Hi, I just upgraded to 1.0.298 this morning and I like the new Job Log, but the Job Completed popup is no longer coming up at the end of a job. While I may be able to check the job queue to make sure that the job is complete, it was nice to be able to see from by a glance that the job is done. Thanks Steve
You were in the minority of liking that, most people hated the popup. So it had to go: OpenBuilds CONTROL Software
Peter, I think most people hated the popup not the info. As I have suggested before, a label with the info that is constant but not popping up in the middle of the screen and has to be canceled is what, probably, most want.
Hey Peter, Is the first timestamp in the lower part of the window the job completion time? If so, it doesnt match the completion time in the job log or in the serial console. [08:25:15] [ JOB COMPLETE ] Job completed in 00h02m Also, maybe change the format on the Name column of the log to be a fixed size. It gets pretty big when a file is sent from OB Cam. Scrunches up the date and makes you scroll right to see the time info.
When the job is done i just set runtime = estimated run time: but you are correct, i should set both to actual run time instead. Due to sim estimate/real world differences I want to set both the same to avoid it looking like its not done yet. good catch, will sort out the table width and turn on wrapping on the name
