Issue with arcs on new blackbox conversion
Discussion in 'Tutorials' started by cpalms, Jul 8, 2020.
  1. cpalms
    cpalms New
    Hi,
    I recently setup a Black box to replace my carbide motion board. The installation was straightforward and I'm very satisfied with the new z motor and rapid speeds. The one issue that Im having and can't seem to resolve by manipulating the $11 or $12 values or with using different pp is absurdly slow speeds on arcs. Both test were done with files that have proved successful with the motion board, please help!
    1) We recommend keeping $11 and $12 default
    2) Post the files for analyses
    3) Post your grbl settings dump ($$, copy, paste)
  3. cpalms
    cpalms New
    Code:
    [00:33:03] [ $$ ] $0=10 ;Step pulse time, microseconds
    [00:33:03] [ $$ ] $1=255 ;Step idle delay, milliseconds
    [00:33:03] [ $$ ] $2=4 ;Step pulse invert, mask
    [00:33:03] [ $$ ] $3=0 ;Step direction invert, mask
    [00:33:03] [ $$ ] $4=1 ;Invert step enable pin, boolean
    [00:33:03] [ $$ ] $5=0 ;Invert limit pins, boolean
    [00:33:03] [ $$ ] $6=0 ;Invert probe pin, boolean
    [00:33:03] [ $$ ] $10=0 ;Status report options, mask
    [00:33:03] [ $$ ] $11=0.020 ;Junction deviation, millimeters
    [00:33:03] [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [00:33:03] [ $$ ] $13=0 ;Report in inches, boolean
    [00:33:03] [ $$ ] $20=1 ;Soft limits enable, boolean
    [00:33:03] [ $$ ] $21=1 ;Hard limits enable, boolean
    [00:33:03] [ $$ ] $22=1 ;Homing cycle enable, boolean
    [00:33:03] [ $$ ] $23=0 ;Homing direction invert, mask
    [00:33:03] [ $$ ] $24=100.000 ;Homing locate feed rate, mm/min
    [00:33:03] [ $$ ] $25=3500.000 ;Homing search seek rate, mm/min
    [00:33:03] [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [00:33:03] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
    [00:33:03] [ $$ ] $30=1000 ;Maximum spindle speed, RPM
    [00:33:03] [ $$ ] $31=0 ;Minimum spindle speed, RPM
    [00:33:03] [ $$ ] $32=0 ;Laser-mode enable, boolean
    [00:33:03] [ $$ ] $100=40.000 ;X-axis steps per millimeter
    [00:33:03] [ $$ ] $101=40.000 ;Y-axis steps per millimeter
    [00:33:03] [ $$ ] $102=320.000 ;Z-axis steps per millimeter
    [00:33:03] [ $$ ] $110=6000.000 ;X-axis maximum rate, mm/min
    [00:33:03] [ $$ ] $111=6000.000 ;Y-axis maximum rate, mm/min
    [00:33:03] [ $$ ] $112=2500.000 ;Z-axis maximum rate, mm/min
    [00:33:03] [ $$ ] $120=400.000 ;X-axis acceleration, mm/sec^2
    [00:33:03] [ $$ ] $121=400.000 ;Y-axis acceleration, mm/sec^2
    [00:33:03] [ $$ ] $122=100.000 ;Z-axis acceleration, mm/sec^2
    [00:33:03] [ $$ ] $130=845.000 ;X-axis maximum travel, millimeters
    [00:33:03] [ $$ ] $131=850.000 ;Y-axis maximum travel, millimeters
    [00:33:03] [ $$ ] $132=140.000 ;Z-axis maximum travel, millimeters
    #3 cpalms, Jul 8, 2020
  4. cpalms
    cpalms New
    Code:
    T1
    G17
    G21
    G90
    G0Z20.3200
    G0X0.0000Y0.0000S12000M3
    G0X486.7747Y136.1393Z5.0800
    G1Z-4.7650F762.0
    G1X486.3649Y136.1356F2667.0
    G1X485.9547Y136.1242
    G1X485.5444Y136.1053
    G1X485.1342Y136.0787
    G1X484.7242Y136.0445
    G1X484.3147Y136.0028
    G1X483.9059Y135.9534
    G1X483.4981Y135.8965
    G1X483.0914Y135.8320
    G1X482.6860Y135.7600
    G1X482.2821Y135.6805
    G1X481.8800Y135.5937
    G1X481.4799Y135.4994
    G1X481.0819Y135.3979
    G1X480.6862Y135.2891
    G1X480.2931Y135.1732
    G1Z0.0000
    G1X478.0666Y134.3623
    G1X475.9271Y133.3123
    G1X473.9124Y132.0392
    G1X472.0558Y130.5668
    G1Z-4.7650F762.0
    G1X471.7535Y130.2947F2667.0
    G1X471.4552Y130.0160
    G1X471.1610Y129.7309
    G1X470.8711Y129.4394
    G1X470.5858Y129.1416
    G1X470.3051Y128.8376
    G1X470.0294Y128.5275
    G1X469.7587Y128.2114
    G1X469.4933Y127.8895
    G1X469.2334Y127.5619
    G1X468.9792Y127.2286
    G1X468.7307Y126.8900
    G1X468.4883Y126.5460
    G1X468.2520Y126.1969
    G1X468.0221Y125.8428
    G1X467.7985Y125.4840
    G1X467.5816Y125.1205
    G1X467.3715Y124.7526
    G1X467.1683Y124.3804
    G1X466.9720Y124.0042
    G1X466.7829Y123.6242
    G1X466.6011Y123.2405
    G1X466.4266Y122.8533
    G1X466.2595Y122.4630
    G1X466.1000Y122.0696
    G1X465.9481Y121.6734
    G1X465.8038Y121.2746
    G1X465.6673Y120.8735
    G1X465.5386Y120.4703
    G1X465.4178Y120.0652
    G1X465.3048Y119.6584
    G1X465.1997Y119.2502
    G1X465.1026Y118.8407
    G1X465.0133Y118.4303
    G1X464.9320Y118.0191
    G1X464.8586Y117.6074
    G1X464.7932Y117.1954
    G1X464.7356Y116.7832
    G1X464.6859Y116.3713
    G1X464.6440Y115.9597
    G1X464.6099Y115.5486
    G1X464.5834Y115.1384
    G1X464.5646Y114.7291
    G1X464.5534Y114.3210
    G1X464.5497Y113.9143
    G1X464.5529Y113.5343
    G1X464.5628Y113.1518
    G1X464.5793Y112.7669
    G1X464.6028Y112.3797
    G1X464.6331Y111.9905
    G1X464.6706Y111.5994
    G1X464.7152Y111.2065
    G1X464.7673Y110.8121
    G1X464.8267Y110.4163
    G1X464.8936Y110.0193
    G1X464.9682Y109.6214
    G1X465.0505Y109.2226
    G1X465.1407Y108.8233
    G1X465.2386Y108.4237
    G1X465.3445Y108.0238
    G1X465.4584Y107.6241
    G1X465.5804Y107.2246
    G1X465.7104Y106.8257
    G1X465.8486Y106.4276
    G1X465.9950Y106.0305
    G1X466.1495Y105.6346
    G1X466.3123Y105.2402
    G1X466.4832Y104.8475
    G1X466.6623Y104.4569
    G1X466.8496Y104.0684
    G1X467.0450Y103.6825
    G1X467.2485Y103.2992
    G1X467.4601Y102.9190
    G1X467.6797Y102.5419
    G1X467.9071Y102.1684
    G1X468.1425Y101.7986
    G1X468.3856Y101.4327
    G1X468.6363Y101.0710
    G1X468.8946Y100.7138
    G1X469.1604Y100.3612
    G1X469.4334Y100.0136
    G1X469.7136Y99.6710
    G1X470.0009Y99.3339
    G1X470.2950Y99.0022
    G1X470.5958Y98.6764
    G1X470.9032Y98.3565
    G1X471.2169Y98.0428
    G1X471.5367Y97.7355
    G1X471.8626Y97.4347
    G1X472.1942Y97.1405
    G1X472.5314Y96.8533
    G1X472.8739Y96.5731
    G1X473.2216Y96.3000
    G1X473.5741Y96.0343
    G1X473.9313Y95.7760
    G1X474.2930Y95.5252
    G1X474.6589Y95.2822
    G1X475.0287Y95.0468
    G1X475.4023Y94.8193
    G1X475.7793Y94.5998
    G1X476.1596Y94.3882
    G1X476.5428Y94.1847
    G1X476.9288Y93.9893
    G1X477.3172Y93.8020
    G1X477.7079Y93.6229
    G1X478.1006Y93.4519
    G1X478.4949Y93.2892
    G1X478.8908Y93.1347
    G1X479.2879Y92.9883
    G1X479.6861Y92.8501
    G1X480.0850Y92.7200
    G1X480.4844Y92.5981
    G1X480.8842Y92.4842
    G1X481.2840Y92.3783
    G1X481.6837Y92.2803
    G1X482.0830Y92.1902
    G1X482.4817Y92.1079
    G1X482.8797Y92.0333
    G1X483.2766Y91.9663
    G1X483.6725Y91.9069
    G1X484.0669Y91.8549
    G1X484.4597Y91.8102
    G1X484.8509Y91.7728
    G1X485.2401Y91.7424
    G1X485.6272Y91.7190
    G1X486.0121Y91.7024
    G1X486.3947Y91.6926
    G1X486.7747Y91.6893
    G1X487.1547Y91.6926
    G1X487.5372Y91.7024
    G1X487.9221Y91.7190
    G1X488.3093Y91.7424
    G1X488.6985Y91.7728
    G1X489.0896Y91.8102
    G1X489.4825Y91.8549
    G1X489.8769Y91.9069
    G1X490.2727Y91.9663
    G1X490.6696Y92.0333
    G1X491.0677Y92.1079
    G1X491.4664Y92.1902
    G1X491.8657Y92.2803
    G1X492.2654Y92.3783
    G1X492.6652Y92.4842
    G1X493.0649Y92.5981
    G1X493.4644Y92.7200
    G1X493.8633Y92.8501
    G1X494.2614Y92.9883
    G1X494.6586Y93.1347
    G1X495.0544Y93.2892
    G1X495.4488Y93.4519
    G1X495.8415Y93.6229
    G1X496.2321Y93.8020
    G1X496.6206Y93.9893
    G1X497.0065Y94.1847
    G1X497.3898Y94.3882
    G1X497.7701Y94.5998
    G1X498.1471Y94.8193
    G1X498.5206Y95.0468
    G1X498.8905Y95.2822
    G1X499.2563Y95.5252
    G1X499.6180Y95.7760
    G1X499.9753Y96.0343
    G1X500.3278Y96.3000
    G1X500.6754Y96.5731
    G1X501.0179Y96.8533
    G1X501.3551Y97.1405
    G1X501.6868Y97.4347
    G1X502.0126Y97.7355
    G1X502.3325Y98.0428
    G1X502.6462Y98.3565
    G1X502.9536Y98.6764
    G1X503.2544Y99.0022
    G1X503.5485Y99.3339
    G1X503.8357Y99.6710
    G1X504.1159Y100.0136
    G1X504.3890Y100.3612
    G1X504.6547Y100.7138
    G1X504.9130Y101.0710
    G1X505.1638Y101.4327
    G1X505.4069Y101.7986
    G1X505.6422Y102.1684
    G1X505.8697Y102.5419
    G1X506.0893Y102.9190
    G1X506.3008Y103.2992
    G1X506.5043Y103.6825
    G1X506.6997Y104.0684
