Impossible Arc
Discussion in 'CNC Mills/Routers' started by Chris Trapani, Apr 18, 2021.
  1. Chris Trapani
    I keep getting an error on an impossible arc but the diameter is 0.9 inches and shouldn't be a problem. I was joining an arc, lines, and a circle. Here is the code, what could be the problem.
    T1
    G17
    G20
    G90
    G0Z0.200
    G0X0.000Y0.000
    S15000M3
    G0X3.360Y7.609Z0.200
    G1Z-0.188F10.0
    G3X3.094Y4.560I6.379J-2.092F40.0
    G2X5.192Y3.282I0.545J-1.466
    G2X3.894Y1.552I-1.552J-0.187
    G2X2.109Y2.774I-0.255J1.543
    G2X2.356Y7.816I13.497J1.867
    G2X2.622Y8.216I0.530J-0.065
    G2X3.005Y8.253I0.239J-0.469
    G2X3.322Y8.021I-0.132J-0.514
    G2X3.360Y7.609I-0.485J-0.252
    G1Z-0.375F10.0
    G1Z-0.563F10.0
    G1Z-0.750F10.0
    G0Z0.200
    G0X0.000Y0.000
    M5
    G0Z0.200
    G0X0.000Y0.000
    M2
    If Grbl says the Arc cannot be created, it cannot be created. Some of the values are just off. Is this hand coded or out of a CAM. If its from a CAM, which are you using, and are you sure its Grbl compatible?
  3. Chris Trapani
    It is from Carveco Maker and it is one of the drop down selections. I guess it confuses me since it can carve the inside of a circle of 1/2 inch diameter but can't make a larger curve cut. Can it have to do with how the vectors were joined?
    In that case, if you used the Grbl post, direct the possible bug at Carveco Support & Training: Get help when you need it to address, thanks - as they edit the built in posts
  5. David the swarfer
    the arc radii are different by 0.0007" which is enough to make it impossible fro GRBL to draw.
    You can try setting your post to use more digits of precision, it is currently using 3, but if it used 5 there will probably be enough precision to remove this error.
  6. Chris Trapani
  7. Chris Trapani
    Thank you
