KEYS CNC SHIELD
Discussion in 'Laser Projects' started by robert christensen, Apr 12, 2020.
  1. robert christensen
    im starting a laser build for my son and we are starting out with a keys cnc shield 3 axis with Arduino nano and grbl,
    1 what pins on the shield do we hook up the laser
    2 do we have to do anything else
    3 change setting in grbl to set off laser is mthe only thing I think we need to change
    thanks in advance Robert
  3. Rob Taylor
    Docs don't seem hard to find? Ks0152 keyestudio CNC Shield V4 - Keyestudio Wiki / Ks0096 keyestudio CNC Kit / CNC Shield V4.0 + Nano 3.0+3pcs a4988 Driver / GRBL Compatible - Keyestudio Wiki
    They seem sufficient to get started, but it doesn't look like the sort of thing you'll get much support with. Those boards typically don't include reverse polarity, hot-plugging, or short circuit protection either, so stock up on spares of both the drivers and the Nano, because there's a very high chance you'll fry a couple of each.
    Those drivers are ok for a laser build, but I would strongly recommend, performance-wise, moving to 24V (assuming NEMA 17 motors) through proper stepper drivers like these: https://smile.amazon.com/STEPPERONLINE-1-0-4-2A-20-50VDC-Micro-step-Resolutions/dp/B06Y5VPSFN - this is the route I took, I originally tried using an Uno and V3 shield, but it's a recipe for frustration. There's really no need any more, it's not 2015! You can get rapids up to 15,000mm/min with this setup quite comfortably.
    ...Or, as Peter says, buy a BlackBox which has the downside of everything being integrated together, but the significant upside of 80% of the wiring work already being done for you.