    G1X506.8870Y104.4569
    G1X507.0661Y104.8475
    G1X507.2371Y105.2402
    G1X507.3998Y105.6346
    G1X507.5544Y106.0305
    G1X507.7007Y106.4276
    G1X507.8389Y106.8257
    G1X507.9690Y107.2246
    G1X508.0909Y107.6241
    G1X508.2049Y108.0238
    G1X508.3108Y108.4237
    G1X508.4087Y108.8233
    G1X508.4988Y109.2226
    G1X508.5811Y109.6214
    G1X508.6557Y110.0193
    G1X508.7227Y110.4163
    G1X508.7821Y110.8121
    G1X508.8341Y111.2065
    G1X508.8788Y111.5994
    G1X508.9163Y111.9905
    G1X508.9466Y112.3797
    G1X508.9700Y112.7669
    G1X508.9866Y113.1518
    G1X508.9964Y113.5343
    G1X508.9997Y113.9143
    G1X508.9964Y114.2943
    G1X508.9866Y114.6769
    G1X508.9700Y115.0618
    G1X508.9466Y115.4489
    G1X508.9163Y115.8382
    G1X508.8788Y116.2293
    G1X508.8341Y116.6221
    G1X508.7821Y117.0166
    G1X508.7227Y117.4124
    G1X508.6557Y117.8093
    G1X508.5811Y118.2073
    G1X508.4988Y118.6060
    G1X508.4087Y119.0053
    G1X508.3108Y119.4050
    G1X508.2049Y119.8048
    G1X508.0909Y120.2046
    G1X507.9690Y120.6040
    G1X507.8389Y121.0029
    G1X507.7007Y121.4011
    G1X507.5544Y121.7982
    G1X507.3998Y122.1941
    G1X507.2371Y122.5885
    G1X507.0661Y122.9811
    G1X506.8870Y123.3718
    G1X506.6997Y123.7602
    G1X506.5043Y124.1462
    G1X506.3008Y124.5294
    G1X506.0893Y124.9097
    G1X505.8697Y125.2867
    G1X505.6422Y125.6603
    G1X505.4069Y126.0301
    G1X505.1638Y126.3960
    G1X504.9130Y126.7577
    G1X504.6547Y127.1149
    G1X504.3890Y127.4675
    G1X504.1159Y127.8151
    G1X503.8357Y128.1576
    G1X503.5485Y128.4948
    G1X503.2544Y128.8264
    G1X502.9536Y129.1523
    G1X502.6462Y129.4722
    G1X502.3325Y129.7858
    G1X502.0126Y130.0932
    G1X501.6868Y130.3940
    G1X501.3551Y130.6881
    G1X501.0179Y130.9754
    G1X500.6754Y131.2556
    G1X500.3278Y131.5286
    G1X499.9753Y131.7944
    G1X499.6180Y132.0527
    G1X499.2563Y132.3034
    G1X498.8905Y132.5465
    G1X498.5206Y132.7819
    G1X498.1471Y133.0093
    G1X497.7701Y133.2289
    G1X497.3898Y133.4405
    G1X497.0065Y133.6440
    G1X496.6206Y133.8394
    G1X496.2321Y134.0267
    G1X495.8415Y134.2058
    G1X495.4488Y134.3767
    G1X495.0544Y134.5395
    G1X494.6586Y134.6940
    G1X494.2614Y134.8404
    G1X493.8633Y134.9786
    G1X493.4644Y135.1086
    G1X493.0649Y135.2306
    G1X492.6652Y135.3445
    G1X492.2654Y135.4504
    G1X491.8657Y135.5484
    G1X491.4664Y135.6385
    G1X491.0677Y135.7208
    G1X490.6696Y135.7954
    G1X490.2727Y135.8623
    G1X489.8769Y135.9218
    G1X489.4825Y135.9738
    G1X489.0896Y136.0184
    G1X488.6985Y136.0559
    G1X488.3093Y136.0863
    G1X487.9221Y136.1097
    G1X487.5372Y136.1263
    G1X487.1547Y136.1361
    G1X486.7747Y136.1393
    G0Z5.0800
    G0Y168.6607
    G1Z-4.7650F762.0
    G1X487.1547Y168.6639F2667.0
    G1X487.5372Y168.6738
    G1X487.9221Y168.6903
    G1X488.3093Y168.7137
    G1X488.6985Y168.7441
    G1X489.0896Y168.7816
    G1X489.4825Y168.8262
    G1X489.8769Y168.8782
    G1X490.2727Y168.9377
    G1X490.6696Y169.0046
    G1X491.0677Y169.0792
    G1X491.4664Y169.1615
    G1X491.8657Y169.2516
    G1X492.2654Y169.3496
    G1X492.6652Y169.4555
    G1X493.0649Y169.5694
    G1X493.4644Y169.6913
    G1X493.8633Y169.8214
    G1X494.2614Y169.9596
    G1X494.6586Y170.1060
    G1X495.0544Y170.2605
    G1X495.4488Y170.4232
    G1X495.8415Y170.5942
    G1X496.2321Y170.7733
    G1X496.6206Y170.9606
    G1X497.0065Y171.1560
    G1X497.3898Y171.3595
    G1X497.7701Y171.5711
    G1X498.1471Y171.7906
    G1X498.5206Y172.0181
    G1X498.8905Y172.2535
    G1X499.2563Y172.4966
    G1X499.6180Y172.7473
    G1X499.9753Y173.0056
    G1X500.3278Y173.2714
    G1X500.6754Y173.5444
    G1X501.0179Y173.8246
    G1X501.3551Y174.1119
    G1X501.6868Y174.4060
    G1X502.0126Y174.7068
    G1X502.3325Y175.0141
    G1X502.6462Y175.3279
    G1X502.9536Y175.6477
    G1X503.2544Y175.9736
    G1X503.5485Y176.3052
    G1X503.8357Y176.6423
    G1X504.1159Y176.9849
    G1X504.3890Y177.3325
    G1X504.6547Y177.6851
    G1X504.9130Y178.0423
    G1X505.1638Y178.4040
    G1X505.4069Y178.7699
    G1X505.6422Y179.1397
    G1X505.8697Y179.5133
    G1X506.0893Y179.8903
    G1X506.3008Y180.2706
    G1X506.5043Y180.6538
    G1X506.6997Y181.0398
    G1X506.8870Y181.4282
    G1X507.0661Y181.8189
    G1X507.2371Y182.2115
    G1X507.3998Y182.6059
    G1X507.5544Y183.0018
    G1X507.7007Y183.3989
    G1X507.8389Y183.7971
    G1X507.9690Y184.1960
    G1X508.0909Y184.5954
    G1X508.2049Y184.9951
    G1X508.3108Y185.3950
    G1X508.4087Y185.7946
    G1X508.4988Y186.1940
    G1X508.5811Y186.5927
    G1X508.6557Y186.9907
    G1X508.7227Y187.3876
    G1X508.7821Y187.7834
    G1X508.8341Y188.1779
    G1X508.8788Y188.5707
    G1X508.9163Y188.9618
    G1X508.9466Y189.3511
    G1X508.9700Y189.7382
    G1X508.9866Y190.1231
    G1X508.9964Y190.5057
    G1X508.9997Y190.8857
    G1X508.9962Y191.2775
    G1X508.9858Y191.6717
    G1X508.9682Y192.0680
    G1X508.9434Y192.4662
    G1X508.9113Y192.8662
    G1X508.8716Y193.2678
    G1X508.8245Y193.6707
    G1X508.7697Y194.0749
    G1X508.7071Y194.4800
    G1X508.6367Y194.8859
    G1X508.5584Y195.2924
    G1X508.4722Y195.6992
    G1X508.3779Y196.1061
    G1X508.2755Y196.5130
    G1X508.1649Y196.9194
    G1X508.0463Y197.3254
    G1X507.9194Y197.7305
    G1X507.7843Y198.1346
    G1X507.6410Y198.5373
    G1X507.4895Y198.9386
    G1X507.3297Y199.3380
    G1X507.1617Y199.7354
    G1X506.9856Y200.1306
    G1X506.8014Y200.5232
    G1X506.6090Y200.9131
    G1X506.4087Y201.2999
    G1X506.2003Y201.6835
    G1X505.9842Y202.0636
    G1X505.7602Y202.4399
    G1X505.5285Y202.8122
    G1X505.2892Y203.1804
    G1X505.0426Y203.5441
    G1X504.7885Y203.9031
    G1X504.5272Y204.2572
    G1X504.2589Y204.6063
    G1X503.9836Y204.9500
    G1X503.7016Y205.2881
    G1X503.4129Y205.6206
    G1X503.1179Y205.9472
    G1X502.8167Y206.2676
    G1X502.5094Y206.5818
    G1X502.1962Y206.8896
    G1X501.8774Y207.1908
    G1X501.5533Y207.4852
    G1X501.2238Y207.7727
    G1X500.8894Y208.0532
    G1X500.5502Y208.3266
    G1X500.2064Y208.5927
    G1X499.8583Y208.8514
    G1X499.5062Y209.1027
    G1X499.1501Y209.3464
    G1X498.7905Y209.5825
    G1X498.4275Y209.8109
    G1X498.0613Y210.0315
    G1X497.6922Y210.2443
    G1X497.3205Y210.4493
    G1X496.9463Y210.6464
    G1X496.5699Y210.8357
    G1X496.1917Y211.0170
    G1X495.8116Y211.1904
    G1X495.4301Y211.3560
    G1X495.0474Y211.5136
    G1X494.6636Y211.6634
    G1X494.2791Y211.8054
    G1X493.8939Y211.9396
    G1X493.5084Y212.0660
    G1X493.1227Y212.1848
    G1X492.7372Y212.2959
    G1X492.3519Y212.3995
    G1X491.9670Y212.4956
    G1X491.5828Y212.5843
    G1X491.1995Y212.6657
    G1Z0.0000
    G1X488.9983Y212.9992
    G1X486.7747Y213.1107
    G1X484.5511Y212.9992
    G1X482.3499Y212.6657
    G1Z-4.7650F762.0
    G1X481.9665Y212.5843F2667.0
    G1X481.5823Y212.4956
    G1X481.1974Y212.3995
    G1X480.8122Y212.2959
    G1X480.4266Y212.1848
    G1X480.0410Y212.0660
    G1X479.6555Y211.9396
    G1X479.2703Y211.8054
    G1X478.8857Y211.6634
    G1X478.5020Y211.5136
    G1X478.1192Y211.3560
    G1X477.7377Y211.1904
    G1X477.3577Y211.0170
    G1X476.9794Y210.8357
    G1X476.6031Y210.6464
    G1X476.2289Y210.4493
    G1X475.8571Y210.2443
    G1X475.4881Y210.0315
    G1X475.1219Y209.8109
    G1X474.7589Y209.5825
    G1X474.3992Y209.3464
    G1X474.0432Y209.1027
    G1X473.6910Y208.8514
    G1X473.3429Y208.5927
    G1X472.9992Y208.3266
    G1X472.6599Y208.0532
    G1X472.3255Y207.7727
    G1X471.9961Y207.4852
    G1X471.6719Y207.1908
    G1X471.3531Y206.8896
    G1X471.0400Y206.5818
    G1X470.7327Y206.2676
    G1X470.4315Y205.9472
    G1X470.1364Y205.6206
    G1X469.8478Y205.2881
    G1X469.5658Y204.9500
    G1X469.2905Y204.6063
    G1X469.0221Y204.2572
    G1X468.7609Y203.9031
    G1X468.5068Y203.5441
    G1X468.2601Y203.1804
    G1X468.0208Y202.8122
    G1X467.7891Y202.4399
    G1X467.5652Y202.0636
    G1X467.3490Y201.6835
    G1X467.1407Y201.2999
    G1X466.9403Y200.9131
    G1X466.7480Y200.5232
    G1X466.5637Y200.1306
    G1X466.3876Y199.7354
    G1X466.2196Y199.3380
    G1X466.0599Y198.9386
    G1X465.9084Y198.5373
    G1X465.7651Y198.1346
