I started to work on getting this LEAD 1515 up and working finally. I decided to add the Interface controller to the machine following the Blackbox v2.7. Have the Jumpers set exactly as shown in the pictures and put it back together and now I can only move Y1 motor, Y2 does not move. Power off and switch the Y1 with Y2 and then power up. Now Y1 will not move, but Y2 will. Is there something I am missing? All other axis work correctly when using the Interface controller. I even had v1.47 firmware installed. Side Note: USB Card is not detected on startup. Its hit or miss on every bootup/restart. Using Fat32 7.48 / 1.36 used. v1.47 bin file is located on the usb. But, USB cant be located. Side Note2: WiFi is showing wrong ip address block. restart and also hit or miss if it finds the network correctly? Keeps defaulting to 192.168.4.1 Interface-003067.
