Interface UI Changes
Discussion in 'Interfaces' started by Jonathon Kwekel, Dec 23, 2021.
  1. Jonathon Kwekel
    Hi there,
    Currently running an ACRO 1010 with NEJE laser, Blackbox Motion System and Interface. Wondering if there is a way to change the color of the x-axis UI readout? The safety glasses for the laser are a dark green and block nearly 100% of the red light emitted from the readout (as well as the keyboard backlighting on my laptop). It's a minor inconvenience when trying to center the laser, but if there was a way to change the color to white/yellow or something I'd like to. (I have no problem with changing config files if needed, have programmed a couple controllers for other projects as well)
    Good suggestion thanks. It has been on the todo, will follow up :)
    Giarc likes this.