    G1X465.6299Y197.7305
    G1X465.5031Y197.3254
    G1X465.3844Y196.9194
    G1X465.2739Y196.5130
    G1X465.1715Y196.1061
    G1X465.0772Y195.6992
    G1X464.9909Y195.2924
    G1X464.9127Y194.8859
    G1X464.8423Y194.4800
    G1X464.7797Y194.0749
    G1X464.7249Y193.6707
    G1X464.6777Y193.2678
    G1X464.6381Y192.8662
    G1X464.6059Y192.4662
    G1X464.5811Y192.0680
    G1X464.5636Y191.6717
    G1X464.5531Y191.2775
    G1X464.5497Y190.8857
    G1X464.5529Y190.5057
    G1X464.5628Y190.1231
    G1X464.5793Y189.7382
    G1X464.6028Y189.3511
    G1X464.6331Y188.9618
    G1X464.6706Y188.5707
    G1X464.7152Y188.1779
    G1X464.7673Y187.7834
    G1X464.8267Y187.3876
    G1X464.8936Y186.9907
    G1X464.9682Y186.5927
    G1X465.0505Y186.1940
    G1X465.1407Y185.7946
    G1X465.2386Y185.3950
    G1X465.3445Y184.9951
    G1X465.4584Y184.5954
    G1X465.5804Y184.1960
    G1X465.7104Y183.7971
    G1X465.8486Y183.3989
    G1X465.9950Y183.0018
    G1X466.1495Y182.6059
    G1X466.3123Y182.2115
    G1X466.4832Y181.8189
    G1X466.6623Y181.4282
    G1X466.8496Y181.0398
    G1X467.0450Y180.6538
    G1X467.2485Y180.2706
    G1X467.4601Y179.8903
    G1X467.6797Y179.5133
    G1X467.9071Y179.1397
    G1X468.1425Y178.7699
    G1X468.3856Y178.4040
    G1X468.6363Y178.0423
    G1X468.8946Y177.6851
    G1X469.1604Y177.3325
    G1X469.4334Y176.9849
    G1X469.7136Y176.6423
    G1X470.0009Y176.3052
    G1X470.2950Y175.9736
    G1X470.5958Y175.6477
    G1X470.9032Y175.3279
    G1X471.2169Y175.0141
    G1X471.5367Y174.7068
    G1X471.8626Y174.4060
    G1X472.1942Y174.1119
    G1X472.5314Y173.8246
    G1X472.8739Y173.5444
    G1X473.2216Y173.2714
    G1X473.5741Y173.0056
    G1X473.9313Y172.7473
    G1X474.2930Y172.4966
    G1X474.6589Y172.2535
    G1X475.0287Y172.0181
    G1X475.4023Y171.7906
    G1X475.7793Y171.5711
    G1X476.1596Y171.3595
    G1X476.5428Y171.1560
    G1X476.9288Y170.9606
    G1X477.3172Y170.7733
    G1X477.7079Y170.5942
    G1X478.1006Y170.4232
    G1X478.4949Y170.2605
    G1X478.8908Y170.1060
    G1X479.2879Y169.9596
    G1X479.6861Y169.8214
    G1X480.0850Y169.6913
    G1X480.4844Y169.5694
    G1X480.8842Y169.4555
    G1X481.2840Y169.3496
    G1X481.6837Y169.2516
    G1X482.0830Y169.1615
    G1X482.4817Y169.0792
    G1X482.8797Y169.0046
    G1X483.2766Y168.9377
    G1X483.6725Y168.8782
    G1X484.0669Y168.8262
    G1X484.4597Y168.7816
    G1X484.8509Y168.7441
    G1X485.2401Y168.7137
    G1X485.6272Y168.6903
    G1X486.0121Y168.6738
    G1X486.3947Y168.6639
    G1X486.7747Y168.6607
    G0Z5.0800
    G0X384.7328Y210.3438
    G1Z0.0000F762.0
    G1X383.4929Y210.3305F2667.0
    G1Z-4.7650F762.0
    G1X382.8730Y210.3139F2667.0
    G1X382.2505Y210.2906
    G1X381.6258Y210.2604
    G1X380.9988Y210.2233
    G1X380.3696Y210.1792
    G1X379.7383Y210.1281
    G1X379.1051Y210.0698
    G1X378.4700Y210.0043
    G1X377.8331Y209.9315
    G1X377.1946Y209.8513
    G1X376.5546Y209.7637
    G1X375.9132Y209.6686
    G1X375.2705Y209.5659
    G1X374.6266Y209.4556
    G1X373.9817Y209.3376
    G1X373.3358Y209.2119
    G1X372.6892Y209.0783
    G1X372.0419Y208.9369
    G1X371.3941Y208.7876
    G1X370.7458Y208.6303
    G1X370.0974Y208.4650
    G1X369.4487Y208.2916
    G1X368.8002Y208.1102
    G1X368.1517Y207.9207
    G1X367.5036Y207.7230
    G1X366.8560Y207.5171
    G1X366.2089Y207.3030
    G1X365.5625Y207.0807
    G1X364.9171Y206.8501
    G1X364.2727Y206.6113
    G1X363.6295Y206.3642
    G1X362.9876Y206.1087
    G1X362.3473Y205.8450
    G1X361.7086Y205.5730
    G1X361.0717Y205.2926
    G1X360.4368Y205.0040
    G1X359.8040Y204.7071
    G1X359.1735Y204.4020
    G1X358.5454Y204.0885
    G1X357.9200Y203.7668
    G1X357.2973Y203.4370
    G1X356.6775Y203.0989
    G1X356.0607Y202.7527
    G1X355.4472Y202.3983
    G1X354.8371Y202.0359
    G1X354.2305Y201.6655
    G1X353.6276Y201.2871
    G1X353.0285Y200.9007
    G1X352.4335Y200.5065
    G1X351.8426Y200.1045
    G1X351.2560Y199.6947
    G1X350.6739Y199.2772
    G1X350.0964Y198.8521
    G1X349.5237Y198.4195
    G1X348.9558Y197.9795
    G1X348.3930Y197.5320
    G1X347.8354Y197.0773
    G1X347.2831Y196.6154
    G1X346.7362Y196.1463
    G1X346.1950Y195.6703
    G1X345.6595Y195.1874
    G1X345.1299Y194.6977
    G1X344.6063Y194.2012
    G1X344.0888Y193.6983
    G1X343.5775Y193.1888
    G1X343.0727Y192.6730
    G1X342.5742Y192.1510
    G1X342.0824Y191.6228
    G1X341.5974Y191.0887
    G1X341.1191Y190.5487
    G1X340.6477Y190.0030
    G1X340.1834Y189.4517
    G1X339.7262Y188.8950
    G1X339.2762Y188.3329
    G1X338.8335Y187.7657
    G1X338.3982Y187.1935
    G1X337.9704Y186.6163
    G1X337.5501Y186.0344
    G1X337.1375Y185.4480
    G1X336.7326Y184.8570
    G1X336.3354Y184.2618
    G1X335.9461Y183.6625
    G1X335.5647Y183.0591
    G1X335.1913Y182.4520
    G1X334.8258Y181.8411
    G1X334.4685Y181.2267
    G1X334.1192Y180.6090
    G1X333.7781Y179.9880
    G1X333.4452Y179.3640
    G1X333.1204Y178.7371
    G1X332.8039Y178.1075
    G1X332.4957Y177.4753
    G1X332.1958Y176.8406
    G1X331.9042Y176.2037
    G1X331.6209Y175.5647
    G1X331.3459Y174.9238
    G1X331.0793Y174.2811
    G1X330.8210Y173.6367
    G1X330.5710Y172.9909
    G1X330.3294Y172.3437
    G1X330.0961Y171.6953
    G1X329.8711Y171.0460
    G1X329.6544Y170.3958
    G1X329.4459Y169.7448
    G1X329.2457Y169.0933
    G1X329.0537Y168.4414
    G1X328.8700Y167.7892
    G1X328.6943Y167.1369
    G1X328.5269Y166.4845
    G1X328.3675Y165.8324
    G1X328.2161Y165.1805
    G1X328.0727Y164.5291
    G1X327.9373Y163.8782
    G1X327.8097Y163.2280
    G1X327.6900Y162.5787
    G1X327.5781Y161.9303
    G1X327.4739Y161.2830
    G1X327.3774Y160.6369
    G1X327.2885Y159.9921
    G1X327.2072Y159.3488
    G1X327.1333Y158.7070
    G1X327.0668Y158.0670
    G1X327.0077Y157.4287
    G1X326.9557Y156.7924
    G1X326.9110Y156.1580
    G1X326.8734Y155.5258
    G1X326.8428Y154.8958
    G1X326.8192Y154.2681
    G1X326.8024Y153.6429
    G1X326.7923Y153.0201
    G1X326.7890Y152.4000
    G1X326.7924Y151.7773
    G1X326.8025Y151.1520
    G1X326.8194Y150.5243
    G1X326.8432Y149.8942
    G1X326.8741Y149.2618
    G1X326.9120Y148.6273
    G1X326.9570Y147.9907
    G1X327.0093Y147.3522
    G1X327.0689Y146.7118
    G1X327.1358Y146.0697
    G1X327.2102Y145.4259
    G1X327.2921Y144.7807
    G1X327.3816Y144.1341
    G1X327.4788Y143.4862
    G1X327.5836Y142.8372
    G1X327.6961Y142.1872
    G1X327.8165Y141.5363
    G1X327.9448Y140.8846
    G1X328.0810Y140.2324
    G1X328.2251Y139.5796
    G1X328.3773Y138.9265
    G1X328.5375Y138.2732
    G1X328.7058Y137.6198
    G1X328.8822Y136.9665
    G1X329.0668Y136.3133
    G1X329.2596Y135.6606
    G1X329.4606Y135.0083
    G1X329.6699Y134.3568
    G1X329.8874Y133.7060
    G1X330.1132Y133.0561
    G1X330.3474Y132.4074
    G1X330.5898Y131.7599
    G1X330.8405Y131.1139
    G1X331.0995Y130.4694
    G1X331.3669Y129.8266
    G1X331.6425Y129.1857
    G1X331.9265Y128.5468
    G1X332.2187Y127.9101
    G1X332.5192Y127.2758
    G1X332.8280Y126.6440
    G1X333.1450Y126.0148
    G1X333.4702Y125.3884
    G1X333.8035Y124.7650
    G1X334.1450Y124.1448
    G1X334.4946Y123.5278
    G1X334.8522Y122.9143
    G1X335.2178Y122.3044
    G1X335.5914Y121.6982
    G1X335.9728Y121.0959
    G1X336.3621Y120.4977
    G1X336.7592Y119.9037
    G1X337.1639Y119.3140
    G1X337.5763Y118.7288
    G1X337.9962Y118.1483
    G1X338.4237Y117.5726
    G1X338.8585Y117.0019
    G1X339.3006Y116.4362
    G1X339.7499Y115.8757
    G1X340.2064Y115.3206
    G1X340.6699Y114.7710
    G1X341.1403Y114.2270
    G1X341.6176Y113.6888
    G1X342.1015Y113.1565
    G1X342.5921Y112.6301
    G1X343.0891Y112.1099
    G1X343.5926Y111.5960
    G1X344.1024Y111.0884
    G1X344.6182Y110.5873
    G1X345.1401Y110.0928
    G1X345.6678Y109.6050
    G1X346.2014Y109.1240
    G1X346.7406Y108.6499
    G1X347.2852Y108.1828
    G1X347.8352Y107.7228
    G1X348.3905Y107.2700
    G1X348.9508Y106.8245
    G1X349.5161Y106.3863
    G1X350.0861Y105.9555
    G1X350.6608Y105.5323
    G1X351.2400Y105.1167
    G1X351.8236Y104.7087
    G1X352.4113Y104.3084
    G1X353.0031Y103.9159
    G1X353.5989Y103.5312
    G1X354.1983Y103.1544
    G1X354.8014Y102.7856
    G1X355.4079Y102.4247
    G1X356.0177Y102.0718
