184 Y53.2879 Z-1.0000 S1000
    G1 F1000 X90.4673 Y54.2863 Z-1.0000 S1000
    G1 F1000 X90.4673 Y59.3230 Z-1.0000 S1000
    G1 F1000 X83.4888 Y60.3255 Z-1.0000 S1000
    G1 F1000 X83.3317 Y60.3521 Z-1.0000 S1000
    G1 F1000 X83.1761 Y60.3865 Z-1.0000 S1000
    G1 F1000 X83.0225 Y60.4288 Z-1.0000 S1000
    G1 F1000 X82.8711 Y60.4786 Z-1.0000 S1000
    G1 F1000 X82.7225 Y60.5361 Z-1.0000 S1000
    G1 F1000 X82.5769 Y60.6009 Z-1.0000 S1000
    G1 F1000 X82.4347 Y60.6729 Z-1.0000 S1000
    G1 F1000 X82.2963 Y60.7519 Z-1.0000 S1000
    G1 F1000 X82.1621 Y60.8379 Z-1.0000 S1000
    G1 F1000 X82.0324 Y60.9304 Z-1.0000 S1000
    G1 F1000 X81.9074 Y61.0293 Z-1.0000 S1000
    G1 F1000 X81.7876 Y61.1344 Z-1.0000 S1000
    G1 F1000 X81.6732 Y61.2454 Z-1.0000 S1000
    G1 F1000 X81.5646 Y61.3619 Z-1.0000 S1000
    G1 F1000 X81.4619 Y61.4838 Z-1.0000 S1000
    G1 F1000 X81.3654 Y61.6106 Z-1.0000 S1000
    G1 F1000 X81.2754 Y61.7422 Z-1.0000 S1000
    G1 F1000 X81.1922 Y61.8781 Z-1.0000 S1000
    G1 F1000 X81.1159 Y62.0179 Z-1.0000 S1000
    G1 F1000 X81.0467 Y62.1615 Z-1.0000 S1000
    G1 F1000 X80.9847 Y62.3083 Z-1.0000 S1000
    G1 F1000 X80.9303 Y62.4581 Z-1.0000 S1000
    G1 F1000 X80.8735 Y62.6465 Z-1.0000 S1000
    G1 F1000 X79.7774 Y66.7374 Z-1.0000 S1000
    G1 F1000 X77.0995 Y71.9932 Z-1.0000 S1000
    G1 F1000 X77.0308 Y72.1370 Z-1.0000 S1000
    G1 F1000 X76.9693 Y72.2840 Z-1.0000 S1000
    G1 F1000 X76.9153 Y72.4339 Z-1.0000 S1000
    G1 F1000 X76.8689 Y72.5864 Z-1.0000 S1000
    G1 F1000 X76.8302 Y72.7410 Z-1.0000 S1000
    G1 F1000 X76.7993 Y72.8973 Z-1.0000 S1000
    G1 F1000 X76.7763 Y73.0550 Z-1.0000 S1000
    G1 F1000 X76.7612 Y73.2137 Z-1.0000 S1000
    G1 F1000 X76.7541 Y73.3729 Z-1.0000 S1000
    G1 F1000 X76.7550 Y73.5322 Z-1.0000 S1000
    G1 F1000 X76.7639 Y73.6913 Z-1.0000 S1000
    G1 F1000 X76.7808 Y73.8498 Z-1.0000 S1000
    G1 F1000 X76.8056 Y74.0072 Z-1.0000 S1000
    G1 F1000 X76.8382 Y74.1632 Z-1.0000 S1000
    G1 F1000 X76.8787 Y74.3173 Z-1.0000 S1000
    G1 F1000 X76.9268 Y74.4693 Z-1.0000 S1000
    G1 F1000 X76.9825 Y74.6186 Z-1.0000 S1000
    G1 F1000 X77.0456 Y74.7649 Z-1.0000 S1000
    G1 F1000 X77.1160 Y74.9079 Z-1.0000 S1000
    G1 F1000 X77.1935 Y75.0471 Z-1.0000 S1000
    G1 F1000 X77.2778 Y75.1823 Z-1.0000 S1000
    G1 F1000 X77.3870 Y75.3376 Z-1.0000 S1000
    G1 F1000 X81.5376 Y80.8809 Z-1.0000 S1000
    G1 F1000 X77.9762 Y84.4423 Z-1.0000 S1000
    G1 F1000 X72.4329 Y80.2917 Z-1.0000 S1000
    G1 F1000 X72.3030 Y80.1994 Z-1.0000 S1000
    G1 F1000 X72.1686 Y80.1138 Z-1.0000 S1000
    G1 F1000 X72.0301 Y80.0350 Z-1.0000 S1000
    G1 F1000 X71.8878 Y79.9632 Z-1.0000 S1000
    G1 F1000 X71.7421 Y79.8987 Z-1.0000 S1000
    G1 F1000 X71.5933 Y79.8416 Z-1.0000 S1000
    G1 F1000 X71.4418 Y79.7920 Z-1.0000 S1000
    G1 F1000 X71.2881 Y79.7501 Z-1.0000 S1000
    G1 F1000 X71.1324 Y79.7159 Z-1.0000 S1000
    G1 F1000 X70.9753 Y79.6896 Z-1.0000 S1000
    G1 F1000 X70.8170 Y79.6712 Z-1.0000 S1000
    G1 F1000 X70.6579 Y79.6608 Z-1.0000 S1000
    G1 F1000 X70.4986 Y79.6584 Z-1.0000 S1000
    G1 F1000 X70.3393 Y79.6639 Z-1.0000 S1000
    G1 F1000 X70.1805 Y79.6775 Z-1.0000 S1000
    G1 F1000 X70.0226 Y79.6990 Z-1.0000 S1000
    G1 F1000 X69.8660 Y79.7284 Z-1.0000 S1000
    G1 F1000 X69.7111 Y79.7656 Z-1.0000 S1000
    G1 F1000 X69.5582 Y79.8106 Z-1.0000 S1000
    G1 F1000 X69.4077 Y79.8631 Z-1.0000 S1000
    G1 F1000 X69.2601 Y79.9232 Z-1.0000 S1000
    G1 F1000 X69.0885 Y80.0042 Z-1.0000 S1000
    G1 F1000 X63.8327 Y82.6821 Z-1.0000 S1000
    G1 F1000 X59.7418 Y83.7782 Z-1.0000 S1000
    G1 F1000 X59.5889 Y83.8233 Z-1.0000 S1000
    G1 F1000 X59.4385 Y83.8760 Z-1.0000 S1000
    G1 F1000 X59.2910 Y83.9362 Z-1.0000 S1000
    G1 F1000 X59.1466 Y84.0037 Z-1.0000 S1000
    G1 F1000 X59.0058 Y84.0784 Z-1.0000 S1000
    G1 F1000 X58.8690 Y84.1600 Z-1.0000 S1000
    G1 F1000 X58.7364 Y84.2484 Z-1.0000 S1000
    G1 F1000 X58.6084 Y84.3434 Z-1.0000 S1000
    G1 F1000 X58.4853 Y84.4446 Z-1.0000 S1000
    G1 F1000 X58.3675 Y84.5519 Z-1.0000 S1000
    G1 F1000 X58.2552 Y84.6650 Z-1.0000 S1000
    G1 F1000 X58.1487 Y84.7836 Z-1.0000 S1000
    G1 F1000 X58.0483 Y84.9073 Z-1.0000 S1000
    G1 F1000 X57.9543 Y85.0360 Z-1.0000 S1000
    G1 F1000 X57.8668 Y85.1692 Z-1.0000 S1000
    G1 F1000 X57.7861 Y85.3066 Z-1.0000 S1000
    G1 F1000 X57.7124 Y85.4479 Z-1.0000 S1000
    G1 F1000 X57.6459 Y85.5927 Z-1.0000 S1000
    G1 F1000 X57.5867 Y85.7407 Z-1.0000 S1000
    G1 F1000 X57.5351 Y85.8914 Z-1.0000 S1000
    G1 F1000 X57.4910 Y86.0446 Z-1.0000 S1000
    G1 F1000 X57.4548 Y86.1998 Z-1.0000 S1000
    G1 F1000 X57.4208 Y86.3935 Z-1.0000 S1000
    G1 F1000 X56.4183 Y93.3720 Z-1.0000 S1000
    G1 F1000 X51.3816 Y93.3720 Z-1.0000 S1000
    G1 F1000 X50.3832 Y86.4231 Z-1.0000 S1000
    G1 F1000 X50.3566 Y86.2659 Z-1.0000 S1000
    G1 F1000 X50.3221 Y86.1104 Z-1.0000 S1000
    G1 F1000 X50.2799 Y85.9567 Z-1.0000 S1000
    G1 F1000 X50.2300 Y85.8053 Z-1.0000 S1000
    G1 F1000 X50.1726 Y85.6567 Z-1.0000 S1000
    G1 F1000 X50.1078 Y85.5111 Z-1.0000 S1000
    G1 F1000 X50.0358 Y85.3689 Z-1.0000 S1000
    G1 F1000 X49.9567 Y85.2306 Z-1.0000 S1000
    G1 F1000 X49.8708 Y85.0964 Z-1.0000 S1000
    G1 F1000 X49.7783 Y84.9666 Z-1.0000 S1000
    G1 F1000 X49.6793 Y84.8417 Z-1.0000 S1000
    G1 F1000 X49.5742 Y84.7219 Z-1.0000 S1000
    G1 F1000 X49.4633 Y84.6075 Z-1.0000 S1000
    G1 F1000 X49.3467 Y84.4988 Z-1.0000 S1000
    G1 F1000 X49.2249 Y84.3961 Z-1.0000 S1000
    G1 F1000 X49.0980 Y84.2997 Z-1.0000 S1000
    G1 F1000 X48.9665 Y84.2097 Z-1.0000 S1000
    G1 F1000 X48.8306 Y84.1265 Z-1.0000 S1000
    G1 F1000 X48.6907 Y84.0501 Z-1.0000 S1000
    G1 F1000 X48.5471 Y83.9809 Z-1.0000 S1000
    G1 F1000 X48.4003 Y83.9190 Z-1.0000 S1000
    G1 F1000 X48.2505 Y83.8645 Z-1.0000 S1000
    G1 F1000 X48.0982 Y83.8177 Z-1.0000 S1000
    G1 F1000 X47.9438 Y83.7785 Z-1.0000 S1000
    G1 F1000 X47.7373 Y83.7387 Z-1.0000 S1000
    G1 F1000 X46.7263 Y83.5785 Z-1.0000 S1000
    G1 F1000 X41.3162 Y81.5015 Z-1.0000 S1000
    G1 F1000 X39.1232 Y80.0776 Z-1.0000 S1000
    G1 F1000 X38.9874 Y79.9942 Z-1.0000 S1000
    G1 F1000 X38.8476 Y79.9177 Z-1.0000 S1000
    G1 F1000 X38.7042 Y79.8483 Z-1.0000 S1000
    G1 F1000 X38.5574 Y79.7862 Z-1.0000 S1000
    G1 F1000 X38.4077 Y79.7316 Z-1.0000 S1000
    G1 F1000 X38.2554 Y79.6845 Z-1.0000 S1000
    G1 F1000 X38.1010 Y79.6452 Z-1.0000 S1000
    G1 F1000 X37.9448 Y79.6136 Z-1.0000 S1000
    G1 F1000 X37.7872 Y79.5899 Z-1.0000 S1000
    G1 F1000 X37.6286 Y79.5742 Z-1.0000 S1000
    G1 F1000 X37.4695 Y79.5664 Z-1.0000 S1000
    G1 F1000 X37.3101 Y79.5666 Z-1.0000 S1000
    G1 F1000 X37.1510 Y79.5748 Z-1.0000 S1000
    G1 F1000 X36.9924 Y79.5910 Z-1.0000 S1000
    G1 F1000 X36.8349 Y79.6152 Z-1.0000 S1000
    G1 F1000 X36.6788 Y79.6472 Z-1.0000 S1000
    G1 F1000 X36.5245 Y79.6869 Z-1.0000 S1000
    G1 F1000 X36.3724 Y79.7344 Z-1.0000 S1000
    G1 F1000 X36.2228 Y79.7895 Z-1.0000 S1000
    G1 F1000 X36.0762 Y79.8520 Z-1.0000 S1000
    G1 F1000 X35.9329 Y79.9218 Z-1.0000 S1000
    G1 F1000 X35.7933 Y79.9986 Z-1.0000 S1000
    G1 F1000 X35.6578 Y80.0824 Z-1.0000 S1000
    G1 F1000 X35.4913 Y80.1990 Z-1.0000 S1000
    G1 F1000 X29.8239 Y84.4424 Z-1.0000 S1000
    G1 F1000 X26.2624 Y80.8809 Z-1.0000 S1000
    G1 F1000 X30.5057 Y75.2136 Z-1.0000 S1000
    G1 F1000 X30.5980 Y75.0836 Z-1.0000 S1000
    G1 F1000 X30.6837 Y74.9493 Z-1.0000 S1000
    G1 F1000 X30.7625 Y74.8107 Z-1.0000 S1000
    G1 F1000 X30.8342 Y74.6684 Z-1.0000 S1000
    G1 F1000 X30.8987 Y74.5227 Z-1.0000 S1000
    G1 F1000 X30.9558 Y74.3739 Z-1.0000 S1000
    G1 F1000 X31.0054 Y74.2225 Z-1.0000 S1000
    G1 F1000 X31.0474 Y74.0688 Z-1.0000 S1000
    G1 F1000 X31.0815 Y73.9131 Z-1.0000 S1000
    G1 F1000 X31.1078 Y73.7559 Z-1.0000 S1000
    G1 F1000 X31.1262 Y73.5976 Z-1.0000 S1000
    G1 F1000 X31.1366 Y73.4386 Z-1.0000 S1000
    G1 F1000 X31.1390 Y73.2793 Z-1.0000 S1000
    G1 F1000 X31.1335 Y73.1200 Z-1.0000 S1000
    G1 F1000 X31.1199 Y72.9612 Z-1.0000 S1000
    G1 F1000 X31.0984 Y72.8033 Z-1.0000 S1000
    G1 F1000 X31.0690 Y72.6467 Z-1.0000 S1000
    G1 F1000 X31.0318 Y72.4917 Z-1.0000 S1000
    G1 F1000 X30.9868 Y72.3388 Z-1.0000 S1000
    G1 F1000 X30.9343 Y72.1884 Z-1.0000 S1000
    G1 F1000 X30.8742 Y72.0408 Z-1.0000 S1000
    G1 F1000 X30.8068 Y71.8964 Z-1.0000 S1000
    G1 F1000 X30.7323 Y71.7555 Z-1.0000 S1000
    G1 F1000 X30.6271 Y71.5816 Z-1.0000 S1000
    G1 F1000 X29.2032 Y69.3886 Z-1.0000 S1000
    G1 F1000 X27.1262 Y63.9784 Z-1.0000 S1000
    G1 F1000 X26.9660 Y62.9674 Z-1.0000 S1000
    G1 F1000 X26.9371 Y62.8106 Z-1.0000 S1000
    G1 F1000 X26.9004 Y62.6556 Z-1.0000 S1000
    G1 F1000 X26.8560 Y62.5025 Z-1.0000 S1000
    G1 F1000 X26.8039 Y62.3519 Z-1.0000 S1000
    G1 F1000 X26.7443 Y62.2041 Z-1.0000 S1000
    G1 F1000 X26.6774 Y62.0595 Z-1.0000 S1000
    G1 F1000 X26.6034 Y61.9184 Z-1.0000 S1000
    G1 F1000 X26.5223 Y61.7811 Z-1.0000 S1000
    G1 F1000 X26.4345 Y61.6482 Z-1.0000 S1000
    G1 F1000 X26.3401 Y61.5198 Z-1.0000 S1000
    G1 F1000 X26.2393 Y61.3963 Z-1.0000 S1000
    G1 F1000 X26.1325 Y61.2780 Z-1.0000 S1000
    G1 F1000 X26.0199 Y61.1652 Z-1.0000 S1000
    G1 F1000 X25.9018 Y61.0583 Z-1.0000 S1000
    G1 F1000 X25.7785 Y60.9573 Z-1.0000 S1000
    G1 F1000 X25.6503 Y60.8627 Z-1.0000 S1000
    G1 F1000 X25.5174 Y60.7747 Z-1.0000 S1000
    G1 F1000 X25.3804 Y60.6934 Z-1.0000 S1000
    G1 F1000 X25.2394 Y60.6191 Z-1.0000 S1000
    G1 F1000 X25.0948 Y60.5520 Z-1.0000 S1000
    G1 F1000 X24.9471 Y60.4922 Z-1.0000 S1000
    G1 F1000 X24.7966 Y60.4399 Z-1.0000 S1000
    G1 F1000 X24.6436 Y60.3952 Z-1.0000 S1000
    G1 F1000 X24.4886 Y60.3582 Z-1.0000 S1000
    G1 F1000 X24.2816 Y60.3215 Z-1.0000 S1000
    G1 F1000 X17.3327 Y59.3231 Z-1.0000 S1000
    G1 F1000 X17.3327 Y54.2864 Z-1.0000 S1000
    G1 F1000 X24.3111 Y53.2840 Z-1.0000 S1000
    G1 F1000 X24.4682 Y53.2574 Z-1.0000 S1000
    G1 F1000 X24.6238 Y53.2230 Z-1.0000 S1000
    G1 F1000 X24.7775 Y53.1808 Z-1.0000 S1000
    G1 F1000 X24.9289 Y53.1309 Z-1.0000 S1000
    G1 F1000 X25.0775 Y53.0735 Z-1.0000 S1000
    G1 F1000 X25.2231 Y53.0087 Z-1.0000 S1000
    G1 F1000 X25.3653 Y52.9366 Z-1.0000 S1000
    G1 F1000 X25.5036 Y52.8576 Z-1.0000 S1000
    G1 F1000 X25.6379 Y52.7717 Z-1.0000 S1000
    G1 F1000 X25.7676 Y52.6791 Z-1.0000 S1000
    G1 F1000 X25.8925 Y52.5802 Z-1.0000 S1000
    G1 F1000 X26.0123 Y52.4751 Z-1.0000 S1000
    G1 F1000 X26.1267 Y52.3642 Z-1.0000 S1000
    G1 F1000 X26.2354 Y52.2476 Z-1.0000 S1000
    G1 F1000 X26.3381 Y52.1258 Z-1.0000 S1000
    G1 F1000 X26.4346 Y51.9989 Z-1.0000 S1000
    G1 F1000 X26.5245 Y51.8674 Z-1.0000 S1000
    G1 F1000 X26.6078 Y51.7315 Z-1.0000 S1000
    G1 F1000 X26.6841 Y51.5916 Z-1.0000 S1000
    G1 F1000 X26.7533 Y51.4480 Z-1.0000 S1000
    G1 F1000 X26.8152 Y51.3012 Z-1.0000 S1000
    G1 F1000 X26.8697 Y51.1514 Z-1.0000 S1000
    G1 F1000 X26.9265 Y50.9630 Z-1.0000 S1000
    G1 F1000 X28.0226 Y46.8720 Z-1.0000 S1000
    G1 F1000 X30.7005 Y41.6162 Z-1.0000 S1000
    G1 F1000 X30.7692 Y41.4724 Z-1.0000 S1000
    G1 F1000 X30.8307 Y41.3254 Z-1.0000 S1000
    G1 F1000 X30.8847 Y41.1754 Z-1.0000 S1000
    G1 F1000 X30.9311 Y41.0230 Z-1.0000 S1000
    G1 F1000 X30.9698 Y40.8684 Z-1.0000 S1000
    G1 F1000 X31.0007 Y40.7121 Z-1.0000 S1000
    G1 F1000 X31.0237 Y40.5544 Z-1.0000 S1000
    G1 F1000 X31.0388 Y40.3957 Z-1.0000 S1000
    G1 F1000 X31.0459 Y40.2365 Z-1.0000 S1000
    G1 F1000 X31.0450 Y40.0772 Z-1.0000 S1000
    G1 F1000 X31.0361 Y39.9180 Z-1.0000 S1000
    G1 F1000 X31.0192 Y39.7596 Z-1.0000 S1000
    G1 F1000 X30.9944 Y39.6022 Z-1.0000 S1000
    G1 F1000 X30.9618 Y39.4462 Z-1.0000 S1000
    G1 F1000 X30.9213 Y39.2920 Z-1.0000 S1000
    G1 F1000 X30.8732 Y39.1401 Z-1.0000 S1000
    G1 F1000 X30.8175 Y38.9908 Z-1.0000 S1000
    G1 F1000 X30.7544 Y38.8445 Z-1.0000 S1000
    G1 F1000 X30.6840 Y38.7015 Z-1.0000 S1000
    G1 F1000 X30.6065 Y38.5622 Z-1.0000 S1000
    G1 F1000 X30.5222 Y38.4270 Z-1.0000 S1000
    G1 F1000 X30.4130 Y38.2718 Z-1.0000 S1000
    G1 F1000 X26.2623 Y32.7285 Z-1.0000 S1000
    G1 F1000 X29.8238 Y29.1671 Z-1.0000 S1000
    G1 F1000 X35.3671 Y33.3177 Z-1.0000 S1000
    G1 F1000 X35.4970 Y33.4100 Z-1.0000 S1000
    G1 F1000 X35.6314 Y33.4957 Z-1.0000 S1000
    G1 F1000 X35.7700 Y33.5744 Z-1.0000 S1000
    G1 F1000 X35.9123 Y33.6462 Z-1.0000 S1000
    G1 F1000 X36.0580 Y33.7107 Z-1.0000 S1000
    G1 F1000 X36.2067 Y33.7678 Z-1.0000 S1000
    G1 F1000 X36.3582 Y33.8174 Z-1.0000 S1000
    G1 F1000 X36.5119 Y33.8594 Z-1.0000 S1000
    G1 F1000 X36.6676 Y33.8935 Z-1.0000 S1000
    G1 F1000 X36.8248 Y33.9198 Z-1.0000 S1000
    G1 F1000 X36.9831 Y33.9382 Z-1.0000 S1000
    G1 F1000 X37.1421 Y33.9486 Z-1.0000 S1000
    G1 F1000 X37.3014 Y33.9510 Z-1.0000 S1000
    G1 F1000 X37.4607 Y33.9455 Z-1.0000 S1000
    G1 F1000 X37.6195 Y33.9319 Z-1.0000 S1000
    G1 F1000 X37.7774 Y33.9104 Z-1.0000 S1000
    G1 F1000 X37.9340 Y33.8810 Z-1.0000 S1000
    G1 F1000 X38.0890 Y33.8438 Z-1.0000 S1000
    G1 F1000 X38.2418 Y33.7988 Z-1.0000 S1000
    G1 F1000 X38.3923 Y33.7463 Z-1.0000 S1000
    G1 F1000 X38.5399 Y33.6862 Z-1.0000 S1000
    G1 F1000 X38.7116 Y33.6051 Z-1.0000 S1000
    G1 F1000 X40.2177 Y32.8376 Z-1.0000 S1000
    G1 F1000 X45.9160 Y45.0577 Z-1.0000 S1000
    G1 F1000 X45.8895 Y45.0785 Z-1.0000 S1000
    G1 F1000 X44.0958 Y46.5308 Z-1.0000 S1000
    G1 F1000 X43.9745 Y46.6342 Z-1.0000 S1000
    G1 F1000 X43.8585 Y46.7435 Z-1.0000 S1000
    G1 F1000 X43.7482 Y46.8585 Z-1.0000 S1000
    G1 F1000 X43.6261 Y47.0005 Z-1.0000 S1000
    G1 F1000 X42.1738 Y48.7942 Z-1.0000 S1000
    G1 F1000 X42.0767 Y48.9205 Z-1.0000 S1000
    G1 F1000 X41.9860 Y49.0516 Z-1.0000 S1000
    G1 F1000 X41.9020 Y49.1870 Z-1.0000 S1000
    G1 F1000 X41.8124 Y49.3508 Z-1.0000 S1000
    G1 F1000 X40.7649 Y51.4068 Z-1.0000 S1000
    G1 F1000 X40.6961 Y51.5505 Z-1.0000 S1000
    G1 F1000 X40.6347 Y51.6976 Z-1.0000 S1000
    G1 F1000 X40.5807 Y51.8475 Z-1.0000 S1000
    G1 F1000 X40.5270 Y52.0265 Z-1.0000 S1000
    G1 F1000 X39.9296 Y54.2565 Z-1.0000 S1000
    G1 F1000 X39.8923 Y54.4114 Z-1.0000 S1000
    G1 F1000 X39.8627 Y54.5680 Z-1.0000 S1000
    G1 F1000 X39.8411 Y54.7259 Z-1.0000 S1000
    G1 F1000 X39.8259 Y54.9116 Z-1.0000 S1000
    G1 F1000 X39.7049 Y57.2162 Z-1.0000 S1000
    G1 F1000 X39.7005 Y57.3755 Z-1.0000 S1000
    G1 F1000 X39.7041 Y57.5349 Z-1.0000 S1000
    G1 F1000 X39.7158 Y57.6938 Z-1.0000 S1000
    G1 F1000 X39.7396 Y57.8796 Z-1.0000 S1000
    G1 F1000 X40.1008 Y60.1591 Z-1.0000 S1000
    G1 F1000 X40.1297 Y60.3158 Z-1.0000 S1000
    G1 F1000 X40.1664 Y60.4709 Z-1.0000 S1000
    G1 F1000 X40.2109 Y60.6239 Z-1.0000 S1000
