Jogging issues
Discussion in 'OpenBuilds Forum Help' started by Paul. cnc.101, May 30, 2024.
  1. Paul. cnc.101
    Hello. I have a lead 1010 and I have an intermittent problem with jogging. If I try to jog the gantry in the “+ Y” Direction, once I let go the mouse, the gantry continues to move. In order to stop the gantry, I need to press “- Y” and then it will stop. The gantry WILL CRASH if I don’t react fast enough. If anyone has any suggestions on how I can fix this, I would appreciate any help.
    • Software up to date? (CONTROL v1.0.376?)
    • Using Continuous mode (make sure you aren't in incremental)
  3. Paul. cnc.101
    I might need to update software.
    I was using Continuous and trying to surface a board manually. I clicked on Y to jog the gantry and once I released the mouse, the gantry did not stop.
  5. Paul. cnc.101
    Not sure. I am at work now and I am not able to check. Can I ask what is the latest vet using a black box?
  7. Paul. cnc.101
    Thank you.
    where do I see what version I have?
    if I download the latest version, will it automatically update my older version?
  8. David the swarfer
    replace the mouse NOW
    I have had this exact thing with 2 different brands of wireless mouse (Microsoft and Genius), a cheap wired USB mouse solved it 100%
  9. Christian James
    Christian James Journeyman
    Agree with keeping a Microsoft mouse out of the workshop!