    G1X356.6306Y101.7271
    G1X357.2465Y101.3904
    G1X357.8652Y101.0618
    G1X358.4866Y100.7413
    G1X359.1105Y100.4291
    G1X359.7367Y100.1250
    G1X360.3652Y99.8291
    G1X360.9956Y99.5414
    G1X361.6280Y99.2620
    G1X362.2621Y98.9907
    G1X362.8978Y98.7277
    G1X363.5349Y98.4729
    G1X364.1733Y98.2263
    G1X364.8129Y97.9879
    G1X365.4533Y97.7577
    G1X366.0947Y97.5356
    G1X366.7367Y97.3217
    G1X367.3793Y97.1159
    G1X368.0222Y96.9181
    G1X368.6655Y96.7285
    G1X369.3088Y96.5468
    G1X369.9521Y96.3731
    G1X370.5952Y96.2074
    G1X371.2381Y96.0496
    G1X371.8805Y95.8996
    G1X372.5224Y95.7574
    G1X373.1635Y95.6230
    G1X373.8039Y95.4962
    G1X374.4433Y95.3772
    G1X375.0817Y95.2656
    G1X375.7188Y95.1617
    G1X376.3547Y95.0651
    G1X376.9891Y94.9760
    G1X377.6220Y94.8942
    G1X378.2533Y94.8197
    G1X378.8828Y94.7523
    G1X379.5105Y94.6921
    G1X380.1362Y94.6389
    G1X380.7599Y94.5926
    G1X381.3813Y94.5533
    G1Z0.0000
    G1X384.7328Y94.4562
    G1X387.4121Y94.5182
    G1X390.0857Y94.7040
    G1Z-4.7650F762.0
    G1X390.7085Y94.7652F2667.0
    G1X391.3332Y94.8334
    G1X391.9597Y94.9087
    G1X392.5879Y94.9912
    G1X393.2176Y95.0808
    G1X393.8487Y95.1778
    G1X394.4812Y95.2822
    G1X395.1149Y95.3940
    G1X395.7497Y95.5132
    G1X396.3855Y95.6400
    G1X397.0221Y95.7745
    G1X397.6595Y95.9166
    G1X398.2974Y96.0664
    G1X398.9359Y96.2239
    G1X399.5747Y96.3893
    G1X400.2137Y96.5626
    G1X400.8528Y96.7437
    G1X401.4918Y96.9328
    G1X402.1306Y97.1298
    G1X402.7692Y97.3349
    G1X403.4072Y97.5480
    G1X404.0446Y97.7691
    G1X404.6812Y97.9984
    G1X405.3170Y98.2357
    G1X405.9517Y98.4812
    G1X406.5851Y98.7348
    G1X407.2173Y98.9966
    G1X407.8479Y99.2665
    G1X408.4769Y99.5446
    G1X409.1041Y99.8308
    G1X409.7293Y100.1252
    G1X410.3524Y100.4278
    G1X410.9733Y100.7385
    G1X411.5917Y101.0573
    G1X412.2076Y101.3842
    G1X412.8207Y101.7192
    G1X413.4310Y102.0623
    G1X414.0382Y102.4133
    G1X414.6423Y102.7724
    G1X415.2430Y103.1394
    G1X415.8401Y103.5143
    G1X416.4337Y103.8971
    G1X417.0235Y104.2878
    G1X417.6093Y104.6861
    G1X418.1910Y105.0922
    G1X418.7684Y105.5060
    G1X419.3415Y105.9273
    G1X419.9100Y106.3561
    G1X420.4738Y106.7924
    G1X421.0328Y107.2360
    G1X421.5868Y107.6869
    G1X422.1356Y108.1450
    G1X422.6792Y108.6102
    G1X423.2175Y109.0825
    G1X423.7502Y109.5617
    G1X424.2772Y110.0477
    G1X424.7984Y110.5404
    G1X425.3137Y111.0398
    G1X425.8229Y111.5457
    G1X426.3260Y112.0580
    G1X426.8228Y112.5765
    G1X427.3131Y113.1013
    G1X427.7970Y113.6321
    G1X428.2742Y114.1689
    G1X428.7447Y114.7115
    G1X429.2083Y115.2597
    G1X429.6650Y115.8135
    G1X430.1146Y116.3727
    G1X430.5571Y116.9373
    G1X430.9924Y117.5069
    G1X431.4203Y118.0816
    G1X431.8408Y118.6611
    G1X432.2538Y119.2454
    G1X432.6593Y119.8342
    G1X433.0571Y120.4275
    G1X433.4472Y121.0251
    G1X433.8295Y121.6268
    G1X434.2040Y122.2325
    G1X434.5705Y122.8420
    G1X434.9292Y123.4552
    G1X435.2798Y124.0719
    G1X435.6223Y124.6920
    G1X435.9568Y125.3153
    G1X436.2831Y125.9417
    G1X436.6013Y126.5710
    G1X436.9112Y127.2030
    G1X437.2130Y127.8377
    G1X437.5064Y128.4747
    G1X437.7916Y129.1141
    G1X438.0685Y129.7556
    G1X438.3372Y130.3990
    G1X438.5975Y131.0442
    G1X438.8495Y131.6911
    G1X439.0932Y132.3395
    G1X439.3286Y132.9893
    G1X439.5557Y133.6402
    G1X439.7744Y134.2922
    G1X439.9850Y134.9451
    G1X440.1872Y135.5987
    G1X440.3812Y136.2529
    G1X440.5670Y136.9076
    G1X440.7446Y137.5625
    G1X440.9141Y138.2176
    G1X441.0754Y138.8727
    G1X441.2286Y139.5277
    G1X441.3738Y140.1824
    G1X441.5110Y140.8367
    G1X441.6402Y141.4905
    G1X441.7615Y142.1436
    G1X441.8751Y142.7959
    G1X441.9807Y143.4472
    G1X442.0786Y144.0975
    G1X442.1688Y144.7466
    G1X442.2514Y145.3943
    G1X442.3265Y146.0407
    G1X442.3940Y146.6854
    G1X442.4541Y147.3285
    G1X442.5069Y147.9698
    G1X442.5524Y148.6093
    G1X442.5907Y149.2467
    G1X442.6218Y149.8820
    G1X442.6458Y150.5151
    G1X442.6629Y151.1458
    G1X442.6731Y151.7742
    G1X442.6765Y152.4000
    G1X442.6731Y153.0279
    G1X442.6628Y153.6583
    G1X442.6457Y154.2910
    G1X442.6214Y154.9260
    G1X442.5901Y155.5631
    G1X442.5516Y156.2023
    G1X442.5059Y156.8434
    G1X442.4528Y157.4864
    G1X442.3924Y158.1310
    G1X442.3245Y158.7773
    G1X442.2491Y159.4250
    G1X442.1661Y160.0742
    G1X442.0754Y160.7245
    G1X441.9771Y161.3760
    G1X441.8709Y162.0285
    G1X441.7570Y162.6818
    G1X441.6352Y163.3358
    G1X441.5055Y163.9905
    G1X441.3678Y164.6456
    G1X441.2220Y165.3011
    G1X441.0683Y165.9567
    G1X440.9065Y166.6124
    G1X440.7365Y167.2680
    G1X440.5584Y167.9233
    G1X440.3721Y168.5783
    G1X440.1777Y169.2328
    G1X439.9749Y169.8865
    G1X439.7640Y170.5395
    G1X439.5448Y171.1915
    G1X439.3173Y171.8423
    G1X439.0816Y172.4919
    G1X438.8376Y173.1400
    G1X438.5853Y173.7866
    G1X438.3247Y174.4314
    G1X438.0558Y175.0743
    G1X437.7788Y175.7152
    G1X437.4934Y176.3539
    G1X437.1999Y176.9902
    G1X436.8981Y177.6240
    G1X436.5882Y178.2552
    G1X436.2701Y178.8835
    G1X435.9440Y179.5089
    G1X435.6097Y180.1311
    G1X435.2674Y180.7500
    G1X434.9172Y181.3655
    G1X434.5590Y181.9774
    G1X434.1929Y182.5856
    G1X433.8190Y183.1899
    G1X433.4373Y183.7901
    G1X433.0480Y184.3862
    G1X432.6511Y184.9779
    G1X432.2465Y185.5651
    G1X431.8345Y186.1477
    G1X431.4151Y186.7255
    G1X430.9883Y187.2984
    G1X430.5544Y187.8663
    G1X430.1133Y188.4290
    G1X429.6651Y188.9864
    G1X429.2100Y189.5383
    G1X428.7480Y190.0847
    G1X428.2793Y190.6253
    G1X427.8040Y191.1601
    G1X427.3221Y191.6890
    G1X426.8338Y192.2118
    G1X426.3392Y192.7284
    G1X425.8385Y193.2387
    G1X425.3316Y193.7426
    G1X424.8188Y194.2400
    G1X424.3003Y194.7307
    G1X423.7760Y195.2148
    G1X423.2461Y195.6920
    G1X422.7109Y196.1623
    G1X422.1703Y196.6257
    G1X421.6246Y197.0819
    G1X421.0739Y197.5309
    G1X420.5183Y197.9727
    G1X419.9579Y198.4072
    G1X419.3930Y198.8343
    G1X418.8236Y199.2539
    G1X418.2500Y199.6660
    G1X417.6722Y200.0704
    G1X417.0904Y200.4673
    G1X416.5048Y200.8564
    G1X415.9153Y201.2377
    G1X415.3224Y201.6113
    G1X414.7261Y201.9770
    G1X414.1266Y202.3348
    G1X413.5239Y202.6847
    G1X412.9183Y203.0266
    G1X412.3098Y203.3606
    G1X411.6989Y203.6866
    G1X411.0853Y204.0045
    G1X410.4694Y204.3144
    G1X409.8513Y204.6162
    G1X409.2313Y204.9100
    G1X408.6093Y205.1958
    G1X407.9856Y205.4734
    G1X407.3603Y205.7430
    G1X406.7335Y206.0045
    G1X406.1055Y206.2580
    G1X405.4763Y206.5034
    G1X404.8461Y206.7409
    G1X404.2151Y206.9703
    G1X403.5833Y207.1917
    G1X402.9510Y207.4052
    G1X402.3182Y207.6108
    G1X401.6852Y207.8084
    G1X401.0520Y207.9982
    G1X400.4187Y208.1802
    G1X399.7856Y208.3544
    G1X399.1527Y208.5208
    G1X398.5202Y208.6795
    G1X397.8882Y208.8306
    G1X397.2568Y208.9741
    G1X396.6261Y209.1100
    G1X395.9963Y209.2385
    G1X395.3675Y209.3595
    G1X394.7398Y209.4731
    G1X394.1133Y209.5794
    G1X393.4882Y209.6785
    G1X392.8645Y209.7703
    G1X392.2423Y209.8551
    G1Z0.0000
    G1X388.4955Y210.2215
    G1X384.7328Y210.3438
    G0Z5.0800
    G0X237.5672
    G1Z-4.7650F762.0
    G1X236.8966Y210.3399F2667.0
    G1X236.2249Y210.3282
    G1X235.5524Y210.3087
    G1X234.8792Y210.2814
    G1X234.2054Y210.2462
    G1X233.5312Y210.2030
    G1X232.8566Y210.1519
    G1X232.1819Y210.0929
    G1X231.5071Y210.0260
    G1X230.8325Y209.9510
    G1X230.1581Y209.8681
    G1X229.4841Y209.7772
    G1X228.8106Y209.6783
    G1X228.1377Y209.5713
    G1X227.4658Y209.4565
    G1X226.7947Y209.3336
    G1X226.1248Y209.2027
    G1X225.4561Y209.0639
    G1X224.7887Y208.9171
    G1X224.1229Y208.7625
    G1X223.4588Y208.5999
    G1X222.7965Y208.4295
    G1X222.1361Y208.2512
    G1X221.4778Y208.0651
    G1X220.8217Y207.8713
    G1X220.1680Y207.6697
    G1X219.5167Y207.4605
    G1X218.8681Y207.2436
    G1X218.2222Y207.0191
    G1X217.5793Y206.7871
    G1X216.9394Y206.5477
