Interface can't update firmware via wifi
Discussion in 'Interfaces' started by JayMcD, Apr 18, 2022.
  1. JayMcD
    JayMcD New
    Gives error message - Error contacting server - cannot update. The wifi is connected and working fine. I can get to the interface via web browser... ?????
    Always give an error on boot as well - unable to check for firmware.
    Is the problem at the server end ? Has the server changed or ?
    If you are on v1.51 you are up to date.
    Temporary server outages are expected from time to time yes
  3. JayMcD
    JayMcD New
    I am at 1.51 - thanks. That said, this “temporary outage” has been happening for over a week, that is why I wondered if it was something more.
  5. JayMcD
    JayMcD New
    Yes. From other devices - no problem. Super odd. Still nothing from the interface though.
    No other reports of similar. Will let you know if anyone else reports an issue
    OK we discovered the cause of the issue: Github replaced a root certicate store without sufficient notice.
    We have released Firmware v1.52 to address the issue - however you won't be able to update to 1.52 via Wifi, you'll have to use Method 2 or 3 from docs:interface:firmware-update [OpenBuilds Documentation] to get onto the version that can access the servers with the updated root certificate, and then from there forth you should not be getting the error anymore
    Let me know if that worked for you
  8. JayMcD
    JayMcD New
    Ok. I thought there might have been a server side issue. Thanks!
  9. krazeekirk
    I am having that same issue, will follow your instructions to update. Thank you
    krazeekirk likes this.
  11. krazeekirk
    Fixed , thanks
