Installed new Blackbox
Discussion in 'OpenBuilds Forum Help' started by Bobbolink, Sep 4, 2020.
  1. Bobbolink
    Bobbolink New
    Ok...... now what? Wired up new box per video for workbee 1510 had power to Y and Z. Shut down computer for a while and restarted it. Selected FTDI USB to Serial COM5 Picked Connect .....and nothing happening; will not let me select anything. I am really getting frustrated fought the Xpro V4 for a month now this with the Blackbox.
    [18:18:54] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [18:18:54] [ Websocket ] Bidirectional Websocket Interface Started
    [18:18:55] [ update ] Checking for Updates
    [18:18:55] [ update ] You are already running OpenBuilds CONTROL 1.0.246
    [18:19:27] [ connect ] PORT INFO: Port is now open: COM5 - Attempting to detect Firmware
    [18:19:27] [ connect ] Checking for firmware on COM5
    [18:19:27] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [18:19:28] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [18:19:29] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [18:19:31] [ connect ] ERROR!: No supported firmware detected - you need a controller with Grbl 1.1x on it, or there is a problem with your controller. Closing port COM5
    [18:19:31] [ disconnect ] PORT INFO: Port closed