    G1X216.3026Y206.3008
    G1X215.6691Y206.0465
    G1X215.0390Y205.7850
    G1X214.4125Y205.5163
    G1X213.7896Y205.2404
    G1X213.1705Y204.9574
    G1X212.5553Y204.6674
    G1X211.9441Y204.3705
    G1X211.3370Y204.0668
    G1X210.7342Y203.7563
    G1X210.1358Y203.4391
    G1X209.5418Y203.1154
    G1X208.9523Y202.7852
    G1X208.3676Y202.4486
    G1X207.7876Y202.1057
    G1X207.2125Y201.7565
    G1X206.6423Y201.4013
    G1X206.0773Y201.0401
    G1Z0.0000
    G1X202.2384Y198.3277
    G1X198.6320Y195.3130
    G1Z-4.7650F762.0
    G1X198.1444Y194.8655F2667.0
    G1X197.6608Y194.4114
    G1X197.1814Y193.9507
    G1X196.7062Y193.4835
    G1X196.2354Y193.0098
    G1X195.7691Y192.5297
    G1X195.3075Y192.0433
    G1X194.8506Y191.5506
    G1X194.3987Y191.0517
    G1X193.9517Y190.5466
    G1X193.5099Y190.0355
    G1X193.0733Y189.5183
    G1X192.6421Y188.9952
    G1X192.2164Y188.4663
    G1X191.7963Y187.9316
    G1X191.3819Y187.3913
    G1X190.9733Y186.8454
    G1X190.5706Y186.2939
    G1X190.1740Y185.7371
    G1X189.7836Y185.1750
    G1X189.3994Y184.6077
    G1X189.0215Y184.0353
    G1X188.6501Y183.4580
    G1X188.2853Y182.8757
    G1X187.9271Y182.2887
    G1X187.5756Y181.6970
    G1X187.2310Y181.1008
    G1X186.8932Y180.5002
    G1X186.5625Y179.8953
    G1X186.2388Y179.2862
    G1X185.9222Y178.6731
    G1X185.6129Y178.0560
    G1X185.3109Y177.4352
    G1X185.0163Y176.8106
    G1X184.7291Y176.1826
    G1X184.4494Y175.5511
    G1X184.1772Y174.9164
    G1X183.9127Y174.2785
    G1X183.6558Y173.6377
    G1X183.4067Y172.9940
    G1X183.1653Y172.3476
    G1X182.9317Y171.6986
    G1X182.7059Y171.0472
    G1X182.4881Y170.3935
    G1X182.2781Y169.7376
    G1X182.0761Y169.0797
    G1X181.8821Y168.4200
    G1X181.6960Y167.7585
    G1X181.5180Y167.0955
    G1X181.3479Y166.4311
    G1X181.1860Y165.7653
    G1X181.0320Y165.0985
    G1X180.8862Y164.4306
    G1X180.7483Y163.7619
    G1X180.6186Y163.0924
    G1X180.4968Y162.4225
    G1X180.3832Y161.7520
    G1X180.2775Y161.0813
    G1X180.1799Y160.4105
    G1X180.0902Y159.7397
    G1X180.0085Y159.0690
    G1X179.9348Y158.3986
    G1X179.8690Y157.7286
    G1X179.8111Y157.0592
    G1X179.7610Y156.3905
    G1X179.7188Y155.7226
    G1X179.6844Y155.0556
    G1X179.6577Y154.3898
    G1X179.6386Y153.7251
    G1X179.6273Y153.0618
    G1X179.6235Y152.4000
    G1X179.6268Y151.7825
    G1X179.6367Y151.1624
    G1X179.6534Y150.5398
    G1X179.6768Y149.9147
    G1X179.7072Y149.2873
    G1X179.7444Y148.6577
    G1X179.7888Y148.0258
    G1X179.8403Y147.3920
    G1X179.8990Y146.7562
    G1X179.9650Y146.1186
    G1X180.0383Y145.4792
    G1X180.1190Y144.8383
    G1X180.2072Y144.1958
    G1X180.3030Y143.5520
    G1X180.4064Y142.9070
    G1X180.5175Y142.2608
    G1X180.6363Y141.6136
    G1X180.7629Y140.9655
    G1X180.8974Y140.3167
    G1X181.0397Y139.6673
    G1X181.1901Y139.0173
    G1X181.3484Y138.3671
    G1X181.5148Y137.7166
    G1X181.6892Y137.0661
    G1X181.8718Y136.4156
    G1X182.0625Y135.7654
    G1X182.2615Y135.1155
    G1X182.4686Y134.4662
    G1X182.6840Y133.8174
    G1X182.9077Y133.1695
    G1X183.1396Y132.5226
    G1X183.3798Y131.8767
    G1X183.6284Y131.2321
    G1X183.8852Y130.5890
    G1X184.1504Y129.9474
    G1X184.4239Y129.3075
    G1X184.7057Y128.6695
    G1X184.9958Y128.0335
    G1X185.2943Y127.3997
    G1X185.6010Y126.7683
    G1X185.9159Y126.1394
    G1X186.2391Y125.5131
    G1X186.5706Y124.8897
    G1X186.9102Y124.2692
    G1X187.2579Y123.6519
    G1X187.6138Y123.0379
    G1X187.9777Y122.4273
    G1X188.3497Y121.8204
    G1X188.7296Y121.2172
    G1X189.1175Y120.6179
    G1X189.5132Y120.0227
    G1X189.9167Y119.4318
    G1X190.3279Y118.8452
    G1X190.7468Y118.2631
    G1X191.1733Y117.6857
    G1X191.6073Y117.1131
    G1X192.0487Y116.5455
    G1X192.4975Y115.9830
    G1X192.9535Y115.4258
    G1X193.4166Y114.8740
    G1X193.8869Y114.3276
    G1X194.3641Y113.7870
    G1X194.8481Y113.2521
    G1X195.3389Y112.7232
    G1X195.8364Y112.2003
    G1X196.3404Y111.6836
    G1X196.8508Y111.1732
    G1X197.3675Y110.6692
    G1X197.8904Y110.1717
    G1X198.4193Y109.6809
    G1X198.9542Y109.1968
    G1X199.4949Y108.7196
    G1X200.0412Y108.2494
    G1X200.5930Y107.7862
    G1X201.1503Y107.3302
    G1X201.7128Y106.8815
    G1X202.2804Y106.4401
    G1X202.8529Y106.0061
    G1X203.4303Y105.5796
    G1X204.0124Y105.1607
    G1X204.5990Y104.7495
    G1X205.1900Y104.3460
    G1X205.7852Y103.9503
    G1X206.3844Y103.5624
    G1X206.9876Y103.1825
    G1X207.5946Y102.8105
    G1X208.2051Y102.4466
    G1X208.8191Y102.0907
    G1X209.4364Y101.7429
    G1X210.0569Y101.4033
    G1X210.6803Y101.0719
    G1X211.3066Y100.7487
    G1X211.9355Y100.4337
    G1X212.5669Y100.1270
    G1X213.2007Y99.8286
    G1X213.8367Y99.5385
    G1X214.4747Y99.2567
    G1X215.1146Y98.9832
    G1X215.7562Y98.7180
    G1X216.3994Y98.4611
    G1X217.0440Y98.2126
    G1X217.6898Y97.9724
    G1X218.3368Y97.7404
    G1X218.9847Y97.5168
    G1X219.6334Y97.3014
    G1X220.2828Y97.0943
    G1X220.9326Y96.8953
    G1X221.5829Y96.7046
    G1X222.2333Y96.5220
    G1X222.8839Y96.3475
    G1X223.5343Y96.1812
    G1X224.1846Y96.0229
    G1X224.8345Y95.8725
    G1X225.4839Y95.7301
    G1X226.1327Y95.5957
    G1X226.7808Y95.4691
    G1X227.4280Y95.3503
    G1X228.0742Y95.2392
    G1X228.7193Y95.1358
    G1X229.3631Y95.0400
    G1X230.0055Y94.9518
    G1X230.6464Y94.8710
    G1X231.2858Y94.7977
    G1X231.9234Y94.7318
    G1X232.5592Y94.6731
    G1X233.1931Y94.6216
    G1X233.8249Y94.5772
    G1X234.4545Y94.5399
    G1X235.0820Y94.5096
    G1X235.7070Y94.4861
    G1X236.3297Y94.4695
    G1X236.9498Y94.4595
    G1X237.5672Y94.4562
    G1X238.2380Y94.4601
    G1X238.9099Y94.4718
    G1X239.5828Y94.4913
    G1X240.2565Y94.5187
    G1X240.9309Y94.5540
    G1X241.6059Y94.5972
    G1X242.2813Y94.6483
    G1X242.9570Y94.7075
    G1X243.6329Y94.7746
    G1X244.3087Y94.8498
    G1X244.9845Y94.9329
    G1X245.6600Y95.0242
    G1X246.3351Y95.1234
    G1X247.0096Y95.2308
    G1X247.6833Y95.3461
    G1X248.3563Y95.4696
    G1X249.0283Y95.6010
    G1X249.6991Y95.7405
    G1X250.3687Y95.8880
    G1X251.0368Y96.0436
    G1X251.7034Y96.2071
    G1X252.3683Y96.3785
    G1X253.0314Y96.5579
    G1X253.6924Y96.7452
    G1X254.3513Y96.9404
    G1X255.0080Y97.1433
    G1X255.6622Y97.3541
    G1X256.3140Y97.5726
    G1X256.9630Y97.7989
    G1X257.6092Y98.0327
    G1X258.2524Y98.2742
    G1X258.8925Y98.5232
    G1X259.5295Y98.7797
    G1X260.1631Y99.0436
    G1X260.7932Y99.3148
    G1X261.4197Y99.5934
    G1X262.0424Y99.8791
    G1X262.6614Y100.1720
    G1X263.2763Y100.4720
    G1X263.8871Y100.7789
    G1X264.4938Y101.0927
    G1X265.0960Y101.4133
    G1X265.6939Y101.7407
    G1X266.2872Y102.0747
    G1X266.8759Y102.4152
    G1X267.4597Y102.7621
    G1X268.0387Y103.1155
    G1X268.6128Y103.4750
    G1X269.1818Y103.8408
    G1X269.7455Y104.2125
    G1X270.3041Y104.5902
    G1X270.8573Y104.9737
    G1X271.4051Y105.3630
    G1X271.9473Y105.7579
    G1Z0.0000
    G1X275.6200Y108.7026
    G1X279.0415Y111.9357
    G1Z-4.7650F762.0
    G1X279.5016Y112.4126F2667.0
    G1X279.9571Y112.8959
    G1X280.4080Y113.3853
    G1X280.8542Y113.8810
    G1X281.2955Y114.3827
    G1X281.7318Y114.8905
    G1X282.1631Y115.4042
    G1X282.5891Y115.9238
    G1X283.0097Y116.4492
    G1X283.4249Y116.9804
    G1X283.8346Y117.5172
    G1X284.2385Y118.0595
    G1X284.6367Y118.6074
    G1X285.0290Y119.1606
    G1X285.4153Y119.7192
    G1X285.7955Y120.2829
    G1X286.1695Y120.8517
    G1X286.5372Y121.4255
    G1X286.8985Y122.0042
    G1X287.2533Y122.5877
    G1X287.6015Y123.1759
    G1X287.9431Y123.7687
    G1X288.2778Y124.3659
    G1X288.6057Y124.9674
    G1X288.9267Y125.5732
    G1X289.2407Y126.1830
    G1X289.5475Y126.7968
    G1X289.8473Y127.4145
    G1X290.1397Y128.0359
    G1X290.4249Y128.6609
    G1X290.7027Y129.2894
    G1X290.9731Y129.9212
    G1X291.2359Y130.5562
    G1X291.4912Y131.1943
    G1X291.7389Y131.8353
    G1X291.9790Y132.4792
    G1X292.2113Y133.1257
    G1X292.4359Y133.7747
    G1X292.6528Y134.4261
    G1X292.8618Y135.0798
    G1X293.0630Y135.7355
    G1X293.2562Y136.3933
    G1X293.4416Y137.0528
    G1X293.6190Y137.7141
    G1X293.7885Y138.3768
