Job keeps stopping and sends alert
Discussion in 'CNC Mills/Routers' started by mcallisterracing, Nov 9, 2022.
Tags:
  1. mcallisterracing
    My workbee 1010 keeps stopping and flashing the alert but no message pops up. Attached is the picture of the code when this happens.
    I have tried new usb cables and different computer, updating, restarting, tracing all wires and checking connections.
    That indicates the controller reset itself.
    Running any 3rd party parts like a VFD spindle? Or anything else that's nonstandard?
  3. mcallisterracing
    No aftermarket parts, only kit workbee parts and a dewalt 610 router.
    The machine is 3 years old.
    Check that USB selective suspend is off (sometimes a windows update can re-enable it): docs:blackbox:install-windows-selective-suspend [OpenBuilds Documentation]
    Also check if the same happens with the Router turned off (zero high, run a job "in the air" with the router off). If the Dewalt is approaching 3 years too its brushes may be worn leading to sparking causing EMI. Quick test run without the router will show you if its related
    JustinTime and David the swarfer like this.
