Interface (probe, bit diameter)
Discussion in 'Interfaces' started by Ian Cross, Mar 18, 2022.
  1. Ian Cross
    Ian Cross New
    I'm using the O/B interface and was planning on using a 1/2" V bit (1/4" shank). However, when I set up to probe the first step 'bit diameter' only goes up to 1/4". Is it still ok to use if I leave it on 1/4" and continue to probe?
    I'm new to this so it's all learning at the moment.
    You should not use V-bits to zero XY. Use a dowel pin or regular endmill to zero XY. Then fit the V-bit and ONLY zero the Z axis.
  3. Ian Cross
    Ian Cross New
    Hi Peter. Great. Thanks for getting back to me. I'll try it like that.
    Ian.
