Is there a way to set incremental instead of continuous jog on the Interface? I use this for some repetitive positioning relative to home (0,0) and don't want to lose that functionality in the process of incorporating the interface into my workflow. Thanks, Chris
Just a toggle in settings that would allow the jog to be speed percentage or defined mm (still 0-100 so you could use the +/- ) would be awesome.
I just got mine & would love incremental jog as well. The switch is in the control software & that's what I use there.
Once you get a https://docs.openbuilds.com/xyzprobe you'll never miss jogging again. Its really our recommended way to zero
I already have the tool. It's handy to have increment to move x inches to see where the cut will go, much like framing on my laser gantry. I'm building and tramming my spoilboard and needed to shift it x inches right to make sure it wouldn't hit the y gantry. Found out the dust boot takes away some x movement and really the 1010 can safely go 28" wide instead of 29". I still think increment is a nice option to have just like the software.
