INTERFACE CNC Touch Controller
Discussion in 'Interfaces' started by gsw, Jan 25, 2021.
  1. gsw
    gsw New
    I got my new interface up and going, but am i going to need to load my code every time i use it! on my computer all i need to do is hit run each time, any views on this
    Not sure I understand? The point is that the Interface replaces the PC? I.e for folks who want to run the jobs directly on the machine, because the PC is in another room, they want to keep it away from the dust, etc
    See docs:interface:usage-instructions [OpenBuilds Documentation]
  3. gsw
    gsw New
    ok when i start the interface i go and get the file where it says load file from usb flash drive, then i run file. when the cycle gets done and i say ok then im ready to run it again i have to go get the same file from the usb flash drive to run it again. it looks like it should stay loaded until l am done with it. i run my project as a sealer so i run the same job over and over.
    #3 gsw, Jan 25, 2021
    Ok thanks for the suggestion, will consider
  5. Peter Sesselmann
    I would like this too...
