Interface trouble
Discussion in 'Interfaces' started by David Mullins, Mar 28, 2021.
  1. David Mullins
    I can start a job with the Interface and after about an hour and half run it just stops and says invalid file system for the USB drive.
    Anyone have any ideas?
    1) add external power via the USB-C port as a test (spare UAB phone charger for example) - might be just borderline low voltage from an older controller.
    2) try formatting flashdrive
    3) try different flashdrive
  3. David Mullins
    Finally got to try a few things but no luck. Formatted flash drive several times. Run with external power using the usb-c connection. It just stops at random times on jobs. Then says invalid file system on flashdrive. I can remove flash drive and place back in and it sees the files and will start again but quit
    Please check in with http://support.openbuilds.com/support/home and they will be happy to assist.