    G1 F1000 X40.2726 Y60.8001 Z-1.0000 S1000
    G1 F1000 X41.0997 Y62.9545 Z-1.0000 S1000
    G1 F1000 X41.1606 Y63.1018 Z-1.0000 S1000
    G1 F1000 X41.2287 Y63.2459 Z-1.0000 S1000
    G1 F1000 X41.3040 Y63.3863 Z-1.0000 S1000
    G1 F1000 X41.4012 Y63.5461 Z-1.0000 S1000
    G1 F1000 X42.6584 Y65.4816 Z-1.0000 S1000
    G1 F1000 X42.7485 Y65.6130 Z-1.0000 S1000
    G1 F1000 X42.8451 Y65.7397 Z-1.0000 S1000
    G1 F1000 X42.9480 Y65.8615 Z-1.0000 S1000
    G1 F1000 X43.0759 Y65.9972 Z-1.0000 S1000
    G1 F1000 X44.7075 Y67.6288 Z-1.0000 S1000
    G1 F1000 X44.8230 Y67.7386 Z-1.0000 S1000
    G1 F1000 X44.9439 Y67.8425 Z-1.0000 S1000
    G1 F1000 X45.0698 Y67.9402 Z-1.0000 S1000
    G1 F1000 X45.2231 Y68.0463 Z-1.0000 S1000
    G1 F1000 X47.1586 Y69.3035 Z-1.0000 S1000
    G1 F1000 X47.2944 Y69.3869 Z-1.0000 S1000
    G1 F1000 X47.4342 Y69.4634 Z-1.0000 S1000
    G1 F1000 X47.5776 Y69.5328 Z-1.0000 S1000
    G1 F1000 X47.7502 Y69.6050 Z-1.0000 S1000
    G1 F1000 X49.9046 Y70.4321 Z-1.0000 S1000
    G1 F1000 X50.0547 Y70.4854 Z-1.0000 S1000
    G1 F1000 X50.2074 Y70.5312 Z-1.0000 S1000
    G1 F1000 X50.3621 Y70.5692 Z-1.0000 S1000
    G1 F1000 X50.5456 Y70.6039 Z-1.0000 S1000
    G1 F1000 X52.8251 Y70.9651 Z-1.0000 S1000
    G1 F1000 X52.9831 Y70.9861 Z-1.0000 S1000
    G1 F1000 X53.1419 Y70.9991 Z-1.0000 S1000
    G1 F1000 X53.3012 Y71.0041 Z-1.0000 S1000
    G1 F1000 X53.4885 Y70.9998 Z-1.0000 S1000
    G1 F1000 X55.7931 Y70.8788 Z-1.0000 S1000
    G1 F1000 X55.9520 Y70.8665 Z-1.0000 S1000
    G1 F1000 X56.1100 Y70.8462 Z-1.0000 S1000
    G1 F1000 X56.2669 Y70.8180 Z-1.0000 S1000
    G1 F1000 X56.4482 Y70.7751 Z-1.0000 S1000
    G1 F1000 X58.6782 Y70.1777 Z-1.0000 S1000
    G1 F1000 X58.8310 Y70.1326 Z-1.0000 S1000
    G1 F1000 X58.9814 Y70.0799 Z-1.0000 S1000
    G1 F1000 X59.1290 Y70.0197 Z-1.0000 S1000
    G1 F1000 X59.2979 Y69.9398 Z-1.0000 S1000
    G1 F1000 X61.3539 Y68.8923 Z-1.0000 S1000
    G1 F1000 X61.4941 Y68.8164 Z-1.0000 S1000
    G1 F1000 X61.6302 Y68.7336 Z-1.0000 S1000
    G1 F1000 X61.7620 Y68.6440 Z-1.0000 S1000
    G1 F1000 X61.9105 Y68.5309 Z-1.0000 S1000
    G1 F1000 X63.7042 Y67.0786 Z-1.0000 S1000
    G1 F1000 X63.8255 Y66.9752 Z-1.0000 S1000
    G1 F1000 X63.9415 Y66.8659 Z-1.0000 S1000
    G1 F1000 X64.0518 Y66.7509 Z-1.0000 S1000
    G1 F1000 X64.1739 Y66.6089 Z-1.0000 S1000
    G1 F1000 X65.6262 Y64.8152 Z-1.0000 S1000
    G1 F1000 X65.7233 Y64.6889 Z-1.0000 S1000
    G1 F1000 X65.8140 Y64.5578 Z-1.0000 S1000
    G1 F1000 X65.8980 Y64.4224 Z-1.0000 S1000
    G1 F1000 X65.9876 Y64.2586 Z-1.0000 S1000
    G1 F1000 X67.0351 Y62.2026 Z-1.0000 S1000
    G1 F1000 X67.1039 Y62.0589 Z-1.0000 S1000
    G1 F1000 X67.1653 Y61.9118 Z-1.0000 S1000
    G1 F1000 X67.2193 Y61.7619 Z-1.0000 S1000
    G1 F1000 X67.2730 Y61.5829 Z-1.0000 S1000
    G1 F1000 X67.8704 Y59.3529 Z-1.0000 S1000
    G1 F1000 X67.9077 Y59.1980 Z-1.0000 S1000
    G1 F1000 X67.9373 Y59.0414 Z-1.0000 S1000
    G1 F1000 X67.9589 Y58.8835 Z-1.0000 S1000
    G1 F1000 X67.9741 Y58.6978 Z-1.0000 S1000
    G1 F1000 X68.0951 Y56.3932 Z-1.0000 S1000
    G1 F1000 X68.0995 Y56.2339 Z-1.0000 S1000
    G1 F1000 X68.0959 Y56.0745 Z-1.0000 S1000
    G1 F1000 X68.0842 Y55.9156 Z-1.0000 S1000
    G1 F1000 X68.0604 Y55.7298 Z-1.0000 S1000
    G1 F1000 X67.6992 Y53.4503 Z-1.0000 S1000
    G1 F1000 X67.6703 Y53.2936 Z-1.0000 S1000
    G1 F1000 X67.6336 Y53.1385 Z-1.0000 S1000
    G1 F1000 X67.5891 Y52.9855 Z-1.0000 S1000
    G1 F1000 X67.5274 Y52.8093 Z-1.0000 S1000
    G1 F1000 X66.7003 Y50.6549 Z-1.0000 S1000
    G1 F1000 X66.6394 Y50.5076 Z-1.0000 S1000
    G1 F1000 X66.5713 Y50.3635 Z-1.0000 S1000
    G1 F1000 X66.4960 Y50.2231 Z-1.0000 S1000
    G1 F1000 X66.3988 Y50.0633 Z-1.0000 S1000
    G1 F1000 X65.1416 Y48.1278 Z-1.0000 S1000
    G1 F1000 X65.0515 Y47.9964 Z-1.0000 S1000
    G1 F1000 X64.9549 Y47.8697 Z-1.0000 S1000
    G1 F1000 X64.8520 Y47.7479 Z-1.0000 S1000
    G1 F1000 X64.7241 Y47.6122 Z-1.0000 S1000
    G1 F1000 X63.0925 Y45.9806 Z-1.0000 S1000
    G1 F1000 X62.9770 Y45.8708 Z-1.0000 S1000
    G1 F1000 X62.8561 Y45.7669 Z-1.0000 S1000
    G1 F1000 X62.7302 Y45.6692 Z-1.0000 S1000
    G1 F1000 X62.6286 Y45.5989 Z-1.0000 S1000
    G1 F700 Z-2.0000
    G1 F1000 X68.3534 Y33.3218 Z-2.0000 S1000
    G1 F1000 X68.6768 Y33.5318 Z-2.0000 S1000
    G1 F1000 X68.8126 Y33.6152 Z-2.0000 S1000
    G1 F1000 X68.9524 Y33.6917 Z-2.0000 S1000
    G1 F1000 X69.0958 Y33.7611 Z-2.0000 S1000
    G1 F1000 X69.2426 Y33.8232 Z-2.0000 S1000
    G1 F1000 X69.3923 Y33.8778 Z-2.0000 S1000
    G1 F1000 X69.5446 Y33.9249 Z-2.0000 S1000
    G1 F1000 X69.6990 Y33.9642 Z-2.0000 S1000
    G1 F1000 X69.8552 Y33.9958 Z-2.0000 S1000
    G1 F1000 X70.0128 Y34.0195 Z-2.0000 S1000
    G1 F1000 X70.1714 Y34.0352 Z-2.0000 S1000
    G1 F1000 X70.3305 Y34.0430 Z-2.0000 S1000
    G1 F1000 X70.4899 Y34.0428 Z-2.0000 S1000
    G1 F1000 X70.6490 Y34.0346 Z-2.0000 S1000
    G1 F1000 X70.8076 Y34.0184 Z-2.0000 S1000
    G1 F1000 X70.9651 Y33.9942 Z-2.0000 S1000
    G1 F1000 X71.1212 Y33.9622 Z-2.0000 S1000
    G1 F1000 X71.2755 Y33.9225 Z-2.0000 S1000
    G1 F1000 X71.4276 Y33.8750 Z-2.0000 S1000
    G1 F1000 X71.5772 Y33.8199 Z-2.0000 S1000
    G1 F1000 X71.7238 Y33.7574 Z-2.0000 S1000
    G1 F1000 X71.8671 Y33.6876 Z-2.0000 S1000
    G1 F1000 X72.0067 Y33.6108 Z-2.0000 S1000
    G1 F1000 X72.1422 Y33.5270 Z-2.0000 S1000
    G1 F1000 X72.3087 Y33.4105 Z-2.0000 S1000
    G1 F1000 X77.9762 Y29.1671 Z-2.0000 S1000
    G1 F1000 X81.5377 Y32.7286 Z-2.0000 S1000
    G1 F1000 X77.2943 Y38.3960 Z-2.0000 S1000
    G1 F1000 X77.2020 Y38.5259 Z-2.0000 S1000
    G1 F1000 X77.1163 Y38.6603 Z-2.0000 S1000
    G1 F1000 X77.0375 Y38.7988 Z-2.0000 S1000
    G1 F1000 X76.9658 Y38.9411 Z-2.0000 S1000
    G1 F1000 X76.9013 Y39.0868 Z-2.0000 S1000
    G1 F1000 X76.8442 Y39.2356 Z-2.0000 S1000
    G1 F1000 X76.7946 Y39.3870 Z-2.0000 S1000
    G1 F1000 X76.7526 Y39.5408 Z-2.0000 S1000
    G1 F1000 X76.7185 Y39.6964 Z-2.0000 S1000
    G1 F1000 X76.6922 Y39.8536 Z-2.0000 S1000
    G1 F1000 X76.6738 Y40.0119 Z-2.0000 S1000
    G1 F1000 X76.6634 Y40.1709 Z-2.0000 S1000
    G1 F1000 X76.6610 Y40.3303 Z-2.0000 S1000
    G1 F1000 X76.6665 Y40.4895 Z-2.0000 S1000
    G1 F1000 X76.6801 Y40.6483 Z-2.0000 S1000
    G1 F1000 X76.7016 Y40.8062 Z-2.0000 S1000
    G1 F1000 X76.7310 Y40.9628 Z-2.0000 S1000
    G1 F1000 X76.7682 Y41.1178 Z-2.0000 S1000
    G1 F1000 X76.8132 Y41.2707 Z-2.0000 S1000
    G1 F1000 X76.8657 Y41.4211 Z-2.0000 S1000
    G1 F1000 X76.9258 Y41.5687 Z-2.0000 S1000
    G1 F1000 X76.9932 Y41.7131 Z-2.0000 S1000
    G1 F1000 X77.0677 Y41.8540 Z-2.0000 S1000
    G1 F1000 X77.1729 Y42.0279 Z-2.0000 S1000
    G1 F1000 X78.5968 Y44.2209 Z-2.0000 S1000
    G1 F1000 X80.6738 Y49.6310 Z-2.0000 S1000
    G1 F1000 X80.8340 Y50.6420 Z-2.0000 S1000
    G1 F1000 X80.8629 Y50.7988 Z-2.0000 S1000
    G1 F1000 X80.8996 Y50.9538 Z-2.0000 S1000
    G1 F1000 X80.9440 Y51.1069 Z-2.0000 S1000
    G1 F1000 X80.9961 Y51.2575 Z-2.0000 S1000
    G1 F1000 X81.0557 Y51.4053 Z-2.0000 S1000
    G1 F1000 X81.1226 Y51.5499 Z-2.0000 S1000
    G1 F1000 X81.1966 Y51.6910 Z-2.0000 S1000
    G1 F1000 X81.2777 Y51.8283 Z-2.0000 S1000
    G1 F1000 X81.3655 Y51.9612 Z-2.0000 S1000
    G1 F1000 X81.4599 Y52.0896 Z-2.0000 S1000
    G1 F1000 X81.5607 Y52.2131 Z-2.0000 S1000
    G1 F1000 X81.6675 Y52.3314 Z-2.0000 S1000
    G1 F1000 X81.7801 Y52.4442 Z-2.0000 S1000
    G1 F1000 X81.8982 Y52.5511 Z-2.0000 S1000
    G1 F1000 X82.0215 Y52.6521 Z-2.0000 S1000
    G1 F1000 X82.1497 Y52.7467 Z-2.0000 S1000
    G1 F1000 X82.2826 Y52.8347 Z-2.0000 S1000
    G1 F1000 X82.4196 Y52.9160 Z-2.0000 S1000
    G1 F1000 X82.5606 Y52.9903 Z-2.0000 S1000
    G1 F1000 X82.7052 Y53.0574 Z-2.0000 S1000
    G1 F1000 X82.8529 Y53.1172 Z-2.0000 S1000
    G1 F1000 X83.0034 Y53.1695 Z-2.0000 S1000
    G1 F1000 X83.1564 Y53.2142 Z-2.0000 S1000
    G1 F1000 X83.3114 Y53.2512 Z-2.0000 S1000
    G1 F1000 X83.5184 Y53.2879 Z-2.0000 S1000
    G1 F1000 X90.4673 Y54.2863 Z-2.0000 S1000
    G1 F1000 X90.4673 Y59.3230 Z-2.0000 S1000
    G1 F1000 X83.4888 Y60.3255 Z-2.0000 S1000
    G1 F1000 X83.3317 Y60.3521 Z-2.0000 S1000
    G1 F1000 X83.1761 Y60.3865 Z-2.0000 S1000
    G1 F1000 X83.0225 Y60.4288 Z-2.0000 S1000
    G1 F1000 X82.8711 Y60.4786 Z-2.0000 S1000
    G1 F1000 X82.7225 Y60.5361 Z-2.0000 S1000
    G1 F1000 X82.5769 Y60.6009 Z-2.0000 S1000
    G1 F1000 X82.4347 Y60.6729 Z-2.0000 S1000
    G1 F1000 X82.2963 Y60.7519 Z-2.0000 S1000
    G1 F1000 X82.1621 Y60.8379 Z-2.0000 S1000
    G1 F1000 X82.0324 Y60.9304 Z-2.0000 S1000
    G1 F1000 X81.9074 Y61.0293 Z-2.0000 S1000
    G1 F1000 X81.7876 Y61.1344 Z-2.0000 S1000
    G1 F1000 X81.6732 Y61.2454 Z-2.0000 S1000
    G1 F1000 X81.5646 Y61.3619 Z-2.0000 S1000
    G1 F1000 X81.4619 Y61.4838 Z-2.0000 S1000
    G1 F1000 X81.3654 Y61.6106 Z-2.0000 S1000
    G1 F1000 X81.2754 Y61.7422 Z-2.0000 S1000
    G1 F1000 X81.1922 Y61.8781 Z-2.0000 S1000
    G1 F1000 X81.1159 Y62.0179 Z-2.0000 S1000
    G1 F1000 X81.0467 Y62.1615 Z-2.0000 S1000
    G1 F1000 X80.9847 Y62.3083 Z-2.0000 S1000
    G1 F1000 X80.9303 Y62.4581 Z-2.0000 S1000
    G1 F1000 X80.8735 Y62.6465 Z-2.0000 S1000
    G1 F1000 X79.7774 Y66.7374 Z-2.0000 S1000
    G1 F1000 X77.0995 Y71.9932 Z-2.0000 S1000
    G1 F1000 X77.0308 Y72.1370 Z-2.0000 S1000
    G1 F1000 X76.9693 Y72.2840 Z-2.0000 S1000
    G1 F1000 X76.9153 Y72.4339 Z-2.0000 S1000
    G1 F1000 X76.8689 Y72.5864 Z-2.0000 S1000
    G1 F1000 X76.8302 Y72.7410 Z-2.0000 S1000
    G1 F1000 X76.7993 Y72.8973 Z-2.0000 S1000
    G1 F1000 X76.7763 Y73.0550 Z-2.0000 S1000
    G1 F1000 X76.7612 Y73.2137 Z-2.0000 S1000
    G1 F1000 X76.7541 Y73.3729 Z-2.0000 S1000
    G1 F1000 X76.7550 Y73.5322 Z-2.0000 S1000
    G1 F1000 X76.7639 Y73.6913 Z-2.0000 S1000
    G1 F1000 X76.7808 Y73.8498 Z-2.0000 S1000
    G1 F1000 X76.8056 Y74.0072 Z-2.0000 S1000
    G1 F1000 X76.8382 Y74.1632 Z-2.0000 S1000
    G1 F1000 X76.8787 Y74.3173 Z-2.0000 S1000
    G1 F1000 X76.9268 Y74.4693 Z-2.0000 S1000
    G1 F1000 X76.9825 Y74.6186 Z-2.0000 S1000
    G1 F1000 X77.0456 Y74.7649 Z-2.0000 S1000
    G1 F1000 X77.1160 Y74.9079 Z-2.0000 S1000
    G1 F1000 X77.1935 Y75.0471 Z-2.0000 S1000
    G1 F1000 X77.2778 Y75.1823 Z-2.0000 S1000
    G1 F1000 X77.3870 Y75.3376 Z-2.0000 S1000
    G1 F1000 X81.5376 Y80.8809 Z-2.0000 S1000
    G1 F1000 X77.9762 Y84.4423 Z-2.0000 S1000
    G1 F1000 X72.4329 Y80.2917 Z-2.0000 S1000
    G1 F1000 X72.3030 Y80.1994 Z-2.0000 S1000
    G1 F1000 X72.1686 Y80.1138 Z-2.0000 S1000
    G1 F1000 X72.0301 Y80.0350 Z-2.0000 S1000
    G1 F1000 X71.8878 Y79.9632 Z-2.0000 S1000
    G1 F1000 X71.7421 Y79.8987 Z-2.0000 S1000
    G1 F1000 X71.5933 Y79.8416 Z-2.0000 S1000
    G1 F1000 X71.4418 Y79.7920 Z-2.0000 S1000
    G1 F1000 X71.2881 Y79.7501 Z-2.0000 S1000
    G1 F1000 X71.1324 Y79.7159 Z-2.0000 S1000
    G1 F1000 X70.9753 Y79.6896 Z-2.0000 S1000
    G1 F1000 X70.8170 Y79.6712 Z-2.0000 S1000
    G1 F1000 X70.6579 Y79.6608 Z-2.0000 S1000
    G1 F1000 X70.4986 Y79.6584 Z-2.0000 S1000
    G1 F1000 X70.3393 Y79.6639 Z-2.0000 S1000
    G1 F1000 X70.1805 Y79.6775 Z-2.0000 S1000
    G1 F1000 X70.0226 Y79.6990 Z-2.0000 S1000
    G1 F1000 X69.8660 Y79.7284 Z-2.0000 S1000
    G1 F1000 X69.7111 Y79.7656 Z-2.0000 S1000
    G1 F1000 X69.5582 Y79.8106 Z-2.0000 S1000
    G1 F1000 X69.4077 Y79.8631 Z-2.0000 S1000
    G1 F1000 X69.2601 Y79.9232 Z-2.0000 S1000
    G1 F1000 X69.0885 Y80.0042 Z-2.0000 S1000
    G1 F1000 X63.8327 Y82.6821 Z-2.0000 S1000
    G1 F1000 X59.7418 Y83.7782 Z-2.0000 S1000
    G1 F1000 X59.5889 Y83.8233 Z-2.0000 S1000
    G1 F1000 X59.4385 Y83.8760 Z-2.0000 S1000
    G1 F1000 X59.2910 Y83.9362 Z-2.0000 S1000
    G1 F1000 X59.1466 Y84.0037 Z-2.0000 S1000
    G1 F1000 X59.0058 Y84.0784 Z-2.0000 S1000
    G1 F1000 X58.8690 Y84.1600 Z-2.0000 S1000
    G1 F1000 X58.7364 Y84.2484 Z-2.0000 S1000
    G1 F1000 X58.6084 Y84.3434 Z-2.0000 S1000
    G1 F1000 X58.4853 Y84.4446 Z-2.0000 S1000
    G1 F1000 X58.3675 Y84.5519 Z-2.0000 S1000
    G1 F1000 X58.2552 Y84.6650 Z-2.0000 S1000
    G1 F1000 X58.1487 Y84.7836 Z-2.0000 S1000
    G1 F1000 X58.0483 Y84.9073 Z-2.0000 S1000
    G1 F1000 X57.9543 Y85.0360 Z-2.0000 S1000
    G1 F1000 X57.8668 Y85.1692 Z-2.0000 S1000
    G1 F1000 X57.7861 Y85.3066 Z-2.0000 S1000
    G1 F1000 X57.7124 Y85.4479 Z-2.0000 S1000
    G1 F1000 X57.6459 Y85.5927 Z-2.0000 S1000
    G1 F1000 X57.5867 Y85.7407 Z-2.0000 S1000
    G1 F1000 X57.5351 Y85.8914 Z-2.0000 S1000
    G1 F1000 X57.4910 Y86.0446 Z-2.0000 S1000
    G1 F1000 X57.4548 Y86.1998 Z-2.0000 S1000
    G1 F1000 X57.4208 Y86.3935 Z-2.0000 S1000
    G1 F1000 X56.4183 Y93.3720 Z-2.0000 S1000
    G1 F1000 X51.3816 Y93.3720 Z-2.0000 S1000
    G1 F1000 X50.3832 Y86.4231 Z-2.0000 S1000
    G1 F1000 X50.3566 Y86.2659 Z-2.0000 S1000
    G1 F1000 X50.3221 Y86.1104 Z-2.0000 S1000
    G1 F1000 X50.2799 Y85.9567 Z-2.0000 S1000
    G1 F1000 X50.2300 Y85.8053 Z-2.0000 S1000
    G1 F1000 X50.1726 Y85.6567 Z-2.0000 S1000
    G1 F1000 X50.1078 Y85.5111 Z-2.0000 S1000
    G1 F1000 X50.0358 Y85.3689 Z-2.0000 S1000
    G1 F1000 X49.9567 Y85.2306 Z-2.0000 S1000
    G1 F1000 X49.8708 Y85.0964 Z-2.0000 S1000
    G1 F1000 X49.7783 Y84.9666 Z-2.0000 S1000
    G1 F1000 X49.6793 Y84.8417 Z-2.0000 S1000
    G1 F1000 X49.5742 Y84.7219 Z-2.0000 S1000
    G1 F1000 X49.4633 Y84.6075 Z-2.0000 S1000
    G1 F1000 X49.3467 Y84.4988 Z-2.0000 S1000
    G1 F1000 X49.2249 Y84.3961 Z-2.0000 S1000
    G1 F1000 X49.0980 Y84.2997 Z-2.0000 S1000
    G1 F1000 X48.9665 Y84.2097 Z-2.0000 S1000
    G1 F1000 X48.8306 Y84.1265 Z-2.0000 S1000
    G1 F1000 X48.6907 Y84.0501 Z-2.0000 S1000
    G1 F1000 X48.5471 Y83.9809 Z-2.0000 S1000
    G1 F1000 X48.4003 Y83.9190 Z-2.0000 S1000
    G1 F1000 X48.2505 Y83.8645 Z-2.0000 S1000
    G1 F1000 X48.0982 Y83.8177 Z-2.0000 S1000
    G1 F1000 X47.9438 Y83.7785 Z-2.0000 S1000
    G1 F1000 X47.7373 Y83.7387 Z-2.0000 S1000
    G1 F1000 X46.7263 Y83.5785 Z-2.0000 S1000
    G1 F1000 X41.3162 Y81.5015 Z-2.0000 S1000
    G1 F1000 X39.1232 Y80.0776 Z-2.0000 S1000
    G1 F1000 X38.9874 Y79.9942 Z-2.0000 S1000
    G1 F1000 X38.8476 Y79.9177 Z-2.0000 S1000
    G1 F1000 X38.7042 Y79.8483 Z-2.0000 S1000
    G1 F1000 X38.5574 Y79.7862 Z-2.0000 S1000
    G1 F1000 X38.4077 Y79.7316 Z-2.0000 S1000
    G1 F1000 X38.2554 Y79.6845 Z-2.0000 S1000
    G1 F1000 X38.1010 Y79.6452 Z-2.0000 S1000
    G1 F1000 X37.9448 Y79.6136 Z-2.0000 S1000
    G1 F1000 X37.7872 Y79.5899 Z-2.0000 S1000
    G1 F1000 X37.6286 Y79.5742 Z-2.0000 S1000
    G1 F1000 X37.4695 Y79.5664 Z-2.0000 S1000
    G1 F1000 X37.3101 Y79.5666 Z-2.0000 S1000
    G1 F1000 X37.1510 Y79.5748 Z-2.0000 S1000
    G1 F1000 X36.9924 Y79.5910 Z-2.0000 S1000
