Ideas to increase Z-axis cutting height in the Workbee cnc ?
Discussion in 'Concepts and Ideas' started by Exodon, Oct 3, 2018.
  1. Welderben
    Welderben New
    I was also working on this issue. What I have come up with is a simple modification of the y axis end plates. (The ones at front and back of the machine that tie the c beams on either side to the smaller cross beams). I have modified the original dxf for these, adding 50.8 mm to the length. I have kept the hole patterns the same in respect to what they tie into. These are going to be killed out of 1/2” aluminum plate I have just sitting around. I could share the fusion file if you guys would like.
  2. Welderben
    Welderben New
  3. MrBoJangles78
    I would like to see the dxf file. May one day mill them myself if I find current z axis not suiting my needs. An extra inch from these plates might come in handy!
  4. Welderben
    Welderben New
    It actually buys you two inches. I was looking at ways to do get the depth without the problem of changing the interaction between the x and y axis. The solution hit while having a midnight snack. I will share the tomorrow after I get off work. I will be mulling these this weekend( can’t right now because I blew a driver, and the replacement will not be here till tomorrow)
  5. Welderben
    Welderben New
    here is the file for the plates
    Alex Chambers and MrBoJangles78 like this.
  6. Alex Chambers
    Many thanks for this - could you please post this in the resources section so that it doesn't get lost?
    Alex :thumbsup:
  7. Welderben
    Welderben New
    I would love to, but how? I am kind of new here
    Alex Chambers likes this.
  8. Alex Chambers
    Click on menu, click on resources, click on add new resource - its fairly clear after that - type a description, upload your dxf the same as you did here. I'd do it for you but better if it has your name on it.
    Alex. :thumbsup:
  9. Welderben
    Welderben New
    This is done! Thanks Alex Chambers.
  10. ekek3d
    ekek3d New
    Hello Welderben,
    How did this pan out for your setup? Any update? This seems like the least invasive solution I've seen that still allows tiling a longer workpiece.
