Just set up a Workbee (from SPAM) + BlackBox but motors aren't working, is it wrong wiring?
Discussion in 'Motors' started by antang808, Aug 5, 2021.
  1. antang808
    antang808 New
    So I just finished the wiring for my first Workbee and I admit that I cheaped out on the mechanical kit from SPAM but I made sure to get a BlackBox. Based on the documentation from SPAM, the wiring should be (red-green-blue-yellow) for the NEMA 23s from SPAM. However, when I turn on the Blackbox, I get this clicking as if the motors aren't properly set up or something in the BlackBox. I can connect to my laptop fine, but I'm not sure if maybe I have too much tension on my wheels or if its the motors. I've attached a video if it with the picture of the connections. If anyone has any ideas on whats going on, I'd greatly appreciate it.
    Thanks,
    Anthony
  3. Alex Chambers
    As @Peter Van Der Walt said above - I'm afraid you can't rely on SPAM's documentation or the colour coding for their motors - I even came across one person who had one motor with a different colour code.
    You can't even rely on the motors working when you do get the wiring right (; - the forum sees it all the time - high inductance, terrible performance (but cheap)
  5. antang808
    antang808 New
    I actually think it might be my power supply. The color scheme is correct and I've confirmed it through the methods of twisting wires togther. The fan of the meanwell power supply is twitching similarly to that clicking so there be some surging or something
    The fan in most (real ones at least, your vendor isn't known for using genuine parts so it may be fake) Meanwell's are temperature controlled, the fan only comes on >65degC
    Check with a multimeter.
    Do note 3rd party PSUs can affect your BlackBox and it's warranty if something goes wrong that can be attributed to a surge from the PSU
  7. antang808
    antang808 New
    I got it to work thanks luckily i have another power supply lying around. I got the meanwell PSU from amazon + the powerkit and the issue was the powersupply was constantly turning off and on
    Alex Chambers likes this.