    G1 F1000 X36.8349 Y79.6152 Z-2.0000 S1000
    G1 F1000 X36.6788 Y79.6472 Z-2.0000 S1000
    G1 F1000 X36.5245 Y79.6869 Z-2.0000 S1000
    G1 F1000 X36.3724 Y79.7344 Z-2.0000 S1000
    G1 F1000 X36.2228 Y79.7895 Z-2.0000 S1000
    G1 F1000 X36.0762 Y79.8520 Z-2.0000 S1000
    G1 F1000 X35.9329 Y79.9218 Z-2.0000 S1000
    G1 F1000 X35.7933 Y79.9986 Z-2.0000 S1000
    G1 F1000 X35.6578 Y80.0824 Z-2.0000 S1000
    G1 F1000 X35.4913 Y80.1990 Z-2.0000 S1000
    G1 F1000 X29.8239 Y84.4424 Z-2.0000 S1000
    G1 F1000 X26.2624 Y80.8809 Z-2.0000 S1000
    G1 F1000 X30.5057 Y75.2136 Z-2.0000 S1000
    G1 F1000 X30.5980 Y75.0836 Z-2.0000 S1000
    G1 F1000 X30.6837 Y74.9493 Z-2.0000 S1000
    G1 F1000 X30.7625 Y74.8107 Z-2.0000 S1000
    G1 F1000 X30.8342 Y74.6684 Z-2.0000 S1000
    G1 F1000 X30.8987 Y74.5227 Z-2.0000 S1000
    G1 F1000 X30.9558 Y74.3739 Z-2.0000 S1000
    G1 F1000 X31.0054 Y74.2225 Z-2.0000 S1000
    G1 F1000 X31.0474 Y74.0688 Z-2.0000 S1000
    G1 F1000 X31.0815 Y73.9131 Z-2.0000 S1000
    G1 F1000 X31.1078 Y73.7559 Z-2.0000 S1000
    G1 F1000 X31.1262 Y73.5976 Z-2.0000 S1000
    G1 F1000 X31.1366 Y73.4386 Z-2.0000 S1000
    G1 F1000 X31.1390 Y73.2793 Z-2.0000 S1000
    G1 F1000 X31.1335 Y73.1200 Z-2.0000 S1000
    G1 F1000 X31.1199 Y72.9612 Z-2.0000 S1000
    G1 F1000 X31.0984 Y72.8033 Z-2.0000 S1000
    G1 F1000 X31.0690 Y72.6467 Z-2.0000 S1000
    G1 F1000 X31.0318 Y72.4917 Z-2.0000 S1000
    G1 F1000 X30.9868 Y72.3388 Z-2.0000 S1000
    G1 F1000 X30.9343 Y72.1884 Z-2.0000 S1000
    G1 F1000 X30.8742 Y72.0408 Z-2.0000 S1000
    G1 F1000 X30.8068 Y71.8964 Z-2.0000 S1000
    G1 F1000 X30.7323 Y71.7555 Z-2.0000 S1000
    G1 F1000 X30.6271 Y71.5816 Z-2.0000 S1000
    G1 F1000 X29.2032 Y69.3886 Z-2.0000 S1000
    G1 F1000 X27.1262 Y63.9784 Z-2.0000 S1000
    G1 F1000 X26.9660 Y62.9674 Z-2.0000 S1000
    G1 F1000 X26.9371 Y62.8106 Z-2.0000 S1000
    G1 F1000 X26.9004 Y62.6556 Z-2.0000 S1000
    G1 F1000 X26.8560 Y62.5025 Z-2.0000 S1000
    G1 F1000 X26.8039 Y62.3519 Z-2.0000 S1000
    G1 F1000 X26.7443 Y62.2041 Z-2.0000 S1000
    G1 F1000 X26.6774 Y62.0595 Z-2.0000 S1000
    G1 F1000 X26.6034 Y61.9184 Z-2.0000 S1000
    G1 F1000 X26.5223 Y61.7811 Z-2.0000 S1000
    G1 F1000 X26.4345 Y61.6482 Z-2.0000 S1000
    G1 F1000 X26.3401 Y61.5198 Z-2.0000 S1000
    G1 F1000 X26.2393 Y61.3963 Z-2.0000 S1000
    G1 F1000 X26.1325 Y61.2780 Z-2.0000 S1000
    G1 F1000 X26.0199 Y61.1652 Z-2.0000 S1000
    G1 F1000 X25.9018 Y61.0583 Z-2.0000 S1000
    G1 F1000 X25.7785 Y60.9573 Z-2.0000 S1000
    G1 F1000 X25.6503 Y60.8627 Z-2.0000 S1000
    G1 F1000 X25.5174 Y60.7747 Z-2.0000 S1000
    G1 F1000 X25.3804 Y60.6934 Z-2.0000 S1000
    G1 F1000 X25.2394 Y60.6191 Z-2.0000 S1000
    G1 F1000 X25.0948 Y60.5520 Z-2.0000 S1000
    G1 F1000 X24.9471 Y60.4922 Z-2.0000 S1000
    G1 F1000 X24.7966 Y60.4399 Z-2.0000 S1000
    G1 F1000 X24.6436 Y60.3952 Z-2.0000 S1000
    G1 F1000 X24.4886 Y60.3582 Z-2.0000 S1000
    G1 F1000 X24.2816 Y60.3215 Z-2.0000 S1000
    G1 F1000 X17.3327 Y59.3231 Z-2.0000 S1000
    G1 F1000 X17.3327 Y54.2864 Z-2.0000 S1000
    G1 F1000 X24.3111 Y53.2840 Z-2.0000 S1000
    G1 F1000 X24.4682 Y53.2574 Z-2.0000 S1000
    G1 F1000 X24.6238 Y53.2230 Z-2.0000 S1000
    G1 F1000 X24.7775 Y53.1808 Z-2.0000 S1000
    G1 F1000 X24.9289 Y53.1309 Z-2.0000 S1000
    G1 F1000 X25.0775 Y53.0735 Z-2.0000 S1000
    G1 F1000 X25.2231 Y53.0087 Z-2.0000 S1000
    G1 F1000 X25.3653 Y52.9366 Z-2.0000 S1000
    G1 F1000 X25.5036 Y52.8576 Z-2.0000 S1000
    G1 F1000 X25.6379 Y52.7717 Z-2.0000 S1000
    G1 F1000 X25.7676 Y52.6791 Z-2.0000 S1000
    G1 F1000 X25.8925 Y52.5802 Z-2.0000 S1000
    G1 F1000 X26.0123 Y52.4751 Z-2.0000 S1000
    G1 F1000 X26.1267 Y52.3642 Z-2.0000 S1000
    G1 F1000 X26.2354 Y52.2476 Z-2.0000 S1000
    G1 F1000 X26.3381 Y52.1258 Z-2.0000 S1000
    G1 F1000 X26.4346 Y51.9989 Z-2.0000 S1000
    G1 F1000 X26.5245 Y51.8674 Z-2.0000 S1000
    G1 F1000 X26.6078 Y51.7315 Z-2.0000 S1000
    G1 F1000 X26.6841 Y51.5916 Z-2.0000 S1000
    G1 F1000 X26.7533 Y51.4480 Z-2.0000 S1000
    G1 F1000 X26.8152 Y51.3012 Z-2.0000 S1000
    G1 F1000 X26.8697 Y51.1514 Z-2.0000 S1000
    G1 F1000 X26.9265 Y50.9630 Z-2.0000 S1000
    G1 F1000 X28.0226 Y46.8720 Z-2.0000 S1000
    G1 F1000 X30.7005 Y41.6162 Z-2.0000 S1000
    G1 F1000 X30.7692 Y41.4724 Z-2.0000 S1000
    G1 F1000 X30.8307 Y41.3254 Z-2.0000 S1000
    G1 F1000 X30.8847 Y41.1754 Z-2.0000 S1000
    G1 F1000 X30.9311 Y41.0230 Z-2.0000 S1000
    G1 F1000 X30.9698 Y40.8684 Z-2.0000 S1000
    G1 F1000 X31.0007 Y40.7121 Z-2.0000 S1000
    G1 F1000 X31.0237 Y40.5544 Z-2.0000 S1000
    G1 F1000 X31.0388 Y40.3957 Z-2.0000 S1000
    G1 F1000 X31.0459 Y40.2365 Z-2.0000 S1000
    G1 F1000 X31.0450 Y40.0772 Z-2.0000 S1000
    G1 F1000 X31.0361 Y39.9180 Z-2.0000 S1000
    G1 F1000 X31.0192 Y39.7596 Z-2.0000 S1000
    G1 F1000 X30.9944 Y39.6022 Z-2.0000 S1000
    G1 F1000 X30.9618 Y39.4462 Z-2.0000 S1000
    G1 F1000 X30.9213 Y39.2920 Z-2.0000 S1000
    G1 F1000 X30.8732 Y39.1401 Z-2.0000 S1000
    G1 F1000 X30.8175 Y38.9908 Z-2.0000 S1000
    G1 F1000 X30.7544 Y38.8445 Z-2.0000 S1000
    G1 F1000 X30.6840 Y38.7015 Z-2.0000 S1000
    G1 F1000 X30.6065 Y38.5622 Z-2.0000 S1000
    G1 F1000 X30.5222 Y38.4270 Z-2.0000 S1000
    G1 F1000 X30.4130 Y38.2718 Z-2.0000 S1000
    G1 F1000 X26.2623 Y32.7285 Z-2.0000 S1000
    G1 F1000 X29.8238 Y29.1671 Z-2.0000 S1000
    G1 F1000 X35.3671 Y33.3177 Z-2.0000 S1000
    G1 F1000 X35.4970 Y33.4100 Z-2.0000 S1000
    G1 F1000 X35.6314 Y33.4957 Z-2.0000 S1000
    G1 F1000 X35.7700 Y33.5744 Z-2.0000 S1000
    G1 F1000 X35.9123 Y33.6462 Z-2.0000 S1000
    G1 F1000 X36.0580 Y33.7107 Z-2.0000 S1000
    G1 F1000 X36.2067 Y33.7678 Z-2.0000 S1000
    G1 F1000 X36.3582 Y33.8174 Z-2.0000 S1000
    G1 F1000 X36.5119 Y33.8594 Z-2.0000 S1000
    G1 F1000 X36.6676 Y33.8935 Z-2.0000 S1000
    G1 F1000 X36.8248 Y33.9198 Z-2.0000 S1000
    G1 F1000 X36.9831 Y33.9382 Z-2.0000 S1000
    G1 F1000 X37.1421 Y33.9486 Z-2.0000 S1000
    G1 F1000 X37.3014 Y33.9510 Z-2.0000 S1000
    G1 F1000 X37.4607 Y33.9455 Z-2.0000 S1000
    G1 F1000 X37.6195 Y33.9319 Z-2.0000 S1000
    G1 F1000 X37.7774 Y33.9104 Z-2.0000 S1000
    G1 F1000 X37.9340 Y33.8810 Z-2.0000 S1000
    G1 F1000 X38.0890 Y33.8438 Z-2.0000 S1000
    G1 F1000 X38.2418 Y33.7988 Z-2.0000 S1000
    G1 F1000 X38.3923 Y33.7463 Z-2.0000 S1000
    G1 F1000 X38.5399 Y33.6862 Z-2.0000 S1000
    G1 F1000 X38.7116 Y33.6051 Z-2.0000 S1000
    G1 F1000 X40.2177 Y32.8376 Z-2.0000 S1000
    G1 F1000 X45.9160 Y45.0577 Z-2.0000 S1000
    G1 F1000 X45.8895 Y45.0785 Z-2.0000 S1000
    G1 F1000 X44.0958 Y46.5308 Z-2.0000 S1000
    G1 F1000 X43.9745 Y46.6342 Z-2.0000 S1000
    G1 F1000 X43.8585 Y46.7435 Z-2.0000 S1000
    G1 F1000 X43.7482 Y46.8585 Z-2.0000 S1000
    G1 F1000 X43.6261 Y47.0005 Z-2.0000 S1000
    G1 F1000 X42.1738 Y48.7942 Z-2.0000 S1000
    G1 F1000 X42.0767 Y48.9205 Z-2.0000 S1000
    G1 F1000 X41.9860 Y49.0516 Z-2.0000 S1000
    G1 F1000 X41.9020 Y49.1870 Z-2.0000 S1000
    G1 F1000 X41.8124 Y49.3508 Z-2.0000 S1000
    G1 F1000 X40.7649 Y51.4068 Z-2.0000 S1000
    G1 F1000 X40.6961 Y51.5505 Z-2.0000 S1000
    G1 F1000 X40.6347 Y51.6976 Z-2.0000 S1000
    G1 F1000 X40.5807 Y51.8475 Z-2.0000 S1000
    G1 F1000 X40.5270 Y52.0265 Z-2.0000 S1000
    G1 F1000 X39.9296 Y54.2565 Z-2.0000 S1000
    G1 F1000 X39.8923 Y54.4114 Z-2.0000 S1000
    G1 F1000 X39.8627 Y54.5680 Z-2.0000 S1000
    G1 F1000 X39.8411 Y54.7259 Z-2.0000 S1000
    G1 F1000 X39.8259 Y54.9116 Z-2.0000 S1000
    G1 F1000 X39.7049 Y57.2162 Z-2.0000 S1000
    G1 F1000 X39.7005 Y57.3755 Z-2.0000 S1000
    G1 F1000 X39.7041 Y57.5349 Z-2.0000 S1000
    G1 F1000 X39.7158 Y57.6938 Z-2.0000 S1000
    G1 F1000 X39.7396 Y57.8796 Z-2.0000 S1000
    G1 F1000 X40.1008 Y60.1591 Z-2.0000 S1000
    G1 F1000 X40.1297 Y60.3158 Z-2.0000 S1000
    G1 F1000 X40.1664 Y60.4709 Z-2.0000 S1000
    G1 F1000 X40.2109 Y60.6239 Z-2.0000 S1000
    G1 F1000 X40.2726 Y60.8001 Z-2.0000 S1000
    G1 F1000 X41.0997 Y62.9545 Z-2.0000 S1000
    G1 F1000 X41.1606 Y63.1018 Z-2.0000 S1000
    G1 F1000 X41.2287 Y63.2459 Z-2.0000 S1000
    G1 F1000 X41.3040 Y63.3863 Z-2.0000 S1000
    G1 F1000 X41.4012 Y63.5461 Z-2.0000 S1000
    G1 F1000 X42.6584 Y65.4816 Z-2.0000 S1000
    G1 F1000 X42.7485 Y65.6130 Z-2.0000 S1000
    G1 F1000 X42.8451 Y65.7397 Z-2.0000 S1000
    G1 F1000 X42.9480 Y65.8615 Z-2.0000 S1000
    G1 F1000 X43.0759 Y65.9972 Z-2.0000 S1000
    G1 F1000 X44.7075 Y67.6288 Z-2.0000 S1000
    G1 F1000 X44.8230 Y67.7386 Z-2.0000 S1000
    G1 F1000 X44.9439 Y67.8425 Z-2.0000 S1000
    G1 F1000 X45.0698 Y67.9402 Z-2.0000 S1000
    G1 F1000 X45.2231 Y68.0463 Z-2.0000 S1000
    G1 F1000 X47.1586 Y69.3035 Z-2.0000 S1000
    G1 F1000 X47.2944 Y69.3869 Z-2.0000 S1000
    G1 F1000 X47.4342 Y69.4634 Z-2.0000 S1000
    G1 F1000 X47.5776 Y69.5328 Z-2.0000 S1000
    G1 F1000 X47.7502 Y69.6050 Z-2.0000 S1000
    G1 F1000 X49.9046 Y70.4321 Z-2.0000 S1000
    G1 F1000 X50.0547 Y70.4854 Z-2.0000 S1000
    G1 F1000 X50.2074 Y70.5312 Z-2.0000 S1000
    G1 F1000 X50.3621 Y70.5692 Z-2.0000 S1000
    G1 F1000 X50.5456 Y70.6039 Z-2.0000 S1000
    G1 F1000 X52.8251 Y70.9651 Z-2.0000 S1000
    G1 F1000 X52.9831 Y70.9861 Z-2.0000 S1000
    G1 F1000 X53.1419 Y70.9991 Z-2.0000 S1000
    G1 F1000 X53.3012 Y71.0041 Z-2.0000 S1000
    G1 F1000 X53.4885 Y70.9998 Z-2.0000 S1000
    G1 F1000 X55.7931 Y70.8788 Z-2.0000 S1000
    G1 F1000 X55.9520 Y70.8665 Z-2.0000 S1000
    G1 F1000 X56.1100 Y70.8462 Z-2.0000 S1000
    G1 F1000 X56.2669 Y70.8180 Z-2.0000 S1000
    G1 F1000 X56.4482 Y70.7751 Z-2.0000 S1000
    G1 F1000 X58.6782 Y70.1777 Z-2.0000 S1000
    G1 F1000 X58.8310 Y70.1326 Z-2.0000 S1000
    G1 F1000 X58.9814 Y70.0799 Z-2.0000 S1000
    G1 F1000 X59.1290 Y70.0197 Z-2.0000 S1000
    G1 F1000 X59.2979 Y69.9398 Z-2.0000 S1000
    G1 F1000 X61.3539 Y68.8923 Z-2.0000 S1000
    G1 F1000 X61.4941 Y68.8164 Z-2.0000 S1000
    G1 F1000 X61.6302 Y68.7336 Z-2.0000 S1000
    G1 F1000 X61.7620 Y68.6440 Z-2.0000 S1000
    G1 F1000 X61.9105 Y68.5309 Z-2.0000 S1000
    G1 F1000 X63.7042 Y67.0786 Z-2.0000 S1000
    G1 F1000 X63.8255 Y66.9752 Z-2.0000 S1000
    G1 F1000 X63.9415 Y66.8659 Z-2.0000 S1000
    G1 F1000 X64.0518 Y66.7509 Z-2.0000 S1000
    G1 F1000 X64.1739 Y66.6089 Z-2.0000 S1000
    G1 F1000 X65.6262 Y64.8152 Z-2.0000 S1000
    G1 F1000 X65.7233 Y64.6889 Z-2.0000 S1000
    G1 F1000 X65.8140 Y64.5578 Z-2.0000 S1000
    G1 F1000 X65.8980 Y64.4224 Z-2.0000 S1000
    G1 F1000 X65.9876 Y64.2586 Z-2.0000 S1000
    G1 F1000 X67.0351 Y62.2026 Z-2.0000 S1000
    G1 F1000 X67.1039 Y62.0589 Z-2.0000 S1000
    G1 F1000 X67.1653 Y61.9118 Z-2.0000 S1000
    G1 F1000 X67.2193 Y61.7619 Z-2.0000 S1000
    G1 F1000 X67.2730 Y61.5829 Z-2.0000 S1000
    G1 F1000 X67.8704 Y59.3529 Z-2.0000 S1000
    G1 F1000 X67.9077 Y59.1980 Z-2.0000 S1000
    G1 F1000 X67.9373 Y59.0414 Z-2.0000 S1000
    G1 F1000 X67.9589 Y58.8835 Z-2.0000 S1000
    G1 F1000 X67.9741 Y58.6978 Z-2.0000 S1000
    G1 F1000 X68.0951 Y56.3932 Z-2.0000 S1000
    G1 F1000 X68.0995 Y56.2339 Z-2.0000 S1000
    G1 F1000 X68.0959 Y56.0745 Z-2.0000 S1000
    G1 F1000 X68.0842 Y55.9156 Z-2.0000 S1000
    G1 F1000 X68.0604 Y55.7298 Z-2.0000 S1000
    G1 F1000 X67.6992 Y53.4503 Z-2.0000 S1000
    G1 F1000 X67.6703 Y53.2936 Z-2.0000 S1000
    G1 F1000 X67.6336 Y53.1385 Z-2.0000 S1000
    G1 F1000 X67.5891 Y52.9855 Z-2.0000 S1000
    G1 F1000 X67.5274 Y52.8093 Z-2.0000 S1000
    G1 F1000 X66.7003 Y50.6549 Z-2.0000 S1000
    G1 F1000 X66.6394 Y50.5076 Z-2.0000 S1000
    G1 F1000 X66.5713 Y50.3635 Z-2.0000 S1000
    G1 F1000 X66.4960 Y50.2231 Z-2.0000 S1000
    G1 F1000 X66.3988 Y50.0633 Z-2.0000 S1000
    G1 F1000 X65.1416 Y48.1278 Z-2.0000 S1000
    G1 F1000 X65.0515 Y47.9964 Z-2.0000 S1000
    G1 F1000 X64.9549 Y47.8697 Z-2.0000 S1000
    G1 F1000 X64.8520 Y47.7479 Z-2.0000 S1000
    G1 F1000 X64.7241 Y47.6122 Z-2.0000 S1000
    G1 F1000 X63.0925 Y45.9806 Z-2.0000 S1000
    G1 F1000 X62.9770 Y45.8708 Z-2.0000 S1000
    G1 F1000 X62.8561 Y45.7669 Z-2.0000 S1000
    G1 F1000 X62.7302 Y45.6692 Z-2.0000 S1000
    G1 F1000 X62.6286 Y45.5989 Z-2.0000 S1000
    G1 F700 Z-3.0000
    G1 F1000 X68.3534 Y33.3218 Z-3.0000 S1000
    G1 F1000 X68.6768 Y33.5318 Z-3.0000 S1000
    G1 F1000 X68.8126 Y33.6152 Z-3.0000 S1000
    G1 F1000 X68.9524 Y33.6917 Z-3.0000 S1000
    G1 F1000 X69.0958 Y33.7611 Z-3.0000 S1000
    G1 F1000 X69.2426 Y33.8232 Z-3.0000 S1000
    G1 F1000 X69.3923 Y33.8778 Z-3.0000 S1000
    G1 F1000 X69.5446 Y33.9249 Z-3.0000 S1000
    G1 F1000 X69.6990 Y33.9642 Z-3.0000 S1000
    G1 F1000 X69.8552 Y33.9958 Z-3.0000 S1000
    G1 F1000 X70.0128 Y34.0195 Z-3.0000 S1000
    G1 F1000 X70.1714 Y34.0352 Z-3.0000 S1000
    G1 F1000 X70.3305 Y34.0430 Z-3.0000 S1000
    G1 F1000 X70.4899 Y34.0428 Z-3.0000 S1000
    G1 F1000 X70.6490 Y34.0346 Z-3.0000 S1000
    G1 F1000 X70.8076 Y34.0184 Z-3.0000 S1000
    G1 F1000 X70.9651 Y33.9942 Z-3.0000 S1000
    G1 F1000 X71.1212 Y33.9622 Z-3.0000 S1000
    G1 F1000 X71.2755 Y33.9225 Z-3.0000 S1000
    G1 F1000 X71.4276 Y33.8750 Z-3.0000 S1000
    G1 F1000 X71.5772 Y33.8199 Z-3.0000 S1000
    G1 F1000 X71.7238 Y33.7574 Z-3.0000 S1000
    G1 F1000 X71.8671 Y33.6876 Z-3.0000 S1000
    G1 F1000 X72.0067 Y33.6108 Z-3.0000 S1000
    G1 F1000 X72.1422 Y33.5270 Z-3.0000 S1000
    G1 F1000 X72.3087 Y33.4105 Z-3.0000 S1000
    G1 F1000 X77.9762 Y29.1671 Z-3.0000 S1000
    G1 F1000 X81.5377 Y32.7286 Z-3.0000 S1000
    G1 F1000 X77.2943 Y38.3960 Z-3.0000 S1000
    G1 F1000 X77.2020 Y38.5259 Z-3.0000 S1000
    G1 F1000 X77.1163 Y38.6603 Z-3.0000 S1000
    G1 F1000 X77.0375 Y38.7988 Z-3.0000 S1000
    G1 F1000 X76.9658 Y38.9411 Z-3.0000 S1000
    G1 F1000 X76.9013 Y39.0868 Z-3.0000 S1000
    G1 F1000 X76.8442 Y39.2356 Z-3.0000 S1000
    G1 F1000 X76.7946 Y39.3870 Z-3.0000 S1000
    G1 F1000 X76.7526 Y39.5408 Z-3.0000 S1000
    G1 F1000 X76.7185 Y39.6964 Z-3.0000 S1000
    G1 F1000 X76.6922 Y39.8536 Z-3.0000 S1000
    G1 F1000 X76.6738 Y40.0119 Z-3.0000 S1000
    G1 F1000 X76.6634 Y40.1709 Z-3.0000 S1000
    G1 F1000 X76.6610 Y40.3303 Z-3.0000 S1000
    G1 F1000 X76.6665 Y40.4895 Z-3.0000 S1000
    G1 F1000 X76.6801 Y40.6483 Z-3.0000 S1000
    G1 F1000 X76.7016 Y40.8062 Z-3.0000 S1000
    G1 F1000 X76.7310 Y40.9628 Z-3.0000 S1000
    G1 F1000 X76.7682 Y41.1178 Z-3.0000 S1000
    G1 F1000 X76.8132 Y41.2707 Z-3.0000 S1000
    G1 F1000 X76.8657 Y41.4211 Z-3.0000 S1000
    G1 F1000 X76.9258 Y41.5687 Z-3.0000 S1000
    G1 F1000 X76.9932 Y41.7131 Z-3.0000 S1000
    G1 F1000 X77.0677 Y41.8540 Z-3.0000 S1000
    G1 F1000 X77.1729 Y42.0279 Z-3.0000 S1000
