Latres version of control update crashed then would not reopen
Discussion in 'OpenBuilds Bug Report' started by donald k wilson, Dec 12, 2021.
  1. donald k wilson
    Hey All,
    I had an automatic update of control on Thursday which immediately crashed and gave me a com port communication error message. It subsequently would not load after shutting off. I've just uninstalled control, done a system check, Windows 10, all clear, fresh download of control, same problem... the program icon shows up on my home screen and acts like it is starting up then stalls. It does not show up on my toolbar as active or on task manager as running. I'm stumped (not difficult ;-) thoughts?
    thanks, dkw
    Uninstall, clean up any remnant files from where it was installed. Reboot. Then install from fresh
  3. donald k wilson
    I have uninstalled the current program, gone thru all the "recommended" steps to remove file remnants from program files, temp files, checked registry and got everything but a couple of residuals that trigger "cant remove files they are currently in use, close the program and try again" . Open Builds Control is nowhere to be found at this point, thoughts...
    Thanks, dkw
  4. donald k wilson
    screenshot of the files and error message
    Reboot to close any running instances that Windows abandoned , then clean up the install locations.
  6. donald k wilson
    shutdown and restarted, Open Builds Control reappears in the program files but wont uninstall. this keeps going around in a circle...
    Sounds like that PC needs a reformat :)
    It's not a CONTROL problem, its a Windows problem
  8. donald k wilson
    I was afraid that was what I was looking at.
    Thanks for all the help! dkw
  9. Peter Van Der Walt
    You could try Safe Mode too
  10. donald k wilson
    FWIW... In my meanderings I discovered I was a version behind in my windows 10 updates. I crossed my fingers and downloaded, got a clean uninstall of Control, reboot and reload, everything is working as it should.
    Thanks again!
