Interface saving GRBL profile
Discussion in 'CNC Mills/Routers' started by Lybrary, Aug 30, 2022.
  1. Lybrary
    Lybrary New
    Is there a way to save the GRBL profile from the Interface? I see in the menu load and edit the GRBL profile. I have edited the profile and would like to save it but I can't see how.
    Its saved automatically, and that gets saved to the EEPROM on the BlackBox's microcontroller (Grbl does that - learn more here Home · gnea/grbl Wiki)
    If you want a backup for safekeeping - use CONTROL > Grbl Settings tab > Backup Grbl Settings button on the top toolbar
  3. Lybrary
    Lybrary New
    I don't have a computer that I can connect. That is why I use Interface. Is there no way to save it to the flash drive using Interface?
    No there is not. You can write down the parameters as a makeshift backup in case you do overwrite them at some point with incorrect values
  5. Lybrary
    Lybrary New
    Is there some technical reason why this can't happen or is not so easy to do? I mean if one offers an edit function it would kind of make sense to have a save, too.
    Thanks for the suggestion