    G1 F1000 X78.5968 Y44.2209 Z-3.0000 S1000
    G1 F1000 X80.6738 Y49.6310 Z-3.0000 S1000
    G1 F1000 X80.8340 Y50.6420 Z-3.0000 S1000
    G1 F1000 X80.8629 Y50.7988 Z-3.0000 S1000
    G1 F1000 X80.8996 Y50.9538 Z-3.0000 S1000
    G1 F1000 X80.9440 Y51.1069 Z-3.0000 S1000
    G1 F1000 X80.9961 Y51.2575 Z-3.0000 S1000
    G1 F1000 X81.0557 Y51.4053 Z-3.0000 S1000
    G1 F1000 X81.1226 Y51.5499 Z-3.0000 S1000
    G1 F1000 X81.1966 Y51.6910 Z-3.0000 S1000
    G1 F1000 X81.2777 Y51.8283 Z-3.0000 S1000
    G1 F1000 X81.3655 Y51.9612 Z-3.0000 S1000
    G1 F1000 X81.4599 Y52.0896 Z-3.0000 S1000
    G1 F1000 X81.5607 Y52.2131 Z-3.0000 S1000
    G1 F1000 X81.6675 Y52.3314 Z-3.0000 S1000
    G1 F1000 X81.7801 Y52.4442 Z-3.0000 S1000
    G1 F1000 X81.8982 Y52.5511 Z-3.0000 S1000
    G1 F1000 X82.0215 Y52.6521 Z-3.0000 S1000
    G1 F1000 X82.1497 Y52.7467 Z-3.0000 S1000
    G1 F1000 X82.2826 Y52.8347 Z-3.0000 S1000
    G1 F1000 X82.4196 Y52.9160 Z-3.0000 S1000
    G1 F1000 X82.5606 Y52.9903 Z-3.0000 S1000
    G1 F1000 X82.7052 Y53.0574 Z-3.0000 S1000
    G1 F1000 X82.8529 Y53.1172 Z-3.0000 S1000
    G1 F1000 X83.0034 Y53.1695 Z-3.0000 S1000
    G1 F1000 X83.1564 Y53.2142 Z-3.0000 S1000
    G1 F1000 X83.3114 Y53.2512 Z-3.0000 S1000
    G1 F1000 X83.5184 Y53.2879 Z-3.0000 S1000
    G1 F1000 X90.4673 Y54.2863 Z-3.0000 S1000
    G1 F1000 X90.4673 Y59.3230 Z-3.0000 S1000
    G1 F1000 X83.4888 Y60.3255 Z-3.0000 S1000
    G1 F1000 X83.3317 Y60.3521 Z-3.0000 S1000
    G1 F1000 X83.1761 Y60.3865 Z-3.0000 S1000
    G1 F1000 X83.0225 Y60.4288 Z-3.0000 S1000
    G1 F1000 X82.8711 Y60.4786 Z-3.0000 S1000
    G1 F1000 X82.7225 Y60.5361 Z-3.0000 S1000
    G1 F1000 X82.5769 Y60.6009 Z-3.0000 S1000
    G1 F1000 X82.4347 Y60.6729 Z-3.0000 S1000
    G1 F1000 X82.2963 Y60.7519 Z-3.0000 S1000
    G1 F1000 X82.1621 Y60.8379 Z-3.0000 S1000
    G1 F1000 X82.0324 Y60.9304 Z-3.0000 S1000
    G1 F1000 X81.9074 Y61.0293 Z-3.0000 S1000
    G1 F1000 X81.7876 Y61.1344 Z-3.0000 S1000
    G1 F1000 X81.6732 Y61.2454 Z-3.0000 S1000
    G1 F1000 X81.5646 Y61.3619 Z-3.0000 S1000
    G1 F1000 X81.4619 Y61.4838 Z-3.0000 S1000
    G1 F1000 X81.3654 Y61.6106 Z-3.0000 S1000
    G1 F1000 X81.2754 Y61.7422 Z-3.0000 S1000
    G1 F1000 X81.1922 Y61.8781 Z-3.0000 S1000
    G1 F1000 X81.1159 Y62.0179 Z-3.0000 S1000
    G1 F1000 X81.0467 Y62.1615 Z-3.0000 S1000
    G1 F1000 X80.9847 Y62.3083 Z-3.0000 S1000
    G1 F1000 X80.9303 Y62.4581 Z-3.0000 S1000
    G1 F1000 X80.8735 Y62.6465 Z-3.0000 S1000
    G1 F1000 X79.7774 Y66.7374 Z-3.0000 S1000
    G1 F1000 X77.0995 Y71.9932 Z-3.0000 S1000
    G1 F1000 X77.0308 Y72.1370 Z-3.0000 S1000
    G1 F1000 X76.9693 Y72.2840 Z-3.0000 S1000
    G1 F1000 X76.9153 Y72.4339 Z-3.0000 S1000
    G1 F1000 X76.8689 Y72.5864 Z-3.0000 S1000
    G1 F1000 X76.8302 Y72.7410 Z-3.0000 S1000
    G1 F1000 X76.7993 Y72.8973 Z-3.0000 S1000
    G1 F1000 X76.7763 Y73.0550 Z-3.0000 S1000
    G1 F1000 X76.7612 Y73.2137 Z-3.0000 S1000
    G1 F1000 X76.7541 Y73.3729 Z-3.0000 S1000
    G1 F1000 X76.7550 Y73.5322 Z-3.0000 S1000
    G1 F1000 X76.7639 Y73.6913 Z-3.0000 S1000
    G1 F1000 X76.7808 Y73.8498 Z-3.0000 S1000
    G1 F1000 X76.8056 Y74.0072 Z-3.0000 S1000
    G1 F1000 X76.8382 Y74.1632 Z-3.0000 S1000
    G1 F1000 X76.8787 Y74.3173 Z-3.0000 S1000
    G1 F1000 X76.9268 Y74.4693 Z-3.0000 S1000
    G1 F1000 X76.9825 Y74.6186 Z-3.0000 S1000
    G1 F1000 X77.0456 Y74.7649 Z-3.0000 S1000
    G1 F1000 X77.1160 Y74.9079 Z-3.0000 S1000
    G1 F1000 X77.1935 Y75.0471 Z-3.0000 S1000
    G1 F1000 X77.2778 Y75.1823 Z-3.0000 S1000
    G1 F1000 X77.3870 Y75.3376 Z-3.0000 S1000
    G1 F1000 X81.5376 Y80.8809 Z-3.0000 S1000
    G1 F1000 X77.9762 Y84.4423 Z-3.0000 S1000
    G1 F1000 X72.4329 Y80.2917 Z-3.0000 S1000
    G1 F1000 X72.3030 Y80.1994 Z-3.0000 S1000
    G1 F1000 X72.1686 Y80.1138 Z-3.0000 S1000
    G1 F1000 X72.0301 Y80.0350 Z-3.0000 S1000
    G1 F1000 X71.8878 Y79.9632 Z-3.0000 S1000
    G1 F1000 X71.7421 Y79.8987 Z-3.0000 S1000
    G1 F1000 X71.5933 Y79.8416 Z-3.0000 S1000
    G1 F1000 X71.4418 Y79.7920 Z-3.0000 S1000
    G1 F1000 X71.2881 Y79.7501 Z-3.0000 S1000
    G1 F1000 X71.1324 Y79.7159 Z-3.0000 S1000
    G1 F1000 X70.9753 Y79.6896 Z-3.0000 S1000
    G1 F1000 X70.8170 Y79.6712 Z-3.0000 S1000
    G1 F1000 X70.6579 Y79.6608 Z-3.0000 S1000
    G1 F1000 X70.4986 Y79.6584 Z-3.0000 S1000
    G1 F1000 X70.3393 Y79.6639 Z-3.0000 S1000
    G1 F1000 X70.1805 Y79.6775 Z-3.0000 S1000
    G1 F1000 X70.0226 Y79.6990 Z-3.0000 S1000
    G1 F1000 X69.8660 Y79.7284 Z-3.0000 S1000
    G1 F1000 X69.7111 Y79.7656 Z-3.0000 S1000
    G1 F1000 X69.5582 Y79.8106 Z-3.0000 S1000
    G1 F1000 X69.4077 Y79.8631 Z-3.0000 S1000
    G1 F1000 X69.2601 Y79.9232 Z-3.0000 S1000
    G1 F1000 X69.0885 Y80.0042 Z-3.0000 S1000
    G1 F1000 X63.8327 Y82.6821 Z-3.0000 S1000
    G1 F1000 X59.7418 Y83.7782 Z-3.0000 S1000
    G1 F1000 X59.5889 Y83.8233 Z-3.0000 S1000
    G1 F1000 X59.4385 Y83.8760 Z-3.0000 S1000
    G1 F1000 X59.2910 Y83.9362 Z-3.0000 S1000
    G1 F1000 X59.1466 Y84.0037 Z-3.0000 S1000
    G1 F1000 X59.0058 Y84.0784 Z-3.0000 S1000
    G1 F1000 X58.8690 Y84.1600 Z-3.0000 S1000
    G1 F1000 X58.7364 Y84.2484 Z-3.0000 S1000
    G1 F1000 X58.6084 Y84.3434 Z-3.0000 S1000
    G1 F1000 X58.4853 Y84.4446 Z-3.0000 S1000
    G1 F1000 X58.3675 Y84.5519 Z-3.0000 S1000
    G1 F1000 X58.2552 Y84.6650 Z-3.0000 S1000
    G1 F1000 X58.1487 Y84.7836 Z-3.0000 S1000
    G1 F1000 X58.0483 Y84.9073 Z-3.0000 S1000
    G1 F1000 X57.9543 Y85.0360 Z-3.0000 S1000
    G1 F1000 X57.8668 Y85.1692 Z-3.0000 S1000
    G1 F1000 X57.7861 Y85.3066 Z-3.0000 S1000
    G1 F1000 X57.7124 Y85.4479 Z-3.0000 S1000
    G1 F1000 X57.6459 Y85.5927 Z-3.0000 S1000
    G1 F1000 X57.5867 Y85.7407 Z-3.0000 S1000
    G1 F1000 X57.5351 Y85.8914 Z-3.0000 S1000
    G1 F1000 X57.4910 Y86.0446 Z-3.0000 S1000
    G1 F1000 X57.4548 Y86.1998 Z-3.0000 S1000
    G1 F1000 X57.4208 Y86.3935 Z-3.0000 S1000
    G1 F1000 X56.4183 Y93.3720 Z-3.0000 S1000
    G1 F1000 X51.3816 Y93.3720 Z-3.0000 S1000
    G1 F1000 X50.3832 Y86.4231 Z-3.0000 S1000
    G1 F1000 X50.3566 Y86.2659 Z-3.0000 S1000
    G1 F1000 X50.3221 Y86.1104 Z-3.0000 S1000
    G1 F1000 X50.2799 Y85.9567 Z-3.0000 S1000
    G1 F1000 X50.2300 Y85.8053 Z-3.0000 S1000
    G1 F1000 X50.1726 Y85.6567 Z-3.0000 S1000
    G1 F1000 X50.1078 Y85.5111 Z-3.0000 S1000
    G1 F1000 X50.0358 Y85.3689 Z-3.0000 S1000
    G1 F1000 X49.9567 Y85.2306 Z-3.0000 S1000
    G1 F1000 X49.8708 Y85.0964 Z-3.0000 S1000
    G1 F1000 X49.7783 Y84.9666 Z-3.0000 S1000
    G1 F1000 X49.6793 Y84.8417 Z-3.0000 S1000
    G1 F1000 X49.5742 Y84.7219 Z-3.0000 S1000
    G1 F1000 X49.4633 Y84.6075 Z-3.0000 S1000
    G1 F1000 X49.3467 Y84.4988 Z-3.0000 S1000
    G1 F1000 X49.2249 Y84.3961 Z-3.0000 S1000
    G1 F1000 X49.0980 Y84.2997 Z-3.0000 S1000
    G1 F1000 X48.9665 Y84.2097 Z-3.0000 S1000
    G1 F1000 X48.8306 Y84.1265 Z-3.0000 S1000
    G1 F1000 X48.6907 Y84.0501 Z-3.0000 S1000
    G1 F1000 X48.5471 Y83.9809 Z-3.0000 S1000
    G1 F1000 X48.4003 Y83.9190 Z-3.0000 S1000
    G1 F1000 X48.2505 Y83.8645 Z-3.0000 S1000
    G1 F1000 X48.0982 Y83.8177 Z-3.0000 S1000
    G1 F1000 X47.9438 Y83.7785 Z-3.0000 S1000
    G1 F1000 X47.7373 Y83.7387 Z-3.0000 S1000
    G1 F1000 X46.7263 Y83.5785 Z-3.0000 S1000
    G1 F1000 X41.3162 Y81.5015 Z-3.0000 S1000
    G1 F1000 X39.1232 Y80.0776 Z-3.0000 S1000
    G1 F1000 X38.9874 Y79.9942 Z-3.0000 S1000
    G1 F1000 X38.8476 Y79.9177 Z-3.0000 S1000
    G1 F1000 X38.7042 Y79.8483 Z-3.0000 S1000
    G1 F1000 X38.5574 Y79.7862 Z-3.0000 S1000
    G1 F1000 X38.4077 Y79.7316 Z-3.0000 S1000
    G1 F1000 X38.2554 Y79.6845 Z-3.0000 S1000
    G1 F1000 X38.1010 Y79.6452 Z-3.0000 S1000
    G1 F1000 X37.9448 Y79.6136 Z-3.0000 S1000
    G1 F1000 X37.7872 Y79.5899 Z-3.0000 S1000
    G1 F1000 X37.6286 Y79.5742 Z-3.0000 S1000
    G1 F1000 X37.4695 Y79.5664 Z-3.0000 S1000
    G1 F1000 X37.3101 Y79.5666 Z-3.0000 S1000
    G1 F1000 X37.1510 Y79.5748 Z-3.0000 S1000
    G1 F1000 X36.9924 Y79.5910 Z-3.0000 S1000
    G1 F1000 X36.8349 Y79.6152 Z-3.0000 S1000
    G1 F1000 X36.6788 Y79.6472 Z-3.0000 S1000
    G1 F1000 X36.5245 Y79.6869 Z-3.0000 S1000
    G1 F1000 X36.3724 Y79.7344 Z-3.0000 S1000
    G1 F1000 X36.2228 Y79.7895 Z-3.0000 S1000
    G1 F1000 X36.0762 Y79.8520 Z-3.0000 S1000
    G1 F1000 X35.9329 Y79.9218 Z-3.0000 S1000
    G1 F1000 X35.7933 Y79.9986 Z-3.0000 S1000
    G1 F1000 X35.6578 Y80.0824 Z-3.0000 S1000
    G1 F1000 X35.4913 Y80.1990 Z-3.0000 S1000
    G1 F1000 X29.8239 Y84.4424 Z-3.0000 S1000
    G1 F1000 X26.2624 Y80.8809 Z-3.0000 S1000
    G1 F1000 X30.5057 Y75.2136 Z-3.0000 S1000
    G1 F1000 X30.5980 Y75.0836 Z-3.0000 S1000
    G1 F1000 X30.6837 Y74.9493 Z-3.0000 S1000
    G1 F1000 X30.7625 Y74.8107 Z-3.0000 S1000
    G1 F1000 X30.8342 Y74.6684 Z-3.0000 S1000
    G1 F1000 X30.8987 Y74.5227 Z-3.0000 S1000
    G1 F1000 X30.9558 Y74.3739 Z-3.0000 S1000
    G1 F1000 X31.0054 Y74.2225 Z-3.0000 S1000
    G1 F1000 X31.0474 Y74.0688 Z-3.0000 S1000
    G1 F1000 X31.0815 Y73.9131 Z-3.0000 S1000
    G1 F1000 X31.1078 Y73.7559 Z-3.0000 S1000
    G1 F1000 X31.1262 Y73.5976 Z-3.0000 S1000
    G1 F1000 X31.1366 Y73.4386 Z-3.0000 S1000
    G1 F1000 X31.1390 Y73.2793 Z-3.0000 S1000
    G1 F1000 X31.1335 Y73.1200 Z-3.0000 S1000
    G1 F1000 X31.1199 Y72.9612 Z-3.0000 S1000
    G1 F1000 X31.0984 Y72.8033 Z-3.0000 S1000
    G1 F1000 X31.0690 Y72.6467 Z-3.0000 S1000
    G1 F1000 X31.0318 Y72.4917 Z-3.0000 S1000
    G1 F1000 X30.9868 Y72.3388 Z-3.0000 S1000
    G1 F1000 X30.9343 Y72.1884 Z-3.0000 S1000
    G1 F1000 X30.8742 Y72.0408 Z-3.0000 S1000
    G1 F1000 X30.8068 Y71.8964 Z-3.0000 S1000
    G1 F1000 X30.7323 Y71.7555 Z-3.0000 S1000
    G1 F1000 X30.6271 Y71.5816 Z-3.0000 S1000
    G1 F1000 X29.2032 Y69.3886 Z-3.0000 S1000
    G1 F1000 X27.1262 Y63.9784 Z-3.0000 S1000
    G1 F1000 X26.9660 Y62.9674 Z-3.0000 S1000
    G1 F1000 X26.9371 Y62.8106 Z-3.0000 S1000
    G1 F1000 X26.9004 Y62.6556 Z-3.0000 S1000
    G1 F1000 X26.8560 Y62.5025 Z-3.0000 S1000
    G1 F1000 X26.8039 Y62.3519 Z-3.0000 S1000
    G1 F1000 X26.7443 Y62.2041 Z-3.0000 S1000
    G1 F1000 X26.6774 Y62.0595 Z-3.0000 S1000
    G1 F1000 X26.6034 Y61.9184 Z-3.0000 S1000
    G1 F1000 X26.5223 Y61.7811 Z-3.0000 S1000
    G1 F1000 X26.4345 Y61.6482 Z-3.0000 S1000
    G1 F1000 X26.3401 Y61.5198 Z-3.0000 S1000
    G1 F1000 X26.2393 Y61.3963 Z-3.0000 S1000
    G1 F1000 X26.1325 Y61.2780 Z-3.0000 S1000
    G1 F1000 X26.0199 Y61.1652 Z-3.0000 S1000
    G1 F1000 X25.9018 Y61.0583 Z-3.0000 S1000
    G1 F1000 X25.7785 Y60.9573 Z-3.0000 S1000
    G1 F1000 X25.6503 Y60.8627 Z-3.0000 S1000
    G1 F1000 X25.5174 Y60.7747 Z-3.0000 S1000
    G1 F1000 X25.3804 Y60.6934 Z-3.0000 S1000
    G1 F1000 X25.2394 Y60.6191 Z-3.0000 S1000
    G1 F1000 X25.0948 Y60.5520 Z-3.0000 S1000
    G1 F1000 X24.9471 Y60.4922 Z-3.0000 S1000
    G1 F1000 X24.7966 Y60.4399 Z-3.0000 S1000
    G1 F1000 X24.6436 Y60.3952 Z-3.0000 S1000
    G1 F1000 X24.4886 Y60.3582 Z-3.0000 S1000
    G1 F1000 X24.2816 Y60.3215 Z-3.0000 S1000
    G1 F1000 X17.3327 Y59.3231 Z-3.0000 S1000
    G1 F1000 X17.3327 Y54.2864 Z-3.0000 S1000
    G1 F1000 X24.3111 Y53.2840 Z-3.0000 S1000
    G1 F1000 X24.4682 Y53.2574 Z-3.0000 S1000
    G1 F1000 X24.6238 Y53.2230 Z-3.0000 S1000
    G1 F1000 X24.7775 Y53.1808 Z-3.0000 S1000
    G1 F1000 X24.9289 Y53.1309 Z-3.0000 S1000
    G1 F1000 X25.0775 Y53.0735 Z-3.0000 S1000
    G1 F1000 X25.2231 Y53.0087 Z-3.0000 S1000
    G1 F1000 X25.3653 Y52.9366 Z-3.0000 S1000
    G1 F1000 X25.5036 Y52.8576 Z-3.0000 S1000
    G1 F1000 X25.6379 Y52.7717 Z-3.0000 S1000
    G1 F1000 X25.7676 Y52.6791 Z-3.0000 S1000
    G1 F1000 X25.8925 Y52.5802 Z-3.0000 S1000
    G1 F1000 X26.0123 Y52.4751 Z-3.0000 S1000
    G1 F1000 X26.1267 Y52.3642 Z-3.0000 S1000
    G1 F1000 X26.2354 Y52.2476 Z-3.0000 S1000
    G1 F1000 X26.3381 Y52.1258 Z-3.0000 S1000
    G1 F1000 X26.4346 Y51.9989 Z-3.0000 S1000
    G1 F1000 X26.5245 Y51.8674 Z-3.0000 S1000
    G1 F1000 X26.6078 Y51.7315 Z-3.0000 S1000
    G1 F1000 X26.6841 Y51.5916 Z-3.0000 S1000
    G1 F1000 X26.7533 Y51.4480 Z-3.0000 S1000
    G1 F1000 X26.8152 Y51.3012 Z-3.0000 S1000
    G1 F1000 X26.8697 Y51.1514 Z-3.0000 S1000
    G1 F1000 X26.9265 Y50.9630 Z-3.0000 S1000
    G1 F1000 X28.0226 Y46.8720 Z-3.0000 S1000
    G1 F1000 X30.7005 Y41.6162 Z-3.0000 S1000
    G1 F1000 X30.7692 Y41.4724 Z-3.0000 S1000
    G1 F1000 X30.8307 Y41.3254 Z-3.0000 S1000
    G1 F1000 X30.8847 Y41.1754 Z-3.0000 S1000
    G1 F1000 X30.9311 Y41.0230 Z-3.0000 S1000
    G1 F1000 X30.9698 Y40.8684 Z-3.0000 S1000
    G1 F1000 X31.0007 Y40.7121 Z-3.0000 S1000
    G1 F1000 X31.0237 Y40.5544 Z-3.0000 S1000
    G1 F1000 X31.0388 Y40.3957 Z-3.0000 S1000
    G1 F1000 X31.0459 Y40.2365 Z-3.0000 S1000
    G1 F1000 X31.0450 Y40.0772 Z-3.0000 S1000
    G1 F1000 X31.0361 Y39.9180 Z-3.0000 S1000
    G1 F1000 X31.0192 Y39.7596 Z-3.0000 S1000
    G1 F1000 X30.9944 Y39.6022 Z-3.0000 S1000
    G1 F1000 X30.9618 Y39.4462 Z-3.0000 S1000
    G1 F1000 X30.9213 Y39.2920 Z-3.0000 S1000
    G1 F1000 X30.8732 Y39.1401 Z-3.0000 S1000
    G1 F1000 X30.8175 Y38.9908 Z-3.0000 S1000
    G1 F1000 X30.7544 Y38.8445 Z-3.0000 S1000
    G1 F1000 X30.6840 Y38.7015 Z-3.0000 S1000
    G1 F1000 X30.6065 Y38.5622 Z-3.0000 S1000
    G1 F1000 X30.5222 Y38.4270 Z-3.0000 S1000
    G1 F1000 X30.4130 Y38.2718 Z-3.0000 S1000
    G1 F1000 X26.2623 Y32.7285 Z-3.0000 S1000
    G1 F1000 X29.8238 Y29.1671 Z-3.0000 S1000
    G1 F1000 X35.3671 Y33.3177 Z-3.0000 S1000
    G1 F1000 X35.4970 Y33.4100 Z-3.0000 S1000
    G1 F1000 X35.6314 Y33.4957 Z-3.0000 S1000
    G1 F1000 X35.7700 Y33.5744 Z-3.0000 S1000
    G1 F1000 X35.9123 Y33.6462 Z-3.0000 S1000
    G1 F1000 X36.0580 Y33.7107 Z-3.0000 S1000
    G1 F1000 X36.2067 Y33.7678 Z-3.0000 S1000
    G1 F1000 X36.3582 Y33.8174 Z-3.0000 S1000
    G1 F1000 X36.5119 Y33.8594 Z-3.0000 S1000
    G1 F1000 X36.6676 Y33.8935 Z-3.0000 S1000
    G1 F1000 X36.8248 Y33.9198 Z-3.0000 S1000
    G1 F1000 X36.9831 Y33.9382 Z-3.0000 S1000
    G1 F1000 X37.1421 Y33.9486 Z-3.0000 S1000
    G1 F1000 X37.3014 Y33.9510 Z-3.0000 S1000
    G1 F1000 X37.4607 Y33.9455 Z-3.0000 S1000
    G1 F1000 X37.6195 Y33.9319 Z-3.0000 S1000
    G1 F1000 X37.7774 Y33.9104 Z-3.0000 S1000
    G1 F1000 X37.9340 Y33.8810 Z-3.0000 S1000
    G1 F1000 X38.0890 Y33.8438 Z-3.0000 S1000
    G1 F1000 X38.2418 Y33.7988 Z-3.0000 S1000
    G1 F1000 X38.3923 Y33.7463 Z-3.0000 S1000
    G1 F1000 X38.5399 Y33.6862 Z-3.0000 S1000
    G1 F1000 X38.7116 Y33.6051 Z-3.0000 S1000
    G1 F1000 X40.2177 Y32.8376 Z-3.0000 S1000
    G1 F1000 X45.9160 Y45.0577 Z-3.0000 S1000
    G1 F1000 X45.8895 Y45.0785 Z-3.0000 S1000
    G1 F1000 X44.0958 Y46.5308 Z-3.0000 S1000
    G1 F1000 X43.9745 Y46.6342 Z-3.0000 S1000
