Interface feed speed
Discussion in 'Interfaces' started by CaptainSawdust, Feb 20, 2022.
  1. CaptainSawdust
    Wondering if anyone can help.
    Using my new interface with the Xpro4. Setup seems to go fine but running a job from the supplied USB and one of my own results in an incredibly slow step feed. This file is set to run at 1000mm/m but I'm getting maybe 100.
    The jog speed is fine making me think connection's are ok.
    Took a quick video to hopefully illustrate the issue.
    Wondering what I'm doing wrong. Can anyone help?
    Check your Grbl parameters, for example the Max Rate parameters.
    Also check your CAM setup - avoid segments that are impossibly short (ie turn on smoothing)
  3. CaptainSawdust
    Thanks Peter. Could you suggest what the max rate should be? Very new to gbrl.
    Also its cutting a straight line so the segment shouldn't be a factor.
    Thanks again
    Depends what machine you have? Also, the xPro has lower current drivers than our BlackBox so derate accordingly from our profiles
  5. CaptainSawdust
    Thanks again.