    G1X293.9500Y139.0410
    G1X294.1035Y139.7064
    G1X294.2491Y140.3729
    G1X294.3866Y141.0405
    G1X294.5161Y141.7088
    G1X294.6377Y142.3778
    G1X294.7512Y143.0473
    G1X294.8567Y143.7173
    G1X294.9543Y144.3875
    G1X295.0439Y145.0578
    G1X295.1256Y145.7281
    G1X295.1993Y146.3982
    G1X295.2651Y147.0681
    G1X295.3231Y147.7375
    G1X295.3732Y148.4063
    G1X295.4155Y149.0745
    G1X295.4500Y149.7418
    G1X295.4767Y150.4081
    G1X295.4958Y151.0733
    G1X295.5072Y151.7374
    G1X295.5110Y152.4000
    G1X295.5077Y153.0175
    G1X295.4977Y153.6376
    G1X295.4811Y154.2602
    G1X295.4577Y154.8853
    G1X295.4273Y155.5127
    G1X295.3900Y156.1423
    G1X295.3456Y156.7742
    G1X295.2942Y157.4080
    G1X295.2355Y158.0438
    G1X295.1695Y158.6814
    G1X295.0962Y159.3208
    G1X295.0154Y159.9617
    G1X294.9272Y160.6042
    G1X294.8315Y161.2480
    G1X294.7281Y161.8931
    G1X294.6170Y162.5392
    G1X294.4981Y163.1864
    G1X294.3716Y163.8345
    G1X294.2371Y164.4833
    G1X294.0947Y165.1327
    G1X293.9444Y165.7827
    G1X293.7860Y166.4329
    G1X293.6197Y167.0834
    G1X293.4452Y167.7339
    G1X293.2626Y168.3843
    G1X293.0719Y169.0346
    G1X292.8730Y169.6845
    G1X292.6658Y170.3338
    G1X292.4504Y170.9825
    G1X292.2268Y171.6305
    G1X291.9948Y172.2774
    G1X291.7546Y172.9233
    G1X291.5061Y173.5679
    G1X291.2492Y174.2110
    G1X290.9840Y174.8526
    G1X290.7105Y175.4925
    G1X290.4287Y176.1305
    G1X290.1386Y176.7665
    G1X289.8402Y177.4003
    G1X289.5335Y178.0317
    G1X289.2185Y178.6606
    G1X288.8953Y179.2869
    G1X288.5639Y179.9103
    G1X288.2243Y180.5308
    G1X287.8765Y181.1481
    G1X287.5207Y181.7621
    G1X287.1567Y182.3727
    G1X286.7847Y182.9796
    G1X286.4048Y183.5828
    G1X286.0170Y184.1821
    G1X285.6213Y184.7773
    G1X285.2178Y185.3682
    G1X284.8065Y185.9548
    G1X284.3876Y186.5369
    G1X283.9612Y187.1143
    G1X283.5272Y187.6869
    G1X283.0858Y188.2545
    G1X282.6370Y188.8170
    G1X282.1810Y189.3742
    G1X281.7178Y189.9260
    G1X281.2476Y190.4724
    G1X280.7704Y191.0130
    G1X280.2863Y191.5479
    G1X279.7955Y192.0768
    G1X279.2980Y192.5997
    G1X278.7940Y193.1164
    G1X278.2836Y193.6268
    G1X277.7669Y194.1308
    G1X277.2440Y194.6283
    G1X276.7151Y195.1191
    G1X276.1803Y195.6031
    G1X275.6396Y196.0804
    G1X275.0933Y196.5506
    G1X274.5414Y197.0138
    G1X273.9842Y197.4698
    G1X273.4217Y197.9185
    G1X272.8541Y198.3599
    G1X272.2815Y198.7939
    G1X271.7041Y199.2204
    G1X271.1221Y199.6393
    G1X270.5355Y200.0505
    G1X269.9445Y200.4540
    G1X269.3493Y200.8497
    G1X268.7500Y201.2376
    G1X268.1469Y201.6175
    G1X267.5399Y201.9895
    G1X266.9294Y202.3534
    G1X266.3153Y202.7093
    G1X265.6980Y203.0571
    G1X265.0776Y203.3967
    G1X264.4541Y203.7281
    G1X263.8279Y204.0513
    G1X263.1989Y204.3663
    G1X262.5675Y204.6730
    G1X261.9337Y204.9714
    G1X261.2978Y205.2615
    G1X260.6598Y205.5433
    G1X260.0199Y205.8168
    G1X259.3783Y206.0820
    G1X258.7351Y206.3389
    G1X258.0905Y206.5874
    G1X257.4446Y206.8276
    G1X256.7977Y207.0596
    G1X256.1498Y207.2832
    G1X255.5011Y207.4986
    G1X254.8517Y207.7057
    G1X254.2018Y207.9047
    G1X253.5516Y208.0954
    G1X252.9011Y208.2780
    G1X252.2506Y208.4524
    G1X251.6001Y208.6188
    G1X250.9499Y208.7771
    G1X250.3000Y208.9275
    G1X249.6505Y209.0698
    G1X249.0017Y209.2043
    G1X248.3537Y209.3309
    G1X247.7065Y209.4497
    G1X247.0603Y209.5608
    G1X246.4152Y209.6642
    G1X245.7714Y209.7600
    G1X245.1290Y209.8482
    G1X244.4880Y209.9289
    G1X243.8487Y210.0023
    G1X243.2110Y210.0682
    G1X242.5753Y210.1269
    G1X241.9414Y210.1784
    G1X241.3096Y210.2228
    G1X240.6799Y210.2601
    G1X240.0525Y210.2904
    G1X239.4274Y210.3139
    G1X238.8048Y210.3305
    G1X238.1847Y210.3405
    G1X237.5672Y210.3438
    G0Z5.0800
    G0X135.5253Y168.6607
    G1Z-4.7650F762.0
    G1X135.9053Y168.6639F2667.0
    G1X136.2879Y168.6738
    G1X136.6728Y168.6903
    G1X137.0599Y168.7137
    G1X137.4491Y168.7441
    G1X137.8403Y168.7816
    G1X138.2331Y168.8262
    G1X138.6275Y168.8782
    G1X139.0233Y168.9377
    G1X139.4203Y169.0046
    G1X139.8183Y169.0792
    G1X140.2170Y169.1615
    G1X140.6163Y169.2516
    G1X141.0160Y169.3496
    G1X141.4158Y169.4555
    G1X141.8156Y169.5694
    G1X142.2150Y169.6913
    G1X142.6139Y169.8214
    G1X143.0121Y169.9596
    G1X143.4092Y170.1060
    G1X143.8051Y170.2605
    G1X144.1995Y170.4232
    G1X144.5921Y170.5942
    G1X144.9828Y170.7733
    G1X145.3712Y170.9606
    G1X145.7572Y171.1560
    G1X146.1404Y171.3595
    G1X146.5207Y171.5711
    G1X146.8977Y171.7906
    G1X147.2713Y172.0181
    G1X147.6411Y172.2535
    G1X148.0070Y172.4966
    G1X148.3686Y172.7473
    G1X148.7259Y173.0056
    G1X149.0784Y173.2714
    G1X149.4261Y173.5444
    G1X149.7686Y173.8246
    G1X150.1058Y174.1119
    G1X150.4374Y174.4060
    G1X150.7632Y174.7068
    G1X151.0831Y175.0141
    G1X151.3968Y175.3279
    G1X151.7042Y175.6477
    G1X152.0050Y175.9736
    G1X152.2991Y176.3052
    G1X152.5864Y176.6423
    G1X152.8666Y176.9849
    G1X153.1396Y177.3325
    G1X153.4053Y177.6851
    G1X153.6637Y178.0423
    G1X153.9144Y178.4040
    G1X154.1575Y178.7699
    G1X154.3928Y179.1397
    G1X154.6203Y179.5133
    G1X154.8399Y179.8903
    G1X155.0515Y180.2706
    G1X155.2550Y180.6538
    G1X155.4504Y181.0398
    G1X155.6377Y181.4282
    G1X155.8168Y181.8189
    G1X155.9877Y182.2115
    G1X156.1505Y182.6059
    G1X156.3050Y183.0018
    G1X156.4514Y183.3989
    G1X156.5896Y183.7971
    G1X156.7196Y184.1960
    G1X156.8416Y184.5954
    G1X156.9555Y184.9951
    G1X157.0614Y185.3950
    G1X157.1594Y185.7946
    G1X157.2495Y186.1940
    G1X157.3318Y186.5927
    G1X157.4064Y186.9907
    G1X157.4733Y187.3876
    G1X157.5327Y187.7834
    G1X157.5847Y188.1779
    G1X157.6294Y188.5707
    G1X157.6669Y188.9618
    G1X157.6973Y189.3511
    G1X157.7207Y189.7382
    G1X157.7372Y190.1231
    G1X157.7471Y190.5057
    G1X157.7503Y190.8857
    G1X157.7470Y191.2695
    G1X157.7370Y191.6557
    G1X157.7201Y192.0443
    G1X157.6963Y192.4349
    G1X157.6653Y192.8275
    G1X157.6272Y193.2219
    G1X157.5817Y193.6179
    G1X157.5289Y194.0153
    G1X157.4685Y194.4139
    G1X157.4005Y194.8136
    G1X157.3248Y195.2141
    G1X157.2412Y195.6152
    G1X157.1499Y196.0168
    G1X157.0506Y196.4185
    G1X156.9433Y196.8202
    G1X156.8280Y197.2216
    G1X156.7047Y197.6226
    G1X156.5732Y198.0228
    G1X156.4335Y198.4221
    G1X156.2857Y198.8202
    G1X156.1297Y199.2168
    G1X155.9656Y199.6118
    G1X155.7933Y200.0049
    G1X155.6128Y200.3958
    G1X155.4243Y200.7842
    G1X155.2276Y201.1700
    G1X155.0230Y201.5529
    G1X154.8104Y201.9327
    G1X154.5899Y202.3090
    G1X154.3615Y202.6817
    G1X154.1255Y203.0506
    G1X153.8818Y203.4153
    G1X153.6306Y203.7756
    G1X153.3719Y204.1314
    G1X153.1060Y204.4823
    G1X152.8330Y204.8282
    G1X152.5529Y205.1689
    G1X152.2660Y205.5041
    G1X151.9725Y205.8336
    G1X151.6723Y206.1573
    G1X151.3659Y206.4749
    G1X151.0533Y206.7863
    G1X150.7348Y207.0913
    G1X150.4105Y207.3897
    G1X150.0806Y207.6813
    G1X149.7454Y207.9661
    G1X149.4050Y208.2438
    G1X149.0598Y208.5143
    G1X148.7098Y208.7776
    G1X148.3554Y209.0334
    G1X147.9968Y209.2817
    G1X147.6342Y209.5223
    G1X147.2678Y209.7553
    G1X146.8980Y209.9805
    G1X146.5248Y210.1979
    G1X146.1487Y210.4073
    G1X145.7698Y210.6088
    G1X145.3883Y210.8023
    G1X145.0046Y210.9878
    G1X144.6188Y211.1652
    G1X144.2312Y211.3346
    G1X143.8420Y211.4959
    G1X143.4515Y211.6492
    G1X143.0599Y211.7945
    G1X142.6674Y211.9318
    G1X142.2744Y212.0611
    G1X141.8809Y212.1825
    G1X141.4872Y212.2961
    G1X141.0936Y212.4018
    G1X140.7002Y212.4998
    G1X140.3072Y212.5901
    G1X139.9149Y212.6729
    G1X139.5235Y212.7481
    G1X139.1331Y212.8159
    G1X138.7440Y212.8764
    G1X138.3562Y212.9296
    G1X137.9701Y212.9758
    G1X137.5857Y213.0150
    G1X137.2032Y213.0472
    G1Z0.0000
    G1X135.5253Y213.1107
    G1X133.0867Y212.9765
    G1X130.6704Y212.5739
    G1X128.3200Y211.9103
    G1Z-4.7650F762.0
    G1X127.9441Y211.7776F2667.0