    G1 F1000 X43.8585 Y46.7435 Z-3.0000 S1000
    G1 F1000 X43.7482 Y46.8585 Z-3.0000 S1000
    G1 F1000 X43.6261 Y47.0005 Z-3.0000 S1000
    G1 F1000 X42.1738 Y48.7942 Z-3.0000 S1000
    G1 F1000 X42.0767 Y48.9205 Z-3.0000 S1000
    G1 F1000 X41.9860 Y49.0516 Z-3.0000 S1000
    G1 F1000 X41.9020 Y49.1870 Z-3.0000 S1000
    G1 F1000 X41.8124 Y49.3508 Z-3.0000 S1000
    G1 F1000 X40.7649 Y51.4068 Z-3.0000 S1000
    G1 F1000 X40.6961 Y51.5505 Z-3.0000 S1000
    G1 F1000 X40.6347 Y51.6976 Z-3.0000 S1000
    G1 F1000 X40.5807 Y51.8475 Z-3.0000 S1000
    G1 F1000 X40.5270 Y52.0265 Z-3.0000 S1000
    G1 F1000 X39.9296 Y54.2565 Z-3.0000 S1000
    G1 F1000 X39.8923 Y54.4114 Z-3.0000 S1000
    G1 F1000 X39.8627 Y54.5680 Z-3.0000 S1000
    G1 F1000 X39.8411 Y54.7259 Z-3.0000 S1000
    G1 F1000 X39.8259 Y54.9116 Z-3.0000 S1000
    G1 F1000 X39.7049 Y57.2162 Z-3.0000 S1000
    G1 F1000 X39.7005 Y57.3755 Z-3.0000 S1000
    G1 F1000 X39.7041 Y57.5349 Z-3.0000 S1000
    G1 F1000 X39.7158 Y57.6938 Z-3.0000 S1000
    G1 F1000 X39.7396 Y57.8796 Z-3.0000 S1000
    G1 F1000 X40.1008 Y60.1591 Z-3.0000 S1000
    G1 F1000 X40.1297 Y60.3158 Z-3.0000 S1000
    G1 F1000 X40.1664 Y60.4709 Z-3.0000 S1000
    G1 F1000 X40.2109 Y60.6239 Z-3.0000 S1000
    G1 F1000 X40.2726 Y60.8001 Z-3.0000 S1000
    G1 F1000 X41.0997 Y62.9545 Z-3.0000 S1000
    G1 F1000 X41.1606 Y63.1018 Z-3.0000 S1000
    G1 F1000 X41.2287 Y63.2459 Z-3.0000 S1000
    G1 F1000 X41.3040 Y63.3863 Z-3.0000 S1000
    G1 F1000 X41.4012 Y63.5461 Z-3.0000 S1000
    G1 F1000 X42.6584 Y65.4816 Z-3.0000 S1000
    G1 F1000 X42.7485 Y65.6130 Z-3.0000 S1000
    G1 F1000 X42.8451 Y65.7397 Z-3.0000 S1000
    G1 F1000 X42.9480 Y65.8615 Z-3.0000 S1000
    G1 F1000 X43.0759 Y65.9972 Z-3.0000 S1000
    G1 F1000 X44.7075 Y67.6288 Z-3.0000 S1000
    G1 F1000 X44.8230 Y67.7386 Z-3.0000 S1000
    G1 F1000 X44.9439 Y67.8425 Z-3.0000 S1000
    G1 F1000 X45.0698 Y67.9402 Z-3.0000 S1000
    G1 F1000 X45.2231 Y68.0463 Z-3.0000 S1000
    G1 F1000 X47.1586 Y69.3035 Z-3.0000 S1000
    G1 F1000 X47.2944 Y69.3869 Z-3.0000 S1000
    G1 F1000 X47.4342 Y69.4634 Z-3.0000 S1000
    G1 F1000 X47.5776 Y69.5328 Z-3.0000 S1000
    G1 F1000 X47.7502 Y69.6050 Z-3.0000 S1000
    G1 F1000 X49.9046 Y70.4321 Z-3.0000 S1000
    G1 F1000 X50.0547 Y70.4854 Z-3.0000 S1000
    G1 F1000 X50.2074 Y70.5312 Z-3.0000 S1000
    G1 F1000 X50.3621 Y70.5692 Z-3.0000 S1000
    G1 F1000 X50.5456 Y70.6039 Z-3.0000 S1000
    G1 F1000 X52.8251 Y70.9651 Z-3.0000 S1000
    G1 F1000 X52.9831 Y70.9861 Z-3.0000 S1000
    G1 F1000 X53.1419 Y70.9991 Z-3.0000 S1000
    G1 F1000 X53.3012 Y71.0041 Z-3.0000 S1000
    G1 F1000 X53.4885 Y70.9998 Z-3.0000 S1000
    G1 F1000 X55.7931 Y70.8788 Z-3.0000 S1000
    G1 F1000 X55.9520 Y70.8665 Z-3.0000 S1000
    G1 F1000 X56.1100 Y70.8462 Z-3.0000 S1000
    G1 F1000 X56.2669 Y70.8180 Z-3.0000 S1000
    G1 F1000 X56.4482 Y70.7751 Z-3.0000 S1000
    G1 F1000 X58.6782 Y70.1777 Z-3.0000 S1000
    G1 F1000 X58.8310 Y70.1326 Z-3.0000 S1000
    G1 F1000 X58.9814 Y70.0799 Z-3.0000 S1000
    G1 F1000 X59.1290 Y70.0197 Z-3.0000 S1000
    G1 F1000 X59.2979 Y69.9398 Z-3.0000 S1000
    G1 F1000 X61.3539 Y68.8923 Z-3.0000 S1000
    G1 F1000 X61.4941 Y68.8164 Z-3.0000 S1000
    G1 F1000 X61.6302 Y68.7336 Z-3.0000 S1000
    G1 F1000 X61.7620 Y68.6440 Z-3.0000 S1000
    G1 F1000 X61.9105 Y68.5309 Z-3.0000 S1000
    G1 F1000 X63.7042 Y67.0786 Z-3.0000 S1000
    G1 F1000 X63.8255 Y66.9752 Z-3.0000 S1000
    G1 F1000 X63.9415 Y66.8659 Z-3.0000 S1000
    G1 F1000 X64.0518 Y66.7509 Z-3.0000 S1000
    G1 F1000 X64.1739 Y66.6089 Z-3.0000 S1000
    G1 F1000 X65.6262 Y64.8152 Z-3.0000 S1000
    G1 F1000 X65.7233 Y64.6889 Z-3.0000 S1000
    G1 F1000 X65.8140 Y64.5578 Z-3.0000 S1000
    G1 F1000 X65.8980 Y64.4224 Z-3.0000 S1000
    G1 F1000 X65.9876 Y64.2586 Z-3.0000 S1000
    G1 F1000 X67.0351 Y62.2026 Z-3.0000 S1000
    G1 F1000 X67.1039 Y62.0589 Z-3.0000 S1000
    G1 F1000 X67.1653 Y61.9118 Z-3.0000 S1000
    G1 F1000 X67.2193 Y61.7619 Z-3.0000 S1000
    G1 F1000 X67.2730 Y61.5829 Z-3.0000 S1000
    G1 F1000 X67.8704 Y59.3529 Z-3.0000 S1000
    G1 F1000 X67.9077 Y59.1980 Z-3.0000 S1000
    G1 F1000 X67.9373 Y59.0414 Z-3.0000 S1000
    G1 F1000 X67.9589 Y58.8835 Z-3.0000 S1000
    G1 F1000 X67.9741 Y58.6978 Z-3.0000 S1000
    G1 F1000 X68.0951 Y56.3932 Z-3.0000 S1000
    G1 F1000 X68.0995 Y56.2339 Z-3.0000 S1000
    G1 F1000 X68.0959 Y56.0745 Z-3.0000 S1000
    G1 F1000 X68.0842 Y55.9156 Z-3.0000 S1000
    G1 F1000 X68.0604 Y55.7298 Z-3.0000 S1000
    G1 F1000 X67.6992 Y53.4503 Z-3.0000 S1000
    G1 F1000 X67.6703 Y53.2936 Z-3.0000 S1000
    G1 F1000 X67.6336 Y53.1385 Z-3.0000 S1000
    G1 F1000 X67.5891 Y52.9855 Z-3.0000 S1000
    G1 F1000 X67.5274 Y52.8093 Z-3.0000 S1000
    G1 F1000 X66.7003 Y50.6549 Z-3.0000 S1000
    G1 F1000 X66.6394 Y50.5076 Z-3.0000 S1000
    G1 F1000 X66.5713 Y50.3635 Z-3.0000 S1000
    G1 F1000 X66.4960 Y50.2231 Z-3.0000 S1000
    G1 F1000 X66.3988 Y50.0633 Z-3.0000 S1000
    G1 F1000 X65.1416 Y48.1278 Z-3.0000 S1000
    G1 F1000 X65.0515 Y47.9964 Z-3.0000 S1000
    G1 F1000 X64.9549 Y47.8697 Z-3.0000 S1000
    G1 F1000 X64.8520 Y47.7479 Z-3.0000 S1000
    G1 F1000 X64.7241 Y47.6122 Z-3.0000 S1000
    G1 F1000 X63.0925 Y45.9806 Z-3.0000 S1000
    G1 F1000 X62.9770 Y45.8708 Z-3.0000 S1000
    G1 F1000 X62.8561 Y45.7669 Z-3.0000 S1000
    G1 F1000 X62.7302 Y45.6692 Z-3.0000 S1000
    G1 F1000 X62.6286 Y45.5989 Z-3.0000 S1000
    G0 Z7
    G0 X60.6075 Y46.1769
    G0 Z0
    G1 F700 Z-1.0000
    G1 F1000 X67.6864 Y30.9960 Z-1.0000 S1000
    G1 F1000 X69.5413 Y32.2004 Z-1.0000 S1000
    G1 F1000 X69.6379 Y32.2583 Z-1.0000 S1000
    G1 F1000 X69.7384 Y32.3093 Z-1.0000 S1000
    G1 F1000 X69.8422 Y32.3530 Z-1.0000 S1000
    G1 F1000 X69.9489 Y32.3892 Z-1.0000 S1000
    G1 F1000 X70.0579 Y32.4178 Z-1.0000 S1000
    G1 F1000 X70.1687 Y32.4386 Z-1.0000 S1000
    G1 F1000 X70.2806 Y32.4515 Z-1.0000 S1000
    G1 F1000 X70.3932 Y32.4563 Z-1.0000 S1000
    G1 F1000 X70.5058 Y32.4532 Z-1.0000 S1000
    G1 F1000 X70.6179 Y32.4422 Z-1.0000 S1000
    G1 F1000 X70.7290 Y32.4232 Z-1.0000 S1000
    G1 F1000 X70.8384 Y32.3963 Z-1.0000 S1000
    G1 F1000 X70.9457 Y32.3618 Z-1.0000 S1000
    G1 F1000 X71.0502 Y32.3197 Z-1.0000 S1000
    G1 F1000 X71.1515 Y32.2704 Z-1.0000 S1000
    G1 F1000 X71.2490 Y32.2139 Z-1.0000 S1000
    G1 F1000 X71.3573 Y32.1397 Z-1.0000 S1000
    G1 F1000 X78.1260 Y27.0718 Z-1.0000 S1000
    G1 F1000 X83.6330 Y32.5787 Z-1.0000 S1000
    G1 F1000 X78.5650 Y39.3474 Z-1.0000 S1000
    G1 F1000 X78.5007 Y39.4400 Z-1.0000 S1000
    G1 F1000 X78.4432 Y39.5368 Z-1.0000 S1000
    G1 F1000 X78.3926 Y39.6375 Z-1.0000 S1000
    G1 F1000 X78.3494 Y39.7416 Z-1.0000 S1000
    G1 F1000 X78.3136 Y39.8484 Z-1.0000 S1000
    G1 F1000 X78.2854 Y39.9575 Z-1.0000 S1000
    G1 F1000 X78.2651 Y40.0683 Z-1.0000 S1000
    G1 F1000 X78.2527 Y40.1803 Z-1.0000 S1000
    G1 F1000 X78.2483 Y40.2929 Z-1.0000 S1000
    G1 F1000 X78.2519 Y40.4055 Z-1.0000 S1000
    G1 F1000 X78.2634 Y40.5176 Z-1.0000 S1000
    G1 F1000 X78.2829 Y40.6286 Z-1.0000 S1000
    G1 F1000 X78.3102 Y40.7379 Z-1.0000 S1000
    G1 F1000 X78.3452 Y40.8450 Z-1.0000 S1000
    G1 F1000 X78.3877 Y40.9494 Z-1.0000 S1000
    G1 F1000 X78.4375 Y41.0505 Z-1.0000 S1000
    G1 F1000 X78.5043 Y41.1634 Z-1.0000 S1000
    G1 F1000 X80.0192 Y43.4966 Z-1.0000 S1000
    G1 F1000 X82.2157 Y49.2179 Z-1.0000 S1000
    G1 F1000 X82.4020 Y50.3936 Z-1.0000 S1000
    G1 F1000 X82.4235 Y50.5042 Z-1.0000 S1000
    G1 F1000 X82.4529 Y50.6130 Z-1.0000 S1000
    G1 F1000 X82.4899 Y50.7194 Z-1.0000 S1000
    G1 F1000 X82.5344 Y50.8230 Z-1.0000 S1000
    G1 F1000 X82.5860 Y50.9231 Z-1.0000 S1000
    G1 F1000 X82.6447 Y51.0193 Z-1.0000 S1000
    G1 F1000 X82.7100 Y51.1111 Z-1.0000 S1000
    G1 F1000 X82.7817 Y51.1980 Z-1.0000 S1000
    G1 F1000 X82.8594 Y51.2796 Z-1.0000 S1000
    G1 F1000 X82.9427 Y51.3556 Z-1.0000 S1000
    G1 F1000 X83.0311 Y51.4254 Z-1.0000 S1000
    G1 F1000 X83.1243 Y51.4887 Z-1.0000 S1000
    G1 F1000 X83.2217 Y51.5453 Z-1.0000 S1000
    G1 F1000 X83.3229 Y51.5949 Z-1.0000 S1000
    G1 F1000 X83.4274 Y51.6371 Z-1.0000 S1000
    G1 F1000 X83.5346 Y51.6718 Z-1.0000 S1000
    G1 F1000 X83.6439 Y51.6989 Z-1.0000 S1000
    G1 F1000 X83.7441 Y51.7166 Z-1.0000 S1000
    G1 F1000 X92.0548 Y52.9107 Z-1.0000 S1000
    G1 F1000 X92.0548 Y60.6987 Z-1.0000 S1000
    G1 F1000 X83.7146 Y61.8968 Z-1.0000 S1000
    G1 F1000 X83.6037 Y61.9168 Z-1.0000 S1000
    G1 F1000 X83.4945 Y61.9446 Z-1.0000 S1000
    G1 F1000 X83.3875 Y61.9800 Z-1.0000 S1000
    G1 F1000 X83.2834 Y62.0230 Z-1.0000 S1000
    G1 F1000 X83.1825 Y62.0732 Z-1.0000 S1000
    G1 F1000 X83.0855 Y62.1305 Z-1.0000 S1000
    G1 F1000 X82.9927 Y62.1945 Z-1.0000 S1000
    G1 F1000 X82.9048 Y62.2649 Z-1.0000 S1000
    G1 F1000 X82.8220 Y62.3414 Z-1.0000 S1000
    G1 F1000 X82.7449 Y62.4236 Z-1.0000 S1000
    G1 F1000 X82.6738 Y62.5110 Z-1.0000 S1000
    G1 F1000 X82.6091 Y62.6032 Z-1.0000 S1000
    G1 F1000 X82.5511 Y62.6998 Z-1.0000 S1000
    G1 F1000 X82.5001 Y62.8003 Z-1.0000 S1000
    G1 F1000 X82.4564 Y62.9042 Z-1.0000 S1000
    G1 F1000 X82.4069 Y63.0573 Z-1.0000 S1000
    G1 F1000 X81.2675 Y67.3097 Z-1.0000 S1000
    G1 F1000 X78.5140 Y72.7139 Z-1.0000 S1000
    G1 F1000 X78.4665 Y72.8161 Z-1.0000 S1000
    G1 F1000 X78.4263 Y72.9213 Z-1.0000 S1000
    G1 F1000 X78.3936 Y73.0292 Z-1.0000 S1000
    G1 F1000 X78.3688 Y73.1391 Z-1.0000 S1000
    G1 F1000 X78.3517 Y73.2504 Z-1.0000 S1000
    G1 F1000 X78.3426 Y73.3628 Z-1.0000 S1000
    G1 F1000 X78.3415 Y73.4754 Z-1.0000 S1000
    G1 F1000 X78.3484 Y73.5879 Z-1.0000 S1000
    G1 F1000 X78.3633 Y73.6996 Z-1.0000 S1000
    G1 F1000 X78.3860 Y73.8099 Z-1.0000 S1000
    G1 F1000 X78.4165 Y73.9184 Z-1.0000 S1000
    G1 F1000 X78.4546 Y74.0244 Z-1.0000 S1000
    G1 F1000 X78.5002 Y74.1275 Z-1.0000 S1000
    G1 F1000 X78.5529 Y74.2271 Z-1.0000 S1000
    G1 F1000 X78.6126 Y74.3226 Z-1.0000 S1000
    G1 F1000 X78.6577 Y74.3861 Z-1.0000 S1000
    G1 F1000 X83.6330 Y81.0307 Z-1.0000 S1000
    G1 F1000 X78.1260 Y86.5377 Z-1.0000 S1000
    G1 F1000 X71.4814 Y81.5624 Z-1.0000 S1000
    G1 F1000 X71.3889 Y81.4982 Z-1.0000 S1000
    G1 F1000 X71.2920 Y81.4406 Z-1.0000 S1000
    G1 F1000 X71.1913 Y81.3900 Z-1.0000 S1000
    G1 F1000 X71.0873 Y81.3468 Z-1.0000 S1000
    G1 F1000 X70.9804 Y81.3110 Z-1.0000 S1000
    G1 F1000 X70.8713 Y81.2828 Z-1.0000 S1000
    G1 F1000 X70.7605 Y81.2625 Z-1.0000 S1000
    G1 F1000 X70.6485 Y81.2501 Z-1.0000 S1000
    G1 F1000 X70.5359 Y81.2457 Z-1.0000 S1000
    G1 F1000 X70.4233 Y81.2493 Z-1.0000 S1000
    G1 F1000 X70.3112 Y81.2608 Z-1.0000 S1000
    G1 F1000 X70.2002 Y81.2803 Z-1.0000 S1000
    G1 F1000 X70.0909 Y81.3076 Z-1.0000 S1000
    G1 F1000 X69.9838 Y81.3426 Z-1.0000 S1000
    G1 F1000 X69.8794 Y81.3851 Z-1.0000 S1000
    G1 F1000 X69.8092 Y81.4187 Z-1.0000 S1000
    G1 F1000 X64.4050 Y84.1722 Z-1.0000 S1000
    G1 F1000 X60.1526 Y85.3116 Z-1.0000 S1000
    G1 F1000 X60.0449 Y85.3446 Z-1.0000 S1000
    G1 F1000 X59.9398 Y85.3852 Z-1.0000 S1000
    G1 F1000 X59.8378 Y85.4331 Z-1.0000 S1000
    G1 F1000 X59.7395 Y85.4881 Z-1.0000 S1000
    G1 F1000 X59.6453 Y85.5500 Z-1.0000 S1000
    G1 F1000 X59.5558 Y85.6184 Z-1.0000 S1000
    G1 F1000 X59.4713 Y85.6929 Z-1.0000 S1000
    G1 F1000 X59.3923 Y85.7733 Z-1.0000 S1000
    G1 F1000 X59.3193 Y85.8591 Z-1.0000 S1000
    G1 F1000 X59.2525 Y85.9498 Z-1.0000 S1000
    G1 F1000 X59.1923 Y86.0451 Z-1.0000 S1000
    G1 F1000 X59.1390 Y86.1444 Z-1.0000 S1000
    G1 F1000 X59.0929 Y86.2472 Z-1.0000 S1000
    G1 F1000 X59.0542 Y86.3530 Z-1.0000 S1000
    G1 F1000 X59.0231 Y86.4613 Z-1.0000 S1000
    G1 F1000 X58.9921 Y86.6193 Z-1.0000 S1000
    G1 F1000 X57.7940 Y94.9595 Z-1.0000 S1000
    G1 F1000 X50.0060 Y94.9595 Z-1.0000 S1000
    G1 F1000 X48.8119 Y86.6488 Z-1.0000 S1000
    G1 F1000 X48.7919 Y86.5379 Z-1.0000 S1000
    G1 F1000 X48.7641 Y86.4287 Z-1.0000 S1000
    G1 F1000 X48.7286 Y86.3218 Z-1.0000 S1000
    G1 F1000 X48.6857 Y86.2176 Z-1.0000 S1000
    G1 F1000 X48.6354 Y86.1168 Z-1.0000 S1000
    G1 F1000 X48.5782 Y86.0197 Z-1.0000 S1000
    G1 F1000 X48.5142 Y85.9270 Z-1.0000 S1000
    G1 F1000 X48.4437 Y85.8390 Z-1.0000 S1000
    G1 F1000 X48.3673 Y85.7563 Z-1.0000 S1000
    G1 F1000 X48.2851 Y85.6792 Z-1.0000 S1000
    G1 F1000 X48.1977 Y85.6081 Z-1.0000 S1000
    G1 F1000 X48.1054 Y85.5434 Z-1.0000 S1000
    G1 F1000 X48.0088 Y85.4854 Z-1.0000 S1000
    G1 F1000 X47.9083 Y85.4344 Z-1.0000 S1000
    G1 F1000 X47.8045 Y85.3907 Z-1.0000 S1000
    G1 F1000 X47.6978 Y85.3544 Z-1.0000 S1000
    G1 F1000 X47.5888 Y85.3258 Z-1.0000 S1000
    G1 F1000 X47.4889 Y85.3067 Z-1.0000 S1000
    G1 F1000 X46.3132 Y85.1204 Z-1.0000 S1000
    G1 F1000 X40.5919 Y82.9239 Z-1.0000 S1000
    G1 F1000 X38.2587 Y81.4090 Z-1.0000 S1000
    G1 F1000 X38.1621 Y81.3511 Z-1.0000 S1000
    G1 F1000 X38.0616 Y81.3001 Z-1.0000 S1000
    G1 F1000 X37.9578 Y81.2564 Z-1.0000 S1000
    G1 F1000 X37.8511 Y81.2202 Z-1.0000 S1000
    G1 F1000 X37.7421 Y81.1916 Z-1.0000 S1000
    G1 F1000 X37.6313 Y81.1708 Z-1.0000 S1000
    G1 F1000 X37.5194 Y81.1579 Z-1.0000 S1000
    G1 F1000 X37.4068 Y81.1531 Z-1.0000 S1000
    G1 F1000 X37.2942 Y81.1562 Z-1.0000 S1000
    G1 F1000 X37.1821 Y81.1672 Z-1.0000 S1000
    G1 F1000 X37.0710 Y81.1862 Z-1.0000 S1000
    G1 F1000 X36.9616 Y81.2131 Z-1.0000 S1000
    G1 F1000 X36.8543 Y81.2476 Z-1.0000 S1000
    G1 F1000 X36.7498 Y81.2897 Z-1.0000 S1000
    G1 F1000 X36.6485 Y81.3390 Z-1.0000 S1000
    G1 F1000 X36.5510 Y81.3955 Z-1.0000 S1000
    G1 F1000 X36.4427 Y81.4697 Z-1.0000 S1000
    G1 F1000 X29.6740 Y86.5377 Z-1.0000 S1000
    G1 F1000 X24.1670 Y81.0307 Z-1.0000 S1000
    G1 F1000 X29.2350 Y74.2621 Z-1.0000 S1000
    G1 F1000 X29.2993 Y74.1695 Z-1.0000 S1000
    G1 F1000 X29.3568 Y74.0727 Z-1.0000 S1000
    G1 F1000 X29.4074 Y73.9720 Z-1.0000 S1000
    G1 F1000 X29.4506 Y73.8679 Z-1.0000 S1000
    G1 F1000 X29.4864 Y73.7611 Z-1.0000 S1000
    G1 F1000 X29.5146 Y73.6520 Z-1.0000 S1000
    G1 F1000 X29.5349 Y73.5412 Z-1.0000 S1000
    G1 F1000 X29.5473 Y73.4292 Z-1.0000 S1000
    G1 F1000 X29.5517 Y73.3166 Z-1.0000 S1000
    G1 F1000 X29.5481 Y73.2040 Z-1.0000 S1000
    G1 F1000 X29.5366 Y73.0919 Z-1.0000 S1000
    G1 F1000 X29.5171 Y72.9809 Z-1.0000 S1000
    G1 F1000 X29.4898 Y72.8716 Z-1.0000 S1000
    G1 F1000 X29.4548 Y72.7645 Z-1.0000 S1000
    G1 F1000 X29.4123 Y72.6601 Z-1.0000 S1000
    G1 F1000 X29.3625 Y72.5590 Z-1.0000 S1000
    G1 F1000 X29.2957 Y72.4461 Z-1.0000 S1000
    G1 F1000 X27.7808 Y70.1128 Z-1.0000 S1000
    G1 F1000 X25.5843 Y64.3915 Z-1.0000 S1000
    G1 F1000 X25.3980 Y63.2158 Z-1.0000 S1000
