K40 LPS to Blackbox wiring question
Discussion in 'Laser Cutters' started by Shawn Talley, Sep 25, 2019.
  1. Shawn Talley
    I need some advise on how best to wire my K40's power supply to a Blackbox. Basically I would like to know how I should wire it so that I can still use the potentiometer to set my lasers max power and use the controlling software and the PWM of the Blackbox to adjust the power from there. I have a rough wire diagram I drew showing the LPS wiring from when it was in the K40 which shows what pins the LPS has. I found a wire diagram showing a Xpro to a LPS that is identical to mine but I'm not sure if this wiring would let me use the potentiometer as it was in the K40 (attached to the GND, 0-5v IN, 5v Pins) or if it would be good to wire the LPS to the Blackbox in this manner. Any advise would be most welcome.
  2. terry marwood
    power the black box separate from the psu in the k40 this is what i am going to do
