Laser delay problem
Discussion in 'Laser Cutters' started by pedrofernandez, Jan 27, 2018.
  1. pedrofernandez
    pedrofernandez Journeyman
    7727D927-8A3D-495C-81CF-8A1FB2071B49.jpeg any ideas why the motion starts before the laser?
  2. Scotty Orr
    Scotty Orr Journeyman
    Can you provide a bit more information? What program is producing the G-code? What is your hardware set-up?
    Looks like it is happening just after (or before) a rapids movement - G0. G0 immediately turns off the laser in laser mode. Are you sure it is moving BEFORE it turns on, or could it be turning off prematurely at the end of a normal move?
    Take a look at your G-code and maybe post a few lines that contain both G0 and G1(2 or 3).
  3. pedrofernandez
    motion start before the laser but it was my rookie way of connecting things without reading i think, just ordered the transistor required for the pwm may be that is my problem, my rig is a cnc sphinx with a xpro controller
  4. pedrofernandez
    thanks for the reply sr. on monday ill see if this works,
  5. pedrofernandez
    still having the same isue with the nmosfet motion start before the laser turns on, gcode generated by sketchucam and laserweb
    (Generated by SketchUcam V1.4c-4ef2001)
    (Bit diameter: ~ 3.18mm)
    (Feed rate: 500.00mm/min)
    (Material Thickness: 0.20mm)
    (Material length: 300.00mm X width: 300.00mm)
    (Overhead Gantry: true)
    (Multipass enabled, Depth = 0.50mm)
    (Plunge Depth first)
    (Optimization is ON)
    (LASER for GRBL PWR)
    (www.PhlatBoyz.com)
    G90 G21 G49 G17 F500
    M05
    (Pass: 1)
    G00 X7.148 Y7.751
    M04 S127
    G01 Y8.055 F500
    G01 X7.568
    G01 X8.174 Y8.171
    G01 X8.579 Y8.516
    G01 X8.708 Y8.951
    G01 X8.751 Y9.732
    G01 Y16.924
    G01 X8.694 Y17.773
    G01 X8.521 Y18.231
    G01 X8.122 Y18.502
    G01 X7.568 Y18.592
    G01 X7.148
    G01 Y18.897
    G01 X12.195
    G01 Y18.592
    G01 X11.440 Y18.555
    G01 X10.950 Y18.428
    G01 X10.461 Y17.992
    G01 X10.329 Y16.735
    G01 Y9.732
    G01 X10.461 Y8.795
    G01 X10.765 Y8.540
    G01 X12.047 Y8.458
    G01 X12.861
    G01 X13.952 Y8.505
    G01 X14.661 Y8.647
    G01 X15.156 Y8.909
    G01 X15.606 Y9.317
    G01 X16.033 Y9.937
    G01 X16.461 Y10.834
    G01 X16.732 Y10.776
    G01 X15.779 Y7.751
    G01 X7.148
    M05
    (Pass: 1)
    G00 X22.674 Y16.595
    M04 S127
    G01 X20.735 Y12.091 F500
    M05
  6. David the swarfer
    what are you settings for $30 and $31 ?
    There may be a minimum PWM below which the laser does not power on.
    So, of $31=0 and $30=255
    then maybe the laser only actually comes on at 25
    thus in G4 mode the head is in motion while the PWM ramps up from 0 to your S setting but between 0 and 25 is is off anyway.
    In this case you need to set $31=25 so it always turns on from the minimum usable power.
    Remember M4 mode is ramping up the laser power during the acceleration phase of the motion so it will not be instantly on at the power set by the S word. You would need M3 mode for that.
    you can easily test this with Gcode like this
    G21 G90
    G0 X0
    M4 S0 F500
    G1 X10 S5
    G1 X20 S10
    G1 X30 S15
    G1 X40 S20
    G1 X50 S25
    G1 X60 S30
    G1 X70 S35
    G1 X80 S40
    G1 X90 S45
    G1 X100 S50
    g0 X0
    M5
    M30
    that will draw a 100mm long line of increasing laser power and you should be able to see where is comes on and relate that to the S setting.
    PS: turn off multipass mode unless you need it.
    #6 David the swarfer, Feb 6, 2018
  7. pedrofernandez
    thanks for the reply, ill test this tomorrow or maybe this evening and let you know how went,
  8. pedrofernandez
    I solved this the hard way, if you notice the very first instruction of the code is to turn the laser off then move, so the module it self takes like half off a second to lit, so i took the code in word and replaced all M05 to M03 s10 that way the module is traveling on all the time at low power and leave the last m05 at the end.