    G1 F1000 X25.3765 Y63.1052 Z-1.0000 S1000
    G1 F1000 X25.3471 Y62.9964 Z-1.0000 S1000
    G1 F1000 X25.3101 Y62.8900 Z-1.0000 S1000
    G1 F1000 X25.2656 Y62.7864 Z-1.0000 S1000
    G1 F1000 X25.2140 Y62.6863 Z-1.0000 S1000
    G1 F1000 X25.1553 Y62.5901 Z-1.0000 S1000
    G1 F1000 X25.0900 Y62.4983 Z-1.0000 S1000
    G1 F1000 X25.0183 Y62.4114 Z-1.0000 S1000
    G1 F1000 X24.9406 Y62.3298 Z-1.0000 S1000
    G1 F1000 X24.8573 Y62.2538 Z-1.0000 S1000
    G1 F1000 X24.7689 Y62.1840 Z-1.0000 S1000
    G1 F1000 X24.6757 Y62.1207 Z-1.0000 S1000
    G1 F1000 X24.5783 Y62.0641 Z-1.0000 S1000
    G1 F1000 X24.4771 Y62.0145 Z-1.0000 S1000
    G1 F1000 X24.3726 Y61.9723 Z-1.0000 S1000
    G1 F1000 X24.2654 Y61.9376 Z-1.0000 S1000
    G1 F1000 X24.1561 Y61.9105 Z-1.0000 S1000
    G1 F1000 X24.0559 Y61.8928 Z-1.0000 S1000
    G1 F1000 X15.7452 Y60.6987 Z-1.0000 S1000
    G1 F1000 X15.7452 Y52.9107 Z-1.0000 S1000
    G1 F1000 X24.0854 Y51.7127 Z-1.0000 S1000
    G1 F1000 X24.1963 Y51.6927 Z-1.0000 S1000
    G1 F1000 X24.3055 Y51.6649 Z-1.0000 S1000
    G1 F1000 X24.4125 Y51.6295 Z-1.0000 S1000
    G1 F1000 X24.5166 Y51.5865 Z-1.0000 S1000
    G1 F1000 X24.6175 Y51.5363 Z-1.0000 S1000
    G1 F1000 X24.7145 Y51.4790 Z-1.0000 S1000
    G1 F1000 X24.8073 Y51.4150 Z-1.0000 S1000
    G1 F1000 X24.8952 Y51.3446 Z-1.0000 S1000
    G1 F1000 X24.9780 Y51.2681 Z-1.0000 S1000
    G1 F1000 X25.0551 Y51.1859 Z-1.0000 S1000
    G1 F1000 X25.1262 Y51.0985 Z-1.0000 S1000
    G1 F1000 X25.1909 Y51.0063 Z-1.0000 S1000
    G1 F1000 X25.2489 Y50.9097 Z-1.0000 S1000
    G1 F1000 X25.2999 Y50.8092 Z-1.0000 S1000
    G1 F1000 X25.3436 Y50.7054 Z-1.0000 S1000
    G1 F1000 X25.3931 Y50.5522 Z-1.0000 S1000
    G1 F1000 X26.5325 Y46.2998 Z-1.0000 S1000
    G1 F1000 X29.2860 Y40.8955 Z-1.0000 S1000
    G1 F1000 X29.3335 Y40.7933 Z-1.0000 S1000
    G1 F1000 X29.3737 Y40.6881 Z-1.0000 S1000
    G1 F1000 X29.4064 Y40.5802 Z-1.0000 S1000
    G1 F1000 X29.4313 Y40.4703 Z-1.0000 S1000
    G1 F1000 X29.4483 Y40.3589 Z-1.0000 S1000
    G1 F1000 X29.4574 Y40.2466 Z-1.0000 S1000
    G1 F1000 X29.4585 Y40.1340 Z-1.0000 S1000
    G1 F1000 X29.4516 Y40.0215 Z-1.0000 S1000
    G1 F1000 X29.4367 Y39.9098 Z-1.0000 S1000
    G1 F1000 X29.4140 Y39.7994 Z-1.0000 S1000
    G1 F1000 X29.3835 Y39.6910 Z-1.0000 S1000
    G1 F1000 X29.3453 Y39.5849 Z-1.0000 S1000
    G1 F1000 X29.2998 Y39.4819 Z-1.0000 S1000
    G1 F1000 X29.2470 Y39.3823 Z-1.0000 S1000
    G1 F1000 X29.1874 Y39.2867 Z-1.0000 S1000
    G1 F1000 X29.1423 Y39.2233 Z-1.0000 S1000
    G1 F1000 X24.1670 Y32.5787 Z-1.0000 S1000
    G1 F1000 X29.6740 Y27.0718 Z-1.0000 S1000
    G1 F1000 X36.3186 Y32.0470 Z-1.0000 S1000
    G1 F1000 X36.4111 Y32.1113 Z-1.0000 S1000
    G1 F1000 X36.5080 Y32.1688 Z-1.0000 S1000
    G1 F1000 X36.6087 Y32.2194 Z-1.0000 S1000
    G1 F1000 X36.7127 Y32.2626 Z-1.0000 S1000
    G1 F1000 X36.8196 Y32.2984 Z-1.0000 S1000
    G1 F1000 X36.9287 Y32.3266 Z-1.0000 S1000
    G1 F1000 X37.0395 Y32.3469 Z-1.0000 S1000
    G1 F1000 X37.1515 Y32.3593 Z-1.0000 S1000
    G1 F1000 X37.2641 Y32.3637 Z-1.0000 S1000
    G1 F1000 X37.3767 Y32.3601 Z-1.0000 S1000
    G1 F1000 X37.4888 Y32.3486 Z-1.0000 S1000
    G1 F1000 X37.5998 Y32.3291 Z-1.0000 S1000
    G1 F1000 X37.7091 Y32.3018 Z-1.0000 S1000
    G1 F1000 X37.8162 Y32.2668 Z-1.0000 S1000
    G1 F1000 X37.9206 Y32.2243 Z-1.0000 S1000
    G1 F1000 X37.9908 Y32.1907 Z-1.0000 S1000
    G1 F1000 X40.9617 Y30.6769 Z-1.0000 S1000
    G1 F1000 X48.0024 Y45.7758 Z-1.0000 S1000
    G1 F1000 X47.2724 Y46.0826 Z-1.0000 S1000
    G1 F1000 X47.1702 Y46.1299 Z-1.0000 S1000
    G1 F1000 X47.0715 Y46.1843 Z-1.0000 S1000
    G1 F1000 X46.9770 Y46.2456 Z-1.0000 S1000
    G1 F1000 X46.8884 Y46.3123 Z-1.0000 S1000
    G1 F1000 X45.0947 Y47.7646 Z-1.0000 S1000
    G1 F1000 X45.0097 Y47.8386 Z-1.0000 S1000
    G1 F1000 X44.9302 Y47.9184 Z-1.0000 S1000
    G1 F1000 X44.8599 Y47.9994 Z-1.0000 S1000
    G1 F1000 X43.4076 Y49.7931 Z-1.0000 S1000
    G1 F1000 X43.3399 Y49.8832 Z-1.0000 S1000
    G1 F1000 X43.2787 Y49.9778 Z-1.0000 S1000
    G1 F1000 X43.2269 Y50.0714 Z-1.0000 S1000
    G1 F1000 X42.1794 Y52.1274 Z-1.0000 S1000
    G1 F1000 X42.1318 Y52.2296 Z-1.0000 S1000
    G1 F1000 X42.0917 Y52.3349 Z-1.0000 S1000
    G1 F1000 X42.0605 Y52.4373 Z-1.0000 S1000
    G1 F1000 X41.4631 Y54.6673 Z-1.0000 S1000
    G1 F1000 X41.4378 Y54.7771 Z-1.0000 S1000
    G1 F1000 X41.4204 Y54.8884 Z-1.0000 S1000
    G1 F1000 X41.4112 Y54.9949 Z-1.0000 S1000
    G1 F1000 X41.2902 Y57.2995 Z-1.0000 S1000
    G1 F1000 X41.2883 Y57.4121 Z-1.0000 S1000
    G1 F1000 X41.2944 Y57.5246 Z-1.0000 S1000
    G1 F1000 X41.3076 Y57.6311 Z-1.0000 S1000
    G1 F1000 X41.6688 Y59.9106 Z-1.0000 S1000
    G1 F1000 X41.6903 Y60.0212 Z-1.0000 S1000
    G1 F1000 X41.7197 Y60.1300 Z-1.0000 S1000
    G1 F1000 X41.7547 Y60.2312 Z-1.0000 S1000
    G1 F1000 X42.5818 Y62.3856 Z-1.0000 S1000
    G1 F1000 X42.6259 Y62.4893 Z-1.0000 S1000
    G1 F1000 X42.6772 Y62.5896 Z-1.0000 S1000
    G1 F1000 X42.7325 Y62.6813 Z-1.0000 S1000
    G1 F1000 X43.9897 Y64.6168 Z-1.0000 S1000
    G1 F1000 X44.0544 Y64.7091 Z-1.0000 S1000
    G1 F1000 X44.1255 Y64.7965 Z-1.0000 S1000
    G1 F1000 X44.1985 Y64.8746 Z-1.0000 S1000
    G1 F1000 X45.8301 Y66.5062 Z-1.0000 S1000
    G1 F1000 X45.9125 Y66.5830 Z-1.0000 S1000
    G1 F1000 X46.0002 Y66.6538 Z-1.0000 S1000
    G1 F1000 X46.0879 Y66.7150 Z-1.0000 S1000
    G1 F1000 X48.0234 Y67.9722 Z-1.0000 S1000
    G1 F1000 X48.1200 Y68.0302 Z-1.0000 S1000
    G1 F1000 X48.2204 Y68.0812 Z-1.0000 S1000
    G1 F1000 X48.3191 Y68.1229 Z-1.0000 S1000
    G1 F1000 X50.4735 Y68.9500 Z-1.0000 S1000
    G1 F1000 X50.5801 Y68.9867 Z-1.0000 S1000
    G1 F1000 X50.6890 Y69.0156 Z-1.0000 S1000
    G1 F1000 X50.7941 Y69.0359 Z-1.0000 S1000
    G1 F1000 X53.0736 Y69.3971 Z-1.0000 S1000
    G1 F1000 X53.1854 Y69.4108 Z-1.0000 S1000
    G1 F1000 X53.2979 Y69.4165 Z-1.0000 S1000
    G1 F1000 X53.4052 Y69.4145 Z-1.0000 S1000
    G1 F1000 X55.7098 Y69.2935 Z-1.0000 S1000
    G1 F1000 X55.8221 Y69.2836 Z-1.0000 S1000
    G1 F1000 X55.9333 Y69.2658 Z-1.0000 S1000
    G1 F1000 X56.0374 Y69.2416 Z-1.0000 S1000
    G1 F1000 X58.2674 Y68.6442 Z-1.0000 S1000
    G1 F1000 X58.3751 Y68.6112 Z-1.0000 S1000
    G1 F1000 X58.4803 Y68.5707 Z-1.0000 S1000
    G1 F1000 X58.5773 Y68.5253 Z-1.0000 S1000
    G1 F1000 X60.6333 Y67.4778 Z-1.0000 S1000
    G1 F1000 X60.7318 Y67.4231 Z-1.0000 S1000
    G1 F1000 X60.8262 Y67.3616 Z-1.0000 S1000
    G1 F1000 X60.9116 Y67.2971 Z-1.0000 S1000
    G1 F1000 X62.7053 Y65.8448 Z-1.0000 S1000
    G1 F1000 X62.7903 Y65.7708 Z-1.0000 S1000
    G1 F1000 X62.8698 Y65.6910 Z-1.0000 S1000
    G1 F1000 X62.9401 Y65.6100 Z-1.0000 S1000
    G1 F1000 X64.3924 Y63.8163 Z-1.0000 S1000
    G1 F1000 X64.4601 Y63.7262 Z-1.0000 S1000
    G1 F1000 X64.5213 Y63.6316 Z-1.0000 S1000
    G1 F1000 X64.5731 Y63.5380 Z-1.0000 S1000
    G1 F1000 X65.6206 Y61.4820 Z-1.0000 S1000
    G1 F1000 X65.6682 Y61.3798 Z-1.0000 S1000
    G1 F1000 X65.7083 Y61.2745 Z-1.0000 S1000
    G1 F1000 X65.7395 Y61.1721 Z-1.0000 S1000
    G1 F1000 X66.3369 Y58.9421 Z-1.0000 S1000
    G1 F1000 X66.3622 Y58.8323 Z-1.0000 S1000
    G1 F1000 X66.3796 Y58.7210 Z-1.0000 S1000
    G1 F1000 X66.3888 Y58.6145 Z-1.0000 S1000
    G1 F1000 X66.5098 Y56.3099 Z-1.0000 S1000
    G1 F1000 X66.5117 Y56.1973 Z-1.0000 S1000
    G1 F1000 X66.5056 Y56.0848 Z-1.0000 S1000
    G1 F1000 X66.4924 Y55.9783 Z-1.0000 S1000
    G1 F1000 X66.1312 Y53.6988 Z-1.0000 S1000
    G1 F1000 X66.1097 Y53.5882 Z-1.0000 S1000
    G1 F1000 X66.0803 Y53.4794 Z-1.0000 S1000
    G1 F1000 X66.0453 Y53.3782 Z-1.0000 S1000
    G1 F1000 X65.2182 Y51.2238 Z-1.0000 S1000
    G1 F1000 X65.1741 Y51.1201 Z-1.0000 S1000
    G1 F1000 X65.1228 Y51.0198 Z-1.0000 S1000
    G1 F1000 X65.0675 Y50.9281 Z-1.0000 S1000
    G1 F1000 X63.8103 Y48.9926 Z-1.0000 S1000
    G1 F1000 X63.7456 Y48.9003 Z-1.0000 S1000
    G1 F1000 X63.6745 Y48.8129 Z-1.0000 S1000
    G1 F1000 X63.6015 Y48.7348 Z-1.0000 S1000
    G1 F1000 X61.9699 Y47.1032 Z-1.0000 S1000
    G1 F1000 X61.8875 Y47.0264 Z-1.0000 S1000
    G1 F1000 X61.7998 Y46.9556 Z-1.0000 S1000
    G1 F1000 X61.7121 Y46.8944 Z-1.0000 S1000
    G1 F1000 X60.6075 Y46.1769 Z-1.0000 S1000
    G1 F700 Z-2.0000
    G1 F1000 X67.6864 Y30.9960 Z-2.0000 S1000
    G1 F1000 X69.5413 Y32.2004 Z-2.0000 S1000
    G1 F1000 X69.6379 Y32.2583 Z-2.0000 S1000
    G1 F1000 X69.7384 Y32.3093 Z-2.0000 S1000
    G1 F1000 X69.8422 Y32.3530 Z-2.0000 S1000
    G1 F1000 X69.9489 Y32.3892 Z-2.0000 S1000
    G1 F1000 X70.0579 Y32.4178 Z-2.0000 S1000
    G1 F1000 X70.1687 Y32.4386 Z-2.0000 S1000
    G1 F1000 X70.2806 Y32.4515 Z-2.0000 S1000
    G1 F1000 X70.3932 Y32.4563 Z-2.0000 S1000
    G1 F1000 X70.5058 Y32.4532 Z-2.0000 S1000
    G1 F1000 X70.6179 Y32.4422 Z-2.0000 S1000
    G1 F1000 X70.7290 Y32.4232 Z-2.0000 S1000
    G1 F1000 X70.8384 Y32.3963 Z-2.0000 S1000
    G1 F1000 X70.9457 Y32.3618 Z-2.0000 S1000
    G1 F1000 X71.0502 Y32.3197 Z-2.0000 S1000
    G1 F1000 X71.1515 Y32.2704 Z-2.0000 S1000
    G1 F1000 X71.2490 Y32.2139 Z-2.0000 S1000
    G1 F1000 X71.3573 Y32.1397 Z-2.0000 S1000
    G1 F1000 X78.1260 Y27.0718 Z-2.0000 S1000
    G1 F1000 X83.6330 Y32.5787 Z-2.0000 S1000
    G1 F1000 X78.5650 Y39.3474 Z-2.0000 S1000
    G1 F1000 X78.5007 Y39.4400 Z-2.0000 S1000
    G1 F1000 X78.4432 Y39.5368 Z-2.0000 S1000
    G1 F1000 X78.3926 Y39.6375 Z-2.0000 S1000
    G1 F1000 X78.3494 Y39.7416 Z-2.0000 S1000
    G1 F1000 X78.3136 Y39.8484 Z-2.0000 S1000
    G1 F1000 X78.2854 Y39.9575 Z-2.0000 S1000
    G1 F1000 X78.2651 Y40.0683 Z-2.0000 S1000
    G1 F1000 X78.2527 Y40.1803 Z-2.0000 S1000
    G1 F1000 X78.2483 Y40.2929 Z-2.0000 S1000
    G1 F1000 X78.2519 Y40.4055 Z-2.0000 S1000
    G1 F1000 X78.2634 Y40.5176 Z-2.0000 S1000
    G1 F1000 X78.2829 Y40.6286 Z-2.0000 S1000
    G1 F1000 X78.3102 Y40.7379 Z-2.0000 S1000
    G1 F1000 X78.3452 Y40.8450 Z-2.0000 S1000
    G1 F1000 X78.3877 Y40.9494 Z-2.0000 S1000
    G1 F1000 X78.4375 Y41.0505 Z-2.0000 S1000
    G1 F1000 X78.5043 Y41.1634 Z-2.0000 S1000
    G1 F1000 X80.0192 Y43.4966 Z-2.0000 S1000
    G1 F1000 X82.2157 Y49.2179 Z-2.0000 S1000
    G1 F1000 X82.4020 Y50.3936 Z-2.0000 S1000
    G1 F1000 X82.4235 Y50.5042 Z-2.0000 S1000
    G1 F1000 X82.4529 Y50.6130 Z-2.0000 S1000
    G1 F1000 X82.4899 Y50.7194 Z-2.0000 S1000
    G1 F1000 X82.5344 Y50.8230 Z-2.0000 S1000
    G1 F1000 X82.5860 Y50.9231 Z-2.0000 S1000
    G1 F1000 X82.6447 Y51.0193 Z-2.0000 S1000
    G1 F1000 X82.7100 Y51.1111 Z-2.0000 S1000
    G1 F1000 X82.7817 Y51.1980 Z-2.0000 S1000
    G1 F1000 X82.8594 Y51.2796 Z-2.0000 S1000
    G1 F1000 X82.9427 Y51.3556 Z-2.0000 S1000
    G1 F1000 X83.0311 Y51.4254 Z-2.0000 S1000
    G1 F1000 X83.1243 Y51.4887 Z-2.0000 S1000
    G1 F1000 X83.2217 Y51.5453 Z-2.0000 S1000
    G1 F1000 X83.3229 Y51.5949 Z-2.0000 S1000
    G1 F1000 X83.4274 Y51.6371 Z-2.0000 S1000
    G1 F1000 X83.5346 Y51.6718 Z-2.0000 S1000
    G1 F1000 X83.6439 Y51.6989 Z-2.0000 S1000
    G1 F1000 X83.7441 Y51.7166 Z-2.0000 S1000
    G1 F1000 X92.0548 Y52.9107 Z-2.0000 S1000
    G1 F1000 X92.0548 Y60.6987 Z-2.0000 S1000
    G1 F1000 X83.7146 Y61.8968 Z-2.0000 S1000
    G1 F1000 X83.6037 Y61.9168 Z-2.0000 S1000
    G1 F1000 X83.4945 Y61.9446 Z-2.0000 S1000
    G1 F1000 X83.3875 Y61.9800 Z-2.0000 S1000
    G1 F1000 X83.2834 Y62.0230 Z-2.0000 S1000
    G1 F1000 X83.1825 Y62.0732 Z-2.0000 S1000
    G1 F1000 X83.0855 Y62.1305 Z-2.0000 S1000
    G1 F1000 X82.9927 Y62.1945 Z-2.0000 S1000
    G1 F1000 X82.9048 Y62.2649 Z-2.0000 S1000
    G1 F1000 X82.8220 Y62.3414 Z-2.0000 S1000
    G1 F1000 X82.7449 Y62.4236 Z-2.0000 S1000
    G1 F1000 X82.6738 Y62.5110 Z-2.0000 S1000
    G1 F1000 X82.6091 Y62.6032 Z-2.0000 S1000
    G1 F1000 X82.5511 Y62.6998 Z-2.0000 S1000
    G1 F1000 X82.5001 Y62.8003 Z-2.0000 S1000
    G1 F1000 X82.4564 Y62.9042 Z-2.0000 S1000
    G1 F1000 X82.4069 Y63.0573 Z-2.0000 S1000
    G1 F1000 X81.2675 Y67.3097 Z-2.0000 S1000
    G1 F1000 X78.5140 Y72.7139 Z-2.0000 S1000
    G1 F1000 X78.4665 Y72.8161 Z-2.0000 S1000
    G1 F1000 X78.4263 Y72.9213 Z-2.0000 S1000
    G1 F1000 X78.3936 Y73.0292 Z-2.0000 S1000
    G1 F1000 X78.3688 Y73.1391 Z-2.0000 S1000
    G1 F1000 X78.3517 Y73.2504 Z-2.0000 S1000
    G1 F1000 X78.3426 Y73.3628 Z-2.0000 S1000
    G1 F1000 X78.3415 Y73.4754 Z-2.0000 S1000
    G1 F1000 X78.3484 Y73.5879 Z-2.0000 S1000
    G1 F1000 X78.3633 Y73.6996 Z-2.0000 S1000
    G1 F1000 X78.3860 Y73.8099 Z-2.0000 S1000
    G1 F1000 X78.4165 Y73.9184 Z-2.0000 S1000
    G1 F1000 X78.4546 Y74.0244 Z-2.0000 S1000
    G1 F1000 X78.5002 Y74.1275 Z-2.0000 S1000
    G1 F1000 X78.5529 Y74.2271 Z-2.0000 S1000
    G1 F1000 X78.6126 Y74.3226 Z-2.0000 S1000
    G1 F1000 X78.6577 Y74.3861 Z-2.0000 S1000
    G1 F1000 X83.6330 Y81.0307 Z-2.0000 S1000
    G1 F1000 X78.1260 Y86.5377 Z-2.0000 S1000
    G1 F1000 X71.4814 Y81.5624 Z-2.0000 S1000
    G1 F1000 X71.3889 Y81.4982 Z-2.0000 S1000
    G1 F1000 X71.2920 Y81.4406 Z-2.0000 S1000
    G1 F1000 X71.1913 Y81.3900 Z-2.0000 S1000
    G1 F1000 X71.0873 Y81.3468 Z-2.0000 S1000
    G1 F1000 X70.9804 Y81.3110 Z-2.0000 S1000
    G1 F1000 X70.8713 Y81.2828 Z-2.0000 S1000
    G1 F1000 X70.7605 Y81.2625 Z-2.0000 S1000
    G1 F1000 X70.6485 Y81.2501 Z-2.0000 S1000
    G1 F1000 X70.5359 Y81.2457 Z-2.0000 S1000
    G1 F1000 X70.4233 Y81.2493 Z-2.0000 S1000
    G1 F1000 X70.3112 Y81.2608 Z-2.0000 S1000
    G1 F1000 X70.2002 Y81.2803 Z-2.0000 S1000
    G1 F1000 X70.0909 Y81.3076 Z-2.0000 S1000
    G1 F1000 X69.9838 Y81.3426 Z-2.0000 S1000
    G1 F1000 X69.8794 Y81.3851 Z-2.0000 S1000
    G1 F1000 X69.8092 Y81.4187 Z-2.0000 S1000
    G1 F1000 X64.4050 Y84.1722 Z-2.0000 S1000
    G1 F1000 X60.1526 Y85.3116 Z-2.0000 S1000
    G1 F1000 X60.0449 Y85.3446 Z-2.0000 S1000
    G1 F1000 X59.9398 Y85.3852 Z-2.0000 S1000
    G1 F1000 X59.8378 Y85.4331 Z-2.0000 S1000
    G1 F1000 X59.7395 Y85.4881 Z-2.0000 S1000
    G1 F1000 X59.6453 Y85.5500 Z-2.0000 S1000
    G1 F1000 X59.5558 Y85.6184 Z-2.0000 S1000
    G1 F1000 X59.4713 Y85.6929 Z-2.0000 S1000
    G1 F1000 X59.3923 Y85.7733 Z-2.0000 S1000
    G1 F1000 X59.3193 Y85.8591 Z-2.0000 S1000
    G1 F1000 X59.2525 Y85.9498 Z-2.0000 S1000
    G1 F1000 X59.1923 Y86.0451 Z-2.0000 S1000
    G1 F1000 X59.1390 Y86.1444 Z-2.0000 S1000
    G1 F1000 X59.0929 Y86.2472 Z-2.0000 S1000
    G1 F1000 X59.0542 Y86.3530 Z-2.0000 S1000
    G1 F1000 X59.0231 Y86.4613 Z-2.0000 S1000
    G1 F1000 X58.9921 Y86.6193 Z-2.0000 S1000
    G1 F1000 X57.7940 Y94.9595 Z-2.0000 S1000
    G1 F1000 X50.0060 Y94.9595 Z-2.0000 S1000
    G1 F1000 X48.8119 Y86.6488 Z-2.0000 S1000
    G1 F1000 X48.7919 Y86.5379 Z-2.0000 S1000
