Inverted Output from Control
Discussion in 'General Talk' started by Wendel99, Jan 2, 2024.
  1. Wendel99
    Wendel99 New
    I have rebuilt my plasma table, and replaced all the old motors with new nema23's
    I have calibrated the table and everything works as it should, other then the fact then when I did a test run of the Hello World I get it in a mirror image(I have a sharpie in my torch holder for now)
    I tried to reverse the x and y in the Step Direction options, but it is still running inversed.
    I have a blackbox x4.
    Any idea what could be causing this?
  2. Misterg
    Misterg Veteran
    One of the axes is inverted:
    Check which direction it moves when jogging and change what ever step direction you need to get X+ moving to the right and Y+ moving the cutter away from you
  3. Wendel99
    Wendel99 New
    ah, so that's why it's still inverted when I flipped both the axis... I'll try that
    thanks!
