Interface hangs then loses XYZ zero
Discussion in 'Interfaces' started by Saul Goodman, Apr 9, 2022.
  1. Saul Goodman
    I've had this happen a few times. I know it's not job related as I've run the same job multiple times without issue.
    Basically, in the middle of a job, XYZ axis will all stop moving, spindle stays running and g-code lines flash at the bottom (can't tell if they're different or the same one flashing) but otherwise operation looks normal as far as the screen and alarms go (no alarms). What I'll have to do is cancel the current job and restart it.
    The problem, besides having to restart the job (obviously) is that it loses XYZ Zero. This is especially bad if I have multiple tool-paths and have no way to 100% accurately return to the original zero.
    Has anyone else had this? I thought it could be related to static or something else but I can't seem to pin it down.
    Zero is stored in Grbl EEPROM. Rehome to re-establish
    Regarding the other issues, make sure your Interface Firmware is up to date (v1.51 or newer)
    If the DROs update but the machine doesn't move, i would also check the PSU (if power cuts out movement may stop) and stepper drivers (fault LEDs on?)