    G1 F1000 X48.7641 Y86.4287 Z-2.0000 S1000
    G1 F1000 X48.7286 Y86.3218 Z-2.0000 S1000
    G1 F1000 X48.6857 Y86.2176 Z-2.0000 S1000
    G1 F1000 X48.6354 Y86.1168 Z-2.0000 S1000
    G1 F1000 X48.5782 Y86.0197 Z-2.0000 S1000
    G1 F1000 X48.5142 Y85.9270 Z-2.0000 S1000
    G1 F1000 X48.4437 Y85.8390 Z-2.0000 S1000
    G1 F1000 X48.3673 Y85.7563 Z-2.0000 S1000
    G1 F1000 X48.2851 Y85.6792 Z-2.0000 S1000
    G1 F1000 X48.1977 Y85.6081 Z-2.0000 S1000
    G1 F1000 X48.1054 Y85.5434 Z-2.0000 S1000
    G1 F1000 X48.0088 Y85.4854 Z-2.0000 S1000
    G1 F1000 X47.9083 Y85.4344 Z-2.0000 S1000
    G1 F1000 X47.8045 Y85.3907 Z-2.0000 S1000
    G1 F1000 X47.6978 Y85.3544 Z-2.0000 S1000
    G1 F1000 X47.5888 Y85.3258 Z-2.0000 S1000
    G1 F1000 X47.4889 Y85.3067 Z-2.0000 S1000
    G1 F1000 X46.3132 Y85.1204 Z-2.0000 S1000
    G1 F1000 X40.5919 Y82.9239 Z-2.0000 S1000
    G1 F1000 X38.2587 Y81.4090 Z-2.0000 S1000
    G1 F1000 X38.1621 Y81.3511 Z-2.0000 S1000
    G1 F1000 X38.0616 Y81.3001 Z-2.0000 S1000
    G1 F1000 X37.9578 Y81.2564 Z-2.0000 S1000
    G1 F1000 X37.8511 Y81.2202 Z-2.0000 S1000
    G1 F1000 X37.7421 Y81.1916 Z-2.0000 S1000
    G1 F1000 X37.6313 Y81.1708 Z-2.0000 S1000
    G1 F1000 X37.5194 Y81.1579 Z-2.0000 S1000
    G1 F1000 X37.4068 Y81.1531 Z-2.0000 S1000
    G1 F1000 X37.2942 Y81.1562 Z-2.0000 S1000
    G1 F1000 X37.1821 Y81.1672 Z-2.0000 S1000
    G1 F1000 X37.0710 Y81.1862 Z-2.0000 S1000
    G1 F1000 X36.9616 Y81.2131 Z-2.0000 S1000
    G1 F1000 X36.8543 Y81.2476 Z-2.0000 S1000
    G1 F1000 X36.7498 Y81.2897 Z-2.0000 S1000
    G1 F1000 X36.6485 Y81.3390 Z-2.0000 S1000
    G1 F1000 X36.5510 Y81.3955 Z-2.0000 S1000
    G1 F1000 X36.4427 Y81.4697 Z-2.0000 S1000
    G1 F1000 X29.6740 Y86.5377 Z-2.0000 S1000
    G1 F1000 X24.1670 Y81.0307 Z-2.0000 S1000
    G1 F1000 X29.2350 Y74.2621 Z-2.0000 S1000
    G1 F1000 X29.2993 Y74.1695 Z-2.0000 S1000
    G1 F1000 X29.3568 Y74.0727 Z-2.0000 S1000
    G1 F1000 X29.4074 Y73.9720 Z-2.0000 S1000
    G1 F1000 X29.4506 Y73.8679 Z-2.0000 S1000
    G1 F1000 X29.4864 Y73.7611 Z-2.0000 S1000
    G1 F1000 X29.5146 Y73.6520 Z-2.0000 S1000
    G1 F1000 X29.5349 Y73.5412 Z-2.0000 S1000
    G1 F1000 X29.5473 Y73.4292 Z-2.0000 S1000
    G1 F1000 X29.5517 Y73.3166 Z-2.0000 S1000
    G1 F1000 X29.5481 Y73.2040 Z-2.0000 S1000
    G1 F1000 X29.5366 Y73.0919 Z-2.0000 S1000
    G1 F1000 X29.5171 Y72.9809 Z-2.0000 S1000
    G1 F1000 X29.4898 Y72.8716 Z-2.0000 S1000
    G1 F1000 X29.4548 Y72.7645 Z-2.0000 S1000
    G1 F1000 X29.4123 Y72.6601 Z-2.0000 S1000
    G1 F1000 X29.3625 Y72.5590 Z-2.0000 S1000
    G1 F1000 X29.2957 Y72.4461 Z-2.0000 S1000
    G1 F1000 X27.7808 Y70.1128 Z-2.0000 S1000
    G1 F1000 X25.5843 Y64.3915 Z-2.0000 S1000
    G1 F1000 X25.3980 Y63.2158 Z-2.0000 S1000
    G1 F1000 X25.3765 Y63.1052 Z-2.0000 S1000
    G1 F1000 X25.3471 Y62.9964 Z-2.0000 S1000
    G1 F1000 X25.3101 Y62.8900 Z-2.0000 S1000
    G1 F1000 X25.2656 Y62.7864 Z-2.0000 S1000
    G1 F1000 X25.2140 Y62.6863 Z-2.0000 S1000
    G1 F1000 X25.1553 Y62.5901 Z-2.0000 S1000
    G1 F1000 X25.0900 Y62.4983 Z-2.0000 S1000
    G1 F1000 X25.0183 Y62.4114 Z-2.0000 S1000
    G1 F1000 X24.9406 Y62.3298 Z-2.0000 S1000
    G1 F1000 X24.8573 Y62.2538 Z-2.0000 S1000
    G1 F1000 X24.7689 Y62.1840 Z-2.0000 S1000
    G1 F1000 X24.6757 Y62.1207 Z-2.0000 S1000
    G1 F1000 X24.5783 Y62.0641 Z-2.0000 S1000
    G1 F1000 X24.4771 Y62.0145 Z-2.0000 S1000
    G1 F1000 X24.3726 Y61.9723 Z-2.0000 S1000
    G1 F1000 X24.2654 Y61.9376 Z-2.0000 S1000
    G1 F1000 X24.1561 Y61.9105 Z-2.0000 S1000
    G1 F1000 X24.0559 Y61.8928 Z-2.0000 S1000
    G1 F1000 X15.7452 Y60.6987 Z-2.0000 S1000
    G1 F1000 X15.7452 Y52.9107 Z-2.0000 S1000
    G1 F1000 X24.0854 Y51.7127 Z-2.0000 S1000
    G1 F1000 X24.1963 Y51.6927 Z-2.0000 S1000
    G1 F1000 X24.3055 Y51.6649 Z-2.0000 S1000
    G1 F1000 X24.4125 Y51.6295 Z-2.0000 S1000
    G1 F1000 X24.5166 Y51.5865 Z-2.0000 S1000
    G1 F1000 X24.6175 Y51.5363 Z-2.0000 S1000
    G1 F1000 X24.7145 Y51.4790 Z-2.0000 S1000
    G1 F1000 X24.8073 Y51.4150 Z-2.0000 S1000
    G1 F1000 X24.8952 Y51.3446 Z-2.0000 S1000
    G1 F1000 X24.9780 Y51.2681 Z-2.0000 S1000
    G1 F1000 X25.0551 Y51.1859 Z-2.0000 S1000
    G1 F1000 X25.1262 Y51.0985 Z-2.0000 S1000
    G1 F1000 X25.1909 Y51.0063 Z-2.0000 S1000
    G1 F1000 X25.2489 Y50.9097 Z-2.0000 S1000
    G1 F1000 X25.2999 Y50.8092 Z-2.0000 S1000
    G1 F1000 X25.3436 Y50.7054 Z-2.0000 S1000
    G1 F1000 X25.3931 Y50.5522 Z-2.0000 S1000
    G1 F1000 X26.5325 Y46.2998 Z-2.0000 S1000
    G1 F1000 X29.2860 Y40.8955 Z-2.0000 S1000
    G1 F1000 X29.3335 Y40.7933 Z-2.0000 S1000
    G1 F1000 X29.3737 Y40.6881 Z-2.0000 S1000
    G1 F1000 X29.4064 Y40.5802 Z-2.0000 S1000
    G1 F1000 X29.4313 Y40.4703 Z-2.0000 S1000
    G1 F1000 X29.4483 Y40.3589 Z-2.0000 S1000
    G1 F1000 X29.4574 Y40.2466 Z-2.0000 S1000
    G1 F1000 X29.4585 Y40.1340 Z-2.0000 S1000
    G1 F1000 X29.4516 Y40.0215 Z-2.0000 S1000
    G1 F1000 X29.4367 Y39.9098 Z-2.0000 S1000
    G1 F1000 X29.4140 Y39.7994 Z-2.0000 S1000
    G1 F1000 X29.3835 Y39.6910 Z-2.0000 S1000
    G1 F1000 X29.3453 Y39.5849 Z-2.0000 S1000
    G1 F1000 X29.2998 Y39.4819 Z-2.0000 S1000
    G1 F1000 X29.2470 Y39.3823 Z-2.0000 S1000
    G1 F1000 X29.1874 Y39.2867 Z-2.0000 S1000
    G1 F1000 X29.1423 Y39.2233 Z-2.0000 S1000
    G1 F1000 X24.1670 Y32.5787 Z-2.0000 S1000
    G1 F1000 X29.6740 Y27.0718 Z-2.0000 S1000
    G1 F1000 X36.3186 Y32.0470 Z-2.0000 S1000
    G1 F1000 X36.4111 Y32.1113 Z-2.0000 S1000
    G1 F1000 X36.5080 Y32.1688 Z-2.0000 S1000
    G1 F1000 X36.6087 Y32.2194 Z-2.0000 S1000
    G1 F1000 X36.7127 Y32.2626 Z-2.0000 S1000
    G1 F1000 X36.8196 Y32.2984 Z-2.0000 S1000
    G1 F1000 X36.9287 Y32.3266 Z-2.0000 S1000
    G1 F1000 X37.0395 Y32.3469 Z-2.0000 S1000
    G1 F1000 X37.1515 Y32.3593 Z-2.0000 S1000
    G1 F1000 X37.2641 Y32.3637 Z-2.0000 S1000
    G1 F1000 X37.3767 Y32.3601 Z-2.0000 S1000
    G1 F1000 X37.4888 Y32.3486 Z-2.0000 S1000
    G1 F1000 X37.5998 Y32.3291 Z-2.0000 S1000
    G1 F1000 X37.7091 Y32.3018 Z-2.0000 S1000
    G1 F1000 X37.8162 Y32.2668 Z-2.0000 S1000
    G1 F1000 X37.9206 Y32.2243 Z-2.0000 S1000
    G1 F1000 X37.9908 Y32.1907 Z-2.0000 S1000
    G1 F1000 X40.9617 Y30.6769 Z-2.0000 S1000
    G1 F1000 X48.0024 Y45.7758 Z-2.0000 S1000
    G1 F1000 X47.2724 Y46.0826 Z-2.0000 S1000
    G1 F1000 X47.1702 Y46.1299 Z-2.0000 S1000
    G1 F1000 X47.0715 Y46.1843 Z-2.0000 S1000
    G1 F1000 X46.9770 Y46.2456 Z-2.0000 S1000
    G1 F1000 X46.8884 Y46.3123 Z-2.0000 S1000
    G1 F1000 X45.0947 Y47.7646 Z-2.0000 S1000
    G1 F1000 X45.0097 Y47.8386 Z-2.0000 S1000
    G1 F1000 X44.9302 Y47.9184 Z-2.0000 S1000
    G1 F1000 X44.8599 Y47.9994 Z-2.0000 S1000
    G1 F1000 X43.4076 Y49.7931 Z-2.0000 S1000
    G1 F1000 X43.3399 Y49.8832 Z-2.0000 S1000
    G1 F1000 X43.2787 Y49.9778 Z-2.0000 S1000
    G1 F1000 X43.2269 Y50.0714 Z-2.0000 S1000
    G1 F1000 X42.1794 Y52.1274 Z-2.0000 S1000
    G1 F1000 X42.1318 Y52.2296 Z-2.0000 S1000
    G1 F1000 X42.0917 Y52.3349 Z-2.0000 S1000
    G1 F1000 X42.0605 Y52.4373 Z-2.0000 S1000
    G1 F1000 X41.4631 Y54.6673 Z-2.0000 S1000
    G1 F1000 X41.4378 Y54.7771 Z-2.0000 S1000
    G1 F1000 X41.4204 Y54.8884 Z-2.0000 S1000
    G1 F1000 X41.4112 Y54.9949 Z-2.0000 S1000
    G1 F1000 X41.2902 Y57.2995 Z-2.0000 S1000
    G1 F1000 X41.2883 Y57.4121 Z-2.0000 S1000
    G1 F1000 X41.2944 Y57.5246 Z-2.0000 S1000
    G1 F1000 X41.3076 Y57.6311 Z-2.0000 S1000
    G1 F1000 X41.6688 Y59.9106 Z-2.0000 S1000
    G1 F1000 X41.6903 Y60.0212 Z-2.0000 S1000
    G1 F1000 X41.7197 Y60.1300 Z-2.0000 S1000
    G1 F1000 X41.7547 Y60.2312 Z-2.0000 S1000
    G1 F1000 X42.5818 Y62.3856 Z-2.0000 S1000
    G1 F1000 X42.6259 Y62.4893 Z-2.0000 S1000
    G1 F1000 X42.6772 Y62.5896 Z-2.0000 S1000
    G1 F1000 X42.7325 Y62.6813 Z-2.0000 S1000
    G1 F1000 X43.9897 Y64.6168 Z-2.0000 S1000
    G1 F1000 X44.0544 Y64.7091 Z-2.0000 S1000
    G1 F1000 X44.1255 Y64.7965 Z-2.0000 S1000
    G1 F1000 X44.1985 Y64.8746 Z-2.0000 S1000
    G1 F1000 X45.8301 Y66.5062 Z-2.0000 S1000
    G1 F1000 X45.9125 Y66.5830 Z-2.0000 S1000
    G1 F1000 X46.0002 Y66.6538 Z-2.0000 S1000
    G1 F1000 X46.0879 Y66.7150 Z-2.0000 S1000
    G1 F1000 X48.0234 Y67.9722 Z-2.0000 S1000
    G1 F1000 X48.1200 Y68.0302 Z-2.0000 S1000
    G1 F1000 X48.2204 Y68.0812 Z-2.0000 S1000
    G1 F1000 X48.3191 Y68.1229 Z-2.0000 S1000
    G1 F1000 X50.4735 Y68.9500 Z-2.0000 S1000
    G1 F1000 X50.5801 Y68.9867 Z-2.0000 S1000
    G1 F1000 X50.6890 Y69.0156 Z-2.0000 S1000
    G1 F1000 X50.7941 Y69.0359 Z-2.0000 S1000
    G1 F1000 X53.0736 Y69.3971 Z-2.0000 S1000
    G1 F1000 X53.1854 Y69.4108 Z-2.0000 S1000
    G1 F1000 X53.2979 Y69.4165 Z-2.0000 S1000
    G1 F1000 X53.4052 Y69.4145 Z-2.0000 S1000
    G1 F1000 X55.7098 Y69.2935 Z-2.0000 S1000
    G1 F1000 X55.8221 Y69.2836 Z-2.0000 S1000
    G1 F1000 X55.9333 Y69.2658 Z-2.0000 S1000
    G1 F1000 X56.0374 Y69.2416 Z-2.0000 S1000
    G1 F1000 X58.2674 Y68.6442 Z-2.0000 S1000
    G1 F1000 X58.3751 Y68.6112 Z-2.0000 S1000
    G1 F1000 X58.4803 Y68.5707 Z-2.0000 S1000
    G1 F1000 X58.5773 Y68.5253 Z-2.0000 S1000
    G1 F1000 X60.6333 Y67.4778 Z-2.0000 S1000
    G1 F1000 X60.7318 Y67.4231 Z-2.0000 S1000
    G1 F1000 X60.8262 Y67.3616 Z-2.0000 S1000
    G1 F1000 X60.9116 Y67.2971 Z-2.0000 S1000
    G1 F1000 X62.7053 Y65.8448 Z-2.0000 S1000
    G1 F1000 X62.7903 Y65.7708 Z-2.0000 S1000
    G1 F1000 X62.8698 Y65.6910 Z-2.0000 S1000
    G1 F1000 X62.9401 Y65.6100 Z-2.0000 S1000
    G1 F1000 X64.3924 Y63.8163 Z-2.0000 S1000
    G1 F1000 X64.4601 Y63.7262 Z-2.0000 S1000
    G1 F1000 X64.5213 Y63.6316 Z-2.0000 S1000
    G1 F1000 X64.5731 Y63.5380 Z-2.0000 S1000
    G1 F1000 X65.6206 Y61.4820 Z-2.0000 S1000
    G1 F1000 X65.6682 Y61.3798 Z-2.0000 S1000
    G1 F1000 X65.7083 Y61.2745 Z-2.0000 S1000
    G1 F1000 X65.7395 Y61.1721 Z-2.0000 S1000
    G1 F1000 X66.3369 Y58.9421 Z-2.0000 S1000
    G1 F1000 X66.3622 Y58.8323 Z-2.0000 S1000
    G1 F1000 X66.3796 Y58.7210 Z-2.0000 S1000
    G1 F1000 X66.3888 Y58.6145 Z-2.0000 S1000
    G1 F1000 X66.5098 Y56.3099 Z-2.0000 S1000
    G1 F1000 X66.5117 Y56.1973 Z-2.0000 S1000
    G1 F1000 X66.5056 Y56.0848 Z-2.0000 S1000
    G1 F1000 X66.4924 Y55.9783 Z-2.0000 S1000
    G1 F1000 X66.1312 Y53.6988 Z-2.0000 S1000
    G1 F1000 X66.1097 Y53.5882 Z-2.0000 S1000
    G1 F1000 X66.0803 Y53.4794 Z-2.0000 S1000
    G1 F1000 X66.0453 Y53.3782 Z-2.0000 S1000
    G1 F1000 X65.2182 Y51.2238 Z-2.0000 S1000
    G1 F1000 X65.1741 Y51.1201 Z-2.0000 S1000
    G1 F1000 X65.1228 Y51.0198 Z-2.0000 S1000
    G1 F1000 X65.0675 Y50.9281 Z-2.0000 S1000
    G1 F1000 X63.8103 Y48.9926 Z-2.0000 S1000
    G1 F1000 X63.7456 Y48.9003 Z-2.0000 S1000
    G1 F1000 X63.6745 Y48.8129 Z-2.0000 S1000
    G1 F1000 X63.6015 Y48.7348 Z-2.0000 S1000
    G1 F1000 X61.9699 Y47.1032 Z-2.0000 S1000
    G1 F1000 X61.8875 Y47.0264 Z-2.0000 S1000
    G1 F1000 X61.7998 Y46.9556 Z-2.0000 S1000
    G1 F1000 X61.7121 Y46.8944 Z-2.0000 S1000
    G1 F1000 X60.6075 Y46.1769 Z-2.0000 S1000
    G1 F700 Z-3.0000
    G1 F1000 X67.6864 Y30.9960 Z-3.0000 S1000
    G1 F1000 X69.5413 Y32.2004 Z-3.0000 S1000
    G1 F1000 X69.6379 Y32.2583 Z-3.0000 S1000
    G1 F1000 X69.7384 Y32.3093 Z-3.0000 S1000
    G1 F1000 X69.8422 Y32.3530 Z-3.0000 S1000
    G1 F1000 X69.9489 Y32.3892 Z-3.0000 S1000
    G1 F1000 X70.0579 Y32.4178 Z-3.0000 S1000
    G1 F1000 X70.1687 Y32.4386 Z-3.0000 S1000
    G1 F1000 X70.2806 Y32.4515 Z-3.0000 S1000
    G1 F1000 X70.3932 Y32.4563 Z-3.0000 S1000
    G1 F1000 X70.5058 Y32.4532 Z-3.0000 S1000
    G1 F1000 X70.6179 Y32.4422 Z-3.0000 S1000
    G1 F1000 X70.7290 Y32.4232 Z-3.0000 S1000
    G1 F1000 X70.8384 Y32.3963 Z-3.0000 S1000
    G1 F1000 X70.9457 Y32.3618 Z-3.0000 S1000
    G1 F1000 X71.0502 Y32.3197 Z-3.0000 S1000
    G1 F1000 X71.1515 Y32.2704 Z-3.0000 S1000
    G1 F1000 X71.2490 Y32.2139 Z-3.0000 S1000
    G1 F1000 X71.3573 Y32.1397 Z-3.0000 S1000
    G1 F1000 X78.1260 Y27.0718 Z-3.0000 S1000
    G1 F1000 X83.6330 Y32.5787 Z-3.0000 S1000
    G1 F1000 X78.5650 Y39.3474 Z-3.0000 S1000
    G1 F1000 X78.5007 Y39.4400 Z-3.0000 S1000
    G1 F1000 X78.4432 Y39.5368 Z-3.0000 S1000
    G1 F1000 X78.3926 Y39.6375 Z-3.0000 S1000
    G1 F1000 X78.3494 Y39.7416 Z-3.0000 S1000
    G1 F1000 X78.3136 Y39.8484 Z-3.0000 S1000
    G1 F1000 X78.2854 Y39.9575 Z-3.0000 S1000
    G1 F1000 X78.2651 Y40.0683 Z-3.0000 S1000
    G1 F1000 X78.2527 Y40.1803 Z-3.0000 S1000
    G1 F1000 X78.2483 Y40.2929 Z-3.0000 S1000
    G1 F1000 X78.2519 Y40.4055 Z-3.0000 S1000
    G1 F1000 X78.2634 Y40.5176 Z-3.0000 S1000
    G1 F1000 X78.2829 Y40.6286 Z-3.0000 S1000
    G1 F1000 X78.3102 Y40.7379 Z-3.0000 S1000
    G1 F1000 X78.3452 Y40.8450 Z-3.0000 S1000
    G1 F1000 X78.3877 Y40.9494 Z-3.0000 S1000
    G1 F1000 X78.4375 Y41.0505 Z-3.0000 S1000
    G1 F1000 X78.5043 Y41.1634 Z-3.0000 S1000
    G1 F1000 X80.0192 Y43.4966 Z-3.0000 S1000
    G1 F1000 X82.2157 Y49.2179 Z-3.0000 S1000
    G1 F1000 X82.4020 Y50.3936 Z-3.0000 S1000
    G1 F1000 X82.4235 Y50.5042 Z-3.0000 S1000
    G1 F1000 X82.4529 Y50.6130 Z-3.0000 S1000
    G1 F1000 X82.4899 Y50.7194 Z-3.0000 S1000
    G1 F1000 X82.5344 Y50.8230 Z-3.0000 S1000
    G1 F1000 X82.5860 Y50.9231 Z-3.0000 S1000
    G1 F1000 X82.6447 Y51.0193 Z-3.0000 S1000
    G1 F1000 X82.7100 Y51.1111 Z-3.0000 S1000
    G1 F1000 X82.7817 Y51.1980 Z-3.0000 S1000
    G1 F1000 X82.8594 Y51.2796 Z-3.0000 S1000
    G1 F1000 X82.9427 Y51.3556 Z-3.0000 S1000
    G1 F1000 X83.0311 Y51.4254 Z-3.0000 S1000
    G1 F1000 X83.1243 Y51.4887 Z-3.0000 S1000
    G1 F1000 X83.2217 Y51.5453 Z-3.0000 S1000
    G1 F1000 X83.3229 Y51.5949 Z-3.0000 S1000
    G1 F1000 X83.4274 Y51.6371 Z-3.0000 S1000
    G1 F1000 X83.5346 Y51.6718 Z-3.0000 S1000
    G1 F1000 X83.6439 Y51.6989 Z-3.0000 S1000
    G1 F1000 X83.7441 Y51.7166 Z-3.0000 S1000
    G1 F1000 X92.0548 Y52.9107 Z-3.0000 S1000
    G1 F1000 X92.0548 Y60.6987 Z-3.0000 S1000
    G1 F1000 X83.7146 Y61.8968 Z-3.0000 S1000
    G1 F1000 X83.6037 Y61.9168 Z-3.0000 S1000
    G1 F1000 X83.4945 Y61.9446 Z-3.0000 S1000
    G1 F1000 X83.3875 Y61.9800 Z-3.0000 S1000
    G1 F1000 X83.2834 Y62.0230 Z-3.0000 S1000
    G1 F1000 X83.1825 Y62.0732 Z-3.0000 S1000
    G1 F1000 X83.0855 Y62.1305 Z-3.0000 S1000
    G1 F1000 X82.9927 Y62.1945 Z-3.0000 S1000
    G1 F1000 X82.9048 Y62.2649 Z-3.0000 S1000
    G1 F1000 X82.8220 Y62.3414 Z-3.0000 S1000
    G1 F1000 X82.7449 Y62.4236 Z-3.0000 S1000
    G1 F1000 X82.6738 Y62.5110 Z-3.0000 S1000
    G1 F1000 X82.6091 Y62.6032 Z-3.0000 S1000
    G1 F1000 X82.5511 Y62.6998 Z-3.0000 S1000
    G1 F1000 X82.5001 Y62.8003 Z-3.0000 S1000
    G1 F1000 X82.4564 Y62.9042 Z-3.0000 S1000
    G1 F1000 X82.4069 Y63.0573 Z-3.0000 S1000