    G1X127.5685Y211.6375
    G1X127.1935Y211.4898
    G1X126.8192Y211.3345
    G1X126.4460Y211.1715
    G1X126.0739Y211.0009
    G1X125.7033Y210.8225
    G1X125.3343Y210.6365
    G1X124.9672Y210.4427
    G1X124.6023Y210.2412
    G1X124.2396Y210.0320
    G1X123.8796Y209.8152
    G1X123.5223Y209.5907
    G1X123.1681Y209.3586
    G1X122.8172Y209.1190
    G1X122.4698Y208.8719
    G1X122.1261Y208.6173
    G1X121.7864Y208.3554
    G1X121.4508Y208.0862
    G1X121.1198Y207.8099
    G1X120.7933Y207.5265
    G1X120.4717Y207.2362
    G1X120.1553Y206.9391
    G1X119.8441Y206.6352
    G1X119.5384Y206.3249
    G1X119.2384Y206.0081
    G1X118.9444Y205.6851
    G1X118.6564Y205.3560
    G1X118.3748Y205.0210
    G1X118.0996Y204.6804
    G1X117.8310Y204.3341
    G1X117.5692Y203.9826
    G1X117.3144Y203.6259
    G1X117.0667Y203.2643
    G1X116.8263Y202.8980
    G1X116.5932Y202.5272
    G1X116.3677Y202.1522
    G1X116.1497Y201.7731
    G1X115.9395Y201.3902
    G1X115.7371Y201.0038
    G1X115.5426Y200.6140
    G1X115.3560Y200.2211
    G1X115.1775Y199.8254
    G1X115.0071Y199.4270
    G1X114.8449Y199.0264
    G1X114.6908Y198.6236
    G1X114.5450Y198.2189
    G1X114.4074Y197.8126
    G1X114.2780Y197.4050
    G1X114.1568Y196.9962
    G1X114.0439Y196.5865
    G1X113.9392Y196.1762
    G1X113.8427Y195.7655
    G1X113.7542Y195.3546
    G1X113.6739Y194.9437
    G1X113.6017Y194.5331
    G1X113.5374Y194.1230
    G1X113.4810Y193.7137
    G1X113.4324Y193.3053
    G1X113.3916Y192.8980
    G1X113.3585Y192.4921
    G1X113.3328Y192.0877
    G1X113.3147Y191.6850
    G1X113.3039Y191.2843
    G1X113.3003Y190.8857
    G1X113.3036Y190.5057
    G1X113.3134Y190.1231
    G1X113.3300Y189.7382
    G1X113.3534Y189.3511
    G1X113.3837Y188.9618
    G1X113.4212Y188.5707
    G1X113.4659Y188.1779
    G1X113.5179Y187.7834
    G1X113.5773Y187.3876
    G1X113.6443Y186.9907
    G1X113.7189Y186.5927
    G1X113.8012Y186.1940
    G1X113.8913Y185.7946
    G1X113.9892Y185.3950
    G1X114.0951Y184.9951
    G1X114.2091Y184.5954
    G1X114.3310Y184.1960
    G1X114.4611Y183.7971
    G1X114.5993Y183.3989
    G1X114.7456Y183.0018
    G1X114.9002Y182.6059
    G1X115.0629Y182.2115
    G1X115.2338Y181.8189
    G1X115.4130Y181.4282
    G1X115.6002Y181.0398
    G1X115.7957Y180.6538
    G1X115.9992Y180.2706
    G1X116.2107Y179.8903
    G1X116.4303Y179.5133
    G1X116.6578Y179.1397
    G1X116.8931Y178.7699
    G1X117.1362Y178.4040
    G1X117.3870Y178.0423
    G1X117.6453Y177.6851
    G1X117.9110Y177.3325
    G1X118.1841Y176.9849
    G1X118.4643Y176.6423
    G1X118.7515Y176.3052
    G1X119.0456Y175.9736
    G1X119.3464Y175.6477
    G1X119.6538Y175.3279
    G1X119.9675Y175.0141
    G1X120.2874Y174.7068
    G1X120.6132Y174.4060
    G1X120.9448Y174.1119
    G1X121.2820Y173.8246
    G1X121.6245Y173.5444
    G1X121.9722Y173.2714
    G1X122.3248Y173.0056
    G1X122.6820Y172.7473
    G1X123.0437Y172.4966
    G1X123.4095Y172.2535
    G1X123.7794Y172.0181
    G1X124.1529Y171.7906
    G1X124.5300Y171.5711
    G1X124.9102Y171.3595
    G1X125.2934Y171.1560
    G1X125.6794Y170.9606
    G1X126.0679Y170.7733
    G1X126.4585Y170.5942
    G1X126.8512Y170.4232
    G1X127.2456Y170.2605
    G1X127.6415Y170.1060
    G1X128.0386Y169.9596
    G1X128.4367Y169.8214
    G1X128.8356Y169.6913
    G1X129.2351Y169.5694
    G1X129.6348Y169.4555
    G1X130.0346Y169.3496
    G1X130.4343Y169.2516
    G1X130.8336Y169.1615
    G1X131.2324Y169.0792
    G1X131.6303Y169.0046
    G1X132.0273Y168.9377
    G1X132.4231Y168.8782
    G1X132.8175Y168.8262
    G1X133.2104Y168.7816
    G1X133.6015Y168.7441
    G1X133.9907Y168.7137
    G1X134.3779Y168.6903
    G1X134.7628Y168.6738
    G1X135.1453Y168.6639
    G1X135.5253Y168.6607
    G0Z5.0800
    G0Y136.1393
    G1Z0.0000F762.0
    G1X133.2199Y136.0194F2667.0
    G1X130.9394Y135.6611
    G1Z-4.7650F762.0
    G1X130.5584Y135.5772F2667.0
    G1X130.1767Y135.4861
    G1X129.7943Y135.3877
    G1X129.4116Y135.2819
    G1X129.0286Y135.1686
    G1X128.6457Y135.0477
    G1X128.2630Y134.9193
    G1X127.8806Y134.7832
    G1X127.4990Y134.6394
    G1X127.1181Y134.4879
    G1X126.7384Y134.3286
    G1X126.3599Y134.1615
    G1X125.9830Y133.9866
    G1X125.6078Y133.8039
    G1X125.2346Y133.6134
    G1X124.8637Y133.4151
    G1X124.4952Y133.2091
    G1X124.1293Y132.9953
    G1X123.7664Y132.7738
    G1X123.4067Y132.5447
    G1X123.0503Y132.3080
    G1X122.6976Y132.0637
    G1X122.3487Y131.8120
    G1X122.0039Y131.5530
    G1X121.6634Y131.2867
    G1X121.3275Y131.0133
    G1X120.9964Y130.7328
    G1X120.6702Y130.4454
    G1X120.3492Y130.1512
    G1X120.0336Y129.8504
    G1X119.7236Y129.5430
    G1X119.4194Y129.2294
    G1X119.1212Y128.9096
    G1X118.8292Y128.5837
    G1X118.5436Y128.2521
    G1X118.2645Y127.9148
    G1X117.9921Y127.5721
    G1X117.7265Y127.2242
    G1X117.4679Y126.8713
    G1X117.2165Y126.5135
    G1X116.9724Y126.1512
    G1X116.7357Y125.7844
    G1X116.5064Y125.4136
    G1X116.2848Y125.0388
    G1X116.0709Y124.6603
    G1X115.8648Y124.2784
    G1X115.6665Y123.8933
    G1X115.4762Y123.5052
    G1X115.2939Y123.1144
    G1X115.1196Y122.7211
    G1X114.9534Y122.3255
    G1X114.7953Y121.9280
    G1X114.6454Y121.5287
    G1X114.5035Y121.1279
    G1X114.3698Y120.7258
    G1X114.2443Y120.3227
    G1X114.1268Y119.9188
    G1X114.0174Y119.5144
    G1X113.9161Y119.1096
    G1X113.8227Y118.7046
    G1X113.7373Y118.2999
    G1X113.6598Y117.8954
    G1X113.5901Y117.4915
    G1X113.5281Y117.0884
    G1X113.4738Y116.6862
    G1X113.4271Y116.2852
    G1X113.3879Y115.8856
    G1X113.3561Y115.4875
    G1X113.3315Y115.0912
    G1X113.3141Y114.6968
    G1X113.3037Y114.3044
    G1X113.3003Y113.9143
    G1X113.3036Y113.5343
    G1X113.3134Y113.1518
    G1X113.3300Y112.7669
    G1X113.3534Y112.3797
    G1X113.3837Y111.9905
    G1X113.4212Y111.5994
    G1X113.4659Y111.2065
    G1X113.5179Y110.8121
    G1X113.5773Y110.4163
    G1X113.6443Y110.0193
    G1X113.7189Y109.6214
    G1X113.8012Y109.2226
    G1X113.8913Y108.8233
    G1X113.9892Y108.4237
    G1X114.0951Y108.0238
    G1X114.2091Y107.6241
    G1X114.3310Y107.2246
    G1X114.4611Y106.8257
    G1X114.5993Y106.4276
    G1X114.7456Y106.0305
    G1X114.9002Y105.6346
    G1X115.0629Y105.2402
    G1X115.2338Y104.8475
    G1X115.4130Y104.4569
    G1X115.6002Y104.0684
    G1X115.7957Y103.6825
    G1X115.9992Y103.2992
    G1X116.2107Y102.9190
    G1X116.4303Y102.5419
    G1X116.6578Y102.1684
    G1X116.8931Y101.7986
    G1X117.1362Y101.4327
    G1X117.3870Y101.0710
    G1X117.6453Y100.7138
    G1X117.9110Y100.3612
    G1X118.1841Y100.0136
    G1X118.4643Y99.6710
    G1X118.7515Y99.3339
    G1X119.0456Y99.0022
    G1X119.3464Y98.6764
    G1X119.6538Y98.3565
    G1X119.9675Y98.0428
    G1X120.2874Y97.7355
    G1X120.6132Y97.4347
    G1X120.9448Y97.1405
    G1X121.2820Y96.8533
    G1X121.6245Y96.5731
    G1X121.9722Y96.3000
    G1X122.3248Y96.0343
    G1X122.6820Y95.7760
    G1X123.0437Y95.5252
    G1X123.4095Y95.2822
    G1X123.7794Y95.0468
    G1X124.1529Y94.8193
    G1X124.5300Y94.5998
    G1X124.9102Y94.3882
    G1X125.2934Y94.1847
    G1X125.6794Y93.9893
    G1X126.0679Y93.8020
    G1X126.4585Y93.6229
    G1X126.8512Y93.4519
    G1X127.2456Y93.2892
    G1X127.6415Y93.1347
    G1X128.0386Y92.9883
    G1X128.4367Y92.8501
    G1X128.8356Y92.7200
    G1X129.2351Y92.5981
    G1X129.6348Y92.4842
    G1X130.0346Y92.3783
    G1X130.4343Y92.2803
    G1X130.8336Y92.1902
    G1X131.2324Y92.1079
    G1X131.6303Y92.0333
    G1X132.0273Y91.9663
    G1X132.4231Y91.9069
    G1X132.8175Y91.8549
    G1X133.2104Y91.8102
    G1X133.6015Y91.7728
    G1X133.9907Y91.7424
    G1X134.3779Y91.7190
    G1X134.7628Y91.7024
    G1X135.1453Y91.6926
    G1X135.5253Y91.6893
    G1X135.9053Y91.6926
    G1X136.2879Y91.7024
    G1X136.6728Y91.7190
    G1X137.0599Y91.7424
    G1X137.4491Y91.7728
    G1X137.8403Y91.8102
    G1X138.2331Y91.8549
    G1X138.6275Y91.9069
    G1X139.0233Y91.9663
    G1X139.4203Y92.0333
    G1X139.8183Y92.1079
    G1X140.2170Y92.1902
    G1X140.6163Y92.2803
    G1X141.0160Y92.3783
    G1X141.4158Y92.4842
    G1X141.8156Y92.5981
    G1X142.2150Y92.7200
    G1X142.6139Y92.8501
    G1X143.0121Y92.9883
    G1X143.4092Y93.1347