    G1 F1000 X81.2675 Y67.3097 Z-3.0000 S1000
    G1 F1000 X78.5140 Y72.7139 Z-3.0000 S1000
    G1 F1000 X78.4665 Y72.8161 Z-3.0000 S1000
    G1 F1000 X78.4263 Y72.9213 Z-3.0000 S1000
    G1 F1000 X78.3936 Y73.0292 Z-3.0000 S1000
    G1 F1000 X78.3688 Y73.1391 Z-3.0000 S1000
    G1 F1000 X78.3517 Y73.2504 Z-3.0000 S1000
    G1 F1000 X78.3426 Y73.3628 Z-3.0000 S1000
    G1 F1000 X78.3415 Y73.4754 Z-3.0000 S1000
    G1 F1000 X78.3484 Y73.5879 Z-3.0000 S1000
    G1 F1000 X78.3633 Y73.6996 Z-3.0000 S1000
    G1 F1000 X78.3860 Y73.8099 Z-3.0000 S1000
    G1 F1000 X78.4165 Y73.9184 Z-3.0000 S1000
    G1 F1000 X78.4546 Y74.0244 Z-3.0000 S1000
    G1 F1000 X78.5002 Y74.1275 Z-3.0000 S1000
    G1 F1000 X78.5529 Y74.2271 Z-3.0000 S1000
    G1 F1000 X78.6126 Y74.3226 Z-3.0000 S1000
    G1 F1000 X78.6577 Y74.3861 Z-3.0000 S1000
    G1 F1000 X83.6330 Y81.0307 Z-3.0000 S1000
    G1 F1000 X78.1260 Y86.5377 Z-3.0000 S1000
    G1 F1000 X71.4814 Y81.5624 Z-3.0000 S1000
    G1 F1000 X71.3889 Y81.4982 Z-3.0000 S1000
    G1 F1000 X71.2920 Y81.4406 Z-3.0000 S1000
    G1 F1000 X71.1913 Y81.3900 Z-3.0000 S1000
    G1 F1000 X71.0873 Y81.3468 Z-3.0000 S1000
    G1 F1000 X70.9804 Y81.3110 Z-3.0000 S1000
    G1 F1000 X70.8713 Y81.2828 Z-3.0000 S1000
    G1 F1000 X70.7605 Y81.2625 Z-3.0000 S1000
    G1 F1000 X70.6485 Y81.2501 Z-3.0000 S1000
    G1 F1000 X70.5359 Y81.2457 Z-3.0000 S1000
    G1 F1000 X70.4233 Y81.2493 Z-3.0000 S1000
    G1 F1000 X70.3112 Y81.2608 Z-3.0000 S1000
    G1 F1000 X70.2002 Y81.2803 Z-3.0000 S1000
    G1 F1000 X70.0909 Y81.3076 Z-3.0000 S1000
    G1 F1000 X69.9838 Y81.3426 Z-3.0000 S1000
    G1 F1000 X69.8794 Y81.3851 Z-3.0000 S1000
    G1 F1000 X69.8092 Y81.4187 Z-3.0000 S1000
    G1 F1000 X64.4050 Y84.1722 Z-3.0000 S1000
    G1 F1000 X60.1526 Y85.3116 Z-3.0000 S1000
    G1 F1000 X60.0449 Y85.3446 Z-3.0000 S1000
    G1 F1000 X59.9398 Y85.3852 Z-3.0000 S1000
    G1 F1000 X59.8378 Y85.4331 Z-3.0000 S1000
    G1 F1000 X59.7395 Y85.4881 Z-3.0000 S1000
    G1 F1000 X59.6453 Y85.5500 Z-3.0000 S1000
    G1 F1000 X59.5558 Y85.6184 Z-3.0000 S1000
    G1 F1000 X59.4713 Y85.6929 Z-3.0000 S1000
    G1 F1000 X59.3923 Y85.7733 Z-3.0000 S1000
    G1 F1000 X59.3193 Y85.8591 Z-3.0000 S1000
    G1 F1000 X59.2525 Y85.9498 Z-3.0000 S1000
    G1 F1000 X59.1923 Y86.0451 Z-3.0000 S1000
    G1 F1000 X59.1390 Y86.1444 Z-3.0000 S1000
    G1 F1000 X59.0929 Y86.2472 Z-3.0000 S1000
    G1 F1000 X59.0542 Y86.3530 Z-3.0000 S1000
    G1 F1000 X59.0231 Y86.4613 Z-3.0000 S1000
    G1 F1000 X58.9921 Y86.6193 Z-3.0000 S1000
    G1 F1000 X57.7940 Y94.9595 Z-3.0000 S1000
    G1 F1000 X50.0060 Y94.9595 Z-3.0000 S1000
    G1 F1000 X48.8119 Y86.6488 Z-3.0000 S1000
    G1 F1000 X48.7919 Y86.5379 Z-3.0000 S1000
    G1 F1000 X48.7641 Y86.4287 Z-3.0000 S1000
    G1 F1000 X48.7286 Y86.3218 Z-3.0000 S1000
    G1 F1000 X48.6857 Y86.2176 Z-3.0000 S1000
    G1 F1000 X48.6354 Y86.1168 Z-3.0000 S1000
    G1 F1000 X48.5782 Y86.0197 Z-3.0000 S1000
    G1 F1000 X48.5142 Y85.9270 Z-3.0000 S1000
    G1 F1000 X48.4437 Y85.8390 Z-3.0000 S1000
    G1 F1000 X48.3673 Y85.7563 Z-3.0000 S1000
    G1 F1000 X48.2851 Y85.6792 Z-3.0000 S1000
    G1 F1000 X48.1977 Y85.6081 Z-3.0000 S1000
    G1 F1000 X48.1054 Y85.5434 Z-3.0000 S1000
    G1 F1000 X48.0088 Y85.4854 Z-3.0000 S1000
    G1 F1000 X47.9083 Y85.4344 Z-3.0000 S1000
    G1 F1000 X47.8045 Y85.3907 Z-3.0000 S1000
    G1 F1000 X47.6978 Y85.3544 Z-3.0000 S1000
    G1 F1000 X47.5888 Y85.3258 Z-3.0000 S1000
    G1 F1000 X47.4889 Y85.3067 Z-3.0000 S1000
    G1 F1000 X46.3132 Y85.1204 Z-3.0000 S1000
    G1 F1000 X40.5919 Y82.9239 Z-3.0000 S1000
    G1 F1000 X38.2587 Y81.4090 Z-3.0000 S1000
    G1 F1000 X38.1621 Y81.3511 Z-3.0000 S1000
    G1 F1000 X38.0616 Y81.3001 Z-3.0000 S1000
    G1 F1000 X37.9578 Y81.2564 Z-3.0000 S1000
    G1 F1000 X37.8511 Y81.2202 Z-3.0000 S1000
    G1 F1000 X37.7421 Y81.1916 Z-3.0000 S1000
    G1 F1000 X37.6313 Y81.1708 Z-3.0000 S1000
    G1 F1000 X37.5194 Y81.1579 Z-3.0000 S1000
    G1 F1000 X37.4068 Y81.1531 Z-3.0000 S1000
    G1 F1000 X37.2942 Y81.1562 Z-3.0000 S1000
    G1 F1000 X37.1821 Y81.1672 Z-3.0000 S1000
    G1 F1000 X37.0710 Y81.1862 Z-3.0000 S1000
    G1 F1000 X36.9616 Y81.2131 Z-3.0000 S1000
    G1 F1000 X36.8543 Y81.2476 Z-3.0000 S1000
    G1 F1000 X36.7498 Y81.2897 Z-3.0000 S1000
    G1 F1000 X36.6485 Y81.3390 Z-3.0000 S1000
    G1 F1000 X36.5510 Y81.3955 Z-3.0000 S1000
    G1 F1000 X36.4427 Y81.4697 Z-3.0000 S1000
    G1 F1000 X29.6740 Y86.5377 Z-3.0000 S1000
    G1 F1000 X24.1670 Y81.0307 Z-3.0000 S1000
    G1 F1000 X29.2350 Y74.2621 Z-3.0000 S1000
    G1 F1000 X29.2993 Y74.1695 Z-3.0000 S1000
    G1 F1000 X29.3568 Y74.0727 Z-3.0000 S1000
    G1 F1000 X29.4074 Y73.9720 Z-3.0000 S1000
    G1 F1000 X29.4506 Y73.8679 Z-3.0000 S1000
    G1 F1000 X29.4864 Y73.7611 Z-3.0000 S1000
    G1 F1000 X29.5146 Y73.6520 Z-3.0000 S1000
    G1 F1000 X29.5349 Y73.5412 Z-3.0000 S1000
    G1 F1000 X29.5473 Y73.4292 Z-3.0000 S1000
    G1 F1000 X29.5517 Y73.3166 Z-3.0000 S1000
    G1 F1000 X29.5481 Y73.2040 Z-3.0000 S1000
    G1 F1000 X29.5366 Y73.0919 Z-3.0000 S1000
    G1 F1000 X29.5171 Y72.9809 Z-3.0000 S1000
    G1 F1000 X29.4898 Y72.8716 Z-3.0000 S1000
    G1 F1000 X29.4548 Y72.7645 Z-3.0000 S1000
    G1 F1000 X29.4123 Y72.6601 Z-3.0000 S1000
    G1 F1000 X29.3625 Y72.5590 Z-3.0000 S1000
    G1 F1000 X29.2957 Y72.4461 Z-3.0000 S1000
    G1 F1000 X27.7808 Y70.1128 Z-3.0000 S1000
    G1 F1000 X25.5843 Y64.3915 Z-3.0000 S1000
    G1 F1000 X25.3980 Y63.2158 Z-3.0000 S1000
    G1 F1000 X25.3765 Y63.1052 Z-3.0000 S1000
    G1 F1000 X25.3471 Y62.9964 Z-3.0000 S1000
    G1 F1000 X25.3101 Y62.8900 Z-3.0000 S1000
    G1 F1000 X25.2656 Y62.7864 Z-3.0000 S1000
    G1 F1000 X25.2140 Y62.6863 Z-3.0000 S1000
    G1 F1000 X25.1553 Y62.5901 Z-3.0000 S1000
    G1 F1000 X25.0900 Y62.4983 Z-3.0000 S1000
    G1 F1000 X25.0183 Y62.4114 Z-3.0000 S1000
    G1 F1000 X24.9406 Y62.3298 Z-3.0000 S1000
    G1 F1000 X24.8573 Y62.2538 Z-3.0000 S1000
    G1 F1000 X24.7689 Y62.1840 Z-3.0000 S1000
    G1 F1000 X24.6757 Y62.1207 Z-3.0000 S1000
    G1 F1000 X24.5783 Y62.0641 Z-3.0000 S1000
    G1 F1000 X24.4771 Y62.0145 Z-3.0000 S1000
    G1 F1000 X24.3726 Y61.9723 Z-3.0000 S1000
    G1 F1000 X24.2654 Y61.9376 Z-3.0000 S1000
    G1 F1000 X24.1561 Y61.9105 Z-3.0000 S1000
    G1 F1000 X24.0559 Y61.8928 Z-3.0000 S1000
    G1 F1000 X15.7452 Y60.6987 Z-3.0000 S1000
    G1 F1000 X15.7452 Y52.9107 Z-3.0000 S1000
    G1 F1000 X24.0854 Y51.7127 Z-3.0000 S1000
    G1 F1000 X24.1963 Y51.6927 Z-3.0000 S1000
    G1 F1000 X24.3055 Y51.6649 Z-3.0000 S1000
    G1 F1000 X24.4125 Y51.6295 Z-3.0000 S1000
    G1 F1000 X24.5166 Y51.5865 Z-3.0000 S1000
    G1 F1000 X24.6175 Y51.5363 Z-3.0000 S1000
    G1 F1000 X24.7145 Y51.4790 Z-3.0000 S1000
    G1 F1000 X24.8073 Y51.4150 Z-3.0000 S1000
    G1 F1000 X24.8952 Y51.3446 Z-3.0000 S1000
    G1 F1000 X24.9780 Y51.2681 Z-3.0000 S1000
    G1 F1000 X25.0551 Y51.1859 Z-3.0000 S1000
    G1 F1000 X25.1262 Y51.0985 Z-3.0000 S1000
    G1 F1000 X25.1909 Y51.0063 Z-3.0000 S1000
    G1 F1000 X25.2489 Y50.9097 Z-3.0000 S1000
    G1 F1000 X25.2999 Y50.8092 Z-3.0000 S1000
    G1 F1000 X25.3436 Y50.7054 Z-3.0000 S1000
    G1 F1000 X25.3931 Y50.5522 Z-3.0000 S1000
    G1 F1000 X26.5325 Y46.2998 Z-3.0000 S1000
    G1 F1000 X29.2860 Y40.8955 Z-3.0000 S1000
    G1 F1000 X29.3335 Y40.7933 Z-3.0000 S1000
    G1 F1000 X29.3737 Y40.6881 Z-3.0000 S1000
    G1 F1000 X29.4064 Y40.5802 Z-3.0000 S1000
    G1 F1000 X29.4313 Y40.4703 Z-3.0000 S1000
    G1 F1000 X29.4483 Y40.3589 Z-3.0000 S1000
    G1 F1000 X29.4574 Y40.2466 Z-3.0000 S1000
    G1 F1000 X29.4585 Y40.1340 Z-3.0000 S1000
    G1 F1000 X29.4516 Y40.0215 Z-3.0000 S1000
    G1 F1000 X29.4367 Y39.9098 Z-3.0000 S1000
    G1 F1000 X29.4140 Y39.7994 Z-3.0000 S1000
    G1 F1000 X29.3835 Y39.6910 Z-3.0000 S1000
    G1 F1000 X29.3453 Y39.5849 Z-3.0000 S1000
    G1 F1000 X29.2998 Y39.4819 Z-3.0000 S1000
    G1 F1000 X29.2470 Y39.3823 Z-3.0000 S1000
    G1 F1000 X29.1874 Y39.2867 Z-3.0000 S1000
    G1 F1000 X29.1423 Y39.2233 Z-3.0000 S1000
    G1 F1000 X24.1670 Y32.5787 Z-3.0000 S1000
    G1 F1000 X29.6740 Y27.0718 Z-3.0000 S1000
    G1 F1000 X36.3186 Y32.0470 Z-3.0000 S1000
    G1 F1000 X36.4111 Y32.1113 Z-3.0000 S1000
    G1 F1000 X36.5080 Y32.1688 Z-3.0000 S1000
    G1 F1000 X36.6087 Y32.2194 Z-3.0000 S1000
    G1 F1000 X36.7127 Y32.2626 Z-3.0000 S1000
    G1 F1000 X36.8196 Y32.2984 Z-3.0000 S1000
    G1 F1000 X36.9287 Y32.3266 Z-3.0000 S1000
    G1 F1000 X37.0395 Y32.3469 Z-3.0000 S1000
    G1 F1000 X37.1515 Y32.3593 Z-3.0000 S1000
    G1 F1000 X37.2641 Y32.3637 Z-3.0000 S1000
    G1 F1000 X37.3767 Y32.3601 Z-3.0000 S1000
    G1 F1000 X37.4888 Y32.3486 Z-3.0000 S1000
    G1 F1000 X37.5998 Y32.3291 Z-3.0000 S1000
    G1 F1000 X37.7091 Y32.3018 Z-3.0000 S1000
    G1 F1000 X37.8162 Y32.2668 Z-3.0000 S1000
    G1 F1000 X37.9206 Y32.2243 Z-3.0000 S1000
    G1 F1000 X37.9908 Y32.1907 Z-3.0000 S1000
    G1 F1000 X40.9617 Y30.6769 Z-3.0000 S1000
    G1 F1000 X48.0024 Y45.7758 Z-3.0000 S1000
    G1 F1000 X47.2724 Y46.0826 Z-3.0000 S1000
    G1 F1000 X47.1702 Y46.1299 Z-3.0000 S1000
    G1 F1000 X47.0715 Y46.1843 Z-3.0000 S1000
    G1 F1000 X46.9770 Y46.2456 Z-3.0000 S1000
    G1 F1000 X46.8884 Y46.3123 Z-3.0000 S1000
    G1 F1000 X45.0947 Y47.7646 Z-3.0000 S1000
    G1 F1000 X45.0097 Y47.8386 Z-3.0000 S1000
    G1 F1000 X44.9302 Y47.9184 Z-3.0000 S1000
    G1 F1000 X44.8599 Y47.9994 Z-3.0000 S1000
    G1 F1000 X43.4076 Y49.7931 Z-3.0000 S1000
    G1 F1000 X43.3399 Y49.8832 Z-3.0000 S1000
    G1 F1000 X43.2787 Y49.9778 Z-3.0000 S1000
    G1 F1000 X43.2269 Y50.0714 Z-3.0000 S1000
    G1 F1000 X42.1794 Y52.1274 Z-3.0000 S1000
    G1 F1000 X42.1318 Y52.2296 Z-3.0000 S1000
    G1 F1000 X42.0917 Y52.3349 Z-3.0000 S1000
    G1 F1000 X42.0605 Y52.4373 Z-3.0000 S1000
    G1 F1000 X41.4631 Y54.6673 Z-3.0000 S1000
    G1 F1000 X41.4378 Y54.7771 Z-3.0000 S1000
    G1 F1000 X41.4204 Y54.8884 Z-3.0000 S1000
    G1 F1000 X41.4112 Y54.9949 Z-3.0000 S1000
    G1 F1000 X41.2902 Y57.2995 Z-3.0000 S1000
    G1 F1000 X41.2883 Y57.4121 Z-3.0000 S1000
    G1 F1000 X41.2944 Y57.5246 Z-3.0000 S1000
    G1 F1000 X41.3076 Y57.6311 Z-3.0000 S1000
    G1 F1000 X41.6688 Y59.9106 Z-3.0000 S1000
    G1 F1000 X41.6903 Y60.0212 Z-3.0000 S1000
    G1 F1000 X41.7197 Y60.1300 Z-3.0000 S1000
    G1 F1000 X41.7547 Y60.2312 Z-3.0000 S1000
    G1 F1000 X42.5818 Y62.3856 Z-3.0000 S1000
    G1 F1000 X42.6259 Y62.4893 Z-3.0000 S1000
    G1 F1000 X42.6772 Y62.5896 Z-3.0000 S1000
    G1 F1000 X42.7325 Y62.6813 Z-3.0000 S1000
    G1 F1000 X43.9897 Y64.6168 Z-3.0000 S1000
    G1 F1000 X44.0544 Y64.7091 Z-3.0000 S1000
    G1 F1000 X44.1255 Y64.7965 Z-3.0000 S1000
    G1 F1000 X44.1985 Y64.8746 Z-3.0000 S1000
    G1 F1000 X45.8301 Y66.5062 Z-3.0000 S1000
    G1 F1000 X45.9125 Y66.5830 Z-3.0000 S1000
    G1 F1000 X46.0002 Y66.6538 Z-3.0000 S1000
    G1 F1000 X46.0879 Y66.7150 Z-3.0000 S1000
    G1 F1000 X48.0234 Y67.9722 Z-3.0000 S1000
    G1 F1000 X48.1200 Y68.0302 Z-3.0000 S1000
    G1 F1000 X48.2204 Y68.0812 Z-3.0000 S1000
    G1 F1000 X48.3191 Y68.1229 Z-3.0000 S1000
    G1 F1000 X50.4735 Y68.9500 Z-3.0000 S1000
    G1 F1000 X50.5801 Y68.9867 Z-3.0000 S1000
    G1 F1000 X50.6890 Y69.0156 Z-3.0000 S1000
    G1 F1000 X50.7941 Y69.0359 Z-3.0000 S1000
    G1 F1000 X53.0736 Y69.3971 Z-3.0000 S1000
    G1 F1000 X53.1854 Y69.4108 Z-3.0000 S1000
    G1 F1000 X53.2979 Y69.4165 Z-3.0000 S1000
    G1 F1000 X53.4052 Y69.4145 Z-3.0000 S1000
    G1 F1000 X55.7098 Y69.2935 Z-3.0000 S1000
    G1 F1000 X55.8221 Y69.2836 Z-3.0000 S1000
    G1 F1000 X55.9333 Y69.2658 Z-3.0000 S1000
    G1 F1000 X56.0374 Y69.2416 Z-3.0000 S1000
    G1 F1000 X58.2674 Y68.6442 Z-3.0000 S1000
    G1 F1000 X58.3751 Y68.6112 Z-3.0000 S1000
    G1 F1000 X58.4803 Y68.5707 Z-3.0000 S1000
    G1 F1000 X58.5773 Y68.5253 Z-3.0000 S1000
    G1 F1000 X60.6333 Y67.4778 Z-3.0000 S1000
    G1 F1000 X60.7318 Y67.4231 Z-3.0000 S1000
    G1 F1000 X60.8262 Y67.3616 Z-3.0000 S1000
    G1 F1000 X60.9116 Y67.2971 Z-3.0000 S1000
    G1 F1000 X62.7053 Y65.8448 Z-3.0000 S1000
    G1 F1000 X62.7903 Y65.7708 Z-3.0000 S1000
    G1 F1000 X62.8698 Y65.6910 Z-3.0000 S1000
    G1 F1000 X62.9401 Y65.6100 Z-3.0000 S1000
    G1 F1000 X64.3924 Y63.8163 Z-3.0000 S1000
    G1 F1000 X64.4601 Y63.7262 Z-3.0000 S1000
    G1 F1000 X64.5213 Y63.6316 Z-3.0000 S1000
    G1 F1000 X64.5731 Y63.5380 Z-3.0000 S1000
    G1 F1000 X65.6206 Y61.4820 Z-3.0000 S1000
    G1 F1000 X65.6682 Y61.3798 Z-3.0000 S1000
    G1 F1000 X65.7083 Y61.2745 Z-3.0000 S1000
    G1 F1000 X65.7395 Y61.1721 Z-3.0000 S1000
    G1 F1000 X66.3369 Y58.9421 Z-3.0000 S1000
    G1 F1000 X66.3622 Y58.8323 Z-3.0000 S1000
    G1 F1000 X66.3796 Y58.7210 Z-3.0000 S1000
    G1 F1000 X66.3888 Y58.6145 Z-3.0000 S1000
    G1 F1000 X66.5098 Y56.3099 Z-3.0000 S1000
    G1 F1000 X66.5117 Y56.1973 Z-3.0000 S1000
    G1 F1000 X66.5056 Y56.0848 Z-3.0000 S1000
    G1 F1000 X66.4924 Y55.9783 Z-3.0000 S1000
    G1 F1000 X66.1312 Y53.6988 Z-3.0000 S1000
    G1 F1000 X66.1097 Y53.5882 Z-3.0000 S1000
    G1 F1000 X66.0803 Y53.4794 Z-3.0000 S1000
    G1 F1000 X66.0453 Y53.3782 Z-3.0000 S1000
    G1 F1000 X65.2182 Y51.2238 Z-3.0000 S1000
    G1 F1000 X65.1741 Y51.1201 Z-3.0000 S1000
    G1 F1000 X65.1228 Y51.0198 Z-3.0000 S1000
    G1 F1000 X65.0675 Y50.9281 Z-3.0000 S1000
    G1 F1000 X63.8103 Y48.9926 Z-3.0000 S1000
    G1 F1000 X63.7456 Y48.9003 Z-3.0000 S1000
    G1 F1000 X63.6745 Y48.8129 Z-3.0000 S1000
    G1 F1000 X63.6015 Y48.7348 Z-3.0000 S1000
    G1 F1000 X61.9699 Y47.1032 Z-3.0000 S1000
    G1 F1000 X61.8875 Y47.0264 Z-3.0000 S1000
    G1 F1000 X61.7998 Y46.9556 Z-3.0000 S1000
    G1 F1000 X61.7121 Y46.8944 Z-3.0000 S1000
    G1 F1000 X60.6075 Y46.1769 Z-3.0000 S1000
    ; retracting back to z-safe
    G0 Z7
    M5 S0; Spindle Off
  2. Christian James
    Christian James Journeyman
  3. sharmstr
    Its hard to tell in the video, but it looks like you didnt zero out your x,y,z when you moved your bit to the corner of the stock. Homing your machine is not the same as setting your work coordinate (WCS).
    Try it again, but this time when you set your bit over the corner, click "set XYZ", then run it.
    davabran and Peter Van Der Walt like this.
  4. Giarc
    I am going to go with Sharmstr's theory. Although difficult to read your numbers, it did not look like you zeroed everything out once you got the endmill down to the z - zero position.
    Peter Van Der Walt and davabran like this.
  5. davabran
    davabran New
    Ok that was the problem. I got too excited and wasn't setting zero. I thought it could just run it from where I moved the router, but shows how much I know. Thanks guys!​