    G1X143.8051Y93.2892
    G1X144.1995Y93.4519
    G1X144.5921Y93.6229
    G1X144.9828Y93.8020
    G1X145.3712Y93.9893
    G1X145.7572Y94.1847
    G1X146.1404Y94.3882
    G1X146.5207Y94.5998
    G1X146.8977Y94.8193
    G1X147.2713Y95.0468
    G1X147.6411Y95.2822
    G1X148.0070Y95.5252
    G1X148.3686Y95.7760
    G1X148.7259Y96.0343
    G1X149.0784Y96.3000
    G1X149.4261Y96.5731
    G1X149.7686Y96.8533
    G1X150.1058Y97.1405
    G1X150.4374Y97.4347
    G1X150.7632Y97.7355
    G1X151.0831Y98.0428
    G1X151.3968Y98.3565
    G1X151.7042Y98.6764
    G1X152.0050Y99.0022
    G1X152.2991Y99.3339
    G1X152.5864Y99.6710
    G1X152.8666Y100.0136
    G1X153.1396Y100.3612
    G1X153.4053Y100.7138
    G1X153.6637Y101.0710
    G1X153.9144Y101.4327
    G1X154.1575Y101.7986
    G1X154.3928Y102.1684
    G1X154.6203Y102.5419
    G1X154.8399Y102.9190
    G1X155.0515Y103.2992
    G1X155.2550Y103.6825
    G1X155.4504Y104.0684
    G1X155.6377Y104.4569
    G1X155.8168Y104.8475
    G1X155.9877Y105.2402
    G1X156.1505Y105.6346
    G1X156.3050Y106.0305
    G1X156.4514Y106.4276
    G1X156.5896Y106.8257
    G1X156.7196Y107.2246
    G1X156.8416Y107.6241
    G1X156.9555Y108.0238
    G1X157.0614Y108.4237
    G1X157.1594Y108.8233
    G1X157.2495Y109.2226
    G1X157.3318Y109.6214
    G1X157.4064Y110.0193
    G1X157.4733Y110.4163
    G1X157.5327Y110.8121
    G1X157.5847Y111.2065
    G1X157.6294Y111.5994
    G1X157.6669Y111.9905
    G1X157.6973Y112.3797
    G1X157.7207Y112.7669
    G1X157.7372Y113.1518
    G1X157.7471Y113.5343
    G1X157.7503Y113.9143
    G1X157.7469Y114.3026
    G1X157.7367Y114.6931
    G1X157.7194Y115.0857
    G1X157.6951Y115.4802
    G1X157.6635Y115.8765
    G1X157.6246Y116.2744
    G1X157.5784Y116.6736
    G1X157.5246Y117.0741
    G1X157.4632Y117.4755
    G1X157.3941Y117.8777
    G1X157.3172Y118.2806
    G1X157.2325Y118.6838
    G1X157.1400Y119.0871
    G1X157.0395Y119.4904
    G1X156.9310Y119.8934
    G1X156.8144Y120.2959
    G1X156.6898Y120.6976
    G1X156.5572Y121.0984
    G1X156.4165Y121.4979
    G1X156.2676Y121.8960
    G1X156.1107Y122.2924
    G1X155.9457Y122.6869
    G1X155.7727Y123.0792
    G1X155.5917Y123.4690
    G1X155.4027Y123.8562
    G1X155.2058Y124.2405
    G1X155.0010Y124.6217
    G1X154.7885Y124.9995
    G1X154.5683Y125.3737
    G1X154.3404Y125.7440
    G1X154.1051Y126.1103
    G1X153.8624Y126.4723
    G1X153.6124Y126.8297
    G1X153.3553Y127.1824
    G1X153.0912Y127.5302
    G1X152.8202Y127.8728
    G1X152.5425Y128.2100
    G1X152.2582Y128.5417
    G1X151.9676Y128.8677
    G1X151.6708Y129.1877
    G1X151.3679Y129.5016
    G1X151.0592Y129.8092
    G1X150.7449Y130.1105
    G1X150.4252Y130.4051
    G1X150.1002Y130.6930
    G1X149.7702Y130.9741
    G1X149.4353Y131.2482
    G1X149.0960Y131.5151
    G1X148.7522Y131.7749
    G1X148.4043Y132.0274
    G1X148.0525Y132.2724
    G1X147.6970Y132.5100
    G1X147.3381Y132.7401
    G1X146.9760Y132.9625
    G1X146.6108Y133.1773
    G1X146.2430Y133.3844
    G1X145.8726Y133.5837
    G1X145.5000Y133.7753
    G1X145.1252Y133.9591
    G1X144.7487Y134.1351
    G1X144.3706Y134.3033
    G1X143.9912Y134.4638
    G1X143.6106Y134.6165
    G1X143.2291Y134.7615
    G1X142.8469Y134.8988
    G1X142.4642Y135.0284
    G1X142.0812Y135.1504
    G1X141.6982Y135.2649
    G1X141.3153Y135.3719
    G1X140.9328Y135.4715
    G1X140.5508Y135.5637
    G1X140.1695Y135.6487
    G1X139.7891Y135.7265
    G1Z0.0000
    G1X137.6672Y136.0359
    G1X135.5253Y136.1393
    G0Z5.0800
    G0Z20.3200
    G0X0.0000Y0.0000
    M02
    #4 cpalms, Jul 8, 2020
    Edited your replies above down into [ code ] blocks to help declutter, but checkout that Attach button :)
    Your file is a whole bunch of G1 moves... Not Arcs. Arcs are G2/3 moves. Use a post the actually generates Arcs
    If you want to use interpolated polylines (G1s) instead, tune up acceleration so it can speed through the short line segments, but actual Arcs will run a little better
    #5 Peter Van Der Walt, Jul 8, 2020
  6. cpalms
    cpalms New
    After looking more closely, the majority of my gcode has been using g1s, the question still remains why the differencein performance? After increasing accel to 600 and then to 800 theres almost no improvement.
    Try it at like 5000 or 10000? from 600-800 isnt a major bump
    Even still though...
    G1s are far from ideal as you have a lot more serial data to move as well, which could also be bottlenecking. Grbl's planner has to evaluate each of those commands, etc (Instead of one G2/3 command, and letting Grbl do its thing, there's a lot more going on now)
    #7 Peter Van Der Walt, Jul 8, 2020
  8. cpalms
    cpalms New
    Even at 5000 still barely moving, while I can understand my code is not ideal. Looking through various files of over the past year, I see the same code and know that if I were to run those with this current performance I would have nothing but broken endmills.
  9. cpalms
    cpalms New
    I will say, it was nice to see accel at 5000 with no stalling and that definitely gives me hope. I've already ordered a bigger machine and was hoping I could transform this one into something faster.
    Not sure what changed, maybe older files had different segment resolution, settings changed, windows update, software updates, etc. regardless, g2/3 are better.
  11. cpalms
    cpalms New
    I think there's some confusion here. Quite simply, why does a setup that has significantly more potential hang up on something a shapeoko did without fault?
  12. Peter Van Der Walt
    Not sure what you mean by that. Both runs the same Grbl
  13. cpalms
    cpalms New
    Right! So what could be faulty? Should they run identically with the same/ very similar parameters?
    While I agree, my files could definitely be optimized further, honestly I never saw much of a problem. I can't fathom what the difference is, and honestly I'm disappointed. I went the lazy/expensive way to upgrading my machine and its still down.
  14. Peter Van Der Walt
    Yes, all else being equal too.
    Same streaming application too... PC specs suited to OpenbuildsCONTROL?
    If pc is a little slow, try UGS2. Refer docs.openbuilds.com > software
  15. cpalms
    cpalms New
    I can't get picsender to connect this controller. Will try ugs when I get home from work, thanks.
  16. David the swarfer
    I have not seen a mention of what you are using to generate the Gcode but do see a T1 in your code.
    since GRBL does not support tool calls I must ask if you are using the correct postprocessor for GRBL?
    Have you returned the arc variables to default? Those values can seriously affect what GRBL does with junctions.
    gnea/grbl
    Your line segments are all about 0.41mm long, if you cannot generate real arcs then set the segments to be about the same as the radius of the cutter.
    I just ran the code on my Sphinx testbed and it does not appear to be slow at all.
    OpenbuildsCONTROL on an 8 year old i3 @ 3.4Ghz -> Arduino Uno with GRBL 1.1h
    cpalms and Peter Van Der Walt like this.
  17. cpalms
    cpalms New
    So, it turns out the open builds software is no good on that computer. Will try to figure out why picsender doesn't see the blackbox or experiment with ugs. Worse case grab a new computer for this. Thanks for your help with confirming its not a black box, or wiring issue. Will also try to figure out why aspire isn't giving me g2/g3 when I use the arc fit, settings.
  18. Peter Van Der Walt
    In control > Troubleshooting tab > Application Diagnostics you can turn off the more resource heavy features
    cpalms likes this.
  19. Peter Van Der Walt
    Screenshot
    cpalms likes this.
  20. David the swarfer
    add a GT710 graphic card? cheapest video card ever but it transformed my old PC (-:
    (of course a GT1050 or bigger would be better but if a 710 is enough...)
  21. cpalms
    cpalms New
    It's an old laptop. I have some desktops sitting around, will look into them.
  22. cpalms
    cpalms New
    Still too heavy for this machine, but ugs did perform. Thanks again for helping me get this sorted. I never even considered the computer being a problem.
